[GIT PULL] Please pull u-boot-dfu-20240516
Hi Tom, everyone,
Sorry for the double email, I missed to include the list :(
Please find some fixes for master:
- Fix cdns3 low power hang via fast access bit - Multiple dwc3 gadget fixes, mainly for USB support on TI AM6232 - Consistent USB_GADGET_MANUFACTURER for PHYTEC boards - MAINTAINERS file update for u-boot-dfu
The CI job is at https://source.denx.de/u-boot/custodians/u-boot-dfu/-/pipelines/20737
Thanks, Mattijs
The following changes since commit c8ffd1356d42223cbb8c86280a083cc3c93e6426:
Merge patch series "arm: dts: am62-beagleplay: Fix Beagleplay Ethernet" (2024-05-13 09:15:51 -0600)
https://source.denx.de/u-boot/custodians/u-boot-dfu.git tags/u-boot-dfu-20240516
for you to fetch changes up to efbc11ccef89030ed54b7368458eeaf9ec687c77:
MAINTAINERS: add USB gadget regex to u-boot-dfu tree (2024-05-16 13:28:45 +0200)
---------------------------------------------------------------- u-boot-dfu-20240516
---------------------------------------------------------------- Aswath Govindraju (1): usb: cdns3: gadget.c: Set fast access bit
Benjamin Hahn (1): configs: Make USB_GADGET_MANUFACTURER consistent over all PHYTEC boards
Felipe Balbi (4): usb: dwc3: gadget: combine return points into a single one usb: dwc3: gadget: clear SUSPHY bit before ep cmds usb: dwc3: gadget: only resume USB2 PHY in <=HIGHSPEED usb: dwc3: gadget: properly check ep cmd
Mattijs Korpershoek (2): MAINTAINERS: add tree link for fastboot MAINTAINERS: add USB gadget regex to u-boot-dfu tree
Thinh Nguyen (2): usb: dwc3: gadget: Check ENBLSLPM before sending ep command usb: dwc3: gadget: Disable GUSB2PHYCFG.SUSPHY for End Transfer
MAINTAINERS | 4 +++ configs/phycore-imx8mp_defconfig | 2 +- configs/phycore_am64x_a53_defconfig | 2 +- configs/phycore_am64x_r5_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/phycore_pcl063_ull_defconfig | 2 +- drivers/usb/cdns3/gadget.c | 4 +++ drivers/usb/dwc3/core.h | 2 ++ drivers/usb/dwc3/gadget.c | 47 +++++++++++++++++++++++++++++++++--- 9 files changed, 59 insertions(+), 8 deletions(-)
On Thu, May 16, 2024 at 05:12:33PM +0200, Mattijs Korpershoek wrote:
Hi Tom, everyone,
Thanks, Mattijs
Mattijs Korpershoek
