[U-Boot-Users] error when compile U-Boot
Hi,all.
I try to compile U-Boot (version u-boot-1.1.2), after #make all
and there print mistake as :
arm-linux-gcc -Wa,-gstabs -D__ASSEMBLY__ -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -mshort-load-bytes -msoft-float -D__KERNEL__ -DTEXT_BASE=0xa3080000 -I/root/download/u-boot-1.1.1/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc-lib/i386-redhat-linux/3.3.2/include -pipe -DCONFIG_ARM -D__ARM__ -mapcs-32 -march=armv5 -mtune=strongarm1100 -c -o cpu/pxa/start.o /root/download/u-boot-1.1.1/cpu/pxa/start.S /root/download/u-boot-1.1.1/cpu/pxa/start.S: Assembler messages: /root/download/u-boot-1.1.1/cpu/pxa/start.S:121: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:122: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:143: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:145: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:360: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:361: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:366: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:367: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:372: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:373: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:378: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:379: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:384:
Kenton Lau
