[U-Boot] [GIT PULL] Pull request u-boot-85xx.git
The following changes since commit 5721385b187b3154c7768e6c182501022f4e2e45:
Merge branch 'master' of git://git.denx.de/u-boot-mpc83xx (2011-11-08 07:44:52 +0100)
git://git.denx.de/u-boot-mpc85xx.git master
Jerry Huang (2): powerpc/mpc85xx: Set SYSCLK to the required frequency powerpc/85xx: Set max alloc length to 10MB on P1022DS
Kumar Gala (20): powerpc/85xx: Add support for Book-E MMU Arch v2.0 powerpc/85xx: Fix MPC8572DS NAND build powerpc/85xx: Fix NAND SPL support arch/powerpc/cpu/mpc85xx/cpu_init.c: Fix GCC 4.6 build warning arch/powerpc/cpu/mpc85xx/tlb.c: Fix GCC 4.6 build warning arch/powerpc/cpu/mpc8xxx/fsl_lbc.c: Fix GCC 4.6 build warning board/freescale/common/cds_pci_ft.c: Fix GCC 4.6 build warning board/freescale/common/pixis.c: Fix GCC 4.6 build warning board/freescale/mpc8548cds/mpc8548cds.c: Fix GCC 4.6 build warning board/freescale/mpc8568mds/mpc8568mds.c: Fix GCC 4.6 build warning board/freescale/mpc8569mds/mpc8569mds.c: Fix GCC 4.6 build warning board/sbc8548/sbc8548.c: Fix GCC 4.6 build warning board/sbc8560/sbc8560.c: Fix GCC 4.6 build warning drivers/net/fm/fm.c: Fix GCC 4.6 build warning drivers/usb/host/ehci-fsl.c: Fix GCC 4.6 build warning drivers/qe/uec.c: Fix GCC 4.6 build warning arch/powerpc/cpu/mpc8xxx/ddr/options.c: Fix GCC 4.6 build warning arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c: Fix GCC 4.6 build warning arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c: Fix GCC 4.6 build warning powerpc/85xx: Fix builds of P1020/P2020RDB-PC_36BIT_NAND
Poonam Aggrwal (1): fsl_ifc: Fixed a bug in the erratum handling code for IFC_A003399
Ramneek Mehresh (2): powerpc/85xx: Fix warning for USB device-fixup powerpc/85xx: Make inclusion of USB device fixup conditional
Roy Zang (1): powerpc/QorIQ: fix network frame manager TBI PHY address settings
Timur Tabi (5): powerpc/85xx: fix definition of MAS register macros powerpc/85xx: fix some comments in the CCSR relocation code powerpc/85xx: add some missing sync instructions in the CCSR relocation code powerpc/85xx: verify the current address of CCSR before relocating it powerpc/85xx: resize the boot page TLB before relocating CCSR
Xie Xiaobo (1): phylib: Enable AR8021 phy support
chenhui zhao (2): powerpc/mpc8548: Add workaround for erratum NMG_eTSEC129 powerpc/mpc8548cds: Fix network initialization
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 3 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 4 +- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 7 ++- arch/powerpc/cpu/mpc85xx/start.S | 84 ++++++++++++++++++++++- arch/powerpc/cpu/mpc85xx/tlb.c | 17 +++-- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 7 +-- arch/powerpc/cpu/mpc8xxx/ddr/options.c | 4 + arch/powerpc/cpu/mpc8xxx/fdt.c | 24 ++++--- arch/powerpc/cpu/mpc8xxx/fsl_lbc.c | 4 +- arch/powerpc/include/asm/config_mpc85xx.h | 1 + arch/powerpc/include/asm/mmu.h | 10 ++-- arch/powerpc/include/asm/processor.h | 6 ++ board/freescale/common/cds_pci_ft.c | 3 +- board/freescale/common/ics307_clk.c | 69 ++++++++++++++++++ board/freescale/common/ics307_clk.h | 4 +- board/freescale/common/ngpixis.c | 27 +++++++ board/freescale/common/pixis.c | 4 +- board/freescale/corenet_ds/eth_hydra.c | 8 -- board/freescale/corenet_ds/eth_p4080.c | 8 -- board/freescale/mpc8548cds/mpc8548cds.c | 69 +++++++++++++++--- board/freescale/mpc8568mds/mpc8568mds.c | 3 +- board/freescale/mpc8569mds/mpc8569mds.c | 2 - board/freescale/mpc8572ds/tlb.c | 2 + board/freescale/p1010rdb/p1010rdb.c | 2 + board/freescale/p1_p2_rdb/p1_p2_rdb.c | 2 + board/freescale/p1_p2_rdb_pc/law.c | 10 ++- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 3 + board/freescale/p2041rdb/eth.c | 8 -- board/sbc8548/sbc8548.c | 2 - board/sbc8560/sbc8560.c | 3 +- drivers/net/fm/fm.c | 3 +- drivers/net/tsec.c | 93 +++++++++++++++++++++++++ drivers/qe/uec.c | 7 -- drivers/usb/host/ehci-fsl.c | 4 +- include/config_phylib_all_drivers.h | 1 + include/configs/MPC8536DS.h | 2 +- include/configs/MPC8548CDS.h | 2 + include/configs/MPC8569MDS.h | 2 +- include/configs/MPC8572DS.h | 2 +- include/configs/P1022DS.h | 2 +- include/configs/P1_P2_RDB.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- 43 files changed, 420 insertions(+), 106 deletions(-)
Dear Kumar Gala,
In message alpine.LFD.2.00.1111110817050.8953@right.am.freescale.net you wrote:
Applied, thanks.
Kumar Gala
