[U-Boot] [PATCH 1/3] zynqmp: Define routines for mmio write and read
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Define routines of mmio write and read functionalities for zynqmp platform.
Also do not call SMC from SPL because SPL is running before ATF in EL3 that's why SMCs can't be called because there is nothing to call. zynqmp_mmio*() are doing direct read/write accesses and this patch does the same. PMUFW is up and running at this time and there is a way to talk to pmufw via IPI but there is no reason to implement IPI stuff in SPL if we need just simple read for getting clock driver to work.
Also make invoke_smc as global so that it can be reused in multile places where ever possible.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/cpu/armv8/zynqmp/cpu.c | 73 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 7 +++ 2 files changed, 80 insertions(+)
diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index 280e07ad3695..f7ed179c1866 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -98,3 +98,76 @@ unsigned int zynqmp_get_silicon_version(void)
return ZYNQMP_CSU_VERSION_SILICON; } + +#define ZYNQMP_MMIO_READ 0xC2000014 +#define ZYNQMP_MMIO_WRITE 0xC2000013 + +#ifndef CONFIG_SPL_BUILD +int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, + u32 *ret_payload) +{ + /* + * Added SIP service call Function Identifier + * Make sure to stay in x0 register + */ + struct pt_regs regs; + + regs.regs[0] = pm_api_id; + regs.regs[1] = ((u64)arg1 << 32) | arg0; + regs.regs[2] = ((u64)arg3 << 32) | arg2; + + smc_call(®s); + + if (ret_payload != NULL) { + ret_payload[0] = (u32)regs.regs[0]; + ret_payload[1] = upper_32_bits(regs.regs[0]); + ret_payload[2] = (u32)regs.regs[1]; + ret_payload[3] = upper_32_bits(regs.regs[1]); + ret_payload[4] = (u32)regs.regs[2]; + } + + return regs.regs[0]; +} + +int zynqmp_mmio_write(const u32 address, + const u32 mask, + const u32 value) +{ + return invoke_smc(ZYNQMP_MMIO_WRITE, address, mask, value, 0, NULL); +} + +int zynqmp_mmio_read(const u32 address, u32 *value) +{ + u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 ret; + + if (!value) + return -EINVAL; + + ret = invoke_smc(ZYNQMP_MMIO_READ, address, 0, 0, 0, ret_payload); + *value = ret_payload[1]; + + return ret; +} +#else +int zynqmp_mmio_write(const u32 address, + const u32 mask, + const u32 value) +{ + u32 data; + u32 value_local = value; + + zynqmp_mmio_read(address, &data); + data &= ~mask; + value_local &= mask; + value_local |= data; + writel(value_local, (ulong)address); + return 0; +} + +int zynqmp_mmio_read(const u32 address, u32 *value) +{ + *value = readl((ulong)address); + return 0; +} +#endif diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 7b11895481be..4ae1bb6eef7c 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -8,6 +8,8 @@ #ifndef _ASM_ARCH_SYS_PROTO_H #define _ASM_ARCH_SYS_PROTO_H
+#define PAYLOAD_ARG_CNT 5 + int zynq_slcr_get_mio_pin_status(const char *periph);
unsigned int zynqmp_get_silicon_version(void); @@ -16,4 +18,9 @@ void psu_init(void);
void handoff_setup(void);
+int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); +int zynqmp_mmio_read(const u32 address, u32 *value); +int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, + u32 *ret_payload); + #endif /* _ASM_ARCH_SYS_PROTO_H */
Reuse invoke_smc() routine which is already defined instead of duplicating same at multiple places.
drivers/fpga/zynqmppl.c | 25 ++++++++----------------- 1 file changed, 8 insertions(+), 17 deletions(-)
diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 23039c3eb2d8..57a4e6c88e7a 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -10,6 +10,7 @@ #include <common.h> #include <zynqmppl.h> #include <linux/sizes.h> +#include <asm/arch/sys_proto.h>
#define DUMMY_WORD 0xffffffff
@@ -191,25 +192,14 @@ static int zynqmp_validate_bitstream(xilinx_desc *desc, const void *buf, return 0; }
-static int invoke_smc(ulong id, ulong reg0, ulong reg1, ulong reg2) -{ - struct pt_regs regs; - regs.regs[0] = id; - regs.regs[1] = reg0; - regs.regs[2] = reg1; - regs.regs[3] = reg2; - - smc_call(®s); - - return regs.regs[0]; -} - static int zynqmp_load(xilinx_desc *desc, const void *buf, size_t bsize, bitstream_type bstype) { u32 swap; - ulong bin_buf, flags; + ulong bin_buf; int ret; + u32 buf_lo, buf_hi; + u32 ret_payload[PAYLOAD_ARG_CNT];
if (zynqmp_validate_bitstream(desc, buf, bsize, bsize, &swap)) return FPGA_FAIL; @@ -224,9 +214,10 @@ static int zynqmp_load(xilinx_desc *desc, const void *buf, size_t bsize, else bsize = bsize / 4;
- flags = (u32)bsize | ((u64)bstype << 32); - - ret = invoke_smc(ZYNQMP_SIP_SVC_PM_FPGA_LOAD, bin_buf, flags, 0); + buf_lo = (u32)bin_buf; + buf_hi = upper_32_bits(bin_buf); + ret = invoke_smc(ZYNQMP_SIP_SVC_PM_FPGA_LOAD, buf_lo, buf_hi, bsize, + bstype, ret_payload); if (ret) debug("PL FPGA LOAD fail\n");
If PMUFW version is not v0.3 then panic. ZynqMP switch to CCF based clock driver which requires PMUFW to be present at certain version. This patch ensure that you use correct and tested PMUFW binary.
arch/arm/cpu/armv8/zynqmp/cpu.c | 35 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 1 + board/xilinx/zynqmp/zynqmp.c | 8 +++++++ include/configs/xilinx_zynqmp.h | 2 ++ 4 files changed, 46 insertions(+)
diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index f7ed179c1866..94ecf9066028 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -129,6 +129,41 @@ int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, return regs.regs[0]; }
+#define ZYNQMP_SIP_SVC_GET_API_VERSION 0xC2000001 + +#define ZYNQMP_PM_VERSION_MAJOR 0 +#define ZYNQMP_PM_VERSION_MINOR 3 +#define ZYNQMP_PM_VERSION_MAJOR_SHIFT 16 +#define ZYNQMP_PM_VERSION_MINOR_MASK 0xFFFF + +#define ZYNQMP_PM_VERSION \ + ((ZYNQMP_PM_VERSION_MAJOR << ZYNQMP_PM_VERSION_MAJOR_SHIFT) | \ + ZYNQMP_PM_VERSION_MINOR) + +#if defined(CONFIG_CLK_ZYNQMP) +void zynqmp_pmufw_version(void) +{ + int ret; + u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 pm_api_version; + + ret = invoke_smc(ZYNQMP_SIP_SVC_GET_API_VERSION, 0, 0, 0, 0, + ret_payload); + pm_api_version = ret_payload[1]; + + if (ret) + panic("PMUFW is not found - Please load it!\n"); + + printf("PMUFW:\tv%d.%d\n", + pm_api_version >> ZYNQMP_PM_VERSION_MAJOR_SHIFT, + pm_api_version & ZYNQMP_PM_VERSION_MINOR_MASK); + + if (pm_api_version != ZYNQMP_PM_VERSION) + panic("PMUFW version error. Expected: v%d.%d\n", + ZYNQMP_PM_VERSION_MAJOR, ZYNQMP_PM_VERSION_MINOR); +} +#endif + int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value) diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 4ae1bb6eef7c..d91d98a1196c 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -18,6 +18,7 @@ void psu_init(void);
+void zynqmp_pmufw_version(void); int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); int zynqmp_mmio_read(const u32 address, u32 *value); int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 3849b5885dfe..51a3d9f276b7 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -113,6 +113,14 @@ static char *zynqmp_get_silicon_idcode_name(void) } #endif
+int board_early_init_f(void) +{ +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_CLK_ZYNQMP) + zynqmp_pmufw_version(); +#endif + return 0; +} + #define ZYNQMP_VERSION_SIZE 9
int board_init(void) diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 87a5da3fb84b..a3ece28dc05a 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -300,4 +300,6 @@ #endif #endif
+#define CONFIG_BOARD_EARLY_INIT_F + #endif /* __XILINX_ZYNQMP_H */
Michal Simek
