Hi!
looking at the redness of the output of `make W=1` here is the question: isn't it a good time to enable `make W=1` by default. Yes, I understand the impact, but at least we can do it mandatory for a _new_ code submitted to U-Boot, right?
Ideally I would have what Linux kernel has for a few releases already, i.e. Werror by default and getting close to make a clean builds with that and make W=1` at least against default configurations (yeah, with U-Boot there is probably no default, but sandbox one).
Hi Andy,
On Mon, 21 Oct 2024 at 16:27, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Hi!
Warnings should be warnings...if you would like to enable it for CI that is fine by me, but the U-Boot makefile shouldn't do it. It defeats the purpose of having a distinction between errors and warnings.
On 10/21/24 18:32, Simon Glass wrote:
Hi Andy,
Hi!
Most contributors don't have access to our CI.
doc/develop/sending_patches.rst does not indicate that patches leading to build warnings won't be accepted.
We should at least amend the documentation.
Best regards
Heinrich
Hi Andy,
Hi!
Yes, please, someone.
Yes, and ideally the code should not have warnings, right?
Otherwise how can we do better? It's quite similar to what you wrote WRT documenting the function prototypes, the same applies to the new contribution WRT `make W=1`.
Yes, that's the idea, but I'm not the owner of any U-Boot CIs, hence it's a proposal.
While it's not what I wanted, I disagree on your comment. The idea is to make rules stricter (for new code) to make it better and that's why Linus enabled Werror by default in the Linux kernel. And personally I consider that as a good thing to follow.
Hi Andy,
On Tue, 22 Oct 2024 at 15:23, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
You can still do a patch...but I see we already use 'buildman -E' in CI, so perhaps it is already working?
I'll note that coreboot enabled this and it is a right pain. Since coreboot always produces copious amounts of pointless output, there is then a warning hidden somewhere in the middle and the build then fails inexplicably. At least with U-Boot we can use -s and only get messages which require user action.
But anyway, so long as we have this enabled in CI, we are not introducing new warnings. But another point is that we tend to get more warnings when moving to a newer toolchain...and devicetree has tons of warnings now.
On Tue, Oct 22, 2024 at 08:13:40PM +0200, Simon Glass wrote:
Hi Andy,
In general, yes, it is.
Personally, I find -Werror very helpful when developing code because it means I either (a) made a mistake or (b) forgot to if-out some code I didn't intend. This is also personal preference. But I think "make KCFLAGS=-Werror -sj" is great, personally. And I'll re-run without the -j if I can't see what failed right there.
It doesn't matter at this point, but perhaps if device tree warnings were errors there'd have been motivation these past many years to (a) resync and (b) fix any number of them. Unfortunately it's like migration notices and just noise to ignore.
Hello,
Am Tue, Oct 22, 2024 at 04:23:07PM +0300 schrieb Andy Shevchenko:
+1
Long term experience: each time you upgrade your toolchain you get new warnings. Each package (u-boot, kernel, userland, does not matter which) enabling -Werror breaks the BSP build. What should a developer do then? Fix each warning in each foreign project and bring it upstream? Or disable -Werror? Last thing is what is usually done. You can see several patches in buildroot or ptxdist disabling -Werror for this reason.
Just my 2 cents.
Greets Alex
+1
That's why the set of enabled/disabled warnings are spread over W=<n> and hence hidden when known to be PITA. W=1 is kinda special in a sense that we put the warnings that might affect code generation, size of the binary, etc. In some cases it even might prevent security bugs.
Hi Andy
On Wed, 23 Oct 2024 at 17:52, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
I think this is a good idea and perhaps we can do it per subsystem. I cleaned up EFI a few years ago, but some new have crept in. I've sent a bunch of no brainer patches, once I clean all of it (and assuming it's doable), I 'll try enabling W=1 as the default for efi_loader
thanks /Ilias
+1
-- With Best Regards, Andy Shevchenko
Thank you!
participants (6)
Alexander Dahl
Andy Shevchenko
Ilias Apalodimas
