[PATCH v7 0/8] Add FU740 chip and HiFive Unmatched board support
This patch set is to add SiFive fu740 chip and HiFive Unmatched board support. Patches are split into several parts:
- [PATCH v7 1/8] support for fu740 cpu - [PATCH v7 2/8] support for fu740 clk driver - [PATCH v7 3/8] rename and support for fu740 ram driver - [PATCH v7 4/8] add pcie driver - [PATCH v7 5/8] dts for SiFive fu740 - [PATCH v7 6/8] dts for SiFive Unmatched board - [PATCH v7 7/8] add Unmatched board support - [PATCH v7 8/8] add fu740 support to macb driver
Description
- For fu740 cpu support, reuse most of fu540 cpu. - For prci driver, add one abstract layer to separate fu540 and fu740. Move orignal fu540 code to separate files. - For pcie driver, it depends on gpio, prci, clk and reset drivers to do init&reset works. Also based on pcie_dw_common.c - Align with Linux DT file.
Tests and patch checks
- Able to boot both unmatched and unleashed boards. - PCIe tests . M.2 NVMe SSD . e1000 compatibale ethernet adapter (ping&tftpboot) . pci-to-usb adapter(usb mass storage) - checkpatch is performed. To keep code derived from other boards the same, ignore some warnings/errors in [PATCH 7/8].
Changlogs - V7 . Rebase to latest master branch . Moved dts for fu740 patch [v6 1/7] to [v7 5/8] and seperate dts of Unmatched board from [v6 6/7] into [v7 6/8] . Applied PCIe refactoring patch to base on the common code in pcie_dw_common.c - V6 . Remove redundant DT string for 1.2GHz CPU clock and squash to [1/7] - V5 . Fix unleashed build error in patch [6/8] . Append one more set for 1.2GHz CPU speed . Add "#include <asm/global_data.h>" back to sifive_ddr.c . Add Reviewed-by to [4/8] and [7/8] - V4 . fixed incorrect file name in ./board/sifive/unmatched/Makefile . fixed link in doc/board/sifive/index.rst, passed 'make htmldocs' - V3 . Rebase to unleashed rename v2 patch . Rename doc/board/sifive/unmatched.rst board/sifive/unmatched/unmatched.c . Fix tail whitespace . Add 'git mv' info to ram driver and merge patch back to one . Add comment to macb driver for PLL hardware quirk . Add reviewed-by to patch [6/7] . Add 'gpio-poweroff' node for upcoming opensbi integration - V2 . Rebase to unleashed rename patch . remove unnessaary fu540 changes . split ram driver patch into 2 to keep 'git mv' info . use a shorter name for unmatched support . Remove redundant&incorrect temperature-sensor in DT . Remove unnecessary USB EHCI & OHCI from defconfig . Revised fu740 doc . Fixed year of copyright . Add reviewed-by received in v1 patch
David Abdurachmanov (1): drivers: net: macb: add fu740 support
Green Wan (7): riscv: cpu: fu740: Add support for cpu fu740 drivers: clk: add fu740 support drivers: ram: sifive: rename fu540_ddr and add fu740 support drivers: pci: add pcie support for fu740 riscv: dts: add fu740 support riscv: dts: add SiFive Unmatched board support board: sifive: add HiFive Unmatched board support
arch/riscv/Kconfig | 5 + arch/riscv/cpu/fu740/Kconfig | 37 + arch/riscv/cpu/fu740/Makefile | 12 + arch/riscv/cpu/fu740/cache.c | 55 + arch/riscv/cpu/fu740/cpu.c | 22 + arch/riscv/cpu/fu740/dram.c | 38 + arch/riscv/cpu/fu740/spl.c | 23 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/fu740-c000-u-boot.dtsi | 105 ++ arch/riscv/dts/fu740-c000.dtsi | 329 ++++ .../dts/fu740-hifive-unmatched-a00-ddr.dtsi | 1489 +++++++++++++++++ .../dts/hifive-unmatched-a00-u-boot.dtsi | 40 + arch/riscv/dts/hifive-unmatched-a00.dts | 259 +++ arch/riscv/include/asm/arch-fu740/cache.h | 14 + arch/riscv/include/asm/arch-fu740/clk.h | 14 + arch/riscv/include/asm/arch-fu740/gpio.h | 38 + arch/riscv/include/asm/arch-fu740/reset.h | 13 + arch/riscv/include/asm/arch-fu740/spl.h | 14 + arch/riscv/lib/sifive_clint.c | 1 - board/sifive/unleashed/Kconfig | 1 + board/sifive/unmatched/Kconfig | 50 + board/sifive/unmatched/MAINTAINERS | 9 + board/sifive/unmatched/Makefile | 9 + board/sifive/unmatched/spl.c | 85 + board/sifive/unmatched/unmatched.c | 24 + common/spl/Kconfig | 4 +- configs/sifive_unleashed_defconfig | 1 + configs/sifive_unmatched_defconfig | 54 + doc/board/sifive/index.rst | 1 + doc/board/sifive/unmatched.rst | 536 ++++++ drivers/clk/sifive/Kconfig | 8 +- drivers/clk/sifive/Makefile | 4 +- drivers/clk/sifive/fu540-prci.c | 769 +-------- drivers/clk/sifive/fu540-prci.h | 22 + drivers/clk/sifive/fu740-prci.c | 158 ++ drivers/clk/sifive/fu740-prci.h | 22 + drivers/clk/sifive/sifive-prci.c | 733 ++++++++ drivers/clk/sifive/sifive-prci.h | 323 ++++ drivers/net/macb.c | 13 +- drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_sifive.c | 508 ++++++ drivers/ram/sifive/Kconfig | 8 +- drivers/ram/sifive/Makefile | 2 +- .../ram/sifive/{fu540_ddr.c => sifive_ddr.c} | 89 +- drivers/reset/Kconfig | 2 +- include/configs/sifive-unmatched.h | 85 + include/dt-bindings/clock/sifive-fu740-prci.h | 25 + include/dt-bindings/reset/sifive-fu740-prci.h | 19 + 49 files changed, 5277 insertions(+), 807 deletions(-) create mode 100644 arch/riscv/cpu/fu740/Kconfig create mode 100644 arch/riscv/cpu/fu740/Makefile create mode 100644 arch/riscv/cpu/fu740/cache.c create mode 100644 arch/riscv/cpu/fu740/cpu.c create mode 100644 arch/riscv/cpu/fu740/dram.c create mode 100644 arch/riscv/cpu/fu740/spl.c create mode 100644 arch/riscv/dts/fu740-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu740-c000.dtsi create mode 100644 arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00.dts create mode 100644 arch/riscv/include/asm/arch-fu740/cache.h create mode 100644 arch/riscv/include/asm/arch-fu740/clk.h create mode 100644 arch/riscv/include/asm/arch-fu740/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu740/reset.h create mode 100644 arch/riscv/include/asm/arch-fu740/spl.h create mode 100644 board/sifive/unmatched/Kconfig create mode 100644 board/sifive/unmatched/MAINTAINERS create mode 100644 board/sifive/unmatched/Makefile create mode 100644 board/sifive/unmatched/spl.c create mode 100644 board/sifive/unmatched/unmatched.c create mode 100644 configs/sifive_unmatched_defconfig create mode 100644 doc/board/sifive/unmatched.rst create mode 100644 drivers/clk/sifive/fu540-prci.h create mode 100644 drivers/clk/sifive/fu740-prci.c create mode 100644 drivers/clk/sifive/fu740-prci.h create mode 100644 drivers/clk/sifive/sifive-prci.c create mode 100644 drivers/clk/sifive/sifive-prci.h create mode 100644 drivers/pci/pcie_dw_sifive.c rename drivers/ram/sifive/{fu540_ddr.c => sifive_ddr.c} (81%) create mode 100644 include/configs/sifive-unmatched.h create mode 100644 include/dt-bindings/clock/sifive-fu740-prci.h create mode 100644 include/dt-bindings/reset/sifive-fu740-prci.h
Add SiFive fu740 cpu to support RISC-V arch
Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu740/Kconfig | 37 +++++++++++++++ arch/riscv/cpu/fu740/Makefile | 12 +++++ arch/riscv/cpu/fu740/cache.c | 55 +++++++++++++++++++++++ arch/riscv/cpu/fu740/cpu.c | 22 +++++++++ arch/riscv/cpu/fu740/dram.c | 38 ++++++++++++++++ arch/riscv/cpu/fu740/spl.c | 23 ++++++++++ arch/riscv/include/asm/arch-fu740/cache.h | 14 ++++++ arch/riscv/include/asm/arch-fu740/clk.h | 14 ++++++ arch/riscv/include/asm/arch-fu740/gpio.h | 38 ++++++++++++++++ arch/riscv/include/asm/arch-fu740/reset.h | 13 ++++++ arch/riscv/include/asm/arch-fu740/spl.h | 14 ++++++ arch/riscv/lib/sifive_clint.c | 1 - 13 files changed, 281 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu740/Kconfig create mode 100644 arch/riscv/cpu/fu740/Makefile create mode 100644 arch/riscv/cpu/fu740/cache.c create mode 100644 arch/riscv/cpu/fu740/cpu.c create mode 100644 arch/riscv/cpu/fu740/dram.c create mode 100644 arch/riscv/cpu/fu740/spl.c create mode 100644 arch/riscv/include/asm/arch-fu740/cache.h create mode 100644 arch/riscv/include/asm/arch-fu740/clk.h create mode 100644 arch/riscv/include/asm/arch-fu740/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu740/reset.h create mode 100644 arch/riscv/include/asm/arch-fu740/spl.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3f221dccdb..4177253e44 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -61,6 +61,7 @@ source "board/sipeed/maix/Kconfig" # platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" source "arch/riscv/cpu/fu540/Kconfig" +source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig"
# architecture-specific options below diff --git a/arch/riscv/cpu/fu740/Kconfig b/arch/riscv/cpu/fu740/Kconfig new file mode 100644 index 0000000000..24788beab1 --- /dev/null +++ b/arch/riscv/cpu/fu740/Kconfig @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020-2021 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com + +config SIFIVE_FU740 + bool + select ARCH_EARLY_INIT_R + select RAM + select SPL_RAM if SPL + imply CPU + imply CPU_RISCV + imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) + imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply CMD_CPU + imply SPL_CPU + imply SPL_OPENSBI + imply SPL_LOAD_FIT + imply SMP + imply CLK_SIFIVE + imply CLK_SIFIVE_PRCI + imply SIFIVE_SERIAL + imply MACB + imply MII + imply SPI + imply SPI_SIFIVE + imply MMC + imply MMC_SPI + imply MMC_BROKEN_CD + imply CMD_MMC + imply DM_GPIO + imply SIFIVE_GPIO + imply CMD_GPIO + imply MISC + imply SIFIVE_OTP + imply DM_PWM + imply PWM_SIFIVE diff --git a/arch/riscv/cpu/fu740/Makefile b/arch/riscv/cpu/fu740/Makefile new file mode 100644 index 0000000000..5ef8ac18a7 --- /dev/null +++ b/arch/riscv/cpu/fu740/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020-2021 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com + +ifeq ($(CONFIG_SPL_BUILD),y) +obj-y += spl.o +else +obj-y += dram.o +obj-y += cpu.o +obj-y += cache.o +endif diff --git a/arch/riscv/cpu/fu740/cache.c b/arch/riscv/cpu/fu740/cache.c new file mode 100644 index 0000000000..680955c9e3 --- /dev/null +++ b/arch/riscv/cpu/fu740/cache.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020-2021 SiFive, Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <asm/global_data.h> + +/* Register offsets */ +#define L2_CACHE_CONFIG 0x000 +#define L2_CACHE_ENABLE 0x008 + +#define MASK_NUM_WAYS GENMASK(15, 8) +#define NUM_WAYS_SHIFT 8 + +DECLARE_GLOBAL_DATA_PTR; + +int cache_enable_ways(void) +{ + const void *blob = gd->fdt_blob; + int node; + fdt_addr_t base; + u32 config; + u32 ways; + + volatile u32 *enable; + + node = fdt_node_offset_by_compatible(blob, -1, + "sifive,fu740-c000-ccache"); + + if (node < 0) + return node; + + base = fdtdec_get_addr_size_auto_parent(blob, 0, node, "reg", 0, + NULL, false); + if (base == FDT_ADDR_T_NONE) + return FDT_ADDR_T_NONE; + + config = readl((volatile u32 *)base + L2_CACHE_CONFIG); + ways = (config & MASK_NUM_WAYS) >> NUM_WAYS_SHIFT; + + enable = (volatile u32 *)(base + L2_CACHE_ENABLE); + + /* memory barrier */ + mb(); + (*enable) = ways - 1; + /* memory barrier */ + mb(); + return 0; +} diff --git a/arch/riscv/cpu/fu740/cpu.c b/arch/riscv/cpu/fu740/cpu.c new file mode 100644 index 0000000000..f13c18942f --- /dev/null +++ b/arch/riscv/cpu/fu740/cpu.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <irq_func.h> +#include <asm/cache.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + disable_interrupts(); + + cache_flush(); + + return 0; +} diff --git a/arch/riscv/cpu/fu740/dram.c b/arch/riscv/cpu/fu740/dram.c new file mode 100644 index 0000000000..1dc77efeca --- /dev/null +++ b/arch/riscv/cpu/fu740/dram.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_64BIT + /* + * Ensure that we run from first 4GB so that all + * addresses used by U-Boot are 32bit addresses. + * + * This in-turn ensures that 32bit DMA capable + * devices work fine because DMA mapping APIs will + * provide 32bit DMA addresses only. + */ + if (gd->ram_top > SZ_4G) + return SZ_4G; +#endif + return gd->ram_top; +} diff --git a/arch/riscv/cpu/fu740/spl.c b/arch/riscv/cpu/fu740/spl.c new file mode 100644 index 0000000000..ea0b2283a2 --- /dev/null +++ b/arch/riscv/cpu/fu740/spl.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020-201 SiFive, Inc + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <dm.h> +#include <log.h> + +int spl_soc_init(void) +{ + int ret; + struct udevice *dev; + + /* DDR init */ + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + return 0; +} diff --git a/arch/riscv/include/asm/arch-fu740/cache.h b/arch/riscv/include/asm/arch-fu740/cache.h new file mode 100644 index 0000000000..7d4fe9942b --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/cache.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifve.com + */ + +#ifndef _CACHE_SIFIVE_H +#define _CACHE_SIFIVE_H + +int cache_enable_ways(void); + +#endif /* _CACHE_SIFIVE_H */ diff --git a/arch/riscv/include/asm/arch-fu740/clk.h b/arch/riscv/include/asm/arch-fu740/clk.h new file mode 100644 index 0000000000..9f883616b2 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/clk.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020-2021 SiFive Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#ifndef __CLK_SIFIVE_H +#define __CLK_SIFIVE_H + +/* Note: This is a placeholder header for driver compilation. */ + +#endif diff --git a/arch/riscv/include/asm/arch-fu740/gpio.h b/arch/riscv/include/asm/arch-fu740/gpio.h new file mode 100644 index 0000000000..908e2e5563 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/gpio.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + */ + +#ifndef _GPIO_SIFIVE_H +#define _GPIO_SIFIVE_H + +#define GPIO_INPUT_VAL 0x00 +#define GPIO_INPUT_EN 0x04 +#define GPIO_OUTPUT_EN 0x08 +#define GPIO_OUTPUT_VAL 0x0C +#define GPIO_RISE_IE 0x18 +#define GPIO_RISE_IP 0x1C +#define GPIO_FALL_IE 0x20 +#define GPIO_FALL_IP 0x24 +#define GPIO_HIGH_IE 0x28 +#define GPIO_HIGH_IP 0x2C +#define GPIO_LOW_IE 0x30 +#define GPIO_LOW_IP 0x34 +#define GPIO_OUTPUT_XOR 0x40 + +#define NR_GPIOS 16 + +enum gpio_state { + LOW, + HIGH +}; + +/* Details about a GPIO bank */ +struct sifive_gpio_plat { + void *base; /* address of registers in physical memory */ +}; + +#define SIFIVE_GENERIC_GPIO_NR(port, index) \ + (((port) * NR_GPIOS) + ((index) & (NR_GPIOS - 1))) + +#endif /* _GPIO_SIFIVE_H */ diff --git a/arch/riscv/include/asm/arch-fu740/reset.h b/arch/riscv/include/asm/arch-fu740/reset.h new file mode 100644 index 0000000000..538ef87410 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/reset.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020-2021 SiFive, Inc. + * + * Author: Sagar Kadam sagar.kadam@sifive.com + */ + +#ifndef __RESET_SIFIVE_H +#define __RESET_SIFIVE_H + +int sifive_reset_bind(struct udevice *dev, ulong count); + +#endif diff --git a/arch/riscv/include/asm/arch-fu740/spl.h b/arch/riscv/include/asm/arch-fu740/spl.h new file mode 100644 index 0000000000..15ad9e7c8b --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/spl.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifve.com + */ + +#ifndef _SPL_SIFIVE_H +#define _SPL_SIFIVE_H + +int spl_soc_init(void); + +#endif /* _SPL_SIFIVE_H */ diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index ab22395c55..cfa288a01a 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -10,7 +10,6 @@
#include <common.h> #include <dm.h> -#include <asm/global_data.h> #include <asm/io.h> #include <asm/smp.h> #include <linux/err.h>
Add fu740 support. One abstract layer is added for supporting multiple chips such as fu540 and fu740.
Signed-off-by: Green Wan green.wan@sifive.com --- drivers/clk/sifive/Kconfig | 8 +- drivers/clk/sifive/Makefile | 4 +- drivers/clk/sifive/fu540-prci.c | 769 +------------------------------ drivers/clk/sifive/fu540-prci.h | 22 + drivers/clk/sifive/fu740-prci.c | 158 +++++++ drivers/clk/sifive/fu740-prci.h | 22 + drivers/clk/sifive/sifive-prci.c | 733 +++++++++++++++++++++++++++++ drivers/clk/sifive/sifive-prci.h | 323 +++++++++++++ 8 files changed, 1286 insertions(+), 753 deletions(-) create mode 100644 drivers/clk/sifive/fu540-prci.h create mode 100644 drivers/clk/sifive/fu740-prci.c create mode 100644 drivers/clk/sifive/fu740-prci.h create mode 100644 drivers/clk/sifive/sifive-prci.c create mode 100644 drivers/clk/sifive/sifive-prci.h
diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index c4d0a1f9b1..20fc004b59 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -6,11 +6,11 @@ config CLK_SIFIVE help SoC drivers for SiFive Linux-capable SoCs.
-config CLK_SIFIVE_FU540_PRCI - bool "PRCI driver for SiFive FU540 SoCs" +config CLK_SIFIVE_PRCI + bool "PRCI driver for SiFive SoCs" depends on CLK_SIFIVE select CLK_ANALOGBITS_WRPLL_CLN28HPC help Supports the Power Reset Clock interface (PRCI) IP block found in - FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC, - enable this driver. + FU540/FU740 SoCs. If this kernel is meant to run on a SiFive FU540/ + FU740 SoCs, enable this driver. diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index b224279afb..51348b1ddc 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,3 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o +obj-y += sifive-prci.o + +obj-$(CONFIG_CLK_SIFIVE_PRCI) += fu540-prci.o fu740-prci.o diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index b3882d0b77..ceb2c6fab0 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -5,6 +5,8 @@ * Copyright (C) 2018 SiFive, Inc. * Wesley Terpstra * Paul Walmsley + * Zong Li + * Pragnesh Patel * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as @@ -15,632 +17,48 @@ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * - * The FU540 PRCI implements clock and reset control for the SiFive - * FU540-C000 chip. This driver assumes that it has sole control - * over all PRCI resources. - * - * This driver is based on the PRCI driver written by Wesley Terpstra. - * - * Refer, commit 999529edf517ed75b56659d456d221b2ee56bb60 of: - * https://github.com/riscv/riscv-linux - * * References: * - SiFive FU540-C000 manual v1p0, Chapter 7 "Clocking and Reset" */
-#include <common.h> -#include <clk-uclass.h> -#include <clk.h> -#include <div64.h> -#include <dm.h> -#include <dm/device.h> -#include <dm/device_compat.h> -#include <dm/uclass.h> #include <dt-bindings/clock/sifive-fu540-prci.h> -#include <dt-bindings/reset/sifive-fu540-prci.h> -#include <errno.h> -#include <reset-uclass.h> -#include <asm/io.h> -#include <asm/arch/reset.h> -#include <linux/delay.h> -#include <linux/err.h> -#include <linux/math64.h> -#include <linux/clk/analogbits-wrpll-cln28hpc.h> - -/* - * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: - * hfclk and rtcclk - */ -#define EXPECTED_CLK_PARENT_COUNT 2 - -/* - * Register offsets and bitmasks - */ - -/* COREPLLCFG0 */ -#define PRCI_COREPLLCFG0_OFFSET 0x4 -#define PRCI_COREPLLCFG0_DIVR_SHIFT 0 -#define PRCI_COREPLLCFG0_DIVR_MASK (0x3f << PRCI_COREPLLCFG0_DIVR_SHIFT) -#define PRCI_COREPLLCFG0_DIVF_SHIFT 6 -#define PRCI_COREPLLCFG0_DIVF_MASK (0x1ff << PRCI_COREPLLCFG0_DIVF_SHIFT) -#define PRCI_COREPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_COREPLLCFG0_DIVQ_MASK (0x7 << PRCI_COREPLLCFG0_DIVQ_SHIFT) -#define PRCI_COREPLLCFG0_RANGE_SHIFT 18 -#define PRCI_COREPLLCFG0_RANGE_MASK (0x7 << PRCI_COREPLLCFG0_RANGE_SHIFT) -#define PRCI_COREPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_COREPLLCFG0_BYPASS_MASK (0x1 << PRCI_COREPLLCFG0_BYPASS_SHIFT) -#define PRCI_COREPLLCFG0_FSE_SHIFT 25 -#define PRCI_COREPLLCFG0_FSE_MASK (0x1 << PRCI_COREPLLCFG0_FSE_SHIFT) -#define PRCI_COREPLLCFG0_LOCK_SHIFT 31 -#define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT) - -/* COREPLLCFG1 */ -#define PRCI_COREPLLCFG1_OFFSET 0x8 -#define PRCI_COREPLLCFG1_CKE_SHIFT 31 -#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT) - -/* DDRPLLCFG0 */ -#define PRCI_DDRPLLCFG0_OFFSET 0xc -#define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 -#define PRCI_DDRPLLCFG0_DIVR_MASK (0x3f << PRCI_DDRPLLCFG0_DIVR_SHIFT) -#define PRCI_DDRPLLCFG0_DIVF_SHIFT 6 -#define PRCI_DDRPLLCFG0_DIVF_MASK (0x1ff << PRCI_DDRPLLCFG0_DIVF_SHIFT) -#define PRCI_DDRPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_DDRPLLCFG0_DIVQ_MASK (0x7 << PRCI_DDRPLLCFG0_DIVQ_SHIFT) -#define PRCI_DDRPLLCFG0_RANGE_SHIFT 18 -#define PRCI_DDRPLLCFG0_RANGE_MASK (0x7 << PRCI_DDRPLLCFG0_RANGE_SHIFT) -#define PRCI_DDRPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_DDRPLLCFG0_BYPASS_MASK (0x1 << PRCI_DDRPLLCFG0_BYPASS_SHIFT) -#define PRCI_DDRPLLCFG0_FSE_SHIFT 25 -#define PRCI_DDRPLLCFG0_FSE_MASK (0x1 << PRCI_DDRPLLCFG0_FSE_SHIFT) -#define PRCI_DDRPLLCFG0_LOCK_SHIFT 31 -#define PRCI_DDRPLLCFG0_LOCK_MASK (0x1 << PRCI_DDRPLLCFG0_LOCK_SHIFT) - -/* DDRPLLCFG1 */ -#define PRCI_DDRPLLCFG1_OFFSET 0x10 -#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 -#define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT) - -/* GEMGXLPLLCFG0 */ -#define PRCI_GEMGXLPLLCFG0_OFFSET 0x1c -#define PRCI_GEMGXLPLLCFG0_DIVR_SHIFT 0 -#define PRCI_GEMGXLPLLCFG0_DIVR_MASK \ - (0x3f << PRCI_GEMGXLPLLCFG0_DIVR_SHIFT) -#define PRCI_GEMGXLPLLCFG0_DIVF_SHIFT 6 -#define PRCI_GEMGXLPLLCFG0_DIVF_MASK \ - (0x1ff << PRCI_GEMGXLPLLCFG0_DIVF_SHIFT) -#define PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_GEMGXLPLLCFG0_DIVQ_MASK (0x7 << PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT) -#define PRCI_GEMGXLPLLCFG0_RANGE_SHIFT 18 -#define PRCI_GEMGXLPLLCFG0_RANGE_MASK \ - (0x7 << PRCI_GEMGXLPLLCFG0_RANGE_SHIFT) -#define PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_GEMGXLPLLCFG0_BYPASS_MASK \ - (0x1 << PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT) -#define PRCI_GEMGXLPLLCFG0_FSE_SHIFT 25 -#define PRCI_GEMGXLPLLCFG0_FSE_MASK \ - (0x1 << PRCI_GEMGXLPLLCFG0_FSE_SHIFT) -#define PRCI_GEMGXLPLLCFG0_LOCK_SHIFT 31 -#define PRCI_GEMGXLPLLCFG0_LOCK_MASK (0x1 << PRCI_GEMGXLPLLCFG0_LOCK_SHIFT) - -/* GEMGXLPLLCFG1 */ -#define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 -#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 -#define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT) - -/* CORECLKSEL */ -#define PRCI_CORECLKSEL_OFFSET 0x24 -#define PRCI_CORECLKSEL_CORECLKSEL_SHIFT 0 -#define PRCI_CORECLKSEL_CORECLKSEL_MASK \ - (0x1 << PRCI_CORECLKSEL_CORECLKSEL_SHIFT) - -/* DEVICESRESETREG */ -#define PRCI_DEVICESRESETREG_OFFSET 0x28 -#define PRCI_DEVICERESETCNT 5 - -#define PRCI_DEVICESRESETREG_DDR_CTRL_RST_N_MASK \ - (0x1 << PRCI_RST_DDR_CTRL_N) -#define PRCI_DEVICESRESETREG_DDR_AXI_RST_N_MASK \ - (0x1 << PRCI_RST_DDR_AXI_N) -#define PRCI_DEVICESRESETREG_DDR_AHB_RST_N_MASK \ - (0x1 << PRCI_RST_DDR_AHB_N) -#define PRCI_DEVICESRESETREG_DDR_PHY_RST_N_MASK \ - (0x1 << PRCI_RST_DDR_PHY_N) -#define PRCI_DEVICESRESETREG_GEMGXL_RST_N_MASK \ - (0x1 << PRCI_RST_GEMGXL_N) - -/* CLKMUXSTATUSREG */ -#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c -#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 -#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ - (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT) - -/* PROCMONCFG */ -#define PRCI_PROCMONCFG_OFFSET 0xF0 -#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 -#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \ - (0x1 << PRCI_PROCMONCFG_CORE_CLOCK_SHIFT) - -/* - * Private structures - */ - -/** - * struct __prci_data - per-device-instance data - * @va: base virtual address of the PRCI IP block - * @parent: parent clk instance - * - * PRCI per-device instance data - */ -struct __prci_data { - void *va; - struct clk parent_hfclk; - struct clk parent_rtcclk; -}; - -/** - * struct __prci_wrpll_data - WRPLL configuration and integration data - * @c: WRPLL current configuration record - * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) - * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) - * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address - * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address - * @release_reset: fn ptr to code to release clock reset - * - * @enable_bypass and @disable_bypass are used for WRPLL instances - * that contain a separate external glitchless clock mux downstream - * from the PLL. The WRPLL internal bypass mux is not glitchless. - */ -struct __prci_wrpll_data { - struct wrpll_cfg c; - void (*enable_bypass)(struct __prci_data *pd); - void (*disable_bypass)(struct __prci_data *pd); - u8 cfg0_offs; - u8 cfg1_offs; - void (*release_reset)(struct __prci_data *pd); -}; - -struct __prci_clock; - -/* struct __prci_clock_ops - clock operations */ -struct __prci_clock_ops { - int (*set_rate)(struct __prci_clock *pc, - unsigned long rate, - unsigned long parent_rate); - unsigned long (*round_rate)(struct __prci_clock *pc, - unsigned long rate, - unsigned long *parent_rate); - unsigned long (*recalc_rate)(struct __prci_clock *pc, - unsigned long parent_rate); - int (*enable_clk)(struct __prci_clock *pc, bool enable); -}; - -/** - * struct __prci_clock - describes a clock device managed by PRCI - * @name: user-readable clock name string - should match the manual - * @parent_name: parent name for this clock - * @ops: struct __prci_clock_ops for control - * @pwd: WRPLL-specific data, associated with this clock (if not NULL) - * @pd: PRCI-specific data associated with this clock (if not NULL) - * - * PRCI clock data. Used by the PRCI driver to register PRCI-provided - * clocks to the Linux clock infrastructure. - */ -struct __prci_clock { - const char *name; - const char *parent_name; - const struct __prci_clock_ops *ops; - struct __prci_wrpll_data *pwd; - struct __prci_data *pd; -}; - -/* - * Private functions - */ - -/** - * __prci_readl() - read from a PRCI register - * @pd: PRCI context - * @offs: register offset to read from (in bytes, from PRCI base address) - * - * Read the register located at offset @offs from the base virtual - * address of the PRCI register target described by @pd, and return - * the value to the caller. - * - * Context: Any context. - * - * Return: the contents of the register described by @pd and @offs. - */ -static u32 __prci_readl(struct __prci_data *pd, u32 offs) -{ - return readl(pd->va + offs); -} - -static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) -{ - writel(v, pd->va + offs); -} - -/* WRPLL-related private functions */ - -/** - * __prci_wrpll_unpack() - unpack WRPLL configuration registers into parameters - * @c: ptr to a struct wrpll_cfg record to write config into - * @r: value read from the PRCI PLL configuration register - * - * Given a value @r read from an FU540 PRCI PLL configuration register, - * split it into fields and populate it into the WRPLL configuration record - * pointed to by @c. - * - * The COREPLLCFG0 macros are used below, but the other *PLLCFG0 macros - * have the same register layout. - * - * Context: Any context. - */ -static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) -{ - u32 v; - - v = r & PRCI_COREPLLCFG0_DIVR_MASK; - v >>= PRCI_COREPLLCFG0_DIVR_SHIFT; - c->divr = v; - - v = r & PRCI_COREPLLCFG0_DIVF_MASK; - v >>= PRCI_COREPLLCFG0_DIVF_SHIFT; - c->divf = v; - - v = r & PRCI_COREPLLCFG0_DIVQ_MASK; - v >>= PRCI_COREPLLCFG0_DIVQ_SHIFT; - c->divq = v; - - v = r & PRCI_COREPLLCFG0_RANGE_MASK; - v >>= PRCI_COREPLLCFG0_RANGE_SHIFT; - c->range = v; - - c->flags &= (WRPLL_FLAGS_INT_FEEDBACK_MASK | - WRPLL_FLAGS_EXT_FEEDBACK_MASK); - - /* external feedback mode not supported */ - c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; -} - -/** - * __prci_wrpll_pack() - pack PLL configuration parameters into a register value - * @c: pointer to a struct wrpll_cfg record containing the PLL's cfg - * - * Using a set of WRPLL configuration values pointed to by @c, - * assemble a PRCI PLL configuration register value, and return it to - * the caller. - * - * Context: Any context. Caller must ensure that the contents of the - * record pointed to by @c do not change during the execution - * of this function. - * - * Returns: a value suitable for writing into a PRCI PLL configuration - * register - */ -static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) -{ - u32 r = 0; - - r |= c->divr << PRCI_COREPLLCFG0_DIVR_SHIFT; - r |= c->divf << PRCI_COREPLLCFG0_DIVF_SHIFT; - r |= c->divq << PRCI_COREPLLCFG0_DIVQ_SHIFT; - r |= c->range << PRCI_COREPLLCFG0_RANGE_SHIFT; - - /* external feedback mode not supported */ - r |= PRCI_COREPLLCFG0_FSE_MASK; - - return r; -} - -/** - * __prci_wrpll_read_cfg0() - read the WRPLL configuration from the PRCI - * @pd: PRCI context - * @pwd: PRCI WRPLL metadata - * - * Read the current configuration of the PLL identified by @pwd from - * the PRCI identified by @pd, and store it into the local configuration - * cache in @pwd. - * - * Context: Any context. Caller must prevent the records pointed to by - * @pd and @pwd from changing during execution. - */ -static void __prci_wrpll_read_cfg0(struct __prci_data *pd, - struct __prci_wrpll_data *pwd) -{ - __prci_wrpll_unpack(&pwd->c, __prci_readl(pd, pwd->cfg0_offs)); -} - -/** - * __prci_wrpll_write_cfg0() - write WRPLL configuration into the PRCI - * @pd: PRCI context - * @pwd: PRCI WRPLL metadata - * @c: WRPLL configuration record to write - * - * Write the WRPLL configuration described by @c into the WRPLL - * configuration register identified by @pwd in the PRCI instance - * described by @c. Make a cached copy of the WRPLL's current - * configuration so it can be used by other code. - * - * Context: Any context. Caller must prevent the records pointed to by - * @pd and @pwd from changing during execution. - */ -static void __prci_wrpll_write_cfg0(struct __prci_data *pd, - struct __prci_wrpll_data *pwd, - struct wrpll_cfg *c) -{ - __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd); - - memcpy(&pwd->c, c, sizeof(*c)); -} - -/** - * __prci_wrpll_write_cfg1() - write Clock enable/disable configuration - * into the PRCI - * @pd: PRCI context - * @pwd: PRCI WRPLL metadata - * @enable: Clock enable or disable value - */ -static void __prci_wrpll_write_cfg1(struct __prci_data *pd, - struct __prci_wrpll_data *pwd, - u32 enable) -{ - __prci_writel(enable, pwd->cfg1_offs, pd); -} - -/* Core clock mux control */ - -/** - * __prci_coreclksel_use_hfclk() - switch the CORECLK mux to output HFCLK - * @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg - * - * Switch the CORECLK mux to the HFCLK input source; return once complete. - * - * Context: Any context. Caller must prevent concurrent changes to the - * PRCI_CORECLKSEL_OFFSET register. - */ -static void __prci_coreclksel_use_hfclk(struct __prci_data *pd) -{ - u32 r; - - r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); - r |= PRCI_CORECLKSEL_CORECLKSEL_MASK; - __prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd); - - r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */ -} - -/** - * __prci_coreclksel_use_corepll() - switch the CORECLK mux to output COREPLL - * @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg - * - * Switch the CORECLK mux to the PLL output clock; return once complete. - * - * Context: Any context. Caller must prevent concurrent changes to the - * PRCI_CORECLKSEL_OFFSET register. - */ -static void __prci_coreclksel_use_corepll(struct __prci_data *pd) -{ - u32 r; - - r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); - r &= ~PRCI_CORECLKSEL_CORECLKSEL_MASK; - __prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd); - - r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */ -} - -static unsigned long sifive_fu540_prci_wrpll_recalc_rate( - struct __prci_clock *pc, - unsigned long parent_rate) -{ - struct __prci_wrpll_data *pwd = pc->pwd;
- return wrpll_calc_output_rate(&pwd->c, parent_rate); -} - -static unsigned long sifive_fu540_prci_wrpll_round_rate( - struct __prci_clock *pc, - unsigned long rate, - unsigned long *parent_rate) -{ - struct __prci_wrpll_data *pwd = pc->pwd; - struct wrpll_cfg c; - - memcpy(&c, &pwd->c, sizeof(c)); - - wrpll_configure_for_rate(&c, rate, *parent_rate); - - return wrpll_calc_output_rate(&c, *parent_rate); -} - -static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, - unsigned long rate, - unsigned long parent_rate) -{ - struct __prci_wrpll_data *pwd = pc->pwd; - struct __prci_data *pd = pc->pd; - int r; - - r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); - if (r) - return r; - - if (pwd->enable_bypass) - pwd->enable_bypass(pd); - - __prci_wrpll_write_cfg0(pd, pwd, &pwd->c); - - udelay(wrpll_calc_max_lock_us(&pwd->c)); - - if (pwd->disable_bypass) - pwd->disable_bypass(pd); - - return 0; -} - -static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable) -{ - struct __prci_wrpll_data *pwd = pc->pwd; - struct __prci_data *pd = pc->pd; - - if (enable) { - __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); - - if (pwd->release_reset) - pwd->release_reset(pd); - } else { - u32 r; - - r = __prci_readl(pd, pwd->cfg1_offs); - r &= ~PRCI_COREPLLCFG1_CKE_MASK; - - __prci_wrpll_write_cfg1(pd, pwd, r); - } - - return 0; -} - -static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { - .set_rate = sifive_fu540_prci_wrpll_set_rate, - .round_rate = sifive_fu540_prci_wrpll_round_rate, - .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, - .enable_clk = sifive_fu540_prci_clock_enable, -}; - -/* TLCLKSEL clock integration */ - -static unsigned long sifive_fu540_prci_tlclksel_recalc_rate( - struct __prci_clock *pc, - unsigned long parent_rate) -{ - struct __prci_data *pd = pc->pd; - u32 v; - u8 div; - - v = __prci_readl(pd, PRCI_CLKMUXSTATUSREG_OFFSET); - v &= PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK; - div = v ? 1 : 2; - - return div_u64(parent_rate, div); -} - -static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { - .recalc_rate = sifive_fu540_prci_tlclksel_recalc_rate, -}; - -static int __prci_consumer_reset(const char *rst_name, bool trigger) -{ - struct udevice *dev; - struct reset_ctl rst_sig; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_RESET, - DM_DRIVER_GET(sifive_reset), - &dev); - if (ret) { - dev_err(dev, "Reset driver not found: %d\n", ret); - return ret; - } - - ret = reset_get_by_name(dev, rst_name, &rst_sig); - if (ret) { - dev_err(dev, "failed to get %s reset\n", rst_name); - return ret; - } - - if (reset_valid(&rst_sig)) { - if (trigger) - ret = reset_deassert(&rst_sig); - else - ret = reset_assert(&rst_sig); - if (ret) { - dev_err(dev, "failed to trigger reset id = %ld\n", - rst_sig.id); - return ret; - } - } - - return ret; -} - -/** - * __prci_ddr_release_reset() - Release DDR reset - * @pd: struct __prci_data * for the PRCI containing the DDRCLK mux reg - * - */ -static void __prci_ddr_release_reset(struct __prci_data *pd) -{ - /* Release DDR ctrl reset */ - __prci_consumer_reset("ddr_ctrl", true); - - /* HACK to get the '1 full controller clock cycle'. */ - asm volatile ("fence"); - - /* Release DDR AXI reset */ - __prci_consumer_reset("ddr_axi", true); - - /* Release DDR AHB reset */ - __prci_consumer_reset("ddr_ahb", true); - - /* Release DDR PHY reset */ - __prci_consumer_reset("ddr_phy", true); - - /* HACK to get the '1 full controller clock cycle'. */ - asm volatile ("fence"); - - /* - * These take like 16 cycles to actually propagate. We can't go sending - * stuff before they come out of reset. So wait. - */ - for (int i = 0; i < 256; i++) - asm volatile ("nop"); -} - -/** - * __prci_ethernet_release_reset() - Release ethernet reset - * @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg - * - */ -static void __prci_ethernet_release_reset(struct __prci_data *pd) -{ - /* Release GEMGXL reset */ - __prci_consumer_reset("gemgxl_reset", true); - - /* Procmon => core clock */ - __prci_writel(PRCI_PROCMONCFG_CORE_CLOCK_MASK, PRCI_PROCMONCFG_OFFSET, - pd); -} - -/* - * PRCI integration data for each WRPLL instance - */ +#include "sifive-prci.h"
+/* PRCI integration data for each WRPLL instance */ static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, .cfg1_offs = PRCI_COREPLLCFG1_OFFSET, - .enable_bypass = __prci_coreclksel_use_hfclk, - .disable_bypass = __prci_coreclksel_use_corepll, + .enable_bypass = sifive_prci_coreclksel_use_hfclk, + .disable_bypass = sifive_prci_coreclksel_use_corepll, };
static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, - .release_reset = __prci_ddr_release_reset, + .release_reset = sifive_prci_ddr_release_reset, };
static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, - .release_reset = __prci_ethernet_release_reset, + .release_reset = sifive_prci_ethernet_release_reset, };
-/* - * List of clock controls provided by the PRCI - */ +/* Linux clock framework integration */ +static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { + .set_rate = sifive_prci_wrpll_set_rate, + .round_rate = sifive_prci_wrpll_round_rate, + .recalc_rate = sifive_prci_wrpll_recalc_rate, + .enable_clk = sifive_prci_clock_enable, +};
-static struct __prci_clock __prci_init_clocks[] = { +static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { + .recalc_rate = sifive_prci_tlclksel_recalc_rate, +}; + +/* List of clock controls provided by the PRCI */ +struct __prci_clock __prci_init_clocks_fu540[] = { [PRCI_CLK_COREPLL] = { .name = "corepll", .parent_name = "hfclk", @@ -665,148 +83,3 @@ static struct __prci_clock __prci_init_clocks[] = { .ops = &sifive_fu540_prci_tlclksel_clk_ops, }, }; - -static ulong sifive_fu540_prci_parent_rate(struct __prci_clock *pc) -{ - ulong parent_rate; - struct __prci_clock *p; - - if (strcmp(pc->parent_name, "corepll") == 0) { - p = &__prci_init_clocks[PRCI_CLK_COREPLL]; - if (!p->pd || !p->ops->recalc_rate) - return -ENXIO; - - return p->ops->recalc_rate(p, sifive_fu540_prci_parent_rate(p)); - } - - if (strcmp(pc->parent_name, "rtcclk") == 0) - parent_rate = clk_get_rate(&pc->pd->parent_rtcclk); - else - parent_rate = clk_get_rate(&pc->pd->parent_hfclk); - - return parent_rate; -} - -static ulong sifive_fu540_prci_get_rate(struct clk *clk) -{ - struct __prci_clock *pc; - - if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) - return -ENXIO; - - pc = &__prci_init_clocks[clk->id]; - if (!pc->pd || !pc->ops->recalc_rate) - return -ENXIO; - - return pc->ops->recalc_rate(pc, sifive_fu540_prci_parent_rate(pc)); -} - -static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) -{ - int err; - struct __prci_clock *pc; - - if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) - return -ENXIO; - - pc = &__prci_init_clocks[clk->id]; - if (!pc->pd || !pc->ops->set_rate) - return -ENXIO; - - err = pc->ops->set_rate(pc, rate, sifive_fu540_prci_parent_rate(pc)); - if (err) - return err; - - return rate; -} - -static int sifive_fu540_prci_enable(struct clk *clk) -{ - struct __prci_clock *pc; - int ret = 0; - - if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) - return -ENXIO; - - pc = &__prci_init_clocks[clk->id]; - if (!pc->pd) - return -ENXIO; - - if (pc->ops->enable_clk) - ret = pc->ops->enable_clk(pc, 1); - - return ret; -} - -static int sifive_fu540_prci_disable(struct clk *clk) -{ - struct __prci_clock *pc; - int ret = 0; - - if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) - return -ENXIO; - - pc = &__prci_init_clocks[clk->id]; - if (!pc->pd) - return -ENXIO; - - if (pc->ops->enable_clk) - ret = pc->ops->enable_clk(pc, 0); - - return ret; -} - -static int sifive_fu540_prci_probe(struct udevice *dev) -{ - int i, err; - struct __prci_clock *pc; - struct __prci_data *pd = dev_get_priv(dev); - - pd->va = (void *)dev_read_addr(dev); - if (IS_ERR(pd->va)) - return PTR_ERR(pd->va); - - err = clk_get_by_index(dev, 0, &pd->parent_hfclk); - if (err) - return err; - - err = clk_get_by_index(dev, 1, &pd->parent_rtcclk); - if (err) - return err; - - for (i = 0; i < ARRAY_SIZE(__prci_init_clocks); ++i) { - pc = &__prci_init_clocks[i]; - pc->pd = pd; - if (pc->pwd) - __prci_wrpll_read_cfg0(pd, pc->pwd); - } - - return 0; -} - -static struct clk_ops sifive_fu540_prci_ops = { - .set_rate = sifive_fu540_prci_set_rate, - .get_rate = sifive_fu540_prci_get_rate, - .enable = sifive_fu540_prci_enable, - .disable = sifive_fu540_prci_disable, -}; - -static int sifive_fu540_clk_bind(struct udevice *dev) -{ - return sifive_reset_bind(dev, PRCI_DEVICERESETCNT); -} - -static const struct udevice_id sifive_fu540_prci_ids[] = { - { .compatible = "sifive,fu540-c000-prci" }, - { } -}; - -U_BOOT_DRIVER(sifive_fu540_prci) = { - .name = "sifive-fu540-prci", - .id = UCLASS_CLK, - .of_match = sifive_fu540_prci_ids, - .probe = sifive_fu540_prci_probe, - .ops = &sifive_fu540_prci_ops, - .priv_auto = sizeof(struct __prci_data), - .bind = sifive_fu540_clk_bind, -}; diff --git a/drivers/clk/sifive/fu540-prci.h b/drivers/clk/sifive/fu540-prci.h new file mode 100644 index 0000000000..113301107d --- /dev/null +++ b/drivers/clk/sifive/fu540-prci.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * Zong Li + * Pragnesh Patel + */ + +#ifndef __SIFIVE_CLK_FU540_PRCI_H +#define __SIFIVE_CLK_FU540_PRCI_H + +#include "sifive-prci.h" + +#define NUM_CLOCK_FU540 4 + +extern struct __prci_clock __prci_init_clocks_fu540[NUM_CLOCK_FU540]; + +static const struct prci_clk_desc prci_clk_fu540 = { + .clks = __prci_init_clocks_fu540, + .num_clks = ARRAY_SIZE(__prci_init_clocks_fu540), +}; + +#endif /* __SIFIVE_CLK_FU540_PRCI_H */ diff --git a/drivers/clk/sifive/fu740-prci.c b/drivers/clk/sifive/fu740-prci.c new file mode 100644 index 0000000000..9a642c1c99 --- /dev/null +++ b/drivers/clk/sifive/fu740-prci.c @@ -0,0 +1,158 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2021 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + * Zong Li + * Pragnesh Patel + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <dt-bindings/clock/sifive-fu740-prci.h> +#include "sifive-prci.h" +#include <asm/io.h> + +int sifive_prci_fu740_pciauxclk_enable(struct __prci_clock *pc, bool enable) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct __prci_data *pd = pc->pd; + u32 v; + + if (pwd->cfg1_offs != PRCI_PCIEAUXCFG1_OFFSET) + return -EINVAL; + + v = readl(pd->va + pwd->cfg1_offs); + v = enable ? (v | PRCI_PCIEAUXCFG1_MASK) : (v & ~PRCI_PCIEAUXCFG1_MASK); + writel(v, pd->va + pwd->cfg1_offs); + + return 0; +} + +/* PRCI integration data for each WRPLL instance */ +static struct __prci_wrpll_data __prci_corepll_data = { + .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, + .cfg1_offs = PRCI_COREPLLCFG1_OFFSET, + .enable_bypass = sifive_prci_coreclksel_use_hfclk, + .disable_bypass = sifive_prci_coreclksel_use_final_corepll, +}; + +static struct __prci_wrpll_data __prci_ddrpll_data = { + .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, + .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, + .release_reset = sifive_prci_ddr_release_reset, +}; + +static struct __prci_wrpll_data __prci_gemgxlpll_data = { + .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, + .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, + .release_reset = sifive_prci_ethernet_release_reset, +}; + +static struct __prci_wrpll_data __prci_dvfscorepll_data = { + .cfg0_offs = PRCI_DVFSCOREPLLCFG0_OFFSET, + .cfg1_offs = PRCI_DVFSCOREPLLCFG1_OFFSET, + .enable_bypass = sifive_prci_corepllsel_use_corepll, + .disable_bypass = sifive_prci_corepllsel_use_dvfscorepll, +}; + +static struct __prci_wrpll_data __prci_hfpclkpll_data = { + .cfg0_offs = PRCI_HFPCLKPLLCFG0_OFFSET, + .cfg1_offs = PRCI_HFPCLKPLLCFG1_OFFSET, + .enable_bypass = sifive_prci_hfpclkpllsel_use_hfclk, + .disable_bypass = sifive_prci_hfpclkpllsel_use_hfpclkpll, +}; + +static struct __prci_wrpll_data __prci_cltxpll_data = { + .cfg0_offs = PRCI_CLTXPLLCFG0_OFFSET, + .cfg1_offs = PRCI_CLTXPLLCFG1_OFFSET, + .release_reset = sifive_prci_cltx_release_reset, +}; + +static struct __prci_wrpll_data __prci_pcieaux_data = { + .cfg1_offs = PRCI_PCIEAUXCFG1_OFFSET, +}; + +/* Linux clock framework integration */ + +static const struct __prci_clock_ops sifive_fu740_prci_wrpll_clk_ops = { + .set_rate = sifive_prci_wrpll_set_rate, + .round_rate = sifive_prci_wrpll_round_rate, + .recalc_rate = sifive_prci_wrpll_recalc_rate, + .enable_clk = sifive_prci_clock_enable, +}; + +static const struct __prci_clock_ops sifive_fu740_prci_tlclksel_clk_ops = { + .recalc_rate = sifive_prci_tlclksel_recalc_rate, +}; + +static const struct __prci_clock_ops sifive_fu740_prci_hfpclkplldiv_clk_ops = { + .recalc_rate = sifive_prci_hfpclkplldiv_recalc_rate, +}; + +static const struct __prci_clock_ops sifive_fu740_prci_pcieaux_clk_ops = { + .enable_clk = sifive_prci_fu740_pciauxclk_enable, +}; + +/* List of clock controls provided by the PRCI */ +struct __prci_clock __prci_init_clocks_fu740[] = { + [PRCI_CLK_COREPLL] = { + .name = "corepll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_corepll_data, + }, + [PRCI_CLK_DDRPLL] = { + .name = "ddrpll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_ddrpll_data, + }, + [PRCI_CLK_GEMGXLPLL] = { + .name = "gemgxlpll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_gemgxlpll_data, + }, + [PRCI_CLK_DVFSCOREPLL] = { + .name = "dvfscorepll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_dvfscorepll_data, + }, + [PRCI_CLK_HFPCLKPLL] = { + .name = "hfpclkpll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_hfpclkpll_data, + }, + [PRCI_CLK_CLTXPLL] = { + .name = "cltxpll", + .parent_name = "hfclk", + .ops = &sifive_fu740_prci_wrpll_clk_ops, + .pwd = &__prci_cltxpll_data, + }, + [PRCI_CLK_TLCLK] = { + .name = "tlclk", + .parent_name = "corepll", + .ops = &sifive_fu740_prci_tlclksel_clk_ops, + }, + [PRCI_CLK_PCLK] = { + .name = "pclk", + .parent_name = "hfpclkpll", + .ops = &sifive_fu740_prci_hfpclkplldiv_clk_ops, + }, + [PRCI_CLK_PCIEAUX] { + .name = "pciaux", + .parent_name = "", + .ops = &sifive_fu740_prci_pcieaux_clk_ops, + .pwd = &__prci_pcieaux_data, + } +}; diff --git a/drivers/clk/sifive/fu740-prci.h b/drivers/clk/sifive/fu740-prci.h new file mode 100644 index 0000000000..b74f078906 --- /dev/null +++ b/drivers/clk/sifive/fu740-prci.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * Zong Li + * Pragnesh Patel + */ + +#ifndef __SIFIVE_CLK_FU740_PRCI_H +#define __SIFIVE_CLK_FU740_PRCI_H + +#include "sifive-prci.h" + +#define NUM_CLOCK_FU740 9 + +extern struct __prci_clock __prci_init_clocks_fu740[NUM_CLOCK_FU740]; + +static const struct prci_clk_desc prci_clk_fu740 = { + .clks = __prci_init_clocks_fu740, + .num_clks = ARRAY_SIZE(__prci_init_clocks_fu740), +}; + +#endif /* __SIFIVE_CLK_FU740_PRCI_H */ diff --git a/drivers/clk/sifive/sifive-prci.c b/drivers/clk/sifive/sifive-prci.c new file mode 100644 index 0000000000..cd1acb9442 --- /dev/null +++ b/drivers/clk/sifive/sifive-prci.c @@ -0,0 +1,733 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2021 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + * Zong Li + * Pragnesh Patel + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * The PRCI implements clock and reset control for the SiFive chip. + * This driver assumes that it has sole control over all PRCI resources. + * + * This driver is based on the PRCI driver written by Wesley Terpstra: + * https://github.com/riscv/riscv-linux/commit/999529edf517ed75b56659d456d221b2... + */ + +#include <common.h> +#include <clk-uclass.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <reset.h> +#include <asm/io.h> +#include <asm/arch/reset.h> +#include <linux/delay.h> +#include <linux/math64.h> +#include <dt-bindings/clock/sifive-fu740-prci.h> + +#include "fu540-prci.h" +#include "fu740-prci.h" + +/* + * Private functions + */ + +/** + * __prci_readl() - read from a PRCI register + * @pd: PRCI context + * @offs: register offset to read from (in bytes, from PRCI base address) + * + * Read the register located at offset @offs from the base virtual + * address of the PRCI register target described by @pd, and return + * the value to the caller. + * + * Context: Any context. + * + * Return: the contents of the register described by @pd and @offs. + */ +static u32 __prci_readl(struct __prci_data *pd, u32 offs) +{ + return readl(pd->va + offs); +} + +static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) +{ + writel(v, pd->va + offs); +} + +/* WRPLL-related private functions */ + +/** + * __prci_wrpll_unpack() - unpack WRPLL configuration registers into parameters + * @c: ptr to a struct wrpll_cfg record to write config into + * @r: value read from the PRCI PLL configuration register + * + * Given a value @r read from an FU540 PRCI PLL configuration register, + * split it into fields and populate it into the WRPLL configuration record + * pointed to by @c. + * + * The COREPLLCFG0 macros are used below, but the other *PLLCFG0 macros + * have the same register layout. + * + * Context: Any context. + */ +static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) +{ + u32 v; + + v = r & PRCI_COREPLLCFG0_DIVR_MASK; + v >>= PRCI_COREPLLCFG0_DIVR_SHIFT; + c->divr = v; + + v = r & PRCI_COREPLLCFG0_DIVF_MASK; + v >>= PRCI_COREPLLCFG0_DIVF_SHIFT; + c->divf = v; + + v = r & PRCI_COREPLLCFG0_DIVQ_MASK; + v >>= PRCI_COREPLLCFG0_DIVQ_SHIFT; + c->divq = v; + + v = r & PRCI_COREPLLCFG0_RANGE_MASK; + v >>= PRCI_COREPLLCFG0_RANGE_SHIFT; + c->range = v; + + c->flags &= (WRPLL_FLAGS_INT_FEEDBACK_MASK | + WRPLL_FLAGS_EXT_FEEDBACK_MASK); + + /* external feedback mode not supported */ + c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; +} + +/** + * __prci_wrpll_pack() - pack PLL configuration parameters into a register value + * @c: pointer to a struct wrpll_cfg record containing the PLL's cfg + * + * Using a set of WRPLL configuration values pointed to by @c, + * assemble a PRCI PLL configuration register value, and return it to + * the caller. + * + * Context: Any context. Caller must ensure that the contents of the + * record pointed to by @c do not change during the execution + * of this function. + * + * Returns: a value suitable for writing into a PRCI PLL configuration + * register + */ +static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) +{ + u32 r = 0; + + r |= c->divr << PRCI_COREPLLCFG0_DIVR_SHIFT; + r |= c->divf << PRCI_COREPLLCFG0_DIVF_SHIFT; + r |= c->divq << PRCI_COREPLLCFG0_DIVQ_SHIFT; + r |= c->range << PRCI_COREPLLCFG0_RANGE_SHIFT; + + /* external feedback mode not supported */ + r |= PRCI_COREPLLCFG0_FSE_MASK; + + return r; +} + +/** + * __prci_wrpll_read_cfg0() - read the WRPLL configuration from the PRCI + * @pd: PRCI context + * @pwd: PRCI WRPLL metadata + * + * Read the current configuration of the PLL identified by @pwd from + * the PRCI identified by @pd, and store it into the local configuration + * cache in @pwd. + * + * Context: Any context. Caller must prevent the records pointed to by + * @pd and @pwd from changing during execution. + */ +static void __prci_wrpll_read_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd) +{ + __prci_wrpll_unpack(&pwd->c, __prci_readl(pd, pwd->cfg0_offs)); +} + +/** + * __prci_wrpll_write_cfg0() - write WRPLL configuration into the PRCI + * @pd: PRCI context + * @pwd: PRCI WRPLL metadata + * @c: WRPLL configuration record to write + * + * Write the WRPLL configuration described by @c into the WRPLL + * configuration register identified by @pwd in the PRCI instance + * described by @c. Make a cached copy of the WRPLL's current + * configuration so it can be used by other code. + * + * Context: Any context. Caller must prevent the records pointed to by + * @pd and @pwd from changing during execution. + */ +static void __prci_wrpll_write_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + struct wrpll_cfg *c) +{ + __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd); + + memcpy(&pwd->c, c, sizeof(*c)); +} + +/** + * __prci_wrpll_write_cfg1() - write Clock enable/disable configuration + * into the PRCI + * @pd: PRCI context + * @pwd: PRCI WRPLL metadata + * @enable: Clock enable or disable value + */ +static void __prci_wrpll_write_cfg1(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + u32 enable) +{ + __prci_writel(enable, pwd->cfg1_offs, pd); +} + +unsigned long sifive_prci_wrpll_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + + return wrpll_calc_output_rate(&pwd->c, parent_rate); +} + +unsigned long sifive_prci_wrpll_round_rate(struct __prci_clock *pc, + unsigned long rate, + unsigned long *parent_rate) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct wrpll_cfg c; + + memcpy(&c, &pwd->c, sizeof(c)); + + wrpll_configure_for_rate(&c, rate, *parent_rate); + + return wrpll_calc_output_rate(&c, *parent_rate); +} + +int sifive_prci_wrpll_set_rate(struct __prci_clock *pc, + unsigned long rate, + unsigned long parent_rate) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct __prci_data *pd = pc->pd; + int r; + + r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); + if (r) + return r; + + if (pwd->enable_bypass) + pwd->enable_bypass(pd); + + __prci_wrpll_write_cfg0(pd, pwd, &pwd->c); + + udelay(wrpll_calc_max_lock_us(&pwd->c)); + + return 0; +} + +int sifive_prci_clock_enable(struct __prci_clock *pc, bool enable) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct __prci_data *pd = pc->pd; + + if (enable) { + __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); + + if (pwd->disable_bypass) + pwd->disable_bypass(pd); + + if (pwd->release_reset) + pwd->release_reset(pd); + } else { + u32 r; + + if (pwd->enable_bypass) + pwd->enable_bypass(pd); + + r = __prci_readl(pd, pwd->cfg1_offs); + r &= ~PRCI_COREPLLCFG1_CKE_MASK; + + __prci_wrpll_write_cfg1(pd, pwd, r); + } + + return 0; +} + +/* TLCLKSEL clock integration */ + +unsigned long sifive_prci_tlclksel_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate) +{ + struct __prci_data *pd = pc->pd; + u32 v; + u8 div; + + v = __prci_readl(pd, PRCI_CLKMUXSTATUSREG_OFFSET); + v &= PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK; + div = v ? 1 : 2; + + return div_u64(parent_rate, div); +} + +/* HFPCLK clock integration */ + +unsigned long sifive_prci_hfpclkplldiv_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate) +{ + struct __prci_data *pd = pc->pd; + u32 div = __prci_readl(pd, PRCI_HFPCLKPLLDIV_OFFSET); + + return div_u64(parent_rate, div + 2); +} + +/** + * sifive_prci_coreclksel_use_final_corepll() - switch the CORECLK mux to output + * FINAL_COREPLL + * @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg + * + * Switch the CORECLK mux to the final COREPLL output clock; return once + * complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_CORECLKSEL_OFFSET register. + */ +void sifive_prci_coreclksel_use_final_corepll(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); + r &= ~PRCI_CORECLKSEL_CORECLKSEL_MASK; + __prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */ +} + +/** + * sifive_prci_corepllsel_use_dvfscorepll() - switch the COREPLL mux to + * output DVFS_COREPLL + * @pd: struct __prci_data * for the PRCI containing the COREPLL mux reg + * + * Switch the COREPLL mux to the DVFSCOREPLL output clock; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_COREPLLSEL_OFFSET register. + */ +void sifive_prci_corepllsel_use_dvfscorepll(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET); + r |= PRCI_COREPLLSEL_COREPLLSEL_MASK; + __prci_writel(r, PRCI_COREPLLSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET); /* barrier */ +} + +/** + * sifive_prci_corepllsel_use_corepll() - switch the COREPLL mux to + * output COREPLL + * @pd: struct __prci_data * for the PRCI containing the COREPLL mux reg + * + * Switch the COREPLL mux to the COREPLL output clock; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_COREPLLSEL_OFFSET register. + */ +void sifive_prci_corepllsel_use_corepll(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET); + r &= ~PRCI_COREPLLSEL_COREPLLSEL_MASK; + __prci_writel(r, PRCI_COREPLLSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET); /* barrier */ +} + +/** + * sifive_prci_hfpclkpllsel_use_hfclk() - switch the HFPCLKPLL mux to + * output HFCLK + * @pd: struct __prci_data * for the PRCI containing the HFPCLKPLL mux reg + * + * Switch the HFPCLKPLL mux to the HFCLK input source; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_HFPCLKPLLSEL_OFFSET register. + */ +void sifive_prci_hfpclkpllsel_use_hfclk(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET); + r |= PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK; + __prci_writel(r, PRCI_HFPCLKPLLSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET); /* barrier */ +} + +/** + * sifive_prci_hfpclkpllsel_use_hfpclkpll() - switch the HFPCLKPLL mux to + * output HFPCLKPLL + * @pd: struct __prci_data * for the PRCI containing the HFPCLKPLL mux reg + * + * Switch the HFPCLKPLL mux to the HFPCLKPLL output clock; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_HFPCLKPLLSEL_OFFSET register. + */ +void sifive_prci_hfpclkpllsel_use_hfpclkpll(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET); + r &= ~PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK; + __prci_writel(r, PRCI_HFPCLKPLLSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET); /* barrier */ +} + +static int __prci_consumer_reset(const char *rst_name, bool trigger) +{ + struct udevice *dev; + struct reset_ctl rst_sig; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_RESET, + DM_DRIVER_GET(sifive_reset), + &dev); + if (ret) { + dev_err(dev, "Reset driver not found: %d\n", ret); + return ret; + } + + ret = reset_get_by_name(dev, rst_name, &rst_sig); + if (ret) { + dev_err(dev, "failed to get %s reset\n", rst_name); + return ret; + } + + if (reset_valid(&rst_sig)) { + if (trigger) + ret = reset_deassert(&rst_sig); + else + ret = reset_assert(&rst_sig); + if (ret) { + dev_err(dev, "failed to trigger reset id = %ld\n", + rst_sig.id); + return ret; + } + } + + return ret; +} + +/** + * sifive_prci_ddr_release_reset() - Release DDR reset + * @pd: struct __prci_data * for the PRCI containing the DDRCLK mux reg + * + */ +void sifive_prci_ddr_release_reset(struct __prci_data *pd) +{ + /* Release DDR ctrl reset */ + __prci_consumer_reset("ddr_ctrl", true); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + + /* Release DDR AXI reset */ + __prci_consumer_reset("ddr_axi", true); + + /* Release DDR AHB reset */ + __prci_consumer_reset("ddr_ahb", true); + + /* Release DDR PHY reset */ + __prci_consumer_reset("ddr_phy", true); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + + /* + * These take like 16 cycles to actually propagate. We can't go sending + * stuff before they come out of reset. So wait. + */ + for (int i = 0; i < 256; i++) + asm volatile ("nop"); +} + +/** + * sifive_prci_ethernet_release_reset() - Release ethernet reset + * @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg + * + */ +void sifive_prci_ethernet_release_reset(struct __prci_data *pd) +{ + /* Release GEMGXL reset */ + __prci_consumer_reset("gemgxl_reset", true); + + /* Procmon => core clock */ + __prci_writel(PRCI_PROCMONCFG_CORE_CLOCK_MASK, PRCI_PROCMONCFG_OFFSET, + pd); + + /* Release Chiplink reset */ + __prci_consumer_reset("cltx_reset", true); +} + +/** + * sifive_prci_cltx_release_reset() - Release cltx reset + * @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg + * + */ +void sifive_prci_cltx_release_reset(struct __prci_data *pd) +{ + /* Release CLTX reset */ + __prci_consumer_reset("cltx_reset", true); +} + +/* Core clock mux control */ + +/** + * sifive_prci_coreclksel_use_hfclk() - switch the CORECLK mux to output HFCLK + * @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg + * + * Switch the CORECLK mux to the HFCLK input source; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_CORECLKSEL_OFFSET register. + */ +void sifive_prci_coreclksel_use_hfclk(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); + r |= PRCI_CORECLKSEL_CORECLKSEL_MASK; + __prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */ +} + +/** + * sifive_prci_coreclksel_use_corepll() - switch the CORECLK mux to output COREPLL + * @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg + * + * Switch the CORECLK mux to the PLL output clock; return once complete. + * + * Context: Any context. Caller must prevent concurrent changes to the + * PRCI_CORECLKSEL_OFFSET register. + */ +void sifive_prci_coreclksel_use_corepll(struct __prci_data *pd) +{ + u32 r; + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); + r &= ~PRCI_CORECLKSEL_CORECLKSEL_MASK; + __prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd); + + r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */ +} + +static ulong sifive_prci_parent_rate(struct __prci_clock *pc, struct prci_clk_desc *data) +{ + ulong parent_rate; + ulong i; + struct __prci_clock *p; + + if (strcmp(pc->parent_name, "corepll") == 0 || + strcmp(pc->parent_name, "hfpclkpll") == 0) { + for (i = 0; i < data->num_clks; i++) { + if (strcmp(pc->parent_name, data->clks[i].name) == 0) + break; + } + + if (i >= data->num_clks) + return -ENXIO; + + p = &data->clks[i]; + if (!p->pd || !p->ops->recalc_rate) + return -ENXIO; + + return p->ops->recalc_rate(p, sifive_prci_parent_rate(p, data)); + } + + if (strcmp(pc->parent_name, "rtcclk") == 0) + parent_rate = clk_get_rate(&pc->pd->parent_rtcclk); + else + parent_rate = clk_get_rate(&pc->pd->parent_hfclk); + + return parent_rate; +} + +static ulong sifive_prci_get_rate(struct clk *clk) +{ + struct __prci_clock *pc; + struct prci_clk_desc *data = + (struct prci_clk_desc *)dev_get_driver_data(clk->dev); + + if (data->num_clks <= clk->id) + return -ENXIO; + + pc = &data->clks[clk->id]; + if (!pc->pd || !pc->ops->recalc_rate) + return -ENXIO; + + return pc->ops->recalc_rate(pc, sifive_prci_parent_rate(pc, data)); +} + +static ulong sifive_prci_set_rate(struct clk *clk, ulong rate) +{ + int err; + struct __prci_clock *pc; + struct prci_clk_desc *data = + (struct prci_clk_desc *)dev_get_driver_data(clk->dev); + + if (data->num_clks <= clk->id) + return -ENXIO; + + pc = &data->clks[clk->id]; + if (!pc->pd || !pc->ops->set_rate) + return -ENXIO; + + err = pc->ops->set_rate(pc, rate, sifive_prci_parent_rate(pc, data)); + if (err) + return err; + + return rate; +} + +static int sifive_prci_enable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + struct prci_clk_desc *data = + (struct prci_clk_desc *)dev_get_driver_data(clk->dev); + + if (data->num_clks <= clk->id) + return -ENXIO; + + pc = &data->clks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 1); + + return ret; +} + +static int sifive_prci_disable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + struct prci_clk_desc *data = + (struct prci_clk_desc *)dev_get_driver_data(clk->dev); + + if (data->num_clks <= clk->id) + return -ENXIO; + + pc = &data->clks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 0); + + return ret; +} + +static int sifive_prci_probe(struct udevice *dev) +{ + int i, err; + struct __prci_clock *pc; + struct __prci_data *pd = dev_get_priv(dev); + + struct prci_clk_desc *data = + (struct prci_clk_desc *)dev_get_driver_data(dev); + + pd->va = (void *)dev_read_addr(dev); + if (IS_ERR(pd->va)) + return PTR_ERR(pd->va); + + err = clk_get_by_index(dev, 0, &pd->parent_hfclk); + if (err) + return err; + + err = clk_get_by_index(dev, 1, &pd->parent_rtcclk); + if (err) + return err; + + for (i = 0; i < data->num_clks; ++i) { + pc = &data->clks[i]; + pc->pd = pd; + if (pc->pwd) + __prci_wrpll_read_cfg0(pd, pc->pwd); + } + + if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (device_is_compatible(dev, "sifive,fu740-c000-prci")) { + u32 prci_pll_reg; + unsigned long parent_rate; + + prci_pll_reg = readl(pd->va + PRCI_PRCIPLL_OFFSET); + + if (prci_pll_reg & PRCI_PRCIPLL_HFPCLKPLL) { + /* + * Only initialize the HFPCLK PLL. In this + * case the design uses hfpclk to drive + * Chiplink + */ + pc = &data->clks[PRCI_CLK_HFPCLKPLL]; + parent_rate = sifive_prci_parent_rate(pc, data); + sifive_prci_wrpll_set_rate(pc, 260000000, + parent_rate); + pc->ops->enable_clk(pc, 1); + } else if (prci_pll_reg & PRCI_PRCIPLL_CLTXPLL) { + /* CLTX pll init */ + pc = &data->clks[PRCI_CLK_CLTXPLL]; + parent_rate = sifive_prci_parent_rate(pc, data); + sifive_prci_wrpll_set_rate(pc, 260000000, + parent_rate); + pc->ops->enable_clk(pc, 1); + } + } + } + + return 0; +} + +static struct clk_ops sifive_prci_ops = { + .set_rate = sifive_prci_set_rate, + .get_rate = sifive_prci_get_rate, + .enable = sifive_prci_enable, + .disable = sifive_prci_disable, +}; + +static int sifive_clk_bind(struct udevice *dev) +{ + return sifive_reset_bind(dev, PRCI_DEVICERESETCNT); +} + +static const struct udevice_id sifive_prci_ids[] = { + { .compatible = "sifive,fu540-c000-prci", .data = (ulong)&prci_clk_fu540 }, + { .compatible = "sifive,fu740-c000-prci", .data = (ulong)&prci_clk_fu740 }, + { } +}; + +U_BOOT_DRIVER(sifive_prci) = { + .name = "sifive-prci", + .id = UCLASS_CLK, + .of_match = sifive_prci_ids, + .probe = sifive_prci_probe, + .ops = &sifive_prci_ops, + .priv_auto = sizeof(struct __prci_data), + .bind = sifive_clk_bind, +}; diff --git a/drivers/clk/sifive/sifive-prci.h b/drivers/clk/sifive/sifive-prci.h new file mode 100644 index 0000000000..5ce33d6184 --- /dev/null +++ b/drivers/clk/sifive/sifive-prci.h @@ -0,0 +1,323 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + * Zong Li + * Pragnesh Patel + */ + +#ifndef __SIFIVE_CLK_SIFIVE_PRCI_H +#define __SIFIVE_CLK_SIFIVE_PRCI_H + +#include <clk.h> +#include <linux/clk/analogbits-wrpll-cln28hpc.h> + +/* + * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: + * hfclk and rtcclk + */ +#define EXPECTED_CLK_PARENT_COUNT 2 + +/* + * Register offsets and bitmasks + */ + +/* COREPLLCFG0 */ +#define PRCI_COREPLLCFG0_OFFSET 0x4 +#define PRCI_COREPLLCFG0_DIVR_SHIFT 0 +#define PRCI_COREPLLCFG0_DIVR_MASK (0x3f << PRCI_COREPLLCFG0_DIVR_SHIFT) +#define PRCI_COREPLLCFG0_DIVF_SHIFT 6 +#define PRCI_COREPLLCFG0_DIVF_MASK (0x1ff << PRCI_COREPLLCFG0_DIVF_SHIFT) +#define PRCI_COREPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_COREPLLCFG0_DIVQ_MASK (0x7 << PRCI_COREPLLCFG0_DIVQ_SHIFT) +#define PRCI_COREPLLCFG0_RANGE_SHIFT 18 +#define PRCI_COREPLLCFG0_RANGE_MASK (0x7 << PRCI_COREPLLCFG0_RANGE_SHIFT) +#define PRCI_COREPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_COREPLLCFG0_BYPASS_MASK (0x1 << PRCI_COREPLLCFG0_BYPASS_SHIFT) +#define PRCI_COREPLLCFG0_FSE_SHIFT 25 +#define PRCI_COREPLLCFG0_FSE_MASK (0x1 << PRCI_COREPLLCFG0_FSE_SHIFT) +#define PRCI_COREPLLCFG0_LOCK_SHIFT 31 +#define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT) + +/* COREPLLCFG1 */ +#define PRCI_COREPLLCFG1_OFFSET 0x8 +#define PRCI_COREPLLCFG1_CKE_SHIFT 31 +#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT) + +/* DDRPLLCFG0 */ +#define PRCI_DDRPLLCFG0_OFFSET 0xc +#define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 +#define PRCI_DDRPLLCFG0_DIVR_MASK (0x3f << PRCI_DDRPLLCFG0_DIVR_SHIFT) +#define PRCI_DDRPLLCFG0_DIVF_SHIFT 6 +#define PRCI_DDRPLLCFG0_DIVF_MASK (0x1ff << PRCI_DDRPLLCFG0_DIVF_SHIFT) +#define PRCI_DDRPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_DDRPLLCFG0_DIVQ_MASK (0x7 << PRCI_DDRPLLCFG0_DIVQ_SHIFT) +#define PRCI_DDRPLLCFG0_RANGE_SHIFT 18 +#define PRCI_DDRPLLCFG0_RANGE_MASK (0x7 << PRCI_DDRPLLCFG0_RANGE_SHIFT) +#define PRCI_DDRPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_DDRPLLCFG0_BYPASS_MASK (0x1 << PRCI_DDRPLLCFG0_BYPASS_SHIFT) +#define PRCI_DDRPLLCFG0_FSE_SHIFT 25 +#define PRCI_DDRPLLCFG0_FSE_MASK (0x1 << PRCI_DDRPLLCFG0_FSE_SHIFT) +#define PRCI_DDRPLLCFG0_LOCK_SHIFT 31 +#define PRCI_DDRPLLCFG0_LOCK_MASK (0x1 << PRCI_DDRPLLCFG0_LOCK_SHIFT) + +/* DDRPLLCFG1 */ +#define PRCI_DDRPLLCFG1_OFFSET 0x10 +#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 +#define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT) + +/* PCIEAUXCFG1 */ +#define PRCI_PCIEAUXCFG1_OFFSET 0x14 +#define PRCI_PCIEAUXCFG1_SHIFT 0 +#define PRCI_PCIEAUXCFG1_MASK (0x1 << PRCI_PCIEAUXCFG1_SHIFT) + +/* GEMGXLPLLCFG0 */ +#define PRCI_GEMGXLPLLCFG0_OFFSET 0x1c +#define PRCI_GEMGXLPLLCFG0_DIVR_SHIFT 0 +#define PRCI_GEMGXLPLLCFG0_DIVR_MASK \ + (0x3f << PRCI_GEMGXLPLLCFG0_DIVR_SHIFT) +#define PRCI_GEMGXLPLLCFG0_DIVF_SHIFT 6 +#define PRCI_GEMGXLPLLCFG0_DIVF_MASK \ + (0x1ff << PRCI_GEMGXLPLLCFG0_DIVF_SHIFT) +#define PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_GEMGXLPLLCFG0_DIVQ_MASK (0x7 << PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT) +#define PRCI_GEMGXLPLLCFG0_RANGE_SHIFT 18 +#define PRCI_GEMGXLPLLCFG0_RANGE_MASK \ + (0x7 << PRCI_GEMGXLPLLCFG0_RANGE_SHIFT) +#define PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_GEMGXLPLLCFG0_BYPASS_MASK \ + (0x1 << PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT) +#define PRCI_GEMGXLPLLCFG0_FSE_SHIFT 25 +#define PRCI_GEMGXLPLLCFG0_FSE_MASK \ + (0x1 << PRCI_GEMGXLPLLCFG0_FSE_SHIFT) +#define PRCI_GEMGXLPLLCFG0_LOCK_SHIFT 31 +#define PRCI_GEMGXLPLLCFG0_LOCK_MASK (0x1 << PRCI_GEMGXLPLLCFG0_LOCK_SHIFT) + +/* GEMGXLPLLCFG1 */ +#define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 +#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 +#define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT) + +/* CORECLKSEL */ +#define PRCI_CORECLKSEL_OFFSET 0x24 +#define PRCI_CORECLKSEL_CORECLKSEL_SHIFT 0 +#define PRCI_CORECLKSEL_CORECLKSEL_MASK \ + (0x1 << PRCI_CORECLKSEL_CORECLKSEL_SHIFT) + +/* DEVICESRESETREG */ +#define PRCI_DEVICESRESETREG_OFFSET 0x28 +#define PRCI_DEVICERESETCNT 6 + +/* CLKMUXSTATUSREG */ +#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c +#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 +#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ + (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT) + +/* CLTXPLLCFG0 */ +#define PRCI_CLTXPLLCFG0_OFFSET 0x30 +#define PRCI_CLTXPLLCFG0_DIVR_SHIFT 0 +#define PRCI_CLTXPLLCFG0_DIVR_MASK (0x3f << PRCI_CLTXPLLCFG0_DIVR_SHIFT) +#define PRCI_CLTXPLLCFG0_DIVF_SHIFT 6 +#define PRCI_CLTXPLLCFG0_DIVF_MASK (0x1ff << PRCI_CLTXPLLCFG0_DIVF_SHIFT) +#define PRCI_CLTXPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_CLTXPLLCFG0_DIVQ_MASK (0x7 << PRCI_CLTXPLLCFG0_DIVQ_SHIFT) +#define PRCI_CLTXPLLCFG0_RANGE_SHIFT 18 +#define PRCI_CLTXPLLCFG0_RANGE_MASK (0x7 << PRCI_CLTXPLLCFG0_RANGE_SHIFT) +#define PRCI_CLTXPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_CLTXPLLCFG0_BYPASS_MASK (0x1 << PRCI_CLTXPLLCFG0_BYPASS_SHIFT) +#define PRCI_CLTXPLLCFG0_FSE_SHIFT 25 +#define PRCI_CLTXPLLCFG0_FSE_MASK (0x1 << PRCI_CLTXPLLCFG0_FSE_SHIFT) +#define PRCI_CLTXPLLCFG0_LOCK_SHIFT 31 +#define PRCI_CLTXPLLCFG0_LOCK_MASK (0x1 << PRCI_CLTXPLLCFG0_LOCK_SHIFT) + +/* CLTXPLLCFG1 */ +#define PRCI_CLTXPLLCFG1_OFFSET 0x34 +#define PRCI_CLTXPLLCFG1_CKE_SHIFT 24 +#define PRCI_CLTXPLLCFG1_CKE_MASK (0x1 << PRCI_CLTXPLLCFG1_CKE_SHIFT) + +/* DVFSCOREPLLCFG0 */ +#define PRCI_DVFSCOREPLLCFG0_OFFSET 0x38 + +/* DVFSCOREPLLCFG1 */ +#define PRCI_DVFSCOREPLLCFG1_OFFSET 0x3c +#define PRCI_DVFSCOREPLLCFG1_CKE_SHIFT 24 +#define PRCI_DVFSCOREPLLCFG1_CKE_MASK (0x1 << PRCI_DVFSCOREPLLCFG1_CKE_SHIFT) + +/* COREPLLSEL */ +#define PRCI_COREPLLSEL_OFFSET 0x40 +#define PRCI_COREPLLSEL_COREPLLSEL_SHIFT 0 +#define PRCI_COREPLLSEL_COREPLLSEL_MASK \ + (0x1 << PRCI_COREPLLSEL_COREPLLSEL_SHIFT) + +/* HFPCLKPLLCFG0 */ +#define PRCI_HFPCLKPLLCFG0_OFFSET 0x50 +#define PRCI_HFPCLKPLL_CFG0_DIVR_SHIFT 0 +#define PRCI_HFPCLKPLL_CFG0_DIVR_MASK \ + (0x3f << PRCI_HFPCLKPLLCFG0_DIVR_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_DIVF_SHIFT 6 +#define PRCI_HFPCLKPLL_CFG0_DIVF_MASK \ + (0x1ff << PRCI_HFPCLKPLLCFG0_DIVF_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_DIVQ_SHIFT 15 +#define PRCI_HFPCLKPLL_CFG0_DIVQ_MASK \ + (0x7 << PRCI_HFPCLKPLLCFG0_DIVQ_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_RANGE_SHIFT 18 +#define PRCI_HFPCLKPLL_CFG0_RANGE_MASK \ + (0x7 << PRCI_HFPCLKPLLCFG0_RANGE_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_BYPASS_SHIFT 24 +#define PRCI_HFPCLKPLL_CFG0_BYPASS_MASK \ + (0x1 << PRCI_HFPCLKPLLCFG0_BYPASS_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_FSE_SHIFT 25 +#define PRCI_HFPCLKPLL_CFG0_FSE_MASK \ + (0x1 << PRCI_HFPCLKPLLCFG0_FSE_SHIFT) +#define PRCI_HFPCLKPLL_CFG0_LOCK_SHIFT 31 +#define PRCI_HFPCLKPLL_CFG0_LOCK_MASK \ + (0x1 << PRCI_HFPCLKPLLCFG0_LOCK_SHIFT) + +/* HFPCLKPLLCFG1 */ +#define PRCI_HFPCLKPLLCFG1_OFFSET 0x54 +#define PRCI_HFPCLKPLLCFG1_CKE_SHIFT 24 +#define PRCI_HFPCLKPLLCFG1_CKE_MASK \ + (0x1 << PRCI_HFPCLKPLLCFG1_CKE_SHIFT) + +/* HFPCLKPLLSEL */ +#define PRCI_HFPCLKPLLSEL_OFFSET 0x58 +#define PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_SHIFT 0 +#define PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK \ + (0x1 << PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_SHIFT) + +/* HFPCLKPLLDIV */ +#define PRCI_HFPCLKPLLDIV_OFFSET 0x5c + +/* PRCIPLL */ +#define PRCI_PRCIPLL_OFFSET 0xe0 + +#define PRCI_PRCIPLL_CLTXPLL (0x1 << 0) +#define PRCI_PRCIPLL_GEMGXLPLL (0x1 << 1) +#define PRCI_PRCIPLL_DDRPLL (0x1 << 2) +#define PRCI_PRCIPLL_HFPCLKPLL (0x1 << 3) +#define PRCI_PRCIPLL_DVFSCOREPLL (0x1 << 4) +#define PRCI_PRCIPLL_COREPLL (0x1 << 5) + +/* PROCMONCFG */ +#define PRCI_PROCMONCFG_OFFSET 0xF0 +#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 +#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \ + (0x1 << PRCI_PROCMONCFG_CORE_CLOCK_SHIFT) + +/* + * Private structures + */ + +/** + * struct __prci_data - per-device-instance data + * @va: base virtual address of the PRCI IP block + * @parent: parent clk instance + * + * PRCI per-device instance data + */ +struct __prci_data { + void *va; + struct clk parent_hfclk; + struct clk parent_rtcclk; +}; + +/** + * struct __prci_wrpll_data - WRPLL configuration and integration data + * @c: WRPLL current configuration record + * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) + * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) + * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address + * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address + * @release_reset: fn ptr to code to release clock reset + * + * @enable_bypass and @disable_bypass are used for WRPLL instances + * that contain a separate external glitchless clock mux downstream + * from the PLL. The WRPLL internal bypass mux is not glitchless. + */ +struct __prci_wrpll_data { + struct wrpll_cfg c; + void (*enable_bypass)(struct __prci_data *pd); + void (*disable_bypass)(struct __prci_data *pd); + u8 cfg0_offs; + u8 cfg1_offs; + void (*release_reset)(struct __prci_data *pd); +}; + +/** + * struct __prci_clock - describes a clock device managed by PRCI + * @name: user-readable clock name string - should match the manual + * @parent_name: parent name for this clock + * @ops: struct __prci_clock_ops for control + * @pwd: WRPLL-specific data, associated with this clock (if not NULL) + * @pd: PRCI-specific data associated with this clock (if not NULL) + * + * PRCI clock data. Used by the PRCI driver to register PRCI-provided + * clocks to the Linux clock infrastructure. + */ +struct __prci_clock { + const char *name; + const char *parent_name; + const struct __prci_clock_ops *ops; + struct __prci_wrpll_data *pwd; + struct __prci_data *pd; +}; + +/* struct __prci_clock_ops - clock operations */ +struct __prci_clock_ops { + int (*set_rate)(struct __prci_clock *pc, + unsigned long rate, + unsigned long parent_rate); + unsigned long (*round_rate)(struct __prci_clock *pc, + unsigned long rate, + unsigned long *parent_rate); + unsigned long (*recalc_rate)(struct __prci_clock *pc, + unsigned long parent_rate); + int (*enable_clk)(struct __prci_clock *pc, bool enable); +}; + +/* + * struct prci_clk_desc - describes the information of clocks of each SoCs + * @clks: point to a array of __prci_clock + * @num_clks: the number of element of clks + */ +struct prci_clk_desc { + struct __prci_clock *clks; + size_t num_clks; +}; + +void sifive_prci_ethernet_release_reset(struct __prci_data *pd); +void sifive_prci_ddr_release_reset(struct __prci_data *pd); +void sifive_prci_cltx_release_reset(struct __prci_data *pd); + +/* Core clock mux control */ +void sifive_prci_coreclksel_use_hfclk(struct __prci_data *pd); +void sifive_prci_coreclksel_use_corepll(struct __prci_data *pd); +void sifive_prci_coreclksel_use_final_corepll(struct __prci_data *pd); +void sifive_prci_corepllsel_use_dvfscorepll(struct __prci_data *pd); +void sifive_prci_corepllsel_use_corepll(struct __prci_data *pd); +void sifive_prci_hfpclkpllsel_use_hfclk(struct __prci_data *pd); +void sifive_prci_hfpclkpllsel_use_hfpclkpll(struct __prci_data *pd); + +unsigned long sifive_prci_wrpll_round_rate(struct __prci_clock *pc, + unsigned long rate, + unsigned long *parent_rate); + +/* Linux clock framework integration */ +int sifive_prci_wrpll_set_rate(struct __prci_clock *pc, + unsigned long rate, + unsigned long parent_rate); + +unsigned long sifive_prci_wrpll_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate); + +unsigned long sifive_prci_tlclksel_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate); + +unsigned long sifive_prci_hfpclkplldiv_recalc_rate(struct __prci_clock *pc, + unsigned long parent_rate); + +int sifive_prci_clock_enable(struct __prci_clock *pc, bool enable); + +#endif /* __SIFIVE_CLK_SIFIVE_PRCI_H */
Rename fu540_ddr.c to sifive_ddr.c and add fu740 support
Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/ram/sifive/Kconfig | 8 +- drivers/ram/sifive/Makefile | 2 +- .../ram/sifive/{fu540_ddr.c => sifive_ddr.c} | 89 ++++++++++--------- 3 files changed, 50 insertions(+), 49 deletions(-) rename drivers/ram/sifive/{fu540_ddr.c => sifive_ddr.c} (81%)
diff --git a/drivers/ram/sifive/Kconfig b/drivers/ram/sifive/Kconfig index 08de692e02..0aaac02656 100644 --- a/drivers/ram/sifive/Kconfig +++ b/drivers/ram/sifive/Kconfig @@ -5,9 +5,9 @@ config RAM_SIFIVE help This enables support for ram drivers of SiFive SoCs.
-config SIFIVE_FU540_DDR - bool "SiFive FU540 DDR driver" +config SIFIVE_DDR + bool "SiFive DDR driver" depends on RAM_SIFIVE - default y if TARGET_SIFIVE_UNLEASHED + default y if TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED help - This enables DDR support for the platforms based on SiFive FU540 SoC. + This enables DDR support for the platforms based on SiFive SoC. diff --git a/drivers/ram/sifive/Makefile b/drivers/ram/sifive/Makefile index d66efec264..4ef89f85bb 100644 --- a/drivers/ram/sifive/Makefile +++ b/drivers/ram/sifive/Makefile @@ -3,4 +3,4 @@ # Copyright (c) 2020 SiFive, Inc #
-obj-$(CONFIG_SIFIVE_FU540_DDR) += fu540_ddr.o +obj-$(CONFIG_SIFIVE_DDR) += sifive_ddr.o diff --git a/drivers/ram/sifive/fu540_ddr.c b/drivers/ram/sifive/sifive_ddr.c similarity index 81% rename from drivers/ram/sifive/fu540_ddr.c rename to drivers/ram/sifive/sifive_ddr.c index c0653bb897..ba18466033 100644 --- a/drivers/ram/sifive/fu540_ddr.c +++ b/drivers/ram/sifive/sifive_ddr.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause /* - * (C) Copyright 2020 SiFive, Inc. + * (C) Copyright 2020-2021 SiFive, Inc. * * Authors: * Pragnesh Patel pragnesh.patel@sifive.com @@ -65,16 +65,16 @@
DECLARE_GLOBAL_DATA_PTR;
-struct fu540_ddrctl { +struct sifive_ddrctl { volatile u32 denali_ctl[265]; };
-struct fu540_ddrphy { +struct sifive_ddrphy { volatile u32 denali_phy[1215]; };
/** - * struct fu540_ddr_info + * struct sifive_ddr_info * * @dev : pointer for the device * @info : UCLASS RAM information @@ -83,23 +83,23 @@ struct fu540_ddrphy { * @ctrl : DDR control base address * @physical_filter_ctrl : DDR physical filter control base address */ -struct fu540_ddr_info { +struct sifive_ddr_info { struct udevice *dev; struct ram_info info; - struct fu540_ddrctl *ctl; - struct fu540_ddrphy *phy; + struct sifive_ddrctl *ctl; + struct sifive_ddrphy *phy; struct clk ddr_clk; u32 *physical_filter_ctrl; };
#if defined(CONFIG_SPL_BUILD) -struct fu540_ddr_params { - struct fu540_ddrctl pctl_regs; - struct fu540_ddrphy phy_regs; +struct sifive_ddr_params { + struct sifive_ddrctl pctl_regs; + struct sifive_ddrphy phy_regs; };
struct sifive_dmc_plat { - struct fu540_ddr_params ddr_params; + struct sifive_ddr_params ddr_params; };
/* @@ -118,7 +118,7 @@ static void sdram_copy_to_reg(volatile u32 *dest, } }
-static void fu540_ddr_setup_range_protection(volatile u32 *ctl, u64 end_addr) +static void sifive_ddr_setup_range_protection(volatile u32 *ctl, u64 end_addr) { u32 end_addr_16kblocks = ((end_addr >> 14) & 0x7FFFFF) - 1;
@@ -135,8 +135,8 @@ static void fu540_ddr_setup_range_protection(volatile u32 *ctl, u64 end_addr) 0x1 << PORT_ADDR_PROTECTION_EN_OFFSET); }
-static void fu540_ddr_start(volatile u32 *ctl, u32 *physical_filter_ctrl, - u64 ddr_end) +static void sifive_ddr_start(volatile u32 *ctl, u32 *physical_filter_ctrl, + u64 ddr_end) { volatile u64 *filterreg = (volatile u64 *)physical_filter_ctrl;
@@ -149,7 +149,7 @@ static void fu540_ddr_start(volatile u32 *ctl, u32 *physical_filter_ctrl, filterreg[0] = 0x0f00000000000000UL | (ddr_end >> 2); }
-static void fu540_ddr_check_errata(u32 regbase, u32 updownreg) +static void sifive_ddr_check_errata(u32 regbase, u32 updownreg) { u64 fails = 0; u32 dq = 0; @@ -202,7 +202,7 @@ static void fu540_ddr_check_errata(u32 regbase, u32 updownreg) } }
-static u64 fu540_ddr_phy_fixup(volatile u32 *ddrphyreg) +static u64 sifive_ddr_phy_fixup(volatile u32 *ddrphyreg) { u32 slicebase = 0;
@@ -213,7 +213,7 @@ static u64 fu540_ddr_phy_fixup(volatile u32 *ddrphyreg) for (u32 reg = 0; reg < 4; reg++) { u32 updownreg = readl(regbase + reg + ddrphyreg);
- fu540_ddr_check_errata(regbase, updownreg); + sifive_ddr_check_errata(regbase, updownreg); } slicebase += 128; } @@ -221,18 +221,18 @@ static u64 fu540_ddr_phy_fixup(volatile u32 *ddrphyreg) return(0); }
-static u32 fu540_ddr_get_dram_class(volatile u32 *ctl) +static u32 sifive_ddr_get_dram_class(volatile u32 *ctl) { u32 reg = readl(DENALI_CTL_0 + ctl);
return ((reg >> DRAM_CLASS_OFFSET) & 0xF); }
-static int fu540_ddr_setup(struct udevice *dev) +static int sifive_ddr_setup(struct udevice *dev) { - struct fu540_ddr_info *priv = dev_get_priv(dev); + struct sifive_ddr_info *priv = dev_get_priv(dev); struct sifive_dmc_plat *plat = dev_get_plat(dev); - struct fu540_ddr_params *params = &plat->ddr_params; + struct sifive_ddr_params *params = &plat->ddr_params; volatile u32 *denali_ctl = priv->ctl->denali_ctl; volatile u32 *denali_phy = priv->phy->denali_phy; const u64 ddr_size = priv->info.size; @@ -251,7 +251,7 @@ static int fu540_ddr_setup(struct udevice *dev)
sdram_copy_to_reg(priv->ctl->denali_ctl, params->pctl_regs.denali_ctl, - sizeof(struct fu540_ddrctl)); + sizeof(struct sifive_ddrctl));
/* phy reset */ for (i = DENALI_PHY_1152; i <= DENALI_PHY_1214; i++) { @@ -285,7 +285,7 @@ static int fu540_ddr_setup(struct udevice *dev) setbits_le32(DENALI_CTL_182 + denali_ctl, 1 << DFI_PHY_RDLVL_GATE_MODE_OFFSET);
- if (fu540_ddr_get_dram_class(denali_ctl) == DRAM_CLASS_DDR4) { + if (sifive_ddr_get_dram_class(denali_ctl) == DRAM_CLASS_DDR4) { /* Enable vref training DENALI_CTL_184 */ setbits_le32(DENALI_CTL_184 + denali_ctl, 1 << VREF_EN_OFFSET); } @@ -302,15 +302,15 @@ static int fu540_ddr_setup(struct udevice *dev) | (1 << MULTIPLE_OUT_OF_RANGE_OFFSET));
/* set up range protection */ - fu540_ddr_setup_range_protection(denali_ctl, priv->info.size); + sifive_ddr_setup_range_protection(denali_ctl, priv->info.size);
/* Mask off port command error interrupt DENALI_CTL_136 */ setbits_le32(DENALI_CTL_136 + denali_ctl, 1 << PORT_COMMAND_CHANNEL_ERROR_OFFSET);
- fu540_ddr_start(denali_ctl, priv->physical_filter_ctrl, ddr_end); + sifive_ddr_start(denali_ctl, priv->physical_filter_ctrl, ddr_end);
- fu540_ddr_phy_fixup(denali_phy); + sifive_ddr_phy_fixup(denali_phy);
/* check size */ priv->info.size = get_ram_size((long *)priv->info.base, @@ -329,9 +329,9 @@ static int fu540_ddr_setup(struct udevice *dev) } #endif
-static int fu540_ddr_probe(struct udevice *dev) +static int sifive_ddr_probe(struct udevice *dev) { - struct fu540_ddr_info *priv = dev_get_priv(dev); + struct sifive_ddr_info *priv = dev_get_priv(dev);
/* Read memory base and size from DT */ fdtdec_setup_mem_size_base(); @@ -342,7 +342,7 @@ static int fu540_ddr_probe(struct udevice *dev) int ret; u32 clock = 0;
- debug("FU540 DDR probe\n"); + debug("sifive DDR probe\n"); priv->dev = dev;
ret = clk_get_by_index(dev, 0, &priv->ddr_clk); @@ -369,42 +369,43 @@ static int fu540_ddr_probe(struct udevice *dev) return ret; }
- priv->ctl = (struct fu540_ddrctl *)dev_read_addr_index(dev, 0); - priv->phy = (struct fu540_ddrphy *)dev_read_addr_index(dev, 1); + priv->ctl = (struct sifive_ddrctl *)dev_read_addr_index(dev, 0); + priv->phy = (struct sifive_ddrphy *)dev_read_addr_index(dev, 1); priv->physical_filter_ctrl = (u32 *)dev_read_addr_index(dev, 2);
- return fu540_ddr_setup(dev); + return sifive_ddr_setup(dev); #endif
return 0; }
-static int fu540_ddr_get_info(struct udevice *dev, struct ram_info *info) +static int sifive_ddr_get_info(struct udevice *dev, struct ram_info *info) { - struct fu540_ddr_info *priv = dev_get_priv(dev); + struct sifive_ddr_info *priv = dev_get_priv(dev);
*info = priv->info;
return 0; }
-static struct ram_ops fu540_ddr_ops = { - .get_info = fu540_ddr_get_info, +static struct ram_ops sifive_ddr_ops = { + .get_info = sifive_ddr_get_info, };
-static const struct udevice_id fu540_ddr_ids[] = { +static const struct udevice_id sifive_ddr_ids[] = { { .compatible = "sifive,fu540-c000-ddr" }, + { .compatible = "sifive,fu740-c000-ddr" }, { } };
-U_BOOT_DRIVER(fu540_ddr) = { - .name = "fu540_ddr", +U_BOOT_DRIVER(sifive_ddr) = { + .name = "sifive_ddr", .id = UCLASS_RAM, - .of_match = fu540_ddr_ids, - .ops = &fu540_ddr_ops, - .probe = fu540_ddr_probe, - .priv_auto = sizeof(struct fu540_ddr_info), + .of_match = sifive_ddr_ids, + .ops = &sifive_ddr_ops, + .probe = sifive_ddr_probe, + .priv_auto = sizeof(struct sifive_ddr_info), #if defined(CONFIG_SPL_BUILD) - .plat_auto = sizeof(struct sifive_dmc_plat), + .plat_auto = sizeof(struct sifive_dmc_plat), #endif };
Add pcie driver for SiFive fu740, the driver depends on fu740 gpio, clk and reset driver to do init. Force running at Gen1 for better capatible enumeration.
Several devices are tested: a) M.2 NVMe SSD b) USB-to-PCI adapter c) Ethernet adapter (E1000 compatible)
Signed-off-by: Green Wan green.wan@sifive.com --- drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_sifive.c | 508 +++++++++++++++++++++++++++++++++++ 3 files changed, 519 insertions(+) create mode 100644 drivers/pci/pcie_dw_sifive.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index cdcdd8f456..b11dd5c02d 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -97,6 +97,16 @@ config PCIE_DW_MVEBU Armada-8K SoCs. The PCIe controller on Armada-8K is based on DesignWare hardware.
+config PCIE_DW_SIFIVE + bool "Enable SiFive FU740 PCIe" + depends on CLK_SIFIVE_PRCI + depends on RESET_SIFIVE + depends on SIFIVE_GPIO + select PCIE_DW_COMMON + help + Say Y here if you want to enable PCIe controller support on + FU740. + config PCIE_FSL bool "FSL PowerPC PCIe support" depends on DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 96d61821fe..7351f8027d 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -53,3 +53,4 @@ obj-$(CONFIG_PCIE_DW_ROCKCHIP) += pcie_dw_rockchip.o obj-$(CONFIG_PCIE_DW_MESON) += pcie_dw_meson.o obj-$(CONFIG_PCI_BRCMSTB) += pcie_brcmstb.o obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o +obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o diff --git a/drivers/pci/pcie_dw_sifive.c b/drivers/pci/pcie_dw_sifive.c new file mode 100644 index 0000000000..599eb0ece2 --- /dev/null +++ b/drivers/pci/pcie_dw_sifive.c @@ -0,0 +1,508 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SiFive FU740 DesignWare PCIe Controller + * + * Copyright (C) 2020-2021 SiFive, Inc. + * + * Based in early part on the i.MX6 PCIe host controller shim which is: + * + * Copyright (C) 2013 Kosagi + * http://www.kosagi.com + * + * Based on driver from author: Alan Mikhak amikhak@wirelessfabric.com + */ +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitops.h> +#include <linux/log2.h> +#include <pci.h> +#include <pci_ep.h> +#include <pci_ids.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> + +#include "pcie_dw_common.h" + +struct pcie_sifive { + /* Must be first member of the struct */ + struct pcie_dw dw; + + /* private control regs */ + void __iomem *priv_base; + + /* reset, power, clock resources */ + int sys_int_pin; + struct gpio_desc pwren_gpio; + struct gpio_desc reset_gpio; + struct clk aux_ck; + struct reset_ctl reset; +}; + +enum pcie_sifive_devtype { + SV_PCIE_UNKNOWN_TYPE = 0, + SV_PCIE_ENDPOINT_TYPE = 1, + SV_PCIE_HOST_TYPE = 3 +}; + +#define ASSERTION_DELAY 100 +#define PCIE_PERST_ASSERT 0x0 +#define PCIE_PERST_DEASSERT 0x1 +#define PCIE_PHY_RESET 0x1 +#define PCIE_PHY_RESET_DEASSERT 0x0 +#define GPIO_LOW 0x0 +#define GPIO_HIGH 0x1 +#define PCIE_PHY_SEL 0x1 + +#define sv_info(sv, fmt, arg...) printf(fmt, ## arg) +#define sv_warn(sv, fmt, arg...) printf(fmt, ## arg) +#define sv_debug(sv, fmt, arg...) debug(fmt, ## arg) +#define sv_err(sv, fmt, arg...) printf(fmt, ## arg) + +/* Doorbell Interface */ +#define DBI_OFFSET 0x0 +#define DBI_SIZE 0x1000 + +#define PL_OFFSET 0x700 + +#define PHY_DEBUG_R0 (PL_OFFSET + 0x28) + +#define PHY_DEBUG_R1 (PL_OFFSET + 0x2c) +#define PHY_DEBUG_R1_LINK_UP (0x1 << 4) +#define PHY_DEBUG_R1_LINK_IN_TRAINING (0x1 << 29) + +#define PCIE_MISC_CONTROL_1 0x8bc +#define DBI_RO_WR_EN BIT(0) + +/* pcie reset */ +#define PCIEX8MGMT_PERST_N 0x0 + +/* LTSSM */ +#define PCIEX8MGMT_APP_LTSSM_ENABLE 0x10 +#define LTSSM_ENABLE_BIT BIT(0) + +/* phy reset */ +#define PCIEX8MGMT_APP_HOLD_PHY_RST 0x18 + +/* device type */ +#define PCIEX8MGMT_DEVICE_TYPE 0x708 +#define DEVICE_TYPE_EP 0x0 +#define DEVICE_TYPE_RC 0x4 + +/* phy control registers*/ +#define PCIEX8MGMT_PHY0_CR_PARA_ADDR 0x860 +#define PCIEX8MGMT_PHY0_CR_PARA_RD_EN 0x870 +#define PCIEX8MGMT_PHY0_CR_PARA_RD_DATA 0x878 +#define PCIEX8MGMT_PHY0_CR_PARA_SEL 0x880 +#define PCIEX8MGMT_PHY0_CR_PARA_WR_DATA 0x888 +#define PCIEX8MGMT_PHY0_CR_PARA_WR_EN 0x890 +#define PCIEX8MGMT_PHY0_CR_PARA_ACK 0x898 +#define PCIEX8MGMT_PHY1_CR_PARA_ADDR 0x8a0 +#define PCIEX8MGMT_PHY1_CR_PARA_RD_EN 0x8b0 +#define PCIEX8MGMT_PHY1_CR_PARA_RD_DATA 0x8b8 +#define PCIEX8MGMT_PHY1_CR_PARA_SEL 0x8c0 +#define PCIEX8MGMT_PHY1_CR_PARA_WR_DATA 0x8c8 +#define PCIEX8MGMT_PHY1_CR_PARA_WR_EN 0x8d0 +#define PCIEX8MGMT_PHY1_CR_PARA_ACK 0x8d8 + +#define PCIEX8MGMT_LANE_NUM 8 +#define PCIEX8MGMT_LANE 0x1008 +#define PCIEX8MGMT_LANE_OFF 0x100 +#define PCIEX8MGMT_TERM_MODE 0x0e21 + +#define PCIE_CAP_BASE 0x70 +#define PCI_CONFIG(r) (DBI_OFFSET + (r)) +#define PCIE_CAPABILITIES(r) PCI_CONFIG(PCIE_CAP_BASE + (r)) + +/* Link capability */ +#define PF0_PCIE_CAP_LINK_CAP PCIE_CAPABILITIES(0xc) +#define PCIE_LINK_CAP_MAX_SPEED_MASK 0xf +#define PCIE_LINK_CAP_MAX_SPEED_GEN1 BIT(0) +#define PCIE_LINK_CAP_MAX_SPEED_GEN2 BIT(1) +#define PCIE_LINK_CAP_MAX_SPEED_GEN3 BIT(2) +#define PCIE_LINK_CAP_MAX_SPEED_GEN4 BIT(3) + +static enum pcie_sifive_devtype pcie_sifive_get_devtype(struct pcie_sifive *sv) +{ + u32 val; + + val = readl(sv->priv_base + PCIEX8MGMT_DEVICE_TYPE); + switch (val) { + case DEVICE_TYPE_RC: + return SV_PCIE_HOST_TYPE; + case DEVICE_TYPE_EP: + return SV_PCIE_ENDPOINT_TYPE; + default: + return SV_PCIE_UNKNOWN_TYPE; + } +} + +static void pcie_sifive_priv_set_state(struct pcie_sifive *sv, u32 reg, + u32 bits, int state) +{ + u32 val; + + val = readl(sv->priv_base + reg); + val = state ? (val | bits) : (val & !bits); + writel(val, sv->priv_base + reg); +} + +static void pcie_sifive_assert_reset(struct pcie_sifive *sv) +{ + dm_gpio_set_value(&sv->reset_gpio, GPIO_LOW); + writel(PCIE_PERST_ASSERT, sv->priv_base + PCIEX8MGMT_PERST_N); + mdelay(ASSERTION_DELAY); +} + +static void pcie_sifive_power_on(struct pcie_sifive *sv) +{ + dm_gpio_set_value(&sv->pwren_gpio, GPIO_HIGH); + mdelay(ASSERTION_DELAY); +} + +static void pcie_sifive_deassert_reset(struct pcie_sifive *sv) +{ + writel(PCIE_PERST_DEASSERT, sv->priv_base + PCIEX8MGMT_PERST_N); + dm_gpio_set_value(&sv->reset_gpio, GPIO_HIGH); + mdelay(ASSERTION_DELAY); +} + +static int pcie_sifive_setphy(const u8 phy, const u8 write, + const u16 addr, const u16 wrdata, + u16 *rddata, struct pcie_sifive *sv) +{ + unsigned char ack = 0; + + if (!(phy == 0 || phy == 1)) + return -2; + + /* setup phy para */ + writel(addr, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_ADDR : + PCIEX8MGMT_PHY0_CR_PARA_ADDR)); + + if (write) + writel(wrdata, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_WR_DATA : + PCIEX8MGMT_PHY0_CR_PARA_WR_DATA)); + + /* enable access if write */ + if (write) + writel(1, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_WR_EN : + PCIEX8MGMT_PHY0_CR_PARA_WR_EN)); + else + writel(1, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_RD_EN : + PCIEX8MGMT_PHY0_CR_PARA_RD_EN)); + + /* wait for wait_idle */ + do { + u32 val; + + val = readl(sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_ACK : + PCIEX8MGMT_PHY0_CR_PARA_ACK)); + if (val) { + ack = 1; + if (!write) + readl(sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_RD_DATA : + PCIEX8MGMT_PHY0_CR_PARA_RD_DATA)); + mdelay(1); + } + } while (!ack); + + /* clear */ + if (write) + writel(0, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_WR_EN : + PCIEX8MGMT_PHY0_CR_PARA_WR_EN)); + else + writel(0, sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_RD_EN : + PCIEX8MGMT_PHY0_CR_PARA_RD_EN)); + + while (readl(sv->priv_base + + (phy ? PCIEX8MGMT_PHY1_CR_PARA_ACK : + PCIEX8MGMT_PHY0_CR_PARA_ACK))) { + /* wait for ~wait_idle */ + } + + return 0; +} + +static void pcie_sifive_init_phy(struct pcie_sifive *sv) +{ + int lane; + + /* enable phy cr_para_sel interfaces */ + writel(PCIE_PHY_SEL, sv->priv_base + PCIEX8MGMT_PHY0_CR_PARA_SEL); + writel(PCIE_PHY_SEL, sv->priv_base + PCIEX8MGMT_PHY1_CR_PARA_SEL); + mdelay(1); + + /* set PHY AC termination mode */ + for (lane = 0; lane < PCIEX8MGMT_LANE_NUM; lane++) { + pcie_sifive_setphy(0, 1, + PCIEX8MGMT_LANE + + (PCIEX8MGMT_LANE_OFF * lane), + PCIEX8MGMT_TERM_MODE, NULL, sv); + pcie_sifive_setphy(1, 1, + PCIEX8MGMT_LANE + + (PCIEX8MGMT_LANE_OFF * lane), + PCIEX8MGMT_TERM_MODE, NULL, sv); + } +} + +static int pcie_sifive_check_link(struct pcie_sifive *sv) +{ + u32 val; + + val = readl(sv->dw.dbi_base + PHY_DEBUG_R1); + return (val & PHY_DEBUG_R1_LINK_UP) && + !(val & PHY_DEBUG_R1_LINK_IN_TRAINING); +} + +static void pcie_sifive_force_gen1(struct pcie_sifive *sv) +{ + u32 val, linkcap; + + /* + * Force Gen1 operation when starting the link. In case the link is + * started in Gen2 mode, there is a possibility the devices on the + * bus will not be detected at all. This happens with PCIe switches. + */ + + /* ctrl_ro_wr_enable */ + val = readl(sv->dw.dbi_base + PCIE_MISC_CONTROL_1); + val |= DBI_RO_WR_EN; + writel(val, sv->dw.dbi_base + PCIE_MISC_CONTROL_1); + + /* configure link cap */ + linkcap = readl(sv->dw.dbi_base + PF0_PCIE_CAP_LINK_CAP); + linkcap |= PCIE_LINK_CAP_MAX_SPEED_MASK; + writel(linkcap, sv->dw.dbi_base + PF0_PCIE_CAP_LINK_CAP); + + /* ctrl_ro_wr_disable */ + val &= ~DBI_RO_WR_EN; + writel(val, sv->dw.dbi_base + PCIE_MISC_CONTROL_1); +} + +static void pcie_sifive_print_phy_debug(struct pcie_sifive *sv) +{ + sv_err(sv, "PHY DEBUG_R0=0x%08x DEBUG_R1=0x%08x\n", + readl(sv->dw.dbi_base + PHY_DEBUG_R0), + readl(sv->dw.dbi_base + PHY_DEBUG_R1)); +} + +static int pcie_sifive_wait_for_link(struct pcie_sifive *sv) +{ + u32 val; + int timeout; + + /* Wait for the link to train */ + mdelay(20); + timeout = 20; + + do { + mdelay(1); + } while (--timeout && !pcie_sifive_check_link(sv)); + + val = readl(sv->dw.dbi_base + PHY_DEBUG_R1); + if (!(val & PHY_DEBUG_R1_LINK_UP) || + (val & PHY_DEBUG_R1_LINK_IN_TRAINING)) { + sv_info(sv, "Failed to negotiate PCIe link!\n"); + pcie_sifive_print_phy_debug(sv); + writel(PCIE_PHY_RESET, + sv->priv_base + PCIEX8MGMT_APP_HOLD_PHY_RST); + return -ETIMEDOUT; + } + + return 0; +} + +static int pcie_sifive_start_link(struct pcie_sifive *sv) +{ + if (pcie_sifive_check_link(sv)) + return -EALREADY; + + pcie_sifive_force_gen1(sv); + + /* set ltssm */ + pcie_sifive_priv_set_state(sv, PCIEX8MGMT_APP_LTSSM_ENABLE, + LTSSM_ENABLE_BIT, 1); + return 0; +} + +static int pcie_sifive_init_port(struct udevice *dev, + enum pcie_sifive_devtype mode) +{ + struct pcie_sifive *sv = dev_get_priv(dev); + int ret; + + /* Power on reset */ + pcie_sifive_assert_reset(sv); + pcie_sifive_power_on(sv); + pcie_sifive_deassert_reset(sv); + + /* Enable pcieauxclk */ + ret = clk_enable(&sv->aux_ck); + if (ret) + dev_err(dev, "unable to enable pcie_aux clock\n"); + + /* + * assert hold_phy_rst (hold the controller LTSSM in reset + * after power_up_rst_n for register programming with cr_para) + */ + writel(PCIE_PHY_RESET, sv->priv_base + PCIEX8MGMT_APP_HOLD_PHY_RST); + + /* deassert power_up_rst_n */ + ret = reset_deassert(&sv->reset); + if (ret < 0) { + dev_err(dev, "failed to deassert reset"); + return -EINVAL; + } + + pcie_sifive_init_phy(sv); + + /* disable pcieauxclk */ + clk_disable(&sv->aux_ck); + + /* deassert hold_phy_rst */ + writel(PCIE_PHY_RESET_DEASSERT, + sv->priv_base + PCIEX8MGMT_APP_HOLD_PHY_RST); + + /* enable pcieauxclk */ + clk_enable(&sv->aux_ck); + + /* Set desired mode while core is not operational */ + if (mode == SV_PCIE_HOST_TYPE) + writel(DEVICE_TYPE_RC, + sv->priv_base + PCIEX8MGMT_DEVICE_TYPE); + else + writel(DEVICE_TYPE_EP, + sv->priv_base + PCIEX8MGMT_DEVICE_TYPE); + + /* Confirm desired mode from operational core */ + if (pcie_sifive_get_devtype(sv) != mode) + return -EINVAL; + + pcie_dw_setup_host(&sv->dw); + + if (pcie_sifive_start_link(sv) == -EALREADY) + sv_info(sv, "PCIe link is already up\n"); + else if (pcie_sifive_wait_for_link(sv) == -ETIMEDOUT) + return -ETIMEDOUT; + + return 0; +} + +static int pcie_sifive_probe(struct udevice *dev) +{ + struct pcie_sifive *sv = dev_get_priv(dev); + struct udevice *parent = pci_get_controller(dev); + struct pci_controller *hose = dev_get_uclass_priv(parent); + int err; + + sv->dw.first_busno = dev_seq(dev); + sv->dw.dev = dev; + + err = pcie_sifive_init_port(dev, SV_PCIE_HOST_TYPE); + if (err) { + sv_info(sv, "Failed to init port.\n"); + return err; + } + + printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", + dev_seq(dev), pcie_dw_get_link_speed(&sv->dw), + pcie_dw_get_link_width(&sv->dw), + hose->first_busno); + + return pcie_dw_prog_outbound_atu_unroll(&sv->dw, + PCIE_ATU_REGION_INDEX0, + PCIE_ATU_TYPE_MEM, + sv->dw.mem.phys_start, + sv->dw.mem.bus_start, + sv->dw.mem.size); +} + +static void __iomem *get_fdt_addr(struct udevice *dev, const char *name) +{ + fdt_addr_t addr; + + addr = dev_read_addr_name(dev, name); + + return (addr == FDT_ADDR_T_NONE) ? NULL : (void __iomem *)addr; +} + +static int pcie_sifive_of_to_plat(struct udevice *dev) +{ + struct pcie_sifive *sv = dev_get_priv(dev); + int err; + + /* get designware DBI base addr */ + sv->dw.dbi_base = get_fdt_addr(dev, "dbi"); + if (!sv->dw.dbi_base) + return -EINVAL; + + /* get private control base addr */ + sv->priv_base = get_fdt_addr(dev, "mgmt"); + if (!sv->priv_base) + return -EINVAL; + + gpio_request_by_name(dev, "pwren-gpios", 0, &sv->pwren_gpio, + GPIOD_IS_OUT); + + if (!dm_gpio_is_valid(&sv->pwren_gpio)) { + sv_info(sv, "pwren_gpio is invalid\n"); + return -EINVAL; + } + + gpio_request_by_name(dev, "reset-gpios", 0, &sv->reset_gpio, + GPIOD_IS_OUT); + + if (!dm_gpio_is_valid(&sv->reset_gpio)) { + sv_info(sv, "reset_gpio is invalid\n"); + return -EINVAL; + } + + err = clk_get_by_index(dev, 0, &sv->aux_ck); + if (err) { + sv_info(sv, "clk_get_by_index(aux_ck) failed: %d\n", err); + return err; + } + + err = reset_get_by_index(dev, 0, &sv->reset); + if (err) { + sv_info(sv, "reset_get_by_index(reset) failed: %d\n", err); + return err; + } + + return 0; +} + +static const struct dm_pci_ops pcie_sifive_ops = { + .read_config = pcie_dw_read_config, + .write_config = pcie_dw_write_config, +}; + +static const struct udevice_id pcie_sifive_ids[] = { + { .compatible = "sifive,fu740-pcie" }, + { .compatible = "sifive,fu740-pcie-ecam" }, + {} +}; + +U_BOOT_DRIVER(pcie_sifive) = { + .name = "pcie_sifive", + .id = UCLASS_PCI, + .of_match = pcie_sifive_ids, + .ops = &pcie_sifive_ops, + .of_to_plat = pcie_sifive_of_to_plat, + .probe = pcie_sifive_probe, + .priv_auto = sizeof(struct pcie_sifive), +};
- bool "Enable SiFive FU740 PCIe"
- depends on CLK_SIFIVE_PRCI
- depends on RESET_SIFIVE
- depends on SIFIVE_GPIO
- select PCIE_DW_COMMON
- help
FU740.
- SiFive FU740 DesignWare PCIe Controller
- Copyright (C) 2020-2021 SiFive, Inc.
- Based in early part on the i.MX6 PCIe host controller shim which is:
- Copyright (C) 2013 Kosagi
- Based on driver from author: Alan Mikhak amikhak@wirelessfabric.com
- /* Must be first member of the struct */
- struct pcie_dw dw;
- /* private control regs */
- void __iomem *priv_base;
- /* reset, power, clock resources */
- int sys_int_pin;
- struct gpio_desc pwren_gpio;
- struct gpio_desc reset_gpio;
- struct clk aux_ck;
- struct reset_ctl reset;
- SV_PCIE_UNKNOWN_TYPE = 0,
- SV_PCIE_ENDPOINT_TYPE = 1,
- SV_PCIE_HOST_TYPE = 3
- u32 val;
- val = readl(sv->priv_base + PCIEX8MGMT_DEVICE_TYPE);
- switch (val) {
- case DEVICE_TYPE_RC:
- case DEVICE_TYPE_EP:
- default:
- u32 val;
- val = readl(sv->priv_base + reg);
- val = state ? (val | bits) : (val & !bits);
- writel(val, sv->priv_base + reg);
- dm_gpio_set_value(&sv->reset_gpio, GPIO_LOW);
- writel(PCIE_PERST_ASSERT, sv->priv_base + PCIEX8MGMT_PERST_N);
- mdelay(ASSERTION_DELAY);
- dm_gpio_set_value(&sv->pwren_gpio, GPIO_HIGH);
- writel(PCIE_PERST_DEASSERT, sv->priv_base + PCIEX8MGMT_PERST_N);
- dm_gpio_set_value(&sv->reset_gpio, GPIO_HIGH);
- unsigned char ack = 0;
- if (!(phy == 0 || phy == 1))
return -2;
- /* setup phy para */
- writel(addr, sv->priv_base +
- if (write)
- /* enable access if write */
- if (write)
- else
- /* wait for wait_idle */
- do {
u32 val;
if (val) {
ack = 1;
if (!write)
mdelay(1);
- } while (!ack);
- /* clear */
- if (write)
- else
- while (readl(sv->priv_base +
- int lane;
- /* enable phy cr_para_sel interfaces */
- writel(PCIE_PHY_SEL, sv->priv_base + PCIEX8MGMT_PHY0_CR_PARA_SEL);
- writel(PCIE_PHY_SEL, sv->priv_base + PCIEX8MGMT_PHY1_CR_PARA_SEL);
- mdelay(1);
- /* set PHY AC termination mode */
- for (lane = 0; lane < PCIEX8MGMT_LANE_NUM; lane++) {
PCIEX8MGMT_LANE +
PCIEX8MGMT_LANE +
- u32 val;
- val = readl(sv->dw.dbi_base + PHY_DEBUG_R1);
- return (val & PHY_DEBUG_R1_LINK_UP) &&
- u32 val, linkcap;
- /* ctrl_ro_wr_enable */
- val = readl(sv->dw.dbi_base + PCIE_MISC_CONTROL_1);
- val |= DBI_RO_WR_EN;
- writel(val, sv->dw.dbi_base + PCIE_MISC_CONTROL_1);
- /* configure link cap */
- linkcap = readl(sv->dw.dbi_base + PF0_PCIE_CAP_LINK_CAP);
- linkcap |= PCIE_LINK_CAP_MAX_SPEED_MASK;
- writel(linkcap, sv->dw.dbi_base + PF0_PCIE_CAP_LINK_CAP);
- /* ctrl_ro_wr_disable */
- val &= ~DBI_RO_WR_EN;
- sv_err(sv, "PHY DEBUG_R0=0x%08x DEBUG_R1=0x%08x\n",
- u32 val;
- int timeout;
- /* Wait for the link to train */
- mdelay(20);
- timeout = 20;
- do {
mdelay(1);
- } while (--timeout && !pcie_sifive_check_link(sv));
- if (!(val & PHY_DEBUG_R1_LINK_UP) ||
return -ETIMEDOUT;
- if (pcie_sifive_check_link(sv))
return -EALREADY;
- pcie_sifive_force_gen1(sv);
- /* set ltssm */
- pcie_sifive_priv_set_state(sv, PCIEX8MGMT_APP_LTSSM_ENABLE,
- struct pcie_sifive *sv = dev_get_priv(dev);
- int ret;
- /* Power on reset */
- pcie_sifive_assert_reset(sv);
- pcie_sifive_power_on(sv);
- pcie_sifive_deassert_reset(sv);
- /* Enable pcieauxclk */
- ret = clk_enable(&sv->aux_ck);
- if (ret)
- writel(PCIE_PHY_RESET, sv->priv_base + PCIEX8MGMT_APP_HOLD_PHY_RST);
- /* deassert power_up_rst_n */
- ret = reset_deassert(&sv->reset);
- if (ret < 0) {
return -EINVAL;
- pcie_sifive_init_phy(sv);
- /* disable pcieauxclk */
- clk_disable(&sv->aux_ck);
- /* deassert hold_phy_rst */
- writel(PCIE_PHY_RESET_DEASSERT,
- /* enable pcieauxclk */
- clk_enable(&sv->aux_ck);
- /* Set desired mode while core is not operational */
- if (mode == SV_PCIE_HOST_TYPE)
- else
- /* Confirm desired mode from operational core */
- if (pcie_sifive_get_devtype(sv) != mode)
return -EINVAL;
- pcie_dw_setup_host(&sv->dw);
- if (pcie_sifive_start_link(sv) == -EALREADY)
- else if (pcie_sifive_wait_for_link(sv) == -ETIMEDOUT)
return -ETIMEDOUT;
- struct udevice *parent = pci_get_controller(dev);
- struct pci_controller *hose = dev_get_uclass_priv(parent);
- int err;
- sv->dw.first_busno = dev_seq(dev);
- sv->dw.dev = dev;
- err = pcie_sifive_init_port(dev, SV_PCIE_HOST_TYPE);
- if (err) {
return err;
- printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n",
hose->first_busno);
- return pcie_dw_prog_outbound_atu_unroll(&sv->dw,
PCIE_ATU_TYPE_MEM,
sv->dw.mem.size);
- fdt_addr_t addr;
- addr = dev_read_addr_name(dev, name);
- return (addr == FDT_ADDR_T_NONE) ? NULL : (void __iomem *)addr;
- int err;
- /* get designware DBI base addr */
- sv->dw.dbi_base = get_fdt_addr(dev, "dbi");
- if (!sv->dw.dbi_base)
return -EINVAL;
- /* get private control base addr */
- sv->priv_base = get_fdt_addr(dev, "mgmt");
- if (!sv->priv_base)
return -EINVAL;
- gpio_request_by_name(dev, "pwren-gpios", 0, &sv->pwren_gpio,
GPIOD_IS_OUT);
- if (!dm_gpio_is_valid(&sv->pwren_gpio)) {
return -EINVAL;
- gpio_request_by_name(dev, "reset-gpios", 0, &sv->reset_gpio,
GPIOD_IS_OUT);
- if (!dm_gpio_is_valid(&sv->reset_gpio)) {
return -EINVAL;
- err = clk_get_by_index(dev, 0, &sv->aux_ck);
- if (err) {
return err;
- err = reset_get_by_index(dev, 0, &sv->reset);
- if (err) {
return err;
- .read_config = pcie_dw_read_config,
- .write_config = pcie_dw_write_config,
- { .compatible = "sifive,fu740-pcie" },
- { .compatible = "sifive,fu740-pcie-ecam" },
Are you sure the controller in ECAM mode should use this driver ? The Linux bindings only declare "sifive,fu740-pcie"
- .name = "pcie_sifive",
- .id = UCLASS_PCI,
- .of_match = pcie_sifive_ids,
- .ops = &pcie_sifive_ops,
- .of_to_plat = pcie_sifive_of_to_plat,
- .probe = pcie_sifive_probe,
- .priv_auto = sizeof(struct pcie_sifive),
otherwise,
Reviewed-by: Neil Armstrong narmstrong@baylibre.com
Neil
help
FU740.
struct pcie_dw dw;
int sys_int_pin;
struct clk aux_ck;
u32 val;
switch (val) {
default:
u32 val;
return -2;
if (write)
if (write)
else
do {
u32 val;
if (val) {
ack = 1;
if (!write)
mdelay(1);
} while (!ack);
/* clear */
if (write)
else
int lane;
mdelay(1);
PCIEX8MGMT_LANE +
PCIEX8MGMT_LANE +
u32 val;
u32 val, linkcap;
u32 val;
int timeout;
mdelay(20);
timeout = 20;
do {
mdelay(1);
return -ETIMEDOUT;
return -EALREADY;
/* set ltssm */
int ret;
if (ret)
if (ret < 0) {
return -EINVAL;
else
return -EINVAL;
return -ETIMEDOUT;
int err;
sv->dw.dev = dev;
if (err) {
return err;
hose->first_busno);
PCIE_ATU_TYPE_MEM,
sv->dw.mem.size);
fdt_addr_t addr;
int err;
return -EINVAL;
if (!sv->priv_base)
return -EINVAL;
GPIOD_IS_OUT);
return -EINVAL;
GPIOD_IS_OUT);
return -EINVAL;
if (err) {
return err;
if (err) {
return err;
You are right. I should remove it. Thanks. - Green
.id = UCLASS_PCI,
otherwise,
Neil
Add dts support for fu740. The HiFive Unmatched support is based on fu740 cpu and drivers in following patch set.
Signed-off-by: Green Wan green.wan@sifive.com [greentime.hu: set fu740 speed to 1.2GHz] Signed-off-by: Greentime Hu greentime.hu@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com --- arch/riscv/dts/fu740-c000-u-boot.dtsi | 105 ++++++ arch/riscv/dts/fu740-c000.dtsi | 329 ++++++++++++++++++ include/dt-bindings/clock/sifive-fu740-prci.h | 25 ++ include/dt-bindings/reset/sifive-fu740-prci.h | 19 + 4 files changed, 478 insertions(+) create mode 100644 arch/riscv/dts/fu740-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu740-c000.dtsi create mode 100644 include/dt-bindings/clock/sifive-fu740-prci.h create mode 100644 include/dt-bindings/reset/sifive-fu740-prci.h
diff --git a/arch/riscv/dts/fu740-c000-u-boot.dtsi b/arch/riscv/dts/fu740-c000-u-boot.dtsi new file mode 100644 index 0000000000..a5d0688b06 --- /dev/null +++ b/arch/riscv/dts/fu740-c000-u-boot.dtsi @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2020-2021 SiFive, Inc + */ + +#include <dt-bindings/reset/sifive-fu740-prci.h> + +/ { + cpus { + assigned-clocks = <&prci PRCI_CLK_COREPLL>; + assigned-clock-rates = <1200000000>; + u-boot,dm-spl; + cpu0: cpu@0 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + status = "okay"; + cpu0_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu1: cpu@1 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu1_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu2: cpu@2 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu2_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu3: cpu@3 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu3_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu4: cpu@4 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu4_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + }; + + soc { + u-boot,dm-spl; + clint: clint@2000000 { + compatible = "riscv,clint0"; + interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 + &cpu1_intc 3 &cpu1_intc 7 + &cpu2_intc 3 &cpu2_intc 7 + &cpu3_intc 3 &cpu3_intc 7 + &cpu4_intc 3 &cpu4_intc 7>; + reg = <0x0 0x2000000 0x0 0x10000>; + u-boot,dm-spl; + }; + prci: clock-controller@10000000 { + #reset-cells = <1>; + resets = <&prci PRCI_RST_DDR_CTRL_N>, + <&prci PRCI_RST_DDR_AXI_N>, + <&prci PRCI_RST_DDR_AHB_N>, + <&prci PRCI_RST_DDR_PHY_N>, + <&prci PRCI_RST_GEMGXL_N>, + <&prci PRCI_RST_CLTX_N>; + reset-names = "ddr_ctrl", "ddr_axi", "ddr_ahb", + "ddr_phy", "gemgxl_reset", "cltx_reset"; + }; + dmc: dmc@100b0000 { + compatible = "sifive,fu740-c000-ddr"; + reg = <0x0 0x100b0000 0x0 0x0800 + 0x0 0x100b2000 0x0 0x2000 + 0x0 0x100b8000 0x0 0x1000>; + clocks = <&prci PRCI_CLK_DDRPLL>; + clock-frequency = <933333324>; + u-boot,dm-spl; + }; + }; +}; + +&prci { + u-boot,dm-spl; +}; + +&uart0 { + u-boot,dm-spl; +}; + +&spi0 { + u-boot,dm-spl; +}; + +ð0 { + assigned-clocks = <&prci PRCI_CLK_GEMGXLPLL>; + assigned-clock-rates = <125125000>; +}; + +&ccache { + status = "okay"; +}; diff --git a/arch/riscv/dts/fu740-c000.dtsi b/arch/riscv/dts/fu740-c000.dtsi new file mode 100644 index 0000000000..9e876a4fe3 --- /dev/null +++ b/arch/riscv/dts/fu740-c000.dtsi @@ -0,0 +1,329 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* Copyright (c) 2020-2021 SiFive, Inc */ + +/dts-v1/; + +#include <dt-bindings/clock/sifive-fu740-prci.h> +#include <dt-bindings/reset/sifive-fu740-prci.h> + +/ { + #address-cells = <2>; + #size-cells = <2>; + compatible = "sifive,fu740-c000", "sifive,fu740"; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + ethernet0 = ð0; + }; + + chosen { + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu0: cpu@0 { + compatible = "sifive,bullet0", "riscv"; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <16384>; + next-level-cache = <&ccache>; + reg = <0x0>; + riscv,isa = "rv64imac"; + status = "disabled"; + cpu0_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu1: cpu@1 { + compatible = "sifive,bullet0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + reg = <0x1>; + riscv,isa = "rv64imafdc"; + tlb-split; + cpu1_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu2: cpu@2 { + compatible = "sifive,bullet0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + reg = <0x2>; + riscv,isa = "rv64imafdc"; + tlb-split; + cpu2_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu3: cpu@3 { + compatible = "sifive,bullet0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + reg = <0x3>; + riscv,isa = "rv64imafdc"; + tlb-split; + cpu3_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + cpu4: cpu@4 { + compatible = "sifive,bullet0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + reg = <0x4>; + riscv,isa = "rv64imafdc"; + tlb-split; + cpu4_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + }; + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "sifive,fu740-c000", "sifive,fu740", "simple-bus"; + ranges; + plic0: interrupt-controller@c000000 { + #interrupt-cells = <1>; + compatible = "sifive,plic-1.0.0"; + reg = <0x0 0xc000000 0x0 0x4000000>; + riscv,ndev = <69>; + interrupt-controller; + interrupts-extended = < + &cpu0_intc 0xffffffff + &cpu1_intc 0xffffffff &cpu1_intc 9 + &cpu2_intc 0xffffffff &cpu2_intc 9 + &cpu3_intc 0xffffffff &cpu3_intc 9 + &cpu4_intc 0xffffffff &cpu4_intc 9>; + }; + prci: clock-controller@10000000 { + compatible = "sifive,fu740-c000-prci"; + reg = <0x0 0x10000000 0x0 0x1000>; + clocks = <&hfclk>, <&rtcclk>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + uart0: serial@10010000 { + compatible = "sifive,fu740-c000-uart", "sifive,uart0"; + reg = <0x0 0x10010000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <39>; + clocks = <&prci PRCI_CLK_PCLK>; + status = "disabled"; + }; + uart1: serial@10011000 { + compatible = "sifive,fu740-c000-uart", "sifive,uart0"; + reg = <0x0 0x10011000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <40>; + clocks = <&prci PRCI_CLK_PCLK>; + status = "disabled"; + }; + i2c0: i2c@10030000 { + compatible = "sifive,fu740-c000-i2c", "sifive,i2c0"; + reg = <0x0 0x10030000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <52>; + clocks = <&prci PRCI_CLK_PCLK>; + reg-shift = <2>; + reg-io-width = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + i2c1: i2c@10031000 { + compatible = "sifive,fu740-c000-i2c", "sifive,i2c0"; + reg = <0x0 0x10031000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <53>; + clocks = <&prci PRCI_CLK_PCLK>; + reg-shift = <2>; + reg-io-width = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + qspi0: spi@10040000 { + compatible = "sifive,fu740-c000-spi", "sifive,spi0"; + reg = <0x0 0x10040000 0x0 0x1000 + 0x0 0x20000000 0x0 0x10000000>; + interrupt-parent = <&plic0>; + interrupts = <41>; + clocks = <&prci PRCI_CLK_PCLK>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + qspi1: spi@10041000 { + compatible = "sifive,fu740-c000-spi", "sifive,spi0"; + reg = <0x0 0x10041000 0x0 0x1000 + 0x0 0x30000000 0x0 0x10000000>; + interrupt-parent = <&plic0>; + interrupts = <42>; + clocks = <&prci PRCI_CLK_PCLK>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + spi0: spi@10050000 { + compatible = "sifive,fu740-c000-spi", "sifive,spi0"; + reg = <0x0 0x10050000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <43>; + clocks = <&prci PRCI_CLK_PCLK>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + eth0: ethernet@10090000 { + compatible = "sifive,fu740-c000-gem"; + interrupt-parent = <&plic0>; + interrupts = <55>; + reg = <0x0 0x10090000 0x0 0x2000 + 0x0 0x100a0000 0x0 0x1000>; + local-mac-address = [00 00 00 00 00 00]; + clock-names = "pclk", "hclk"; + clocks = <&prci PRCI_CLK_GEMGXLPLL>, + <&prci PRCI_CLK_GEMGXLPLL>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + pwm0: pwm@10020000 { + compatible = "sifive,fu740-c000-pwm", "sifive,pwm0"; + reg = <0x0 0x10020000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <44 45 46 47>; + clocks = <&prci PRCI_CLK_PCLK>; + #pwm-cells = <3>; + status = "disabled"; + }; + pwm1: pwm@10021000 { + compatible = "sifive,fu740-c000-pwm", "sifive,pwm0"; + reg = <0x0 0x10021000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <48 49 50 51>; + clocks = <&prci PRCI_CLK_PCLK>; + #pwm-cells = <3>; + status = "disabled"; + }; + ccache: cache-controller@2010000 { + compatible = "sifive,fu740-c000-ccache", "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <2048>; + cache-size = <2097152>; + cache-unified; + interrupt-parent = <&plic0>; + interrupts = <19 21 22 20>; + reg = <0x0 0x2010000 0x0 0x1000>; + }; + gpio: gpio@10060000 { + compatible = "sifive,fu740-c000-gpio", "sifive,gpio0"; + interrupt-parent = <&plic0>; + interrupts = <23>, <24>, <25>, <26>, <27>, <28>, <29>, + <30>, <31>, <32>, <33>, <34>, <35>, <36>, + <37>, <38>; + reg = <0x0 0x10060000 0x0 0x1000>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&prci PRCI_CLK_PCLK>; + status = "disabled"; + }; + pcie@e00000000 { + #address-cells = <3>; + #interrupt-cells = <1>; + #num-lanes = <8>; + #size-cells = <2>; + compatible = "sifive,fu740-pcie"; + reg = <0xe 0x00000000 0x1 0x0 + 0xd 0xf0000000 0x0 0x10000000 + 0x0 0x100d0000 0x0 0x1000>; + reg-names = "dbi", "config", "mgmt"; + device_type = "pci"; + dma-coherent; + bus-range = <0x0 0xff>; + ranges = <0x81000000 0x0 0x60080000 0x0 0x60080000 0x0 0x10000 + 0x82000000 0x0 0x60090000 0x0 0x60090000 0x0 0xff70000 + 0x82000000 0x0 0x70000000 0x0 0x70000000 0x0 0x1000000 + 0xc3000000 0x20 0x00000000 0x20 0x00000000 0x20 0x00000000>; + num-lanes = <0x8>; + interrupts = <56 57 58 59 60 61 62 63 64>; + interrupt-names = "msi", "inta", "intb", "intc", "intd"; + interrupt-parent = <&plic0>; + interrupt-map-mask = <0x0 0x0 0x0 0x7>; + interrupt-map = <0x0 0x0 0x0 0x1 &plic0 57>, + <0x0 0x0 0x0 0x2 &plic0 58>, + <0x0 0x0 0x0 0x3 &plic0 59>, + <0x0 0x0 0x0 0x4 &plic0 60>; + pwren-gpios = <&gpio 5 0>; + reset-gpios = <&gpio 8 0>; + clocks = <&prci PRCI_CLK_PCIEAUX>; + clock-names = "pcieaux"; + resets = <&prci PRCI_RST_PCIE_POWER_UP_N>; + reset-names = "rst_n"; + + status = "okay"; + }; + }; +}; diff --git a/include/dt-bindings/clock/sifive-fu740-prci.h b/include/dt-bindings/clock/sifive-fu740-prci.h new file mode 100644 index 0000000000..c1224783c0 --- /dev/null +++ b/include/dt-bindings/clock/sifive-fu740-prci.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ +/* + * Copyright (C) 2020-2021 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + * Zong Li + * Pragnesh Patel + */ + +#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H +#define __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H + +/* Clock indexes for use by Device Tree data and the PRCI driver */ + +#define PRCI_CLK_COREPLL 0 +#define PRCI_CLK_DDRPLL 1 +#define PRCI_CLK_GEMGXLPLL 2 +#define PRCI_CLK_DVFSCOREPLL 3 +#define PRCI_CLK_HFPCLKPLL 4 +#define PRCI_CLK_CLTXPLL 5 +#define PRCI_CLK_TLCLK 6 +#define PRCI_CLK_PCLK 7 +#define PRCI_CLK_PCIEAUX 8 + +#endif diff --git a/include/dt-bindings/reset/sifive-fu740-prci.h b/include/dt-bindings/reset/sifive-fu740-prci.h new file mode 100644 index 0000000000..02210f4105 --- /dev/null +++ b/include/dt-bindings/reset/sifive-fu740-prci.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ +/* + * Copyright (C) 2020-2021 Sifive, Inc. + * Author: Pragnesh Patel pragnesh.patel@sifive.com + */ + +#ifndef __DT_BINDINGS_RESET_SIFIVE_FU740_PRCI_H +#define __DT_BINDINGS_RESET_SIFIVE_FU740_PRCI_H + +/* Reset indexes for use by device tree data and the PRCI driver */ +#define PRCI_RST_DDR_CTRL_N 0 +#define PRCI_RST_DDR_AXI_N 1 +#define PRCI_RST_DDR_AHB_N 2 +#define PRCI_RST_DDR_PHY_N 3 +#define PRCI_RST_PCIE_POWER_UP_N 4 +#define PRCI_RST_GEMGXL_N 5 +#define PRCI_RST_CLTX_N 6 + +#endif
Add dts files for SiFive Unmatched board.
Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Rick Chen rick@andestech.com --- arch/riscv/dts/Makefile | 1 + .../dts/fu740-hifive-unmatched-a00-ddr.dtsi | 1489 +++++++++++++++++ .../dts/hifive-unmatched-a00-u-boot.dtsi | 40 + arch/riscv/dts/hifive-unmatched-a00.dts | 259 +++ 4 files changed, 1789 insertions(+) create mode 100644 arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00.dts
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 8138d89d84..ed32f56c9e 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb +dtb-$(CONFIG_TARGET_SIFIVE_UNMATCHED) += hifive-unmatched-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb
diff --git a/arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi b/arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi new file mode 100644 index 0000000000..fc3dfd1959 --- /dev/null +++ b/arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi @@ -0,0 +1,1489 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2020-2021 SiFive, Inc + */ + +&dmc { + sifive,ddr-params = < + 0x00000a00 /* DENALI_CTL_00_DATA */ + 0x00000000 /* DENALI_CTL_01_DATA */ + 0x00000000 /* DENALI_CTL_02_DATA */ + 0x00000000 /* DENALI_CTL_03_DATA */ + 0x00000000 /* DENALI_CTL_04_DATA */ + 0x00000000 /* DENALI_CTL_05_DATA */ + 0x0000000a /* DENALI_CTL_06_DATA */ + 0x0002d362 /* DENALI_CTL_07_DATA */ + 0x00071073 /* DENALI_CTL_08_DATA */ + 0x0a1c0255 /* DENALI_CTL_09_DATA */ + 0x1c1c0400 /* DENALI_CTL_10_DATA */ + 0x0404c90b /* DENALI_CTL_11_DATA */ + 0x2b050405 /* DENALI_CTL_12_DATA */ + 0x0d0c081e /* DENALI_CTL_13_DATA */ + 0x08090914 /* DENALI_CTL_14_DATA */ + 0x00fde718 /* DENALI_CTL_15_DATA */ + 0x00180a05 /* DENALI_CTL_16_DATA */ + 0x008b130d /* DENALI_CTL_17_DATA */ + 0x01000118 /* DENALI_CTL_18_DATA */ + 0x0d032001 /* DENALI_CTL_19_DATA */ + 0x00000000 /* DENALI_CTL_20_DATA */ + 0x00000101 /* DENALI_CTL_21_DATA */ + 0x00000000 /* DENALI_CTL_22_DATA */ + 0x0a000000 /* DENALI_CTL_23_DATA */ + 0x00000000 /* DENALI_CTL_24_DATA */ + 0x01450100 /* DENALI_CTL_25_DATA */ + 0x00001c36 /* DENALI_CTL_26_DATA */ + 0x00000005 /* DENALI_CTL_27_DATA */ + 0x00170006 /* DENALI_CTL_28_DATA */ + 0x014e0400 /* DENALI_CTL_29_DATA */ + 0x03010000 /* DENALI_CTL_30_DATA */ + 0x000a0e00 /* DENALI_CTL_31_DATA */ + 0x04030200 /* DENALI_CTL_32_DATA */ + 0x0000031f /* DENALI_CTL_33_DATA */ + 0x00070004 /* DENALI_CTL_34_DATA */ + 0x00000000 /* DENALI_CTL_35_DATA */ + 0x00000000 /* DENALI_CTL_36_DATA */ + 0x00000000 /* DENALI_CTL_37_DATA */ + 0x00000000 /* DENALI_CTL_38_DATA */ + 0x00000000 /* DENALI_CTL_39_DATA */ + 0x00000000 /* DENALI_CTL_40_DATA */ + 0x00000000 /* DENALI_CTL_41_DATA */ + 0x00000000 /* DENALI_CTL_42_DATA */ + 0x00000000 /* DENALI_CTL_43_DATA */ + 0x00000000 /* DENALI_CTL_44_DATA */ + 0x00000000 /* DENALI_CTL_45_DATA */ + 0x00000000 /* DENALI_CTL_46_DATA */ + 0x00000000 /* DENALI_CTL_47_DATA */ + 0x00000000 /* DENALI_CTL_48_DATA */ + 0x00000000 /* DENALI_CTL_49_DATA */ + 0x00000000 /* DENALI_CTL_50_DATA */ + 0x00000000 /* DENALI_CTL_51_DATA */ + 0x00000000 /* DENALI_CTL_52_DATA */ + 0x00000000 /* DENALI_CTL_53_DATA */ + 0x00000000 /* DENALI_CTL_54_DATA */ + 0x00000000 /* DENALI_CTL_55_DATA */ + 0x00000000 /* DENALI_CTL_56_DATA */ + 0x00000000 /* DENALI_CTL_57_DATA */ + 0x00000000 /* DENALI_CTL_58_DATA */ + 0x00000000 /* DENALI_CTL_59_DATA */ + 0x00000424 /* DENALI_CTL_60_DATA */ + 0x00000201 /* DENALI_CTL_61_DATA */ + 0x00001008 /* DENALI_CTL_62_DATA */ + 0x00000000 /* DENALI_CTL_63_DATA */ + 0x00000200 /* DENALI_CTL_64_DATA */ + 0x00000800 /* DENALI_CTL_65_DATA */ + 0x00000481 /* DENALI_CTL_66_DATA */ + 0x00000400 /* DENALI_CTL_67_DATA */ + 0x00000424 /* DENALI_CTL_68_DATA */ + 0x00000201 /* DENALI_CTL_69_DATA */ + 0x00001008 /* DENALI_CTL_70_DATA */ + 0x00000000 /* DENALI_CTL_71_DATA */ + 0x00000200 /* DENALI_CTL_72_DATA */ + 0x00000800 /* DENALI_CTL_73_DATA */ + 0x00000481 /* DENALI_CTL_74_DATA */ + 0x00000400 /* DENALI_CTL_75_DATA */ + 0x01010000 /* DENALI_CTL_76_DATA */ + 0x00000000 /* DENALI_CTL_77_DATA */ + 0x00000000 /* DENALI_CTL_78_DATA */ + 0x00000000 /* DENALI_CTL_79_DATA */ + 0x00000000 /* DENALI_CTL_80_DATA */ + 0x00000000 /* DENALI_CTL_81_DATA */ + 0x00000000 /* DENALI_CTL_82_DATA */ + 0x00000000 /* DENALI_CTL_83_DATA */ + 0x00000000 /* DENALI_CTL_84_DATA */ + 0x00000000 /* DENALI_CTL_85_DATA */ + 0x00000000 /* DENALI_CTL_86_DATA */ + 0x00000000 /* DENALI_CTL_87_DATA */ + 0x00000000 /* DENALI_CTL_88_DATA */ + 0x00000000 /* DENALI_CTL_89_DATA */ + 0x00000000 /* DENALI_CTL_90_DATA */ + 0x00000000 /* DENALI_CTL_91_DATA */ + 0x00000000 /* DENALI_CTL_92_DATA */ + 0x00000000 /* DENALI_CTL_93_DATA */ + 0x00000000 /* DENALI_CTL_94_DATA */ + 0x00000000 /* DENALI_CTL_95_DATA */ + 0x00000000 /* DENALI_CTL_96_DATA */ + 0x00000000 /* DENALI_CTL_97_DATA */ + 0x00000000 /* DENALI_CTL_98_DATA */ + 0x00000000 /* DENALI_CTL_99_DATA */ + 0x00000000 /* DENALI_CTL_100_DATA */ + 0x00000000 /* DENALI_CTL_101_DATA */ + 0x00000000 /* DENALI_CTL_102_DATA */ + 0x00000000 /* DENALI_CTL_103_DATA */ + 0x00000000 /* DENALI_CTL_104_DATA */ + 0x00000003 /* DENALI_CTL_105_DATA */ + 0x00000000 /* DENALI_CTL_106_DATA */ + 0x00000000 /* DENALI_CTL_107_DATA */ + 0x00000000 /* DENALI_CTL_108_DATA */ + 0x00000000 /* DENALI_CTL_109_DATA */ + 0x01000000 /* DENALI_CTL_110_DATA */ + 0x00040000 /* DENALI_CTL_111_DATA */ + 0x00800200 /* DENALI_CTL_112_DATA */ + 0x00000200 /* DENALI_CTL_113_DATA */ + 0x00000040 /* DENALI_CTL_114_DATA */ + 0x01000100 /* DENALI_CTL_115_DATA */ + 0x0a000002 /* DENALI_CTL_116_DATA */ + 0x0101ffff /* DENALI_CTL_117_DATA */ + 0x01010101 /* DENALI_CTL_118_DATA */ + 0x01010101 /* DENALI_CTL_119_DATA */ + 0x0000010b /* DENALI_CTL_120_DATA */ + 0x00000c03 /* DENALI_CTL_121_DATA */ + 0x00000000 /* DENALI_CTL_122_DATA */ + 0x00000000 /* DENALI_CTL_123_DATA */ + 0x00000000 /* DENALI_CTL_124_DATA */ + 0x00000000 /* DENALI_CTL_125_DATA */ + 0x00030300 /* DENALI_CTL_126_DATA */ + 0x00000000 /* DENALI_CTL_127_DATA */ + 0x00010101 /* DENALI_CTL_128_DATA */ + 0x00000000 /* DENALI_CTL_129_DATA */ + 0x00000000 /* DENALI_CTL_130_DATA */ + 0x00000000 /* DENALI_CTL_131_DATA */ + 0x00000000 /* DENALI_CTL_132_DATA */ + 0x00000000 /* DENALI_CTL_133_DATA */ + 0x00000000 /* DENALI_CTL_134_DATA */ + 0x00000000 /* DENALI_CTL_135_DATA */ + 0x00000000 /* DENALI_CTL_136_DATA */ + 0x00000000 /* DENALI_CTL_137_DATA */ + 0x00000000 /* DENALI_CTL_138_DATA */ + 0x00000000 /* DENALI_CTL_139_DATA */ + 0x00000000 /* DENALI_CTL_140_DATA */ + 0x00000000 /* DENALI_CTL_141_DATA */ + 0x00000000 /* DENALI_CTL_142_DATA */ + 0x00000000 /* DENALI_CTL_143_DATA */ + 0x00000000 /* DENALI_CTL_144_DATA */ + 0x00000000 /* DENALI_CTL_145_DATA */ + 0x00000000 /* DENALI_CTL_146_DATA */ + 0x00000000 /* DENALI_CTL_147_DATA */ + 0x00000000 /* DENALI_CTL_148_DATA */ + 0x00000000 /* DENALI_CTL_149_DATA */ + 0x00000000 /* DENALI_CTL_150_DATA */ + 0x00000000 /* DENALI_CTL_151_DATA */ + 0x00000000 /* DENALI_CTL_152_DATA */ + 0x00000000 /* DENALI_CTL_153_DATA */ + 0x00000000 /* DENALI_CTL_154_DATA */ + 0x00000000 /* DENALI_CTL_155_DATA */ + 0x00000000 /* DENALI_CTL_156_DATA */ + 0x00000000 /* DENALI_CTL_157_DATA */ + 0x00000000 /* DENALI_CTL_158_DATA */ + 0x00000000 /* DENALI_CTL_159_DATA */ + 0x00000000 /* DENALI_CTL_160_DATA */ + 0x02010102 /* DENALI_CTL_161_DATA */ + 0x0108070d /* DENALI_CTL_162_DATA */ + 0x05050300 /* DENALI_CTL_163_DATA */ + 0x04000503 /* DENALI_CTL_164_DATA */ + 0x00000000 /* DENALI_CTL_165_DATA */ + 0x00000000 /* DENALI_CTL_166_DATA */ + 0x00000000 /* DENALI_CTL_167_DATA */ + 0x00000000 /* DENALI_CTL_168_DATA */ + 0x280d0000 /* DENALI_CTL_169_DATA */ + 0x01000000 /* DENALI_CTL_170_DATA */ + 0x00000000 /* DENALI_CTL_171_DATA */ + 0x00030001 /* DENALI_CTL_172_DATA */ + 0x00000000 /* DENALI_CTL_173_DATA */ + 0x00000000 /* DENALI_CTL_174_DATA */ + 0x00000000 /* DENALI_CTL_175_DATA */ + 0x00000000 /* DENALI_CTL_176_DATA */ + 0x00000000 /* DENALI_CTL_177_DATA */ + 0x00000000 /* DENALI_CTL_178_DATA */ + 0x00000000 /* DENALI_CTL_179_DATA */ + 0x00000000 /* DENALI_CTL_180_DATA */ + 0x01000000 /* DENALI_CTL_181_DATA */ + 0x00000001 /* DENALI_CTL_182_DATA */ + 0x00000100 /* DENALI_CTL_183_DATA */ + 0x00010303 /* DENALI_CTL_184_DATA */ + 0x67676701 /* DENALI_CTL_185_DATA */ + 0x67676767 /* DENALI_CTL_186_DATA */ + 0x67676767 /* DENALI_CTL_187_DATA */ + 0x67676767 /* DENALI_CTL_188_DATA */ + 0x67676767 /* DENALI_CTL_189_DATA */ + 0x67676767 /* DENALI_CTL_190_DATA */ + 0x67676767 /* DENALI_CTL_191_DATA */ + 0x67676767 /* DENALI_CTL_192_DATA */ + 0x67676767 /* DENALI_CTL_193_DATA */ + 0x01000067 /* DENALI_CTL_194_DATA */ + 0x00000001 /* DENALI_CTL_195_DATA */ + 0x00000101 /* DENALI_CTL_196_DATA */ + 0x00000000 /* DENALI_CTL_197_DATA */ + 0x00000000 /* DENALI_CTL_198_DATA */ + 0x00000000 /* DENALI_CTL_199_DATA */ + 0x00000000 /* DENALI_CTL_200_DATA */ + 0x00000000 /* DENALI_CTL_201_DATA */ + 0x00000000 /* DENALI_CTL_202_DATA */ + 0x00000000 /* DENALI_CTL_203_DATA */ + 0x00000000 /* DENALI_CTL_204_DATA */ + 0x00000000 /* DENALI_CTL_205_DATA */ + 0x00000000 /* DENALI_CTL_206_DATA */ + 0x00000000 /* DENALI_CTL_207_DATA */ + 0x00000001 /* DENALI_CTL_208_DATA */ + 0x00000000 /* DENALI_CTL_209_DATA */ + 0x007fffff /* DENALI_CTL_210_DATA */ + 0x00000000 /* DENALI_CTL_211_DATA */ + 0x007fffff /* DENALI_CTL_212_DATA */ + 0x00000000 /* DENALI_CTL_213_DATA */ + 0x007fffff /* DENALI_CTL_214_DATA */ + 0x00000000 /* DENALI_CTL_215_DATA */ + 0x007fffff /* DENALI_CTL_216_DATA */ + 0x00000000 /* DENALI_CTL_217_DATA */ + 0x007fffff /* DENALI_CTL_218_DATA */ + 0x00000000 /* DENALI_CTL_219_DATA */ + 0x007fffff /* DENALI_CTL_220_DATA */ + 0x00000000 /* DENALI_CTL_221_DATA */ + 0x007fffff /* DENALI_CTL_222_DATA */ + 0x00000000 /* DENALI_CTL_223_DATA */ + 0x037fffff /* DENALI_CTL_224_DATA */ + 0xffffffff /* DENALI_CTL_225_DATA */ + 0x000f000f /* DENALI_CTL_226_DATA */ + 0x00ffff03 /* DENALI_CTL_227_DATA */ + 0x000fffff /* DENALI_CTL_228_DATA */ + 0x0003000f /* DENALI_CTL_229_DATA */ + 0xffffffff /* DENALI_CTL_230_DATA */ + 0x000f000f /* DENALI_CTL_231_DATA */ + 0x00ffff03 /* DENALI_CTL_232_DATA */ + 0x000fffff /* DENALI_CTL_233_DATA */ + 0x0003000f /* DENALI_CTL_234_DATA */ + 0xffffffff /* DENALI_CTL_235_DATA */ + 0x000f000f /* DENALI_CTL_236_DATA */ + 0x00ffff03 /* DENALI_CTL_237_DATA */ + 0x000fffff /* DENALI_CTL_238_DATA */ + 0x0003000f /* DENALI_CTL_239_DATA */ + 0xffffffff /* DENALI_CTL_240_DATA */ + 0x000f000f /* DENALI_CTL_241_DATA */ + 0x00ffff03 /* DENALI_CTL_242_DATA */ + 0x000fffff /* DENALI_CTL_243_DATA */ + 0x6407000f /* DENALI_CTL_244_DATA */ + 0x01640001 /* DENALI_CTL_245_DATA */ + 0x00000000 /* DENALI_CTL_246_DATA */ + 0x00000000 /* DENALI_CTL_247_DATA */ + 0x00001800 /* DENALI_CTL_248_DATA */ + 0x00386c05 /* DENALI_CTL_249_DATA */ + 0x02000200 /* DENALI_CTL_250_DATA */ + 0x02000200 /* DENALI_CTL_251_DATA */ + 0x0000386c /* DENALI_CTL_252_DATA */ + 0x00023438 /* DENALI_CTL_253_DATA */ + 0x02020d0f /* DENALI_CTL_254_DATA */ + 0x00140303 /* DENALI_CTL_255_DATA */ + 0x00000000 /* DENALI_CTL_256_DATA */ + 0x00000000 /* DENALI_CTL_257_DATA */ + 0x00001403 /* DENALI_CTL_258_DATA */ + 0x00000000 /* DENALI_CTL_259_DATA */ + 0x00000000 /* DENALI_CTL_260_DATA */ + 0x00000000 /* DENALI_CTL_261_DATA */ + 0x00000000 /* DENALI_CTL_262_DATA */ + 0x0c010000 /* DENALI_CTL_263_DATA */ + 0x00000008 /* DENALI_CTL_264_DATA */ + 0x01375642 /* DENALI_PHY_00_DATA */ + 0x0004c008 /* DENALI_PHY_01_DATA */ + 0x000000da /* DENALI_PHY_02_DATA */ + 0x00000000 /* DENALI_PHY_03_DATA */ + 0x00000000 /* DENALI_PHY_04_DATA */ + 0x00010000 /* DENALI_PHY_05_DATA */ + 0x01DDDD90 /* DENALI_PHY_06_DATA */ + 0x01DDDD90 /* DENALI_PHY_07_DATA */ + 0x01030001 /* DENALI_PHY_08_DATA */ + 0x01000000 /* DENALI_PHY_09_DATA */ + 0x00c00000 /* DENALI_PHY_10_DATA */ + 0x00000007 /* DENALI_PHY_11_DATA */ + 0x00000000 /* DENALI_PHY_12_DATA */ + 0x00000000 /* DENALI_PHY_13_DATA */ + 0x04000408 /* DENALI_PHY_14_DATA */ + 0x00000408 /* DENALI_PHY_15_DATA */ + 0x00e4e400 /* DENALI_PHY_16_DATA */ + 0x00000000 /* DENALI_PHY_17_DATA */ + 0x00000000 /* DENALI_PHY_18_DATA */ + 0x00000000 /* DENALI_PHY_19_DATA */ + 0x00000000 /* DENALI_PHY_20_DATA */ + 0x00000000 /* DENALI_PHY_21_DATA */ + 0x00000000 /* DENALI_PHY_22_DATA */ + 0x00000000 /* DENALI_PHY_23_DATA */ + 0x00000000 /* DENALI_PHY_24_DATA */ + 0x00000000 /* DENALI_PHY_25_DATA */ + 0x00000000 /* DENALI_PHY_26_DATA */ + 0x00000000 /* DENALI_PHY_27_DATA */ + 0x00000000 /* DENALI_PHY_28_DATA */ + 0x00000000 /* DENALI_PHY_29_DATA */ + 0x00000000 /* DENALI_PHY_30_DATA */ + 0x00000000 /* DENALI_PHY_31_DATA */ + 0x00000000 /* DENALI_PHY_32_DATA */ + 0x00200000 /* DENALI_PHY_33_DATA */ + 0x00000000 /* DENALI_PHY_34_DATA */ + 0x00000000 /* DENALI_PHY_35_DATA */ + 0x00000000 /* DENALI_PHY_36_DATA */ + 0x00000000 /* DENALI_PHY_37_DATA */ + 0x00000000 /* DENALI_PHY_38_DATA */ + 0x00000000 /* DENALI_PHY_39_DATA */ + 0x02800280 /* DENALI_PHY_40_DATA */ + 0x02800280 /* DENALI_PHY_41_DATA */ + 0x02800280 /* DENALI_PHY_42_DATA */ + 0x02800280 /* DENALI_PHY_43_DATA */ + 0x00000280 /* DENALI_PHY_44_DATA */ + 0x00000000 /* DENALI_PHY_45_DATA */ + 0x00000000 /* DENALI_PHY_46_DATA */ + 0x00000000 /* DENALI_PHY_47_DATA */ + 0x00000000 /* DENALI_PHY_48_DATA */ + 0x00000000 /* DENALI_PHY_49_DATA */ + 0x00800080 /* DENALI_PHY_50_DATA */ + 0x00800080 /* DENALI_PHY_51_DATA */ + 0x00800080 /* DENALI_PHY_52_DATA */ + 0x00800080 /* DENALI_PHY_53_DATA */ + 0x00800080 /* DENALI_PHY_54_DATA */ + 0x00800080 /* DENALI_PHY_55_DATA */ + 0x00800080 /* DENALI_PHY_56_DATA */ + 0x00800080 /* DENALI_PHY_57_DATA */ + 0x00800080 /* DENALI_PHY_58_DATA */ + 0x000100da /* DENALI_PHY_59_DATA */ + 0x01ff0010 /* DENALI_PHY_60_DATA */ + 0x00000000 /* DENALI_PHY_61_DATA */ + 0x00000000 /* DENALI_PHY_62_DATA */ + 0x00000002 /* DENALI_PHY_63_DATA */ + 0x51313152 /* DENALI_PHY_64_DATA */ + 0x80013130 /* DENALI_PHY_65_DATA */ + 0x02000080 /* DENALI_PHY_66_DATA */ + 0x00100001 /* DENALI_PHY_67_DATA */ + 0x0c064208 /* DENALI_PHY_68_DATA */ + 0x000f0c0f /* DENALI_PHY_69_DATA */ + 0x01000140 /* DENALI_PHY_70_DATA */ + 0x0000000c /* DENALI_PHY_71_DATA */ + 0x00000000 /* DENALI_PHY_72_DATA */ + 0x00000000 /* DENALI_PHY_73_DATA */ + 0x00000000 /* DENALI_PHY_74_DATA */ + 0x00000000 /* DENALI_PHY_75_DATA */ + 0x00000000 /* DENALI_PHY_76_DATA */ + 0x00000000 /* DENALI_PHY_77_DATA */ + 0x00000000 /* DENALI_PHY_78_DATA */ + 0x00000000 /* DENALI_PHY_79_DATA */ + 0x00000000 /* DENALI_PHY_80_DATA */ + 0x00000000 /* DENALI_PHY_81_DATA */ + 0x00000000 /* DENALI_PHY_82_DATA */ + 0x00000000 /* DENALI_PHY_83_DATA */ + 0x00000000 /* DENALI_PHY_84_DATA */ + 0x00000000 /* DENALI_PHY_85_DATA */ + 0x00000000 /* DENALI_PHY_86_DATA */ + 0x00000000 /* DENALI_PHY_87_DATA */ + 0x00000000 /* DENALI_PHY_88_DATA */ + 0x00000000 /* DENALI_PHY_89_DATA */ + 0x00000000 /* DENALI_PHY_90_DATA */ + 0x00000000 /* DENALI_PHY_91_DATA */ + 0x00000000 /* DENALI_PHY_92_DATA */ + 0x00000000 /* DENALI_PHY_93_DATA */ + 0x00000000 /* DENALI_PHY_94_DATA */ + 0x00000000 /* DENALI_PHY_95_DATA */ + 0x00000000 /* DENALI_PHY_96_DATA */ + 0x00000000 /* DENALI_PHY_97_DATA */ + 0x00000000 /* DENALI_PHY_98_DATA */ + 0x00000000 /* DENALI_PHY_99_DATA */ + 0x00000000 /* DENALI_PHY_100_DATA */ + 0x00000000 /* DENALI_PHY_101_DATA */ + 0x00000000 /* DENALI_PHY_102_DATA */ + 0x00000000 /* DENALI_PHY_103_DATA */ + 0x00000000 /* DENALI_PHY_104_DATA */ + 0x00000000 /* DENALI_PHY_105_DATA */ + 0x00000000 /* DENALI_PHY_106_DATA */ + 0x00000000 /* DENALI_PHY_107_DATA */ + 0x00000000 /* DENALI_PHY_108_DATA */ + 0x00000000 /* DENALI_PHY_109_DATA */ + 0x00000000 /* DENALI_PHY_110_DATA */ + 0x00000000 /* DENALI_PHY_111_DATA */ + 0x00000000 /* DENALI_PHY_112_DATA */ + 0x00000000 /* DENALI_PHY_113_DATA */ + 0x00000000 /* DENALI_PHY_114_DATA */ + 0x00000000 /* DENALI_PHY_115_DATA */ + 0x00000000 /* DENALI_PHY_116_DATA */ + 0x00000000 /* DENALI_PHY_117_DATA */ + 0x00000000 /* DENALI_PHY_118_DATA */ + 0x00000000 /* DENALI_PHY_119_DATA */ + 0x00000000 /* DENALI_PHY_120_DATA */ + 0x00000000 /* DENALI_PHY_121_DATA */ + 0x00000000 /* DENALI_PHY_122_DATA */ + 0x00000000 /* DENALI_PHY_123_DATA */ + 0x00000000 /* DENALI_PHY_124_DATA */ + 0x00000000 /* DENALI_PHY_125_DATA */ + 0x00000000 /* DENALI_PHY_126_DATA */ + 0x00000000 /* DENALI_PHY_127_DATA */ + 0x40263571 /* DENALI_PHY_128_DATA */ + 0x0004c008 /* DENALI_PHY_129_DATA */ + 0x000000da /* DENALI_PHY_130_DATA */ + 0x00000000 /* DENALI_PHY_131_DATA */ + 0x00000000 /* DENALI_PHY_132_DATA */ + 0x00010000 /* DENALI_PHY_133_DATA */ + 0x01DDDD90 /* DENALI_PHY_134_DATA */ + 0x01DDDD90 /* DENALI_PHY_135_DATA */ + 0x01030001 /* DENALI_PHY_136_DATA */ + 0x01000000 /* DENALI_PHY_137_DATA */ + 0x00c00000 /* DENALI_PHY_138_DATA */ + 0x00000007 /* DENALI_PHY_139_DATA */ + 0x00000000 /* DENALI_PHY_140_DATA */ + 0x00000000 /* DENALI_PHY_141_DATA */ + 0x04000408 /* DENALI_PHY_142_DATA */ + 0x00000408 /* DENALI_PHY_143_DATA */ + 0x00e4e400 /* DENALI_PHY_144_DATA */ + 0x00000000 /* DENALI_PHY_145_DATA */ + 0x00000000 /* DENALI_PHY_146_DATA */ + 0x00000000 /* DENALI_PHY_147_DATA */ + 0x00000000 /* DENALI_PHY_148_DATA */ + 0x00000000 /* DENALI_PHY_149_DATA */ + 0x00000000 /* DENALI_PHY_150_DATA */ + 0x00000000 /* DENALI_PHY_151_DATA */ + 0x00000000 /* DENALI_PHY_152_DATA */ + 0x00000000 /* DENALI_PHY_153_DATA */ + 0x00000000 /* DENALI_PHY_154_DATA */ + 0x00000000 /* DENALI_PHY_155_DATA */ + 0x00000000 /* DENALI_PHY_156_DATA */ + 0x00000000 /* DENALI_PHY_157_DATA */ + 0x00000000 /* DENALI_PHY_158_DATA */ + 0x00000000 /* DENALI_PHY_159_DATA */ + 0x00000000 /* DENALI_PHY_160_DATA */ + 0x00200000 /* DENALI_PHY_161_DATA */ + 0x00000000 /* DENALI_PHY_162_DATA */ + 0x00000000 /* DENALI_PHY_163_DATA */ + 0x00000000 /* DENALI_PHY_164_DATA */ + 0x00000000 /* DENALI_PHY_165_DATA */ + 0x00000000 /* DENALI_PHY_166_DATA */ + 0x00000000 /* DENALI_PHY_167_DATA */ + 0x02800280 /* DENALI_PHY_168_DATA */ + 0x02800280 /* DENALI_PHY_169_DATA */ + 0x02800280 /* DENALI_PHY_170_DATA */ + 0x02800280 /* DENALI_PHY_171_DATA */ + 0x00000280 /* DENALI_PHY_172_DATA */ + 0x00000000 /* DENALI_PHY_173_DATA */ + 0x00000000 /* DENALI_PHY_174_DATA */ + 0x00000000 /* DENALI_PHY_175_DATA */ + 0x00000000 /* DENALI_PHY_176_DATA */ + 0x00000000 /* DENALI_PHY_177_DATA */ + 0x00800080 /* DENALI_PHY_178_DATA */ + 0x00800080 /* DENALI_PHY_179_DATA */ + 0x00800080 /* DENALI_PHY_180_DATA */ + 0x00800080 /* DENALI_PHY_181_DATA */ + 0x00800080 /* DENALI_PHY_182_DATA */ + 0x00800080 /* DENALI_PHY_183_DATA */ + 0x00800080 /* DENALI_PHY_184_DATA */ + 0x00800080 /* DENALI_PHY_185_DATA */ + 0x00800080 /* DENALI_PHY_186_DATA */ + 0x000100da /* DENALI_PHY_187_DATA */ + 0x01ff0010 /* DENALI_PHY_188_DATA */ + 0x00000000 /* DENALI_PHY_189_DATA */ + 0x00000000 /* DENALI_PHY_190_DATA */ + 0x00000002 /* DENALI_PHY_191_DATA */ + 0x51313152 /* DENALI_PHY_192_DATA */ + 0x80013130 /* DENALI_PHY_193_DATA */ + 0x02000080 /* DENALI_PHY_194_DATA */ + 0x00100001 /* DENALI_PHY_195_DATA */ + 0x0c064208 /* DENALI_PHY_196_DATA */ + 0x000f0c0f /* DENALI_PHY_197_DATA */ + 0x01000140 /* DENALI_PHY_198_DATA */ + 0x0000000c /* DENALI_PHY_199_DATA */ + 0x00000000 /* DENALI_PHY_200_DATA */ + 0x00000000 /* DENALI_PHY_201_DATA */ + 0x00000000 /* DENALI_PHY_202_DATA */ + 0x00000000 /* DENALI_PHY_203_DATA */ + 0x00000000 /* DENALI_PHY_204_DATA */ + 0x00000000 /* DENALI_PHY_205_DATA */ + 0x00000000 /* DENALI_PHY_206_DATA */ + 0x00000000 /* DENALI_PHY_207_DATA */ + 0x00000000 /* DENALI_PHY_208_DATA */ + 0x00000000 /* DENALI_PHY_209_DATA */ + 0x00000000 /* DENALI_PHY_210_DATA */ + 0x00000000 /* DENALI_PHY_211_DATA */ + 0x00000000 /* DENALI_PHY_212_DATA */ + 0x00000000 /* DENALI_PHY_213_DATA */ + 0x00000000 /* DENALI_PHY_214_DATA */ + 0x00000000 /* DENALI_PHY_215_DATA */ + 0x00000000 /* DENALI_PHY_216_DATA */ + 0x00000000 /* DENALI_PHY_217_DATA */ + 0x00000000 /* DENALI_PHY_218_DATA */ + 0x00000000 /* DENALI_PHY_219_DATA */ + 0x00000000 /* DENALI_PHY_220_DATA */ + 0x00000000 /* DENALI_PHY_221_DATA */ + 0x00000000 /* DENALI_PHY_222_DATA */ + 0x00000000 /* DENALI_PHY_223_DATA */ + 0x00000000 /* DENALI_PHY_224_DATA */ + 0x00000000 /* DENALI_PHY_225_DATA */ + 0x00000000 /* DENALI_PHY_226_DATA */ + 0x00000000 /* DENALI_PHY_227_DATA */ + 0x00000000 /* DENALI_PHY_228_DATA */ + 0x00000000 /* DENALI_PHY_229_DATA */ + 0x00000000 /* DENALI_PHY_230_DATA */ + 0x00000000 /* DENALI_PHY_231_DATA */ + 0x00000000 /* DENALI_PHY_232_DATA */ + 0x00000000 /* DENALI_PHY_233_DATA */ + 0x00000000 /* DENALI_PHY_234_DATA */ + 0x00000000 /* DENALI_PHY_235_DATA */ + 0x00000000 /* DENALI_PHY_236_DATA */ + 0x00000000 /* DENALI_PHY_237_DATA */ + 0x00000000 /* DENALI_PHY_238_DATA */ + 0x00000000 /* DENALI_PHY_239_DATA */ + 0x00000000 /* DENALI_PHY_240_DATA */ + 0x00000000 /* DENALI_PHY_241_DATA */ + 0x00000000 /* DENALI_PHY_242_DATA */ + 0x00000000 /* DENALI_PHY_243_DATA */ + 0x00000000 /* DENALI_PHY_244_DATA */ + 0x00000000 /* DENALI_PHY_245_DATA */ + 0x00000000 /* DENALI_PHY_246_DATA */ + 0x00000000 /* DENALI_PHY_247_DATA */ + 0x00000000 /* DENALI_PHY_248_DATA */ + 0x00000000 /* DENALI_PHY_249_DATA */ + 0x00000000 /* DENALI_PHY_250_DATA */ + 0x00000000 /* DENALI_PHY_251_DATA */ + 0x00000000 /* DENALI_PHY_252_DATA */ + 0x00000000 /* DENALI_PHY_253_DATA */ + 0x00000000 /* DENALI_PHY_254_DATA */ + 0x00000000 /* DENALI_PHY_255_DATA */ + 0x46052371 /* DENALI_PHY_256_DATA */ + 0x0004c008 /* DENALI_PHY_257_DATA */ + 0x000000da /* DENALI_PHY_258_DATA */ + 0x00000000 /* DENALI_PHY_259_DATA */ + 0x00000000 /* DENALI_PHY_260_DATA */ + 0x00010000 /* DENALI_PHY_261_DATA */ + 0x01DDDD90 /* DENALI_PHY_262_DATA */ + 0x01DDDD90 /* DENALI_PHY_263_DATA */ + 0x01030001 /* DENALI_PHY_264_DATA */ + 0x01000000 /* DENALI_PHY_265_DATA */ + 0x00c00000 /* DENALI_PHY_266_DATA */ + 0x00000007 /* DENALI_PHY_267_DATA */ + 0x00000000 /* DENALI_PHY_268_DATA */ + 0x00000000 /* DENALI_PHY_269_DATA */ + 0x04000408 /* DENALI_PHY_270_DATA */ + 0x00000408 /* DENALI_PHY_271_DATA */ + 0x00e4e400 /* DENALI_PHY_272_DATA */ + 0x00000000 /* DENALI_PHY_273_DATA */ + 0x00000000 /* DENALI_PHY_274_DATA */ + 0x00000000 /* DENALI_PHY_275_DATA */ + 0x00000000 /* DENALI_PHY_276_DATA */ + 0x00000000 /* DENALI_PHY_277_DATA */ + 0x00000000 /* DENALI_PHY_278_DATA */ + 0x00000000 /* DENALI_PHY_279_DATA */ + 0x00000000 /* DENALI_PHY_280_DATA */ + 0x00000000 /* DENALI_PHY_281_DATA */ + 0x00000000 /* DENALI_PHY_282_DATA */ + 0x00000000 /* DENALI_PHY_283_DATA */ + 0x00000000 /* DENALI_PHY_284_DATA */ + 0x00000000 /* DENALI_PHY_285_DATA */ + 0x00000000 /* DENALI_PHY_286_DATA */ + 0x00000000 /* DENALI_PHY_287_DATA */ + 0x00000000 /* DENALI_PHY_288_DATA */ + 0x00200000 /* DENALI_PHY_289_DATA */ + 0x00000000 /* DENALI_PHY_290_DATA */ + 0x00000000 /* DENALI_PHY_291_DATA */ + 0x00000000 /* DENALI_PHY_292_DATA */ + 0x00000000 /* DENALI_PHY_293_DATA */ + 0x00000000 /* DENALI_PHY_294_DATA */ + 0x00000000 /* DENALI_PHY_295_DATA */ + 0x02800280 /* DENALI_PHY_296_DATA */ + 0x02800280 /* DENALI_PHY_297_DATA */ + 0x02800280 /* DENALI_PHY_298_DATA */ + 0x02800280 /* DENALI_PHY_299_DATA */ + 0x00000280 /* DENALI_PHY_300_DATA */ + 0x00000000 /* DENALI_PHY_301_DATA */ + 0x00000000 /* DENALI_PHY_302_DATA */ + 0x00000000 /* DENALI_PHY_303_DATA */ + 0x00000000 /* DENALI_PHY_304_DATA */ + 0x00000000 /* DENALI_PHY_305_DATA */ + 0x00800080 /* DENALI_PHY_306_DATA */ + 0x00800080 /* DENALI_PHY_307_DATA */ + 0x00800080 /* DENALI_PHY_308_DATA */ + 0x00800080 /* DENALI_PHY_309_DATA */ + 0x00800080 /* DENALI_PHY_310_DATA */ + 0x00800080 /* DENALI_PHY_311_DATA */ + 0x00800080 /* DENALI_PHY_312_DATA */ + 0x00800080 /* DENALI_PHY_313_DATA */ + 0x00800080 /* DENALI_PHY_314_DATA */ + 0x000100da /* DENALI_PHY_315_DATA */ + 0x01ff0010 /* DENALI_PHY_316_DATA */ + 0x00000000 /* DENALI_PHY_317_DATA */ + 0x00000000 /* DENALI_PHY_318_DATA */ + 0x00000002 /* DENALI_PHY_319_DATA */ + 0x51313152 /* DENALI_PHY_320_DATA */ + 0x80013130 /* DENALI_PHY_321_DATA */ + 0x02000080 /* DENALI_PHY_322_DATA */ + 0x00100001 /* DENALI_PHY_323_DATA */ + 0x0c064208 /* DENALI_PHY_324_DATA */ + 0x000f0c0f /* DENALI_PHY_325_DATA */ + 0x01000140 /* DENALI_PHY_326_DATA */ + 0x0000000c /* DENALI_PHY_327_DATA */ + 0x00000000 /* DENALI_PHY_328_DATA */ + 0x00000000 /* DENALI_PHY_329_DATA */ + 0x00000000 /* DENALI_PHY_330_DATA */ + 0x00000000 /* DENALI_PHY_331_DATA */ + 0x00000000 /* DENALI_PHY_332_DATA */ + 0x00000000 /* DENALI_PHY_333_DATA */ + 0x00000000 /* DENALI_PHY_334_DATA */ + 0x00000000 /* DENALI_PHY_335_DATA */ + 0x00000000 /* DENALI_PHY_336_DATA */ + 0x00000000 /* DENALI_PHY_337_DATA */ + 0x00000000 /* DENALI_PHY_338_DATA */ + 0x00000000 /* DENALI_PHY_339_DATA */ + 0x00000000 /* DENALI_PHY_340_DATA */ + 0x00000000 /* DENALI_PHY_341_DATA */ + 0x00000000 /* DENALI_PHY_342_DATA */ + 0x00000000 /* DENALI_PHY_343_DATA */ + 0x00000000 /* DENALI_PHY_344_DATA */ + 0x00000000 /* DENALI_PHY_345_DATA */ + 0x00000000 /* DENALI_PHY_346_DATA */ + 0x00000000 /* DENALI_PHY_347_DATA */ + 0x00000000 /* DENALI_PHY_348_DATA */ + 0x00000000 /* DENALI_PHY_349_DATA */ + 0x00000000 /* DENALI_PHY_350_DATA */ + 0x00000000 /* DENALI_PHY_351_DATA */ + 0x00000000 /* DENALI_PHY_352_DATA */ + 0x00000000 /* DENALI_PHY_353_DATA */ + 0x00000000 /* DENALI_PHY_354_DATA */ + 0x00000000 /* DENALI_PHY_355_DATA */ + 0x00000000 /* DENALI_PHY_356_DATA */ + 0x00000000 /* DENALI_PHY_357_DATA */ + 0x00000000 /* DENALI_PHY_358_DATA */ + 0x00000000 /* DENALI_PHY_359_DATA */ + 0x00000000 /* DENALI_PHY_360_DATA */ + 0x00000000 /* DENALI_PHY_361_DATA */ + 0x00000000 /* DENALI_PHY_362_DATA */ + 0x00000000 /* DENALI_PHY_363_DATA */ + 0x00000000 /* DENALI_PHY_364_DATA */ + 0x00000000 /* DENALI_PHY_365_DATA */ + 0x00000000 /* DENALI_PHY_366_DATA */ + 0x00000000 /* DENALI_PHY_367_DATA */ + 0x00000000 /* DENALI_PHY_368_DATA */ + 0x00000000 /* DENALI_PHY_369_DATA */ + 0x00000000 /* DENALI_PHY_370_DATA */ + 0x00000000 /* DENALI_PHY_371_DATA */ + 0x00000000 /* DENALI_PHY_372_DATA */ + 0x00000000 /* DENALI_PHY_373_DATA */ + 0x00000000 /* DENALI_PHY_374_DATA */ + 0x00000000 /* DENALI_PHY_375_DATA */ + 0x00000000 /* DENALI_PHY_376_DATA */ + 0x00000000 /* DENALI_PHY_377_DATA */ + 0x00000000 /* DENALI_PHY_378_DATA */ + 0x00000000 /* DENALI_PHY_379_DATA */ + 0x00000000 /* DENALI_PHY_380_DATA */ + 0x00000000 /* DENALI_PHY_381_DATA */ + 0x00000000 /* DENALI_PHY_382_DATA */ + 0x00000000 /* DENALI_PHY_383_DATA */ + 0x37651240 /* DENALI_PHY_384_DATA */ + 0x0004c008 /* DENALI_PHY_385_DATA */ + 0x000000da /* DENALI_PHY_386_DATA */ + 0x00000000 /* DENALI_PHY_387_DATA */ + 0x00000000 /* DENALI_PHY_388_DATA */ + 0x00010000 /* DENALI_PHY_389_DATA */ + 0x01DDDD90 /* DENALI_PHY_390_DATA */ + 0x01DDDD90 /* DENALI_PHY_391_DATA */ + 0x01030001 /* DENALI_PHY_392_DATA */ + 0x01000000 /* DENALI_PHY_393_DATA */ + 0x00c00000 /* DENALI_PHY_394_DATA */ + 0x00000007 /* DENALI_PHY_395_DATA */ + 0x00000000 /* DENALI_PHY_396_DATA */ + 0x00000000 /* DENALI_PHY_397_DATA */ + 0x04000408 /* DENALI_PHY_398_DATA */ + 0x00000408 /* DENALI_PHY_399_DATA */ + 0x00e4e400 /* DENALI_PHY_400_DATA */ + 0x00000000 /* DENALI_PHY_401_DATA */ + 0x00000000 /* DENALI_PHY_402_DATA */ + 0x00000000 /* DENALI_PHY_403_DATA */ + 0x00000000 /* DENALI_PHY_404_DATA */ + 0x00000000 /* DENALI_PHY_405_DATA */ + 0x00000000 /* DENALI_PHY_406_DATA */ + 0x00000000 /* DENALI_PHY_407_DATA */ + 0x00000000 /* DENALI_PHY_408_DATA */ + 0x00000000 /* DENALI_PHY_409_DATA */ + 0x00000000 /* DENALI_PHY_410_DATA */ + 0x00000000 /* DENALI_PHY_411_DATA */ + 0x00000000 /* DENALI_PHY_412_DATA */ + 0x00000000 /* DENALI_PHY_413_DATA */ + 0x00000000 /* DENALI_PHY_414_DATA */ + 0x00000000 /* DENALI_PHY_415_DATA */ + 0x00000000 /* DENALI_PHY_416_DATA */ + 0x00200000 /* DENALI_PHY_417_DATA */ + 0x00000000 /* DENALI_PHY_418_DATA */ + 0x00000000 /* DENALI_PHY_419_DATA */ + 0x00000000 /* DENALI_PHY_420_DATA */ + 0x00000000 /* DENALI_PHY_421_DATA */ + 0x00000000 /* DENALI_PHY_422_DATA */ + 0x00000000 /* DENALI_PHY_423_DATA */ + 0x02800280 /* DENALI_PHY_424_DATA */ + 0x02800280 /* DENALI_PHY_425_DATA */ + 0x02800280 /* DENALI_PHY_426_DATA */ + 0x02800280 /* DENALI_PHY_427_DATA */ + 0x00000280 /* DENALI_PHY_428_DATA */ + 0x00000000 /* DENALI_PHY_429_DATA */ + 0x00000000 /* DENALI_PHY_430_DATA */ + 0x00000000 /* DENALI_PHY_431_DATA */ + 0x00000000 /* DENALI_PHY_432_DATA */ + 0x00000000 /* DENALI_PHY_433_DATA */ + 0x00800080 /* DENALI_PHY_434_DATA */ + 0x00800080 /* DENALI_PHY_435_DATA */ + 0x00800080 /* DENALI_PHY_436_DATA */ + 0x00800080 /* DENALI_PHY_437_DATA */ + 0x00800080 /* DENALI_PHY_438_DATA */ + 0x00800080 /* DENALI_PHY_439_DATA */ + 0x00800080 /* DENALI_PHY_440_DATA */ + 0x00800080 /* DENALI_PHY_441_DATA */ + 0x00800080 /* DENALI_PHY_442_DATA */ + 0x000100da /* DENALI_PHY_443_DATA */ + 0x01ff0010 /* DENALI_PHY_444_DATA */ + 0x00000000 /* DENALI_PHY_445_DATA */ + 0x00000000 /* DENALI_PHY_446_DATA */ + 0x00000002 /* DENALI_PHY_447_DATA */ + 0x51313152 /* DENALI_PHY_448_DATA */ + 0x80013130 /* DENALI_PHY_449_DATA */ + 0x02000080 /* DENALI_PHY_450_DATA */ + 0x00100001 /* DENALI_PHY_451_DATA */ + 0x0c064208 /* DENALI_PHY_452_DATA */ + 0x000f0c0f /* DENALI_PHY_453_DATA */ + 0x01000140 /* DENALI_PHY_454_DATA */ + 0x0000000c /* DENALI_PHY_455_DATA */ + 0x00000000 /* DENALI_PHY_456_DATA */ + 0x00000000 /* DENALI_PHY_457_DATA */ + 0x00000000 /* DENALI_PHY_458_DATA */ + 0x00000000 /* DENALI_PHY_459_DATA */ + 0x00000000 /* DENALI_PHY_460_DATA */ + 0x00000000 /* DENALI_PHY_461_DATA */ + 0x00000000 /* DENALI_PHY_462_DATA */ + 0x00000000 /* DENALI_PHY_463_DATA */ + 0x00000000 /* DENALI_PHY_464_DATA */ + 0x00000000 /* DENALI_PHY_465_DATA */ + 0x00000000 /* DENALI_PHY_466_DATA */ + 0x00000000 /* DENALI_PHY_467_DATA */ + 0x00000000 /* DENALI_PHY_468_DATA */ + 0x00000000 /* DENALI_PHY_469_DATA */ + 0x00000000 /* DENALI_PHY_470_DATA */ + 0x00000000 /* DENALI_PHY_471_DATA */ + 0x00000000 /* DENALI_PHY_472_DATA */ + 0x00000000 /* DENALI_PHY_473_DATA */ + 0x00000000 /* DENALI_PHY_474_DATA */ + 0x00000000 /* DENALI_PHY_475_DATA */ + 0x00000000 /* DENALI_PHY_476_DATA */ + 0x00000000 /* DENALI_PHY_477_DATA */ + 0x00000000 /* DENALI_PHY_478_DATA */ + 0x00000000 /* DENALI_PHY_479_DATA */ + 0x00000000 /* DENALI_PHY_480_DATA */ + 0x00000000 /* DENALI_PHY_481_DATA */ + 0x00000000 /* DENALI_PHY_482_DATA */ + 0x00000000 /* DENALI_PHY_483_DATA */ + 0x00000000 /* DENALI_PHY_484_DATA */ + 0x00000000 /* DENALI_PHY_485_DATA */ + 0x00000000 /* DENALI_PHY_486_DATA */ + 0x00000000 /* DENALI_PHY_487_DATA */ + 0x00000000 /* DENALI_PHY_488_DATA */ + 0x00000000 /* DENALI_PHY_489_DATA */ + 0x00000000 /* DENALI_PHY_490_DATA */ + 0x00000000 /* DENALI_PHY_491_DATA */ + 0x00000000 /* DENALI_PHY_492_DATA */ + 0x00000000 /* DENALI_PHY_493_DATA */ + 0x00000000 /* DENALI_PHY_494_DATA */ + 0x00000000 /* DENALI_PHY_495_DATA */ + 0x00000000 /* DENALI_PHY_496_DATA */ + 0x00000000 /* DENALI_PHY_497_DATA */ + 0x00000000 /* DENALI_PHY_498_DATA */ + 0x00000000 /* DENALI_PHY_499_DATA */ + 0x00000000 /* DENALI_PHY_500_DATA */ + 0x00000000 /* DENALI_PHY_501_DATA */ + 0x00000000 /* DENALI_PHY_502_DATA */ + 0x00000000 /* DENALI_PHY_503_DATA */ + 0x00000000 /* DENALI_PHY_504_DATA */ + 0x00000000 /* DENALI_PHY_505_DATA */ + 0x00000000 /* DENALI_PHY_506_DATA */ + 0x00000000 /* DENALI_PHY_507_DATA */ + 0x00000000 /* DENALI_PHY_508_DATA */ + 0x00000000 /* DENALI_PHY_509_DATA */ + 0x00000000 /* DENALI_PHY_510_DATA */ + 0x00000000 /* DENALI_PHY_511_DATA */ + 0x34216750 /* DENALI_PHY_512_DATA */ + 0x0004c008 /* DENALI_PHY_513_DATA */ + 0x000000da /* DENALI_PHY_514_DATA */ + 0x00000000 /* DENALI_PHY_515_DATA */ + 0x00000000 /* DENALI_PHY_516_DATA */ + 0x00010000 /* DENALI_PHY_517_DATA */ + 0x01DDDD90 /* DENALI_PHY_518_DATA */ + 0x01DDDD90 /* DENALI_PHY_519_DATA */ + 0x01030001 /* DENALI_PHY_520_DATA */ + 0x01000000 /* DENALI_PHY_521_DATA */ + 0x00c00000 /* DENALI_PHY_522_DATA */ + 0x00000007 /* DENALI_PHY_523_DATA */ + 0x00000000 /* DENALI_PHY_524_DATA */ + 0x00000000 /* DENALI_PHY_525_DATA */ + 0x04000408 /* DENALI_PHY_526_DATA */ + 0x00000408 /* DENALI_PHY_527_DATA */ + 0x00e4e400 /* DENALI_PHY_528_DATA */ + 0x00000000 /* DENALI_PHY_529_DATA */ + 0x00000000 /* DENALI_PHY_530_DATA */ + 0x00000000 /* DENALI_PHY_531_DATA */ + 0x00000000 /* DENALI_PHY_532_DATA */ + 0x00000000 /* DENALI_PHY_533_DATA */ + 0x00000000 /* DENALI_PHY_534_DATA */ + 0x00000000 /* DENALI_PHY_535_DATA */ + 0x00000000 /* DENALI_PHY_536_DATA */ + 0x00000000 /* DENALI_PHY_537_DATA */ + 0x00000000 /* DENALI_PHY_538_DATA */ + 0x00000000 /* DENALI_PHY_539_DATA */ + 0x00000000 /* DENALI_PHY_540_DATA */ + 0x00000000 /* DENALI_PHY_541_DATA */ + 0x00000000 /* DENALI_PHY_542_DATA */ + 0x00000000 /* DENALI_PHY_543_DATA */ + 0x00000000 /* DENALI_PHY_544_DATA */ + 0x00200000 /* DENALI_PHY_545_DATA */ + 0x00000000 /* DENALI_PHY_546_DATA */ + 0x00000000 /* DENALI_PHY_547_DATA */ + 0x00000000 /* DENALI_PHY_548_DATA */ + 0x00000000 /* DENALI_PHY_549_DATA */ + 0x00000000 /* DENALI_PHY_550_DATA */ + 0x00000000 /* DENALI_PHY_551_DATA */ + 0x02800280 /* DENALI_PHY_552_DATA */ + 0x02800280 /* DENALI_PHY_553_DATA */ + 0x02800280 /* DENALI_PHY_554_DATA */ + 0x02800280 /* DENALI_PHY_555_DATA */ + 0x00000280 /* DENALI_PHY_556_DATA */ + 0x00000000 /* DENALI_PHY_557_DATA */ + 0x00000000 /* DENALI_PHY_558_DATA */ + 0x00000000 /* DENALI_PHY_559_DATA */ + 0x00000000 /* DENALI_PHY_560_DATA */ + 0x00000000 /* DENALI_PHY_561_DATA */ + 0x00800080 /* DENALI_PHY_562_DATA */ + 0x00800080 /* DENALI_PHY_563_DATA */ + 0x00800080 /* DENALI_PHY_564_DATA */ + 0x00800080 /* DENALI_PHY_565_DATA */ + 0x00800080 /* DENALI_PHY_566_DATA */ + 0x00800080 /* DENALI_PHY_567_DATA */ + 0x00800080 /* DENALI_PHY_568_DATA */ + 0x00800080 /* DENALI_PHY_569_DATA */ + 0x00800080 /* DENALI_PHY_570_DATA */ + 0x000100da /* DENALI_PHY_571_DATA */ + 0x01ff0010 /* DENALI_PHY_572_DATA */ + 0x00000000 /* DENALI_PHY_573_DATA */ + 0x00000000 /* DENALI_PHY_574_DATA */ + 0x00000002 /* DENALI_PHY_575_DATA */ + 0x51313152 /* DENALI_PHY_576_DATA */ + 0x80013130 /* DENALI_PHY_577_DATA */ + 0x02000080 /* DENALI_PHY_578_DATA */ + 0x00100001 /* DENALI_PHY_579_DATA */ + 0x0c064208 /* DENALI_PHY_580_DATA */ + 0x000f0c0f /* DENALI_PHY_581_DATA */ + 0x01000140 /* DENALI_PHY_582_DATA */ + 0x0000000c /* DENALI_PHY_583_DATA */ + 0x00000000 /* DENALI_PHY_584_DATA */ + 0x00000000 /* DENALI_PHY_585_DATA */ + 0x00000000 /* DENALI_PHY_586_DATA */ + 0x00000000 /* DENALI_PHY_587_DATA */ + 0x00000000 /* DENALI_PHY_588_DATA */ + 0x00000000 /* DENALI_PHY_589_DATA */ + 0x00000000 /* DENALI_PHY_590_DATA */ + 0x00000000 /* DENALI_PHY_591_DATA */ + 0x00000000 /* DENALI_PHY_592_DATA */ + 0x00000000 /* DENALI_PHY_593_DATA */ + 0x00000000 /* DENALI_PHY_594_DATA */ + 0x00000000 /* DENALI_PHY_595_DATA */ + 0x00000000 /* DENALI_PHY_596_DATA */ + 0x00000000 /* DENALI_PHY_597_DATA */ + 0x00000000 /* DENALI_PHY_598_DATA */ + 0x00000000 /* DENALI_PHY_599_DATA */ + 0x00000000 /* DENALI_PHY_600_DATA */ + 0x00000000 /* DENALI_PHY_601_DATA */ + 0x00000000 /* DENALI_PHY_602_DATA */ + 0x00000000 /* DENALI_PHY_603_DATA */ + 0x00000000 /* DENALI_PHY_604_DATA */ + 0x00000000 /* DENALI_PHY_605_DATA */ + 0x00000000 /* DENALI_PHY_606_DATA */ + 0x00000000 /* DENALI_PHY_607_DATA */ + 0x00000000 /* DENALI_PHY_608_DATA */ + 0x00000000 /* DENALI_PHY_609_DATA */ + 0x00000000 /* DENALI_PHY_610_DATA */ + 0x00000000 /* DENALI_PHY_611_DATA */ + 0x00000000 /* DENALI_PHY_612_DATA */ + 0x00000000 /* DENALI_PHY_613_DATA */ + 0x00000000 /* DENALI_PHY_614_DATA */ + 0x00000000 /* DENALI_PHY_615_DATA */ + 0x00000000 /* DENALI_PHY_616_DATA */ + 0x00000000 /* DENALI_PHY_617_DATA */ + 0x00000000 /* DENALI_PHY_618_DATA */ + 0x00000000 /* DENALI_PHY_619_DATA */ + 0x00000000 /* DENALI_PHY_620_DATA */ + 0x00000000 /* DENALI_PHY_621_DATA */ + 0x00000000 /* DENALI_PHY_622_DATA */ + 0x00000000 /* DENALI_PHY_623_DATA */ + 0x00000000 /* DENALI_PHY_624_DATA */ + 0x00000000 /* DENALI_PHY_625_DATA */ + 0x00000000 /* DENALI_PHY_626_DATA */ + 0x00000000 /* DENALI_PHY_627_DATA */ + 0x00000000 /* DENALI_PHY_628_DATA */ + 0x00000000 /* DENALI_PHY_629_DATA */ + 0x00000000 /* DENALI_PHY_630_DATA */ + 0x00000000 /* DENALI_PHY_631_DATA */ + 0x00000000 /* DENALI_PHY_632_DATA */ + 0x00000000 /* DENALI_PHY_633_DATA */ + 0x00000000 /* DENALI_PHY_634_DATA */ + 0x00000000 /* DENALI_PHY_635_DATA */ + 0x00000000 /* DENALI_PHY_636_DATA */ + 0x00000000 /* DENALI_PHY_637_DATA */ + 0x00000000 /* DENALI_PHY_638_DATA */ + 0x00000000 /* DENALI_PHY_639_DATA */ + 0x35176402 /* DENALI_PHY_640_DATA */ + 0x0004c008 /* DENALI_PHY_641_DATA */ + 0x000000da /* DENALI_PHY_642_DATA */ + 0x00000000 /* DENALI_PHY_643_DATA */ + 0x00000000 /* DENALI_PHY_644_DATA */ + 0x00010000 /* DENALI_PHY_645_DATA */ + 0x01DDDD90 /* DENALI_PHY_646_DATA */ + 0x01DDDD90 /* DENALI_PHY_647_DATA */ + 0x01030001 /* DENALI_PHY_648_DATA */ + 0x01000000 /* DENALI_PHY_649_DATA */ + 0x00c00000 /* DENALI_PHY_650_DATA */ + 0x00000007 /* DENALI_PHY_651_DATA */ + 0x00000000 /* DENALI_PHY_652_DATA */ + 0x00000000 /* DENALI_PHY_653_DATA */ + 0x04000408 /* DENALI_PHY_654_DATA */ + 0x00000408 /* DENALI_PHY_655_DATA */ + 0x00e4e400 /* DENALI_PHY_656_DATA */ + 0x00000000 /* DENALI_PHY_657_DATA */ + 0x00000000 /* DENALI_PHY_658_DATA */ + 0x00000000 /* DENALI_PHY_659_DATA */ + 0x00000000 /* DENALI_PHY_660_DATA */ + 0x00000000 /* DENALI_PHY_661_DATA */ + 0x00000000 /* DENALI_PHY_662_DATA */ + 0x00000000 /* DENALI_PHY_663_DATA */ + 0x00000000 /* DENALI_PHY_664_DATA */ + 0x00000000 /* DENALI_PHY_665_DATA */ + 0x00000000 /* DENALI_PHY_666_DATA */ + 0x00000000 /* DENALI_PHY_667_DATA */ + 0x00000000 /* DENALI_PHY_668_DATA */ + 0x00000000 /* DENALI_PHY_669_DATA */ + 0x00000000 /* DENALI_PHY_670_DATA */ + 0x00000000 /* DENALI_PHY_671_DATA */ + 0x00000000 /* DENALI_PHY_672_DATA */ + 0x00200000 /* DENALI_PHY_673_DATA */ + 0x00000000 /* DENALI_PHY_674_DATA */ + 0x00000000 /* DENALI_PHY_675_DATA */ + 0x00000000 /* DENALI_PHY_676_DATA */ + 0x00000000 /* DENALI_PHY_677_DATA */ + 0x00000000 /* DENALI_PHY_678_DATA */ + 0x00000000 /* DENALI_PHY_679_DATA */ + 0x02800280 /* DENALI_PHY_680_DATA */ + 0x02800280 /* DENALI_PHY_681_DATA */ + 0x02800280 /* DENALI_PHY_682_DATA */ + 0x02800280 /* DENALI_PHY_683_DATA */ + 0x00000280 /* DENALI_PHY_684_DATA */ + 0x00000000 /* DENALI_PHY_685_DATA */ + 0x00000000 /* DENALI_PHY_686_DATA */ + 0x00000000 /* DENALI_PHY_687_DATA */ + 0x00000000 /* DENALI_PHY_688_DATA */ + 0x00000000 /* DENALI_PHY_689_DATA */ + 0x00800080 /* DENALI_PHY_690_DATA */ + 0x00800080 /* DENALI_PHY_691_DATA */ + 0x00800080 /* DENALI_PHY_692_DATA */ + 0x00800080 /* DENALI_PHY_693_DATA */ + 0x00800080 /* DENALI_PHY_694_DATA */ + 0x00800080 /* DENALI_PHY_695_DATA */ + 0x00800080 /* DENALI_PHY_696_DATA */ + 0x00800080 /* DENALI_PHY_697_DATA */ + 0x00800080 /* DENALI_PHY_698_DATA */ + 0x000100da /* DENALI_PHY_699_DATA */ + 0x01ff0010 /* DENALI_PHY_700_DATA */ + 0x00000000 /* DENALI_PHY_701_DATA */ + 0x00000000 /* DENALI_PHY_702_DATA */ + 0x00000002 /* DENALI_PHY_703_DATA */ + 0x51313152 /* DENALI_PHY_704_DATA */ + 0x80013130 /* DENALI_PHY_705_DATA */ + 0x02000080 /* DENALI_PHY_706_DATA */ + 0x00100001 /* DENALI_PHY_707_DATA */ + 0x0c064208 /* DENALI_PHY_708_DATA */ + 0x000f0c0f /* DENALI_PHY_709_DATA */ + 0x01000140 /* DENALI_PHY_710_DATA */ + 0x0000000c /* DENALI_PHY_711_DATA */ + 0x00000000 /* DENALI_PHY_712_DATA */ + 0x00000000 /* DENALI_PHY_713_DATA */ + 0x00000000 /* DENALI_PHY_714_DATA */ + 0x00000000 /* DENALI_PHY_715_DATA */ + 0x00000000 /* DENALI_PHY_716_DATA */ + 0x00000000 /* DENALI_PHY_717_DATA */ + 0x00000000 /* DENALI_PHY_718_DATA */ + 0x00000000 /* DENALI_PHY_719_DATA */ + 0x00000000 /* DENALI_PHY_720_DATA */ + 0x00000000 /* DENALI_PHY_721_DATA */ + 0x00000000 /* DENALI_PHY_722_DATA */ + 0x00000000 /* DENALI_PHY_723_DATA */ + 0x00000000 /* DENALI_PHY_724_DATA */ + 0x00000000 /* DENALI_PHY_725_DATA */ + 0x00000000 /* DENALI_PHY_726_DATA */ + 0x00000000 /* DENALI_PHY_727_DATA */ + 0x00000000 /* DENALI_PHY_728_DATA */ + 0x00000000 /* DENALI_PHY_729_DATA */ + 0x00000000 /* DENALI_PHY_730_DATA */ + 0x00000000 /* DENALI_PHY_731_DATA */ + 0x00000000 /* DENALI_PHY_732_DATA */ + 0x00000000 /* DENALI_PHY_733_DATA */ + 0x00000000 /* DENALI_PHY_734_DATA */ + 0x00000000 /* DENALI_PHY_735_DATA */ + 0x00000000 /* DENALI_PHY_736_DATA */ + 0x00000000 /* DENALI_PHY_737_DATA */ + 0x00000000 /* DENALI_PHY_738_DATA */ + 0x00000000 /* DENALI_PHY_739_DATA */ + 0x00000000 /* DENALI_PHY_740_DATA */ + 0x00000000 /* DENALI_PHY_741_DATA */ + 0x00000000 /* DENALI_PHY_742_DATA */ + 0x00000000 /* DENALI_PHY_743_DATA */ + 0x00000000 /* DENALI_PHY_744_DATA */ + 0x00000000 /* DENALI_PHY_745_DATA */ + 0x00000000 /* DENALI_PHY_746_DATA */ + 0x00000000 /* DENALI_PHY_747_DATA */ + 0x00000000 /* DENALI_PHY_748_DATA */ + 0x00000000 /* DENALI_PHY_749_DATA */ + 0x00000000 /* DENALI_PHY_750_DATA */ + 0x00000000 /* DENALI_PHY_751_DATA */ + 0x00000000 /* DENALI_PHY_752_DATA */ + 0x00000000 /* DENALI_PHY_753_DATA */ + 0x00000000 /* DENALI_PHY_754_DATA */ + 0x00000000 /* DENALI_PHY_755_DATA */ + 0x00000000 /* DENALI_PHY_756_DATA */ + 0x00000000 /* DENALI_PHY_757_DATA */ + 0x00000000 /* DENALI_PHY_758_DATA */ + 0x00000000 /* DENALI_PHY_759_DATA */ + 0x00000000 /* DENALI_PHY_760_DATA */ + 0x00000000 /* DENALI_PHY_761_DATA */ + 0x00000000 /* DENALI_PHY_762_DATA */ + 0x00000000 /* DENALI_PHY_763_DATA */ + 0x00000000 /* DENALI_PHY_764_DATA */ + 0x00000000 /* DENALI_PHY_765_DATA */ + 0x00000000 /* DENALI_PHY_766_DATA */ + 0x00000000 /* DENALI_PHY_767_DATA */ + 0x10526347 /* DENALI_PHY_768_DATA */ + 0x0004c008 /* DENALI_PHY_769_DATA */ + 0x000000da /* DENALI_PHY_770_DATA */ + 0x00000000 /* DENALI_PHY_771_DATA */ + 0x00000000 /* DENALI_PHY_772_DATA */ + 0x00010000 /* DENALI_PHY_773_DATA */ + 0x01DDDD90 /* DENALI_PHY_774_DATA */ + 0x01DDDD90 /* DENALI_PHY_775_DATA */ + 0x01030001 /* DENALI_PHY_776_DATA */ + 0x01000000 /* DENALI_PHY_777_DATA */ + 0x00c00000 /* DENALI_PHY_778_DATA */ + 0x00000007 /* DENALI_PHY_779_DATA */ + 0x00000000 /* DENALI_PHY_780_DATA */ + 0x00000000 /* DENALI_PHY_781_DATA */ + 0x04000408 /* DENALI_PHY_782_DATA */ + 0x00000408 /* DENALI_PHY_783_DATA */ + 0x00e4e400 /* DENALI_PHY_784_DATA */ + 0x00000000 /* DENALI_PHY_785_DATA */ + 0x00000000 /* DENALI_PHY_786_DATA */ + 0x00000000 /* DENALI_PHY_787_DATA */ + 0x00000000 /* DENALI_PHY_788_DATA */ + 0x00000000 /* DENALI_PHY_789_DATA */ + 0x00000000 /* DENALI_PHY_790_DATA */ + 0x00000000 /* DENALI_PHY_791_DATA */ + 0x00000000 /* DENALI_PHY_792_DATA */ + 0x00000000 /* DENALI_PHY_793_DATA */ + 0x00000000 /* DENALI_PHY_794_DATA */ + 0x00000000 /* DENALI_PHY_795_DATA */ + 0x00000000 /* DENALI_PHY_796_DATA */ + 0x00000000 /* DENALI_PHY_797_DATA */ + 0x00000000 /* DENALI_PHY_798_DATA */ + 0x00000000 /* DENALI_PHY_799_DATA */ + 0x00000000 /* DENALI_PHY_800_DATA */ + 0x00200000 /* DENALI_PHY_801_DATA */ + 0x00000000 /* DENALI_PHY_802_DATA */ + 0x00000000 /* DENALI_PHY_803_DATA */ + 0x00000000 /* DENALI_PHY_804_DATA */ + 0x00000000 /* DENALI_PHY_805_DATA */ + 0x00000000 /* DENALI_PHY_806_DATA */ + 0x00000000 /* DENALI_PHY_807_DATA */ + 0x02800280 /* DENALI_PHY_808_DATA */ + 0x02800280 /* DENALI_PHY_809_DATA */ + 0x02800280 /* DENALI_PHY_810_DATA */ + 0x02800280 /* DENALI_PHY_811_DATA */ + 0x00000280 /* DENALI_PHY_812_DATA */ + 0x00000000 /* DENALI_PHY_813_DATA */ + 0x00000000 /* DENALI_PHY_814_DATA */ + 0x00000000 /* DENALI_PHY_815_DATA */ + 0x00000000 /* DENALI_PHY_816_DATA */ + 0x00000000 /* DENALI_PHY_817_DATA */ + 0x00800080 /* DENALI_PHY_818_DATA */ + 0x00800080 /* DENALI_PHY_819_DATA */ + 0x00800080 /* DENALI_PHY_820_DATA */ + 0x00800080 /* DENALI_PHY_821_DATA */ + 0x00800080 /* DENALI_PHY_822_DATA */ + 0x00800080 /* DENALI_PHY_823_DATA */ + 0x00800080 /* DENALI_PHY_824_DATA */ + 0x00800080 /* DENALI_PHY_825_DATA */ + 0x00800080 /* DENALI_PHY_826_DATA */ + 0x000100da /* DENALI_PHY_827_DATA */ + 0x01ff0010 /* DENALI_PHY_828_DATA */ + 0x00000000 /* DENALI_PHY_829_DATA */ + 0x00000000 /* DENALI_PHY_830_DATA */ + 0x00000002 /* DENALI_PHY_831_DATA */ + 0x51313152 /* DENALI_PHY_832_DATA */ + 0x80013130 /* DENALI_PHY_833_DATA */ + 0x02000080 /* DENALI_PHY_834_DATA */ + 0x00100001 /* DENALI_PHY_835_DATA */ + 0x0c064208 /* DENALI_PHY_836_DATA */ + 0x000f0c0f /* DENALI_PHY_837_DATA */ + 0x01000140 /* DENALI_PHY_838_DATA */ + 0x0000000c /* DENALI_PHY_839_DATA */ + 0x00000000 /* DENALI_PHY_840_DATA */ + 0x00000000 /* DENALI_PHY_841_DATA */ + 0x00000000 /* DENALI_PHY_842_DATA */ + 0x00000000 /* DENALI_PHY_843_DATA */ + 0x00000000 /* DENALI_PHY_844_DATA */ + 0x00000000 /* DENALI_PHY_845_DATA */ + 0x00000000 /* DENALI_PHY_846_DATA */ + 0x00000000 /* DENALI_PHY_847_DATA */ + 0x00000000 /* DENALI_PHY_848_DATA */ + 0x00000000 /* DENALI_PHY_849_DATA */ + 0x00000000 /* DENALI_PHY_850_DATA */ + 0x00000000 /* DENALI_PHY_851_DATA */ + 0x00000000 /* DENALI_PHY_852_DATA */ + 0x00000000 /* DENALI_PHY_853_DATA */ + 0x00000000 /* DENALI_PHY_854_DATA */ + 0x00000000 /* DENALI_PHY_855_DATA */ + 0x00000000 /* DENALI_PHY_856_DATA */ + 0x00000000 /* DENALI_PHY_857_DATA */ + 0x00000000 /* DENALI_PHY_858_DATA */ + 0x00000000 /* DENALI_PHY_859_DATA */ + 0x00000000 /* DENALI_PHY_860_DATA */ + 0x00000000 /* DENALI_PHY_861_DATA */ + 0x00000000 /* DENALI_PHY_862_DATA */ + 0x00000000 /* DENALI_PHY_863_DATA */ + 0x00000000 /* DENALI_PHY_864_DATA */ + 0x00000000 /* DENALI_PHY_865_DATA */ + 0x00000000 /* DENALI_PHY_866_DATA */ + 0x00000000 /* DENALI_PHY_867_DATA */ + 0x00000000 /* DENALI_PHY_868_DATA */ + 0x00000000 /* DENALI_PHY_869_DATA */ + 0x00000000 /* DENALI_PHY_870_DATA */ + 0x00000000 /* DENALI_PHY_871_DATA */ + 0x00000000 /* DENALI_PHY_872_DATA */ + 0x00000000 /* DENALI_PHY_873_DATA */ + 0x00000000 /* DENALI_PHY_874_DATA */ + 0x00000000 /* DENALI_PHY_875_DATA */ + 0x00000000 /* DENALI_PHY_876_DATA */ + 0x00000000 /* DENALI_PHY_877_DATA */ + 0x00000000 /* DENALI_PHY_878_DATA */ + 0x00000000 /* DENALI_PHY_879_DATA */ + 0x00000000 /* DENALI_PHY_880_DATA */ + 0x00000000 /* DENALI_PHY_881_DATA */ + 0x00000000 /* DENALI_PHY_882_DATA */ + 0x00000000 /* DENALI_PHY_883_DATA */ + 0x00000000 /* DENALI_PHY_884_DATA */ + 0x00000000 /* DENALI_PHY_885_DATA */ + 0x00000000 /* DENALI_PHY_886_DATA */ + 0x00000000 /* DENALI_PHY_887_DATA */ + 0x00000000 /* DENALI_PHY_888_DATA */ + 0x00000000 /* DENALI_PHY_889_DATA */ + 0x00000000 /* DENALI_PHY_890_DATA */ + 0x00000000 /* DENALI_PHY_891_DATA */ + 0x00000000 /* DENALI_PHY_892_DATA */ + 0x00000000 /* DENALI_PHY_893_DATA */ + 0x00000000 /* DENALI_PHY_894_DATA */ + 0x00000000 /* DENALI_PHY_895_DATA */ + 0x41753260 /* DENALI_PHY_896_DATA */ + 0x0004c008 /* DENALI_PHY_897_DATA */ + 0x000000da /* DENALI_PHY_898_DATA */ + 0x00000000 /* DENALI_PHY_899_DATA */ + 0x00000000 /* DENALI_PHY_900_DATA */ + 0x00010000 /* DENALI_PHY_901_DATA */ + 0x01DDDD90 /* DENALI_PHY_902_DATA */ + 0x01DDDD90 /* DENALI_PHY_903_DATA */ + 0x01030001 /* DENALI_PHY_904_DATA */ + 0x01000000 /* DENALI_PHY_905_DATA */ + 0x00c00000 /* DENALI_PHY_906_DATA */ + 0x00000007 /* DENALI_PHY_907_DATA */ + 0x00000000 /* DENALI_PHY_908_DATA */ + 0x00000000 /* DENALI_PHY_909_DATA */ + 0x04000408 /* DENALI_PHY_910_DATA */ + 0x00000408 /* DENALI_PHY_911_DATA */ + 0x00e4e400 /* DENALI_PHY_912_DATA */ + 0x00000000 /* DENALI_PHY_913_DATA */ + 0x00000000 /* DENALI_PHY_914_DATA */ + 0x00000000 /* DENALI_PHY_915_DATA */ + 0x00000000 /* DENALI_PHY_916_DATA */ + 0x00000000 /* DENALI_PHY_917_DATA */ + 0x00000000 /* DENALI_PHY_918_DATA */ + 0x00000000 /* DENALI_PHY_919_DATA */ + 0x00000000 /* DENALI_PHY_920_DATA */ + 0x00000000 /* DENALI_PHY_921_DATA */ + 0x00000000 /* DENALI_PHY_922_DATA */ + 0x00000000 /* DENALI_PHY_923_DATA */ + 0x00000000 /* DENALI_PHY_924_DATA */ + 0x00000000 /* DENALI_PHY_925_DATA */ + 0x00000000 /* DENALI_PHY_926_DATA */ + 0x00000000 /* DENALI_PHY_927_DATA */ + 0x00000000 /* DENALI_PHY_928_DATA */ + 0x00200000 /* DENALI_PHY_929_DATA */ + 0x00000000 /* DENALI_PHY_930_DATA */ + 0x00000000 /* DENALI_PHY_931_DATA */ + 0x00000000 /* DENALI_PHY_932_DATA */ + 0x00000000 /* DENALI_PHY_933_DATA */ + 0x00000000 /* DENALI_PHY_934_DATA */ + 0x00000000 /* DENALI_PHY_935_DATA */ + 0x02800280 /* DENALI_PHY_936_DATA */ + 0x02800280 /* DENALI_PHY_937_DATA */ + 0x02800280 /* DENALI_PHY_938_DATA */ + 0x02800280 /* DENALI_PHY_939_DATA */ + 0x00000280 /* DENALI_PHY_940_DATA */ + 0x00000000 /* DENALI_PHY_941_DATA */ + 0x00000000 /* DENALI_PHY_942_DATA */ + 0x00000000 /* DENALI_PHY_943_DATA */ + 0x00000000 /* DENALI_PHY_944_DATA */ + 0x00000000 /* DENALI_PHY_945_DATA */ + 0x00800080 /* DENALI_PHY_946_DATA */ + 0x00800080 /* DENALI_PHY_947_DATA */ + 0x00800080 /* DENALI_PHY_948_DATA */ + 0x00800080 /* DENALI_PHY_949_DATA */ + 0x00800080 /* DENALI_PHY_950_DATA */ + 0x00800080 /* DENALI_PHY_951_DATA */ + 0x00800080 /* DENALI_PHY_952_DATA */ + 0x00800080 /* DENALI_PHY_953_DATA */ + 0x00800080 /* DENALI_PHY_954_DATA */ + 0x000100da /* DENALI_PHY_955_DATA */ + 0x01ff0010 /* DENALI_PHY_956_DATA */ + 0x00000000 /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + 0x00000002 /* DENALI_PHY_959_DATA */ + 0x51313152 /* DENALI_PHY_960_DATA */ + 0x80013130 /* DENALI_PHY_961_DATA */ + 0x02000080 /* DENALI_PHY_962_DATA */ + 0x00100001 /* DENALI_PHY_963_DATA */ + 0x0c064208 /* DENALI_PHY_964_DATA */ + 0x000f0c0f /* DENALI_PHY_965_DATA */ + 0x01000140 /* DENALI_PHY_966_DATA */ + 0x0000000c /* DENALI_PHY_967_DATA */ + 0x00000000 /* DENALI_PHY_968_DATA */ + 0x00000000 /* DENALI_PHY_969_DATA */ + 0x00000000 /* DENALI_PHY_970_DATA */ + 0x00000000 /* DENALI_PHY_971_DATA */ + 0x00000000 /* DENALI_PHY_972_DATA */ + 0x00000000 /* DENALI_PHY_973_DATA */ + 0x00000000 /* DENALI_PHY_974_DATA */ + 0x00000000 /* DENALI_PHY_975_DATA */ + 0x00000000 /* DENALI_PHY_976_DATA */ + 0x00000000 /* DENALI_PHY_977_DATA */ + 0x00000000 /* DENALI_PHY_978_DATA */ + 0x00000000 /* DENALI_PHY_979_DATA */ + 0x00000000 /* DENALI_PHY_980_DATA */ + 0x00000000 /* DENALI_PHY_981_DATA */ + 0x00000000 /* DENALI_PHY_982_DATA */ + 0x00000000 /* DENALI_PHY_983_DATA */ + 0x00000000 /* DENALI_PHY_984_DATA */ + 0x00000000 /* DENALI_PHY_985_DATA */ + 0x00000000 /* DENALI_PHY_986_DATA */ + 0x00000000 /* DENALI_PHY_987_DATA */ + 0x00000000 /* DENALI_PHY_988_DATA */ + 0x00000000 /* DENALI_PHY_989_DATA */ + 0x00000000 /* DENALI_PHY_990_DATA */ + 0x00000000 /* DENALI_PHY_991_DATA */ + 0x00000000 /* DENALI_PHY_992_DATA */ + 0x00000000 /* DENALI_PHY_993_DATA */ + 0x00000000 /* DENALI_PHY_994_DATA */ + 0x00000000 /* DENALI_PHY_995_DATA */ + 0x00000000 /* DENALI_PHY_996_DATA */ + 0x00000000 /* DENALI_PHY_997_DATA */ + 0x00000000 /* DENALI_PHY_998_DATA */ + 0x00000000 /* DENALI_PHY_999_DATA */ + 0x00000000 /* DENALI_PHY_1000_DATA */ + 0x00000000 /* DENALI_PHY_1001_DATA */ + 0x00000000 /* DENALI_PHY_1002_DATA */ + 0x00000000 /* DENALI_PHY_1003_DATA */ + 0x00000000 /* DENALI_PHY_1004_DATA */ + 0x00000000 /* DENALI_PHY_1005_DATA */ + 0x00000000 /* DENALI_PHY_1006_DATA */ + 0x00000000 /* DENALI_PHY_1007_DATA */ + 0x00000000 /* DENALI_PHY_1008_DATA */ + 0x00000000 /* DENALI_PHY_1009_DATA */ + 0x00000000 /* DENALI_PHY_1010_DATA */ + 0x00000000 /* DENALI_PHY_1011_DATA */ + 0x00000000 /* DENALI_PHY_1012_DATA */ + 0x00000000 /* DENALI_PHY_1013_DATA */ + 0x00000000 /* DENALI_PHY_1014_DATA */ + 0x00000000 /* DENALI_PHY_1015_DATA */ + 0x00000000 /* DENALI_PHY_1016_DATA */ + 0x00000000 /* DENALI_PHY_1017_DATA */ + 0x00000000 /* DENALI_PHY_1018_DATA */ + 0x00000000 /* DENALI_PHY_1019_DATA */ + 0x00000000 /* DENALI_PHY_1020_DATA */ + 0x00000000 /* DENALI_PHY_1021_DATA */ + 0x00000000 /* DENALI_PHY_1022_DATA */ + 0x00000000 /* DENALI_PHY_1023_DATA */ + 0x76543210 /* DENALI_PHY_1024_DATA */ + 0x0004c008 /* DENALI_PHY_1025_DATA */ + 0x000000da /* DENALI_PHY_1026_DATA */ + 0x00000000 /* DENALI_PHY_1027_DATA */ + 0x00000000 /* DENALI_PHY_1028_DATA */ + 0x00010000 /* DENALI_PHY_1029_DATA */ + 0x01665555 /* DENALI_PHY_1030_DATA */ + 0x01665555 /* DENALI_PHY_1031_DATA */ + 0x01030001 /* DENALI_PHY_1032_DATA */ + 0x01000000 /* DENALI_PHY_1033_DATA */ + 0x00c00000 /* DENALI_PHY_1034_DATA */ + 0x00000007 /* DENALI_PHY_1035_DATA */ + 0x00000000 /* DENALI_PHY_1036_DATA */ + 0x00000000 /* DENALI_PHY_1037_DATA */ + 0x04000408 /* DENALI_PHY_1038_DATA */ + 0x00000408 /* DENALI_PHY_1039_DATA */ + 0x00e4e400 /* DENALI_PHY_1040_DATA */ + 0x00000000 /* DENALI_PHY_1041_DATA */ + 0x00000000 /* DENALI_PHY_1042_DATA */ + 0x00000000 /* DENALI_PHY_1043_DATA */ + 0x00000000 /* DENALI_PHY_1044_DATA */ + 0x00000000 /* DENALI_PHY_1045_DATA */ + 0x00000000 /* DENALI_PHY_1046_DATA */ + 0x00000000 /* DENALI_PHY_1047_DATA */ + 0x00000000 /* DENALI_PHY_1048_DATA */ + 0x00000000 /* DENALI_PHY_1049_DATA */ + 0x00000000 /* DENALI_PHY_1050_DATA */ + 0x00000000 /* DENALI_PHY_1051_DATA */ + 0x00000000 /* DENALI_PHY_1052_DATA */ + 0x00000000 /* DENALI_PHY_1053_DATA */ + 0x00000000 /* DENALI_PHY_1054_DATA */ + 0x00000000 /* DENALI_PHY_1055_DATA */ + 0x00000000 /* DENALI_PHY_1056_DATA */ + 0x00200000 /* DENALI_PHY_1057_DATA */ + 0x00000000 /* DENALI_PHY_1058_DATA */ + 0x00000000 /* DENALI_PHY_1059_DATA */ + 0x00000000 /* DENALI_PHY_1060_DATA */ + 0x00000000 /* DENALI_PHY_1061_DATA */ + 0x00000000 /* DENALI_PHY_1062_DATA */ + 0x00000000 /* DENALI_PHY_1063_DATA */ + 0x02800280 /* DENALI_PHY_1064_DATA */ + 0x02800280 /* DENALI_PHY_1065_DATA */ + 0x02800280 /* DENALI_PHY_1066_DATA */ + 0x02800280 /* DENALI_PHY_1067_DATA */ + 0x00000280 /* DENALI_PHY_1068_DATA */ + 0x00000000 /* DENALI_PHY_1069_DATA */ + 0x00000000 /* DENALI_PHY_1070_DATA */ + 0x00000000 /* DENALI_PHY_1071_DATA */ + 0x00000000 /* DENALI_PHY_1072_DATA */ + 0x00000000 /* DENALI_PHY_1073_DATA */ + 0x00800080 /* DENALI_PHY_1074_DATA */ + 0x00800080 /* DENALI_PHY_1075_DATA */ + 0x00800080 /* DENALI_PHY_1076_DATA */ + 0x00800080 /* DENALI_PHY_1077_DATA */ + 0x00800080 /* DENALI_PHY_1078_DATA */ + 0x00800080 /* DENALI_PHY_1079_DATA */ + 0x00800080 /* DENALI_PHY_1080_DATA */ + 0x00800080 /* DENALI_PHY_1081_DATA */ + 0x00800080 /* DENALI_PHY_1082_DATA */ + 0x000100da /* DENALI_PHY_1083_DATA */ + 0x01ff0010 /* DENALI_PHY_1084_DATA */ + 0x00000000 /* DENALI_PHY_1085_DATA */ + 0x00000000 /* DENALI_PHY_1086_DATA */ + 0x00000002 /* DENALI_PHY_1087_DATA */ + 0x51313152 /* DENALI_PHY_1088_DATA */ + 0x80013130 /* DENALI_PHY_1089_DATA */ + 0x02000080 /* DENALI_PHY_1090_DATA */ + 0x00100001 /* DENALI_PHY_1091_DATA */ + 0x0c064208 /* DENALI_PHY_1092_DATA */ + 0x000f0c0f /* DENALI_PHY_1093_DATA */ + 0x01000140 /* DENALI_PHY_1094_DATA */ + 0x0000000c /* DENALI_PHY_1095_DATA */ + 0x00000000 /* DENALI_PHY_1096_DATA */ + 0x00000000 /* DENALI_PHY_1097_DATA */ + 0x00000000 /* DENALI_PHY_1098_DATA */ + 0x00000000 /* DENALI_PHY_1099_DATA */ + 0x00000000 /* DENALI_PHY_1100_DATA */ + 0x00000000 /* DENALI_PHY_1101_DATA */ + 0x00000000 /* DENALI_PHY_1102_DATA */ + 0x00000000 /* DENALI_PHY_1103_DATA */ + 0x00000000 /* DENALI_PHY_1104_DATA */ + 0x00000000 /* DENALI_PHY_1105_DATA */ + 0x00000000 /* DENALI_PHY_1106_DATA */ + 0x00000000 /* DENALI_PHY_1107_DATA */ + 0x00000000 /* DENALI_PHY_1108_DATA */ + 0x00000000 /* DENALI_PHY_1109_DATA */ + 0x00000000 /* DENALI_PHY_1110_DATA */ + 0x00000000 /* DENALI_PHY_1111_DATA */ + 0x00000000 /* DENALI_PHY_1112_DATA */ + 0x00000000 /* DENALI_PHY_1113_DATA */ + 0x00000000 /* DENALI_PHY_1114_DATA */ + 0x00000000 /* DENALI_PHY_1115_DATA */ + 0x00000000 /* DENALI_PHY_1116_DATA */ + 0x00000000 /* DENALI_PHY_1117_DATA */ + 0x00000000 /* DENALI_PHY_1118_DATA */ + 0x00000000 /* DENALI_PHY_1119_DATA */ + 0x00000000 /* DENALI_PHY_1120_DATA */ + 0x00000000 /* DENALI_PHY_1121_DATA */ + 0x00000000 /* DENALI_PHY_1122_DATA */ + 0x00000000 /* DENALI_PHY_1123_DATA */ + 0x00000000 /* DENALI_PHY_1124_DATA */ + 0x00000000 /* DENALI_PHY_1125_DATA */ + 0x00000000 /* DENALI_PHY_1126_DATA */ + 0x00000000 /* DENALI_PHY_1127_DATA */ + 0x00000000 /* DENALI_PHY_1128_DATA */ + 0x00000000 /* DENALI_PHY_1129_DATA */ + 0x00000000 /* DENALI_PHY_1130_DATA */ + 0x00000000 /* DENALI_PHY_1131_DATA */ + 0x00000000 /* DENALI_PHY_1132_DATA */ + 0x00000000 /* DENALI_PHY_1133_DATA */ + 0x00000000 /* DENALI_PHY_1134_DATA */ + 0x00000000 /* DENALI_PHY_1135_DATA */ + 0x00000000 /* DENALI_PHY_1136_DATA */ + 0x00000000 /* DENALI_PHY_1137_DATA */ + 0x00000000 /* DENALI_PHY_1138_DATA */ + 0x00000000 /* DENALI_PHY_1139_DATA */ + 0x00000000 /* DENALI_PHY_1140_DATA */ + 0x00000000 /* DENALI_PHY_1141_DATA */ + 0x00000000 /* DENALI_PHY_1142_DATA */ + 0x00000000 /* DENALI_PHY_1143_DATA */ + 0x00000000 /* DENALI_PHY_1144_DATA */ + 0x00000000 /* DENALI_PHY_1145_DATA */ + 0x00000000 /* DENALI_PHY_1146_DATA */ + 0x00000000 /* DENALI_PHY_1147_DATA */ + 0x00000000 /* DENALI_PHY_1148_DATA */ + 0x00000000 /* DENALI_PHY_1149_DATA */ + 0x00000000 /* DENALI_PHY_1150_DATA */ + 0x00000000 /* DENALI_PHY_1151_DATA */ + 0x00000000 /* DENALI_PHY_1152_DATA */ + 0x00000000 /* DENALI_PHY_1153_DATA */ + 0x00050000 /* DENALI_PHY_1154_DATA */ + 0x00000000 /* DENALI_PHY_1155_DATA */ + 0x00000000 /* DENALI_PHY_1156_DATA */ + 0x00000000 /* DENALI_PHY_1157_DATA */ + 0x00000100 /* DENALI_PHY_1158_DATA */ + 0x00000000 /* DENALI_PHY_1159_DATA */ + 0x00000000 /* DENALI_PHY_1160_DATA */ + 0x00506401 /* DENALI_PHY_1161_DATA */ + 0x01221102 /* DENALI_PHY_1162_DATA */ + 0x00000122 /* DENALI_PHY_1163_DATA */ + 0x00000000 /* DENALI_PHY_1164_DATA */ + 0x000B1F00 /* DENALI_PHY_1165_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1166_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1167_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1168_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1169_DATA */ + 0x00000B00 /* DENALI_PHY_1170_DATA */ + 0x42080010 /* DENALI_PHY_1171_DATA */ + 0x01000100 /* DENALI_PHY_1172_DATA */ + 0x01000100 /* DENALI_PHY_1173_DATA */ + 0x01000100 /* DENALI_PHY_1174_DATA */ + 0x01000100 /* DENALI_PHY_1175_DATA */ + 0x00000000 /* DENALI_PHY_1176_DATA */ + 0x00000000 /* DENALI_PHY_1177_DATA */ + 0x00000000 /* DENALI_PHY_1178_DATA */ + 0x00000000 /* DENALI_PHY_1179_DATA */ + 0x00000000 /* DENALI_PHY_1180_DATA */ + 0x00000803 /* DENALI_PHY_1181_DATA */ + 0x223FFF00 /* DENALI_PHY_1182_DATA */ + 0x000008FF /* DENALI_PHY_1183_DATA */ + 0x0000057F /* DENALI_PHY_1184_DATA */ + 0x0000057F /* DENALI_PHY_1185_DATA */ + 0x00037FFF /* DENALI_PHY_1186_DATA */ + 0x00037FFF /* DENALI_PHY_1187_DATA */ + 0x00004410 /* DENALI_PHY_1188_DATA */ + 0x00004410 /* DENALI_PHY_1189_DATA */ + 0x00004410 /* DENALI_PHY_1190_DATA */ + 0x00004410 /* DENALI_PHY_1191_DATA */ + 0x00004410 /* DENALI_PHY_1192_DATA */ + 0x00000111 /* DENALI_PHY_1193_DATA */ + 0x00000111 /* DENALI_PHY_1194_DATA */ + 0x00000000 /* DENALI_PHY_1195_DATA */ + 0x00000000 /* DENALI_PHY_1196_DATA */ + 0x00000000 /* DENALI_PHY_1197_DATA */ + 0x04000000 /* DENALI_PHY_1198_DATA */ + 0x00000000 /* DENALI_PHY_1199_DATA */ + 0x00000000 /* DENALI_PHY_1200_DATA */ + 0x00000108 /* DENALI_PHY_1201_DATA */ + 0x00000000 /* DENALI_PHY_1202_DATA */ + 0x00000000 /* DENALI_PHY_1203_DATA */ + 0x00000000 /* DENALI_PHY_1204_DATA */ + 0x00000001 /* DENALI_PHY_1205_DATA */ + 0x00000000 /* DENALI_PHY_1206_DATA */ + 0x00000000 /* DENALI_PHY_1207_DATA */ + 0x00000000 /* DENALI_PHY_1208_DATA */ + 0x00000000 /* DENALI_PHY_1209_DATA */ + 0x00000000 /* DENALI_PHY_1210_DATA */ + 0x00000000 /* DENALI_PHY_1211_DATA */ + 0x00020100 /* DENALI_PHY_1212_DATA */ + 0x00000000 /* DENALI_PHY_1213_DATA */ + 0x00000000 /* DENALI_PHY_1214_DATA */ + >; +}; diff --git a/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi new file mode 100644 index 0000000000..3dcd2b4987 --- /dev/null +++ b/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2020-2021 SiFive, Inc + */ + +#include "fu740-c000-u-boot.dtsi" +#include "fu740-hifive-unmatched-a00-ddr.dtsi" + +/ { + aliases { + spi0 = &spi0; + }; + + memory@80000000 { + u-boot,dm-spl; + }; + + hfclk { + u-boot,dm-spl; + }; + + rtcclk { + u-boot,dm-spl; + }; + +}; + +&clint { + clocks = <&rtcclk>; +}; + +&spi0 { + mmc@0 { + u-boot,dm-spl; + }; +}; + +&gpio { + u-boot,dm-spl; +}; diff --git a/arch/riscv/dts/hifive-unmatched-a00.dts b/arch/riscv/dts/hifive-unmatched-a00.dts new file mode 100644 index 0000000000..b44e8c160d --- /dev/null +++ b/arch/riscv/dts/hifive-unmatched-a00.dts @@ -0,0 +1,259 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* Copyright (c) 2019-2021 SiFive, Inc */ + +#include "fu740-c000.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/* Clock frequency (in Hz) of the PCB crystal for rtcclk */ +#define RTCCLK_FREQ 1000000 + +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "SiFive HiFive Unmatched A00"; + compatible = "sifive,hifive-unmatched-a00", "sifive,fu740-c000", + "sifive,fu740"; + + chosen { + stdout-path = "serial0"; + }; + + cpus { + timebase-frequency = <RTCCLK_FREQ>; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x0 0x80000000 0x4 0x00000000>; + }; + + soc { + }; + + hfclk: hfclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + clock-output-names = "hfclk"; + }; + + rtcclk: rtcclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <RTCCLK_FREQ>; + clock-output-names = "rtcclk"; + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + gpios = <&gpio 2 GPIO_ACTIVE_LOW>; + }; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + temperature-sensor@4c { + compatible = "ti,tmp451"; + reg = <0x4c>; + interrupt-parent = <&gpio>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + }; + + pmic@58 { + compatible = "dlg,da9063"; + reg = <0x58>; + interrupt-parent = <&gpio>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>; + interrupt-controller; + + regulators { + vdd_bcore1: bcore1 { + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-min-microamp = <5000000>; + regulator-max-microamp = <5000000>; + regulator-always-on; + }; + + vdd_bcore2: bcore2 { + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-min-microamp = <5000000>; + regulator-max-microamp = <5000000>; + regulator-always-on; + }; + + vdd_bpro: bpro { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <2500000>; + regulator-always-on; + }; + + vdd_bperi: bperi { + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-min-microamp = <1500000>; + regulator-max-microamp = <1500000>; + regulator-always-on; + }; + + vdd_bmem: bmem { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3000000>; + regulator-max-microamp = <3000000>; + regulator-always-on; + }; + + vdd_bio: bio { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3000000>; + regulator-max-microamp = <3000000>; + regulator-always-on; + }; + + vdd_ldo1: ldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-min-microamp = <100000>; + regulator-max-microamp = <100000>; + regulator-always-on; + }; + + vdd_ldo2: ldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ldo3: ldo3 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ldo4: ldo4 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ldo5: ldo5 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-min-microamp = <100000>; + regulator-max-microamp = <100000>; + regulator-always-on; + }; + + vdd_ldo6: ldo6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ldo7: ldo7 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ldo8: ldo8 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + regulator-always-on; + }; + + vdd_ld09: ldo9 { + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-min-microamp = <200000>; + regulator-max-microamp = <200000>; + }; + + vdd_ldo10: ldo10 { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-min-microamp = <300000>; + regulator-max-microamp = <300000>; + }; + + vdd_ldo11: ldo11 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-min-microamp = <300000>; + regulator-max-microamp = <300000>; + regulator-always-on; + }; + }; + }; +}; + +&qspi0 { + status = "okay"; + flash@0 { + compatible = "issi,is25wp256", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <50000000>; + m25p,fast-read; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + }; +}; + +&spi0 { + status = "okay"; + mmc@0 { + compatible = "mmc-spi-slot"; + reg = <0>; + spi-max-frequency = <20000000>; + voltage-ranges = <3300 3300>; + disable-wp; + }; +}; + +ð0 { + status = "okay"; + phy-mode = "gmii"; + phy-handle = <&phy0>; + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm1 { + status = "okay"; +}; + +&gpio { + status = "okay"; +};
Add defconfig and board support for HiFive Unmatched.
Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com --- arch/riscv/Kconfig | 4 + board/sifive/unleashed/Kconfig | 1 + board/sifive/unmatched/Kconfig | 50 +++ board/sifive/unmatched/MAINTAINERS | 9 + board/sifive/unmatched/Makefile | 9 + board/sifive/unmatched/spl.c | 85 +++++ board/sifive/unmatched/unmatched.c | 24 ++ common/spl/Kconfig | 4 +- configs/sifive_unleashed_defconfig | 1 + configs/sifive_unmatched_defconfig | 54 +++ doc/board/sifive/index.rst | 1 + doc/board/sifive/unmatched.rst | 536 +++++++++++++++++++++++++++++ drivers/reset/Kconfig | 2 +- include/configs/sifive-unmatched.h | 85 +++++ 14 files changed, 862 insertions(+), 3 deletions(-) create mode 100644 board/sifive/unmatched/Kconfig create mode 100644 board/sifive/unmatched/MAINTAINERS create mode 100644 board/sifive/unmatched/Makefile create mode 100644 board/sifive/unmatched/spl.c create mode 100644 board/sifive/unmatched/unmatched.c create mode 100644 configs/sifive_unmatched_defconfig create mode 100644 doc/board/sifive/unmatched.rst create mode 100644 include/configs/sifive-unmatched.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 4177253e44..d12a3be72c 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -20,6 +20,9 @@ config TARGET_QEMU_VIRT config TARGET_SIFIVE_UNLEASHED bool "Support SiFive Unleashed Board"
+config TARGET_SIFIVE_UNMATCHED + bool "Support SiFive Unmatched Board" + config TARGET_SIPEED_MAIX bool "Support Sipeed Maix Board"
@@ -56,6 +59,7 @@ source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" source "board/sifive/unleashed/Kconfig" +source "board/sifive/unmatched/Kconfig" source "board/sipeed/maix/Kconfig"
# platform-specific options below diff --git a/board/sifive/unleashed/Kconfig b/board/sifive/unleashed/Kconfig index dbffd59c98..833cbd370d 100644 --- a/board/sifive/unleashed/Kconfig +++ b/board/sifive/unleashed/Kconfig @@ -27,6 +27,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select SIFIVE_FU540 select ENV_IS_IN_SPI_FLASH + select RESET_SIFIVE imply CMD_DHCP imply CMD_EXT2 imply CMD_EXT4 diff --git a/board/sifive/unmatched/Kconfig b/board/sifive/unmatched/Kconfig new file mode 100644 index 0000000000..9e2748ce1e --- /dev/null +++ b/board/sifive/unmatched/Kconfig @@ -0,0 +1,50 @@ +if TARGET_SIFIVE_UNMATCHED + +config SYS_BOARD + default "unmatched" + +config SYS_VENDOR + default "sifive" + +config SYS_CPU + default "fu740" + +config SYS_CONFIG_NAME + default "sifive-unmatched" + +config SYS_TEXT_BASE + default 0x80200000 if SPL + default 0x80000000 if !RISCV_SMODE + default 0x80200000 if RISCV_SMODE + +config SPL_TEXT_BASE + default 0x08000000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x80000000 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select SIFIVE_FU740 + select SUPPORT_SPL + select RESET_SIFIVE + imply CMD_DHCP + imply CMD_EXT2 + imply CMD_EXT4 + imply CMD_FAT + imply CMD_FS_GENERIC + imply CMD_GPT + imply PARTITION_TYPE_GUID + imply CMD_NET + imply CMD_PING + imply CMD_SF + imply DOS_PARTITION + imply EFI_PARTITION + imply IP_DYN + imply ISO_PARTITION + imply PHY_LIB + imply PHY_MSCC + imply SYSRESET + imply SYSRESET_GPIO + +endif diff --git a/board/sifive/unmatched/MAINTAINERS b/board/sifive/unmatched/MAINTAINERS new file mode 100644 index 0000000000..94c9510bfa --- /dev/null +++ b/board/sifive/unmatched/MAINTAINERS @@ -0,0 +1,9 @@ +SiFive HiFive Unmatched FU740 BOARD +M: Paul Walmsley paul.walmsley@sifive.com +M: Pragnesh Patel pragnesh.patel@sifive.com +M: Green Wan green.wan@sifive.com +S: Maintained +F: board/sifive/unmatched/ +F: doc/board/sifive/hifive-unmatched-fu740.rst +F: include/configs/sifive-unmatched.h +F: configs/sifive_unmatched_defconfig diff --git a/board/sifive/unmatched/Makefile b/board/sifive/unmatched/Makefile new file mode 100644 index 0000000000..6308c80d64 --- /dev/null +++ b/board/sifive/unmatched/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2020-2021 SiFive, Inc + +obj-y += unmatched.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/sifive/unmatched/spl.c b/board/sifive/unmatched/spl.c new file mode 100644 index 0000000000..5e1333b09a --- /dev/null +++ b/board/sifive/unmatched/spl.c @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020-2021 SiFive, Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <init.h> +#include <spl.h> +#include <misc.h> +#include <log.h> +#include <linux/delay.h> +#include <linux/io.h> +#include <asm/gpio.h> +#include <asm/arch/gpio.h> +#include <asm/arch/spl.h> + +#define GEM_PHY_RESET SIFIVE_GENERIC_GPIO_NR(0, 12) + +#define MODE_SELECT_REG 0x1000 +#define MODE_SELECT_SD 0xb +#define MODE_SELECT_MASK GENMASK(3, 0) + +int spl_board_init_f(void) +{ + int ret; + + ret = spl_soc_init(); + if (ret) { + debug("HiFive Unmatched FU740 SPL init failed: %d\n", ret); + return ret; + } + + /* + * GEMGXL init VSC8541 PHY reset sequence; + * leave pull-down active for 2ms + */ + udelay(2000); + ret = gpio_request(GEM_PHY_RESET, "gem_phy_reset"); + if (ret) { + debug("gem_phy_reset gpio request failed: %d\n", ret); + return ret; + } + + /* Set GPIO 12 (PHY NRESET) */ + ret = gpio_direction_output(GEM_PHY_RESET, 1); + if (ret) { + debug("gem_phy_reset gpio direction set failed: %d\n", ret); + return ret; + } + + udelay(1); + + /* Reset PHY again to enter unmanaged mode */ + gpio_set_value(GEM_PHY_RESET, 0); + udelay(1); + gpio_set_value(GEM_PHY_RESET, 1); + mdelay(15); + + return 0; +} + +u32 spl_boot_device(void) +{ + u32 mode_select = readl((void *)MODE_SELECT_REG); + u32 boot_device = mode_select & MODE_SELECT_MASK; + + switch (boot_device) { + case MODE_SELECT_SD: + return BOOT_DEVICE_MMC1; + default: + debug("Unsupported boot device 0x%x but trying MMC1\n", + boot_device); + return BOOT_DEVICE_MMC1; + } +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* boot using first FIT config */ + return 0; +} +#endif diff --git a/board/sifive/unmatched/unmatched.c b/board/sifive/unmatched/unmatched.c new file mode 100644 index 0000000000..6d60559588 --- /dev/null +++ b/board/sifive/unmatched/unmatched.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020-2021, SiFive Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/arch/cache.h> + +int board_init(void) +{ + int ret; + + /* enable all cache ways */ + ret = cache_enable_ways(); + if (ret) { + debug("%s: could not enable cache ways\n", __func__); + return ret; + } + return 0; +} diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0f528f346f..ff41557b0a 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -331,7 +331,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ OMAP44XX || OMAP54XX || AM33XX || AM43XX || \ - TARGET_SIFIVE_UNLEASHED + TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED help Use sector number for specifying U-Boot location on MMC/SD in raw mode. @@ -348,7 +348,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR default 0x300 if ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || OMAP44XX || \ OMAP54XX || AM33XX || AM43XX || ARCH_K3 default 0x4000 if ARCH_ROCKCHIP - default 0x822 if TARGET_SIFIVE_UNLEASHED + default 0x822 if TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes). diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index 62416a7c1d..58e0718b7c 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -27,3 +27,4 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_CLK=y CONFIG_DM_MTD=y CONFIG_DM_RESET=y +CONFIG_CLK_SIFIVE_PRCI=y diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig new file mode 100644 index 0000000000..4e5ed45ad9 --- /dev/null +++ b/configs/sifive_unmatched_defconfig @@ -0,0 +1,54 @@ +CONFIG_RISCV=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x3000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="hifive-unmatched-a00" +CONFIG_TARGET_SIFIVE_UNMATCHED=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x84000000 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_CLK=y +CONFIG_DM_RESET=y +CONFIG_CMD_PCI=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_PNP=y +CONFIG_PCIE_DW_SIFIVE=y +CONFIG_NVME=y +CONFIG_DM_ETH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_USB=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_CMD_PART=y +CONFIG_CMD_NVME=y +CONFIG_SYS_USB_EVENT_POLL=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OCORES=y +CONFIG_CLK_SIFIVE_PRCI=y +CONFIG_DM_PWM=y +CONFIG_PWM_SIFIVE=y +CONFIG_CMD_PWM=y +CONFIG_SPL_USE_ARCH_MEMMOVE=n diff --git a/doc/board/sifive/index.rst b/doc/board/sifive/index.rst index ed7eacfb54..a43937a3e0 100644 --- a/doc/board/sifive/index.rst +++ b/doc/board/sifive/index.rst @@ -7,3 +7,4 @@ SiFive :maxdepth: 2
unleashed + unmatched diff --git a/doc/board/sifive/unmatched.rst b/doc/board/sifive/unmatched.rst new file mode 100644 index 0000000000..e65b0d3206 --- /dev/null +++ b/doc/board/sifive/unmatched.rst @@ -0,0 +1,536 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +HiFive Unmatched +================ + +FU740-C000 RISC-V SoC +--------------------- +The FU740-C000 is a 4+1 64-bit RISC-V core SoC from SiFive. + +The HiFive Unmatched development platform is based on FU740-C000 and capable +of running Linux. + +Mainline support +---------------- +The support for following drivers are already enabled: + +1. SiFive UART Driver. +2. SiFive PRCI Driver for clock. +3. Cadence MACB ethernet driver for networking support. +4. SiFive SPI Driver. +5. MMC SPI Driver for MMC/SD support. + +Booting from uSD using U-Boot SPL +--------------------------------- + +Building +-------- + +Before building U-Boot SPL, OpenSBI must be built first. OpenSBI can be +cloned and built for FU740 as below: + +.. code-block:: console + + git clone https://github.com/riscv/opensbi.git + cd opensbi + make PLATFORM=generic + export OPENSBI=<path to opensbi/build/platform/generic/firmware/fw_dynamic.bin> + +Now build the U-Boot SPL and U-Boot proper + +.. code-block:: console + + cd <U-Boot-dir> + make sifive_unmatched_defconfig + make + +This will generate spl/u-boot-spl.bin and u-boot.itb + + +Flashing +-------- + +ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition with GUID type +5B193300-FC78-40CD-8002-E86C45580B47 + +U-Boot SPL expects u-boot.itb from a partition with GUID +type 2E54B353-1271-4842-806F-E436D6AF6985 + +u-boot.itb is a combination of fw_dynamic.bin, u-boot-nodtb.bin and +device tree blob (hifive-unmatched-a00.dtb) + +Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch) + +.. code-block:: none + + # sudo sgdisk -g --clear -a 1 \ + > --new=1:34:2081 --change-name=1:spl --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ + > --new=2:2082:10273 --change-name=2:uboot --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ + > --new=3:16384:282623 --change-name=3:boot --typecode=3:0x0700 \ + > --new=4:286720:13918207 --change-name=4:root --typecode=4:0x8300 \ + > /dev/sdb + +Copy linux Image.gz and hifive-unmatched-a00.dtb to boot partition + +.. code-block:: none + + sudo mkfs.vfat /dev/sdb3 + sudo mkfs.ext4 /dev/sdb4 + + sudo mount /dev/sdb3 /media/sdb3 + sudo cp Image.gz hifive-unmatched-a00.dtb /media/sdb3/ + +Program the SD card + +.. code-block:: none + + sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 + sudo dd if=u-boot.itb of=/dev/sda seek=2082 + +Booting +------- +Once you plugin the sdcard and power up, you should see the U-Boot prompt. + + +Loading the kernel and dtb + +.. code-block:: none + + fatload mmc 0:3 ${kernel_addr_r} Image.gz + fatload mmc 0:3 ${fdt_addr_r} hifive-unmatched-a00.dtb + booti ${kernel_addr_r} - ${fdt_addr_r} + + +Sample boot log from HiFive Unmatched board +------------------------------------------- + +.. code-block:: none + + U-Boot SPL 2021.04-rc4-00009-g7d70643cc3-dirty (Mar 16 2021 - 18:03:14 +0800) + Trying to boot from MMC1 + + U-Boot 2021.04-rc4-00009-g7d70643cc3-dirty (Mar 16 2021 - 18:03:14 +0800) + + CPU: rv64imafdc + Model: SiFive HiFive Unmatched A00 + DRAM: 16 GiB + MMC: spi@10050000:mmc@0: 0 + In: serial@10010000 + Out: serial@10010000 + Err: serial@10010000 + Model: SiFive HiFive Unmatched A00 + Net: + Error: ethernet@10090000 address not set. + No ethernet found. + + Hit any key to stop autoboot: 0 + PCIe Link up, Gen1 + + Device 0: Vendor: 0x126f Rev: S1111A0L Prod: AA000000000000001995 + Type: Hard Disk + Capacity: 488386.3 MB = 476.9 GB (1000215216 x 512) + ... is now current device + Scanning nvme 0:1... + libfdt fdt_check_header(): FDT_ERR_BADMAGIC + Scanning disk mmc@0.blk... + ** Unrecognized filesystem type ** + ** Unrecognized filesystem type ** + Scanning disk nvme#0.blk#0... + Found 8 disks + No EFI system partition + + Error: ethernet@10090000 address not set. + BootOrder not defined + EFI boot manager: Cannot load any image + starting USB... + Bus xhci_pci: Register 4000840 NbrPorts 4 + Starting the controller + USB XHCI 1.00 + scanning bus xhci_pci for devices... 3 USB Device(s) found + scanning usb for storage devices... 0 Storage Device(s) found + + Device 0: unknown device + switch to partitions #0, OK + mmc0 is current device + Scanning mmc 0:3... + Found /extlinux/extlinux.conf + Retrieving file: /extlinux/extlinux.conf + 205 bytes read in 9 ms (21.5 KiB/s) + 1: OpenEmbedded-SiFive-HiFive-Unmatched + Retrieving file: /Image.gz + 7225919 bytes read in 4734 ms (1.5 MiB/s) + append: root=/dev/mmcblk0p4 rootfstype=ext4 rootwait console=ttySIF0,115200 earlycon=sbi + Retrieving file: /hifive-unmatched-a00.dtb + 10445 bytes read in 13 ms (784.2 KiB/s) + Uncompressing Kernel Image + Moving Image from 0x84000000 to 0x80200000, end=81629000 + ## Flattened Device Tree blob at 88000000 + Booting using the fdt blob at 0x88000000 + Using Device Tree in place at 0000000088000000, end 00000000880058cc + + Starting kernel ... + + [ 0.000000] Linux version 5.10.15 (oe-user@oe-host) (riscv64-oe-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.0.201 + [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 + [ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') + [ 0.000000] printk: bootconsole [sbi0] enabled + [ 0.000000] efi: UEFI not found. + [ 0.000000] Zone ranges: + [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff] + [ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff] + [ 0.000000] Movable zone start for each node + [ 0.000000] Early memory node ranges + [ 0.000000] node 0: [mem 0x0000000080200000-0x000000027fffffff] + [ 0.000000] Zeroed struct page in unavailable ranges: 512 pages + [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000027fffffff] + [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) + [ 0.000000] SBI specification v0.3 detected + [ 0.000000] SBI implementation ID=0x1 Version=0x9 + [ 0.000000] SBI v0.2 TIME extension detected + [ 0.000000] SBI v0.2 IPI extension detected + [ 0.000000] SBI v0.2 RFENCE extension detected + [ 0.000000] SBI v0.2 HSM extension detected + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] riscv: ISA extensions acdfim + [ 0.000000] riscv: ELF capabilities acdfim + [ 0.000000] percpu: Embedded 26 pages/cpu s66904 r8192 d31400 u106496 + [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975 + [ 0.000000] Kernel command line: root=/dev/mmcblk0p4 rootfstype=ext4 rootwait console=ttySIF0,115200 earlycon=sbi + [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) + [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) + [ 0.000000] Sorting __ex_table... + [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off + [ 0.000000] Memory: 8155880K/8386560K available (8490K kernel code, 5515K rwdata, 4096K rodata, 285K init, 383K bss, 23) + [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 + [ 0.000000] rcu: Hierarchical RCU implementation. + [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. + [ 0.000000] Tracing variant of Tasks RCU enabled. + [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. + [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 + [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@0/interrupt-controller + [ 0.000000] riscv-intc: 64 local interrupts mapped + [ 0.000000] plic: interrupt-controller@c000000: mapped 69 interrupts with 4 handlers for 9 contexts. + [ 0.000000] random: get_random_bytes called from 0xffffffe000002a6a with crng_init=0 + [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1] + [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 352636161696s + [ 0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns + [ 0.008626] Console: colour dummy device 80x25 + [ 0.013049] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000) + [ 0.023115] pid_max: default: 32768 minimum: 301 + [ 0.028423] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) + [ 0.035919] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) + [ 0.045957] rcu: Hierarchical SRCU implementation. + [ 0.050393] EFI services will not be available. + [ 0.055132] smp: Bringing up secondary CPUs ... + [ 0.061824] smp: Brought up 1 node, 4 CPUs + [ 0.067458] devtmpfs: initialized + [ 0.072700] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns + [ 0.081789] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) + [ 0.089738] NET: Registered protocol family 16 + [ 0.093999] thermal_sys: Registered thermal governor 'step_wise' + [ 0.109208] iommu: Default domain type: Translated + [ 0.119694] vgaarb: loaded + [ 0.122571] SCSI subsystem initialized + [ 0.126499] usbcore: registered new interface driver usbfs + [ 0.131686] usbcore: registered new interface driver hub + [ 0.137071] usbcore: registered new device driver usb + [ 0.142286] EDAC MC: Ver: 3.0.0 + [ 0.145760] Advanced Linux Sound Architecture Driver Initialized. + [ 0.152205] clocksource: Switched to clocksource riscv_clocksource + [ 1.046286] VFS: Disk quotas dquot_6.6.0 + [ 1.049651] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) + [ 1.062844] NET: Registered protocol family 2 + [ 1.067172] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) + [ 1.075455] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) + [ 1.085428] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) + [ 1.096548] TCP: Hash tables configured (established 65536 bind 65536) + [ 1.103043] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) + [ 1.109879] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) + [ 1.117413] NET: Registered protocol family 1 + [ 1.121881] RPC: Registered named UNIX socket transport module. + [ 1.127139] RPC: Registered udp transport module. + [ 1.131901] RPC: Registered tcp transport module. + [ 1.136677] RPC: Registered tcp NFSv4.1 backchannel transport module. + [ 1.143194] PCI: CLS 0 bytes, default 64 + [ 1.148359] Initialise system trusted keyrings + [ 1.152364] workingset: timestamp_bits=62 max_order=21 bucket_order=0 + [ 1.165382] NFS: Registering the id_resolver key type + [ 1.169781] Key type id_resolver registered + [ 1.174011] Key type id_legacy registered + [ 1.178179] nfs4filelayout_init: NFSv4 File Layout Driver Registering... + [ 1.184874] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). + [ 1.192453] 9p: Installing v9fs 9p2000 file system support + [ 1.198116] NET: Registered protocol family 38 + [ 1.201886] Key type asymmetric registered + [ 1.206046] Asymmetric key parser 'x509' registered + [ 1.211029] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) + [ 1.218468] io scheduler mq-deadline registered + [ 1.223072] io scheduler kyber registered + [ 1.228803] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 + [ 1.235017] fu740-pcie e00000000.pcie: FPGA PCIE PROBE + [ 1.281706] fu740-pcie e00000000.pcie: PCIE-PERSTN is GPIO 504 + [ 1.286922] fu740-pcie e00000000.pcie: PWREN is GPIO 501 + [ 1.292377] fu740-pcie e00000000.pcie: host bridge /soc/pcie@e00000000 ranges: + [ 1.299603] fu740-pcie e00000000.pcie: IO 0x0060080000..0x006008ffff -> 0x0060080000 + [ 1.307922] fu740-pcie e00000000.pcie: MEM 0x0060090000..0x0070ffffff -> 0x0060090000 + [ 1.316244] fu740-pcie e00000000.pcie: MEM 0x2000000000..0x3fffffffff -> 0x2000000000 + [ 1.432223] fu740-pcie e00000000.pcie: PWREN enabling + [ 1.436607] fu740-pcie e00000000.pcie: PWREN valid + [ 1.560226] fu740-pcie e00000000.pcie: invalid resource + [ 1.664802] fu740-pcie e00000000.pcie: Link up + [ 1.768582] fu740-pcie e00000000.pcie: Link up + [ 1.872369] fu740-pcie e00000000.pcie: Link up + [ 1.876116] fu740-pcie e00000000.pcie: Link up, Gen3 + [ 1.881352] fu740-pcie e00000000.pcie: PCI host bridge to bus 0000:00 + [ 1.887700] pci_bus 0000:00: root bus resource [bus 00-ff] + [ 1.893247] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x60080000-0x6008ffff]) + [ 1.902807] pci_bus 0000:00: root bus resource [mem 0x60090000-0x70ffffff] + [ 1.909748] pci_bus 0000:00: root bus resource [mem 0x2000000000-0x3fffffffff pref] + [ 1.917517] pci 0000:00:00.0: [f15e:0000] type 01 class 0x060400 + [ 1.923569] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff] + [ 1.929902] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] + [ 1.936723] pci 0000:00:00.0: supports D1 + [ 1.940755] pci 0000:00:00.0: PME# supported from D0 D1 D3hot + [ 1.947619] pci 0000:01:00.0: [1b21:2824] type 01 class 0x060400 + [ 1.953052] pci 0000:01:00.0: enabling Extended Tags + [ 1.958165] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold + [ 1.976890] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 1.984425] pci 0000:02:00.0: [1b21:2824] type 01 class 0x060400 + [ 1.990396] pci 0000:02:00.0: enabling Extended Tags + [ 1.995509] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold + [ 2.001938] pci 0000:02:02.0: [1b21:2824] type 01 class 0x060400 + [ 2.007682] pci 0000:02:02.0: enabling Extended Tags + [ 2.012793] pci 0000:02:02.0: PME# supported from D0 D3hot D3cold + [ 2.019167] pci 0000:02:03.0: [1b21:2824] type 01 class 0x060400 + [ 2.024966] pci 0000:02:03.0: enabling Extended Tags + [ 2.030075] pci 0000:02:03.0: PME# supported from D0 D3hot D3cold + [ 2.036468] pci 0000:02:04.0: [1b21:2824] type 01 class 0x060400 + [ 2.042250] pci 0000:02:04.0: enabling Extended Tags + [ 2.047359] pci 0000:02:04.0: PME# supported from D0 D3hot D3cold + [ 2.053811] pci 0000:02:08.0: [1b21:2824] type 01 class 0x060400 + [ 2.059534] pci 0000:02:08.0: enabling Extended Tags + [ 2.064647] pci 0000:02:08.0: PME# supported from D0 D3hot D3cold + [ 2.071499] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 2.078837] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 2.086911] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 2.094987] pci 0000:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 2.103075] pci 0000:02:08.0: bridge configuration invalid ([bus 00-00]), reconfiguring + [ 2.111901] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03 + [ 2.118031] pci 0000:04:00.0: [1b21:1142] type 00 class 0x0c0330 + [ 2.123968] pci 0000:04:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit] + [ 2.131038] pci 0000:04:00.0: PME# supported from D3cold + [ 2.148888] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 04 + [ 2.155588] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05 + [ 2.162286] pci_bus 0000:06: busn_res: [bus 06-ff] end is updated to 06 + [ 2.168408] pci 0000:07:00.0: [126f:2263] type 00 class 0x010802 + [ 2.174351] pci 0000:07:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] + [ 2.192890] pci_bus 0000:07: busn_res: [bus 07-ff] end is updated to 07 + [ 2.198837] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 07 + [ 2.205522] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 07 + [ 2.212241] pci 0000:00:00.0: BAR 0: assigned [mem 0x60100000-0x601fffff] + [ 2.219067] pci 0000:00:00.0: BAR 14: assigned [mem 0x60200000-0x603fffff] + [ 2.226010] pci 0000:00:00.0: BAR 6: assigned [mem 0x60090000-0x6009ffff pref] + [ 2.233308] pci 0000:01:00.0: BAR 14: assigned [mem 0x60200000-0x603fffff] + [ 2.240259] pci 0000:02:02.0: BAR 14: assigned [mem 0x60200000-0x602fffff] + [ 2.247203] pci 0000:02:08.0: BAR 14: assigned [mem 0x60300000-0x603fffff] + [ 2.254150] pci 0000:02:00.0: PCI bridge to [bus 03] + [ 2.259217] pci 0000:04:00.0: BAR 0: assigned [mem 0x60200000-0x60207fff 64bit] + [ 2.266594] pci 0000:02:02.0: PCI bridge to [bus 04] + [ 2.271615] pci 0000:02:02.0: bridge window [mem 0x60200000-0x602fffff] + [ 2.278485] pci 0000:02:03.0: PCI bridge to [bus 05] + [ 2.283529] pci 0000:02:04.0: PCI bridge to [bus 06] + [ 2.288572] pci 0000:07:00.0: BAR 0: assigned [mem 0x60300000-0x60303fff 64bit] + [ 2.295952] pci 0000:02:08.0: PCI bridge to [bus 07] + [ 2.300973] pci 0000:02:08.0: bridge window [mem 0x60300000-0x603fffff] + [ 2.307842] pci 0000:01:00.0: PCI bridge to [bus 02-07] + [ 2.313133] pci 0000:01:00.0: bridge window [mem 0x60200000-0x603fffff] + [ 2.320009] pci 0000:00:00.0: PCI bridge to [bus 01-07] + [ 2.325288] pci 0000:00:00.0: bridge window [mem 0x60200000-0x603fffff] + [ 2.332808] pcieport 0000:00:00.0: AER: enabled with IRQ 51 + [ 2.337946] pcieport 0000:01:00.0: enabling device (0000 -> 0002) + [ 2.344786] pcieport 0000:02:02.0: enabling device (0000 -> 0002) + [ 2.351328] pcieport 0000:02:08.0: enabling device (0000 -> 0002) + [ 2.357091] pci 0000:04:00.0: enabling device (0000 -> 0002) + [ 2.362751] switchtec: loaded. + [ 2.365933] L2CACHE: DataError @ 0x00000003.00964470 + [ 2.365992] L2CACHE: No. of Banks in the cache: 4 + [ 2.375414] L2CACHE: No. of ways per bank: 16 + [ 2.379846] L2CACHE: Sets per bank: 512 + [ 2.383751] L2CACHE: Bytes per cache block: 64 + [ 2.388267] L2CACHE: Index of the largest way enabled: 15 + [ 2.434865] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled + [ 2.441695] 10010000.serial: ttySIF0 at MMIO 0x10010000 (irq = 1, base_baud = 115200) is a SiFive UART v0 + [ 2.450625] printk: console [ttySIF0] enabled + [ 2.450625] printk: console [ttySIF0] enabled + [ 2.459360] printk: bootconsole [sbi0] disabled + [ 2.459360] printk: bootconsole [sbi0] disabled + [ 2.468824] 10011000.serial: ttySIF1 at MMIO 0x10011000 (irq = 2, base_baud = 115200) is a SiFive UART v0 + [ 2.493853] loop: module loaded + [ 2.526475] nvme nvme0: pci function 0000:07:00.0 + [ 2.530852] nvme 0000:07:00.0: enabling device (0000 -> 0002) + [ 2.537716] Rounding down aligned max_sectors from 4294967295 to 4294967288 + [ 2.544470] db_root: cannot open: /etc/target + [ 2.545926] nvme nvme0: allocated 64 MiB host memory buffer. + [ 2.549020] sifive_spi 10040000.spi: mapped; irq=4, cs=1 + [ 2.559941] spi-nor spi0.0: is25wp256 (32768 Kbytes) + [ 2.566431] sifive_spi 10050000.spi: mapped; irq=6, cs=1 + [ 2.566707] nvme nvme0: 4/0/0 default/read/poll queues + [ 2.571935] libphy: Fixed MDIO Bus: probed + [ 2.580950] macb 10090000.ethernet: Registered clk switch 'sifive-gemgxl-mgmt' + [ 2.587536] macb 10090000.ethernet: invalid hw address, using random + [ 2.588100] nvme0n1: p1 p2 + [ 2.593875] BEU: Load or Store TILINK BUS ERR occurred + [ 2.594342] libphy: MACB_mii_bus: probed + [ 2.599312] macb 10090000.ethernet eth0: Cadence GEM rev 0x10070109 at 0x10090000 irq 7 (5e:57:b8:ab:24:4a) + [ 2.615501] e1000e: Intel(R) PRO/1000 Network Driver + [ 2.620251] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. + [ 2.626463] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver + [ 2.632684] ehci-pci: EHCI PCI platform driver + [ 2.637144] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver + [ 2.643273] ohci-pci: OHCI PCI platform driver + [ 2.647731] uhci_hcd: USB Universal Host Controller Interface driver + [ 2.654315] xhci_hcd 0000:04:00.0: xHCI Host Controller + [ 2.659450] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 1 + [ 2.807373] xhci_hcd 0000:04:00.0: hcc params 0x0200e081 hci version 0x100 quirks 0x0000000010000410 + [ 2.816609] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 + [ 2.824115] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 + [ 2.831312] usb usb1: Product: xHCI Host Controller + [ 2.836174] usb usb1: Manufacturer: Linux 5.10.15 xhci-hcd + [ 2.841652] usb usb1: SerialNumber: 0000:04:00.0 + [ 2.846639] hub 1-0:1.0: USB hub found + [ 2.850037] hub 1-0:1.0: 2 ports detected + [ 2.854306] xhci_hcd 0000:04:00.0: xHCI Host Controller + [ 2.859335] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 2 + [ 2.866599] xhci_hcd 0000:04:00.0: Host supports USB 3.0 SuperSpeed + [ 2.873638] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. + [ 2.881074] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 + [ 2.889212] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 + [ 2.896422] usb usb2: Product: xHCI Host Controller + [ 2.901282] usb usb2: Manufacturer: Linux 5.10.15 xhci-hcd + [ 2.906752] usb usb2: SerialNumber: 0000:04:00.0 + [ 2.911671] hub 2-0:1.0: USB hub found + [ 2.915130] hub 2-0:1.0: 2 ports detected + [ 2.919486] usbcore: registered new interface driver usb-storage + [ 2.925212] usbcore: registered new interface driver usbserial_generic + [ 2.931620] usbserial: USB Serial support registered for generic + [ 2.937771] mousedev: PS/2 mouse device common for all mice + [ 2.943220] usbcore: registered new interface driver usbtouchscreen + [ 2.949466] i2c /dev entries driver + [ 2.954218] lm90 0-004c: supply vcc not found, using dummy regulator + [ 2.961629] EDAC DEVICE0: Giving out device to module Sifive ECC Manager controller sifive_edac.0: DEV sifive_edac.0 (I) + [ 2.997874] mmc_spi spi1.0: SD/MMC host mmc0, no DMA, no WP, no poweroff, cd polling + [ 3.005138] ledtrig-cpu: registered to indicate activity on CPUs + [ 3.010980] usbcore: registered new interface driver usbhid + [ 3.016407] usbhid: USB HID core driver + [ 3.020540] usbcore: registered new interface driver snd-usb-audio + [ 3.027209] NET: Registered protocol family 10 + [ 3.031878] Segment Routing with IPv6 + [ 3.034864] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver + [ 3.041232] NET: Registered protocol family 17 + [ 3.045324] 9pnet: Installing 9P2000 support + [ 3.049397] Key type dns_resolver registered + [ 3.053786] Loading compiled-in X.509 certificates + [ 3.059729] ALSA device list: + [ 3.061943] No soundcards found. + [ 3.066057] Waiting for root device /dev/mmcblk0p4... + [ 3.077319] mmc0: host does not support reading read-only switch, assuming write-enable + [ 3.084564] mmc0: new SDHC card on SPI + [ 3.089699] mmcblk0: mmc0:0000 SD32G 29.7 GiB + [ 3.126488] GPT:Primary header thinks Alt. header is not at the end of the disk. + [ 3.133144] GPT:13918241 != 62333951 + [ 3.136679] GPT:Alternate GPT header not at the end of the disk. + [ 3.142673] GPT:13918241 != 62333951 + [ 3.146231] GPT: Use GNU Parted to correct GPT errors. + [ 3.151398] mmcblk0: p1 p2 p3 p4 + [ 3.212226] usb 1-2: new high-speed USB device number 2 using xhci_hcd + [ 3.258310] EXT4-fs (mmcblk0p4): INFO: recovery required on readonly filesystem + [ 3.264855] EXT4-fs (mmcblk0p4): write access will be enabled during recovery + [ 3.458247] usb 1-2: New USB device found, idVendor=174c, idProduct=2074, bcdDevice= 0.01 + [ 3.465662] usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1 + [ 3.472775] usb 1-2: Product: AS2107 + [ 3.476336] usb 1-2: Manufacturer: ASMedia + [ 3.480419] usb 1-2: SerialNumber: USB2.0 Hub + [ 3.533583] EXT4-fs (mmcblk0p4): recovery complete + [ 3.543756] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null) + [ 3.551132] VFS: Mounted root (ext4 filesystem) readonly on device 179:4. + [ 3.554682] hub 1-2:1.0: USB hub found + [ 3.561105] devtmpfs: mounted + [ 3.561778] hub 1-2:1.0: 4 ports detected + [ 3.565546] Freeing unused kernel memory: 284K + [ 3.572964] Kernel memory protection not selected by kernel config. + [ 3.579225] Run /sbin/init as init process + [ 3.613136] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd + [ 3.643539] usb 2-2: New USB device found, idVendor=174c, idProduct=3074, bcdDevice= 0.01 + [ 3.650948] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1 + [ 3.658072] usb 2-2: Product: AS2107 + [ 3.661630] usb 2-2: Manufacturer: ASMedia + [ 3.665709] usb 2-2: SerialNumber: USB2.0 Hub + [ 3.762380] hub 2-2:1.0: USB hub found + [ 3.766074] hub 2-2:1.0: 4 ports detected + [ 7.487226] systemd[1]: System time before build time, advancing clock. + [ 7.788093] systemd[1]: systemd 247.2+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +U) + [ 7.809694] systemd[1]: Detected architecture riscv64. + + Welcome to OpenEmbedded nodistro.0! + + [ 7.832648] systemd[1]: Set hostname to <unmatched>. + [ 9.397499] systemd[1]: Queued start job for default target Multi-User System. + [ 9.408518] random: systemd: uninitialized urandom read (16 bytes read) + [ 9.429329] systemd[1]: Created slice system-getty.slice. + [ OK ] Created slice system-getty.slice. + [ 9.440400] random: systemd: uninitialized urandom read (16 bytes read) + [ 9.447086] systemd[1]: Created slice system-modprobe.slice. + [ OK ] Created slice system-modprobe.slice. + [ 9.458480] random: systemd: uninitialized urandom read (16 bytes read) + [ 9.465436] systemd[1]: Created slice system-serial\x2dgetty.slice. + [ OK ] Created slice system-serial\x2dgetty.slice. + [ 9.478594] systemd[1]: Created slice User and Session Slice. + [ OK ] Created slice User and Session Slice. + [ 9.490225] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. + [ OK ] Started Dispatch Password ��…ts to Console Directory Watch. + [ 9.506407] systemd[1]: Started Forward Password Requests to Wall Directory Watch. + [ OK ] Started Forward Password R��…uests to Wall Directory Watch. + [ 9.522312] systemd[1]: Reached target Paths. + [ OK ] Reached target Paths. + [ 9.531078] systemd[1]: Reached target Remote File Systems. + [ OK ] Reached target Remote File Systems. + [ 9.542855] systemd[1]: Reached target Slices. + [ OK ] Reached target Slices. + [ 9.552712] systemd[1]: Reached target Swap. + [ OK ] Reached target Swap. + [ 9.561566] systemd[1]: Listening on initctl Compatibility Named Pipe. + [ OK ] Listening on initctl Compatibility Named Pipe. + [ 9.578686] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. + [ 9.586545] systemd[1]: Listening on Journal Socket (/dev/log). + [ OK ] Listening on Journal Socket (/dev/log). + + [snip] + + [ OK ] Reached target System Time Synchronized. + [ OK ] Reached target Timers. + [ OK ] Listening on D-Bus System Message Bus Socket. + [ OK ] Reached target Sockets. + [ OK ] Reached target Basic System. + [ OK ] Started D-Bus System Message Bus. + Starting User Login Management... + Starting Permit User Sessions... + [ OK ] Started Xinetd A Powerful Replacement For Inetd. + [ OK ] Finished Permit User Sessions. + [ OK ] Started Getty on tty1. + [ OK ] Started Serial Getty on hvc0. + [ OK ] Started Serial Getty on ttySIF0. + [ OK ] Reached target Login Prompts. + [ OK ] Started User Login Management. + [ OK ] Reached target Multi-User System. + Starting Update UTMP about System Runlevel Changes... + [ OK ] Finished Update UTMP about System Runlevel Changes. + + OpenEmbedded nodistro.0 unmatched hvc0 + + unmatched login: + OpenEmbedded nodistro.0 unmatched ttySIF0 + + unmatched login: diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 019565f979..8ddea851e8 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -166,7 +166,7 @@ config RESET_IPQ419
config RESET_SIFIVE bool "Reset Driver for SiFive SoC's" - depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && TARGET_SIFIVE_UNLEASHED + depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && (TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED) default y help PRCI module within SiFive SoC's provides mechanism to reset diff --git a/include/configs/sifive-unmatched.h b/include/configs/sifive-unmatched.h new file mode 100644 index 0000000000..c73809dd19 --- /dev/null +++ b/include/configs/sifive-unmatched.h @@ -0,0 +1,85 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020-2021 SiFive, Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#ifndef __SIFIVE_UNMATCHED_H +#define __SIFIVE_UNMATCHED_H + +#include <linux/sizes.h> + +#ifdef CONFIG_SPL + +#define CONFIG_SPL_MAX_SIZE 0x00100000 +#define CONFIG_SPL_BSS_START_ADDR 0x85000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 + +#define CONFIG_SPL_STACK (0x08000000 + 0x001D0000 - \ + GENERATED_GBL_DATA_SIZE) + +#endif + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) + +#define CONFIG_SYS_MALLOC_LEN SZ_8M + +#define CONFIG_SYS_BOOTM_LEN SZ_64M + +#define CONFIG_STANDALONE_LOAD_ADDR 0x80200000 + +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit resources */ + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +/* Environment options */ + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(NVME, nvme, 0) \ + func(USB, usb, 0) \ + func(MMC, mmc, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define TYPE_GUID_LOADER1 "5B193300-FC78-40CD-8002-E86C45580B47" +#define TYPE_GUID_LOADER2 "2E54B353-1271-4842-806F-E436D6AF6985" +#define TYPE_GUID_SYSTEM "0FC63DAF-8483-4772-8E79-3D69D8477DE4" + +#define PARTS_DEFAULT \ + "name=loader1,start=17K,size=1M,type=${type_guid_gpt_loader1};" \ + "name=loader2,size=4MB,type=${type_guid_gpt_loader2};" \ + "name=system,size=-,bootable,type=${type_guid_gpt_system};" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_addr_r=0x84000000\0" \ + "fdt_addr_r=0x88000000\0" \ + "scriptaddr=0x88100000\0" \ + "pxefile_addr_r=0x88200000\0" \ + "ramdisk_addr_r=0x88300000\0" \ + "kernel_comp_addr_r=0x90000000\0" \ + "kernel_comp_size=0x4000000\0" \ + "type_guid_gpt_loader1=" TYPE_GUID_LOADER1 "\0" \ + "type_guid_gpt_loader2=" TYPE_GUID_LOADER2 "\0" \ + "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ + BOOTENV + +#define CONFIG_PREBOOT \ + "setenv fdt_addr ${fdtcontroladdr};" \ + "fdt addr ${fdtcontroladdr};" +#endif /* CONFIG_SPL_BUILD */ + +#endif /* __SIFIVE_UNMATCHED_H */
From: David Abdurachmanov david.abdurachmanov@sifive.com
Add fu740 support to macb ethernet driver
There is a PLL HW quirk in FU740. The VSC8541XMV-02 specification requires 125 +/-0.0125 Mhz. But the most close value can be output by PLL is 125.125 MHz and out of VSC8541XMV-02 spec.
Signed-off-by: David Abdurachmanov david.abdurachmanov@sifive.com Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/net/macb.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 57ea45e2dc..bf70525c54 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -591,8 +591,17 @@ static int macb_sifive_clk_init(struct udevice *dev, ulong rate) * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic * and output clock on GMII output signal GTX_CLK * 1 = MII mode. Use MII input signal TX_CLK in TX logic + * + * FU740 have a PLL HW quirk. The 125.125 Mhz is actually out of + * VSC8541XMV-02 specification. The tolerance level is +/-100ppm. + * Which means the range should be in between 125MHz +/-0.0125. + * But the most close value can be output by PLL is 125.125 MHz. */ - writel(rate != 125000000, gemgxl_regs); + if (device_is_compatible(dev, "sifive,fu540-c000-gem")) + writel(rate != 125000000, gemgxl_regs); + else if (device_is_compatible(dev, "sifive,fu740-c000-gem")) + writel(rate != 125125000, gemgxl_regs); + return 0; }
@@ -1507,6 +1516,8 @@ static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,zynq-gem" }, { .compatible = "sifive,fu540-c000-gem", .data = (ulong)&sifive_config }, + { .compatible = "sifive,fu740-c000-gem", + .data = (ulong)&sifive_config }, { .compatible = "microchip,mpfs-mss-gem", .data = (ulong)µchip_config }, { }
It looks this patch was never applied. Both U-Boot and Linux drivers do not have the "sifive,fu740-c000-gem" codes.
Not sure what the current upstream status of this?
Regards, Bin
On Thu, 22 Apr 2021 02:11:51 PDT (-0700), green.wan@sifive.com wrote:
This patch set is to add SiFive fu740 chip and HiFive Unmatched board support. Patches are split into several parts:
- [PATCH v7 1/8] support for fu740 cpu
- [PATCH v7 2/8] support for fu740 clk driver
- [PATCH v7 3/8] rename and support for fu740 ram driver
- [PATCH v7 4/8] add pcie driver
- [PATCH v7 5/8] dts for SiFive fu740
- [PATCH v7 6/8] dts for SiFive Unmatched board
- [PATCH v7 7/8] add Unmatched board support
- [PATCH v7 8/8] add fu740 support to macb driver
I've got a bunch of versions of this in my inbox, but I always have an arbitrary subset of the patches. This generally LGTM, but it's kind of hard to figure out what goes where when patch sets are split between trees like this.
IMO the drivers don't need to be in my tree for the DTS files to get merged, we just need the bindings to be agreed upon. Can you send a version of this with just the patches that haven't otherwise been merged and are relevant for the RISC-V tree?
Description
- For fu740 cpu support, reuse most of fu540 cpu.
- For prci driver, add one abstract layer to separate fu540 and fu740. Move orignal fu540 code to separate files.
- For pcie driver, it depends on gpio, prci, clk and reset drivers to do init&reset works. Also based on pcie_dw_common.c
- Align with Linux DT file.
Tests and patch checks
- Able to boot both unmatched and unleashed boards.
- PCIe tests . M.2 NVMe SSD . e1000 compatibale ethernet adapter (ping&tftpboot) . pci-to-usb adapter(usb mass storage)
- checkpatch is performed. To keep code derived from other boards the same, ignore some warnings/errors in [PATCH 7/8].
Changlogs
- V7 . Rebase to latest master branch . Moved dts for fu740 patch [v6 1/7] to [v7 5/8] and seperate dts of Unmatched board from [v6 6/7] into [v7 6/8] . Applied PCIe refactoring patch to base on the common code in pcie_dw_common.c
- V6 . Remove redundant DT string for 1.2GHz CPU clock and squash to [1/7]
- V5 . Fix unleashed build error in patch [6/8] . Append one more set for 1.2GHz CPU speed . Add "#include <asm/global_data.h>" back to sifive_ddr.c . Add Reviewed-by to [4/8] and [7/8]
- V4 . fixed incorrect file name in ./board/sifive/unmatched/Makefile . fixed link in doc/board/sifive/index.rst, passed 'make htmldocs'
- V3 . Rebase to unleashed rename v2 patch . Rename doc/board/sifive/unmatched.rst board/sifive/unmatched/unmatched.c . Fix tail whitespace . Add 'git mv' info to ram driver and merge patch back to one . Add comment to macb driver for PLL hardware quirk . Add reviewed-by to patch [6/7] . Add 'gpio-poweroff' node for upcoming opensbi integration
- V2 . Rebase to unleashed rename patch . remove unnessaary fu540 changes . split ram driver patch into 2 to keep 'git mv' info . use a shorter name for unmatched support . Remove redundant&incorrect temperature-sensor in DT . Remove unnecessary USB EHCI & OHCI from defconfig . Revised fu740 doc . Fixed year of copyright . Add reviewed-by received in v1 patch
David Abdurachmanov (1): drivers: net: macb: add fu740 support
Green Wan (7): riscv: cpu: fu740: Add support for cpu fu740 drivers: clk: add fu740 support drivers: ram: sifive: rename fu540_ddr and add fu740 support drivers: pci: add pcie support for fu740 riscv: dts: add fu740 support riscv: dts: add SiFive Unmatched board support board: sifive: add HiFive Unmatched board support
arch/riscv/Kconfig | 5 + arch/riscv/cpu/fu740/Kconfig | 37 + arch/riscv/cpu/fu740/Makefile | 12 + arch/riscv/cpu/fu740/cache.c | 55 + arch/riscv/cpu/fu740/cpu.c | 22 + arch/riscv/cpu/fu740/dram.c | 38 + arch/riscv/cpu/fu740/spl.c | 23 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/fu740-c000-u-boot.dtsi | 105 ++ arch/riscv/dts/fu740-c000.dtsi | 329 ++++ .../dts/fu740-hifive-unmatched-a00-ddr.dtsi | 1489 +++++++++++++++++ .../dts/hifive-unmatched-a00-u-boot.dtsi | 40 + arch/riscv/dts/hifive-unmatched-a00.dts | 259 +++ arch/riscv/include/asm/arch-fu740/cache.h | 14 + arch/riscv/include/asm/arch-fu740/clk.h | 14 + arch/riscv/include/asm/arch-fu740/gpio.h | 38 + arch/riscv/include/asm/arch-fu740/reset.h | 13 + arch/riscv/include/asm/arch-fu740/spl.h | 14 + arch/riscv/lib/sifive_clint.c | 1 - board/sifive/unleashed/Kconfig | 1 + board/sifive/unmatched/Kconfig | 50 + board/sifive/unmatched/MAINTAINERS | 9 + board/sifive/unmatched/Makefile | 9 + board/sifive/unmatched/spl.c | 85 + board/sifive/unmatched/unmatched.c | 24 + common/spl/Kconfig | 4 +- configs/sifive_unleashed_defconfig | 1 + configs/sifive_unmatched_defconfig | 54 + doc/board/sifive/index.rst | 1 + doc/board/sifive/unmatched.rst | 536 ++++++ drivers/clk/sifive/Kconfig | 8 +- drivers/clk/sifive/Makefile | 4 +- drivers/clk/sifive/fu540-prci.c | 769 +-------- drivers/clk/sifive/fu540-prci.h | 22 + drivers/clk/sifive/fu740-prci.c | 158 ++ drivers/clk/sifive/fu740-prci.h | 22 + drivers/clk/sifive/sifive-prci.c | 733 ++++++++ drivers/clk/sifive/sifive-prci.h | 323 ++++ drivers/net/macb.c | 13 +- drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_sifive.c | 508 ++++++ drivers/ram/sifive/Kconfig | 8 +- drivers/ram/sifive/Makefile | 2 +- .../ram/sifive/{fu540_ddr.c => sifive_ddr.c} | 89 +- drivers/reset/Kconfig | 2 +- include/configs/sifive-unmatched.h | 85 + include/dt-bindings/clock/sifive-fu740-prci.h | 25 + include/dt-bindings/reset/sifive-fu740-prci.h | 19 + 49 files changed, 5277 insertions(+), 807 deletions(-) create mode 100644 arch/riscv/cpu/fu740/Kconfig create mode 100644 arch/riscv/cpu/fu740/Makefile create mode 100644 arch/riscv/cpu/fu740/cache.c create mode 100644 arch/riscv/cpu/fu740/cpu.c create mode 100644 arch/riscv/cpu/fu740/dram.c create mode 100644 arch/riscv/cpu/fu740/spl.c create mode 100644 arch/riscv/dts/fu740-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu740-c000.dtsi create mode 100644 arch/riscv/dts/fu740-hifive-unmatched-a00-ddr.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00.dts create mode 100644 arch/riscv/include/asm/arch-fu740/cache.h create mode 100644 arch/riscv/include/asm/arch-fu740/clk.h create mode 100644 arch/riscv/include/asm/arch-fu740/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu740/reset.h create mode 100644 arch/riscv/include/asm/arch-fu740/spl.h create mode 100644 board/sifive/unmatched/Kconfig create mode 100644 board/sifive/unmatched/MAINTAINERS create mode 100644 board/sifive/unmatched/Makefile create mode 100644 board/sifive/unmatched/spl.c create mode 100644 board/sifive/unmatched/unmatched.c create mode 100644 configs/sifive_unmatched_defconfig create mode 100644 doc/board/sifive/unmatched.rst create mode 100644 drivers/clk/sifive/fu540-prci.h create mode 100644 drivers/clk/sifive/fu740-prci.c create mode 100644 drivers/clk/sifive/fu740-prci.h create mode 100644 drivers/clk/sifive/sifive-prci.c create mode 100644 drivers/clk/sifive/sifive-prci.h create mode 100644 drivers/pci/pcie_dw_sifive.c rename drivers/ram/sifive/{fu540_ddr.c => sifive_ddr.c} (81%) create mode 100644 include/configs/sifive-unmatched.h create mode 100644 include/dt-bindings/clock/sifive-fu740-prci.h create mode 100644 include/dt-bindings/reset/sifive-fu740-prci.h
Ah, sorry, I'm lost here -- I thought this was a Linux patch set. That probably explains why I can't follow the thread... ;)
Description
Changlogs
Hi Bin,
How should this patch set be proceeded?
To summary the major changes, - I've rebased to mainstream and merged pcie refactoring code which based on pcie_dw_common.c - separate unmatched dts into separated patch.
Thanks, - Green
Description
Changlogs
-- 2.31.0
Hi Green,
On Thu, Apr 29, 2021 at 7:11 PM Green Wan green.wan@sifive.com wrote:
Hi Bin,
I don't have specific comments. Rick should pick this up via the riscv tree. Thanks!
Regards, Bin
Thanks, Bin.
Hi Rick,
Not sure whether you have a chance to pick it up. Or let me know if any part needs change.
Thanks, - Green
On Thu, Apr 29, 2021 at 8:27 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Green,
Hi Bin,
Regards, Bin
Bin Meng
Green Wan
Neil Armstrong
Palmer Dabbelt
