[U-Boot] [PATCH 1/2] wandboard: Fix error handling in board_mmc_init()
When an invalid USDHC port is passed we should return -EINVAL instead of 0.
Also, return the error immediately on fsl_esdhc_initialize() failure.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/wandboard/wandboard.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 3c8b7a5..1075c65 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -144,7 +144,7 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { - s32 status = 0; + int ret; u32 index = 0;
/* @@ -173,13 +173,15 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; }
- status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + if (ret) + return ret; }
- return status; + return 0; }
static int mx6_rgmii_rework(struct phy_device *phydev)
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53loco/mx53loco.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 7569ded..efcf4b3 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -186,7 +186,7 @@ int board_mmc_init(bd_t *bis) };
u32 index; - s32 status = 0; + int ret;
esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); esdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); @@ -205,12 +205,14 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(2)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } - status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); + ret = fsl_esdhc_initialize(bis, &esdhc_cfg[index]); + if (ret) + return ret; }
- return status; + return 0; } #endif
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
