[U-Boot] [PATCH v3 00/11] UniPhier updates for v2015.07-rc2
Masahiro Yamada (11): ARM: UniPhier: replace <asm/io.h> with <linux/io.h> ARM: UniPhier: update the vendor name of UniPhier in Kconfig ARM: UniPhier: use 32 bit register access for debug UART setting ARM: UniPhier: remove unnecessary cache coherency code ARM: UniPhier: remove meaningless CONFIG_SPL_BUILD ifdefs ARM: UniPhier: move CONFIG_SYS_TEXT_BASE to Kconfig ARM: UniPhier: set MACH_PH1_PRO4 as default SoC ARM: UniPhier: enable CONFIG_NET_RANDOM_ETHADDR ARM: UniPhier: update DDR PHY register map for PH1-Pro5 ARM: UniPhier: fix pin mux setting for USB port 2 of PH1-sLD8 ARM: UniPhier: add pin mux setting for NAND CS1 of PH1-Pro4
Kconfig | 2 +- arch/arm/Kconfig | 5 ++++- arch/arm/mach-uniphier/Kconfig | 7 +++---- arch/arm/mach-uniphier/board_late_init.c | 5 ++--- arch/arm/mach-uniphier/cache_uniphier.c | 6 ++---- arch/arm/mach-uniphier/cmd_ddrphy.c | 5 ++--- arch/arm/mach-uniphier/cpu_info.c | 5 ++--- arch/arm/mach-uniphier/ddrphy_training.c | 9 ++------ arch/arm/mach-uniphier/include/mach/ddrphy-regs.h | 11 ++++++---- arch/arm/mach-uniphier/include/mach/debug-uart.S | 7 +++---- arch/arm/mach-uniphier/include/mach/led.h | 5 ++--- arch/arm/mach-uniphier/include/mach/sbc-regs.h | 4 ++-- arch/arm/mach-uniphier/include/mach/sg-regs.h | 4 ++-- arch/arm/mach-uniphier/lowlevel_init.S | 24 +--------------------- arch/arm/mach-uniphier/memconf.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/bcu_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/boot-mode.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c | 4 ++-- .../arm/mach-uniphier/ph1-pro4/early_clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 7 ++++--- arch/arm/mach-uniphier/ph1-pro4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 9 ++++---- arch/arm/mach-uniphier/ph1-sld8/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-sld8/umc_init.c | 4 ++-- arch/arm/mach-uniphier/reset.c | 5 ++--- arch/arm/mach-uniphier/support_card.c | 6 ++---- arch/arm/mach-uniphier/timer.c | 5 ++--- configs/ph1_ld4_defconfig | 3 +++ configs/ph1_pro4_defconfig | 4 +++- configs/ph1_sld8_defconfig | 3 +++ drivers/i2c/Kconfig | 6 +++--- drivers/i2c/i2c-uniphier-f.c | 6 ++---- drivers/i2c/i2c-uniphier.c | 6 ++---- drivers/serial/Kconfig | 5 +++-- drivers/serial/serial_uniphier.c | 6 ++---- drivers/usb/host/Kconfig | 10 ++++----- drivers/usb/host/ehci-uniphier.c | 6 ++---- drivers/usb/host/xhci-uniphier.c | 5 ++--- include/configs/uniphier.h | 8 +++----- 56 files changed, 131 insertions(+), 183 deletions(-)
In the Linux coding style, it is recommended to include <linux/io.h> rather than <asm/io.h>. Follow this trend.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v3: - Newly added
Changes in v2: None
arch/arm/mach-uniphier/board_late_init.c | 5 ++--- arch/arm/mach-uniphier/cache_uniphier.c | 6 ++---- arch/arm/mach-uniphier/cmd_ddrphy.c | 5 ++--- arch/arm/mach-uniphier/cpu_info.c | 5 ++--- arch/arm/mach-uniphier/ddrphy_training.c | 5 ++--- arch/arm/mach-uniphier/include/mach/led.h | 5 ++--- arch/arm/mach-uniphier/include/mach/sbc-regs.h | 4 ++-- arch/arm/mach-uniphier/include/mach/sg-regs.h | 4 ++-- arch/arm/mach-uniphier/memconf.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/bcu_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-ld4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/boot-mode.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 5 ++--- arch/arm/mach-uniphier/ph1-pro4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 5 ++--- arch/arm/mach-uniphier/ph1-sld8/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c | 5 ++--- arch/arm/mach-uniphier/ph1-sld8/umc_init.c | 4 ++-- arch/arm/mach-uniphier/reset.c | 5 ++--- arch/arm/mach-uniphier/support_card.c | 6 ++---- arch/arm/mach-uniphier/timer.c | 5 ++--- drivers/i2c/i2c-uniphier-f.c | 6 ++---- drivers/i2c/i2c-uniphier.c | 6 ++---- drivers/serial/serial_uniphier.c | 6 ++---- drivers/usb/host/ehci-uniphier.c | 6 ++---- drivers/usb/host/xhci-uniphier.c | 5 ++--- 43 files changed, 86 insertions(+), 123 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 0622a1e..a7530eb 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -1,6 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -8,7 +7,7 @@ #include <common.h> #include <spl.h> #include <nand.h> -#include <asm/io.h> +#include <linux/io.h> #include <../drivers/mtd/nand/denali.h>
static void nand_denali_wp_disable(void) diff --git a/arch/arm/mach-uniphier/cache_uniphier.c b/arch/arm/mach-uniphier/cache_uniphier.c index d8b8228..bf85ad6 100644 --- a/arch/arm/mach-uniphier/cache_uniphier.c +++ b/arch/arm/mach-uniphier/cache_uniphier.c @@ -1,13 +1,11 @@ /* - * Copyright (C) 2012-2014 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <asm/armv7.h> #include <mach/ssc-regs.h>
diff --git a/arch/arm/mach-uniphier/cmd_ddrphy.c b/arch/arm/mach-uniphier/cmd_ddrphy.c index 5f44927..dbbefd4 100644 --- a/arch/arm/mach-uniphier/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/cmd_ddrphy.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/ddrphy-regs.h>
/* Select either decimal or hexadecimal */ diff --git a/arch/arm/mach-uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c index 13a0b1e..c4ba6d2 100644 --- a/arch/arm/mach-uniphier/cpu_info.c +++ b/arch/arm/mach-uniphier/cpu_info.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2013-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2013-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/sg-regs.h>
int print_cpuinfo(void) diff --git a/arch/arm/mach-uniphier/ddrphy_training.c b/arch/arm/mach-uniphier/ddrphy_training.c index b1d46cf..e99c5e6 100644 --- a/arch/arm/mach-uniphier/ddrphy_training.c +++ b/arch/arm/mach-uniphier/ddrphy_training.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void ddrphy_prepare_training(struct ddrphy __iomem *phy, int rank) diff --git a/arch/arm/mach-uniphier/include/mach/led.h b/arch/arm/mach-uniphier/include/mach/led.h index 21277da..f7749b4 100644 --- a/arch/arm/mach-uniphier/include/mach/led.h +++ b/arch/arm/mach-uniphier/include/mach/led.h @@ -1,6 +1,5 @@ /* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -77,7 +76,7 @@
#else /* __ASSEMBLY__ */
#define led_write(C0, C1, C2, C3) \ do { \ diff --git a/arch/arm/mach-uniphier/include/mach/sbc-regs.h b/arch/arm/mach-uniphier/include/mach/sbc-regs.h index efb68e8..493363b 100644 --- a/arch/arm/mach-uniphier/include/mach/sbc-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sbc-regs.h @@ -1,7 +1,7 @@ /* * UniPhier SBC (System Bus Controller) registers * - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -99,7 +99,7 @@ #define ROM_BOOT_ROMRSV2 0x59801208
#ifndef __ASSEMBLY__ -#include <asm/io.h> +#include <linux/io.h> static inline int boot_is_swapped(void) { return !(readl(SBBASE0) & SBBASE_BANK_ENABLE); diff --git a/arch/arm/mach-uniphier/include/mach/sg-regs.h b/arch/arm/mach-uniphier/include/mach/sg-regs.h index 63408d5..a65f058 100644 --- a/arch/arm/mach-uniphier/include/mach/sg-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sg-regs.h @@ -1,7 +1,7 @@ /* * UniPhier SG (SoC Glue) block registers * - * Copyright (C) 2011-2015 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -108,7 +108,7 @@ #else
#include <linux/types.h> -#include <asm/io.h> +#include <linux/io.h>
static inline void sg_set_pinsel(int n, int value) { diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c index bf3c177..59ed0b5 100644 --- a/arch/arm/mach-uniphier/memconf.c +++ b/arch/arm/mach-uniphier/memconf.c @@ -1,13 +1,12 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <linux/sizes.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/sg-regs.h>
static inline u32 sg_memconf_val_ch0(unsigned long size, int num) diff --git a/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c b/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c index 837e0d1..a7bc15e 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/bcu-regs.h>
#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x)) diff --git a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c index 4ac5411..2de81f0 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
-#include <asm/io.h> +#include <linux/io.h> #include <mach/sc-regs.h>
void clkrst_init(void) diff --git a/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c index a47e87a..2add8fa 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <linux/types.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/ddrphy-regs.h>
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) diff --git a/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c b/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c index 3074d0a..20cc7b3 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void pin_init(void) diff --git a/arch/arm/mach-uniphier/ph1-ld4/pll_init.c b/arch/arm/mach-uniphier/ph1-ld4/pll_init.c index 985e14f..f8ec2b6 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/pll_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/sc-regs.h> #include <mach/sg-regs.h>
diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c index 00f8461..8e25792 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/sbc-regs.h> #include <mach/sg-regs.h>
diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c index 374a8c0..5b5958b 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c index 93e44af..dab56e9 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void sg_init(void) diff --git a/arch/arm/mach-uniphier/ph1-ld4/umc_init.c b/arch/arm/mach-uniphier/ph1-ld4/umc_init.c index 081b028..a7a4157 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/umc_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/umc-regs.h> #include <mach/ddrphy-regs.h>
diff --git a/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c b/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c index 9894c1a..54a2510 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c +++ b/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c @@ -1,13 +1,12 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <spl.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/boot-device.h> #include <mach/sg-regs.h> #include <mach/sbc-regs.h> diff --git a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c index 054efa6..46cace7 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void clkrst_init(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c index 7df5aea..61ddcf4 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) diff --git a/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c index 37bb79e..60204b5 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c @@ -1,13 +1,12 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <spl.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/sc-regs.h>
void early_clkrst_init(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c index 85bb6a0..e78d6ab 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void early_pin_init(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c index 4df9098..72cd346 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void pin_init(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c index 2a965a5..d693368 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c index ff9c73f..fcf2ad2 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void enable_dpll_ssc(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c index 5e75454..533739c 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c index 67e6d82..877ba79 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c index 8677666..d6ccffb 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void sg_init(void) diff --git a/arch/arm/mach-uniphier/ph1-pro4/umc_init.c b/arch/arm/mach-uniphier/ph1-pro4/umc_init.c index 6cbb6b2..bd8b9d8 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/umc_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c index 304edfb..21efe62 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c @@ -1,12 +1,12 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <config.h> #include <linux/types.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/ddrphy-regs.h>
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) diff --git a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c index 57a8093..2b1dd1e 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void pin_init(void) diff --git a/arch/arm/mach-uniphier/ph1-sld8/pll_init.c b/arch/arm/mach-uniphier/ph1-sld8/pll_init.c index 8851007..109cb5f 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/pll_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c index fdef88e..c2267c7 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c +++ b/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/ph1-sld8/umc_init.c b/arch/arm/mach-uniphier/ph1-sld8/umc_init.c index 302611e..7baea7e 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/umc_init.c @@ -1,11 +1,11 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
diff --git a/arch/arm/mach-uniphier/reset.c b/arch/arm/mach-uniphier/reset.c index 005fbcf..4c82511 100644 --- a/arch/arm/mach-uniphier/reset.c +++ b/arch/arm/mach-uniphier/reset.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
void reset_cpu(unsigned long ignored) diff --git a/arch/arm/mach-uniphier/support_card.c b/arch/arm/mach-uniphier/support_card.c index 77cc794..ea85b20 100644 --- a/arch/arm/mach-uniphier/support_card.c +++ b/arch/arm/mach-uniphier/support_card.c @@ -1,13 +1,11 @@ /* - * Copyright (C) 2012-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/board.h>
#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) diff --git a/arch/arm/mach-uniphier/timer.c b/arch/arm/mach-uniphier/timer.c index adef08d..27ada29 100644 --- a/arch/arm/mach-uniphier/timer.c +++ b/arch/arm/mach-uniphier/timer.c @@ -1,12 +1,11 @@ /* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/io.h> +#include <linux/io.h> #include <mach/arm-mpcore.h>
#define PERIPHCLK (50 * 1000 * 1000) /* 50 MHz */ diff --git a/drivers/i2c/i2c-uniphier-f.c b/drivers/i2c/i2c-uniphier-f.c index d29dd45..b3349af 100644 --- a/drivers/i2c/i2c-uniphier-f.c +++ b/drivers/i2c/i2c-uniphier-f.c @@ -1,14 +1,12 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <linux/types.h> -#include <asm/io.h> +#include <linux/io.h> #include <asm/errno.h> #include <dm/device.h> #include <dm/root.h> diff --git a/drivers/i2c/i2c-uniphier.c b/drivers/i2c/i2c-uniphier.c index c4972ff..85b9eff 100644 --- a/drivers/i2c/i2c-uniphier.c +++ b/drivers/i2c/i2c-uniphier.c @@ -1,14 +1,12 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <linux/types.h> -#include <asm/io.h> +#include <linux/io.h> #include <asm/errno.h> #include <dm/device.h> #include <dm/root.h> diff --git a/drivers/serial/serial_uniphier.c b/drivers/serial/serial_uniphier.c index 74547eb..f210986 100644 --- a/drivers/serial/serial_uniphier.c +++ b/drivers/serial/serial_uniphier.c @@ -1,13 +1,11 @@ /* - * Copyright (C) 2012-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
+#include <linux/io.h> #include <linux/serial_reg.h> -#include <asm/io.h> #include <asm/errno.h> #include <dm/device.h> #include <dm/platform_data/serial-uniphier.h> diff --git a/drivers/usb/host/ehci-uniphier.c b/drivers/usb/host/ehci-uniphier.c index 846bf50..c3f827c 100644 --- a/drivers/usb/host/ehci-uniphier.c +++ b/drivers/usb/host/ehci-uniphier.c @@ -1,14 +1,12 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <linux/err.h> -#include <asm/io.h> +#include <linux/io.h> #include <usb.h> #include <mach/mio-regs.h> #include <fdtdec.h> diff --git a/drivers/usb/host/xhci-uniphier.c b/drivers/usb/host/xhci-uniphier.c index e0ef322..1b3f3d2 100644 --- a/drivers/usb/host/xhci-uniphier.c +++ b/drivers/usb/host/xhci-uniphier.c @@ -1,13 +1,12 @@ /* - * Copyright (C) 2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <linux/err.h> +#include <linux/io.h> #include <usb.h> #include <fdtdec.h> #include "xhci.h"
The business for UniPhier Soc family has been transferred from Panasonic Corporation to Socionext Inc.
Update the SoC select menu in Kconfig.
Changes in v2: None
arch/arm/Kconfig | 5 ++++- arch/arm/mach-uniphier/Kconfig | 5 ++--- drivers/i2c/Kconfig | 6 +++--- drivers/serial/Kconfig | 5 +++-- drivers/usb/host/Kconfig | 10 ++++------ 5 files changed, 16 insertions(+), 15 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b62842f..2985e6e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -786,7 +786,7 @@ config TARGET_JORNADA select CPU_SA1100
config ARCH_UNIPHIER - bool "Panasonic UniPhier platform" + bool "Socionext UniPhier SoCs" select CPU_V7 select SUPPORT_SPL select SPL @@ -794,6 +794,9 @@ config ARCH_UNIPHIER select DM select DM_SERIAL select DM_I2C + help + Support for UniPhier SoC family developed by Socionext Inc. + (formerly, System LSI Business Division of Panasonic Corporation)
config TARGET_STM32F429_DISCOVERY bool "Support STM32F429 Discovery" diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 2d27c49..73b8676 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -1,5 +1,4 @@ -menu "Panasonic UniPhier platform" - depends on ARCH_UNIPHIER +if ARCH_UNIPHIER
config SYS_CONFIG_NAME default "uniphier" @@ -78,4 +77,4 @@ config DDR_FREQ default 1333 if DDR_FREQ_1333 default 1600 if DDR_FREQ_1600
-endmenu +endif diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index ba43019..86fb36b 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -63,13 +63,13 @@ config SYS_I2C_UNIPHIER depends on ARCH_UNIPHIER && DM_I2C default y help - Support for Panasonic UniPhier I2C controller driver. This I2C - controller is used on PH1-LD4, PH1-sLD8 or older UniPhier SoCs. + Support for UniPhier I2C controller driver. This I2C controller + is used on PH1-LD4, PH1-sLD8 or older UniPhier SoCs.
config SYS_I2C_UNIPHIER_F bool "UniPhier FIFO-builtin I2C driver" depends on ARCH_UNIPHIER && DM_I2C default y help - Support for Panasonic UniPhier FIFO-builtin I2C controller driver. + Support for UniPhier FIFO-builtin I2C controller driver. This I2C controller is used on PH1-Pro4 or newer UniPhier SoCs. diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 54e6f26..5611fac 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -77,7 +77,8 @@ config DEBUG_UART_SHIFT registers, 2=32-bit word registers, etc.
config UNIPHIER_SERIAL - bool "UniPhier on-chip UART support" + bool "Support for UniPhier on-chip UART" depends on ARCH_UNIPHIER && DM_SERIAL help - Support for the on-chip UARTs on the Panasonic UniPhier platform. + If you have a UniPhier based board and want to use the on-chip + serial ports, say Y to this option. If unsure, say N. diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 24a595f..8705c7c 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -18,12 +18,11 @@ config USB_XHCI if USB_XHCI_HCD
config USB_XHCI_UNIPHIER - bool "Support for Panasonic UniPhier on-chip xHCI USB controller" + bool "Support for UniPhier on-chip xHCI USB controller" depends on ARCH_UNIPHIER default y ---help--- - Enables support for the on-chip xHCI controller on Panasonic - UniPhier SoCs. + Enables support for the on-chip xHCI controller on UniPhier SoCs.
endif
@@ -54,11 +53,10 @@ config USB_EHCI if USB_EHCI_HCD
config USB_EHCI_UNIPHIER - bool "Support for Panasonic UniPhier on-chip EHCI USB controller" + bool "Support for UniPhier on-chip EHCI USB controller" depends on ARCH_UNIPHIER && OF_CONTROL default y ---help--- - Enables support for the on-chip EHCI controller on Panasonic - UniPhier SoCs. + Enables support for the on-chip EHCI controller on UniPhier SoCs.
endif
For the same reason as commit d0c47b3ef7c5 (serial: UniPhier: use 32 bit register access), use "str" instead of "strb" for the LCR register setting.
arch/arm/mach-uniphier/include/mach/debug-uart.S | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/debug-uart.S b/arch/arm/mach-uniphier/include/mach/debug-uart.S index af55fee..d2b431f 100644 --- a/arch/arm/mach-uniphier/include/mach/debug-uart.S +++ b/arch/arm/mach-uniphier/include/mach/debug-uart.S @@ -1,6 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -17,8 +16,8 @@
.macro init_debug_uart, ra, rb, rc addruart \ra, \rb, \rc - mov \rb, #UART_LCR_WLEN8 - strb \rb, [\ra, #0x11] + mov \rb, #UART_LCR_WLEN8 << 8 + str \rb, [\ra, #0x10] ldr \rb, =DIVISOR str \rb, [\ra, #0x24] .endm
Cache coherency for SMP is cared by Linux. In U-Boot, the secondary CPU(s) are just sleeping. Nothing in memory is shared with the primary CPU.
arch/arm/mach-uniphier/lowlevel_init.S | 24 +----------------------- 1 file changed, 1 insertion(+), 23 deletions(-)
diff --git a/arch/arm/mach-uniphier/lowlevel_init.S b/arch/arm/mach-uniphier/lowlevel_init.S index 825b160..fd34a4a 100644 --- a/arch/arm/mach-uniphier/lowlevel_init.S +++ b/arch/arm/mach-uniphier/lowlevel_init.S @@ -1,7 +1,5 @@ /* - * Copyright (C) 2012-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -67,20 +65,6 @@ secondary_startup: * jump to Linux * kick secondaries ---(sev)---> jump to Linux */ - /* - * ACTLR (Auxiliary Control Register) for Cortex-A9 - * bit[9] Parity on - * bit[8] Alloc in one way - * bit[7] EXCL (Exclusive cache bit) - * bit[6] SMP - * bit[3] Write full line of zeros mode - * bit[2] L1 prefetch enable - * bit[1] L2 prefetch enable - * bit[0] FW (Cache and TLB maintenance broadcast) - */ - mrc p15, 0, r0, c1, c0, 1 @ ACTLR (Auxiliary Control Register) - orr r0, r0, #0x41 @ enable SMP, FW bit - mcr p15, 0, r0, c1, c0, 1
/* branch by CPU ID */ mrc p15, 0, r0, c0, c0, 5 @ MPIDR (Multiprocessor Affinity Register) @@ -112,12 +96,6 @@ primary_cpu: str r0, [r1] ldr r0, [r1] @ make sure str is complete before sev sev @ kick the secondary CPU - mrc p15, 4, r1, c15, c0, 0 @ Configuration Base Address Register - bfc r1, #0, #13 @ clear bit 12-0 - mov r0, #-1 - str r0, [r1, #SCU_INV_ALL] @ SCU Invalidate All Register - mov r0, #1 @ SCU enable - str r0, [r1, #SCU_CTRL] @ SCU Control Register #endif
bl setup_init_ram @ RAM area for temporary stack pointer
This file is only built for SPL. These ifdef conditionals are unnecessary because UniPhier platform now supports UART on SPL. Show appropriate messages on error.
arch/arm/mach-uniphier/ddrphy_training.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/ddrphy_training.c b/arch/arm/mach-uniphier/ddrphy_training.c index e99c5e6..a98b814 100644 --- a/arch/arm/mach-uniphier/ddrphy_training.c +++ b/arch/arm/mach-uniphier/ddrphy_training.c @@ -115,10 +115,8 @@ int ddrphy_training(struct ddrphy __iomem *phy)
do { if (--timeout < 0) { -#ifndef CONFIG_SPL_BUILD printf("%s: error: timeout during DDR training\n", __func__); -#endif return -1; } udelay(1); @@ -127,10 +125,8 @@ int ddrphy_training(struct ddrphy __iomem *phy)
for (i = 0; i < ARRAY_SIZE(init_sequence); i++) { if (pgsr0 & init_sequence[i].err_flag) { -#ifndef CONFIG_SPL_BUILD printf("%s: error: %s failed\n", __func__, init_sequence[i].description); -#endif return -1; } }
Changes in v3: None Changes in v2: - Sort by savedefconfig
Kconfig | 2 +- configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + include/configs/uniphier.h | 6 +----- 5 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/Kconfig b/Kconfig index 85faff7..15e15af 100644 --- a/Kconfig +++ b/Kconfig @@ -178,7 +178,7 @@ config SYS_EXTRA_OPTIONS new boards should not use this option.
config SYS_TEXT_BASE - depends on SPARC || ARC || X86 + depends on SPARC || ARC || X86 || ARCH_UNIPHIER hex "Text Base" help TODO: Move CONFIG_SYS_TEXT_BASE for all the architecture diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 036e2d1..45d484e 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_MACH_PH1_LD4=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 9a010ee..cc3a9a4 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_MACH_PH1_PRO4=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 29fe0e8..fc79866 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_MACH_PH1_SLD8=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-sld8-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 331df62..8510472 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -1,7 +1,5 @@ /* - * Copyright (C) 2012-2015 Panasonic Corporation - * Copyright (C) 2015 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2012-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -266,8 +264,6 @@ #define CONFIG_SYS_SDRAM_SIZE (CONFIG_SDRAM0_SIZE) #endif
-#define CONFIG_SYS_TEXT_BASE 0x84000000 - #if defined(CONFIG_MACH_PH1_LD4) || defined(CONFIG_MACH_PH1_SLD8) #define CONFIG_SPL_TEXT_BASE 0x00040000 #endif
One disadvantage of commit a26cd04920dc (arch: Make board selection choices optional) is that Kconfig could create such an insane .config file that no board is selected.
As PH1-Pro4 is the main stream of UniPhier SoC family, rip off the "optional" again in favor of PH1-Pro4 as the default SoC.
Changes in v3: None Changes in v2: - Newly added
arch/arm/mach-uniphier/Kconfig | 2 +- configs/ph1_pro4_defconfig | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 73b8676..feda49e 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -8,7 +8,7 @@ config UNIPHIER_SMP
choice prompt "UniPhier SoC select" - optional + default MACH_PH1_PRO4
config MACH_PH1_PRO4 bool "PH1-Pro4" diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index cc3a9a4..65ff3e0 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y -CONFIG_MACH_PH1_PRO4=y CONFIG_PFC_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref"
Since commit 92ac52082140 (net: Remove all references to CONFIG_ETHADDR and friends), the ethernet device on UniPhier boards is not working because of the incorrect (all-zero) MAC address.
Enable CONFIG_NET_RANDOM_ETHADDR to generate the random one.
Changes in v3: - Add CONFIG_LIB_RAND to the header in order not to depend Michal's patch
configs/ph1_ld4_defconfig | 2 ++ configs/ph1_pro4_defconfig | 2 ++ configs/ph1_sld8_defconfig | 2 ++ include/configs/uniphier.h | 2 ++ 4 files changed, 8 insertions(+)
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 45d484e..82ce8c7 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_MACH_PH1_LD4=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_NET=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" CONFIG_FIT=y @@ -31,6 +32,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_NFS=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 65ff3e0..671d9cc 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_NET=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref" CONFIG_FIT=y @@ -30,6 +31,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_NFS=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index fc79866..3e763dc 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_UNIPHIER=y CONFIG_SPL_DM=y CONFIG_MACH_PH1_SLD8=y CONFIG_PFC_MICRO_SUPPORT_CARD=y +CONFIG_NET=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-sld8-ref" CONFIG_FIT=y @@ -31,6 +32,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_NFS=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 8510472..850083c 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -250,6 +250,8 @@ /* Open Firmware flat tree */ #define CONFIG_OF_LIBFDT
+#define CONFIG_LIB_RAND + #define CONFIG_HAVE_ARM_SECURE
/* Memory Size & Mapping */
Hi Masahiro / Tom,
On Fri, May 29, 2015 at 3:30 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v3:
Changes in v2:
- Newly added
8<-snip->8
Michal's patch will make this error... https://patchwork.ozlabs.org/patch/476114/
Please be aware depending on which PR goes in first. I have his patch reworked here: http://git.denx.de/?p=u-boot/u-boot-net.git;a=shortlog;h=refs/heads/master
Cheers, -Joe
PH1-Pro5 includes a newer version of DDR PHY IP. Some registers have been added to the reserved areas.
arch/arm/mach-uniphier/include/mach/ddrphy-regs.h | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h b/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h index 6b7d600..fce0c01 100644 --- a/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h +++ b/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h @@ -1,8 +1,7 @@ /* * UniPhier DDR PHY registers * - * Copyright (C) 2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * Copyright (C) 2014-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -37,7 +36,10 @@ struct ddrphy { u32 dtar[4]; /* Data Training Address Register */ u32 dtdr[2]; /* Data Training Data Register */ u32 dtedr[2]; /* Data Training Eye Data Register */ - u32 rsv0[13]; /* Reserved */ + u32 pgcr2; /* PHY General Configuration Register 2 */ + u32 rsv0[8]; /* Reserved */ + u32 rdimmgcr[2]; /* RDIMM General Configuration Register */ + u32 rdimmcr0[2]; /* RDIMM Control Register */ u32 dcuar; /* DCU Address Register */ u32 dcudr; /* DCU Data Register */ u32 dcurr; /* DCU Run Register */ @@ -70,7 +72,8 @@ struct ddrphy { u32 lcdlr[3]; /* Local Calibrated Delay Line Register */ u32 mdlr; /* Master Delay Line Register */ u32 gtr; /* General Timing Register */ - u32 rsv[3]; /* Reserved */ + u32 gsr2; /* General Status Register 2 */ + u32 rsv[2]; /* Reserved */ } dx[9]; };
The register value should be 1, not 4.
Changes in v2: None
arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c index 2b1dd1e..130c831 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c @@ -45,7 +45,7 @@ void pin_init(void) sg_set_pinsel(42, 0); /* USB0OD -> USB0OD */ sg_set_pinsel(43, 0); /* USB1VBUS -> USB1VBUS */ sg_set_pinsel(44, 0); /* USB1OD -> USB1OD */ - /* sg_set_pinsel(114, 4); */ /* TXD1 -> USB2VBUS (shared with UART) */ - /* sg_set_pinsel(115, 4); */ /* RXD1 -> USB2OD */ + /* sg_set_pinsel(114, 1); */ /* TXD1 -> USB2VBUS (shared with UART) */ + /* sg_set_pinsel(115, 1); */ /* RXD1 -> USB2OD */ #endif }
The chip select 1 of the NAND controller is available if you want to use, although the pins are shared with UART port 2.
Changes in v2: None
arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c index 72cd346..2a5a296 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c @@ -27,6 +27,8 @@ void pin_init(void) sg_set_pinsel(52, 0); /* XNFWP -> XNFWP */ sg_set_pinsel(53, 0); /* XNFCE0 -> XNFCE0 */ sg_set_pinsel(54, 0); /* NRYBY0 -> NRYBY0 */ + /* sg_set_pinsel(131, 1); */ /* RXD2 -> NRYBY1 */ + /* sg_set_pinsel(132, 1); */ /* TXD2 -> XNFCE1 */ #endif
#ifdef CONFIG_USB_XHCI_UNIPHIER
2015-05-29 17:29 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series, applied to u-boot-uniphier/master.
Joe Hershberger
Masahiro Yamada
