[PATCH v2 1/1] riscv: additional crash information
If an exception occurs, the relocated program counter and return address are required for an analysis.
With this patch you get:
=> exception undefined
Unhandled exception: Illegal instruction EPC: 0000000080595908 RA: 000000008059c0c6 TVAL: 000000008030c01e EPC: 0000000080007908 RA: 000000008000e0c6 reloc adjusted
We can use the relocated addresses to find the involved functions in u.boot.map:
.text.do_undefined 0x0000000080007908 0x8 cmd/built-in.o .text.cmd_process 0x000000008000dfcc 0x11a common/built-in.o 0x000000008000dfcc cmd_process
If an exception occurs in an UEFI binary additionally the load addresses of the UEFI binaries are needed. With this patch:
=> setenv efi_selftest exception => bootefi selftest
Unhandled exception: Illegal instruction EPC: 000000008042e18a RA: 000000008042e18a TVAL: 000000008030c01e EPC: 000000007fea018a RA: 000000007fea018a reloc adjusted
UEFI image [0x0000000000000000:0xffffffffffffffff] '/\selftest' UEFI image [0x000000008042e000:0x000000008042e43f] pc=0x18a '/bug.efi'
The value pc=0x18a matches the position of the illegal instruction in efi_selftest_miniapp_exception.efi (loaded as /bug.efi);
asm volatile (".word 0xffffffff\n");
00000180 93 85 C5 11 1C 64 22 85 82 97 FF FF FF FF 1C 64
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Sean Anderson seanga2@gmail.com Tested-by: Sean Anderson seanga2@gmail.com --- v2: description of relocated addresses: %s/reloc/reloc adjusted/ --- arch/riscv/lib/interrupts.c | 57 +++++++++++++++++++++++-------------- 1 file changed, 35 insertions(+), 22 deletions(-)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 074c70ee77..cd47e64487 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -10,36 +10,43 @@ */
#include <common.h> +#include <efi_loader.h> #include <hang.h> #include <irq_func.h> #include <asm/ptrace.h> #include <asm/system.h> #include <asm/encoding.h>
+DECLARE_GLOBAL_DATA_PTR; + +static void show_efi_loaded_images(uintptr_t epc) +{ + efi_print_image_infos((void *)epc); +} + static void show_regs(struct pt_regs *regs) { #ifdef CONFIG_SHOW_REGS - printf("RA: " REG_FMT " SP: " REG_FMT " GP: " REG_FMT "\n", - regs->ra, regs->sp, regs->gp); - printf("TP: " REG_FMT " T0: " REG_FMT " T1: " REG_FMT "\n", - regs->tp, regs->t0, regs->t1); - printf("T2: " REG_FMT " S0: " REG_FMT " S1: " REG_FMT "\n", - regs->t2, regs->s0, regs->s1); - printf("A0: " REG_FMT " A1: " REG_FMT " A2: " REG_FMT "\n", - regs->a0, regs->a1, regs->a2); - printf("A3: " REG_FMT " A4: " REG_FMT " A5: " REG_FMT "\n", - regs->a3, regs->a4, regs->a5); - printf("A6: " REG_FMT " A7: " REG_FMT " S2: " REG_FMT "\n", - regs->a6, regs->a7, regs->s2); - printf("S3: " REG_FMT " S4: " REG_FMT " S5: " REG_FMT "\n", - regs->s3, regs->s4, regs->s5); - printf("S6: " REG_FMT " S7: " REG_FMT " S8: " REG_FMT "\n", - regs->s6, regs->s7, regs->s8); - printf("S9: " REG_FMT " S10: " REG_FMT " S11: " REG_FMT "\n", - regs->s9, regs->s10, regs->s11); - printf("T3: " REG_FMT " T4: " REG_FMT " T5: " REG_FMT "\n", - regs->t3, regs->t4, regs->t5); - printf("T6: " REG_FMT "\n", regs->t6); + printf("SP: " REG_FMT " GP: " REG_FMT " TP: " REG_FMT "\n", + regs->sp, regs->gp, regs->tp); + printf("T0: " REG_FMT " T1: " REG_FMT " T2: " REG_FMT "\n", + regs->t0, regs->t1, regs->t2); + printf("S0: " REG_FMT " S1: " REG_FMT " A0: " REG_FMT "\n", + regs->s0, regs->s1, regs->a0); + printf("A1: " REG_FMT " A2: " REG_FMT " A3: " REG_FMT "\n", + regs->a1, regs->a2, regs->a3); + printf("A4: " REG_FMT " A5: " REG_FMT " A6: " REG_FMT "\n", + regs->a4, regs->a5, regs->a6); + printf("A7: " REG_FMT " S2: " REG_FMT " S3: " REG_FMT "\n", + regs->a7, regs->s2, regs->s3); + printf("S4: " REG_FMT " S5: " REG_FMT " S6: " REG_FMT "\n", + regs->s4, regs->s5, regs->s6); + printf("S7: " REG_FMT " S8: " REG_FMT " S9: " REG_FMT "\n", + regs->s7, regs->s8, regs->s9); + printf("S10: " REG_FMT " S11: " REG_FMT " T3: " REG_FMT "\n", + regs->s10, regs->s11, regs->t3); + printf("T4: " REG_FMT " T5: " REG_FMT " T6: " REG_FMT "\n\n", + regs->t4, regs->t5, regs->t6); #endif }
@@ -69,8 +76,14 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs) else printf("Unhandled exception code: %ld\n", code);
- printf("EPC: " REG_FMT " TVAL: " REG_FMT "\n", epc, tval); + printf("EPC: " REG_FMT " RA: " REG_FMT " TVAL: " REG_FMT "\n", + epc, regs->ra, tval); + if (gd->flags & GD_FLG_RELOC) + printf("EPC: " REG_FMT " RA: " REG_FMT " reloc adjusted\n\n", + epc - gd->reloc_off, regs->ra - gd->reloc_off); + show_regs(regs); + show_efi_loaded_images(epc); hang(); }
-- 2.27.0
-- 2.27.0
On Sat, Aug 1, 2020 at 11:16 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
=> exception undefined Unhandled exception: Illegal instruction EPC: 0000000080595908 RA: 000000008059c0c6 TVAL: 000000008030c01e EPC: 0000000080007908 RA: 000000008000e0c6 reloc adjusted
=> setenv efi_selftest exception => bootefi selftest Unhandled exception: Illegal instruction EPC: 000000008042e18a RA: 000000008042e18a TVAL: 000000008030c01e EPC: 000000007fea018a RA: 000000007fea018a reloc adjusted UEFI image [0x0000000000000000:0xffffffffffffffff] '/\selftest' UEFI image [0x000000008042e000:0x000000008042e43f] pc=0x18a '/bug.efi'
asm volatile (".word 0xffffffff\n"); 00000180 93 85 C5 11 1C 64 22 85 82 97 FF FF FF FF 1C 64
Reviewed-by: Bin Meng bin.meng@windriver.com
Bin Meng
