[U-Boot] [RESEND PATCH v14 00/10] arm64 pat
The content is same with original v14. 04/05/06 patches is totally provided by scott wood. Them are mistakenly encoded "From: David Feng", so modify its to "From: Scott Wood".
Changes for v14: - Merge rela relocation patches from Scott Wood scottwood@freescale.com. - Remove all CONFIG_NEED_MANUAL_RELOC and other fixups due to manual relocation. With rela relocation patches them are not needed. - Fix the bug of MEMORY_ATTRIBUTES definition due to assembler. That need put brackets around (MT_NORMAL*8). Otherwise the result is wrong.This bug is reported by York Sun yorksun@freescale.com. - -msoft-float is not supported by aarch64-gcc, make a test though $(call cc-option,-msoft-float). - Adjust the virtual address space to 42 bits. - Filter armv8 boards from LIST_arm in MAKEALL. - remove gpio.h in asm/arch-armv8/ and move mmu.h to asm/armv8/ directory. - remove vexpress64.dts from this patch, it could be accessed from linux kernel.
Changes for v13: - fix the bug of board_r.c and arm/lib/board.c due to CONFIG_NEED_MANUAL_RELOC. adjust initr_serial() in board_r.c to the first entry of init_sequence_r[] and relocate serial_initialize() in arm/lib/board.c, routines of serial_device should be relocated firstly by serial_initialize(), so that printf access the correct puts function, otherwise uninitialized serial_current will be selected as the output device. - fix the bug of dcache_enable(). after mmu_setup the sctrl register value should be fetched again because it has been modifed by mmu_seup() function. This bug is reported by York Sun yorksun@freescale.com. - add macro branch_if_slave to macro.h, it choose processor with all zero affinity value as the master and is used in start.S.
Changes for v12: - custom the patches to new format boards.cfg.
Changes for v11: - Replace CONFIG_ARMV8 with CONFIG_ARM64. Currently, it's hard to distinguish what is armv8 specific and what is aarch64 specific, so we use CONFIG_ARM64 only, no CONFIG_ARMV8 used. - rename README.armv8 with README.arm64 and make some modification.
Changes for v10: - add weak definition to include/linux/linkage.h and make setup_el2/setup_el3/lowlevel_init weak routines, so them can be easily overridden by processor specific code. - modify s-o-f of 0002-board-support-of-vexpress_aemv8a which use wrong mail address of Bhupesh Sharma.
Changes for v9: - add Signed-off-by information to patch "board support of vexpress_aemv8a" which SMC91111 support is integrated from Sharma Bhupesh's patch. - adjust pt_regs struct and add exception state preservation in exception.S.
Changes for v8: - Integrate SMC91111 patch of sharma bhupesh. - remove v8_outer_cache* which is not need currently. - Change license tag. - Mov crt0.S/relocate.S/interrupts.c to arm/lib and rename them with _64 suffix. - Make el3/el2 initializing process of start.S as two separate routines. It could be easier to be replaced with processor specific codes. - Remove exception stack save and restore routine, it is unnecessary now. - simplify __weak function declaration.
Changes for v7: - Check the patches with checkpatch.pl and get rid of almost all warnings. There are a few warnings still, but I think it should be that. - change printf format in cmd_pxe.c, use %zd indtead of %ld to format size_t type variable. - add macro PGTABLE_SIZE to identify tlb table size.
Changes for v6: - Make modification to inappropriate licensed file and bugs according to ScottWood's advice. Thanks Scott for his checking to these patches. - Enable u-boot's running at EL1. - Get rid of compiling warnings originated from cmd_pxe.c.
Changes for v5: - fix the generic board_f.c, remove zero_global_data from init_sequence_f array and move it to board_init_f() function with CONFIG_X86 switch. The previous fixup is inaccurate. - Replace __ARMEB__ with __AARCH64EB__ in byteorder.h and unaligned.h, gcc for aarch64 use __AARCH64EB__ and __AARCH64EL__ to identify endian. - Some modification to README.armv8
Changes for v4: - merge arm64 to arm architecture.
David Feng (10): fdt_support: 64bit initrd start address support cmd_pxe.c: remove compiling warnings add weak entry definition arm64: Add tool to statically apply RELA relocations arm64: Turn u-boot.bin back into an ELF file after relocate-rela arm64: Make checkarmreloc accept arm64 relocations arm64: core support arm64: generic board support arm64: board support of vexpress_aemv8a arm64: MAKEALL, filter armv8 boards from LIST_arm
MAKEALL | 13 +- Makefile | 39 +++++- arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Makefile | 38 +++++ arch/arm/cpu/armv8/cache.S | 130 +++++++++++++++++ arch/arm/cpu/armv8/cache_v8.c | 218 ++++++++++++++++++++++++++++ arch/arm/cpu/armv8/config.mk | 15 ++ arch/arm/cpu/armv8/cpu.c | 67 +++++++++ arch/arm/cpu/armv8/exceptions.S | 112 +++++++++++++++ arch/arm/cpu/armv8/start.S | 234 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv8/timer.c | 80 +++++++++++ arch/arm/cpu/armv8/tlb.S | 30 ++++ arch/arm/cpu/armv8/u-boot.lds | 89 ++++++++++++ arch/arm/include/asm/armv8/mmu.h | 110 +++++++++++++++ arch/arm/include/asm/byteorder.h | 12 ++ arch/arm/include/asm/cache.h | 5 + arch/arm/include/asm/config.h | 6 + arch/arm/include/asm/global_data.h | 6 +- arch/arm/include/asm/io.h | 15 +- arch/arm/include/asm/macro.h | 36 +++++ arch/arm/include/asm/posix_types.h | 10 ++ arch/arm/include/asm/proc-armv/ptrace.h | 21 +++ arch/arm/include/asm/proc-armv/system.h | 59 +++++++- arch/arm/include/asm/system.h | 77 ++++++++++ arch/arm/include/asm/types.h | 4 + arch/arm/include/asm/u-boot.h | 4 + arch/arm/include/asm/unaligned.h | 2 +- arch/arm/lib/Makefile | 14 ++ arch/arm/lib/board.c | 7 +- arch/arm/lib/bootm.c | 16 +++ arch/arm/lib/crt0_64.S | 113 +++++++++++++++ arch/arm/lib/interrupts_64.c | 120 ++++++++++++++++ arch/arm/lib/relocate_64.S | 58 ++++++++ board/armltd/vexpress64/Makefile | 27 ++++ board/armltd/vexpress64/vexpress64.c | 50 +++++++ boards.cfg | 1 + common/board_f.c | 20 ++- common/cmd_pxe.c | 4 +- common/fdt_support.c | 66 ++++----- common/image.c | 1 + doc/README.arm64 | 45 ++++++ examples/standalone/stubs.c | 15 ++ include/configs/vexpress_aemv8a.h | 191 +++++++++++++++++++++++++ include/image.h | 1 + include/linux/linkage.h | 4 + tools/Makefile | 6 + tools/relocate-rela.c | 185 ++++++++++++++++++++++++ 47 files changed, 2321 insertions(+), 58 deletions(-) create mode 100644 arch/arm/cpu/armv8/Makefile create mode 100644 arch/arm/cpu/armv8/cache.S create mode 100644 arch/arm/cpu/armv8/cache_v8.c create mode 100644 arch/arm/cpu/armv8/config.mk create mode 100644 arch/arm/cpu/armv8/cpu.c create mode 100644 arch/arm/cpu/armv8/exceptions.S create mode 100644 arch/arm/cpu/armv8/start.S create mode 100644 arch/arm/cpu/armv8/timer.c create mode 100644 arch/arm/cpu/armv8/tlb.S create mode 100644 arch/arm/cpu/armv8/u-boot.lds create mode 100644 arch/arm/include/asm/armv8/mmu.h create mode 100644 arch/arm/lib/crt0_64.S create mode 100644 arch/arm/lib/interrupts_64.c create mode 100644 arch/arm/lib/relocate_64.S create mode 100644 board/armltd/vexpress64/Makefile create mode 100644 board/armltd/vexpress64/vexpress64.c create mode 100644 doc/README.arm64 create mode 100644 include/configs/vexpress_aemv8a.h create mode 100644 tools/relocate-rela.c
Signed-off-by: David Feng fenghua@phytium.com.cn --- common/fdt_support.c | 66 ++++++++++++++++++++++++++------------------------ 1 file changed, 34 insertions(+), 32 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index b034c98..9bc5821 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -21,6 +21,34 @@ */ DECLARE_GLOBAL_DATA_PTR;
+/* + * Get cells len in bytes + * if #NNNN-cells property is 2 then len is 8 + * otherwise len is 4 + */ +static int get_cells_len(void *blob, char *nr_cells_name) +{ + const fdt32_t *cell; + + cell = fdt_getprop(blob, 0, nr_cells_name, NULL); + if (cell && fdt32_to_cpu(*cell) == 2) + return 8; + + return 4; +} + +/* + * Write a 4 or 8 byte big endian cell + */ +static void write_cell(u8 *addr, u64 val, int size) +{ + int shift = (size - 1) * 8; + while (size-- > 0) { + *addr++ = (val >> shift) & 0xff; + shift -= 8; + } +} + /** * fdt_getprop_u32_default - Find a node and return it's property or a default * @@ -131,9 +159,9 @@ static int fdt_fixup_stdout(void *fdt, int chosenoff)
int fdt_initrd(void *fdt, ulong initrd_start, ulong initrd_end, int force) { - int nodeoffset; + int nodeoffset, addr_cell_len; int err, j, total; - fdt32_t tmp; + fdt64_t tmp; const char *path; uint64_t addr, size;
@@ -170,9 +198,11 @@ int fdt_initrd(void *fdt, ulong initrd_start, ulong initrd_end, int force) return err; }
+ addr_cell_len = get_cells_len(fdt, "#address-cells"); + path = fdt_getprop(fdt, nodeoffset, "linux,initrd-start", NULL); if ((path == NULL) || force) { - tmp = cpu_to_fdt32(initrd_start); + write_cell((u8 *)&tmp, initrd_start, addr_cell_len); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-start", &tmp, sizeof(tmp)); if (err < 0) { @@ -181,7 +211,7 @@ int fdt_initrd(void *fdt, ulong initrd_start, ulong initrd_end, int force) fdt_strerror(err)); return err; } - tmp = cpu_to_fdt32(initrd_end); + write_cell((u8 *)&tmp, initrd_end, addr_cell_len); err = fdt_setprop(fdt, nodeoffset, "linux,initrd-end", &tmp, sizeof(tmp)); if (err < 0) { @@ -343,34 +373,6 @@ void do_fixup_by_compat_u32(void *fdt, const char *compat, do_fixup_by_compat(fdt, compat, prop, &tmp, 4, create); }
-/* - * Get cells len in bytes - * if #NNNN-cells property is 2 then len is 8 - * otherwise len is 4 - */ -static int get_cells_len(void *blob, char *nr_cells_name) -{ - const fdt32_t *cell; - - cell = fdt_getprop(blob, 0, nr_cells_name, NULL); - if (cell && fdt32_to_cpu(*cell) == 2) - return 8; - - return 4; -} - -/* - * Write a 4 or 8 byte big endian cell - */ -static void write_cell(u8 *addr, u64 val, int size) -{ - int shift = (size - 1) * 8; - while (size-- > 0) { - *addr++ = (val >> shift) & 0xff; - shift -= 8; - } -} - #ifdef CONFIG_NR_DRAM_BANKS #define MEMORY_BANKS_MAX CONFIG_NR_DRAM_BANKS #else
Signed-off-by: David Feng fenghua@phytium.com.cn --- common/cmd_pxe.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_pxe.c b/common/cmd_pxe.c index c5f4a22..1df9a8a 100644 --- a/common/cmd_pxe.c +++ b/common/cmd_pxe.c @@ -57,7 +57,7 @@ static int format_mac_pxe(char *outbuf, size_t outbuf_len) uchar ethaddr[6];
if (outbuf_len < 21) { - printf("outbuf is too small (%d < 21)\n", outbuf_len); + printf("outbuf is too small (%zd < 21)\n", outbuf_len);
return -EINVAL; } @@ -100,7 +100,7 @@ static int get_bootfile_path(const char *file_path, char *bootfile_path, path_len = (last_slash - bootfile) + 1;
if (bootfile_path_size < path_len) { - printf("bootfile_path too small. (%d < %d)\n", + printf("bootfile_path too small. (%zd < %zd)\n", bootfile_path_size, path_len);
return -1;
Signed-off-by: David Feng fenghua@phytium.com.cn --- include/linux/linkage.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/linux/linkage.h b/include/linux/linkage.h index 9ddf830..2a2848a 100644 --- a/include/linux/linkage.h +++ b/include/linux/linkage.h @@ -49,6 +49,10 @@ .globl SYMBOL_NAME(name); \ LENTRY(name)
+#define WEAK(name) \ + .weak SYMBOL_NAME(name); \ + LENTRY(name) + #ifndef END #define END(name) \ .size name, .-name
ARM64 uses the newer RELA-style relocations rather than the older REL. RELA relocations have an addend in the relocation struct, rather than expecting the loader to read a value from the location to be updated.
While this is beneficial for ordinary program loading, it's problematic for U-Boot because the location to be updated starts out with zero, rather than a pre-relocation value. Since we need to be able to run C code before relocation, we need a tool to apply the relocations at build time.
In theory this tool is applicable to other newer architectures (mainly 64-bit), but currently the only relocations it supports are for arm64, and it assumes a 64-bit little-endian target. If the latter limitation is ever to be changed, we'll need a way to tell the tool what format the image is in. Eventually this may be replaced by a tool that uses libelf or similar and operates directly on the ELF file. I've written some code for such an approach but libelf does not make it easy to poke addresses by memory address (rather than by section), and I was hesitant to write code to manually parse the program headers and do the update outside of libelf (or to iterate over sections) -- especially since it wouldn't get test coverage on things like binaries with multiple PT_LOAD segments. This should be good enough for now to let the manual relocation stuff be removed from the arm64 patches.
NOTE: Please make sure R_AARCH64_RELATIVE is defined at system include files or manually defined. Otherwise, the rela relocation will not apply.
Signed-off-by: Scott Wood scottwood@freescale.com Signed-off-by: David Feng fenghua@phytium.com.cn --- Makefile | 12 ++++ tools/Makefile | 6 ++ tools/relocate-rela.c | 185 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 203 insertions(+) create mode 100644 tools/relocate-rela.c
diff --git a/Makefile b/Makefile index b09bfcc..5dd28a9 100644 --- a/Makefile +++ b/Makefile @@ -392,6 +392,17 @@ else BOARD_SIZE_CHECK = endif
+# Statically apply RELA-style relocations (currently arm64 only) +ifneq ($(CONFIG_STATIC_RELA),) +# $(1) is u-boot ELF, $(2) is u-boot bin, $(3) is text base +DO_STATIC_RELA = \ + start=$$($(NM) $(1) | grep __rel_dyn_start | cut -f 1 -d ' '); \ + end=$$($(NM) $(1) | grep __rel_dyn_end | cut -f 1 -d ' '); \ + $(obj)tools/relocate-rela $(2) $(3) $$start $$end +else +DO_STATIC_RELA = +endif + # Always append ALL so that arch config.mk's can add custom ones ALL-y += $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map
@@ -431,6 +442,7 @@ $(obj)u-boot.srec: $(obj)u-boot
$(obj)u-boot.bin: $(obj)u-boot $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + $(call DO_STATIC_RELA,$<,$@,$(CONFIG_SYS_TEXT_BASE)) $(BOARD_SIZE_CHECK)
$(obj)u-boot.ldr: $(obj)u-boot diff --git a/tools/Makefile b/tools/Makefile index c36cde2..a5eb85e 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -59,6 +59,7 @@ BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) BIN_FILES-$(CONFIG_KIRKWOOD) += kwboot$(SFX) BIN_FILES-y += proftool(SFX) +BIN_FILES-$(CONFIG_STATIC_RELA) += relocate-rela$(SFX)
# Source files which exist outside the tools directory EXT_OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += common/env_embedded.o @@ -84,6 +85,7 @@ NOPED_OBJ_FILES-y += os_support.o NOPED_OBJ_FILES-y += pblimage.o NOPED_OBJ_FILES-y += proftool.o NOPED_OBJ_FILES-y += ublimage.o +NOPED_OBJ_FILES-y += relocate-rela.o OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc.o OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_CMD_NET) += gen_eth_addr.o @@ -250,6 +252,10 @@ $(obj)kwboot$(SFX): $(obj)kwboot.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@
+$(obj)relocate-rela$(SFX): $(obj)relocate-rela.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(HOSTSTRIP) $@ + # Some of the tool objects need to be accessed from outside the tools directory $(obj)%.o: $(SRCTREE)/common/%.c $(HOSTCC) -g $(HOSTCFLAGS_NOPED) -c -o $@ $< diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c new file mode 100644 index 0000000..47afe0b --- /dev/null +++ b/tools/relocate-rela.c @@ -0,0 +1,185 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause + * + * 64-bit and little-endian target only until we need to support a different + * arch that needs this. + */ + +#include <elf.h> +#include <errno.h> +#include <inttypes.h> +#include <stdarg.h> +#include <stdbool.h> +#include <stdio.h> +#include <stdlib.h> +#include <string.h> + +static const bool debug_en; + +static void debug(const char *fmt, ...) +{ + va_list args; + + va_start(args, fmt); + if (debug_en) + vprintf(fmt, args); +} + +static bool supported_rela(Elf64_Rela *rela) +{ + uint64_t mask = 0xffffffffULL; /* would be different on 32-bit */ + uint32_t type = rela->r_info & mask; + + switch (type) { +#ifdef R_AARCH64_RELATIVE + case R_AARCH64_RELATIVE: + return true; +#endif + default: + fprintf(stderr, "warning: unsupported relocation type %" + PRIu32 " at %" PRIx64 "\n", + type, rela->r_offset); + + return false; + } +} + +static inline uint64_t swap64(uint64_t val) +{ + return ((val >> 56) & 0x00000000000000ffULL) | + ((val >> 40) & 0x000000000000ff00ULL) | + ((val >> 24) & 0x0000000000ff0000ULL) | + ((val >> 8) & 0x00000000ff000000ULL) | + ((val << 8) & 0x000000ff00000000ULL) | + ((val << 24) & 0x0000ff0000000000ULL) | + ((val << 40) & 0x00ff000000000000ULL) | + ((val << 56) & 0xff00000000000000ULL); +} + +#if __BYTE_ORDER == __LITTLE_ENDIAN +static inline uint64_t be64(uint64_t val) +{ + return swap64(val); +} + +static inline uint64_t le64(uint64_t val) +{ + return val; +} +#else +static inline uint64_t le64(uint64_t val) +{ + return swap64(val); +} + +static inline uint64_t be64(uint64_t val) +{ + return val; +} +#endif + +static bool read_num(const char *str, uint64_t *num) +{ + char *endptr; + *num = strtoull(str, &endptr, 16); + return str[0] && !endptr[0]; +} + +int main(int argc, char **argv) +{ + FILE *f; + int i, num; + uint64_t rela_start, rela_end, text_base; + + if (argc != 5) { + fprintf(stderr, "Statically apply ELF rela relocations\n"); + fprintf(stderr, "Usage: %s <bin file> <text base> <rela start> <rela end>\n", + argv[0]); + fprintf(stderr, "All numbers in hex.\n"); + return 1; + } + + f = fopen(argv[1], "r+b"); + if (!f) { + fprintf(stderr, "%s: Cannot open %s: %s\n", + argv[0], argv[1], strerror(errno)); + return 2; + } + + if (!read_num(argv[2], &text_base) || + !read_num(argv[3], &rela_start) || + !read_num(argv[4], &rela_end)) { + fprintf(stderr, "%s: bad number\n", argv[0]); + return 3; + } + + if (rela_start > rela_end || rela_start < text_base || + (rela_end - rela_start) % 24) { + fprintf(stderr, "%s: bad rela bounds\n", argv[0]); + return 3; + } + + rela_start -= text_base; + rela_end -= text_base; + + num = (rela_end - rela_start) / sizeof(Elf64_Rela); + + for (i = 0; i < num; i++) { + Elf64_Rela rela, swrela; + uint64_t pos = rela_start + sizeof(Elf64_Rela) * i; + uint64_t addr; + + if (fseek(f, pos, SEEK_SET) < 0) { + fprintf(stderr, "%s: %s: seek to %" PRIx64 + " failed: %s\n", + argv[0], argv[1], pos, strerror(errno)); + } + + if (fread(&rela, sizeof(rela), 1, f) != 1) { + fprintf(stderr, "%s: %s: read rela failed at %" + PRIx64 "\n", + argv[0], argv[1], pos); + return 4; + } + + swrela.r_offset = le64(rela.r_offset); + swrela.r_info = le64(rela.r_info); + swrela.r_addend = le64(rela.r_addend); + + if (!supported_rela(&swrela)) + continue; + + debug("Rela %" PRIx64 " %" PRIu64 " %" PRIx64 "\n", + swrela.r_offset, swrela.r_info, swrela.r_addend); + + if (swrela.r_offset < text_base) { + fprintf(stderr, "%s: %s: bad rela at %" PRIx64 "\n", + argv[0], argv[1], pos); + return 4; + } + + addr = swrela.r_offset - text_base; + + if (fseek(f, addr, SEEK_SET) < 0) { + fprintf(stderr, "%s: %s: seek to %" + PRIx64 " failed: %s\n", + argv[0], argv[1], addr, strerror(errno)); + } + + if (fwrite(&rela.r_addend, sizeof(rela.r_addend), 1, f) != 1) { + fprintf(stderr, "%s: %s: write failed at %" PRIx64 "\n", + argv[0], argv[1], addr); + return 4; + } + } + + if (fclose(f) < 0) { + fprintf(stderr, "%s: %s: close failed: %s\n", + argv[0], argv[1], strerror(errno)); + return 4; + } + + return 0; +}
While performing relocations on u-boot.bin should be good enough for booting on real hardware, some simulators insist on booting an ELF file (and yet don't perform ELF relocations), so convert the relocated binary back into an ELF file. This can go away in the future if we change relocate-rela to operate directly on the ELF file, or if and when we stop caring about a simulator with this restriction.
Signed-off-by: Scott Wood scottwood@freescale.com Signed-off-by: David Feng fenghua@phytium.com.cn --- Makefile | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/Makefile b/Makefile index 5dd28a9..86464c9 100644 --- a/Makefile +++ b/Makefile @@ -415,6 +415,7 @@ ALL-$(CONFIG_OF_SEPARATE) += $(obj)u-boot.dtb $(obj)u-boot-dtb.bin ifneq ($(CONFIG_SPL_TARGET),) ALL-$(CONFIG_SPL) += $(obj)$(subst ",,$(CONFIG_SPL_TARGET)) endif +ALL-$(CONFIG_REMAKE_ELF) += $(obj)u-boot.elf
# enable combined SPL/u-boot/dtb rules for tegra ifneq ($(CONFIG_TEGRA),) @@ -581,6 +582,18 @@ $(obj)u-boot-img-spl-at-end.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img conv=notrunc 2>/dev/null cat $(obj)u-boot-pad.img $(obj)spl/u-boot-spl.bin > $@
+# Create a new ELF from a raw binary file. This is useful for arm64 +# where static relocation needs to be performed on the raw binary, +# but certain simulators only accept an ELF file (but don't do the +# relocation). +# FIXME refactor dts/Makefile to share target/arch detection +$(obj)u-boot.elf: $(obj)u-boot.bin + @$(OBJCOPY) -B aarch64 -I binary -O elf64-littleaarch64 \ + $< $(obj)u-boot-elf.o + @$(LD) $(obj)u-boot-elf.o -o $@ \ + --defsym=_start=$(CONFIG_SYS_TEXT_BASE) \ + -Ttext=$(CONFIG_SYS_TEXT_BASE) + ifeq ($(CONFIG_SANDBOX),y) GEN_UBOOT = \ cd $(LNDIR) && $(CC) $(SYMS) -T $(obj)u-boot.lds \
Signed-off-by: Scott Wood scottwood@freescale.com Signed-off-by: David Feng fenghua@phytium.com.cn --- Makefile | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index 86464c9..edf52f2 100644 --- a/Makefile +++ b/Makefile @@ -805,12 +805,16 @@ tools: $(VERSION_FILE) $(TIMESTAMP_FILE) $(MAKE) -C $@ all endif # config.mk
-# ARM relocations should all be R_ARM_RELATIVE. +# ARM relocations should all be R_ARM_RELATIVE (32-bit) or +# R_AARCH64_RELATIVE (64-bit). checkarmreloc: $(obj)u-boot - @if test "R_ARM_RELATIVE" != \ - "`$(CROSS_COMPILE)readelf -r $< | cut -d ' ' -f 4 | grep R_ARM | sort -u`"; \ - then echo "$< contains relocations other than \ - R_ARM_RELATIVE"; false; fi + @RELOC="`$(CROSS_COMPILE)readelf -r -W $< | cut -d ' ' -f 4 | \ + grep R_A | sort -u`"; \ + if test "$$RELOC" != "R_ARM_RELATIVE" -a \ + "$$RELOC" != "R_AARCH64_RELATIVE"; then \ + echo "$< contains unexpected relocations: $$RELOC"; \ + false; \ + fi
$(VERSION_FILE): @mkdir -p $(dir $(VERSION_FILE))
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood scottwood@freescale.com
Signed-off-by: David Feng fenghua@phytium.com.cn --- arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Makefile | 38 +++++ arch/arm/cpu/armv8/cache.S | 130 +++++++++++++++++ arch/arm/cpu/armv8/cache_v8.c | 218 ++++++++++++++++++++++++++++ arch/arm/cpu/armv8/config.mk | 15 ++ arch/arm/cpu/armv8/cpu.c | 67 +++++++++ arch/arm/cpu/armv8/exceptions.S | 112 +++++++++++++++ arch/arm/cpu/armv8/start.S | 234 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv8/timer.c | 80 +++++++++++ arch/arm/cpu/armv8/tlb.S | 30 ++++ arch/arm/cpu/armv8/u-boot.lds | 89 ++++++++++++ arch/arm/include/asm/armv8/mmu.h | 110 +++++++++++++++ arch/arm/include/asm/byteorder.h | 12 ++ arch/arm/include/asm/cache.h | 5 + arch/arm/include/asm/config.h | 6 + arch/arm/include/asm/global_data.h | 6 +- arch/arm/include/asm/io.h | 15 +- arch/arm/include/asm/macro.h | 36 +++++ arch/arm/include/asm/posix_types.h | 10 ++ arch/arm/include/asm/proc-armv/ptrace.h | 21 +++ arch/arm/include/asm/proc-armv/system.h | 59 +++++++- arch/arm/include/asm/system.h | 77 ++++++++++ arch/arm/include/asm/types.h | 4 + arch/arm/include/asm/u-boot.h | 4 + arch/arm/include/asm/unaligned.h | 2 +- arch/arm/lib/Makefile | 14 ++ arch/arm/lib/board.c | 7 +- arch/arm/lib/bootm.c | 16 +++ arch/arm/lib/crt0_64.S | 113 +++++++++++++++ arch/arm/lib/interrupts_64.c | 120 ++++++++++++++++ arch/arm/lib/relocate_64.S | 58 ++++++++ common/image.c | 1 + doc/README.arm64 | 45 ++++++ examples/standalone/stubs.c | 15 ++ include/image.h | 1 + 35 files changed, 1762 insertions(+), 11 deletions(-) create mode 100644 arch/arm/cpu/armv8/Makefile create mode 100644 arch/arm/cpu/armv8/cache.S create mode 100644 arch/arm/cpu/armv8/cache_v8.c create mode 100644 arch/arm/cpu/armv8/config.mk create mode 100644 arch/arm/cpu/armv8/cpu.c create mode 100644 arch/arm/cpu/armv8/exceptions.S create mode 100644 arch/arm/cpu/armv8/start.S create mode 100644 arch/arm/cpu/armv8/timer.c create mode 100644 arch/arm/cpu/armv8/tlb.S create mode 100644 arch/arm/cpu/armv8/u-boot.lds create mode 100644 arch/arm/include/asm/armv8/mmu.h create mode 100644 arch/arm/lib/crt0_64.S create mode 100644 arch/arm/lib/interrupts_64.c create mode 100644 arch/arm/lib/relocate_64.S create mode 100644 doc/README.arm64
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index d0cf43f..a259193 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -17,7 +17,8 @@ endif
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections \ - -fno-common -ffixed-r9 -msoft-float + -fno-common -ffixed-r9 +PLATFORM_RELFLAGS += $(call cc-option, -msoft-float)
# Support generic board on ARM __HAVE_ARCH_GENERIC_BOARD := y diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile new file mode 100644 index 0000000..b216f27 --- /dev/null +++ b/arch/arm/cpu/armv8/Makefile @@ -0,0 +1,38 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).o + +START := start.o + +COBJS += cpu.o +COBJS += timer.o +COBJS += cache_v8.o + +SOBJS += exceptions.o +SOBJS += cache.o +SOBJS += tlb.o + +SRCS := $(START:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S new file mode 100644 index 0000000..419f169 --- /dev/null +++ b/arch/arm/cpu/armv8/cache.S @@ -0,0 +1,130 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <version.h> +#include <asm/macro.h> +#include <linux/linkage.h> + +/* + * void __asm_flush_dcache_level(level) + * + * clean and invalidate one level cache. + * + * x0: cache level + * x1~x9: clobbered + */ +ENTRY(__asm_flush_dcache_level) + lsl x1, x0, #1 + msr csselr_el1, x1 /* select cache level */ + isb /* isb to sych the new cssr & csidr */ + mrs x6, ccsidr_el1 /* read the new ccsidr */ + and x2, x6, #7 /* x2 <- length of the cache lines */ + add x2, x2, #4 /* add 4 (line length offset) */ + mov x3, #0x3ff + and x3, x3, x6, lsr #3 /* x3 <- maximum number of way size */ + clz w5, w3 /* bit position of way size */ + mov x4, #0x7fff + and x4, x4, x1, lsr #13 /* x4 <- max number of the set size */ + /* x1 <- cache level << 1 */ + /* x2 <- line length offset */ + /* x3 <- number of cache ways */ + /* x4 <- number of cache sets */ + /* x5 <- bit position of way size */ + +loop_set: + mov x6, x3 /* create working copy of way size */ +loop_way: + lsl x7, x6, x5 + orr x9, x0, x7 /* map way and level to cisw value */ + lsl x7, x4, x2 + orr x9, x9, x7 /* map set number to cisw value */ + dc cisw, x9 /* clean & invalidate by set/way */ + subs x6, x6, #1 /* decrement the way */ + b.ge loop_way + subs x4, x4, #1 /* decrement the set */ + b.ge loop_set + + ret +ENDPROC(__asm_flush_dcache_level) + +/* + * void __asm_flush_dcache_all(void) + * + * clean and invalidate all data cache by SET/WAY. + */ +ENTRY(__asm_flush_dcache_all) + dsb sy + mov x15, lr + mrs x10, clidr_el1 /* read clidr */ + lsr x11, x10, #24 + and x11, x11, #0x7 /* x11 <- loc */ + cbz x11, finished /* if loc is 0, no need to clean */ + mov x0, #0 /* start flush at cache level 0 */ + /* x0 <- cache level */ + /* x10 <- clidr_el1 */ + /* x11 <- loc */ + +loop_level: + lsl x1, x0, #1 + add x1, x1, x0 /* x0 <- 3x cache level */ + lsr x1, x10, x1 + and x1, x1, #7 /* x1 <- cache type */ + cmp x1, #2 + b.lt skip /* skip if no cache or icache */ + bl __asm_flush_dcache_level +skip: + add x0, x0, #1 /* increment cache level */ + cmp x11, x0 + b.gt loop_level + +finished: + mov x0, #0 + msr csselr_el1, x0 /* swith back to cache level 0 */ + dsb sy + isb + mov lr, x15 + ret +ENDPROC(__asm_flush_dcache_all) + +/* + * void __asm_flush_dcache_range(start, end) + * + * clean & invalidate data cache in the range + * + * x0: start address + * x1: end address + */ +ENTRY(__asm_flush_dcache_range) + mrs x3, ctr_el0 /* read CTR */ + lsr x3, x3, #16 + and x3, x3, #0xf /* cache line size encoding */ + mov x2, #4 /* bytes per word */ + lsl x2, x2, x3 /* actual cache line size */ + + /* x2 <- minimal cache line size in cache system */ + sub x3, x2, #1 + bic x0, x0, x3 +1: dc civac, x0 /* clean & invalidate D/unified line */ + add x0, x0, x2 + cmp x0, x1 + b.lo 1b + dsb sy + ret +ENDPROC(__asm_flush_dcache_range) + +/* + * void __asm_invalidate_icache_all(void) + * + * invalidate all tlb entries. + */ +ENTRY(__asm_invalidate_icache_all) + ic ialluis + isb sy + ret +ENDPROC(__asm_invalidate_icache_all) diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c new file mode 100644 index 0000000..efd7466 --- /dev/null +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -0,0 +1,218 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/system.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_SYS_DCACHE_OFF + +static void set_pgtable_section(u64 section, u64 memory_type) +{ + u64 *page_table = (u64 *)gd->arch.tlb_addr; + u64 value; + + value = (section << SECTION_SHIFT) | PMD_TYPE_SECT | PMD_SECT_AF; + value |= PMD_ATTRINDX(memory_type); + page_table[section] = value; +} + +/* to activate the MMU we need to set up virtual memory */ +static void mmu_setup(void) +{ + int i, j, el; + bd_t *bd = gd->bd; + + /* Setup an identity-mapping for all spaces */ + for (i = 0; i < (PGTABLE_SIZE >> 3); i++) + set_pgtable_section(i, MT_DEVICE_NGNRNE); + + /* Setup an identity-mapping for all RAM space */ + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + ulong start = bd->bi_dram[i].start; + ulong end = bd->bi_dram[i].start + bd->bi_dram[i].size; + for (j = start >> SECTION_SHIFT; + j < end >> SECTION_SHIFT; j++) { + set_pgtable_section(j, MT_NORMAL); + } + } + + /* load TTBR0 */ + el = curent_el(); + if (el == 1) + asm volatile("msr ttbr0_el1, %0" + : : "r" (gd->arch.tlb_addr) : "memory"); + else if (el == 2) + asm volatile("msr ttbr0_el2, %0" + : : "r" (gd->arch.tlb_addr) : "memory"); + else + panic("Not Supported Exception Level"); + + /* enable the mmu */ + set_sctlr(get_sctlr() | CR_M); +} + +/* + * Performs a invalidation of the entire data cache at all levels + */ +void invalidate_dcache_all(void) +{ + __asm_flush_dcache_all(); +} + +/* + * Performs a clean & invalidation of the entire data cache at all levels + */ +void flush_dcache_all(void) +{ + __asm_flush_dcache_all(); +} + +/* + * Invalidates range in all levels of D-cache/unified cache + */ +void invalidate_dcache_range(unsigned long start, unsigned long stop) +{ + __asm_flush_dcache_range(start, stop); +} + +/* + * Flush range(clean & invalidate) from all levels of D-cache/unified cache + */ +void flush_dcache_range(unsigned long start, unsigned long stop) +{ + __asm_flush_dcache_range(start, stop); +} + +void dcache_enable(void) +{ + /* The data cache is not active unless the mmu is enabled */ + if (!(get_sctlr() & CR_M)) { + invalidate_dcache_all(); + __asm_invalidate_tlb_all(); + mmu_setup(); + } + + set_sctlr(get_sctlr() | CR_C); +} + +void dcache_disable(void) +{ + uint32_t sctlr; + + sctlr = get_sctlr(); + + /* if cache isn't enabled no need to disable */ + if (!(sctlr & CR_C)) + return; + + set_sctlr(sctlr & ~(CR_C|CR_M)); + + flush_dcache_all(); + __asm_invalidate_tlb_all(); +} + +int dcache_status(void) +{ + return (get_sctlr() & CR_C) != 0; +} + +#else /* CONFIG_SYS_DCACHE_OFF */ + +void invalidate_dcache_all(void) +{ +} + +void flush_dcache_all(void) +{ +} + +void invalidate_dcache_range(unsigned long start, unsigned long stop) +{ +} + +void flush_dcache_range(unsigned long start, unsigned long stop) +{ +} + +void dcache_enable(void) +{ +} + +void dcache_disable(void) +{ +} + +int dcache_status(void) +{ + return 0; +} + +#endif /* CONFIG_SYS_DCACHE_OFF */ + +#ifndef CONFIG_SYS_ICACHE_OFF + +void icache_enable(void) +{ + set_sctlr(get_sctlr() | CR_I); +} + +void icache_disable(void) +{ + set_sctlr(get_sctlr() & ~CR_I); +} + +int icache_status(void) +{ + return (get_sctlr() & CR_I) != 0; +} + +void invalidate_icache_all(void) +{ + __asm_invalidate_icache_all(); +} + +#else /* CONFIG_SYS_ICACHE_OFF */ + +void icache_enable(void) +{ +} + +void icache_disable(void) +{ +} + +int icache_status(void) +{ + return 0; +} + +void invalidate_icache_all(void) +{ +} + +#endif /* CONFIG_SYS_ICACHE_OFF */ + +/* + * Enable dCache & iCache, whether cache is actually enabled + * depend on CONFIG_SYS_DCACHE_OFF and CONFIG_SYS_ICACHE_OFF + */ +void enable_caches(void) +{ + icache_enable(); + dcache_enable(); +} + +/* + * Flush range from all levels of d-cache/unified-cache + */ +void flush_cache(unsigned long start, unsigned long size) +{ + flush_dcache_range(start, start + size); +} diff --git a/arch/arm/cpu/armv8/config.mk b/arch/arm/cpu/armv8/config.mk new file mode 100644 index 0000000..027a68c --- /dev/null +++ b/arch/arm/cpu/armv8/config.mk @@ -0,0 +1,15 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, garyj@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# +PLATFORM_RELFLAGS += -fno-common -ffixed-x18 + +# SEE README.arm-unaligned-accesses +PF_NO_UNALIGNED := $(call cc-option, -mstrict-align) +PLATFORM_NO_UNALIGNED := $(PF_NO_UNALIGNED) + +PF_CPPFLAGS_ARMV8 := $(call cc-option, -march=armv8-a) +PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_ARMV8) +PLATFORM_CPPFLAGS += $(PF_NO_UNALIGNED) diff --git a/arch/arm/cpu/armv8/cpu.c b/arch/arm/cpu/armv8/cpu.c new file mode 100644 index 0000000..83e73ab --- /dev/null +++ b/arch/arm/cpu/armv8/cpu.c @@ -0,0 +1,67 @@ +/* + * (C) Copyright 2008 Texas Insturments + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * CPU specific code + */ + +#include <common.h> +#include <command.h> +#include <asm/system.h> +#include <linux/compiler.h> + +void __weak cpu_cache_initialization(void){} + +int cleanup_before_linux(void) +{ + /* + * this function is called just before we call linux + * it prepares the processor for linux + * + * we turn off caches etc ... + */ +#ifndef CONFIG_SPL_BUILD + disable_interrupts(); +#endif + + /* + * Turn off I-cache and invalidate it + */ + icache_disable(); + invalidate_icache_all(); + + /* + * turn off D-cache + * dcache_disable() in turn flushes the d-cache and disables MMU + */ + dcache_disable(); + + /* + * After D-cache is flushed and before it is disabled there may + * be some new valid entries brought into the cache. We are sure + * that these lines are not dirty and will not affect our execution. + * (because unwinding the call-stack and setting a bit in CP15 SCTRL + * is all we did during this. We have not pushed anything on to the + * stack. Neither have we affected any static data) + * So just invalidate the entire d-cache again to avoid coherency + * problems for kernel + */ + invalidate_dcache_all(); + + /* + * Some CPU need more cache attention before starting the kernel. + */ + cpu_cache_initialization(); + + return 0; +} diff --git a/arch/arm/cpu/armv8/exceptions.S b/arch/arm/cpu/armv8/exceptions.S new file mode 100644 index 0000000..b00d4b3 --- /dev/null +++ b/arch/arm/cpu/armv8/exceptions.S @@ -0,0 +1,112 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <version.h> +#include <asm/ptrace.h> +#include <asm/macro.h> +#include <linux/linkage.h> + +/* + * Enter Exception. + * This will save the processor state that is ELR/X0~X30 + * to the stack frame. + */ +.macro exception_entry + stp x29, x30, [sp, #-16]! + stp x27, x28, [sp, #-16]! + stp x25, x26, [sp, #-16]! + stp x23, x24, [sp, #-16]! + stp x21, x22, [sp, #-16]! + stp x19, x20, [sp, #-16]! + stp x17, x18, [sp, #-16]! + stp x15, x16, [sp, #-16]! + stp x13, x14, [sp, #-16]! + stp x11, x12, [sp, #-16]! + stp x9, x10, [sp, #-16]! + stp x7, x8, [sp, #-16]! + stp x5, x6, [sp, #-16]! + stp x3, x4, [sp, #-16]! + stp x1, x2, [sp, #-16]! + + /* Could be running at EL1 or EL2 */ + mrs x11, CurrentEL + cmp x11, 0x8 + b.eq 1f + mrs x1, esr_el1 + mrs x2, elr_el1 + b 2f +1: mrs x1, esr_el2 + mrs x2, elr_el2 +2: + stp x2, x0, [sp, #-16]! + mov x0, sp +.endm + +/* + * Exception vectors. + */ + .align 11 + .globl vectors +vectors: + .align 7 + b _do_bad_sync /* Current EL Synchronous Thread */ + + .align 7 + b _do_bad_irq /* Current EL IRQ Thread */ + + .align 7 + b _do_bad_fiq /* Current EL FIQ Thread */ + + .align 7 + b _do_bad_error /* Current EL Error Thread */ + + .align 7 + b _do_sync /* Current EL Synchronous Handler */ + + .align 7 + b _do_irq /* Current EL IRQ Handler */ + + .align 7 + b _do_fiq /* Current EL FIQ Handler */ + + .align 7 + b _do_error /* Current EL Error Handler */ + + +_do_bad_sync: + exception_entry + bl do_bad_sync + +_do_bad_irq: + exception_entry + bl do_bad_irq + +_do_bad_fiq: + exception_entry + bl do_bad_fiq + +_do_bad_error: + exception_entry + bl do_bad_error + +_do_sync: + exception_entry + bl do_sync + +_do_irq: + exception_entry + bl do_irq + +_do_fiq: + exception_entry + bl do_fiq + +_do_error: + exception_entry + bl do_error diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S new file mode 100644 index 0000000..7352778 --- /dev/null +++ b/arch/arm/cpu/armv8/start.S @@ -0,0 +1,234 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <version.h> +#include <linux/linkage.h> +#include <asm/macro.h> +#include <asm/armv8/mmu.h> + +/************************************************************************* + * + * Startup Code (reset vector) + * + *************************************************************************/ + +.globl _start +_start: + b reset + + .align 3 + +.globl _TEXT_BASE +_TEXT_BASE: + .quad CONFIG_SYS_TEXT_BASE + +/* + * These are defined in the linker script. + */ +.globl _end_ofs +_end_ofs: + .quad _end - _start + +.globl _bss_start_ofs +_bss_start_ofs: + .quad __bss_start - _start + +.globl _bss_end_ofs +_bss_end_ofs: + .quad __bss_end - _start + +reset: + /* + * Could be EL3/EL2/EL1 + */ + mrs x0, CurrentEL + cmp x0, #0xc + b.ne reset_nonsecure /* Not EL3 */ + + bl setup_el3 /* EL3 initialization */ + + /* + * MMU Disabled, iCache Disabled, dCache Disabled + */ +reset_nonsecure: + +#ifdef CONFIG_BOOTING_EL1 + branch_if_el2 x0, 1f + b 2f +1: bl setup_el2 /* EL2 initialization */ +2: +#endif + + /* Initialize vBAR/CPACR_EL1/MDSCR_EL1 */ + adr x0, vectors + branch_if_el2 x1, 1f + msr vbar_el1, x0 + mov x0, #3 << 20 + msr cpacr_el1, x0 /* Enable FP/SIMD */ + msr mdscr_el1, xzr + b 2f +1: msr vbar_el2, x0 +2: + + /* Cache/BPB/TLB Invalidate */ + bl __asm_flush_dcache_all /* dCache clean & invalidate */ + bl __asm_invalidate_icache_all /* iCache invalidate */ + bl __asm_invalidate_tlb_all /* invalidate TLBs */ + + /* Processor specific initialization */ + bl lowlevel_init + + branch_if_slave x0, slave_cpu + + /* + * Master CPU + */ +master_cpu: + bl _main + + /* + * Slave CPUs + */ +slave_cpu: + wfe + ldr x1, =CPU_RELEASE_ADDR + ldr x0, [x1] + cbz x0, slave_cpu + br x0 /* branch to the given address */ + +/*-------------------------------------------------------------------------*/ + +WEAK(setup_el3) + mov x0, #0x531 /* Non-secure EL0/EL1 | HVC | 64bit EL2 */ + msr scr_el3, x0 + msr cptr_el3, xzr /* Disable coprocessor traps to EL3 */ + + /* GIC initialization */ + branch_if_slave x0, 2f + + /* Master initialize distributor */ + ldr x1, =GICD_BASE /* GICD_CTLR */ + mov w0, #0x3 /* Enable Group0 & Group1 */ + str w0, [x1] + ldr w0, [x1, #0x4] /* GICD_TYPER */ + and w2, w0, #0x1f /* ITLinesNumber */ + add w2, w2, #0x1 /* Number of GICD_IGROUPR registers */ + add x1, x1, #0x80 /* GICD_IGROUPR */ + mov w0, #~0 /* All Group1 */ +1: str w0, [x1], #0x4 + sub w2, w2, #0x1 + cbnz w2, 1b + b 3f + + /* Slave initialize distributor */ +2: ldr x1, =GICD_BASE /* GICD_CTLR */ + mov w0, #~0 /* All Group1 */ + str w0, [x1, #0x80] + + /* Initialize cpu interface */ +3: ldr x1, =GICC_BASE /* GICC_CTLR */ + mov w0, #0x3 /* Enable Group0 & Group1 */ + str w0, [x1] + + mov w0, #0x1 << 7 /* Non-Secure access to GICC_PMR */ + str w0, [x1, #0x4] /* GICC_PMR */ + + /* Counter frequency initialization */ + ldr x0, =CONFIG_SYS_CNTFRQ + msr cntfrq_el0, x0 + + /* SCTLR_EL2 initialization */ + msr sctlr_el2, xzr + + /* Return to the EL2_SP2 mode from EL3 */ + mov x0, #0x3c9 /* EL2_SP2 | D | A | I | F */ + msr elr_el3, lr + msr spsr_el3, x0 + eret +ENDPROC(setup_el3) + +WEAK(setup_el2) + /* Initialize Generic Timers */ + mrs x0, cnthctl_el2 + orr x0, x0, #0x3 /* Enable EL1 access to timers */ + msr cnthctl_el2, x0 + msr cntvoff_el2, x0 /* Clear virtual offset */ + mrs x0, cntkctl_el1 + orr x0, x0, #0x3 /* EL0 access to counters */ + msr cntkctl_el1, x0 + + /* Initilize MPID/MPIDR registers */ + mrs x0, midr_el1 + mrs x1, mpidr_el1 + msr vpidr_el2, x0 + msr vmpidr_el2, x1 + + /* Disable coprocessor traps */ + mov x0, #0x33ff + msr cptr_el2, x0 /* Disable coprocessor traps to EL2 */ + msr hstr_el2, xzr /* Disable CP15 traps to EL2 */ + + /* Initialize HCR_EL2 */ + mov x0, #(1 << 31) /* 64bit EL1 */ + orr x0, x0, #(1 << 29) /* Disable HVC */ + msr hcr_el2, x0 + + /* SCTLR_EL1 initialization */ + mov x0, #0x0800 + movk x0, #0x30d0, lsl #16 + msr sctlr_el1, x0 + + /* Return to the EL1_SP1 mode from EL2 */ + mov x0, #0x3c5 /* EL1_SP1 | D | A | I | F */ + msr elr_el2, lr + msr spsr_el2, x0 + eret +ENDPROC(setup_el2) + +WEAK(lowlevel_init) + ret +ENDPROC(lowlevel_init) + +/*-------------------------------------------------------------------------*/ + +ENTRY(c_runtime_cpu_setup) + /* If I-cache is enabled invalidate it */ +#ifndef CONFIG_SYS_ICACHE_OFF + ic iallu /* I+BTB cache invalidate */ + isb sy +#endif + +#ifndef CONFIG_SYS_DCACHE_OFF + /* + * Setup MAIR and TCR. + */ + ldr x0, =MEMORY_ATTRIBUTES + ldr x1, =TCR_FLAGS + + branch_if_el2 x2, 1f + orr x1, x1, TCR_EL1_IPS_BITS + msr mair_el1, x0 + msr tcr_el1, x1 + b 2f +1: orr x1, x1, TCR_EL2_IPS_BITS + msr mair_el2, x0 + msr tcr_el2, x1 +2: +#endif + + /* Relocate vBAR */ + adr x0, vectors + branch_if_el2 x1, 1f + msr vbar_el1, x0 + b 2f +1: msr vbar_el2, x0 +2: + + ret +ENDPROC(c_runtime_cpu_setup) diff --git a/arch/arm/cpu/armv8/timer.c b/arch/arm/cpu/armv8/timer.c new file mode 100644 index 0000000..9605e84 --- /dev/null +++ b/arch/arm/cpu/armv8/timer.c @@ -0,0 +1,80 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <linux/compiler.h> + +/* + * Genertic Timer implementation of __udelay/get_timer/get_ticks/get_tbclk + * functions. If any other timers used, another implementation should be + * placed in platform code. + */ + +static inline u64 get_cntfrq(void) +{ + u64 cntfrq; + asm volatile("mrs %0, cntfrq_el0" : "=r" (cntfrq)); + return cntfrq; +} + +static inline u64 tick_to_time(u64 tick) +{ + tick *= CONFIG_SYS_HZ; + do_div(tick, get_cntfrq()); + return tick; +} + +static inline u64 time_to_tick(u64 time) +{ + time *= get_cntfrq(); + do_div(time, CONFIG_SYS_HZ); + return time; +} + +/* + * Generic timer implementation of get_tbclk() + */ +ulong __weak get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} + +/* + * Generic timer implementation of get_timer() + */ +ulong __weak get_timer(ulong base) +{ + u64 cval; + + isb(); + asm volatile("mrs %0, cntpct_el0" : "=r" (cval)); + + return tick_to_time(cval) - base; +} + +/* + * Generic timer implementation of get_ticks() + */ +unsigned long long __weak get_ticks(void) +{ + return get_timer(0); +} + +/* + * Generic timer implementation of __udelay() + */ +void __weak __udelay(ulong usec) +{ + unsigned long ticks, limit; + + limit = get_ticks() + usec/1000; + + do { + ticks = get_ticks(); + } while (ticks < limit); +} diff --git a/arch/arm/cpu/armv8/tlb.S b/arch/arm/cpu/armv8/tlb.S new file mode 100644 index 0000000..4dd3a65 --- /dev/null +++ b/arch/arm/cpu/armv8/tlb.S @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <version.h> +#include <linux/linkage.h> +#include <asm/macro.h> + +/* + * void __asm_invalidate_tlb_all(void) + * + * invalidate all tlb entries. + */ +ENTRY(__asm_invalidate_tlb_all) + branch_if_el2 x9, 1f + tlbi vmalle1 + dsb sy + isb + b 2f +1: tlbi alle2 + dsb sy + isb +2: + ret +ENDPROC(__asm_invalidate_tlb_all) diff --git a/arch/arm/cpu/armv8/u-boot.lds b/arch/arm/cpu/armv8/u-boot.lds new file mode 100644 index 0000000..4c12222 --- /dev/null +++ b/arch/arm/cpu/armv8/u-boot.lds @@ -0,0 +1,89 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") +OUTPUT_ARCH(aarch64) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(8); + .text : + { + *(.__image_copy_start) + CPUDIR/start.o (.text*) + *(.text*) + } + + . = ALIGN(8); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(8); + .data : { + *(.data*) + } + + . = ALIGN(8); + + . = .; + + . = ALIGN(8); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(8); + + .image_copy_end : + { + *(.__image_copy_end) + } + + . = ALIGN(8); + + .rel_dyn_start : + { + *(.__rel_dyn_start) + } + + .rela.dyn : { + *(.rela*) + } + + .rel_dyn_end : + { + *(.__rel_dyn_end) + } + + _end = .; + + . = ALIGN(8); + + .bss_start : { + KEEP(*(.__bss_start)); + } + + .bss : { + *(.bss*) + . = ALIGN(8); + } + + .bss_end : { + KEEP(*(.__bss_end)); + } + + /DISCARD/ : { *(.dynsym) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} diff --git a/arch/arm/include/asm/armv8/mmu.h b/arch/arm/include/asm/armv8/mmu.h new file mode 100644 index 0000000..c131751 --- /dev/null +++ b/arch/arm/include/asm/armv8/mmu.h @@ -0,0 +1,110 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARMV8_MMU_H_ +#define _ASM_ARMV8_MMU_H_ + +#ifdef __ASSEMBLY__ +#define _AC(X, Y) X +#else +#define _AC(X, Y) (X##Y) +#endif + +#define UL(x) _AC(x, UL) + +/***************************************************************/ +/* + * The following definitions are related each other, shoud be + * calculated specifically. + */ +#define VA_BITS (42) /* 42 bits virtual address */ + +/* PAGE_SHIFT determines the page size */ +#undef PAGE_SIZE +#define PAGE_SHIFT 16 +#define PAGE_SIZE (1 << PAGE_SHIFT) +#define PAGE_MASK (~(PAGE_SIZE-1)) + +/* + * section address mask and size definitions. + */ +#define SECTION_SHIFT 29 +#define SECTION_SIZE (UL(1) << SECTION_SHIFT) +#define SECTION_MASK (~(SECTION_SIZE-1)) +/***************************************************************/ + +/* + * Memory types + */ +#define MT_DEVICE_NGNRNE 0 +#define MT_DEVICE_NGNRE 1 +#define MT_DEVICE_GRE 2 +#define MT_NORMAL_NC 3 +#define MT_NORMAL 4 + +#define MEMORY_ATTRIBUTES ((0x00 << (MT_DEVICE_NGNRNE*8)) | \ + (0x04 << (MT_DEVICE_NGNRE*8)) | \ + (0x0c << (MT_DEVICE_GRE*8)) | \ + (0x44 << (MT_NORMAL_NC*8)) | \ + (UL(0xff) << (MT_NORMAL*8))) + +/* + * Hardware page table definitions. + * + * Level 2 descriptor (PMD). + */ +#define PMD_TYPE_MASK (3 << 0) +#define PMD_TYPE_FAULT (0 << 0) +#define PMD_TYPE_TABLE (3 << 0) +#define PMD_TYPE_SECT (1 << 0) + +/* + * Section + */ +#define PMD_SECT_S (3 << 8) +#define PMD_SECT_AF (1 << 10) +#define PMD_SECT_NG (1 << 11) +#define PMD_SECT_PXN (UL(1) << 53) +#define PMD_SECT_UXN (UL(1) << 54) + +/* + * AttrIndx[2:0] + */ +#define PMD_ATTRINDX(t) ((t) << 2) +#define PMD_ATTRINDX_MASK (7 << 2) + +/* + * TCR flags. + */ +#define TCR_T0SZ(x) ((64 - (x)) << 0) +#define TCR_IRGN_NC (0 << 8) +#define TCR_IRGN_WBWA (1 << 8) +#define TCR_IRGN_WT (2 << 8) +#define TCR_IRGN_WBNWA (3 << 8) +#define TCR_IRGN_MASK (3 << 8) +#define TCR_ORGN_NC (0 << 10) +#define TCR_ORGN_WBWA (1 << 10) +#define TCR_ORGN_WT (2 << 10) +#define TCR_ORGN_WBNWA (3 << 10) +#define TCR_ORGN_MASK (3 << 10) +#define TCR_SHARED_NON (0 << 12) +#define TCR_SHARED_OUTER (1 << 12) +#define TCR_SHARED_INNER (2 << 12) +#define TCR_TG0_4K (0 << 14) +#define TCR_TG0_64K (1 << 14) +#define TCR_TG0_16K (2 << 14) +#define TCR_EL1_IPS_BITS (UL(3) << 32) /* 42 bits physical address */ +#define TCR_EL2_IPS_BITS (3 << 16) /* 42 bits physical address */ + +/* PTWs cacheable, inner/outer WBWA and non-shareable */ +#define TCR_FLAGS (TCR_TG0_64K | \ + TCR_SHARED_NON | \ + TCR_ORGN_WBWA | \ + TCR_IRGN_WBWA | \ + TCR_T0SZ(VA_BITS)) + +#endif /* _ASM_ARMV8_MMU_H_ */ diff --git a/arch/arm/include/asm/byteorder.h b/arch/arm/include/asm/byteorder.h index c3489f1..71a9966 100644 --- a/arch/arm/include/asm/byteorder.h +++ b/arch/arm/include/asm/byteorder.h @@ -23,10 +23,22 @@ # define __SWAB_64_THRU_32__ #endif
+#ifdef CONFIG_ARM64 + +#ifdef __AARCH64EB__ +#include <linux/byteorder/big_endian.h> +#else +#include <linux/byteorder/little_endian.h> +#endif + +#else /* CONFIG_ARM64 */ + #ifdef __ARMEB__ #include <linux/byteorder/big_endian.h> #else #include <linux/byteorder/little_endian.h> #endif
+#endif /* CONFIG_ARM64 */ + #endif diff --git a/arch/arm/include/asm/cache.h b/arch/arm/include/asm/cache.h index 6d60a4a..ddebbc8 100644 --- a/arch/arm/include/asm/cache.h +++ b/arch/arm/include/asm/cache.h @@ -11,6 +11,8 @@
+#ifndef CONFIG_ARM64 + /* * Invalidate L2 Cache using co-proc instruction */ @@ -28,6 +30,9 @@ void l2_cache_disable(void); void set_section_dcache(int section, enum dcache_option option);
void dram_bank_mmu_setup(int bank); + +#endif + /* * The current upper bound for ARM L1 data cache line sizes is 64 bytes. We * use that value for aligning DMA buffers unless the board config has specified diff --git a/arch/arm/include/asm/config.h b/arch/arm/include/asm/config.h index 99b703e..abf79e5 100644 --- a/arch/arm/include/asm/config.h +++ b/arch/arm/include/asm/config.h @@ -9,4 +9,10 @@
#define CONFIG_LMB #define CONFIG_SYS_BOOT_RAMDISK_HIGH + +#ifdef CONFIG_ARM64 +#define CONFIG_PHYS_64BIT +#define CONFIG_STATIC_RELA +#endif + #endif diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index e126436..60e8726 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -47,6 +47,10 @@ struct arch_global_data {
#include <asm-generic/global_data.h>
-#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r9") +#ifdef CONFIG_ARM64 +#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("x18") +#else +#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r9") +#endif
#endif /* __ASM_GBL_DATA_H */ diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 1fbc531..6a1f05a 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -75,42 +75,45 @@ static inline phys_addr_t virt_to_phys(void * vaddr) #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) #define __arch_putl(v,a) (*(volatile unsigned int *)(a) = (v))
-extern inline void __raw_writesb(unsigned int addr, const void *data, int bytelen) +extern inline void __raw_writesb(unsigned long addr, const void *data, + int bytelen) { uint8_t *buf = (uint8_t *)data; while(bytelen--) __arch_putb(*buf++, addr); }
-extern inline void __raw_writesw(unsigned int addr, const void *data, int wordlen) +extern inline void __raw_writesw(unsigned long addr, const void *data, + int wordlen) { uint16_t *buf = (uint16_t *)data; while(wordlen--) __arch_putw(*buf++, addr); }
-extern inline void __raw_writesl(unsigned int addr, const void *data, int longlen) +extern inline void __raw_writesl(unsigned long addr, const void *data, + int longlen) { uint32_t *buf = (uint32_t *)data; while(longlen--) __arch_putl(*buf++, addr); }
-extern inline void __raw_readsb(unsigned int addr, void *data, int bytelen) +extern inline void __raw_readsb(unsigned long addr, void *data, int bytelen) { uint8_t *buf = (uint8_t *)data; while(bytelen--) *buf++ = __arch_getb(addr); }
-extern inline void __raw_readsw(unsigned int addr, void *data, int wordlen) +extern inline void __raw_readsw(unsigned long addr, void *data, int wordlen) { uint16_t *buf = (uint16_t *)data; while(wordlen--) *buf++ = __arch_getw(addr); }
-extern inline void __raw_readsl(unsigned int addr, void *data, int longlen) +extern inline void __raw_readsl(unsigned long addr, void *data, int longlen) { uint32_t *buf = (uint32_t *)data; while(longlen--) diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index ff13f36..0977830 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -54,5 +54,41 @@ bcs 1b .endm
+#ifdef CONFIG_ARM64 +/* + * Register aliases. + */ +lr .req x30 + +/* + * Branch according to exception level + */ +.macro branch_if_el2, xreg, el2_label + mrs \xreg, CurrentEL + cmp \xreg, 0x8 + b.eq \el2_label +.endm + +/* + * Branch if current processor is a slave, + * choose processor with all zero affinity value as the master. + */ +.macro branch_if_slave, xreg, slave_label + mrs \xreg, mpidr_el1 + tst \xreg, #0xff /* Test Affinity 0 */ + b.ne \slave_label + lsr \xreg, \xreg, #8 + tst \xreg, #0xff /* Test Affinity 1 */ + b.ne \slave_label + lsr \xreg, \xreg, #8 + tst \xreg, #0xff /* Test Affinity 2 */ + b.ne \slave_label + lsr \xreg, \xreg, #16 + tst \xreg, #0xff /* Test Affinity 3 */ + b.ne \slave_label +.endm + +#endif /* CONFIG_ARM64 */ + #endif /* __ASSEMBLY__ */ #endif /* __ASM_ARM_MACRO_H__ */ diff --git a/arch/arm/include/asm/posix_types.h b/arch/arm/include/asm/posix_types.h index c412486..9ba9add 100644 --- a/arch/arm/include/asm/posix_types.h +++ b/arch/arm/include/asm/posix_types.h @@ -13,6 +13,8 @@ #ifndef __ARCH_ARM_POSIX_TYPES_H #define __ARCH_ARM_POSIX_TYPES_H
+#include <config.h> + /* * This file is generally used by user-level software, so you need to * be a little careful about namespace pollution etc. Also, we cannot @@ -28,9 +30,17 @@ typedef int __kernel_pid_t; typedef unsigned short __kernel_ipc_pid_t; typedef unsigned short __kernel_uid_t; typedef unsigned short __kernel_gid_t; + +#ifdef CONFIG_ARM64 +typedef unsigned long __kernel_size_t; +typedef long __kernel_ssize_t; +typedef long __kernel_ptrdiff_t; +#else /* CONFIG_ARM64 */ typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; +#endif /* CONFIG_ARM64 */ + typedef long __kernel_time_t; typedef long __kernel_suseconds_t; typedef long __kernel_clock_t; diff --git a/arch/arm/include/asm/proc-armv/ptrace.h b/arch/arm/include/asm/proc-armv/ptrace.h index 79cc644..fd280cb 100644 --- a/arch/arm/include/asm/proc-armv/ptrace.h +++ b/arch/arm/include/asm/proc-armv/ptrace.h @@ -12,6 +12,25 @@
#include <linux/config.h>
+#ifdef CONFIG_ARM64 + +#define PCMASK 0 + +#ifndef __ASSEMBLY__ + +/* + * This struct defines the way the registers are stored + * on the stack during an exception. + */ +struct pt_regs { + unsigned long elr; + unsigned long regs[31]; +}; + +#endif /* __ASSEMBLY__ */ + +#else /* CONFIG_ARM64 */ + #define USR26_MODE 0x00 #define FIQ26_MODE 0x01 #define IRQ26_MODE 0x02 @@ -106,4 +125,6 @@ static inline int valid_user_regs(struct pt_regs *regs)
+#endif /* CONFIG_ARM64 */ + #endif diff --git a/arch/arm/include/asm/proc-armv/system.h b/arch/arm/include/asm/proc-armv/system.h index b4cfa68..19b2b44 100644 --- a/arch/arm/include/asm/proc-armv/system.h +++ b/arch/arm/include/asm/proc-armv/system.h @@ -15,6 +15,60 @@ /* * Save the current interrupt enable state & disable IRQs */ +#ifdef CONFIG_ARM64 + +/* + * Save the current interrupt enable state + * and disable IRQs/FIQs + */ +#define local_irq_save(flags) \ + ({ \ + asm volatile( \ + "mrs %0, daif" \ + "msr daifset, #3" \ + : "=r" (flags) \ + : \ + : "memory"); \ + }) + +/* + * restore saved IRQ & FIQ state + */ +#define local_irq_restore(flags) \ + ({ \ + asm volatile( \ + "msr daif, %0" \ + : \ + : "r" (flags) \ + : "memory"); \ + }) + +/* + * Enable IRQs/FIQs + */ +#define local_irq_enable() \ + ({ \ + asm volatile( \ + "msr daifclr, #3" \ + : \ + : \ + : "memory"); \ + }) + +/* + * Disable IRQs/FIQs + */ +#define local_irq_disable() \ + ({ \ + asm volatile( \ + "msr daifset, #3" \ + : \ + : \ + : "memory"); \ + }) + +#else /* CONFIG_ARM64 */ + #define local_irq_save(x) \ ({ \ unsigned long temp; \ @@ -109,7 +163,10 @@ : "r" (x) \ : "memory")
-#if defined(CONFIG_CPU_SA1100) || defined(CONFIG_CPU_SA110) +#endif /* CONFIG_ARM64 */ + +#if defined(CONFIG_CPU_SA1100) || defined(CONFIG_CPU_SA110) || \ + defined(CONFIG_ARM64) /* * On the StrongARM, "swp" is terminally broken since it bypasses the * cache totally. This means that the cache becomes inconsistent, and, diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 760345f..0e7c455 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -1,6 +1,79 @@ #ifndef __ASM_ARM_SYSTEM_H #define __ASM_ARM_SYSTEM_H
+#ifdef CONFIG_ARM64 + +/* + * SCTLR_EL1/SCTLR_EL2 bits definitions + */ +#define CR_M (1 << 0) /* MMU enable */ +#define CR_A (1 << 1) /* Alignment abort enable */ +#define CR_C (1 << 2) /* Dcache enable */ +#define CR_SA (1 << 3) /* Stack Alignment Check Enable */ +#define CR_I (1 << 12) /* Icache enable */ +#define CR_WXN (1 << 19) /* Write Permision Imply XN */ +#define CR_EE (1 << 25) /* Exception (Big) Endian */ + +#define PGTABLE_SIZE (0x10000) + +#ifndef __ASSEMBLY__ + +#define isb() \ + ({asm volatile( \ + "isb" : : : "memory"); \ + }) + +#define wfi() \ + ({asm volatile( \ + "wfi" : : : "memory"); \ + }) + +static inline unsigned int curent_el(void) +{ + unsigned int el; + asm volatile("mrs %0, CurrentEL" : "=r" (el) : : "cc"); + return el >> 2; +} + +static inline unsigned int get_sctlr(void) +{ + unsigned int el, val; + + el = curent_el(); + if (el == 1) + asm volatile("mrs %0, sctlr_el1" : "=r" (val) : : "cc"); + else if (el == 2) + asm volatile("mrs %0, sctlr_el2" : "=r" (val) : : "cc"); + else + panic("Not Supported Exception Level"); + + return val; +} + +static inline void set_sctlr(unsigned int val) +{ + unsigned int el; + + el = curent_el(); + if (el == 1) + asm volatile("msr sctlr_el1, %0" : : "r" (val) : "cc"); + else if (el == 2) + asm volatile("msr sctlr_el2, %0" : : "r" (val) : "cc"); + else + panic("Not Supported Exception Level"); + + asm volatile("isb"); +} + +void __asm_flush_dcache_all(void); +void __asm_flush_dcache_range(u64 start, u64 end); +void __asm_invalidate_tlb_all(void); +void __asm_invalidate_icache_all(void); + +#endif /* __ASSEMBLY__ */ + +#else /* CONFIG_ARM64 */ + #ifdef __KERNEL__
#define CPU_ARCH_UNKNOWN 0 @@ -45,6 +118,8 @@ #define CR_AFE (1 << 29) /* Access flag enable */ #define CR_TE (1 << 30) /* Thumb exception enable */
+#define PGTABLE_SIZE (4096 * 4) + /* * This is used to ensure the compiler did actually allocate the register we * asked it for some inline assembly sequences. Apparently we can't trust @@ -132,4 +207,6 @@ void mmu_page_table_flush(unsigned long start, unsigned long stop);
#endif /* __KERNEL__ */
+#endif /* CONFIG_ARM64 */ + #endif diff --git a/arch/arm/include/asm/types.h b/arch/arm/include/asm/types.h index 71dc049..2326420 100644 --- a/arch/arm/include/asm/types.h +++ b/arch/arm/include/asm/types.h @@ -39,7 +39,11 @@ typedef unsigned int u32; typedef signed long long s64; typedef unsigned long long u64;
+#ifdef CONFIG_ARM64 +#define BITS_PER_LONG 64 +#else /* CONFIG_ARM64 */ #define BITS_PER_LONG 32 +#endif /* CONFIG_ARM64 */
/* Dma addresses are 32-bits wide. */
diff --git a/arch/arm/include/asm/u-boot.h b/arch/arm/include/asm/u-boot.h index 2b5fce8..cb81232 100644 --- a/arch/arm/include/asm/u-boot.h +++ b/arch/arm/include/asm/u-boot.h @@ -44,6 +44,10 @@ typedef struct bd_info { #endif /* !CONFIG_SYS_GENERIC_BOARD */
/* For image.h:image_check_target_arch() */ +#ifndef CONFIG_ARM64 #define IH_ARCH_DEFAULT IH_ARCH_ARM +#else +#define IH_ARCH_DEFAULT IH_ARCH_ARM64 +#endif
#endif /* _U_BOOT_H_ */ diff --git a/arch/arm/include/asm/unaligned.h b/arch/arm/include/asm/unaligned.h index 44593a8..0a228fb 100644 --- a/arch/arm/include/asm/unaligned.h +++ b/arch/arm/include/asm/unaligned.h @@ -8,7 +8,7 @@ /* * Select endianness */ -#ifndef __ARMEB__ +#if __BYTE_ORDER == __LITTLE_ENDIAN #define get_unaligned __get_unaligned_le #define put_unaligned __put_unaligned_le #else diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 4e78723..03c31c7 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -10,6 +10,9 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(ARCH).o LIBGCC = $(obj)libgcc.o
+ifdef CONFIG_ARM64 +SOBJS-y += crt0_64.o +else GLSOBJS += _ashldi3.o GLSOBJS += _ashrdi3.o GLSOBJS += _divsi3.o @@ -21,9 +24,14 @@ GLSOBJS += _umodsi3.o GLCOBJS += div0.o
SOBJS-y += crt0.o +endif
ifndef CONFIG_SPL_BUILD +ifdef CONFIG_ARM64 +SOBJS-y += relocate_64.o +else SOBJS-y += relocate.o +endif ifndef CONFIG_SYS_GENERIC_BOARD COBJS-y += board.o endif @@ -38,11 +46,17 @@ else COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o endif
+ifdef CONFIG_ARM64 +COBJS-y += interrupts_64.o +else COBJS-y += interrupts.o +endif COBJS-y += reset.o
COBJS-y += cache.o +ifndef CONFIG_ARM64 COBJS-y += cache-cp15.o +endif
SRCS := $(GLSOBJS:.o=.S) $(GLCOBJS:.o=.c) \ $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 34f50b0..c4904b4 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -344,7 +344,7 @@ void board_init_f(ulong bootflag)
#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) /* reserve TLB table */ - gd->arch.tlb_size = 4096 * 4; + gd->arch.tlb_size = PGTABLE_SIZE; addr -= gd->arch.tlb_size;
/* round down to next 64 kB limit */ @@ -419,6 +419,7 @@ void board_init_f(ulong bootflag) } #endif
+#ifndef CONFIG_ARM64 /* setup stackpointer for exeptions */ gd->irq_sp = addr_sp; #ifdef CONFIG_USE_IRQ @@ -431,6 +432,10 @@ void board_init_f(ulong bootflag)
/* 8-byte alignment for ABI compliance */ addr_sp &= ~0x07; +#else /* CONFIG_ARM64 */ + /* 16-byte alignment for ABI compliance */ + addr_sp &= ~0x0f; +#endif /* CONFIG_ARM64 */ #else addr_sp += 128; /* leave 32 words for abort-stack */ gd->irq_sp = addr_sp; diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index f476a89..b372d99 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -240,6 +240,21 @@ static void boot_prep_linux(bootm_headers_t *images) /* Subcommand: GO */ static void boot_jump_linux(bootm_headers_t *images, int flag) { +#ifdef CONFIG_ARM64 + void (*kernel_entry)(void *fdt_addr); + int fake = (flag & BOOTM_STATE_OS_FAKE_GO); + + kernel_entry = (void (*)(void *fdt_addr))images->ep; + + debug("## Transferring control to Linux (at address %lx)...\n", + (ulong) kernel_entry); + bootstage_mark(BOOTSTAGE_ID_RUN_OS); + + announce_and_cleanup(fake); + + if (!fake) + kernel_entry(images->ft_addr); +#else unsigned long machid = gd->bd->bi_arch_number; char *s; void (*kernel_entry)(int zero, int arch, uint params); @@ -266,6 +281,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag)
if (!fake) kernel_entry(0, machid, r2); +#endif }
/* Main Entry point for arm bootm implementation diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S new file mode 100644 index 0000000..7756396 --- /dev/null +++ b/arch/arm/lib/crt0_64.S @@ -0,0 +1,113 @@ +/* + * crt0 - C-runtime startup Code for AArch64 U-Boot + * + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * (C) Copyright 2012 + * Albert ARIBAUD albert.u.boot@aribaud.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm-offsets.h> +#include <asm/macro.h> +#include <linux/linkage.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure, both located in some readily + * available RAM (SRAM, locked cache...). In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from system RAM (DRAM, DDR...) As system RAM may not + * be available yet, , board_init_f() must use the current GD to + * store any data which must be passed on to later stages. These + * data include the relocation destination, the future stack, and + * the future GD location. + * + * (the following applies only to non-SPL builds) + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in system RAM, but BSS and + * initialized non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in system + * RAM. GD has retained values set by board_init_f(). Some CPUs + * have some work left to do at this point regarding memory, so + * call c_runtime_cpu_setup. + * + * 6. Branch to board_init_r(). + */ + +ENTRY(_main) + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + ldr x0, =(CONFIG_SYS_INIT_SP_ADDR) + sub x0, x0, #GD_SIZE /* allocate one GD above SP */ + bic sp, x0, #0xf /* 16-byte alignment for ABI compliance */ + mov x18, sp /* GD is above SP */ + mov x0, #0 + bl board_init_f + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_moni). Trick here is that we'll return + * 'here' but relocated. + */ + ldr x0, [x18, #GD_START_ADDR_SP] /* x0 <- gd->start_addr_sp */ + bic sp, x0, #0xf /* 16-byte alignment for ABI compliance */ + ldr x18, [x18, #GD_BD] /* x18 <- gd->bd */ + sub x18, x18, #GD_SIZE /* new GD is below bd */ + + adr lr, relocation_return + ldr x9, [x18, #GD_RELOC_OFF] /* x9 <- gd->reloc_off */ + add lr, lr, x9 /* new return address after relocation */ + ldr x0, [x18, #GD_RELOCADDR] /* x0 <- gd->relocaddr */ + b relocate_code + +relocation_return: + +/* + * Set up final (full) environment + */ + bl c_runtime_cpu_setup /* still call old routine */ + +/* + * Clear BSS section + */ + ldr x0, =__bss_start /* this is auto-relocated! */ + ldr x1, =__bss_end /* this is auto-relocated! */ + mov x2, #0 +clear_loop: + str x2, [x0] + add x0, x0, #8 + cmp x0, x1 + b.lo clear_loop + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + mov x0, x18 /* gd_t */ + ldr x1, [x18, #GD_RELOCADDR] /* dest_addr */ + b board_init_r /* PC relative jump */ + + /* NOTREACHED - board_init_r() does not return */ + +ENDPROC(_main) diff --git a/arch/arm/lib/interrupts_64.c b/arch/arm/lib/interrupts_64.c new file mode 100644 index 0000000..b476722 --- /dev/null +++ b/arch/arm/lib/interrupts_64.c @@ -0,0 +1,120 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/compiler.h> + + +int interrupt_init(void) +{ + return 0; +} + +void enable_interrupts(void) +{ + return; +} + +int disable_interrupts(void) +{ + return 0; +} + +void show_regs(struct pt_regs *regs) +{ + int i; + + printf("ELR: %lx\n", regs->elr); + printf("LR: %lx\n", regs->regs[30]); + for (i = 0; i < 29; i += 2) + printf("x%-2d: %016lx x%-2d: %016lx\n", + i, regs->regs[i], i+1, regs->regs[i+1]); + printf("\n"); +} + +/* + * do_bad_sync handles the impossible case in the Synchronous Abort vector. + */ +void do_bad_sync(struct pt_regs *pt_regs, unsigned int esr) +{ + printf("Bad mode in "Synchronous Abort" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_bad_irq handles the impossible case in the Irq vector. + */ +void do_bad_irq(struct pt_regs *pt_regs, unsigned int esr) +{ + printf("Bad mode in "Irq" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_bad_fiq handles the impossible case in the Fiq vector. + */ +void do_bad_fiq(struct pt_regs *pt_regs, unsigned int esr) +{ + printf("Bad mode in "Fiq" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_bad_error handles the impossible case in the Error vector. + */ +void do_bad_error(struct pt_regs *pt_regs, unsigned int esr) +{ + printf("Bad mode in "Error" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_sync handles the Synchronous Abort exception. + */ +void do_sync(struct pt_regs *pt_regs, unsigned int esr) +{ + printf(""Synchronous Abort" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_irq handles the Irq exception. + */ +void do_irq(struct pt_regs *pt_regs, unsigned int esr) +{ + printf(""Irq" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_fiq handles the Fiq exception. + */ +void do_fiq(struct pt_regs *pt_regs, unsigned int esr) +{ + printf(""Fiq" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} + +/* + * do_error handles the Error exception. + * Errors are more likely to be processor specific, + * it is defined with weak attribute and can be redefined + * in processor specific code. + */ +void __weak do_error(struct pt_regs *pt_regs, unsigned int esr) +{ + printf(""Error" handler, esr 0x%08x\n", esr); + show_regs(pt_regs); + panic("Resetting CPU ...\n"); +} diff --git a/arch/arm/lib/relocate_64.S b/arch/arm/lib/relocate_64.S new file mode 100644 index 0000000..7fba9e2 --- /dev/null +++ b/arch/arm/lib/relocate_64.S @@ -0,0 +1,58 @@ +/* + * relocate - common relocation function for AArch64 U-Boot + * + * (C) Copyright 2013 + * Albert ARIBAUD albert.u.boot@aribaud.net + * David Feng fenghua@phytium.com.cn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> + +/* + * void relocate_code (addr_moni) + * + * This function relocates the monitor code. + * x0 holds the destination address. + */ +ENTRY(relocate_code) + /* + * Copy u-boot from flash to RAM + */ + ldr x1, =__image_copy_start /* x1 <- SRC &__image_copy_start */ + subs x9, x0, x1 /* x9 <- relocation offset */ + b.eq relocate_done /* skip relocation */ + ldr x2, =__image_copy_end /* x2 <- SRC &__image_copy_end */ + +copy_loop: + ldp x10, x11, [x1], #16 /* copy from source address [x1] */ + stp x10, x11, [x0], #16 /* copy to target address [x0] */ + cmp x1, x2 /* until source end address [x2] */ + b.lo copy_loop + + /* + * Fix .rela.dyn relocations + */ + ldr x2, =__rel_dyn_start /* x2 <- SRC &__rel_dyn_start */ + ldr x3, =__rel_dyn_end /* x3 <- SRC &__rel_dyn_end */ +fixloop: + ldp x0, x1, [x2], #16 /* (x0,x1) <- (SRC location, fixup) */ + ldr x4, [x2], #8 /* x4 <- addend */ + and x1, x1, #0xffffffff + cmp x1, #1027 /* relative fixup? */ + bne fixnext + + /* relative fix: store addend plus offset at dest location */ + add x0, x0, x9 + add x4, x4, x9 + str x4, [x0] +fixnext: + cmp x2, x3 + b.lo fixloop + +relocate_done: + ret +ENDPROC(relocate_code) diff --git a/common/image.c b/common/image.c index b0ae58f..4145354 100644 --- a/common/image.c +++ b/common/image.c @@ -81,6 +81,7 @@ static const table_entry_t uimage_arch[] = { { IH_ARCH_NDS32, "nds32", "NDS32", }, { IH_ARCH_OPENRISC, "or1k", "OpenRISC 1000",}, { IH_ARCH_SANDBOX, "sandbox", "Sandbox", }, + { IH_ARCH_ARM64, "arm64", "AArch64", }, { -1, "", "", }, };
diff --git a/doc/README.arm64 b/doc/README.arm64 new file mode 100644 index 0000000..b7800cb --- /dev/null +++ b/doc/README.arm64 @@ -0,0 +1,45 @@ +U-boot for arm64 + +Summary +======= +No hardware platform of arm64 is available now. The u-boot is +simulated on Foundation Model and Fast Model for ARMv8. + +Notes +===== + +1. Currenly, u-boot could be running at EL1 or EL2. + +2. U-boot for arm64 is compiled with AArch64-gcc. AArch64-gcc + use rela relocation format, a tool(tools/relocate-rela) by Scott Wood + is used to encode the initial addend of rela to u-boot.bin. After running, + the u-boot will be relocated to destination again. + +3. Fdt should be placed at a 2-megabyte boundary and within the first 512 + megabytes from the start of the kernel image. So, fdt_high should be + defined specially. + Please reference linux/Documentation/arm64/booting.txt for detail. + +4. Spin-table is used to wake up secondary processors. One location + (or per processor location) is defined to hold the kernel entry point + for secondary processors. It must be ensured that the location is + accessible and zero immediately after secondary processor + enter slave_cpu branch execution in start.S. The location address + is encoded in cpu node of DTS. Linux kernel store the entry point + of secondary processors to it and send event to wakeup secondary + processors. + Please reference linux/Documentation/arm64/booting.txt for detail. + +5. Generic board is supported. + +6. CONFIG_ARM64 instead of CONFIG_ARMV8 is used to distinguish aarch64 and + aarch32 specific codes. + +Contributor +=========== + Tom Rini trini@ti.com + Scott Wood scottwood@freescale.com + York Sun yorksun@freescale.com + Simon Glass sjg@chromium.org + Sharma Bhupesh bhupesh.sharma@freescale.com + Rob Herring robherring2@gmail.com diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index 8fb1765..fc5d7ef 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -39,6 +39,20 @@ gd_t *global_data; " bctr\n" \ : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r11"); #elif defined(CONFIG_ARM) +#ifdef CONFIG_ARM64 +/* + * x18 holds the pointer to the global_data, x9 is a call-clobbered + * register + */ +#define EXPORT_FUNC(x) \ + asm volatile ( \ +" .globl " #x "\n" \ +#x ":\n" \ +" ldr x9, [x18, %0]\n" \ +" ldr x9, [x9, %1]\n" \ +" br x9\n" \ + : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "x9"); +#else /* * r8 holds the pointer to the global_data, ip is a call-clobbered * register @@ -50,6 +64,7 @@ gd_t *global_data; " ldr ip, [r8, %0]\n" \ " ldr pc, [ip, %1]\n" \ : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "ip"); +#endif #elif defined(CONFIG_MIPS) /* * k0 ($26) holds the pointer to the global_data; t9 ($25) is a call- diff --git a/include/image.h b/include/image.h index ee6eb8d..7de2bb2 100644 --- a/include/image.h +++ b/include/image.h @@ -156,6 +156,7 @@ struct lmb; #define IH_ARCH_SANDBOX 19 /* Sandbox architecture (test only) */ #define IH_ARCH_NDS32 20 /* ANDES Technology - NDS32 */ #define IH_ARCH_OPENRISC 21 /* OpenRISC 1000 */ +#define IH_ARCH_ARM64 22 /* ARM64 */
/* * Image Types
Signed-off-by: David Feng fenghua@phytium.com.cn --- common/board_f.c | 20 +++++++++++++------- 1 file changed, 13 insertions(+), 7 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 0ada1af..d821dbe 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -458,7 +458,7 @@ static int reserve_round_4k(void) static int reserve_mmu(void) { /* reserve TLB table */ - gd->arch.tlb_size = 4096 * 4; + gd->arch.tlb_size = PGTABLE_SIZE; gd->relocaddr -= gd->arch.tlb_size;
/* round down to next 64 kB limit */ @@ -610,7 +610,7 @@ static int reserve_stacks(void) * TODO(sjg@chromium.org): Perhaps create arch_reserve_stack() * to handle this and put in arch/xxx/lib/stack.c */ -# ifdef CONFIG_ARM +# if defined(CONFIG_ARM) && !defined(CONFIG_ARM64) # ifdef CONFIG_USE_IRQ gd->start_addr_sp -= (CONFIG_STACKSIZE_IRQ + CONFIG_STACKSIZE_FIQ); debug("Reserving %zu Bytes for IRQ stack at: %08lx\n", @@ -807,11 +807,6 @@ static int mark_bootstage(void) }
static init_fnc_t init_sequence_f[] = { -#if !defined(CONFIG_CPM2) && !defined(CONFIG_MPC512X) && \ - !defined(CONFIG_MPC83xx) && !defined(CONFIG_MPC85xx) && \ - !defined(CONFIG_MPC86xx) && !defined(CONFIG_X86) - zero_global_data, -#endif #ifdef CONFIG_SANDBOX setup_ram_buf, #endif @@ -1005,6 +1000,17 @@ void board_init_f(ulong boot_flags) gd = &data; #endif
+ /* + * Clear global data before it is accessed at debug print + * in initcall_run_list. Otherwise the debug print probably + * get the wrong vaule of gd->have_console. + */ +#if !defined(CONFIG_CPM2) && !defined(CONFIG_MPC512X) && \ + !defined(CONFIG_MPC83xx) && !defined(CONFIG_MPC85xx) && \ + !defined(CONFIG_MPC86xx) && !defined(CONFIG_X86) + zero_global_data(); +#endif + gd->flags = boot_flags;
if (initcall_run_list(init_sequence_f))
Signed-off-by: David Feng fenghua@phytium.com.cn Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com --- board/armltd/vexpress64/Makefile | 27 +++++ board/armltd/vexpress64/vexpress64.c | 50 +++++++++ boards.cfg | 1 + include/configs/vexpress_aemv8a.h | 191 ++++++++++++++++++++++++++++++++++ 4 files changed, 269 insertions(+) create mode 100644 board/armltd/vexpress64/Makefile create mode 100644 board/armltd/vexpress64/vexpress64.c create mode 100644 include/configs/vexpress_aemv8a.h
diff --git a/board/armltd/vexpress64/Makefile b/board/armltd/vexpress64/Makefile new file mode 100644 index 0000000..f907c92 --- /dev/null +++ b/board/armltd/vexpress64/Makefile @@ -0,0 +1,27 @@ +# +# (C) Copyright 2000-2004 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := vexpress64.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c new file mode 100644 index 0000000..dae18d4 --- /dev/null +++ b/board/armltd/vexpress64/vexpress64.c @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * Sharma Bhupesh bhupesh.sharma@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <malloc.h> +#include <errno.h> +#include <netdev.h> +#include <asm/io.h> +#include <linux/compiler.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; +} + +int timer_init(void) +{ + return 0; +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ +} + +/* + * Board specific ethernet initialization routine. + */ +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC91111 + rc = smc91111_initialize(0, CONFIG_SMC91111_BASE); +#endif + return rc; +} diff --git a/boards.cfg b/boards.cfg index 85143c6..6d3dd69 100644 --- a/boards.cfg +++ b/boards.cfg @@ -383,6 +383,7 @@ Active arm pxa - - vpac270 Active arm pxa - icpdas lp8x4x lp8x4x - Sergey Yanovich ynvich@gmail.com Active arm pxa - toradex - colibri_pxa270 - Marek Vasut marek.vasut@gmail.com Active arm sa1100 - - - jornada - Kristoffer Ericson kristoffer.ericson@gmail.com +Active arm armv8 - armltd vexpress64 vexpress_aemv8a vexpress_aemv8a:ARM64 David Feng fenghua@phytium.com.cn Active avr32 at32ap at32ap700x atmel - atngw100 - Haavard Skinnemoen haavard.skinnemoen@atmel.com Active avr32 at32ap at32ap700x atmel - atngw100mkii - Andreas Bießmann andreas.devel@googlemail.com Active avr32 at32ap at32ap700x atmel atstk1000 atstk1002 - Haavard Skinnemoen haavard.skinnemoen@atmel.com diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h new file mode 100644 index 0000000..e93b00f --- /dev/null +++ b/include/configs/vexpress_aemv8a.h @@ -0,0 +1,191 @@ +/* + * Configuration for Versatile Express. Parts were derived from other ARM + * configurations. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __VEXPRESS_AEMV8A_H +#define __VEXPRESS_AEMV8A_H + +#define DEBUG + +#define CONFIG_REMAKE_ELF + +/*#define CONFIG_BOOTING_EL1*/ + +/*#define CONFIG_SYS_GENERIC_BOARD*/ + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SUPPORT_RAW_INITRD + +/* Cache Definitions */ +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_SYS_ICACHE_OFF + +#define CONFIG_IDENT_STRING " vexpress_aemv8a" +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv8.vexpress_aemv8a" + +/* Link Definitions */ +#define CONFIG_SYS_TEXT_BASE 0x80000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_LIBFDT + +#define CONFIG_DEFAULT_DEVICE_TREE vexpress64 + +/* SMP Definitions */ +#define CPU_RELEASE_ADDR 0x8007fff0 + +/* CS register bases for the original memory map. */ +#define V2M_PA_CS0 0x00000000 +#define V2M_PA_CS1 0x14000000 +#define V2M_PA_CS2 0x18000000 +#define V2M_PA_CS3 0x1c000000 +#define V2M_PA_CS4 0x0c000000 +#define V2M_PA_CS5 0x10000000 + +#define V2M_PERIPH_OFFSET(x) (x << 16) +#define V2M_SYSREGS (V2M_PA_CS3 + V2M_PERIPH_OFFSET(1)) +#define V2M_SYSCTL (V2M_PA_CS3 + V2M_PERIPH_OFFSET(2)) +#define V2M_SERIAL_BUS_PCI (V2M_PA_CS3 + V2M_PERIPH_OFFSET(3)) + +#define V2M_BASE 0x80000000 + +/* + * Physical addresses, offset from V2M_PA_CS0-3 + */ +#define V2M_NOR0 (V2M_PA_CS0) +#define V2M_NOR1 (V2M_PA_CS4) +#define V2M_SRAM (V2M_PA_CS1) + +/* Common peripherals relative to CS7. */ +#define V2M_AACI (V2M_PA_CS3 + V2M_PERIPH_OFFSET(4)) +#define V2M_MMCI (V2M_PA_CS3 + V2M_PERIPH_OFFSET(5)) +#define V2M_KMI0 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(6)) +#define V2M_KMI1 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(7)) + +#define V2M_UART0 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(9)) +#define V2M_UART1 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(10)) +#define V2M_UART2 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(11)) +#define V2M_UART3 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(12)) + +#define V2M_WDT (V2M_PA_CS3 + V2M_PERIPH_OFFSET(15)) + +#define V2M_TIMER01 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(17)) +#define V2M_TIMER23 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(18)) + +#define V2M_SERIAL_BUS_DVI (V2M_PA_CS3 + V2M_PERIPH_OFFSET(22)) +#define V2M_RTC (V2M_PA_CS3 + V2M_PERIPH_OFFSET(23)) + +#define V2M_CF (V2M_PA_CS3 + V2M_PERIPH_OFFSET(26)) + +#define V2M_CLCD (V2M_PA_CS3 + V2M_PERIPH_OFFSET(31)) + +/* System register offsets. */ +#define V2M_SYS_CFGDATA (V2M_SYSREGS + 0x0a0) +#define V2M_SYS_CFGCTRL (V2M_SYSREGS + 0x0a4) +#define V2M_SYS_CFGSTAT (V2M_SYSREGS + 0x0a8) + +/* Generic Timer Definitions */ +#define CONFIG_SYS_CNTFRQ (0x1800000) /* 24MHz */ + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE (0x2C001000) +#define GICC_BASE (0x2C002000) + +#define CONFIG_SYS_MEMTEST_START V2M_BASE +#define CONFIG_SYS_MEMTEST_END (V2M_BASE + 0x80000000) + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) + +/* SMSC9115 Ethernet from SMSC9118 family */ +#define CONFIG_SMC9111 1 +#define CONFIG_SMC9111_BASE (0x1a000000) + +/* PL011 Serial Configuration */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ + (void *)CONFIG_SYS_SERIAL1} +#define CONFIG_CONS_INDEX 0 + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#define CONFIG_SYS_SERIAL0 V2M_UART0 +#define CONFIG_SYS_SERIAL1 V2M_UART1 + +/* Command line configuration */ +#define CONFIG_MENU +/*#define CONFIG_MENU_SHOW*/ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_BDI +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PXE +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_IMI +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_RUN +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_SOURCE +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_PXE +#define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (V2M_BASE + 0x10000000) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 (V2M_BASE) /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2048 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#define CONFIG_SYS_HZ 1000 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "console=ttyAMA0,38400n8\0" + +#define CONFIG_BOOTARGS "console=ttyAMA0 root=/dev/ram0" +#define CONFIG_BOOTCOMMAND "bootm $kernel_addr $ramdisk_addr:$ramdisk_size" +#define CONFIG_BOOTDELAY -1 + +/* Store environment at top of flash */ +#define CONFIG_ENV_IS_NOWHERE 1 +#define CONFIG_ENV_SIZE 0x1000 + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PROMPT "VExpress# " +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#endif /* __VEXPRESS_AEMV8A_H */
Signed-off-by: David Feng fenghua@phytium.com.cn --- MAKEALL | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/MAKEALL b/MAKEALL index 956f3da..cb414ca 100755 --- a/MAKEALL +++ b/MAKEALL @@ -370,6 +370,12 @@ LIST_ARM11="$(boards_by_cpu arm1136) \ LIST_ARMV7="$(boards_by_cpu armv7)"
######################################################################### +## ARMV8 Systems +######################################################################### + +LIST_ARMV8="$(boards_by_cpu armv8)" + +######################################################################### ## AT91 Systems #########################################################################
@@ -393,7 +399,11 @@ LIST_spear="$(boards_by_soc spear)" ## ARM groups #########################################################################
-LIST_arm="$(boards_by_arch arm)" +LIST_arm="$(boards_by_arch arm | \ + for ARMV8_BOARD in $LIST_ARMV8; \ + do sed "/$ARMV8_BOARD/d"; \ + done) \ +"
######################################################################### ## MIPS Systems (default = big endian)
On 10/14/2013 08:34 PM, fenghua@phytium.com.cn wrote:
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood scottwood@freescale.com
arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Makefile | 38 +++++ arch/arm/cpu/armv8/cache.S | 130 +++++++++++++++++
<snip>
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S new file mode 100644 index 0000000..419f169 --- /dev/null +++ b/arch/arm/cpu/armv8/cache.S @@ -0,0 +1,130 @@ +/*
- (C) Copyright 2013
- David Feng fenghua@phytium.com.cn
+#include <asm-offsets.h> +#include <config.h> +#include <version.h> +#include <asm/macro.h> +#include <linux/linkage.h>
- void __asm_flush_dcache_level(level)
- clean and invalidate one level cache.
- x0: cache level
- x1~x9: clobbered
+ENTRY(__asm_flush_dcache_level)
- lsl x1, x0, #1
- msr csselr_el1, x1 /* select cache level */
- isb /* isb to sych the new cssr & csidr */
- mrs x6, ccsidr_el1 /* read the new ccsidr */
- and x2, x6, #7 /* x2 <- length of the cache lines */
- add x2, x2, #4 /* add 4 (line length offset) */
- mov x3, #0x3ff
- and x3, x3, x6, lsr #3 /* x3 <- maximum number of way size */
- clz w5, w3 /* bit position of way size */
- mov x4, #0x7fff
- and x4, x4, x1, lsr #13 /* x4 <- max number of the set size */
Shouldn't this x1 be x6?
- /* x1 <- cache level << 1 */
- /* x2 <- line length offset */
- /* x3 <- number of cache ways */
- /* x4 <- number of cache sets */
- /* x5 <- bit position of way size */
+loop_set:
- mov x6, x3 /* create working copy of way size */
+loop_way:
- lsl x7, x6, x5
- orr x9, x0, x7 /* map way and level to cisw value */
Shouldn't this x0 be x1?
- lsl x7, x4, x2
- orr x9, x9, x7 /* map set number to cisw value */
- dc cisw, x9 /* clean & invalidate by set/way */
- subs x6, x6, #1 /* decrement the way */
- b.ge loop_way
- subs x4, x4, #1 /* decrement the set */
- b.ge loop_set
- ret
+ENDPROC(__asm_flush_dcache_level)
I haven't been able to verify this change. It simply takes too long to finish on emulator.
York
- x0: cache level
- x1~x9: clobbered
- lsl x1, x0, #1
- mov x3, #0x3ff
You should round up (so "add w3, w3, w3; sub w3, w3, #1" before clz), since the architecture allows non-power-of-2 values for #sets/#ways.
Also s/way size/#ways/ and s/set size/#sets/
When I see "set size" I think of the number of ways times the size of a cache line, not the number of sets.
BTW, I see some very similar comments, register usage, and code structure in the Linux code. Are you *sure* this code wasn't derived from it (or some other common source)? Do we need to start from scratch, if we can't trust that you're identifying all the code that you didn't write yourself? You were asked several times to do so.
+loop_level:
- lsl x1, x0, #1
- add x1, x1, x0 /* x0 <- 3x cache level */
Comment says x0 gets "3x cache level", but the value is placed in x1.
- sub x3, x2, #1
- bic x0, x0, x3
+1: dc civac, x0 /* clean & invalidate D/unified line */
- add x0, x0, x2
Whitespace
- /* load TTBR0 */
- el = curent_el();
- if (el == 1)
asm volatile("msr ttbr0_el1, %0"
: : "r" (gd->arch.tlb_addr) : "memory");
- else if (el == 2)
asm volatile("msr ttbr0_el2, %0"
- else
Do we really need to support running in either el1 or el2 at runtime, throughout U-Boot? If Linux is started in el2, it enters el1 after setting up exception vectors to get control back if it needs to. Can't we do the same (and go back to el2 if available immediately before entering an OS)? Assuming we don't want to just set the expected exception level at compile time.
-Scott
Hi David,
arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Makefile | 38 +++++ arch/arm/cpu/armv8/cache.S | 130 +++++++++++++++++ arch/arm/cpu/armv8/cache_v8.c | 218 ++++++++++++++++++++++++++++ arch/arm/cpu/armv8/config.mk | 15 ++ arch/arm/cpu/armv8/cpu.c | 67 +++++++++ arch/arm/cpu/armv8/exceptions.S | 112 +++++++++++++++ arch/arm/cpu/armv8/start.S | 234 +++++++++++++++++++++++++++++++ arch/arm/cpu/armv8/timer.c | 80 +++++++++++ arch/arm/cpu/armv8/tlb.S | 30 ++++ arch/arm/cpu/armv8/u-boot.lds | 89 ++++++++++++ arch/arm/include/asm/armv8/mmu.h | 110 +++++++++++++++ arch/arm/include/asm/byteorder.h | 12 ++ arch/arm/include/asm/cache.h | 5 + arch/arm/include/asm/config.h | 6 + arch/arm/include/asm/global_data.h | 6 +- arch/arm/include/asm/io.h | 15 +- arch/arm/include/asm/macro.h | 36 +++++ arch/arm/include/asm/posix_types.h | 10 ++ arch/arm/include/asm/proc-armv/ptrace.h | 21 +++ arch/arm/include/asm/proc-armv/system.h | 59 +++++++- arch/arm/include/asm/system.h | 77 ++++++++++ arch/arm/include/asm/types.h | 4 + arch/arm/include/asm/u-boot.h | 4 + arch/arm/include/asm/unaligned.h | 2 +- arch/arm/lib/Makefile | 14 ++ arch/arm/lib/board.c | 7 +- arch/arm/lib/bootm.c | 16 +++ arch/arm/lib/crt0_64.S | 113 +++++++++++++++ arch/arm/lib/interrupts_64.c | 120 ++++++++++++++++ arch/arm/lib/relocate_64.S | 58 ++++++++ common/image.c | 1 + doc/README.arm64 | 45 ++++++ examples/standalone/stubs.c | 15 ++ include/image.h | 1 + 35 files changed, 1762 insertions(+), 11 deletions(-)
I think this series needs to be rebased to mainline now. I also found that it did not build for armv7 past this commit - if it helps I did a bit of tweaking and pushed a branch to 'armv8' at u-boot-x86.git.
Scott Wood
York Sun
