[U-Boot] [PATCH 1/4] ppc/km/tegr1: support second localbus clock signal
On kmtegr1 we have to specify the second localbus clock signal also instead of using the default for our ppc 8309 boards.
Signed-off-by: Holger Brunck holger.brunck@ch.abb.com CC: Priyanka Jain priyanka.jain@nxp.com CC: Valentin Longchamp valentin.longchamp@ch.abb.com --- include/configs/km/km-mpc8309.h | 2 ++ include/configs/kmtegr1.h | 17 +++++++++++++++++ 2 files changed, 19 insertions(+)
diff --git a/include/configs/km/km-mpc8309.h b/include/configs/km/km-mpc8309.h index 9aaea273e0..e710c04493 100644 --- a/include/configs/km/km-mpc8309.h +++ b/include/configs/km/km-mpc8309.h @@ -22,6 +22,7 @@ * System IO Config */ /* 0x14000180 SICR_1 */ +#ifndef CONFIG_SYS_SICRL #define CONFIG_SYS_SICRL (0 \ | SICR_1_UART1_UART1RTS \ | SICR_1_I2C_CKSTOP \ @@ -38,6 +39,7 @@ | SICR_1_FEC1_FEC1 \ | SICR_1_FEC2_FEC2 \ ) +#endif
/* 0x00080400 SICR_2 */ #define CONFIG_SYS_SICRH (0 \ diff --git a/include/configs/kmtegr1.h b/include/configs/kmtegr1.h index e627606222..a441fca121 100644 --- a/include/configs/kmtegr1.h +++ b/include/configs/kmtegr1.h @@ -30,6 +30,23 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define NAND_MAX_CHIPS 1
+#define CONFIG_SYS_SICRL (0 \ + | SICR_1_UART1_UART1RTS \ + | SICR_1_I2C_CKSTOP \ + | SICR_1_IRQ_A_IRQ \ + | SICR_1_IRQ_B_IRQ \ + | SICR_1_GPIO_A_GPIO \ + | SICR_1_GPIO_B_GPIO \ + | SICR_1_GPIO_C_GPIO \ + | SICR_1_GPIO_D_GPIO \ + | SICR_1_GPIO_E_LCS \ + | SICR_1_GPIO_F_GPIO \ + | SICR_1_USB_A_UART2S \ + | SICR_1_USB_B_UART2RTS \ + | SICR_1_FEC1_FEC1 \ + | SICR_1_FEC2_FEC2 \ + ) + /* include common defines/options for all Keymile boards */ #include "km/keymile-common.h" #include "km/km-powerpc.h"
Remove this from the board header files and move it to Kconfig. Also use the correct default address for kmtegr1.
Signed-off-by: Holger Brunck holger.brunck@ch.abb.com CC: Priyanka Jain priyanka.jain@nxp.com CC: Valentin Longchamp valentin.longchamp@ch.abb.com --- board/keymile/Kconfig | 6 ++++++ configs/kmcoge5ne_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmtegr1_defconfig | 1 + include/configs/km/keymile-common.h | 7 +------ include/configs/kmcoge5ne.h | 1 - include/configs/kmeter1.h | 1 - include/configs/kmp204x.h | 2 -- scripts/config_whitelist.txt | 1 - 9 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/board/keymile/Kconfig b/board/keymile/Kconfig index ba1960f3d0..634dbbe097 100644 --- a/board/keymile/Kconfig +++ b/board/keymile/Kconfig @@ -62,6 +62,12 @@ config KM_CONSOLE_TTY help TTY console to use on board.
+config KM_DEF_NETDEV + string "Default Netdevice" + default "eth0" + help + Default netdevice for debug interface + config KM_COMMON_ETH_INIT bool "Common Ethernet Initialization" default y if KIRKWOOD || MPC83xx diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 472dc88fbf..aa2a344d3d 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_KM_DEF_NETDEV="eth1" CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 CONFIG_ENV_SECT_SIZE=0x20000 diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 02b17ed624..7e9b8930a9 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_KM_DEF_NETDEV="eth2" CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 CONFIG_ENV_SECT_SIZE=0x20000 diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index 27a58833f8..f194d605f6 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_KM_DEF_NETDEV="eth1" CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_ENV_SECT_SIZE=0x20000 diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 8433d8e568..e690d8f39d 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -38,11 +38,6 @@ "actual_bank=0\0" #endif
-#ifndef CONFIG_KM_DEF_NETDEV -#define CONFIG_KM_DEF_NETDEV \ - "netdev=eth0\0" -#endif - #ifndef CONFIG_KM_UBI_PARTITION_NAME_BOOT #define CONFIG_KM_UBI_PARTITION_NAME_BOOT "ubi0" #endif /* CONFIG_KM_UBI_PARTITION_NAME_BOOT */ @@ -168,7 +163,7 @@ #ifndef CONFIG_KM_DEF_ENV #define CONFIG_KM_DEF_ENV \ CONFIG_KM_DEF_ENV_BOOTPARAMS \ - CONFIG_KM_DEF_NETDEV \ + "netdev=" __stringify(CONFIG_KM_DEF_NETDEV) "\0" \ CONFIG_KM_DEF_ENV_CPU \ CONFIG_KM_DEF_ENV_BOOTTARGETS \ CONFIG_KM_DEF_ENV_BOOTARGS \ diff --git a/include/configs/kmcoge5ne.h b/include/configs/kmcoge5ne.h index fc78b27cbb..5335034505 100644 --- a/include/configs/kmcoge5ne.h +++ b/include/configs/kmcoge5ne.h @@ -10,7 +10,6 @@
#define CONFIG_HOSTNAME "kmcoge5ne" #define CONFIG_KM_BOARD_NAME "kmcoge5ne" -#define CONFIG_KM_DEF_NETDEV "netdev=eth1\0" #define CONFIG_NAND_ECC_BCH #define CONFIG_NAND_KMETER1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index bfa7ca27c7..7d85a02c68 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -10,7 +10,6 @@
#define CONFIG_HOSTNAME "kmeter1" #define CONFIG_KM_BOARD_NAME "kmeter1" -#define CONFIG_KM_DEF_NETDEV "netdev=eth2\0"
/* include common defines/options for all Keymile boards */ #include "km/keymile-common.h" diff --git a/include/configs/kmp204x.h b/include/configs/kmp204x.h index 771d0248f7..9c17044b9b 100644 --- a/include/configs/kmp204x.h +++ b/include/configs/kmp204x.h @@ -17,8 +17,6 @@
#define CONFIG_KMP204X
-#define CONFIG_KM_DEF_NETDEV "netdev=eth0\0" - /* an additionnal option is required for UBI as subpage access is * supported in u-boot */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 08fab0aebf..6413d1f5ac 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -939,7 +939,6 @@ CONFIG_KM_DEF_ENV_BOOTTARGETS CONFIG_KM_DEF_ENV_CONSTANTS CONFIG_KM_DEF_ENV_CPU CONFIG_KM_DEF_ENV_FLASH_BOOT -CONFIG_KM_DEF_NETDEV CONFIG_KM_DEV_ENV_FLASH_BOOT_UBI CONFIG_KM_DISABLE_PCIE CONFIG_KM_ECC_MODE
We can use the existing CONFIG_SYS_CONFIG_NAME define for that and remove the option. Also fix the boot string for all km83xx boards.
Signed-off-by: Holger Brunck holger.brunck@ch.abb.com CC: Priyanka Jain priyanka.jain@nxp.com CC: Valentin Longchamp valentin.longchamp@ch.abb.com --- board/keymile/km83xx/km83xx.c | 2 +- board/keymile/kmp204x/kmp204x.c | 2 +- include/configs/kmcoge5ne.h | 1 - include/configs/kmeter1.h | 1 - include/configs/kmopti2.h | 1 - include/configs/kmp204x.h | 1 - include/configs/kmsupx5.h | 1 - include/configs/kmtegr1.h | 1 - include/configs/kmtepr2.h | 1 - include/configs/suvd3.h | 1 - include/configs/tuge1.h | 1 - include/configs/tuxx1.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 59347a3990..b17d60f9ff 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -277,7 +277,7 @@ int dram_init(void)
int checkboard(void) { - puts("Board: Keymile " CONFIG_KM_BOARD_NAME); + puts("Board: ABB " CONFIG_SYS_CONFIG_NAME);
if (piggy_present()) puts(" with PIGGY."); diff --git a/board/keymile/kmp204x/kmp204x.c b/board/keymile/kmp204x/kmp204x.c index e7c321c326..76382dbc30 100644 --- a/board/keymile/kmp204x/kmp204x.c +++ b/board/keymile/kmp204x/kmp204x.c @@ -28,7 +28,7 @@ static uchar ivm_content[CONFIG_SYS_IVM_EEPROM_MAX_LEN];
int checkboard(void) { - printf("Board: Keymile %s\n", CONFIG_KM_BOARD_NAME); + printf("Board: Keymile %s\n", CONFIG_SYS_CONFIG_NAME);
return 0; } diff --git a/include/configs/kmcoge5ne.h b/include/configs/kmcoge5ne.h index 5335034505..cdfb280aee 100644 --- a/include/configs/kmcoge5ne.h +++ b/include/configs/kmcoge5ne.h @@ -9,7 +9,6 @@ #define __CONFIG_H
#define CONFIG_HOSTNAME "kmcoge5ne" -#define CONFIG_KM_BOARD_NAME "kmcoge5ne" #define CONFIG_NAND_ECC_BCH #define CONFIG_NAND_KMETER1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 7d85a02c68..4129d97505 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -9,7 +9,6 @@ #define __CONFIG_H
#define CONFIG_HOSTNAME "kmeter1" -#define CONFIG_KM_BOARD_NAME "kmeter1"
/* include common defines/options for all Keymile boards */ #include "km/keymile-common.h" diff --git a/include/configs/kmopti2.h b/include/configs/kmopti2.h index 67e864fc98..5050c70303 100644 --- a/include/configs/kmopti2.h +++ b/include/configs/kmopti2.h @@ -23,7 +23,6 @@ /* * High Level Configuration Options */ -#define CONFIG_KM_BOARD_NAME "kmopti2" #define CONFIG_HOSTNAME "kmopti2"
/* include common defines/options for all Keymile boards */ diff --git a/include/configs/kmp204x.h b/include/configs/kmp204x.h index 9c17044b9b..6cee3b47b3 100644 --- a/include/configs/kmp204x.h +++ b/include/configs/kmp204x.h @@ -9,7 +9,6 @@
#if defined(CONFIG_KMCOGE4) #define CONFIG_HOSTNAME "kmcoge4" -#define CONFIG_KM_BOARD_NAME "kmcoge4"
#else #error ("Board not supported") diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index ba33e6074b..e3de6c61e7 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -23,7 +23,6 @@ /* * High Level Configuration Options */ -#define CONFIG_KM_BOARD_NAME "kmsupx5" #define CONFIG_HOSTNAME "kmsupx5"
/* include common defines/options for all Keymile boards */ diff --git a/include/configs/kmtegr1.h b/include/configs/kmtegr1.h index a441fca121..bdd35cc7fb 100644 --- a/include/configs/kmtegr1.h +++ b/include/configs/kmtegr1.h @@ -21,7 +21,6 @@ */
#define CONFIG_HOSTNAME "kmtegr1" -#define CONFIG_KM_BOARD_NAME "kmtegr1" #define CONFIG_KM_UBI_PARTITION_NAME_BOOT "ubi0" #define CONFIG_KM_UBI_PARTITION_NAME_APP "ubi1"
diff --git a/include/configs/kmtepr2.h b/include/configs/kmtepr2.h index e0c907d11a..a4ceb1c50d 100644 --- a/include/configs/kmtepr2.h +++ b/include/configs/kmtepr2.h @@ -23,7 +23,6 @@ /* * High Level Configuration Options */ -#define CONFIG_KM_BOARD_NAME "kmtepr2" #define CONFIG_HOSTNAME "kmtepr2"
/* include common defines/options for all Keymile boards */ diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 1705f9cafb..d74707971b 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -21,7 +21,6 @@ */
#define CONFIG_HOSTNAME "suvd3" -#define CONFIG_KM_BOARD_NAME "suvd3"
/* include common defines/options for all Keymile boards */ #include "km/keymile-common.h" diff --git a/include/configs/tuge1.h b/include/configs/tuge1.h index 808538ef9d..d43ccbe8dd 100644 --- a/include/configs/tuge1.h +++ b/include/configs/tuge1.h @@ -23,7 +23,6 @@ /* * High Level Configuration Options */ -#define CONFIG_KM_BOARD_NAME "tuge1" #define CONFIG_HOSTNAME "tuge1"
/* include common defines/options for all Keymile boards */ diff --git a/include/configs/tuxx1.h b/include/configs/tuxx1.h index 0eb673a947..f5a9f1284a 100644 --- a/include/configs/tuxx1.h +++ b/include/configs/tuxx1.h @@ -23,7 +23,6 @@ /* * High Level Configuration Options */ -#define CONFIG_KM_BOARD_NAME "tuxx1" #define CONFIG_HOSTNAME "tuxx1"
/* include common defines/options for all Keymile boards */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 6413d1f5ac..e84a563c28 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -928,7 +928,6 @@ CONFIG_KMCOGE4 CONFIG_KMP204X CONFIG_KMTEGR1 CONFIG_KM_BOARD_EXTRA_ENV -CONFIG_KM_BOARD_NAME CONFIG_KM_COGE5UN CONFIG_KM_DEF_ARCH CONFIG_KM_DEF_BOOT_ARGS_CPU
CONFIG_CONS_INDEX is nowhere used for this board, we can drop it.
Signed-off-by: Holger Brunck holger.brunck@ch.abb.com CC: Priyanka Jain priyanka.jain@nxp.com CC: Valentin Longchamp valentin.longchamp@ch.abb.com --- include/configs/kmeter1.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 4129d97505..4245875e39 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -16,11 +16,6 @@ #include "km/km-mpc83xx.h" #include "km/km-mpc8360.h"
-/* - * Serial Port - */ -#define CONFIG_CONS_INDEX 1 - #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_AP | \ CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10 | \
-----Original Message----- From: Holger Brunck holger.brunck@ch.abb.com Sent: Tuesday, November 26, 2019 11:39 PM To: u-boot@lists.denx.de Cc: Holger Brunck holger.brunck@ch.abb.com; Priyanka Jain priyanka.jain@nxp.com; Valentin Longchamp valentin.longchamp@ch.abb.com Subject: [PATCH 1/4] ppc/km/tegr1: support second localbus clock signal
diff --git a/include/configs/km/km-mpc8309.h b/include/configs/km/km- mpc8309.h index 9aaea273e0..e710c04493 100644 --- a/include/configs/km/km-mpc8309.h +++ b/include/configs/km/km-mpc8309.h @@ -22,6 +22,7 @@
- System IO Config
| SICR_1_I2C_CKSTOP \
| SICR_1_IRQ_A_IRQ \
| SICR_1_IRQ_B_IRQ \
| SICR_1_GPIO_E_LCS \
| SICR_1_FEC1_FEC1 \
| SICR_1_FEC2_FEC2 \
2.24.0.rc1
Series applied on u-boot-mpc85xx. Awaiting upstream Thanks Priyanka
Holger Brunck
Priyanka Jain
