[U-Boot] [PATCH] Remove unused CONFIG_SERIAL_SOFTWARE_FIFO feature
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner.
Signed-off-by: Stefan Roese sr@denx.de --- README | 12 --- arch/i386/lib/board.c | 7 -- arch/m68k/lib/board.c | 4 - arch/powerpc/cpu/ppc4xx/4xx_uart.c | 134 ------------------------------------ arch/powerpc/lib/board.c | 7 -- arch/sparc/lib/board.c | 4 - common/stdio.c | 8 -- doc/README.ppc440 | 6 -- include/common.h | 8 -- include/configs/AP1000.h | 6 -- include/configs/ATUM8548.h | 1 - include/configs/JSE.h | 6 -- include/configs/KAREF.h | 1 - include/configs/METROBOX.h | 1 - include/configs/ML2.h | 10 --- include/configs/MPC8308RDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC8360EMDS.h | 1 - include/configs/MPC8360ERDK.h | 1 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8540EVAL.h | 1 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/MVBLM7.h | 1 - include/configs/P1_P2_RDB.h | 1 - include/configs/P2020DS.h | 1 - include/configs/PM854.h | 1 - include/configs/SBC8540.h | 1 - include/configs/TQM834x.h | 1 - include/configs/TQM85xx.h | 1 - include/configs/aria.h | 1 - include/configs/bubinga.h | 1 - include/configs/dlvision.h | 1 - include/configs/eNET.h | 1 - include/configs/ebony.h | 1 - include/configs/hcu5.h | 1 - include/configs/kmeter1.h | 1 - include/configs/mcu25.h | 7 -- include/configs/mecp5123.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/neo.h | 1 - include/configs/ocotea.h | 1 - include/configs/sbc8349.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sbc8560.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sc3.h | 8 -- include/configs/socrates.h | 1 - include/configs/stxssa.h | 1 - include/configs/taihu.h | 1 - include/configs/vme8349.h | 1 - include/configs/walnut.h | 1 - include/configs/yucca.h | 1 - 67 files changed, 0 insertions(+), 280 deletions(-)
diff --git a/README b/README index aa11c37..93e064a 100644 --- a/README +++ b/README @@ -532,18 +532,6 @@ The following options need to be configured: must be defined, to setup the maximum idle timeout for the SMC.
-- Interrupt driven serial port input: - CONFIG_SERIAL_SOFTWARE_FIFO - - PPC405GP only. - Use an interrupt handler for receiving data on the - serial port. It also enables using hardware handshake - (RTS/CTS) and UART's built-in FIFO. Set the number of - bytes the interrupt driven input buffer should have. - - Leave undefined to disable this feature, including - disable the buffer and hardware handshake. - - Console UART Number: CONFIG_UART1_CONSOLE
diff --git a/arch/i386/lib/board.c b/arch/i386/lib/board.c index 684cdb8..731c6b4 100644 --- a/arch/i386/lib/board.c +++ b/arch/i386/lib/board.c @@ -335,13 +335,6 @@ void board_init_r(gd_t *id, ulong dest_addr) enable_interrupts(); show_boot_progress(0x28);
- /* Must happen after interrupts are initialized since - * an irq handler gets installed - */ -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - serial_buffered_init(); -#endif - #ifdef CONFIG_STATUS_LED status_led_set (STATUS_LED_BOOT, STATUS_LED_BLINKING); #endif diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index ae9478a..c29f577 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -569,10 +569,6 @@ void board_init_r (gd_t *id, ulong dest_addr) */ timer_init();
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - serial_buffered_init(); -#endif - #ifdef CONFIG_STATUS_LED status_led_set (STATUS_LED_BOOT, STATUS_LED_BLINKING); #endif diff --git a/arch/powerpc/cpu/ppc4xx/4xx_uart.c b/arch/powerpc/cpu/ppc4xx/4xx_uart.c index 58d6c78..70346e2 100644 --- a/arch/powerpc/cpu/ppc4xx/4xx_uart.c +++ b/arch/powerpc/cpu/ppc4xx/4xx_uart.c @@ -56,10 +56,6 @@ #include <serial.h> #endif
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO -#include <malloc.h> -#endif - DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_405GP) || defined(CONFIG_405CR) || \ @@ -155,19 +151,6 @@ DECLARE_GLOBAL_DATA_PTR; #error "External serial clock not supported on AMCC PPC405EP!" #endif
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO -/*-----------------------------------------------------------------------------+ - | Fifo - +-----------------------------------------------------------------------------*/ -typedef struct { - char *rx_buffer; - ulong rx_put; - ulong rx_get; -} serial_buffer_t; - -volatile static serial_buffer_t buf_info; -#endif - static void serial_init_common(struct NS16550 *com_port, u32 udiv, u16 bdiv) { PPC4xx_SYS_INFO sys_info; @@ -496,123 +479,6 @@ int serial_tstc_dev (struct NS16550 *com_port) return 0; }
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - -void serial_isr (void *arg) -{ - int space; - int c; - const int rx_get = buf_info.rx_get; - int rx_put = buf_info.rx_put; - - if (rx_get <= rx_put) - space = CONFIG_SERIAL_SOFTWARE_FIFO - (rx_put - rx_get); - else - space = rx_get - rx_put; - - while (serial_tstc_dev (ACTING_UART0_BASE)) { - c = serial_getc_dev (ACTING_UART0_BASE); - if (space) { - buf_info.rx_buffer[rx_put++] = c; - space--; - } - if (rx_put == CONFIG_SERIAL_SOFTWARE_FIFO) - rx_put = 0; - if (space < CONFIG_SERIAL_SOFTWARE_FIFO / 4) { - /* Stop flow by setting RTS inactive */ - out_8((u8 *)ACTING_UART0_BASE + UART_MCR, - in_8((u8 *)ACTING_UART0_BASE + UART_MCR) & - (0xFF ^ 0x02)); - } - } - buf_info.rx_put = rx_put; -} - -void serial_buffered_init (void) -{ - serial_puts ("Switching to interrupt driven serial input mode.\n"); - buf_info.rx_buffer = malloc (CONFIG_SERIAL_SOFTWARE_FIFO); - buf_info.rx_put = 0; - buf_info.rx_get = 0; - - if (in_8((u8 *)ACTING_UART0_BASE + UART_MSR) & 0x10) - serial_puts ("Check CTS signal present on serial port: OK.\n"); - else - serial_puts ("WARNING: CTS signal not present on serial port.\n"); - - irq_install_handler ( VECNUM_U0 /*UART0 */ /*int vec */ , - serial_isr /*interrupt_handler_t *handler */ , - (void *) &buf_info /*void *arg */ ); - - /* Enable "RX Data Available" Interrupt on UART */ - out_8(ACTING_UART0_BASE + UART_IER, 0x01); - /* Set DTR active */ - out_8(ACTING_UART0_BASE + UART_MCR, - in_8((u8 *)ACTING_UART0_BASE + UART_MCR) | 0x01); - /* Start flow by setting RTS active */ - out_8(ACTING_UART0_BASE + UART_MCR, - in_8((u8 *)ACTING_UART0_BASE + UART_MCR) | 0x02); - /* Setup UART FIFO: RX trigger level: 4 byte, Enable FIFO */ - out_8(ACTING_UART0_BASE + UART_FCR, (1 << 6) | 1); -} - -void serial_buffered_putc (const char c) -{ - /* Wait for CTS */ -#if defined(CONFIG_HW_WATCHDOG) - while (!(in_8((u8 *)ACTING_UART0_BASE + UART_MSR) & 0x10)) - WATCHDOG_RESET (); -#else - while (!(in_8((u8 *)ACTING_UART0_BASE + UART_MSR) & 0x10)); -#endif - serial_putc (c); -} - -void serial_buffered_puts (const char *s) -{ - serial_puts (s); -} - -int serial_buffered_getc (void) -{ - int space; - int c; - int rx_get = buf_info.rx_get; - int rx_put; - -#if defined(CONFIG_HW_WATCHDOG) - while (rx_get == buf_info.rx_put) - WATCHDOG_RESET (); -#else - while (rx_get == buf_info.rx_put); -#endif - c = buf_info.rx_buffer[rx_get++]; - if (rx_get == CONFIG_SERIAL_SOFTWARE_FIFO) - rx_get = 0; - buf_info.rx_get = rx_get; - - rx_put = buf_info.rx_put; - if (rx_get <= rx_put) - space = CONFIG_SERIAL_SOFTWARE_FIFO - (rx_put - rx_get); - else - space = rx_get - rx_put; - - if (space > CONFIG_SERIAL_SOFTWARE_FIFO / 2) { - /* Start flow by setting RTS active */ - out_8(ACTING_UART0_BASE + UART_MCR, - in_8((u8 *)ACTING_UART0_BASE + UART_MCR) | 0x02); - } - - return c; -} - -int serial_buffered_tstc (void) -{ - return (buf_info.rx_get != buf_info.rx_put) ? 1 : 0; -} - -#endif /* CONFIG_SERIAL_SOFTWARE_FIFO */ - #if defined(CONFIG_CMD_KGDB) /* AS HARNOIS : according to CONFIG_KGDB_SER_INDEX kgdb uses serial port diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 950680c..ae19cc7 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -890,13 +890,6 @@ void board_init_r (gd_t *id, ulong dest_addr) */ interrupt_init ();
- /* Must happen after interrupts are initialized since - * an irq handler gets installed - */ -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - serial_buffered_init(); -#endif - #if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) status_led_set (STATUS_LED_BOOT, STATUS_LED_BLINKING); #endif diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index d0890f6..09bcdb0 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -359,10 +359,6 @@ void board_init_f(ulong bootflag) /* Initialize the console (after the relocation and devices init) */ console_init_r();
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - serial_buffered_init(); -#endif - #ifdef CONFIG_STATUS_LED status_led_set(STATUS_LED_BOOT, STATUS_LED_BLINKING); #endif diff --git a/common/stdio.c b/common/stdio.c index 870ddfd..2501369 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -76,18 +76,10 @@ static void drv_system_init (void)
strcpy (dev.name, "serial"); dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - dev.putc = serial_buffered_putc; - dev.puts = serial_buffered_puts; - dev.getc = serial_buffered_getc; - dev.tstc = serial_buffered_tstc; -#else dev.putc = serial_putc; dev.puts = serial_puts; dev.getc = serial_getc; dev.tstc = serial_tstc; -#endif - stdio_register (&dev);
#ifdef CONFIG_SYS_DEVICE_NULLDEV diff --git a/doc/README.ppc440 b/doc/README.ppc440 index 1b96458..dd8ccaa 100644 --- a/doc/README.ppc440 +++ b/doc/README.ppc440 @@ -77,12 +77,6 @@ This is controlled with the CONFIG_SYS_EXT_SERIAL_CLOCK flag. When using internal clocking, the "ideal baud rate" settings in the 440GP user manual are automatically calculated.
-CONFIG_SERIAL_SOFTWARE_FIFO enables interrupt-driven serial operation. -But the last time I checked, interrupts were initialized after the -serial port causing the interrupt handler to be removed from the -handler table. This will probably be fixed soon ... or fix it -yourself and submit a patch :-) -
I2C ================= diff --git a/include/common.h b/include/common.h index 2151597..0780c17 100644 --- a/include/common.h +++ b/include/common.h @@ -214,14 +214,6 @@ typedef void (interrupt_handler_t)(void *); * Function Prototypes */
-#ifdef CONFIG_SERIAL_SOFTWARE_FIFO -void serial_buffered_init (void); -void serial_buffered_putc (const char); -void serial_buffered_puts (const char *); -int serial_buffered_getc (void); -int serial_buffered_tstc (void); -#endif /* CONFIG_SERIAL_SOFTWARE_FIFO */ - void hang (void) __attribute__ ((noreturn));
/* */ diff --git a/include/configs/AP1000.h b/include/configs/AP1000.h index ae0a873..e707075 100644 --- a/include/configs/AP1000.h +++ b/include/configs/AP1000.h @@ -52,12 +52,6 @@
#define CONFIG_BOOTCOMMAND "" /* autoboot command */
-/* Size (bytes) of interrupt driven serial port buffer. - * Set to 0 to use polling instead of interrupts. - * Setting to 0 will also disable RTS/CTS handshaking. - */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO - #define CONFIG_BOOTARGS "console=ttyS0,57600"
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ diff --git a/include/configs/ATUM8548.h b/include/configs/ATUM8548.h index c133033..58f0c1f 100644 --- a/include/configs/ATUM8548.h +++ b/include/configs/ATUM8548.h @@ -200,7 +200,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/JSE.h b/include/configs/JSE.h index 98f5661..95152c7 100644 --- a/include/configs/JSE.h +++ b/include/configs/JSE.h @@ -101,12 +101,6 @@ /* Set console baudrate to 9600 */ #define CONFIG_BAUDRATE 9600
-/* Size (bytes) of interrupt driven serial port buffer. - * Set to 0 to use polling instead of interrupts. - * Setting to 0 will also disable RTS/CTS handshaking. - */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO - /* * Configuration related to auto-boot. * diff --git a/include/configs/KAREF.h b/include/configs/KAREF.h index 49a7378..84e0e6b 100644 --- a/include/configs/KAREF.h +++ b/include/configs/KAREF.h @@ -91,7 +91,6 @@ /*----------------------------------------------------------------------- * Serial Port *----------------------------------------------------------------------*/ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SERIAL_MULTI 1 #define CONFIG_BAUDRATE 9600
diff --git a/include/configs/METROBOX.h b/include/configs/METROBOX.h index e7429dd..5c06029 100644 --- a/include/configs/METROBOX.h +++ b/include/configs/METROBOX.h @@ -153,7 +153,6 @@ /*----------------------------------------------------------------------- * Serial Port *----------------------------------------------------------------------*/ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SERIAL_MULTI 1 #define CONFIG_BAUDRATE 9600
diff --git a/include/configs/ML2.h b/include/configs/ML2.h index 5fcc173..2fc0119 100644 --- a/include/configs/ML2.h +++ b/include/configs/ML2.h @@ -52,16 +52,6 @@
#define CONFIG_PREBOOT "fsload 0x00100000 /boot/image"
-/* Size (bytes) of interrupt driven serial port buffer. - * Set to 0 to use polling instead of interrupts. - * Setting to 0 will also disable RTS/CTS handshaking. - */ -#if 0 -#define CONFIG_SERIAL_SOFTWARE_FIFO 4000 -#else -#undef CONFIG_SERIAL_SOFTWARE_FIFO -#endif - #if 0 #define CONFIG_BOOTARGS "root=/dev/nfs " \ "ip=192.168.2.176:192.168.2.190:192.168.2.79:255.255.255.0 " \ diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 6cd5da7..c6f12bd 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -279,7 +279,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index f1b110b..7007255 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -298,7 +298,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 9a296a1..590005d 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -262,7 +262,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 68ff191..9957756 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -273,7 +273,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 73dbea4..eaa8a9d 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -283,7 +283,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 9be571f..4c6c273 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -329,7 +329,6 @@ boards, we say we have two, but don't display a message if we find only one. */ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index c58e003..c8db10b 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -307,7 +307,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 9fa577d..2685dee 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -237,7 +237,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 9092755..bdf8a2a 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -299,7 +299,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 79dadc4..675021c 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -316,7 +316,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 2a3c058..0a9f47b 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -400,7 +400,6 @@ * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 577c276..c133895 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -237,7 +237,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8540EVAL.h b/include/configs/MPC8540EVAL.h index 7daf934..75227a6 100644 --- a/include/configs/MPC8540EVAL.h +++ b/include/configs/MPC8540EVAL.h @@ -173,7 +173,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 8797b30..c3167e9 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -263,7 +263,6 @@ extern unsigned long get_clock_freq(void);
/* Serial Port */ #define CONFIG_CONS_INDEX 2 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index d1ac32f..1804582 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -214,7 +214,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 33f49f5..e1e4acf 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -282,7 +282,6 @@ extern unsigned long get_clock_freq(void);
/* Serial Port */ #define CONFIG_CONS_INDEX 2 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 0f71f11..b0dd175 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -261,7 +261,6 @@ extern unsigned long get_clock_freq(void);
/* Serial Port */ #define CONFIG_CONS_INDEX 2 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 2dc2932..a98ecde 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -244,7 +244,6 @@ extern unsigned long get_clock_freq(void);
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 8177db3..8ffd458 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -276,7 +276,6 @@ extern unsigned long get_clock_freq(void); /* Serial Port */ #define CONFIG_CONS_INDEX 1 #define CONFIG_SERIAL_MULTI 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 081661e..34ebbdb 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -333,7 +333,6 @@ * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 4d9606e..aece1db 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -218,7 +218,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 974cb6b..3b80d14 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -275,7 +275,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index c28eb64..5b12b88 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -150,7 +150,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 7e901e1..fa45b5b 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -281,7 +281,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 79ce2c0..74cff0c 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -337,7 +337,6 @@ * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/PM854.h b/include/configs/PM854.h index 7426bca..cf8a8cf 100644 --- a/include/configs/PM854.h +++ b/include/configs/PM854.h @@ -174,7 +174,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/SBC8540.h b/include/configs/SBC8540.h index 5d424dd..d6b3cb8 100644 --- a/include/configs/SBC8540.h +++ b/include/configs/SBC8540.h @@ -205,7 +205,6 @@ #undef CONFIG_CONS_NONE /* define if console on something else */
#define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c1e0e64..6cd1af3 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -166,7 +166,6 @@ extern int tqm834x_num_flash_banks; * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index abbaf38..ccb339d 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -256,7 +256,6 @@ #else /* !CONFIG_TQM8560 */
#define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/aria.h b/include/configs/aria.h index c5f9cc1..01e347e 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -321,7 +321,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO
/* * Serial console configuration diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index 05c4766..befe41f 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -123,7 +123,6 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200 diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index 4533799..3f02006 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -97,7 +97,6 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200 diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 361fe61..da2a97d 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -59,7 +59,6 @@ * Serial Configuration */ #define CONFIG_SERIAL_MULTI -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/ebony.h b/include/configs/ebony.h index 10f425d..269b4bf 100644 --- a/include/configs/ebony.h +++ b/include/configs/ebony.h @@ -81,7 +81,6 @@ /*----------------------------------------------------------------------- * Serial Port *----------------------------------------------------------------------*/ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_EXT_SERIAL_CLOCK (1843200 * 6) /* Ext clk @ 11.059 MHz */
/*----------------------------------------------------------------------- diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h index 26d2d0c..388100d 100644 --- a/include/configs/hcu5.h +++ b/include/configs/hcu5.h @@ -93,7 +93,6 @@ *----------------------------------------------------------------------*/ #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #define CONFIG_BAUDRATE 115200 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_UART1_CONSOLE
/*----------------------------------------------------------------------- diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index f7d36b1..1dcdeab 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -257,7 +257,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/mcu25.h b/include/configs/mcu25.h index 5f31198..6042986 100644 --- a/include/configs/mcu25.h +++ b/include/configs/mcu25.h @@ -86,16 +86,9 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -/* needed to be able to define CONFIG_SERIAL_SOFTWARE_FIFO */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200
-/* Size (bytes) of interrupt driven serial port buffer. - * Set to 0 to use polling instead of interrupts. - * Setting to 0 will also disable RTS/CTS handshaking. - */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO - /* Set console baudrate to 9600 */ #define CONFIG_BAUDRATE 9600
diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 92c4f5f..539c8c1 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -218,7 +218,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO
/* * Serial console configuration diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 5281042..609156d 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -284,7 +284,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO
/* * Serial console configuration diff --git a/include/configs/neo.h b/include/configs/neo.h index f275c7b..93bf3bf 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -98,7 +98,6 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200 diff --git a/include/configs/ocotea.h b/include/configs/ocotea.h index 2e809b0..ce57032 100644 --- a/include/configs/ocotea.h +++ b/include/configs/ocotea.h @@ -81,7 +81,6 @@ /*----------------------------------------------------------------------- * Serial Port *----------------------------------------------------------------------*/ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_EXT_SERIAL_CLOCK (1843200 * 6) /* Ext clk @ 11.059 MHz */
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index deaddde..e85e8f7 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -270,7 +270,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 564f661..8d047de 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -338,7 +338,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index 53d06ed..6352278 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -203,7 +203,6 @@ #undef CONFIG_CONS_NONE /* define if console on something else */
#define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 618513a..a7831c0 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -257,7 +257,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/sc3.h b/include/configs/sc3.h index 19084ce..65f5aeb 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -77,14 +77,6 @@ * Serial Port *----------------------------------------------------------------------*/ #define CONFIG_SERIAL_MULTI -#undef CONFIG_SERIAL_SOFTWARE_FIFO -/* - * define CONFIG_POWER_DOWN if your cpu should power down while waiting for your input - * Works only, if you have enabled the CONFIG_SERIAL_SOFTWARE_FIFO feature - */ -#if CONFIG_SERIAL_SOFTWARE_FIFO - #define CONFIG_POWER_DOWN -#endif
/* * define CONFIG_SYS_CLK_FREQ to your base crystal clock in Hz diff --git a/include/configs/socrates.h b/include/configs/socrates.h index af1e19e..88be349 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -218,7 +218,6 @@ /* Serial Port */
#define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index 57bb8d1..911c906 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -176,7 +176,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 2 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/taihu.h b/include/configs/taihu.h index 836081d..54a2072 100644 --- a/include/configs/taihu.h +++ b/include/configs/taihu.h @@ -127,7 +127,6 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200 diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index f493e75..ec533b8 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -184,7 +184,6 @@ * Serial Port */ #define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/walnut.h b/include/configs/walnut.h index 630c0d3..8440965 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -84,7 +84,6 @@ * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ #undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ #define CONFIG_SYS_BASE_BAUD 691200 diff --git a/include/configs/yucca.h b/include/configs/yucca.h index 0b4dfb8..91751e4 100644 --- a/include/configs/yucca.h +++ b/include/configs/yucca.h @@ -108,7 +108,6 @@ *----------------------------------------------------------------------*/ #undef CONFIG_UART1_CONSOLE
-#undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* #define CONFIG_SYS_EXT_SERIAL_CLOCK (1843200 * 6) */ /* Ext clk @ 11.059 MHz */
Hi Stefan,
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
Detlev Zundel
Stefan Roese
