[U-Boot] [PATCH] kbuild: define DO_DEPS_ONLY for u-boot.cfg to fix build error
Since 741e58e0fc8e (Create a .cfg file containing the CONFIG options used to build), all the Blackfin boards fail to build if the parallel (-j) option is passed.
$ make -s bf506f-ezkit_defconfig # # configuration written to .config # $ make -j8 CROSS_COMPILE=bfin-elf- scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h UPD include/config.h GEN include/autoconf.mk GEN include/autoconf.mk.dep CHK include/config/uboot.release CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CFG u-boot.cfg include/asm-offsets.h:3:43: fatal error: generated/generic-asm-offsets.h: No such file or directory compilation terminated. make: *** [u-boot.cfg] Error 1
When parsing header files for defined CONFIG options, DO_DEPS_ONLY must be defined to exclude generated headers that might not have been available yet.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Makefile | 2 +- scripts/Makefile.spl | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index bc47d98..da8cb05 100644 --- a/Makefile +++ b/Makefile @@ -876,7 +876,7 @@ endif # Create a file containing the configuration options the image was built with quiet_cmd_cpp_cfg = CFG $@ cmd_cpp_cfg = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) -ansi \ - -D__ASSEMBLY__ -x assembler-with-cpp -P -dM -E -o $@ $< + -DDO_DEPS_ONLY -D__ASSEMBLY__ -x assembler-with-cpp -P -dM -E -o $@ $<
MKIMAGEFLAGS_u-boot.img = -A $(ARCH) -T firmware -C none -O u-boot \ -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ea67137..fd572f4 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -167,7 +167,7 @@ all: $(ALL-y)
$(obj)/$(SPL_BIN).cfg: include/config.h $(call if_changed,cpp_cfg)
On 25 May 2015 at 21:51, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
Masahiro Yamada
