[U-Boot] [PATCH] doc: fix: Replace SPL_OF_PLATDATA with OF_PLATDATA in examples
The of-plat.rst file till this change has been using
This is at best misleading as SPL_OF_PLATDATA is always defined when we want to use this SPL tinification feature (also in U-Boot proper). As a result the OF_PLATDATA SPL specific code is also compiled in when U-Boot proper is build.
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com
doc/driver-model/of-plat.rst | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/doc/driver-model/of-plat.rst b/doc/driver-model/of-plat.rst index 0d3cd8c01e..a38e58e4d2 100644 --- a/doc/driver-model/of-plat.rst +++ b/doc/driver-model/of-plat.rst @@ -224,7 +224,7 @@ For example: #include <dt-structs.h>
struct mmc_platdata { - #if CONFIG_IS_ENABLED(SPL_OF_PLATDATA) + #if CONFIG_IS_ENABLED(OF_PLATDATA) /* Put this first since driver model will copy the data here */ struct dtd_mmc dtplat; #endif @@ -237,7 +237,7 @@ For example:
static int mmc_ofdata_to_platdata(struct udevice *dev) { - #if !CONFIG_IS_ENABLED(SPL_OF_PLATDATA) + #if !CONFIG_IS_ENABLED(OF_PLATDATA) /* Decode the device tree data */ struct mmc_platdata *plat = dev_get_platdata(dev); const void *blob = gd->fdt_blob; @@ -253,7 +253,7 @@ For example: { struct mmc_platdata *plat = dev_get_platdata(dev);
- #if CONFIG_IS_ENABLED(SPL_OF_PLATDATA) + #if CONFIG_IS_ENABLED(OF_PLATDATA) /* Decode the of-platdata from the C structures */ struct dtd_mmc *dtplat = &plat->dtplat;
@@ -308,7 +308,7 @@ The dt-structs.h file includes the generated file (include/generated//dt-structs.h) if CONFIG_SPL_OF_PLATDATA is enabled. Otherwise (such as in U-Boot proper) these structs are not available. This prevents them being used inadvertently. All usage must be bracketed with -#if CONFIG_IS_ENABLED(SPL_OF_PLATDATA). +#if CONFIG_IS_ENABLED(OF_PLATDATA).
The dt-platdata.c file contains the device declarations and is is built in spl/dt-platdata.c.
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Simon Glass sjg@chromium.org
Lukasz Majewski
