[U-Boot-Users] FW:回复:_Re:__A_starter_of_ porting u-boot to a new boar d(by yeshi20 8@126.com)
---------- 转发邮件信息 ---------- From:yeshi208@126.com Date:2007-04-28 12:01:53 Subject:回复:_Re:_[U-Boot-Users]_A_starter_of_porting u-boot to a new boar d To:"eric miao"
Thank you, Eric Miao,En ,I have copy file from s3c44b0 and Dave/B2 for my board. and create a config file in include/configs directory.Then make distclean make XXXX_config make all
when I download the u-boot.bin to RAM by AXD at 0x3080000, It does not run . Then I run step by step , It raise a exception when "bl cpu_init_crit". What's the meaning now? Is it I have configure a wrong config file in include/configs?
在2007-04-28,"Eric Miao" eric.y.miao@gmail.com 写道:
On 4/27/07, yeshi208@126.com yeshi208@126.com wrote:
Hello:
I am a newbie to use u-boot, and I have browse the readme file in the
source directory. Now I want to port u-boot to a new board. But I do not
know the step exactly.Could some good people tell me where should I start
The CPU is SEP3203F50 using ARM7TDMI core, and for the first time I want
to make a u-boot.bin file to write into flash. The bin file could not
surport net.
I guess the README has already provided sufficient information to start,
right? You can start copy a similar board (regarding CPU architecture,
SoC, and peripherals on board) directory within board/ and rename it
to yours, and copy a similar board config header file within include/configs/,
then you start with ./mkconfig
Best Wishs
yeshi
免费试玩2006中国最佳网络游戏--梦幻西游
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
U-Boot-Users mailing list
U-Boot-Users@lists.sourceforge.net
yeshi208@126.com
