[PATCH] net: ftgmac100: Add reset control
Add optional reset control, especially for the Aspeed SOC. For the hardware without a reset line, the reset assertion/deassertion will be skipped.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/net/ftgmac100.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index a50cde338a..886b97119d 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -13,6 +13,7 @@
#include <common.h> #include <clk.h> +#include <reset.h> #include <cpu_func.h> #include <dm.h> #include <log.h> @@ -90,6 +91,7 @@ struct ftgmac100_data { u32 max_speed;
struct clk_bulk clks; + struct reset_ctl *reset_ctl;
/* End of RX/TX ring buffer bits. Depend on model */ u32 rxdes0_edorr_mask; @@ -568,6 +570,8 @@ static int ftgmac100_of_to_plat(struct udevice *dev) priv->txdes0_edotr_mask = BIT(15); }
+ priv->reset_ctl = devm_reset_control_get_optional(dev, NULL); + return clk_get_bulk(dev, &priv->clks); }
@@ -593,6 +597,12 @@ static int ftgmac100_probe(struct udevice *dev) if (ret) goto out;
+ if (priv->reset_ctl) { + ret = reset_deassert(priv->reset_ctl); + if (ret) + goto out; + } + /* * If DM MDIO is enabled, the MDIO bus will be initialized later in * dm_eth_phy_connect @@ -628,6 +638,8 @@ static int ftgmac100_remove(struct udevice *dev) free(priv->phydev); mdio_unregister(priv->bus); mdio_free(priv->bus); + if (priv->reset_ctl) + reset_assert(priv->reset_ctl); clk_release_bulk(&priv->clks);
-----Original Message----- From: Dylan Hung kobedylan@gmail.com Sent: Thursday, July 27, 2023 9:58 AM To: Ryan Chen ryan_chen@aspeedtech.com; ChiaWei Wang chiawei_wang@aspeedtech.com; BMC-SW BMC-SW@aspeedtech.com; joel@jms.id.au; joe.hershberger@ni.com; rfried.dev@gmail.com; u-boot@lists.denx.de Cc: kobedylan@gmail.com; Dylan Hung dylan_hung@aspeedtech.com Subject: [PATCH] net: ftgmac100: Add reset control
Reviewed-by: Ryan Chen ryan_chen@aspeedtech.com
- priv->reset_ctl = devm_reset_control_get_optional(dev, NULL);
- return clk_get_bulk(dev, &priv->clks); }
- if (priv->reset_ctl) {
if (ret)
goto out;
- If DM MDIO is enabled, the MDIO bus will be initialized later in
- dm_eth_phy_connect
-- 2.25.1
struct reset_ctl *reset_ctl; /* End of RX/TX ring buffer bits. Depend on model */ u32 rxdes0_edorr_mask;
if (ret)
goto out;
reset_assert(priv->reset_ctl); clk_release_bulk(&priv->clks); return 0;
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com Reviewed-by: Ryan Chen ryan_chen@aspeedtech.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Dylan Hung
Ramon Fried
Ryan Chen
