[U-Boot] [PATCH] AT91 Fix: return value of get_tbclk
* Fix: return value of get_tbclk * this fixes issue with prematurely restart/retry, if BOOT_RETRY_TIMEOUT is used
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- cpu/arm926ejs/at91/timer.c | 5 +---- 1 files changed, 1 insertions(+), 4 deletions(-)
diff --git a/cpu/arm926ejs/at91/timer.c b/cpu/arm926ejs/at91/timer.c index d21eebf..8efc34b 100644 --- a/cpu/arm926ejs/at91/timer.c +++ b/cpu/arm926ejs/at91/timer.c @@ -138,8 +138,5 @@ ulong get_timer(ulong base) */ ulong get_tbclk(void) { - ulong tbclk; - - tbclk = CONFIG_SYS_HZ; - return tbclk; + return timer_freq; }
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- the V2 supports the actually file structure. the original patch http://lists.denx.de/pipermail/u-boot/2010-April/069415.html use the old directory /cpu/arch structure.
arch/arm/cpu/arm920t/at91/timer.c | 2 +- arch/arm/cpu/arm920t/at91rm9200/timer.c | 5 +---- arch/arm/cpu/arm926ejs/at91/timer.c | 5 +---- 3 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/arm920t/at91/timer.c b/arch/arm/cpu/arm920t/at91/timer.c index 91377d4..1c20857 100644 --- a/arch/arm/cpu/arm920t/at91/timer.c +++ b/arch/arm/cpu/arm920t/at91/timer.c @@ -159,5 +159,5 @@ unsigned long long get_ticks(void) */ ulong get_tbclk(void) { - return CONFIG_SYS_HZ; + return timer_freq; } diff --git a/arch/arm/cpu/arm920t/at91rm9200/timer.c b/arch/arm/cpu/arm920t/at91rm9200/timer.c index 9c54bbe..8db7e76 100644 --- a/arch/arm/cpu/arm920t/at91rm9200/timer.c +++ b/arch/arm/cpu/arm920t/at91rm9200/timer.c @@ -153,8 +153,5 @@ unsigned long long get_ticks(void) */ ulong get_tbclk (void) { - ulong tbclk; - - tbclk = CONFIG_SYS_HZ; - return tbclk; + return timer_freq; } diff --git a/arch/arm/cpu/arm926ejs/at91/timer.c b/arch/arm/cpu/arm926ejs/at91/timer.c index d21eebf..8efc34b 100644 --- a/arch/arm/cpu/arm926ejs/at91/timer.c +++ b/arch/arm/cpu/arm926ejs/at91/timer.c @@ -138,8 +138,5 @@ ulong get_timer(ulong base) */ ulong get_tbclk(void) { - ulong tbclk; - - tbclk = CONFIG_SYS_HZ; - return tbclk; + return timer_freq; }
Sorry I have attach the wrong patch file I ll resend the right as V3
regards Jens
Jens Scharsig
