[U-Boot-Users] A couple of newbie questions.
Hi all u-boot users
1) I have a question about how to build a u-boot image that will be downloaded to flash memory. I am running a OKI67ML5001 CPU with ARM7TDMI core. I will save the u-boot image to flash and when starting up reallocate the u-boot code to SDRAM. How do I configure it ? I have tried with changning TEXT_BASE parameter, but in that case the whole mapping was moved to the new address. I am looking for one copy to SDRAM address and one flash address to store the u-boot.
2) My ARM7TDMI CPU have also possibillity to change mapping in run-time. Is there any support in u-boot for remapping in run-time ?
3) The parameters that I can store in flash with the u-boot (ENV_) can uClinux read and use them ? Or has Linux own parameter ?
4) How do I config a filesystem to be used with u-boot ? I have seen something about a romfs or jffs2 filesystem. Can I store uClinux images in a filesystem that u-boot can read and download to SDRAM and start. Can you give me more information here !
Thanks in advance.
Have a nice day.
/Anders
Anders Öhlander
