[PATCH u-boot-dm v4] fdt_support: Add fdt_for_each_node_by_compatible() helper macro
Add macro fdt_for_each_node_by_compatible() to allow iterating over fdt nodes by compatible string.
Convert various usages of off = fdt_node_offset_by_compatible(fdt, start, compat); while (off > 0) { code(); off = fdt_node_offset_by_compatible(fdt, off, compat); } and similar, to fdt_for_each_node_by_compatible(off, fdt, start, compat) code();
Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- Dear Stefan, fixed and tested on GitHub CI: https://github.com/u-boot/u-boot/pull/105 Hopefully this time it works :-)
As in v3, to resolve conflict with Tom's master, change CONFIG_SYS_CLK_FREQ to get_board_sys_clk() --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 9 ++------- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 5 +---- arch/arm/mach-tegra/gpu.c | 5 +---- arch/mips/mach-octeon/octeon_fdt.c | 11 ++--------- arch/powerpc/cpu/mpc85xx/liodn.c | 9 ++------- board/Marvell/octeon_ebb7304/board.c | 9 +++------ board/congatec/cgtqmx8/spl.c | 8 +++----- board/freescale/lx2160a/lx2160a.c | 5 +---- common/fdt_support.c | 22 ++++++++-------------- drivers/misc/fsl_portals.c | 6 +----- drivers/net/fm/fdt.c | 3 +-- drivers/pci/pcie_layerscape_fixup_common.c | 12 ++---------- drivers/phy/marvell/comphy_a3700.c | 12 ++++++------ drivers/video/meson/simplefb_common.c | 9 +++------ drivers/video/sunxi/simplefb_common.c | 7 +++---- include/fdt_support.h | 6 ++++++ 16 files changed, 45 insertions(+), 93 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 4354aa251e..2fa7ebf163 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -161,14 +161,9 @@ void fsl_fdt_disable_usb(void *blob) * controller is used, SYSCLK must meet the additional requirement * of 100 MHz. */ - if (CONFIG_SYS_CLK_FREQ != 100000000) { - off = fdt_node_offset_by_compatible(blob, -1, "snps,dwc3"); - while (off != -FDT_ERR_NOTFOUND) { + if (CONFIG_SYS_CLK_FREQ != 100000000) + fdt_for_each_node_by_compatible(off, blob, -1, "snps,dwc3") fdt_status_disabled(blob, off); - off = fdt_node_offset_by_compatible(blob, off, - "snps,dwc3"); - } - } }
#ifdef CONFIG_HAS_FEATURE_GIC64K_ALIGN diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c index 82c5a8b123..25cd82f16e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/icid.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -116,8 +116,7 @@ void fdt_fixup_fman_port_icid_by_compat(void *blob, int smmu_ph, int noff, len, icid; const u32 *prop;
- noff = fdt_node_offset_by_compatible(blob, -1, compat); - while (noff > 0) { + fdt_for_each_node_by_compatible(noff, blob, -1, compat) { prop = fdt_getprop(blob, noff, "cell-index", &len); if (!prop) { printf("WARNING missing cell-index for fman port\n"); @@ -137,8 +136,6 @@ void fdt_fixup_fman_port_icid_by_compat(void *blob, int smmu_ph, }
fdt_set_iommu_prop(blob, noff, smmu_ph, (u32 *)&icid, 1); - - noff = fdt_node_offset_by_compatible(blob, noff, compat); } }
diff --git a/arch/arm/mach-tegra/gpu.c b/arch/arm/mach-tegra/gpu.c index 13ffade040..36538e7f96 100644 --- a/arch/arm/mach-tegra/gpu.c +++ b/arch/arm/mach-tegra/gpu.c @@ -46,11 +46,8 @@ int tegra_gpu_enable_node(void *blob, const char *compat) if (!_configured) return 0;
- offset = fdt_node_offset_by_compatible(blob, -1, compat); - while (offset != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(offset, blob, -1, compat) fdt_status_okay(blob, offset); - offset = fdt_node_offset_by_compatible(blob, offset, compat); - }
return 0; } diff --git a/arch/mips/mach-octeon/octeon_fdt.c b/arch/mips/mach-octeon/octeon_fdt.c index 199f692516..5c5a14e87a 100644 --- a/arch/mips/mach-octeon/octeon_fdt.c +++ b/arch/mips/mach-octeon/octeon_fdt.c @@ -424,12 +424,8 @@ void __octeon_fixup_fdt_mac_addr(void) }
/* Assign 78XX addresses in the order they appear in the device tree. */ - node = fdt_node_offset_by_compatible(working_fdt, -1, "cavium,octeon-7890-bgx-port"); - while (node != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(node, working_fdt, -1, "cavium,octeon-7890-bgx-port") octeon_set_one_fdt_mac(node, &mac); - node = fdt_node_offset_by_compatible(working_fdt, node, - "cavium,octeon-7890-bgx-port"); - } } #endif
@@ -450,11 +446,8 @@ void __octeon_fixup_fdt_uart(void) /* Device trees already have good values for fast simulator * output, real boards need the correct value. */ - node = fdt_node_offset_by_compatible(working_fdt, -1, "cavium,octeon-3860-uart"); - while (node != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(node, working_fdt, -1, "cavium,octeon-3860-uart") fdt_setprop_inplace_cell(working_fdt, node, "clock-frequency", clk); - node = fdt_node_offset_by_compatible(working_fdt, node, "cavium,octeon-3860-uart"); - } }
/** diff --git a/arch/powerpc/cpu/mpc85xx/liodn.c b/arch/powerpc/cpu/mpc85xx/liodn.c index e552378e78..a084002494 100644 --- a/arch/powerpc/cpu/mpc85xx/liodn.c +++ b/arch/powerpc/cpu/mpc85xx/liodn.c @@ -268,15 +268,10 @@ static void fdt_fixup_pci_liodn_offsets(void *fdt, const char *compat, * Count the number of pci nodes. * It's needed later when the interleaved liodn offsets are generated. */ - off = fdt_node_offset_by_compatible(fdt, -1, compat); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, fdt, -1, compat) pci_cnt++; - off = fdt_node_offset_by_compatible(fdt, off, compat); - }
- for (off = fdt_node_offset_by_compatible(fdt, -1, compat); - off != -FDT_ERR_NOTFOUND; - off = fdt_node_offset_by_compatible(fdt, off, compat)) { + fdt_for_each_node_by_compatible(off, fdt, -1, compat) { base_liodn = fdt_getprop(fdt, off, "fsl,liodn", &rc); if (!base_liodn) { char path[64]; diff --git a/board/Marvell/octeon_ebb7304/board.c b/board/Marvell/octeon_ebb7304/board.c index c6c7c13483..5fd84b260b 100644 --- a/board/Marvell/octeon_ebb7304/board.c +++ b/board/Marvell/octeon_ebb7304/board.c @@ -103,9 +103,7 @@ static int get_lmac_fdt_node(const void *fdt, int search_node, int search_bgx, i int parent;
/* Iterate through all bgx ports */ - node = -1; - while ((node = fdt_node_offset_by_compatible((void *)fdt, node, - compat)) >= 0) { + fdt_for_each_node_by_compatible(node, (void *)fdt, -1, compat) { /* Get the node and bgx from the physical address */ parent = fdt_parent_offset(fdt, node); reg = fdt_getprop(fdt, parent, "reg", &len); @@ -146,9 +144,8 @@ static int get_mix_fdt_node(const void *fdt, int search_node, int search_index) int node;
/* Iterate through all the mix fdt nodes */ - node = -1; - while ((node = fdt_node_offset_by_compatible((void *)fdt, node, - "cavium,octeon-7890-mix")) >= 0) { + fdt_for_each_node_by_compatible(node, (void *)fdt, -1, + "cavium,octeon-7890-mix") { int parent; int len; const char *name; diff --git a/board/congatec/cgtqmx8/spl.c b/board/congatec/cgtqmx8/spl.c index 37b7221c52..dea34e4dc6 100644 --- a/board/congatec/cgtqmx8/spl.c +++ b/board/congatec/cgtqmx8/spl.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <fdt_support.h> #include <init.h> #include <log.h> #include <spl.h> @@ -29,13 +30,10 @@ void spl_board_init(void) continue; }
- offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "nxp,imx8-pd"); - while (offset != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(offset, gd->fdt_blob, -1, + "nxp,imx8-pd") lists_bind_fdt(gd->dm_root, offset_to_ofnode(offset), NULL, NULL, true); - offset = fdt_node_offset_by_compatible(gd->fdt_blob, offset, - "nxp,imx8-pd"); - }
uclass_find_first_device(UCLASS_POWER_DOMAIN, &dev);
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index bda665624d..c9835f9299 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -123,8 +123,7 @@ int board_fix_fdt(void *fdt) if (IS_SVR_REV(get_svr(), 1, 0)) return 0;
- off = fdt_node_offset_by_compatible(fdt, -1, "fsl,lx2160a-pcie"); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie") { fdt_setprop(fdt, off, "compatible", "fsl,ls-pcie", strlen("fsl,ls-pcie") + 1);
@@ -166,8 +165,6 @@ int board_fix_fdt(void *fdt) }
fdt_setprop(fdt, off, "reg-names", reg_names, names_len); - off = fdt_node_offset_by_compatible(fdt, off, - "fsl,lx2160a-pcie"); }
return 0; diff --git a/common/fdt_support.c b/common/fdt_support.c index c6b93e7889..77ee3ea051 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -371,12 +371,9 @@ void do_fixup_by_compat(void *fdt, const char *compat, debug(" %.2x", *(u8*)(val+i)); debug("\n"); #endif - off = fdt_node_offset_by_compatible(fdt, -1, compat); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, fdt, -1, compat) if (create || (fdt_get_property(fdt, off, prop, NULL) != NULL)) fdt_setprop(fdt, off, prop, val, len); - off = fdt_node_offset_by_compatible(fdt, off, compat); - } }
void do_fixup_by_compat_u32(void *fdt, const char *compat, @@ -996,10 +993,9 @@ void fdt_fixup_mtdparts(void *blob, const struct node_info *node_info,
for (i = 0; i < node_info_size; i++) { idx = 0; - noff = -1;
- while ((noff = fdt_node_offset_by_compatible(blob, noff, - node_info[i].compat)) >= 0) { + fdt_for_each_node_by_compatible(noff, blob, -1, + node_info[i].compat) { const char *prop;
prop = fdt_getprop(blob, noff, "status", NULL); @@ -1473,14 +1469,12 @@ out: int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off) { - int len, off = fdt_node_offset_by_compatible(blob, -1, compat); - while (off != -FDT_ERR_NOTFOUND) { + int len, off; + + fdt_for_each_node_by_compatible(off, blob, -1, compat) { const fdt32_t *reg = fdt_getprop(blob, off, "reg", &len); - if (reg) { - if (compat_off == fdt_translate_address(blob, off, reg)) - return off; - } - off = fdt_node_offset_by_compatible(blob, off, compat); + if (reg && compat_off == fdt_translate_address(blob, off, reg)) + return off; }
return -FDT_ERR_NOTFOUND; diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c index 02bc3f86ca..59df57a9ac 100644 --- a/drivers/misc/fsl_portals.c +++ b/drivers/misc/fsl_portals.c @@ -208,8 +208,7 @@ void fdt_fixup_qportals(void *blob) maj, min, ip_cfg) + 1; compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1;
- off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, blob, -1, "fsl,qman-portal") { #if defined(CONFIG_PPC) || defined(CONFIG_ARCH_LS1043A) || \ defined(CONFIG_ARCH_LS1046A) #ifdef CONFIG_FSL_CORENET @@ -295,9 +294,6 @@ err: fdt_strerror(err)); return; } - - off = fdt_node_offset_by_compatible(blob, off, - "fsl,qman-portal"); } }
diff --git a/drivers/net/fm/fdt.c b/drivers/net/fm/fdt.c index 3855d7d58f..9828753412 100644 --- a/drivers/net/fm/fdt.c +++ b/drivers/net/fm/fdt.c @@ -115,8 +115,7 @@ void fdt_fixup_fman_firmware(void *blob) }
/* Find all other Fman nodes and point them to the firmware node. */ - while ((fmnode = fdt_node_offset_by_compatible(blob, fmnode, - "fsl,fman")) > 0) { + fdt_for_each_node_by_compatible(fmnode, blob, fmnode, "fsl,fman") { rc = fdt_setprop_cell(blob, fmnode, "fsl,firmware-phandle", phandle); if (rc < 0) { diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index faccf6c141..095874a927 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -48,8 +48,7 @@ static int lx2_board_fix_fdt(void *fdt) const fdt32_t *prop; u32 ob_wins, ib_wins;
- off = fdt_node_offset_by_compatible(fdt, -1, "fsl,lx2160a-pcie"); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie") { fdt_setprop(fdt, off, "compatible", "fsl,ls2088a-pcie", strlen("fsl,ls2088a-pcie") + 1);
@@ -89,14 +88,10 @@ static int lx2_board_fix_fdt(void *fdt) fdt_setprop(fdt, off, "reg-names", reg_names, names_len); fdt_delprop(fdt, off, "apio-wins"); fdt_delprop(fdt, off, "ppio-wins"); - off = fdt_node_offset_by_compatible(fdt, off, - "fsl,lx2160a-pcie"); }
/* Fixup PCIe EP nodes */ - off = -1; - off = fdt_node_offset_by_compatible(fdt, off, "fsl,lx2160a-pcie-ep"); - while (off != -FDT_ERR_NOTFOUND) { + fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie-ep") { fdt_setprop_string(fdt, off, "compatible", "fsl,lx2160ar2-pcie-ep"); prop = fdt_getprop(fdt, off, "apio-wins", NULL); @@ -113,9 +108,6 @@ static int lx2_board_fix_fdt(void *fdt) fdt_setprop_u32(fdt, off, "num-ib-windows", ib_wins); fdt_setprop_u32(fdt, off, "num-ob-windows", ob_wins); fdt_delprop(fdt, off, "apio-wins"); - - off = fdt_node_offset_by_compatible(fdt, off, - "fsl,lx2160a-pcie-ep"); }
return 0; diff --git a/drivers/phy/marvell/comphy_a3700.c b/drivers/phy/marvell/comphy_a3700.c index 4104353555..7cde59b8e2 100644 --- a/drivers/phy/marvell/comphy_a3700.c +++ b/drivers/phy/marvell/comphy_a3700.c @@ -4,7 +4,7 @@ */
#include <common.h> -#include <fdtdec.h> +#include <fdt_support.h> #include <log.h> #include <asm/global_data.h> #include <asm/io.h> @@ -985,12 +985,12 @@ void comphy_dedicated_phys_init(void)
static int find_available_node_by_compatible(int offset, const char *compatible) { - do { - offset = fdt_node_offset_by_compatible(gd->fdt_blob, offset, - compatible); - } while (offset > 0 && !fdtdec_get_is_enabled(gd->fdt_blob, offset)); + fdt_for_each_node_by_compatible(offset, gd->fdt_blob, offset, + compatible) + if (fdtdec_get_is_enabled(gd->fdt_blob, offset)) + return offset;
- return offset; + return -1; }
static bool comphy_a3700_find_lane(const int nodes[3], int node, diff --git a/drivers/video/meson/simplefb_common.c b/drivers/video/meson/simplefb_common.c index 81782326d4..c8b5af501d 100644 --- a/drivers/video/meson/simplefb_common.c +++ b/drivers/video/meson/simplefb_common.c @@ -7,22 +7,19 @@ * (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io */
int meson_simplefb_fdt_match(void *blob, const char *pipeline) { int offset, ret;
/* Find a prefilled simpefb node, matching out pipeline config */ - offset = fdt_node_offset_by_compatible(blob, -1, - "amlogic,simple-framebuffer"); - while (offset >= 0) { + fdt_for_each_node_by_compatible(offset, blob, -1, + "amlogic,simple-framebuffer") { ret = fdt_stringlist_search(blob, offset, "amlogic,pipeline", pipeline); if (ret == 0) break; - offset = fdt_node_offset_by_compatible(blob, offset, - "amlogic,simple-framebuffer"); }
return offset; diff --git a/drivers/video/sunxi/simplefb_common.c b/drivers/video/sunxi/simplefb_common.c index df6501e4c3..ce0dc8f171 100644 --- a/drivers/video/sunxi/simplefb_common.c +++ b/drivers/video/sunxi/simplefb_common.c @@ -7,7 +7,7 @@ * (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io */
int sunxi_simplefb_fdt_match(void *blob, const char *pipeline) { @@ -16,13 +16,12 @@ int sunxi_simplefb_fdt_match(void *blob, const char *pipeline) /* Find a prefilled simpefb node, matching out pipeline config */ offset = fdt_node_offset_by_compatible(blob, -1, "allwinner,simple-framebuffer"); - while (offset >= 0) { + fdt_for_each_node_by_compatible(offset, blob, -1, + "allwinner,simple-framebuffer") { ret = fdt_stringlist_search(blob, offset, "allwinner,pipeline", pipeline); if (ret == 0) break; - offset = fdt_node_offset_by_compatible(blob, offset, - "allwinner,simple-framebuffer"); }
return offset; diff --git a/include/fdt_support.h b/include/fdt_support.h index 8ec461af6c..852040f66f 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -289,6 +289,12 @@ int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off); int fdt_node_offset_by_pathf(void *blob, const char *fmt, ...) __attribute__ ((format (printf, 2, 3))); + +#define fdt_for_each_node_by_compatible(node, fdt, start, compat) \ + for (node = fdt_node_offset_by_compatible(fdt, start, compat); \ + node >= 0; \ + node = fdt_node_offset_by_compatible(fdt, node, compat)) + int fdt_set_phandle(void *fdt, int nodeoffset, uint32_t phandle); unsigned int fdt_create_phandle(void *fdt, int nodeoffset); unsigned int fdt_create_phandle_by_compatible(void *fdt, const char *compat);
Applied to u-boot-marvell/master
Thanks, Stefan
"snps,dwc3");
- fdt_for_each_node_by_compatible(noff, blob, -1, compat) { prop = fdt_getprop(blob, noff, "cell-index", &len); if (!prop) { printf("WARNING missing cell-index for fman port\n");
} }noff = fdt_node_offset_by_compatible(blob, noff, compat);
- fdt_for_each_node_by_compatible(offset, blob, -1, compat) fdt_status_okay(blob, offset);
return 0; }
- fdt_for_each_node_by_compatible(node, working_fdt, -1, "cavium,octeon-7890-bgx-port") octeon_set_one_fdt_mac(node, &mac);
- } } #endif
- fdt_for_each_node_by_compatible(node, working_fdt, -1, "cavium,octeon-3860-uart") fdt_setprop_inplace_cell(working_fdt, node, "clock-frequency", clk);
- fdt_for_each_node_by_compatible(off, fdt, -1, compat) pci_cnt++;
- fdt_for_each_node_by_compatible(off, fdt, -1, compat) { base_liodn = fdt_getprop(fdt, off, "fsl,liodn", &rc); if (!base_liodn) { char path[64];
- node = -1;
compat)) >= 0) {
- fdt_for_each_node_by_compatible(node, (void *)fdt, -1, compat) { /* Get the node and bgx from the physical address */ parent = fdt_parent_offset(fdt, node); reg = fdt_getprop(fdt, parent, "reg", &len);
- node = -1;
int parent; int len; const char *name;"cavium,octeon-7890-mix") {
- fdt_for_each_node_by_compatible(offset, gd->fdt_blob, -1,
lists_bind_fdt(gd->dm_root, offset_to_ofnode(offset), NULL, NULL, true);"nxp,imx8-pd")
"nxp,imx8-pd");
- fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie") { fdt_setprop(fdt, off, "compatible", "fsl,ls-pcie", strlen("fsl,ls-pcie") + 1);
- fdt_for_each_node_by_compatible(off, fdt, -1, compat) if (create || (fdt_get_property(fdt, off, prop, NULL) != NULL)) fdt_setprop(fdt, off, prop, val, len);
noff = -1;
node_info[i].compat) { const char *prop; prop = fdt_getprop(blob, noff, "status", NULL);
- int len, off;
- fdt_for_each_node_by_compatible(off, blob, -1, compat) { const fdt32_t *reg = fdt_getprop(blob, off, "reg", &len);
if (reg) {
return off;
return off;
- fdt_for_each_node_by_compatible(off, blob, -1, "fsl,qman-portal") { #if defined(CONFIG_PPC) || defined(CONFIG_ARCH_LS1043A) || \ defined(CONFIG_ARCH_LS1046A) #ifdef CONFIG_FSL_CORENET
} }"fsl,qman-portal");
"fsl,fman")) > 0) {
- fdt_for_each_node_by_compatible(fmnode, blob, fmnode, "fsl,fman") { rc = fdt_setprop_cell(blob, fmnode, "fsl,firmware-phandle", phandle); if (rc < 0) {
- fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie") { fdt_setprop(fdt, off, "compatible", "fsl,ls2088a-pcie", strlen("fsl,ls2088a-pcie") + 1);
off = -1;
- fdt_for_each_node_by_compatible(off, fdt, -1, "fsl,lx2160a-pcie-ep") { fdt_setprop_string(fdt, off, "compatible", "fsl,lx2160ar2-pcie-ep"); prop = fdt_getprop(fdt, off, "apio-wins", NULL);
- do {
compatible);
- fdt_for_each_node_by_compatible(offset, gd->fdt_blob, offset,
compatible)
return offset;
- return offset;
return -1; }
- (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io
ret = fdt_stringlist_search(blob, offset, "amlogic,pipeline", pipeline); if (ret == 0) break;"amlogic,simple-framebuffer") {
return offset;
ret = fdt_stringlist_search(blob, offset, "allwinner,pipeline", pipeline); if (ret == 0) break;"allwinner,simple-framebuffer") {
return offset;
- for (node = fdt_node_offset_by_compatible(fdt, start, compat); \
node >= 0; \
- int fdt_set_phandle(void *fdt, int nodeoffset, uint32_t phandle); unsigned int fdt_create_phandle(void *fdt, int nodeoffset); unsigned int fdt_create_phandle_by_compatible(void *fdt, const char *compat);
Viele Grüße, Stefan Roese
Marek Behún
Stefan Roese
