[U-Boot] [PATCH 0/3] Enable eMMC on mx6qsabresd board
The series is to enable the use of eMMC on mx6qsabresd board, so that we do not need to carry an external card to boot the board. The DDR mode support for eMMC is not included.
Shawn Guo (3): fsl_esdhc: add MMC_MODE_HC host_caps mx6qsabresd: add usdhc2 and usdhc4 support mx6qsabresd: use on-board eMMC to store environment
board/freescale/mx6qsabresd/mx6qsabresd.c | 80 ++++++++++++++++++++++++++--- drivers/mmc/fsl_esdhc.c | 3 +- include/configs/mx6qsabre_common.h | 2 - include/configs/mx6qsabreauto.h | 5 ++ include/configs/mx6qsabresd.h | 6 +++ 5 files changed, 87 insertions(+), 9 deletions(-)
All esdhc variants we know should support high capacity MMC cards, so let's add MMC_MODE_HC host_caps unconditionally to support those MMC cards (capacity > 2 GB).
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- drivers/mmc/fsl_esdhc.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index e93e38a..29f3122 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -262,6 +262,7 @@ static void check_and_invalidate_dcache_range unsigned end = start+size ; invalidate_dcache_range(start, end); } + /* * Sends a command out on the bus. Takes the mmc pointer, * a command pointer, and an optional data pointer. @@ -577,7 +578,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) return -1; }
- mmc->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; + mmc->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT | MMC_MODE_HC;
if (caps & ESDHC_HOSTCAPBLT_HSS) mmc->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
This is an accident coding style cleanup which I forgot recovering. Hope maintainer is fine with it, otherwise I can resend the patch to keep it unchanged.
Shawn
- Sends a command out on the bus. Takes the mmc pointer,
- a command pointer, and an optional data pointer.
-- 1.7.9.5
I drop myself this from the commit.
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
The on-board number of available usdhc devices is something board specific. The patch moves CONFIG_SYS_FSL_USDHC_NUM out of mx6qsabre_common.h and adds usdhc2 and usdhc4 support for mx6qsabresd board.
To keep the default mmc device for environment same as before (usdhc3), it moves CONFIG_SYS_MMC_ENV_DEV out of mx6qsabre_common.h and changes it to 1 for mx6qsabresd.
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- board/freescale/mx6qsabresd/mx6qsabresd.c | 80 ++++++++++++++++++++++++++--- include/configs/mx6qsabre_common.h | 2 - include/configs/mx6qsabreauto.h | 5 ++ include/configs/mx6qsabresd.h | 5 ++ 4 files changed, 84 insertions(+), 8 deletions(-)
diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6qsabresd/mx6qsabresd.c index 0240fb5..65c4a1a 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6qsabresd/mx6qsabresd.c @@ -86,6 +86,20 @@ static void setup_iomux_enet(void) gpio_set_value(IMX_GPIO_NR(1, 25), 1); }
+iomux_v3_cfg_t const usdhc2_pads[] = { + MX6Q_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_NANDF_D4__USDHC2_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_NANDF_D5__USDHC2_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_NANDF_D6__USDHC2_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_NANDF_D7__USDHC2_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + iomux_v3_cfg_t const usdhc3_pads[] = { MX6Q_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6Q_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -100,28 +114,82 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6Q_PAD_NANDF_D0__GPIO_2_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
+iomux_v3_cfg_t const usdhc4_pads[] = { + MX6Q_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT4__USDHC4_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT5__USDHC4_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT6__USDHC4_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6Q_PAD_SD4_DAT7__USDHC4_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
#ifdef CONFIG_FSL_ESDHC -struct fsl_esdhc_cfg usdhc_cfg[1] = { +struct fsl_esdhc_cfg usdhc_cfg[3] = { + {USDHC2_BASE_ADDR}, {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, };
+#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 2) +#define USDHC3_CD_GPIO IMX_GPIO_NR(2, 0) + int board_mmc_getcd(struct mmc *mmc) { - gpio_direction_input(IMX_GPIO_NR(2, 0)); - return !gpio_get_value(IMX_GPIO_NR(2, 0)); + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + return !gpio_get_value(USDHC2_CD_GPIO); + case USDHC3_BASE_ADDR: + return !gpio_get_value(USDHC3_CD_GPIO); + default: + return 1; /* eMMC/uSDHC4 is always present */ + } }
int board_mmc_init(bd_t *bis) { - imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + int i; + + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + gpio_direction_input(USDHC2_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + gpio_direction_input(USDHC3_CD_GPIO); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + break; + case 2: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + usdhc_cfg[2].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + + if (fsl_esdhc_initialize(bis, &usdhc_cfg[i])) + printf("Warning: failed to initialize mmc dev %d\n", i); + }
- usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); + return 0; } #endif
diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6qsabre_common.h index 9a25480..bd2fb10 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6qsabre_common.h @@ -41,7 +41,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define CONFIG_SYS_FSL_USDHC_NUM 2
#define CONFIG_MMC #define CONFIG_CMD_MMC @@ -166,7 +165,6 @@
#if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_SYS_MMC_ENV_DEV 0 #endif
#define CONFIG_OF_LIBFDT diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 760f3ce..f1ff201 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -20,4 +20,9 @@
#include "mx6qsabre_common.h"
+#define CONFIG_SYS_FSL_USDHC_NUM 2 +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + #endif /* __MX6QSABREAUTO_CONFIG_H */ diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index 771d129..227d410 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -25,4 +25,9 @@
+#define CONFIG_SYS_FSL_USDHC_NUM 3 +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_SYS_MMC_ENV_DEV 1 +#endif + #endif /* __MX6QSABRESD_CONFIG_H */
It makes more sense to use on-board eMMC to store environments. The boot partition 1 is selected by default.
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- include/configs/mx6qsabresd.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index 227d410..a1d9285 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -27,7 +27,8 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_SYS_MMC_ENV_DEV 1 +#define CONFIG_SYS_MMC_ENV_DEV 2 /* eMMC/uSDHC4 */ +#define CONFIG_SYS_MMC_ENV_PART 1 /* Boot partition 1 */ #endif
Forgot adding [U-Boot] prefix for these patches. Will do next time.
Shawn
-- 1.7.9.5
No need to add [U-Boot] prefix. This gets added by the mailing list.
Regards,
Fabio Estevam
Hi Shawn,
Never mind - and nobody adds [U-Boot] to a patch. I think it is added automatically by the mailing list server.
Fabio Estevam
Shawn Guo
Stefano Babic
