[PATCH] ARM: stm32: Add additional ID register check for KSZ8851 presence
Currently the code sets eth1addr only if /ethernet1 alias exists in DT, the node pointed to by the alias has "micrel,ks8851-mll" compatible string, and the KSZ8851 CCR register read indicates programmed EEPROM is not connected.
This is not sufficient to detect cases where the DT still contains the KSZ8851 nodes, but the chip itself is not present. Extend the detection to handle these cases.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@st.com Cc: Patrick Delaunay patrick.delaunay@st.com --- board/dhelectronics/dh_stm32mp1/board.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 49b12c4c042..ac1af718d4a 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -86,6 +86,8 @@ DECLARE_GLOBAL_DATA_PTR; #define KS_CCR_EEPROM BIT(9) #define KS_BE0 BIT(12) #define KS_BE1 BIT(13) +#define KS_CIDER 0xC0 +#define CIDER_ID 0x8870
int setup_mac_address(void) { @@ -123,11 +125,18 @@ int setup_mac_address(void) * is present. If EEPROM is present, it must contain valid * MAC address. */ - u32 reg, ccr; + u32 reg, cider, ccr; reg = fdt_get_base_address(gd->fdt_blob, off); if (!reg) goto out_set_ethaddr;
+ writew(KS_BE0 | KS_BE1 | KS_CIDER, reg + 2); + cider = readw(reg); + if ((cider & 0xfff0) != CIDER_ID) { + skip_eth1 = true; + goto out_set_ethaddr; + } + writew(KS_BE0 | KS_BE1 | KS_CCR, reg + 2); ccr = readw(reg); if (ccr & KS_CCR_EEPROM) {
Hi Marek
Can you resend this patch to our @foss.st.com email address please ?
Thanks Patrice ________________________________ De : Marek Vasut marex@denx.de Envoyé : vendredi 30 avril 2021 13:29 À : u-boot@lists.denx.de u-boot@lists.denx.de Cc : Marek Vasut marex@denx.de; Patrice CHOTARD patrice.chotard@st.com; Patrick DELAUNAY patrick.delaunay@st.com Objet : [PATCH] ARM: stm32: Add additional ID register check for KSZ8851 presence
+ writew(KS_BE0 | KS_BE1 | KS_CIDER, reg + 2); + cider = readw(reg); + if ((cider & 0xfff0) != CIDER_ID) { + skip_eth1 = true; + goto out_set_ethaddr; + } + writew(KS_BE0 | KS_BE1 | KS_CCR, reg + 2); ccr = readw(reg); if (ccr & KS_CCR_EEPROM) { -- 2.30.2
ST Restricted
Patrice CHOTARD
