[PATCH] mmc: msm_sdhci: program core_vendor_spec
After resetting the host controller, program in the POR val for this register just like the Linux driver does.
This seems to help with initialization when running U-Boot as the primary bootloader on some boards.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/mmc/msm_sdhci.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index 4ce0de6c47d8..8b3188fa20d4 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -31,8 +31,10 @@ #define SDCC_MCI_STATUS2 0x6C #define SDCC_MCI_STATUS2_MCI_ACT 0x1 #define SDCC_MCI_HC_MODE 0x78
+#define CORE_VENDOR_SPEC_POR_VAL 0xa9c + struct msm_sdhc_plat { struct mmc_config cfg; struct mmc mmc; }; @@ -45,21 +47,25 @@ struct msm_sdhc {
struct msm_sdhc_variant_info { bool mci_removed;
+ u32 core_vendor_spec; u32 core_vendor_spec_capabilities0; };
DECLARE_GLOBAL_DATA_PTR;
static int msm_sdc_clk_init(struct udevice *dev) { struct msm_sdhc *prv = dev_get_priv(dev); + const struct msm_sdhc_variant_info *var_info; ofnode node = dev_ofnode(dev); ulong clk_rate; int ret, i = 0, n_clks; const char *clk_name;
+ var_info = (void *)dev_get_driver_data(dev); + ret = ofnode_read_u32(node, "clock-frequency", (uint *)(&clk_rate)); if (ret) clk_rate = 201500000;
@@ -104,8 +110,11 @@ static int msm_sdc_clk_init(struct udevice *dev) log_warning("Couldn't set MMC core clock rate: %dE\n", clk_rate ? (int)PTR_ERR((void *)clk_rate) : 0); return -EINVAL; }
+ writel_relaxed(CORE_VENDOR_SPEC_POR_VAL, + prv->host.ioaddr + var_info->core_vendor_spec); + return 0; }
static int msm_sdc_mci_init(struct msm_sdhc *prv) @@ -254,14 +263,16 @@ static int msm_sdc_bind(struct udevice *dev)
static const struct msm_sdhc_variant_info msm_sdhc_mci_var = { .mci_removed = false,
+ .core_vendor_spec = 0x10c, .core_vendor_spec_capabilities0 = 0x11c, };
static const struct msm_sdhc_variant_info msm_sdhc_v5_var = { .mci_removed = true,
+ .core_vendor_spec = 0x20c, .core_vendor_spec_capabilities0 = 0x21c, };
static const struct udevice_id msm_mmc_ids[] = {
Caleb Connolly
