[RFC PATCH 0/1] net: xilinx: handle internal PHY/PCS
On Xilinx AXI Ethernet we can have both "internal" (PCS) and "external" phy's.
As per Xilinx SPEC's they should have different addresses on MDIO bus.
In Linux we have a phylink mechanism to handle this particular situation.
PCS has to be at least BMCR_ANENABLE after Core bringup.
Without this patch we can't bringup the Xilinx AXI Ethernet in u-boot properly.
Nikita Shubin (1): net: xilinx: handle internal PHY/PCS
drivers/net/xilinx_axi_emac.c | 50 +++++++++++++++++++++++++++++++++-- 1 file changed, 48 insertions(+), 2 deletions(-)
In SGMII/1000BaseX Xilinx AXI Ethernet may also have an Internal PHY (PCS) in addition to external PHY, in that case we should also set at least BMCR_ANENABLE.
PCS are not visible until axinet bringup, so init should be done after, controller is brought up, then we should poll BMSR_ANEGCOMPLETE prior to polling the external PHY.
The PCS handling relies on "pcs-handle" device tree handle which serves the similar purpose in Linux device tree.
Signed-off-by: Nikita Shubin n.shubin@yadro.com --- drivers/net/xilinx_axi_emac.c | 50 +++++++++++++++++++++++++++++++++-- 1 file changed, 48 insertions(+), 2 deletions(-)
diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 04277b1269..edbcf6fae3 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -84,6 +84,9 @@ DECLARE_GLOBAL_DATA_PTR; #define DMAALIGN 128 #define XXV_MIN_PKT_SIZE 60
+/* Xilinx internal PCS PHY ID */ +#define XILINX_PHY_ID 0x01740c00 + static u8 rxframe[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); static u8 txminframe[XXV_MIN_PKT_SIZE] __attribute((aligned(DMAALIGN)));
@@ -108,6 +111,7 @@ struct axidma_plat { struct axidma_reg *dmatx; struct axidma_reg *dmarx; int phyaddr; + int pcsaddr; u8 eth_hasnobuf; int phy_of_handle; enum emac_variant mactype; @@ -118,9 +122,11 @@ struct axidma_priv { struct axidma_reg *dmatx; struct axidma_reg *dmarx; int phyaddr; + int pcsaddr; struct axi_regs *iobase; phy_interface_t interface; struct phy_device *phydev; + struct phy_device *pcsdev; struct mii_dev *bus; u8 eth_hasnobuf; int phy_of_handle; @@ -285,6 +291,7 @@ static int axiemac_phy_init(struct udevice *dev) struct axidma_priv *priv = dev_get_priv(dev); struct axi_regs *regs = priv->iobase; struct phy_device *phydev; + struct phy_device *pcsdev;
u32 supported = SUPPORTED_10baseT_Half | SUPPORTED_10baseT_Full | @@ -324,6 +331,15 @@ static int axiemac_phy_init(struct udevice *dev) priv->phydev->node = offset_to_ofnode(priv->phy_of_handle); phy_config(phydev);
+ /* Creating PCS phy here, but it shouldn't be accessed before axiemac_start */ + if (priv->pcsaddr != -1) { + pcsdev = phy_device_create(priv->bus, priv->pcsaddr, + XILINX_PHY_ID, false); + pcsdev->dev = dev; + priv->pcsdev = pcsdev; + printf("axiemac: registered PCS phy, 0x%x\n", priv->pcsaddr); + } + return 0; }
@@ -335,6 +351,7 @@ static int setup_phy(struct udevice *dev) struct axidma_priv *priv = dev_get_priv(dev); struct axi_regs *regs = priv->iobase; struct phy_device *phydev = priv->phydev; + struct phy_device *pcsdev = priv->pcsdev;
if (priv->interface == PHY_INTERFACE_MODE_SGMII) { /* @@ -353,6 +370,12 @@ static int setup_phy(struct udevice *dev) } }
+ if (pcsdev && genphy_update_link(pcsdev)) { + printf("axiemac: could not initialize PCS %s\n", + pcsdev->dev->name); + return 0; + } + if (phy_startup(phydev)) { printf("axiemac: could not initialize PHY %s\n", phydev->dev->name); @@ -520,7 +543,9 @@ static void axi_dma_init(struct axidma_priv *priv) static int axiemac_start(struct udevice *dev) { struct axidma_priv *priv = dev_get_priv(dev); + struct phy_device *pcsdev = priv->pcsdev; u32 temp; + int ret;
debug("axiemac: Init started\n"); /* @@ -540,6 +565,20 @@ static int axiemac_start(struct udevice *dev) return -1; }
+ if (pcsdev) { + /* It looks like we need a bit of delay for core to come up + * may be we could poll MgtRdy or PhyRstCmplt bit + * in 0x00000010, but 1 msec is no a big deal. + */ + udelay(1000); + ret = phywrite(priv, pcsdev->addr, MII_BMCR, + BMCR_ANENABLE | BMCR_FULLDPLX | BMCR_SPEED1000); + if (ret) { + printf("%s: failed to init PCS\n", __func__); + return -1; + } + } + /* Disable all RX interrupts before RxBD space setup */ temp = readl(&priv->dmarx->control); temp &= ~XAXIDMA_IRQ_ALL_MASK; @@ -781,6 +820,7 @@ static int axi_emac_probe(struct udevice *dev) priv->phyaddr = plat->phyaddr; priv->phy_of_handle = plat->phy_of_handle; priv->interface = pdata->phy_interface; + priv->pcsaddr = plat->pcsaddr;
if (IS_ENABLED(CONFIG_DM_ETH_PHY)) priv->bus = eth_phy_get_mdio_bus(dev); @@ -802,8 +842,9 @@ static int axi_emac_probe(struct udevice *dev) axiemac_phy_init(dev); }
- printf("AXI EMAC: %lx, phyaddr %d, interface %s\n", (ulong)pdata->iobase, - priv->phyaddr, phy_string_for_interface(pdata->phy_interface)); + printf("AXI EMAC: %lx, phyaddr %d, pcsaddr %d, interface %s\n", + (ulong)pdata->iobase, priv->phyaddr, priv->pcsaddr, + phy_string_for_interface(pdata->phy_interface));
return 0; } @@ -836,6 +877,7 @@ static int axi_emac_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = &plat->eth_pdata; int node = dev_of_offset(dev); int offset = 0; + struct ofnode_phandle_args phandle_args;
pdata->iobase = dev_read_addr(dev); plat->mactype = dev_get_driver_data(dev); @@ -872,6 +914,10 @@ static int axi_emac_of_to_plat(struct udevice *dev)
plat->eth_hasnobuf = fdtdec_get_bool(gd->fdt_blob, node, "xlnx,eth-hasnobuf"); + if (!dev_read_phandle_with_args(dev, "pcs-handle", NULL, + 0, 0, &phandle_args)) + plat->pcsaddr = ofnode_read_u32_default(phandle_args.node, + "reg", -1); }
Hi Nikita,
- static u8 rxframe[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); static u8 txminframe[XXV_MIN_PKT_SIZE] __attribute((aligned(DMAALIGN)));
- int pcsaddr; u8 eth_hasnobuf; int phy_of_handle; enum emac_variant mactype;
- int pcsaddr; struct axi_regs *iobase; phy_interface_t interface; struct phy_device *phydev;
- struct phy_device *pcsdev; struct mii_dev *bus; u8 eth_hasnobuf; int phy_of_handle;
- /* Creating PCS phy here, but it shouldn't be accessed before axiemac_start */
- if (priv->pcsaddr != -1) {
pcsdev->dev = dev;
- return 0; }
- if (pcsdev && genphy_update_link(pcsdev)) {
pcsdev->dev->name);
- if (phy_startup(phydev)) { printf("axiemac: could not initialize PHY %s\n", phydev->dev->name);
int ret;
- if (pcsdev) {
udelay(1000);
if (ret) {
return -1;
- /* Disable all RX interrupts before RxBD space setup */ temp = readl(&priv->dmarx->control); temp &= ~XAXIDMA_IRQ_ALL_MASK;
return 0; }
"reg", -1);
My collegue Swati is out of office right now and I need to get more information about this configuration. That's why please give us some time to get back to you on this.
Thanks, Michal
Michal Simek
Nikita Shubin
