[U-Boot] [PATCH v6 0/4] Tegra: MMC: Add DT support for MMC to T20 boards
This patchset adds device-tree support to the Tegra MMC driver. All device config is done via properties in the DT files instead of hard-coded config options/function arguments.
I've tested this on my Seaboard and everything works fine, including card detect. For the other T20 boards, I've used the Linux kernel DTS files for the sdhci nodes where there wasn't one already, or expanded the info that was already there. Everything builds fine, but I haven't tested anything but Seaboard.
v2: Changes as per Stephen's & Simon's review v3: Changes as per Stephen/Lucas/Thierry/Simon's feedback v4: Additional changes as per Stephen/Lucas/Thierry/Simon v5: Additional changes as per Stephen/Lucas/Andy v6: Additional changes requested by Stephen
Tom Warren (4): Tegra: fdt: Change /include/ to #include for C preprocessor Tegra: fdt: tamonten: Add common tamonten.dtsi file from linux Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT files Tegra: MMC: Add DT support to MMC driver for all T20 boards
arch/arm/dts/tegra114.dtsi | 2 +- arch/arm/dts/tegra20.dtsi | 18 +- arch/arm/dts/tegra30.dtsi | 2 +- arch/arm/include/asm/arch-tegra/mmc.h | 2 +- arch/arm/include/asm/arch-tegra/tegra_mmc.h | 13 +- board/avionic-design/common/tamonten.c | 19 +- board/avionic-design/dts/tegra20-medcom-wide.dts | 3 +- board/avionic-design/dts/tegra20-plutux.dts | 3 +- board/avionic-design/dts/tegra20-tamonten.dtsi | 489 +++++++++++++++++++++ board/avionic-design/dts/tegra20-tec.dts | 3 +- board/compal/dts/tegra20-paz00.dts | 21 +- board/compal/paz00/paz00.c | 26 +- board/compulab/dts/tegra20-trimslice.dts | 16 +- board/compulab/trimslice/trimslice.c | 23 +- board/nvidia/common/board.c | 25 + board/nvidia/dts/tegra114-dalmore.dts | 2 +- board/nvidia/dts/tegra20-harmony.dts | 20 +- board/nvidia/dts/tegra20-seaboard.dts | 14 +- board/nvidia/dts/tegra20-ventana.dts | 17 +- board/nvidia/dts/tegra20-whistler.dts | 15 +- board/nvidia/dts/tegra30-cardhu.dts | 2 +- board/nvidia/harmony/harmony.c | 26 +- board/nvidia/seaboard/seaboard.c | 25 +- board/nvidia/whistler/whistler.c | 30 +- board/toradex/colibri_t20_iris/colibri_t20_iris.c | 11 +- board/toradex/dts/tegra20-colibri_t20_iris.dts | 9 +- drivers/mmc/tegra_mmc.c | 179 +++++--- dts/Makefile | 3 +- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 30 files changed, 786 insertions(+), 234 deletions(-) create mode 100644 board/avionic-design/dts/tegra20-tamonten.dtsi
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS. This allows the use of '#include "xyz"' in the dts/dtsi file which helps the C preprocessor find common dtsi include files.
Signed-off-by: Tom Warren twarren@nvidia.com --- --- v4: new v5: add dts/dtsi paths to DTS_CPPFLAGS instead of DTC command line v6: change all DT files to use #include instead of /include/
arch/arm/dts/tegra114.dtsi | 2 +- arch/arm/dts/tegra20.dtsi | 2 +- arch/arm/dts/tegra30.dtsi | 2 +- board/avionic-design/dts/tegra20-medcom-wide.dts | 2 +- board/avionic-design/dts/tegra20-plutux.dts | 2 +- board/avionic-design/dts/tegra20-tec.dts | 2 +- board/compal/dts/tegra20-paz00.dts | 2 +- board/compulab/dts/tegra20-trimslice.dts | 2 +- board/nvidia/dts/tegra114-dalmore.dts | 2 +- board/nvidia/dts/tegra20-harmony.dts | 2 +- board/nvidia/dts/tegra20-seaboard.dts | 2 +- board/nvidia/dts/tegra20-ventana.dts | 2 +- board/nvidia/dts/tegra20-whistler.dts | 2 +- board/nvidia/dts/tegra30-cardhu.dts | 2 +- board/toradex/dts/tegra20-colibri_t20_iris.dts | 2 +- dts/Makefile | 3 ++- 16 files changed, 17 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi index d06cd12..ee08962 100644 --- a/arch/arm/dts/tegra114.dtsi +++ b/arch/arm/dts/tegra114.dtsi @@ -1,4 +1,4 @@ -/include/ "skeleton.dtsi" +#include "skeleton.dtsi"
/ { compatible = "nvidia,tegra114"; diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 9a89685..d163ff8 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -1,4 +1,4 @@ -/include/ "skeleton.dtsi" +#include "skeleton.dtsi"
/ { compatible = "nvidia,tegra20"; diff --git a/arch/arm/dts/tegra30.dtsi b/arch/arm/dts/tegra30.dtsi index 7b8126f..561c617 100644 --- a/arch/arm/dts/tegra30.dtsi +++ b/arch/arm/dts/tegra30.dtsi @@ -1,4 +1,4 @@ -/include/ "skeleton.dtsi" +#include "skeleton.dtsi"
/ { compatible = "nvidia,tegra30"; diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/board/avionic-design/dts/tegra20-medcom-wide.dts index e46afbe..934a4e6 100644 --- a/board/avionic-design/dts/tegra20-medcom-wide.dts +++ b/board/avionic-design/dts/tegra20-medcom-wide.dts @@ -1,6 +1,6 @@ /dts-v1/;
-/include/ ARCH_CPU_DTS +#include ARCH_CPU_DTS
/ { model = "Avionic Design Medcom-Wide"; diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/board/avionic-design/dts/tegra20-plutux.dts index 3e6cce0..fc77031 100644 --- a/board/avionic-design/dts/tegra20-plutux.dts +++ b/board/avionic-design/dts/tegra20-plutux.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Avionic Design Plutux"; diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index bf3ff1d..708adec 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Avionic Design Tamonten Evaluation Carrier"; diff --git a/board/compal/dts/tegra20-paz00.dts b/board/compal/dts/tegra20-paz00.dts index 31b064d..b5580c9 100644 --- a/board/compal/dts/tegra20-paz00.dts +++ b/board/compal/dts/tegra20-paz00.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Toshiba AC100 / Dynabook AZ"; diff --git a/board/compulab/dts/tegra20-trimslice.dts b/board/compulab/dts/tegra20-trimslice.dts index 7aeed67..04cd121 100644 --- a/board/compulab/dts/tegra20-trimslice.dts +++ b/board/compulab/dts/tegra20-trimslice.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Compulab TrimSlice board"; diff --git a/board/nvidia/dts/tegra114-dalmore.dts b/board/nvidia/dts/tegra114-dalmore.dts index 7315577..a3e7863 100644 --- a/board/nvidia/dts/tegra114-dalmore.dts +++ b/board/nvidia/dts/tegra114-dalmore.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Dalmore"; diff --git a/board/nvidia/dts/tegra20-harmony.dts b/board/nvidia/dts/tegra20-harmony.dts index aeda3a1..35baff0 100644 --- a/board/nvidia/dts/tegra20-harmony.dts +++ b/board/nvidia/dts/tegra20-harmony.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Harmony evaluation board"; diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/board/nvidia/dts/tegra20-seaboard.dts index 527a296..bb56820 100644 --- a/board/nvidia/dts/tegra20-seaboard.dts +++ b/board/nvidia/dts/tegra20-seaboard.dts @@ -1,7 +1,7 @@ /dts-v1/;
/memreserve/ 0x1c000000 0x04000000; -/include/ ARCH_CPU_DTS +#include ARCH_CPU_DTS
/ { model = "NVIDIA Seaboard"; diff --git a/board/nvidia/dts/tegra20-ventana.dts b/board/nvidia/dts/tegra20-ventana.dts index 3e5e39d..b2cf863 100644 --- a/board/nvidia/dts/tegra20-ventana.dts +++ b/board/nvidia/dts/tegra20-ventana.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Ventana evaluation board"; diff --git a/board/nvidia/dts/tegra20-whistler.dts b/board/nvidia/dts/tegra20-whistler.dts index 4579557..aa3761f 100644 --- a/board/nvidia/dts/tegra20-whistler.dts +++ b/board/nvidia/dts/tegra20-whistler.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Whistler evaluation board"; diff --git a/board/nvidia/dts/tegra30-cardhu.dts b/board/nvidia/dts/tegra30-cardhu.dts index f9f80c5..f7ea07a 100644 --- a/board/nvidia/dts/tegra30-cardhu.dts +++ b/board/nvidia/dts/tegra30-cardhu.dts @@ -1,7 +1,7 @@ /dts-v1/;
/ { model = "NVIDIA Cardhu"; diff --git a/board/toradex/dts/tegra20-colibri_t20_iris.dts b/board/toradex/dts/tegra20-colibri_t20_iris.dts index c29b43a..d8a0328 100644 --- a/board/toradex/dts/tegra20-colibri_t20_iris.dts +++ b/board/toradex/dts/tegra20-colibri_t20_iris.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Toradex Colibri T20"; diff --git a/dts/Makefile b/dts/Makefile index 922c78c..6f36153 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -38,7 +38,8 @@ Please define CONFIG_ARCH_DEVICE_TREE)) # We preprocess the device tree file provide a useful define DTS_CPPFLAGS := -x assembler-with-cpp \ -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" \ - -DBOARD_DTS="$(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts/$(DEVICE_TREE).dts" + -DBOARD_DTS="$(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts/$(DEVICE_TREE).dts" \ + -I$(SRCTREE)/board/$(VENDOR)/dts -I$(SRCTREE)/arch/$(ARCH)/dts
all: $(obj).depend $(LIB)
Still lots of instances of this...
Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings.
Signed-off-by: Tom Warren twarren@nvidia.com Acked-by: Thierry Reding thierry.reding@avionic-design.de --- v3: new v4: no change v5: change /include/ to #include v6: change AD DT files ARCH_CPU_DTS to "tegra20-tamonten.dtsi"
board/avionic-design/dts/tegra20-medcom-wide.dts | 2 +- board/avionic-design/dts/tegra20-plutux.dts | 2 +- board/avionic-design/dts/tegra20-tamonten.dtsi | 489 ++++++++++++++++++++++ board/avionic-design/dts/tegra20-tec.dts | 2 +- 4 files changed, 492 insertions(+), 3 deletions(-) create mode 100644 board/avionic-design/dts/tegra20-tamonten.dtsi
diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/board/avionic-design/dts/tegra20-medcom-wide.dts index 934a4e6..2acfbc1 100644 --- a/board/avionic-design/dts/tegra20-medcom-wide.dts +++ b/board/avionic-design/dts/tegra20-medcom-wide.dts @@ -1,6 +1,6 @@ /dts-v1/;
-#include ARCH_CPU_DTS +#include "tegra20-tamonten.dtsi"
/ { model = "Avionic Design Medcom-Wide"; diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/board/avionic-design/dts/tegra20-plutux.dts index fc77031..dba200d 100644 --- a/board/avionic-design/dts/tegra20-plutux.dts +++ b/board/avionic-design/dts/tegra20-plutux.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Avionic Design Plutux"; diff --git a/board/avionic-design/dts/tegra20-tamonten.dtsi b/board/avionic-design/dts/tegra20-tamonten.dtsi new file mode 100644 index 0000000..4c0560e --- /dev/null +++ b/board/avionic-design/dts/tegra20-tamonten.dtsi @@ -0,0 +1,489 @@ +#include ARCH_CPU_DTS + +/ { + model = "Avionic Design Tamonten SOM"; + compatible = "ad,tamonten", "nvidia,tegra20"; + + memory { + reg = <0x00000000 0x20000000>; + }; + + host1x { + hdmi { + vdd-supply = <&hdmi_vdd_reg>; + pll-supply = <&hdmi_pll_reg>; + + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = <&gpio 111 0>; /* PN7 */ + }; + }; + + pinmux { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + ata { + nvidia,pins = "ata"; + nvidia,function = "ide"; + }; + atb { + nvidia,pins = "atb", "gma", "gme"; + nvidia,function = "sdio4"; + }; + atc { + nvidia,pins = "atc"; + nvidia,function = "nand"; + }; + atd { + nvidia,pins = "atd", "ate", "gmb", "gmd", "gpu", + "spia", "spib", "spic"; + nvidia,function = "gmi"; + }; + cdev1 { + nvidia,pins = "cdev1"; + nvidia,function = "plla_out"; + }; + cdev2 { + nvidia,pins = "cdev2"; + nvidia,function = "pllp_out4"; + }; + crtp { + nvidia,pins = "crtp"; + nvidia,function = "crt"; + }; + csus { + nvidia,pins = "csus"; + nvidia,function = "vi_sensor_clk"; + }; + dap1 { + nvidia,pins = "dap1"; + nvidia,function = "dap1"; + }; + dap2 { + nvidia,pins = "dap2"; + nvidia,function = "dap2"; + }; + dap3 { + nvidia,pins = "dap3"; + nvidia,function = "dap3"; + }; + dap4 { + nvidia,pins = "dap4"; + nvidia,function = "dap4"; + }; + dta { + nvidia,pins = "dta", "dtd"; + nvidia,function = "sdio2"; + }; + dtb { + nvidia,pins = "dtb", "dtc", "dte"; + nvidia,function = "rsvd1"; + }; + dtf { + nvidia,pins = "dtf"; + nvidia,function = "i2c3"; + }; + gmc { + nvidia,pins = "gmc"; + nvidia,function = "uartd"; + }; + gpu7 { + nvidia,pins = "gpu7"; + nvidia,function = "rtck"; + }; + gpv { + nvidia,pins = "gpv", "slxa", "slxk"; + nvidia,function = "pcie"; + }; + hdint { + nvidia,pins = "hdint"; + nvidia,function = "hdmi"; + }; + i2cp { + nvidia,pins = "i2cp"; + nvidia,function = "i2cp"; + }; + irrx { + nvidia,pins = "irrx", "irtx"; + nvidia,function = "uarta"; + }; + kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf"; + nvidia,function = "kbc"; + }; + lcsn { + nvidia,pins = "lcsn", "ld0", "ld1", "ld2", + "ld3", "ld4", "ld5", "ld6", "ld7", + "ld8", "ld9", "ld10", "ld11", "ld12", + "ld13", "ld14", "ld15", "ld16", "ld17", + "ldc", "ldi", "lhp0", "lhp1", "lhp2", + "lhs", "lm0", "lm1", "lpp", "lpw0", + "lpw1", "lpw2", "lsc0", "lsc1", "lsck", + "lsda", "lsdi", "lspi", "lvp0", "lvp1", + "lvs"; + nvidia,function = "displaya"; + }; + owc { + nvidia,pins = "owc", "spdi", "spdo", "uac"; + nvidia,function = "rsvd2"; + }; + pmc { + nvidia,pins = "pmc"; + nvidia,function = "pwr_on"; + }; + rm { + nvidia,pins = "rm"; + nvidia,function = "i2c1"; + }; + sdb { + nvidia,pins = "sdb", "sdc", "sdd"; + nvidia,function = "pwm"; + }; + sdio1 { + nvidia,pins = "sdio1"; + nvidia,function = "sdio1"; + }; + slxc { + nvidia,pins = "slxc", "slxd"; + nvidia,function = "spdif"; + }; + spid { + nvidia,pins = "spid", "spie", "spif"; + nvidia,function = "spi1"; + }; + spig { + nvidia,pins = "spig", "spih"; + nvidia,function = "spi2_alt"; + }; + uaa { + nvidia,pins = "uaa", "uab", "uda"; + nvidia,function = "ulpi"; + }; + uad { + nvidia,pins = "uad"; + nvidia,function = "irda"; + }; + uca { + nvidia,pins = "uca", "ucb"; + nvidia,function = "uartc"; + }; + conf_ata { + nvidia,pins = "ata", "atb", "atc", "atd", "ate", + "cdev1", "cdev2", "dap1", "dtb", "gma", + "gmb", "gmc", "gmd", "gme", "gpu7", + "gpv", "i2cp", "pta", "rm", "slxa", + "slxk", "spia", "spib", "uac"; + nvidia,pull = <0>; + nvidia,tristate = <0>; + }; + conf_ck32 { + nvidia,pins = "ck32", "ddrc", "pmca", "pmcb", + "pmcc", "pmcd", "pmce", "xm2c", "xm2d"; + nvidia,pull = <0>; + }; + conf_csus { + nvidia,pins = "csus", "spid", "spif"; + nvidia,pull = <1>; + nvidia,tristate = <1>; + }; + conf_crtp { + nvidia,pins = "crtp", "dap2", "dap3", "dap4", + "dtc", "dte", "dtf", "gpu", "sdio1", + "slxc", "slxd", "spdi", "spdo", "spig", + "uda"; + nvidia,pull = <0>; + nvidia,tristate = <1>; + }; + conf_ddc { + nvidia,pins = "ddc", "dta", "dtd", "kbca", + "kbcb", "kbcc", "kbcd", "kbce", "kbcf", + "sdc"; + nvidia,pull = <2>; + nvidia,tristate = <0>; + }; + conf_hdint { + nvidia,pins = "hdint", "lcsn", "ldc", "lm1", + "lpw1", "lsc1", "lsck", "lsda", "lsdi", + "lvp0", "owc", "sdb"; + nvidia,tristate = <1>; + }; + conf_irrx { + nvidia,pins = "irrx", "irtx", "sdd", "spic", + "spie", "spih", "uaa", "uab", "uad", + "uca", "ucb"; + nvidia,pull = <2>; + nvidia,tristate = <1>; + }; + conf_lc { + nvidia,pins = "lc", "ls"; + nvidia,pull = <2>; + }; + conf_ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lm0", "lpp", + "lpw0", "lpw2", "lsc0", "lspi", "lvp1", + "lvs", "pmc"; + nvidia,tristate = <0>; + }; + conf_ld17_0 { + nvidia,pins = "ld17_0", "ld19_18", "ld21_20", + "ld23_22"; + nvidia,pull = <1>; + }; + }; + + state_i2cmux_ddc: pinmux_i2cmux_ddc { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "i2c2"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + + state_i2cmux_pta: pinmux_i2cmux_pta { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "i2c2"; + }; + }; + + state_i2cmux_idle: pinmux_i2cmux_idle { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + }; + + i2s@70002800 { + status = "okay"; + }; + + serial@70006300 { + status = "okay"; + }; + + i2c@7000c000 { + clock-frequency = <400000>; + status = "okay"; + }; + + i2c@7000c400 { + clock-frequency = <100000>; + status = "okay"; + }; + + i2cmux { + compatible = "i2c-mux-pinctrl"; + #address-cells = <1>; + #size-cells = <0>; + + i2c-parent = <&{/i2c@7000c400}>; + + pinctrl-names = "ddc", "pta", "idle"; + pinctrl-0 = <&state_i2cmux_ddc>; + pinctrl-1 = <&state_i2cmux_pta>; + pinctrl-2 = <&state_i2cmux_idle>; + + hdmi_ddc: i2c@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + i2c@7000d000 { + clock-frequency = <400000>; + status = "okay"; + + pmic: tps6586x@34 { + compatible = "ti,tps6586x"; + reg = <0x34>; + interrupts = <0 86 0x4>; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + sys-supply = <&vdd_5v0_reg>; + vin-sm0-supply = <&sys_reg>; + vin-sm1-supply = <&sys_reg>; + vin-sm2-supply = <&sys_reg>; + vinldo01-supply = <&sm2_reg>; + vinldo23-supply = <&sm2_reg>; + vinldo4-supply = <&sm2_reg>; + vinldo678-supply = <&sm2_reg>; + vinldo9-supply = <&sm2_reg>; + + regulators { + sys_reg: sys { + regulator-name = "vdd_sys"; + regulator-always-on; + }; + + sm0 { + regulator-name = "vdd_sys_sm0,vdd_core"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + sm1 { + regulator-name = "vdd_sys_sm1,vdd_cpu"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + sm2_reg: sm2 { + regulator-name = "vdd_sys_sm2,vin_ldo*"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + regulator-always-on; + }; + + ldo0 { + regulator-name = "vdd_ldo0,vddio_pex_clk"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + ldo1 { + regulator-name = "vdd_ldo1,avdd_pll*"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + ldo2 { + regulator-name = "vdd_ldo2,vdd_rtc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + ldo3 { + regulator-name = "vdd_ldo3,avdd_usb*"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo4 { + regulator-name = "vdd_ldo4,avdd_osc,vddio_sys"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + ldo5 { + regulator-name = "vdd_ldo5,vcore_mmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + }; + + ldo6 { + regulator-name = "vdd_ldo6,avdd_vdac"; + /* + * According to the Tegra 2 Automotive + * DataSheet, a typical value for this + * would be 2.8V, but the PMIC only + * supports 2.85V. + */ + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + }; + + hdmi_vdd_reg: ldo7 { + regulator-name = "vdd_ldo7,avdd_hdmi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + hdmi_pll_reg: ldo8 { + regulator-name = "vdd_ldo8,avdd_hdmi_pll"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo9 { + regulator-name = "vdd_ldo9,vdd_ddr_rx,avdd_cam"; + /* + * According to the Tegra 2 Automotive + * DataSheet, a typical value for this + * would be 2.8V, but the PMIC only + * supports 2.85V. + */ + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo_rtc { + regulator-name = "vdd_rtc_out"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + temperature-sensor@4c { + compatible = "onnn,nct1008"; + reg = <0x4c>; + }; + }; + + pmc { + nvidia,invert-interrupt; + }; + + usb@c5008000 { + status = "okay"; + }; + + sdhci@c8000600 { + cd-gpios = <&gpio 58 1>; /* gpio PH2 */ + wp-gpios = <&gpio 59 0>; /* gpio PH3 */ + bus-width = <4>; + status = "okay"; + }; + + regulators { + compatible = "simple-bus"; + + #address-cells = <1>; + #size-cells = <0>; + + vdd_5v0_reg: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "vdd_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + }; +}; diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index 708adec..04e6730 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -1,6 +1,6 @@ /dts-v1/;
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux).
Signed-off-by: Tom Warren twarren@nvidia.com Tested-by: Thierry Reding thierry.reding@avionic-design.de --- v2: - cleanup comments in dts files/match w/kernel files - add sdhci aliases in all dts files - use tegra20-tamonten.dtsi from the kernel for AD boards v3: - include tamonten.dtsi file directly in AD dts files - fix Seaboard power-gpios flags - add cd-gpios for Colibri T20 Iris - add include paths to DTC command v4: - move dts Makefile change to separate patch v5: - change /include/ to #include, allows C preprocessor to find files v6: - change ARCH_CPU_DTS to "tegra20.dtsi" - change cd-gpios flags to 1, active-low
arch/arm/dts/tegra20.dtsi | 16 ++++++++++++---- board/avionic-design/dts/tegra20-medcom-wide.dts | 1 + board/avionic-design/dts/tegra20-plutux.dts | 1 + board/avionic-design/dts/tegra20-tec.dts | 1 + board/compal/dts/tegra20-paz00.dts | 21 ++++++++++++++++++--- board/compulab/dts/tegra20-trimslice.dts | 16 +++++++++++++++- board/nvidia/dts/tegra114-dalmore.dts | 2 +- board/nvidia/dts/tegra20-harmony.dts | 20 +++++++++++++++++++- board/nvidia/dts/tegra20-seaboard.dts | 14 +++++++++----- board/nvidia/dts/tegra20-ventana.dts | 17 ++++++++++++++++- board/nvidia/dts/tegra20-whistler.dts | 15 ++++++++++++++- board/nvidia/dts/tegra30-cardhu.dts | 2 +- board/toradex/dts/tegra20-colibri_t20_iris.dts | 9 ++++++++- 13 files changed, 116 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index d163ff8..3805750 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -318,24 +318,32 @@ sdhci@c8000000 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000000 0x200>; - interrupts = < 46 >; + interrupts = <0 14 0x04>; + clocks = <&tegra_car 14>; + status = "disabled"; };
sdhci@c8000200 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000200 0x200>; - interrupts = < 47 >; + interrupts = <0 15 0x04>; + clocks = <&tegra_car 9>; + status = "disabled"; };
sdhci@c8000400 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000400 0x200>; - interrupts = < 51 >; + interrupts = <0 19 0x04>; + clocks = <&tegra_car 69>; + status = "disabled"; };
sdhci@c8000600 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000600 0x200>; - interrupts = < 63 >; + interrupts = <0 31 0x04>; + clocks = <&tegra_car 15>; + status = "disabled"; }; }; diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/board/avionic-design/dts/tegra20-medcom-wide.dts index 2acfbc1..a9a07f9 100644 --- a/board/avionic-design/dts/tegra20-medcom-wide.dts +++ b/board/avionic-design/dts/tegra20-medcom-wide.dts @@ -8,6 +8,7 @@
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; };
memory { diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/board/avionic-design/dts/tegra20-plutux.dts index dba200d..20016f2 100644 --- a/board/avionic-design/dts/tegra20-plutux.dts +++ b/board/avionic-design/dts/tegra20-plutux.dts @@ -8,6 +8,7 @@
memory { diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index 04e6730..1d7cf89 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -8,6 +8,7 @@
memory { diff --git a/board/compal/dts/tegra20-paz00.dts b/board/compal/dts/tegra20-paz00.dts index b5580c9..780203c 100644 --- a/board/compal/dts/tegra20-paz00.dts +++ b/board/compal/dts/tegra20-paz00.dts @@ -1,13 +1,15 @@ /dts-v1/;
-#include ARCH_CPU_DTS +#include "tegra20.dtsi"
/ { - model = "Toshiba AC100 / Dynabook AZ"; - compatible = "compal,paz00", "nvidia,tegra20"; + model = "Toshiba AC100 / Dynabook AZ"; + compatible = "compal,paz00", "nvidia,tegra20";
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000000"; };
memory { @@ -53,6 +55,19 @@ status = "disabled"; };
+ sdhci@c8000000 { + status = "okay"; + cd-gpios = <&gpio 173 1>; /* gpio PV5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 169 0>; /* gpio PV1 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; + lcd_panel: panel { /* PAZ00 has 1024x600 */ clock = <54030000>; diff --git a/board/compulab/dts/tegra20-trimslice.dts b/board/compulab/dts/tegra20-trimslice.dts index 04cd121..ee31476 100644 --- a/board/compulab/dts/tegra20-trimslice.dts +++ b/board/compulab/dts/tegra20-trimslice.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Compulab TrimSlice board"; @@ -9,6 +9,8 @@ aliases { usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000000"; };
memory { @@ -47,4 +49,16 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000000 { + status = "okay"; + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 121 1>; /* gpio PP1 */ + wp-gpios = <&gpio 122 0>; /* gpio PP2 */ + bus-width = <4>; + }; }; diff --git a/board/nvidia/dts/tegra114-dalmore.dts b/board/nvidia/dts/tegra114-dalmore.dts index a3e7863..ccac932 100644 --- a/board/nvidia/dts/tegra114-dalmore.dts +++ b/board/nvidia/dts/tegra114-dalmore.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Dalmore"; diff --git a/board/nvidia/dts/tegra20-harmony.dts b/board/nvidia/dts/tegra20-harmony.dts index 35baff0..7934e4a 100644 --- a/board/nvidia/dts/tegra20-harmony.dts +++ b/board/nvidia/dts/tegra20-harmony.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Harmony evaluation board"; @@ -9,6 +9,8 @@ aliases { usb0 = "/usb@c5008000"; usb1 = "/usb@c5004000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000200"; };
memory { @@ -52,4 +54,20 @@ usb@c5004000 { nvidia,phy-reset-gpio = <&gpio 169 0>; /* gpio PV1 */ }; + + sdhci@c8000200 { + status = "okay"; + cd-gpios = <&gpio 69 1>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 155 0>; /* gpio PT3 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 58 1>; /* gpio PH2 */ + wp-gpios = <&gpio 59 0>; /* gpio PH3 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <8>; + }; }; diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/board/nvidia/dts/tegra20-seaboard.dts index bb56820..12cb0bc 100644 --- a/board/nvidia/dts/tegra20-seaboard.dts +++ b/board/nvidia/dts/tegra20-seaboard.dts @@ -1,7 +1,7 @@ /dts-v1/;
/memreserve/ 0x1c000000 0x04000000; -#include ARCH_CPU_DTS +#include "tegra20.dtsi"
/ { model = "NVIDIA Seaboard"; @@ -12,14 +12,15 @@ };
aliases { - /* This defines the order of our USB ports */ + /* This defines the order of our ports */ usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; - i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; i2c3 = "/i2c@7000c500"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -156,13 +157,16 @@ };
sdhci@c8000400 { - cd-gpios = <&gpio 69 0>; /* gpio PI5 */ + status = "okay"; + cd-gpios = <&gpio 69 1>; /* gpio PI5 */ wp-gpios = <&gpio 57 0>; /* gpio PH1 */ power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <4>; };
sdhci@c8000600 { - support-8bit; + status = "okay"; + bus-width = <8>; };
lcd_panel: panel { diff --git a/board/nvidia/dts/tegra20-ventana.dts b/board/nvidia/dts/tegra20-ventana.dts index b2cf863..e1a3d1e 100644 --- a/board/nvidia/dts/tegra20-ventana.dts +++ b/board/nvidia/dts/tegra20-ventana.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Ventana evaluation board"; @@ -8,6 +8,8 @@
aliases { usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -41,4 +43,17 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000400 { + status = "okay"; + cd-gpios = <&gpio 69 1>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + bus-width = <4>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; }; diff --git a/board/nvidia/dts/tegra20-whistler.dts b/board/nvidia/dts/tegra20-whistler.dts index aa3761f..eb92264 100644 --- a/board/nvidia/dts/tegra20-whistler.dts +++ b/board/nvidia/dts/tegra20-whistler.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "NVIDIA Tegra20 Whistler evaluation board"; @@ -9,6 +9,8 @@ aliases { i2c0 = "/i2c@7000d000"; usb0 = "/usb@c5008000"; + sdhci0 = "/sdhci@c8000600"; + sdhci1 = "/sdhci@c8000400"; };
memory { @@ -57,4 +59,15 @@ usb@c5004000 { status = "disabled"; }; + + sdhci@c8000400 { + status = "okay"; + wp-gpios = <&gpio 173 0>; /* gpio PV5 */ + bus-width = <8>; + }; + + sdhci@c8000600 { + status = "okay"; + bus-width = <8>; + }; }; diff --git a/board/nvidia/dts/tegra30-cardhu.dts b/board/nvidia/dts/tegra30-cardhu.dts index f7ea07a..383cdb5 100644 --- a/board/nvidia/dts/tegra30-cardhu.dts +++ b/board/nvidia/dts/tegra30-cardhu.dts @@ -1,7 +1,7 @@ /dts-v1/;
/ { model = "NVIDIA Cardhu"; diff --git a/board/toradex/dts/tegra20-colibri_t20_iris.dts b/board/toradex/dts/tegra20-colibri_t20_iris.dts index d8a0328..c0e54af 100644 --- a/board/toradex/dts/tegra20-colibri_t20_iris.dts +++ b/board/toradex/dts/tegra20-colibri_t20_iris.dts @@ -1,6 +1,6 @@ /dts-v1/;
/ { model = "Toradex Colibri T20"; @@ -10,6 +10,7 @@ usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; usb2 = "/usb@c5004000"; + sdhci0 = "/sdhci@c8000600"; };
usb@c5000000 { @@ -35,4 +36,10 @@ compatible = "nand-flash"; }; }; + + sdhci@c8000600 { + status = "okay"; + cd-gpios = <&gpio 23 1>; /* gpio PC7 */ + bus-width = <4>; + }; };
I just noticed that I used 'tegra20.dtsi' in the tegra114.dtsi and tegra30.dtsi files, which is obviously functionally wrong, but doesn't break the build. I'll handle this when I apply this patchset to u-boot-tegra/next (assuming it gets enough Acks). I'm also going to submit a cleanup patch for the memreserve fields that Stephen pointed out in Seaboard and Cardhu dts.
v2:
v3:
v4:
v5:
v6:
status = "disabled"; }; sdhci@c8000200 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000200 0x200>;
status = "disabled"; }; sdhci@c8000400 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000400 0x200>;
status = "disabled"; }; sdhci@c8000600 { compatible = "nvidia,tegra20-sdhci"; reg = <0xc8000600 0x200>;
sdhci0 = "/sdhci@c8000600"; }; memory {
compatible = "compal,paz00", "nvidia,tegra20"; aliases { usb0 = "/usb@c5008000";
sdhci1 = "/sdhci@c8000000"; }; memory {
sdhci@c8000000 {
status = "okay";
bus-width = <4>;
sdhci@c8000600 {
status = "okay";
bus-width = <8>;
sdhci@c8000000 {
status = "okay";
bus-width = <4>;
sdhci@c8000600 {
status = "okay";
bus-width = <4>;
sdhci1 = "/sdhci@c8000200"; }; memory {
sdhci@c8000200 {
status = "okay";
bus-width = <4>;
sdhci@c8000600 {
status = "okay";
bus-width = <8>;
aliases {
sdhci1 = "/sdhci@c8000400"; }; memory {
sdhci@c8000400 {
status = "okay";
bus-width = <4>; }; sdhci@c8000600 {
support-8bit;
status = "okay";
bus-width = <8>; }; lcd_panel: panel {
sdhci@c8000400 {
status = "okay";
bus-width = <4>;
sdhci@c8000600 {
status = "okay";
bus-width = <8>;
sdhci@c8000400 {
status = "okay";
bus-width = <8>;
sdhci@c8000600 {
status = "okay";
bus-width = <8>;
sdhci0 = "/sdhci@c8000600"; }; usb@c5000000 {
sdhci@c8000600 {
status = "okay";
bus-width = <4>;
1.7.0.4
looks (and boots) fine now. Thanks!
Tested-by: Marc Dietrich marvin24@gmx.de
v2:
v3:
v4:
v5:
v6:
};status = "disabled";
memory {
memory {
memory {
memory {
- sdhci@c8000000 {
status = "okay";
bus-width = <4>;
- sdhci@c8000600 {
status = "okay";
bus-width = <8>;
- lcd_panel: panel { /* PAZ00 has 1024x600 */ clock = <54030000>;
memory {
- sdhci@c8000000 {
status = "okay";
bus-width = <4>;
- sdhci@c8000600 {
status = "okay";
bus-width = <4>;
memory {
- sdhci@c8000200 {
status = "okay";
bus-width = <4>;
- sdhci@c8000600 {
status = "okay";
bus-width = <8>;
aliases {
usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000";/* This defines the order of our ports */
memory {
sdhci@c8000400 {
status = "okay";
bus-width = <4>;
sdhci@c8000600 {
support-8bit;
status = "okay";
bus-width = <8>;
lcd_panel: panel {
memory {
- sdhci@c8000400 {
status = "okay";
bus-width = <4>;
- sdhci@c8000600 {
status = "okay";
bus-width = <8>;
memory {
- sdhci@c8000400 {
status = "okay";
bus-width = <8>;
- sdhci@c8000600 {
status = "okay";
bus-width = <8>;
usb@c5000000 {
- sdhci@c8000600 {
status = "okay";
bus-width = <4>;
v6:
Oh. That should be a separate patch, or part of patch 1. It has nothing to do with SDHCI.
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional.
Signed-off-by: Tom Warren twarren@nvidia.com Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- v2: - all boards now call tegra_mmc_init once, w/no params - count MMC controllers, not aliases - AD boards (medcom/plutux/tec) use common tegra20-tamonten.dtsi v3: - move any power init inside board's pin_mux_mmc function, and/or create pin_mux_mmc function if necessary. - move board_mmc_init out of each board file and into ../common/board.c v4: - remove #ifdef CONFIG_TEGRA_MMC from trimslice.c - fix minor whitespace issue in board/nvidia/common/board.c - remove marking of used node_list entries in MMC driver, not needed v5: - restore previous debug statements, remove any new ones - fix pwr_gpio/cd_gpio initialization in do_mmc_init - update copyright to 2013 v6: - change tegra_mmc_getcd to reflect new cd-gpios polarity (active-low)
arch/arm/include/asm/arch-tegra/mmc.h | 2 +- arch/arm/include/asm/arch-tegra/tegra_mmc.h | 13 +- board/avionic-design/common/tamonten.c | 19 +-- board/compal/paz00/paz00.c | 26 +--- board/compulab/trimslice/trimslice.c | 23 +--- board/nvidia/common/board.c | 25 +++ board/nvidia/harmony/harmony.c | 26 +--- board/nvidia/seaboard/seaboard.c | 25 +--- board/nvidia/whistler/whistler.c | 30 +--- board/toradex/colibri_t20_iris/colibri_t20_iris.c | 11 +- drivers/mmc/tegra_mmc.c | 179 ++++++++++++++------- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 13 files changed, 173 insertions(+), 208 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/mmc.h b/arch/arm/include/asm/arch-tegra/mmc.h index 5c95047..71ad407 100644 --- a/arch/arm/include/asm/arch-tegra/mmc.h +++ b/arch/arm/include/asm/arch-tegra/mmc.h @@ -22,6 +22,6 @@ #ifndef _TEGRA_MMC_H_ #define _TEGRA_MMC_H_
-int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio); +void tegra_mmc_init(void);
#endif /* _TEGRA_MMC_H_ */ diff --git a/arch/arm/include/asm/arch-tegra/tegra_mmc.h b/arch/arm/include/asm/arch-tegra/tegra_mmc.h index dd746ca..bd18f5f 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_mmc.h +++ b/arch/arm/include/asm/arch-tegra/tegra_mmc.h @@ -27,6 +27,8 @@ #define TEGRA_SDMMC3_BASE 0xC8000400 #define TEGRA_SDMMC4_BASE 0xC8000600
+#define MAX_HOSTS 4 /* Max number of 'hosts'/controllers */ + #ifndef __ASSEMBLY__ struct tegra_mmc { unsigned int sysad; /* _SYSTEM_ADDRESS_0 */ @@ -119,12 +121,15 @@ struct tegra_mmc {
struct mmc_host { struct tegra_mmc *reg; + int id; /* device id/number, 0-3 */ + int enabled; /* 1 to enable, 0 to disable */ + int width; /* Bus Width, 1, 4 or 8 */ + enum periph_id mmc_id; /* Peripheral ID: PERIPH_ID_... */ + struct fdt_gpio_state cd_gpio; /* Change Detect GPIO */ + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state wp_gpio; /* Write Protect GPIO */ unsigned int version; /* SDHCI spec. version */ unsigned int clock; /* Current clock (MHz) */ - unsigned int base; /* Base address, SDMMC1/2/3/4 */ - enum periph_id mmc_id; /* Peripheral ID: PERIPH_ID_... */ - int pwr_gpio; /* Power GPIO */ - int cd_gpio; /* Change Detect GPIO */ };
#endif /* __ASSEMBLY__ */ diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index e6a932e..ea95e43 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -33,13 +33,8 @@ #include <asm/arch/tegra.h> #include <asm/arch-tegra/board.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/mmc.h> #include <asm/arch-tegra/sys_proto.h> #include <asm/arch-tegra/uart.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_BOARD_EARLY_INIT_F void gpio_early_init(void) @@ -54,7 +49,7 @@ void gpio_early_init(void) * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); /* for write-protect GPIO PI6 */ @@ -62,16 +57,4 @@ static void pin_mux_mmc(void) /* for CD GPIO PH2 */ pinmux_tristate_disable(PINGRP_ATD); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0, SD slot, with 4-bit bus */ - tegra_mmc_init(0, 4, GPIO_PI6, GPIO_PH2); - - return 0; -} #endif diff --git a/board/compal/paz00/paz00.c b/board/compal/paz00/paz00.c index 1447f47..d6e5c37 100644 --- a/board/compal/paz00/paz00.c +++ b/board/compal/paz00/paz00.c @@ -18,19 +18,14 @@ #include <asm/io.h> #include <asm/arch/tegra.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { /* SDMMC4: config 3, x8 on 2nd set of pins */ pinmux_set_func(PINGRP_ATB, PMUX_FUNC_SDIO4); @@ -51,25 +46,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PV5 */ pinmux_tristate_disable(PINGRP_GPV); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init eMMC\n"); - /* init dev 0, eMMC chip, with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - debug("board_mmc_init: init SD slot\n"); - /* init dev 3, SD slot, with 4-bit bus */ - tegra_mmc_init(3, 4, GPIO_PV1, GPIO_PV5); - - return 0; -} #endif
#ifdef CONFIG_LCD diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c index 8f4dd09..8401100 100644 --- a/board/compulab/trimslice/trimslice.c +++ b/board/compulab/trimslice/trimslice.c @@ -27,12 +27,8 @@ #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> #include <i2c.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif
void pin_mux_usb(void) { @@ -52,7 +48,7 @@ void pin_mux_spi(void) * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC1, FUNCMUX_SDMMC1_SDIO1_4BIT); funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); @@ -60,20 +56,3 @@ static void pin_mux_mmc(void) /* For CD GPIO PP1 */ pinmux_tristate_disable(PINGRP_DAP3); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0 (SDMMC4), (micro-SD slot) with 4-bit bus */ - tegra_mmc_init(0, 4, -1, GPIO_PP1); - - /* init dev 3 (SDMMC1), (SD slot) with 4-bit bus */ - tegra_mmc_init(3, 4, -1, -1); - - return 0; -} diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index d1d8a29..474a4a2 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -48,6 +48,9 @@ #ifdef CONFIG_USB_EHCI_TEGRA #include <asm/arch/usb.h> #endif +#ifdef CONFIG_TEGRA_MMC +#include <asm/arch-tegra/mmc.h> +#endif #include <i2c.h> #include <spi.h> #include "emc.h" @@ -221,3 +224,25 @@ int board_late_init(void) #endif return 0; } + +#if defined(CONFIG_TEGRA_MMC) +void __pin_mux_mmc(void) +{ +} + +void pin_mux_mmc(void) __attribute__((weak, alias("__pin_mux_mmc"))); + +/* this is a weak define that we are overriding */ +int board_mmc_init(bd_t *bd) +{ + debug("%s called\n", __func__); + + /* Enable muxes, etc. for SDMMC controllers */ + pin_mux_mmc(); + + debug("%s: init MMC\n", __func__); + tegra_mmc_init(); + + return 0; +} +#endif diff --git a/board/nvidia/harmony/harmony.c b/board/nvidia/harmony/harmony.c index 93430ed..3122441 100644 --- a/board/nvidia/harmony/harmony.c +++ b/board/nvidia/harmony/harmony.c @@ -27,19 +27,14 @@ #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> #include <asm/arch/tegra.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); funcmux_select(PERIPH_ID_SDMMC2, FUNCMUX_SDMMC2_DTA_DTD_8BIT); @@ -54,25 +49,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PI5 */ pinmux_tristate_disable(PINGRP_ATC); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init SD slot J26\n"); - /* init dev 0, SD slot J26, with 8-bit bus */ - tegra_mmc_init(0, 8, GPIO_PI6, GPIO_PH2); - - debug("board_mmc_init: init SD slot J5\n"); - /* init dev 2, SD slot J5, with 4-bit bus */ - tegra_mmc_init(2, 4, GPIO_PT3, GPIO_PI5); - - return 0; -} #endif
void pin_mux_usb(void) diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index 3e33da0..e581fdd 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -28,11 +28,7 @@ #include <asm/arch/funcmux.h> #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif
/* TODO: Remove this code when the SPI switch is working */ #if !defined(CONFIG_SPI_UART_SWITCH) && (CONFIG_MACH_TYPE != MACH_TYPE_VENTANA) @@ -51,7 +47,7 @@ void gpio_early_init_uart(void) * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_4BIT); @@ -61,25 +57,6 @@ static void pin_mux_mmc(void) /* For CD GPIO PI5 */ pinmux_tristate_disable(PINGRP_ATC); } - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) -{ - debug("board_mmc_init called\n"); - - /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - debug("board_mmc_init: init eMMC\n"); - /* init dev 0, eMMC chip, with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - debug("board_mmc_init: init SD slot\n"); - /* init dev 1, SD slot, with 4-bit bus */ - tegra_mmc_init(1, 4, GPIO_PI6, GPIO_PI5); - - return 0; -} #endif
void pin_mux_usb(void) diff --git a/board/nvidia/whistler/whistler.c b/board/nvidia/whistler/whistler.c index 592cd6b..f18aa27 100644 --- a/board/nvidia/whistler/whistler.c +++ b/board/nvidia/whistler/whistler.c @@ -27,32 +27,19 @@ #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> -#include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> #include <i2c.h> -#ifdef CONFIG_TEGRA_MMC -#include <mmc.h> -#endif -
+#ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc * Description: setup the pin muxes/tristate values for the SDMMC(s) */ -static void pin_mux_mmc(void) -{ - funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_SLXA_8BIT); - funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATC_ATD_8BIT); -} - -/* this is a weak define that we are overriding */ -int board_mmc_init(bd_t *bd) +void pin_mux_mmc(void) { uchar val; int ret;
- debug("board_mmc_init called\n"); - /* Turn on MAX8907B LDO12 to 2.8V for J40 power */ ret = i2c_set_bus_num(0); if (ret) @@ -70,17 +57,10 @@ int board_mmc_init(bd_t *bd) if (ret) printf("i2c_write 0 0x3c 0x44 failed: %d\n", ret);
- /* Enable muxes, etc. for SDMMC controllers */ - pin_mux_mmc(); - - /* init dev 0 (SDMMC4), (J29 "HSMMC") with 8-bit bus */ - tegra_mmc_init(0, 8, -1, -1); - - /* init dev 1 (SDMMC3), (J40 "SDIO3") with 8-bit bus */ - tegra_mmc_init(1, 8, -1, -1); - - return 0; + funcmux_select(PERIPH_ID_SDMMC3, FUNCMUX_SDMMC3_SDB_SLXA_8BIT); + funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATC_ATD_8BIT); } +#endif
/* this is a weak define that we are overriding */ void pin_mux_usb(void) diff --git a/board/toradex/colibri_t20_iris/colibri_t20_iris.c b/board/toradex/colibri_t20_iris/colibri_t20_iris.c index e40a986..aa76f65 100644 --- a/board/toradex/colibri_t20_iris/colibri_t20_iris.c +++ b/board/toradex/colibri_t20_iris/colibri_t20_iris.c @@ -19,7 +19,6 @@ #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> #include <asm/arch-tegra/board.h> -#include <asm/arch-tegra/mmc.h>
#include "../colibri_t20-common/colibri_t20-common.h"
@@ -34,13 +33,13 @@ void pin_mux_usb(void) #endif
#ifdef CONFIG_TEGRA_MMC -int board_mmc_init(bd_t *bd) +/* + * Routine: pin_mux_mmc + * Description: setup the pin muxes/tristate values for the SDMMC(s) + */ +void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); pinmux_tristate_disable(PINGRP_GMB); - - tegra_mmc_init(0, 4, -1, GPIO_PC7); - - return 0; } #endif diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index d749ab0..6063d08 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -2,7 +2,7 @@ * (C) Copyright 2009 SAMSUNG Electronics * Minkyu Kang mk7.kang@samsung.com * Jaehoon Chung jh80.chung@samsung.com - * Portions Copyright 2011-2012 NVIDIA Corporation + * Portions Copyright 2011-2013 NVIDIA Corporation * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -21,6 +21,7 @@
#include <bouncebuf.h> #include <common.h> +#include <fdtdec.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/clock.h> @@ -28,44 +29,14 @@ #include <asm/arch-tegra/tegra_mmc.h> #include <mmc.h>
-/* support 4 mmc hosts */ -struct mmc mmc_dev[4]; -struct mmc_host mmc_host[4]; +DECLARE_GLOBAL_DATA_PTR;
+struct mmc mmc_dev[MAX_HOSTS]; +struct mmc_host mmc_host[MAX_HOSTS];
-/** - * Get the host address and peripheral ID for a device. Devices are numbered - * from 0 to 3. - * - * @param host Structure to fill in (base, reg, mmc_id) - * @param dev_index Device index (0-3) - */ -static void tegra_get_setup(struct mmc_host *host, int dev_index) -{ - debug("tegra_get_setup: dev_index = %d\n", dev_index); - - switch (dev_index) { - case 1: - host->base = TEGRA_SDMMC3_BASE; - host->mmc_id = PERIPH_ID_SDMMC3; - break; - case 2: - host->base = TEGRA_SDMMC2_BASE; - host->mmc_id = PERIPH_ID_SDMMC2; - break; - case 3: - host->base = TEGRA_SDMMC1_BASE; - host->mmc_id = PERIPH_ID_SDMMC1; - break; - case 0: - default: - host->base = TEGRA_SDMMC4_BASE; - host->mmc_id = PERIPH_ID_SDMMC4; - break; - } - - host->reg = (struct tegra_mmc *)host->base; -} +#ifndef CONFIG_OF_CONTROL +#error "Please enable device tree support to use this driver" +#endif
static void mmc_prepare_data(struct mmc_host *host, struct mmc_data *data, struct bounce_buffer *bbstate) @@ -518,41 +489,43 @@ int tegra_mmc_getcd(struct mmc *mmc)
debug("tegra_mmc_getcd called\n");
- if (host->cd_gpio >= 0) - return !gpio_get_value(host->cd_gpio); + if (fdt_gpio_isvalid(&host->cd_gpio)) + return fdtdec_get_gpio(&host->cd_gpio);
return 1; }
-int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio) +static int do_mmc_init(int dev_index) { struct mmc_host *host; char gpusage[12]; /* "SD/MMCn PWR" or "SD/MMCn CD" */ struct mmc *mmc;
- debug(" tegra_mmc_init: index %d, bus width %d " - "pwr_gpio %d cd_gpio %d\n", - dev_index, bus_width, pwr_gpio, cd_gpio); - + /* DT should have been read & host config filled in */ host = &mmc_host[dev_index]; + if (!host->enabled) + return -1;
- host->clock = 0; - host->pwr_gpio = pwr_gpio; - host->cd_gpio = cd_gpio; - tegra_get_setup(host, dev_index); + debug(" do_mmc_init: index %d, bus width %d " + "pwr_gpio %d cd_gpio %d\n", + dev_index, host->width, + host->pwr_gpio.gpio, host->cd_gpio.gpio);
+ host->clock = 0; clock_start_periph_pll(host->mmc_id, CLOCK_ID_PERIPH, 20000000);
- if (host->pwr_gpio >= 0) { + if (fdt_gpio_isvalid(&host->pwr_gpio)) { sprintf(gpusage, "SD/MMC%d PWR", dev_index); - gpio_request(host->pwr_gpio, gpusage); - gpio_direction_output(host->pwr_gpio, 1); + gpio_request(host->pwr_gpio.gpio, gpusage); + gpio_direction_output(host->pwr_gpio.gpio, 1); + debug(" Power GPIO name = %s\n", host->pwr_gpio.name); }
- if (host->cd_gpio >= 0) { + if (fdt_gpio_isvalid(&host->cd_gpio)) { sprintf(gpusage, "SD/MMC%d CD", dev_index); - gpio_request(host->cd_gpio, gpusage); - gpio_direction_input(host->cd_gpio); + gpio_request(host->cd_gpio.gpio, gpusage); + gpio_direction_input(host->cd_gpio.gpio); + debug(" CD GPIO name = %s\n", host->cd_gpio.name); }
mmc = &mmc_dev[dev_index]; @@ -566,9 +539,9 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio)
mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; mmc->host_caps = 0; - if (bus_width == 8) + if (host->width == 8) mmc->host_caps |= MMC_MODE_8BIT; - if (bus_width >= 4) + if (host->width >= 4) mmc->host_caps |= MMC_MODE_4BIT; mmc->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_HC;
@@ -577,8 +550,6 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio) * low-speed SDIO card frequency (actually 400KHz) * max freq is highest HS eMMC clock as per the SD/MMC spec * (actually 52MHz) - * Both of these are the closest equivalents w/216MHz source - * clock and Tegra SDMMC divisors. */ mmc->f_min = 375000; mmc->f_max = 48000000; @@ -587,3 +558,95 @@ int tegra_mmc_init(int dev_index, int bus_width, int pwr_gpio, int cd_gpio)
return 0; } + +/** + * Get the host address and peripheral ID for a node. + * + * @param blob fdt blob + * @param node Device index (0-3) + * @param host Structure to fill in (reg, width, mmc_id) + */ +static int mmc_get_config(const void *blob, int node, struct mmc_host *host) +{ + debug("%s: node = %d\n", __func__, node); + + host->enabled = fdtdec_get_is_enabled(blob, node); + + host->reg = (struct tegra_mmc *)fdtdec_get_addr(blob, node, "reg"); + if ((fdt_addr_t)host->reg == FDT_ADDR_T_NONE) { + debug("%s: no sdmmc base reg info found\n", __func__); + return -FDT_ERR_NOTFOUND; + } + + host->mmc_id = clock_decode_periph_id(blob, node); + if (host->mmc_id == PERIPH_ID_NONE) { + debug("%s: could not decode periph id\n", __func__); + return -FDT_ERR_NOTFOUND; + } + + /* + * NOTE: mmc->bus_width is determined by mmc.c dynamically. + * TBD: Override it with this value? + */ + host->width = fdtdec_get_int(blob, node, "bus-width", 0); + if (!host->width) + debug("%s: no sdmmc width found\n", __func__); + + /* These GPIOs are optional */ + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + fdtdec_decode_gpio(blob, node, "wp-gpios", &host->wp_gpio); + fdtdec_decode_gpio(blob, node, "power-gpios", &host->pwr_gpio); + + debug("%s: found controller at %p, width = %d, periph_id = %d\n", + __func__, host->reg, host->width, host->mmc_id); + return 0; +} + +/* + * Process a list of nodes, adding them to our list of SDMMC ports. + * + * @param blob fdt blob + * @param node_list list of nodes to process (any <=0 are ignored) + * @param count number of nodes to process + * @return 0 if ok, -1 on error + */ +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct mmc_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build mmc_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &mmc_host[i]; + host->id = i; + + if (mmc_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_mmc_init(i); + } + return 0; +} + +void tegra_mmc_init(void) +{ + int node_list[MAX_HOSTS], count; + const void *blob = gd->fdt_blob; + debug("%s entry\n", __func__); + + count = fdtdec_find_aliases_for_id(blob, "sdhci", + COMPAT_NVIDIA_TEGRA20_SDMMC, node_list, MAX_HOSTS); + debug("%s: count of sdhci nodes is %d\n", __func__, count); + + if (process_nodes(blob, node_list, count)) { + printf("%s: Error processing mmc node(s)!\n", __func__); + return; + } +} diff --git a/include/fdtdec.h b/include/fdtdec.h index 77f244f..4f9dbcf 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -70,6 +70,7 @@ enum fdt_compat_id { COMPAT_NVIDIA_TEGRA20_NAND, /* Tegra2 NAND controller */ COMPAT_NVIDIA_TEGRA20_PWM, /* Tegra 2 PWM controller */ COMPAT_NVIDIA_TEGRA20_DC, /* Tegra 2 Display controller */ + COMPAT_NVIDIA_TEGRA20_SDMMC, /* Tegra SDMMC controller */ COMPAT_NVIDIA_TEGRA20_SFLASH, /* Tegra 2 SPI flash controller */ COMPAT_NVIDIA_TEGRA20_SLINK, /* Tegra 2 SPI SLINK controller */ COMPAT_SMSC_LAN9215, /* SMSC 10/100 Ethernet LAN9215 */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 3ae348d..57e552c 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -45,6 +45,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(NVIDIA_TEGRA20_NAND, "nvidia,tegra20-nand"), COMPAT(NVIDIA_TEGRA20_PWM, "nvidia,tegra20-pwm"), COMPAT(NVIDIA_TEGRA20_DC, "nvidia,tegra20-dc"), + COMPAT(NVIDIA_TEGRA20_SDMMC, "nvidia,tegra20-sdhci"), COMPAT(NVIDIA_TEGRA20_SFLASH, "nvidia,tegra20-sflash"), COMPAT(NVIDIA_TEGRA20_SLINK, "nvidia,tegra20-slink"), COMPAT(SMSC_LAN9215, "smsc,lan9215"),
Aside from the patch split issue I mentioned earlier, the series, Reviewed-by: Stephen Warren swarren@nvidia.com
Marc Dietrich
Stephen Warren
Tom Warren
