[PATCH 0/5] xilinx: DT/Kconfig changes
this is small series with misc changes target configs and DTs.
Thanks, Michal
Ashok Reddy Soma (2): arm: zynq: Enable alternative memory test arm64: versal: Enable config to map TCM and OCM
Saeed Nowshadi (1): arm64: zynqmp: Fix si570 clock output names and references
T Karthik Reddy (2): arm64: zynqmp: Reduce console buffer size arm64: zynqmp: Change spi-max-frequency for qspi mini
arch/arm/dts/zynqmp-e-a2197-00-revA.dts | 10 +++++----- arch/arm/dts/zynqmp-mini-qspi.dts | 2 +- configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + include/configs/xilinx_zynqmp_mini.h | 2 ++ 5 files changed, 10 insertions(+), 6 deletions(-)
Enable alternative memory test for zynq platforms.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/xilinx_zynq_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 375d54cbad63..63bb51a73369 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_IMLS=y CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_CMD_DFU=y
Enable CONFIG_DEFINE_TCM_OCM_MMAP to map TCM and OCM memory.
configs/xilinx_versal_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 7c20123b66fa..ac1182e77df5 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_VERSAL=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x100000 CONFIG_DM_GPIO=y +CONFIG_DEFINE_TCM_OCM_MMAP=y CONFIG_COUNTER_FREQUENCY=62500000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y
Reduce console buffer size to 1kbyte to accommodate memory allocations in mini u-boot for zynqmp.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
include/configs/xilinx_zynqmp_mini.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/xilinx_zynqmp_mini.h b/include/configs/xilinx_zynqmp_mini.h index 3078b9c55b52..65c33ed4d94a 100644 --- a/include/configs/xilinx_zynqmp_mini.h +++ b/include/configs/xilinx_zynqmp_mini.h @@ -27,5 +27,7 @@ /* BOOTP options */ #undef CONFIG_BOOTP_BOOTFILESIZE #undef CONFIG_BOOTP_MAY_FAIL +#undef CONFIG_SYS_CBSIZE +#define CONFIG_SYS_CBSIZE 1024
#endif /* __CONFIG_ZYNQMP_MINI_H */
Align clock output names with node references.
Signed-off-by: Saeed Nowshadi saeed.nowshadi@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-e-a2197-00-revA.dts | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/zynqmp-e-a2197-00-revA.dts b/arch/arm/dts/zynqmp-e-a2197-00-revA.dts index bf982e221830..c260411d7571 100644 --- a/arch/arm/dts/zynqmp-e-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-e-a2197-00-revA.dts @@ -2,7 +2,7 @@ /* * dts file for Xilinx Versal a2197 RevA System Controller * - * (C) Copyright 2019, Xilinx, Inc. + * (C) Copyright 2019 - 2020, Xilinx, Inc. * * Michal Simek michal.simek@xilinx.com */ @@ -421,14 +421,14 @@ temperature-stability = <50>; factory-fout = <156250000>; clock-frequency = <156250000>; - clock-output-names = "si570_hsdp_clk"; + clock-output-names = "si570_zsfp_clk"; }; }; i2c@6 { /* USER_SI570_1 */ #address-cells = <1>; #size-cells = <0>; reg = <6>; - si570_user1_clk: clock-generator@5d { /* u205 */ + si570_user1: clock-generator@5d { /* u205 */ #clock-cells = <0>; compatible = "silabs,si570"; reg = <0x5f>; @@ -510,7 +510,7 @@ #address-cells = <1>; #size-cells = <0>; reg = <4>; - si570_ddr_dimm2: clock-generator@60 { /* u3 */ + si570_lpddr4clk2: clock-generator@60 { /* u3 */ #clock-cells = <0>; compatible = "silabs,si570"; reg = <0x60>; @@ -524,7 +524,7 @@ #address-cells = <1>; #size-cells = <0>; reg = <5>; - si570_lpddr4: clock-generator@60 { /* u4 */ + si570_lpddr4clk1: clock-generator@60 { /* u4 */ #clock-cells = <0>; compatible = "silabs,si570"; reg = <0x60>;
Change mini u-boot qspi spi-max-frequency to 108Mhz, make the frequency similar to full u-boot qspi flash spi-max-frequency.
arch/arm/dts/zynqmp-mini-qspi.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-mini-qspi.dts b/arch/arm/dts/zynqmp-mini-qspi.dts index c523e8123666..a76e6404661e 100644 --- a/arch/arm/dts/zynqmp-mini-qspi.dts +++ b/arch/arm/dts/zynqmp-mini-qspi.dts @@ -70,7 +70,7 @@ reg = <0x0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; - spi-max-frequency = <10000000>; + spi-max-frequency = <108000000>; }; };
Ășt 12. 5. 2020 v 8:55 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.26.2
Applied all. M
Michal Simek
Michal Simek
