[U-Boot] [PATCH] fs: btrfs: fix btrfs methods return values on failure
The btrfs implementation methods .ls(), .size() and .read() returns 1 on failure, but the command handlers expect values <0 on failure.
For example if given a nonexistent path, the load command currently returns success, and hush scripting does not work.
Fix this by setting return values of these methods to -1 instead of 1 on failure.
Signed-off-by: Marek Behún marek.behun@nic.cz --- fs/btrfs/btrfs.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/fs/btrfs/btrfs.c b/fs/btrfs/btrfs.c index 6f35854823..cb7e182742 100644 --- a/fs/btrfs/btrfs.c +++ b/fs/btrfs/btrfs.c @@ -119,17 +119,17 @@ int btrfs_ls(const char *path)
if (inr == -1ULL) { printf("Cannot lookup path %s\n", path); - return 1; + return -1; }
if (type != BTRFS_FT_DIR) { printf("Not a directory: %s\n", path); - return 1; + return -1; }
if (btrfs_readdir(&root, inr, readdir_callback)) { printf("An error occured while listing directory %s\n", path); - return 1; + return -1; }
return 0; @@ -158,12 +158,12 @@ int btrfs_size(const char *file, loff_t *size)
if (inr == -1ULL) { printf("Cannot lookup file %s\n", file); - return 1; + return -1; }
if (type != BTRFS_FT_REG_FILE) { printf("Not a regular file: %s\n", file); - return 1; + return -1; }
*size = inode.size; @@ -183,12 +183,12 @@ int btrfs_read(const char *file, void *buf, loff_t offset, loff_t len,
if (!len) @@ -200,7 +200,7 @@ int btrfs_read(const char *file, void *buf, loff_t offset, loff_t len, rd = btrfs_file_read(&root, inr, offset, len, buf); if (rd == -1ULL) { printf("An error occured while reading file %s\n", file); - return 1; + return -1; }
*actread = rd;
Marek Behún
