[U-Boot] [PATCH 01/15][v3] power: pmic: add pfuze3000 support
* Add pmic pfuze3000 support, implement power_pfuze3000_init to be used in power_init_board callback function.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- Changes for V2: - Correct pfuze device name to pfuze3000; Freescale documentation uses Pfuze 3000 as product name for the pmic, align driver name with the actual product name. Changes for V3: Resend
drivers/power/pmic/Makefile | 1 + drivers/power/pmic/pmic_pfuze3000.c | 32 +++++++++++++++ include/power/pfuze3000_pmic.h | 78 +++++++++++++++++++++++++++++++++++++ 3 files changed, 111 insertions(+) create mode 100644 drivers/power/pmic/pmic_pfuze3000.c create mode 100644 include/power/pfuze3000_pmic.h
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index ae86f04..b271acb 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o +obj-$(CONFIG_POWER_PFUZE3000) += pmic_pfuze3000.o obj-$(CONFIG_POWER_TPS65090_I2C) += pmic_tps65090.o obj-$(CONFIG_POWER_TPS65090_EC) += pmic_tps65090_ec.o obj-$(CONFIG_POWER_TPS65217) += pmic_tps65217.o diff --git a/drivers/power/pmic/pmic_pfuze3000.c b/drivers/power/pmic/pmic_pfuze3000.c new file mode 100644 index 0000000..ac807a8 --- /dev/null +++ b/drivers/power/pmic/pmic_pfuze3000.c @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/pfuze3000_pmic.h> + +int power_pfuze3000_init(unsigned char bus) +{ + static const char name[] = "PFUZE3000"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + p->name = name; + p->interface = PMIC_I2C; + p->number_of_regs = PMIC_NUM_OF_REGS; + p->hw.i2c.addr = CONFIG_POWER_PFUZE3000_I2C_ADDR; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + return 0; +} diff --git a/include/power/pfuze3000_pmic.h b/include/power/pfuze3000_pmic.h new file mode 100644 index 0000000..e8b892b --- /dev/null +++ b/include/power/pfuze3000_pmic.h @@ -0,0 +1,78 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __PFUZE3000_PMIC_H_ +#define __PFUZE3000_PMIC_H_ + +/* PFUZE3000 registers */ +enum { + PFUZE3000_DEVICEID = 0x00, + + PFUZE3000_REVID = 0x03, + PFUZE3000_FABID = 0x04, + PFUZE3000_INTSTAT0 = 0x05, + PFUZE3000_INTMASK0 = 0x06, + PFUZE3000_INTSENSE0 = 0x07, + PFUZE3000_INTSTAT1 = 0x08, + PFUZE3000_INTMASK1 = 0x09, + PFUZE3000_INTSENSE1 = 0x0A, + + PFUZE3000_INTSTAT3 = 0x0E, + PFUZE3000_INTMASK3 = 0x0F, + PFUZE3000_INTSENSE3 = 0x10, + PFUZE3000_INTSTAT4 = 0x11, + PFUZE3000_INTMASK4 = 0x12, + PFUZE3000_INTSENSE4 = 0x13, + + PFUZE3000_COINCTL = 0x1A, + PFUZE3000_PWRCTL = 0x1B, + PFUZE3000_MEMA = 0x1C, + PFUZE3000_MEMB = 0x1D, + PFUZE3000_MEMC = 0x1E, + PFUZE3000_MEMD = 0x1F, + + PFUZE3000_SW1AVOLT = 0x20, + PFUZE3000_SW1ASTBY = 0x21, + PFUZE3000_SW1AOFF = 0x22, + PFUZE3000_SW1AMODE = 0x23, + PFUZE3000_SW1ACONF = 0x24, + + PFUZE3000_SW1BVOLT = 0x2E, + PFUZE3000_SW1BSTBY = 0x2F, + PFUZE3000_SW1BOFF = 0x30, + PFUZE3000_SW1BMODE = 0x31, + PFUZE3000_SW1BCONF = 0x32, + + PFUZE3000_SW2VOLT = 0x35, + PFUZE3000_SW2STBY = 0x36, + PFUZE3000_SW2OFF = 0x37, + PFUZE3000_SW2MODE = 0x38, + PFUZE3000_SW2CONF = 0x39, + + PFUZE3000_SW3VOLT = 0x3C, + PFUZE3000_SW3STBY = 0x3D, + PFUZE3000_SW3OFF = 0x3E, + PFUZE3000_SW3MODE = 0x3F, + PFUZE3000_SW3CONF = 0x40, + + PFUZE3000_SWBSTCTL = 0x66, + + PFUZE3000_LDOGCTL = 0x69, + PFUZE3000_VREFDDRCTL = 0x6A, + PFUZE3000_VSNVSCTL = 0x6B, + PFUZE3000_VLDO1CTL = 0x6C, + PFUZE3000_VLDO2CTL = 0x6D, + PFUZE3000_VCC_SDCTL = 0x6E, + PFUZE3000_V33CTL = 0x6F, + PFUZE3000_VLDO3CTL = 0x70, + PFUZE3000_VLD4CTL = 0x71, + + PMIC_NUM_OF_REGS = 0x7F, +}; + +int power_pfuze3000_init(unsigned char bus); + +#endif
DCIMVAC is upgraded to DCCIMVAC for the individual processor (Cortex-A7) that the DCIMVAC is executed on.
We should follow the linux dma follow. Before DMA read, first invalidate dcache then after DMA read, invalidate dcache again.
With the DMA direction DMA_FROM_DEVICE, the dcache need be invalidated again after the DMA completion. The reason is that we need explicity make sure the dcache been invalidated thus to get the DMA'ed memory correctly from the physical memory. Any cache-line fill during the DMA operations such as the pre-fetching can cause the DMA coherency issue, thus CPU get the stale data.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Nitin Garg nitin.garg@freescale.com Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Resend Changes for V3: Resend
drivers/mmc/fsl_esdhc.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index c4719e6..0510bf0 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -341,6 +341,9 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) err = esdhc_setup_data(mmc, data); if(err) return err; + + if (data->flags & MMC_DATA_READ) + check_and_invalidate_dcache_range(cmd, data); }
/* Figure out the transfer arguments */ @@ -437,6 +440,11 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) } } while ((irqstat & DATA_COMPLETE) != DATA_COMPLETE);
+ /* + * Need invalidate the dcache here again to avoid any + * cache-fill during the DMA operations such as the + * speculative pre-fetching etc. + */ if (data->flags & MMC_DATA_READ) check_and_invalidate_dcache_range(cmd, data); #endif
Hi Adrian,
Pen has already sent this patch:
https://patchwork.ozlabs.org/patch/488273/
Please do not copy and resend patches that are already enqueded. Instead, advise that your patches depend on some previous ones. Thanks.
Best regards, Stefano Babic
* Add imx7d support for iomux controller * imx7d has two iomux controllers iomuxc (0x3033000) and iomuxc-lpsr (0x302C0000) each conroller provides control and mux mode pad registers but shares iomuxc input select register with iomuxc-lpsr IOMUX_CONFIG_LPSR flag is used to properly set daisy chain settings for iomuxc-lpsr pads. * Since mx7d introduces LPSR IOMUX pins, add new base to IOMUX v3 driver for these LPSR pins.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: - Update commit log information Changes for V3: Resend
arch/arm/imx-common/iomux-v3.c | 20 +- arch/arm/include/asm/arch-mx7/mx7-pins.h | 19 + arch/arm/include/asm/arch-mx7/mx7d_pins.h | 1308 ++++++++++++++++++++++++++++ arch/arm/include/asm/imx-common/iomux-v3.h | 32 + 4 files changed, 1378 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx7/mx7-pins.h create mode 100644 arch/arm/include/asm/arch-mx7/mx7d_pins.h
diff --git a/arch/arm/imx-common/iomux-v3.c b/arch/arm/imx-common/iomux-v3.c index 7fb23dd..07e75a6 100644 --- a/arch/arm/imx-common/iomux-v3.c +++ b/arch/arm/imx-common/iomux-v3.c @@ -4,7 +4,7 @@ * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH, * armlinux@phytec.de * - * Copyright (C) 2004-2011 Freescale Semiconductor, Inc. + * Copyright (C) 2004-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -41,6 +41,18 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) } #endif
+#ifdef CONFIG_IOMUX_LPSR + u32 lpsr = (pad & MUX_MODE_LPSR) >> MUX_MODE_SHIFT; + + if (lpsr == IOMUX_CONFIG_LPSR) { + base = (void *)IOMUXC_LPSR_BASE_ADDR; + mux_mode &= ~IOMUX_CONFIG_LPSR; + /* set daisy chain sel_input */ + if (sel_input_ofs) + sel_input_ofs += IOMUX_LPSR_SEL_INPUT_OFS; + } +#endif + if (mux_ctrl_ofs) __raw_writel(mux_mode, base + mux_ctrl_ofs);
@@ -55,6 +67,12 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) if (!(pad_ctrl & NO_PAD_CTRL) && pad_ctrl_ofs) __raw_writel(pad_ctrl, base + pad_ctrl_ofs); #endif + +#ifdef CONFIG_IOMUX_LPSR + if (lpsr == IOMUX_CONFIG_LPSR) + base = (void *)IOMUXC_BASE_ADDR; +#endif + }
/* configures a list of pads within declared with IOMUX_PADS macro */ diff --git a/arch/arm/include/asm/arch-mx7/mx7-pins.h b/arch/arm/include/asm/arch-mx7/mx7-pins.h new file mode 100644 index 0000000..164c2be --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7-pins.h @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __ASM_ARCH_MX7_PINS_H__ +#define __ASM_ARCH_MX7_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +#if defined(CONFIG_MX7D) +#include "mx7d_pins.h" +#elif defined(CONFIG_MX7S) +#include "mx7s_pins.h" +#else +#error "Please select cpu" +#endif /* CONFIG_MX7D */ + +#endif /*__ASM_ARCH_MX7_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx7/mx7d_pins.h b/arch/arm/include/asm/arch-mx7/mx7d_pins.h new file mode 100644 index 0000000..d8b4097 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7d_pins.h @@ -0,0 +1,1308 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_IMX7D_PINS_H__ +#define __ASM_ARCH_IMX7D_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +enum { + MX7D_PAD_GPIO1_IO00__GPIO1_IO0 = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO00__PWM4_OUT = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO01__GPIO1_IO1 = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO01__PWM1_OUT = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO01__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 2, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO01__SAI1_MCLK = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO02__GPIO1_IO2 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO02__PWM2_OUT = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO02__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 2, 0x0564, 3, 0), + MX7D_PAD_GPIO1_IO02__SAI2_MCLK = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO02__CCM_CLKO1 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO02__USB_OTG1_ID = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 7, 0x0734, 3, 0), + + MX7D_PAD_GPIO1_IO03__GPIO1_IO3 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO03__PWM3_OUT = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO03__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 2, 0x0570, 3, 0), + MX7D_PAD_GPIO1_IO03__SAI3_MCLK = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO03__CCM_CLKO2 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO03__USB_OTG2_ID = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 7, 0x0730, 3, 0), + + MX7D_PAD_GPIO1_IO04__GPIO1_IO4 = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO04__USB_OTG1_OC = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 1, 0x072C, 1, 0), + MX7D_PAD_GPIO1_IO04__FLEXTIMER_CH4 = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 2, 0x0594, 1, 0), + MX7D_PAD_GPIO1_IO04__UART5_CTS_B = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 3, 0x0710, 4, 0), + MX7D_PAD_GPIO1_IO04__I2C1_SCL = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D4, 2, 0), + + MX7D_PAD_GPIO1_IO05__GPIO1_IO5 = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO05__FLEXTIMER1_CH5 = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 2, 0x0598, 1, 0), + MX7D_PAD_GPIO1_IO05__UART5_RTS_B = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 3, 0x0710, 5, 0), + MX7D_PAD_GPIO1_IO05__I2C1_SDA = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D8, 2, 0), + + MX7D_PAD_GPIO1_IO06__GPIO1_IO6 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO06__USB_OTG2_OC = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 1, 0x0728, 1, 0), + MX7D_PAD_GPIO1_IO06__FLEXTIMER1_CH6 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 2, 0x059C, 1, 0), + MX7D_PAD_GPIO1_IO06__UART5_RX_DATA = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 3, 0x0714, 4, 0), + MX7D_PAD_GPIO1_IO06__I2C2_SCL = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05DC, 2, 0), + MX7D_PAD_GPIO1_IO06__CCM_WAIT = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO06__KPP_ROW4 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 6, 0x0624, 1, 0), + + MX7D_PAD_GPIO1_IO07__GPIO1_IO7 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO07__USB_OTG2_PWR = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO07__FLEXTIMER1_CH7 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 2, 0x05A0, 1, 0), + MX7D_PAD_GPIO1_IO07__UART5_TX_DATA = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 3, 0x0714, 5, 0), + MX7D_PAD_GPIO1_IO07__I2C2_SDA = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05E0, 2, 0), + MX7D_PAD_GPIO1_IO07__CCM_STOP = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO07__KPP_COL4 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 6, 0x0604, 1, 0), +}; + +enum { + MX7D_PAD_GPIO1_IO08__GPIO1_IO8 = IOMUX_PAD(0x026C, 0x0014, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO08__SD1_VSELECT = IOMUX_PAD(0x026C, 0x0014, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO08__WDOG1_WDOG_B = IOMUX_PAD(0x026C, 0x0014, 2, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO08__UART3_DCE_RX = IOMUX_PAD(0x026C, 0x0014, 3, 0x0704, 0, 0), + MX7D_PAD_GPIO1_IO08__UART3_DTE_TX = IOMUX_PAD(0x026C, 0x0014, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO08__I2C3_SCL = IOMUX_PAD(0x026C, 0x0014, IOMUX_CONFIG_SION | 4, 0x05E4, 0, 0), + MX7D_PAD_GPIO1_IO08__KPP_COL5 = IOMUX_PAD(0x026C, 0x0014, 6, 0x0608, 0, 0), + MX7D_PAD_GPIO1_IO08__PWM1_OUT = IOMUX_PAD(0x026C, 0x0014, 7, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO09__GPIO1_IO9 = IOMUX_PAD(0x0270, 0x0018, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO09__SD1_LCTL = IOMUX_PAD(0x0270, 0x0018, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO09__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x0270, 0x0018, 2, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO09__UART3_DCE_TX = IOMUX_PAD(0x0270, 0x0018, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO09__UART3_DTE_RX = IOMUX_PAD(0x0270, 0x0018, 3, 0x0704, 1, 0), + MX7D_PAD_GPIO1_IO09__I2C3_SDA = IOMUX_PAD(0x0270, 0x0018, IOMUX_CONFIG_SION | 4, 0x05E8, 0, 0), + MX7D_PAD_GPIO1_IO09__CCM_PMIC_READY = IOMUX_PAD(0x0270, 0x0018, 5, 0x04F4, 0, 0), + MX7D_PAD_GPIO1_IO09__KPP_ROW5 = IOMUX_PAD(0x0270, 0x0018, 6, 0x0628, 0, 0), + MX7D_PAD_GPIO1_IO09__PWM2_OUT = IOMUX_PAD(0x0270, 0x0018, 7, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO10__GPIO1_IO10 = IOMUX_PAD(0x0274, 0x001C, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO10__SD2_LCTL = IOMUX_PAD(0x0274, 0x001C, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO10__ENET1_MDIO = IOMUX_PAD(0x0274, 0x001C, 2, 0x0568, 0, 0), + MX7D_PAD_GPIO1_IO10__UART3_DCE_RTS = IOMUX_PAD(0x0274, 0x001C, 3, 0x0700, 0, 0), + MX7D_PAD_GPIO1_IO10__UART3_DTE_CTS = IOMUX_PAD(0x0274, 0x001C, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO10__I2C4_SCL = IOMUX_PAD(0x0274, 0x001C, IOMUX_CONFIG_SION | 4, 0x05EC, 0, 0), + MX7D_PAD_GPIO1_IO10__FLEXTIMER1_PHA = IOMUX_PAD(0x0274, 0x001C, 5, 0x05A4, 0, 0), + MX7D_PAD_GPIO1_IO10__KPP_COL6 = IOMUX_PAD(0x0274, 0x001C, 6, 0x060C, 0, 0), + MX7D_PAD_GPIO1_IO10__PWM3_OUT = IOMUX_PAD(0x0274, 0x001C, 7, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO11__GPIO1_IO11 = IOMUX_PAD(0x0278, 0x0020, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO11__SD3_LCTL = IOMUX_PAD(0x0278, 0x0020, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO11__ENET1_MDC = IOMUX_PAD(0x0278, 0x0020, 2, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO11__UART3_DCE_CTS = IOMUX_PAD(0x0278, 0x0020, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO11__UART3_DTE_RTS = IOMUX_PAD(0x0278, 0x0020, 3, 0x0700, 1, 0), + MX7D_PAD_GPIO1_IO11__I2C4_SDA = IOMUX_PAD(0x0278, 0x0020, IOMUX_CONFIG_SION | 4, 0x05F0, 0, 0), + MX7D_PAD_GPIO1_IO11__FLEXTIMER1_PHB = IOMUX_PAD(0x0278, 0x0020, 5, 0x05A8, 0, 0), + MX7D_PAD_GPIO1_IO11__KPP_ROW6 = IOMUX_PAD(0x0278, 0x0020, 6, 0x062C, 0, 0), + MX7D_PAD_GPIO1_IO11__PWM4_OUT = IOMUX_PAD(0x0278, 0x0020, 7, 0x0000, 0, 0), + + MX7D_PAD_GPIO1_IO12__GPIO1_IO12 = IOMUX_PAD(0x027C, 0x0024, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO12__SD2_VSELECT = IOMUX_PAD(0x027C, 0x0024, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO12__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x027C, 0x0024, 2, 0x0564, 0, 0), + MX7D_PAD_GPIO1_IO12__FLEXCAN1_RX = IOMUX_PAD(0x027C, 0x0024, 3, 0x04DC, 0, 0), + MX7D_PAD_GPIO1_IO12__CM4_NMI = IOMUX_PAD(0x027C, 0x0024, 4, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO12__CCM_EXT_CLK1 = IOMUX_PAD(0x027C, 0x0024, 5, 0x04E4, 0, 0), + MX7D_PAD_GPIO1_IO12__SNVS_VIO_5 = IOMUX_PAD(0x027C, 0x0024, 6, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO12__USB_OTG1_ID = IOMUX_PAD(0x027C, 0x0024, 7, 0x0734, 0, 0), + + MX7D_PAD_GPIO1_IO13__GPIO1_IO13 = IOMUX_PAD(0x0280, 0x0028, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO13__SD3_VSELECT = IOMUX_PAD(0x0280, 0x0028, 1, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO13__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x0280, 0x0028, 2, 0x0570, 0, 0), + MX7D_PAD_GPIO1_IO13__FLEXCAN1_TX = IOMUX_PAD(0x0280, 0x0028, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO13__CCM_PMIC_READY = IOMUX_PAD(0x0280, 0x0028, 4, 0x04F4, 1, 0), + MX7D_PAD_GPIO1_IO13__CCM_EXT_CLK2 = IOMUX_PAD(0x0280, 0x0028, 5, 0x04E8, 0, 0), + MX7D_PAD_GPIO1_IO13__SNVS_VIO_5_CTL = IOMUX_PAD(0x0280, 0x0028, 6, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO13__USB_OTG2_ID = IOMUX_PAD(0x0280, 0x0028, 7, 0x0730, 0, 0), + + MX7D_PAD_GPIO1_IO14__GPIO1_IO14 = IOMUX_PAD(0x0284, 0x002C, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO14__SD3_CD_B = IOMUX_PAD(0x0284, 0x002C, 1, 0x0738, 0, 0), + MX7D_PAD_GPIO1_IO14__ENET2_MDIO = IOMUX_PAD(0x0284, 0x002C, 2, 0x0574, 0, 0), + MX7D_PAD_GPIO1_IO14__FLEXCAN2_RX = IOMUX_PAD(0x0284, 0x002C, 3, 0x04E0, 0, 0), + MX7D_PAD_GPIO1_IO14__WDOG3_WDOG_B = IOMUX_PAD(0x0284, 0x002C, 4, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO14__CCM_EXT_CLK3 = IOMUX_PAD(0x0284, 0x002C, 5, 0x04EC, 0, 0), + MX7D_PAD_GPIO1_IO14__SDMA_EXT_EVENT0 = IOMUX_PAD(0x0284, 0x002C, 6, 0x06D8, 0, 0), + + MX7D_PAD_GPIO1_IO15__GPIO1_IO15 = IOMUX_PAD(0x0288, 0x0030, 0, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO15__SD3_WP = IOMUX_PAD(0x0288, 0x0030, 1, 0x073C, 0, 0), + MX7D_PAD_GPIO1_IO15__ENET2_MDC = IOMUX_PAD(0x0288, 0x0030, 2, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO15__FLEXCAN2_TX = IOMUX_PAD(0x0288, 0x0030, 3, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO15__WDOG4_WDOG_B = IOMUX_PAD(0x0288, 0x0030, 4, 0x0000, 0, 0), + MX7D_PAD_GPIO1_IO15__CCM_EXT_CLK4 = IOMUX_PAD(0x0288, 0x0030, 5, 0x04F0, 0, 0), + MX7D_PAD_GPIO1_IO15__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0288, 0x0030, 6, 0x06DC, 0, 0), + + MX7D_PAD_EPDC_DATA00__EPDC_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA00__SIM1_PORT2_TRXD = IOMUX_PAD(0x02A4, 0x0034, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA00__KPP_ROW3 = IOMUX_PAD(0x02A4, 0x0034, 3, 0x0620, 0, 0), + MX7D_PAD_EPDC_DATA00__EIM_AD0 = IOMUX_PAD(0x02A4, 0x0034, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA00__GPIO2_IO0 = IOMUX_PAD(0x02A4, 0x0034, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA00__LCD_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 6, 0x0638, 0, 0), + MX7D_PAD_EPDC_DATA00__LCD_CLK = IOMUX_PAD(0x02A4, 0x0034, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA01__EPDC_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA01__SIM1_PORT2_CLK = IOMUX_PAD(0x02A8, 0x0038, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA01__KPP_COL3 = IOMUX_PAD(0x02A8, 0x0038, 3, 0x0600, 0, 0), + MX7D_PAD_EPDC_DATA01__EIM_AD1 = IOMUX_PAD(0x02A8, 0x0038, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA01__GPIO2_IO1 = IOMUX_PAD(0x02A8, 0x0038, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA01__LCD_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 6, 0x063C, 0, 0), + MX7D_PAD_EPDC_DATA01__LCD_ENABLE = IOMUX_PAD(0x02A8, 0x0038, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA02__EPDC_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA02__SIM1_PORT2_RST_B = IOMUX_PAD(0x02AC, 0x003C, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA02__KPP_ROW2 = IOMUX_PAD(0x02AC, 0x003C, 3, 0x061C, 0, 0), + MX7D_PAD_EPDC_DATA02__EIM_AD2 = IOMUX_PAD(0x02AC, 0x003C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA02__GPIO2_IO2 = IOMUX_PAD(0x02AC, 0x003C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA02__LCD_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 6, 0x0640, 0, 0), + MX7D_PAD_EPDC_DATA02__LCD_VSYNC = IOMUX_PAD(0x02AC, 0x003C, 7, 0x0698, 0, 0), + + MX7D_PAD_EPDC_DATA03__EPDC_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA03__SIM1_PORT2_SVEN = IOMUX_PAD(0x02B0, 0x0040, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA03__KPP_COL2 = IOMUX_PAD(0x02B0, 0x0040, 3, 0x05FC, 0, 0), + MX7D_PAD_EPDC_DATA03__EIM_AD3 = IOMUX_PAD(0x02B0, 0x0040, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA03__GPIO2_IO3 = IOMUX_PAD(0x02B0, 0x0040, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA03__LCD_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 6, 0x0644, 0, 0), + MX7D_PAD_EPDC_DATA03__LCD_HSYNC = IOMUX_PAD(0x02B0, 0x0040, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA04__EPDC_DATA4 = IOMUX_PAD(0x02B4, 0x0044, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA04__SIM1_PORT2_PD = IOMUX_PAD(0x02B4, 0x0044, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA04__QSPI_A_DQS = IOMUX_PAD(0x02B4, 0x0044, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA04__KPP_ROW1 = IOMUX_PAD(0x02B4, 0x0044, 3, 0x0618, 0, 0), + MX7D_PAD_EPDC_DATA04__EIM_AD4 = IOMUX_PAD(0x02B4, 0x0044, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA04__GPIO2_IO4 = IOMUX_PAD(0x02B4, 0x0044, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA04__LCD_DATA4 = IOMUX_PAD(0x02B4, 0x0044, 6, 0x0648, 0, 0), + MX7D_PAD_EPDC_DATA04__JTAG_FAIL = IOMUX_PAD(0x02B4, 0x0044, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA05__EPDC_DATA5 = IOMUX_PAD(0x02B8, 0x0048, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA05__SIM2_PORT2_TRXD = IOMUX_PAD(0x02B8, 0x0048, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK = IOMUX_PAD(0x02B8, 0x0048, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA05__KPP_COL1 = IOMUX_PAD(0x02B8, 0x0048, 3, 0x05F8, 0, 0), + MX7D_PAD_EPDC_DATA05__EIM_AD5 = IOMUX_PAD(0x02B8, 0x0048, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA05__GPIO2_IO5 = IOMUX_PAD(0x02B8, 0x0048, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA05__LCD_DATA5 = IOMUX_PAD(0x02B8, 0x0048, 6, 0x064C, 0, 0), + MX7D_PAD_EPDC_DATA05__JTAG_ACTIVE = IOMUX_PAD(0x02B8, 0x0048, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA06__EPDC_DATA6 = IOMUX_PAD(0x02BC, 0x004C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA06__SIM2_PORT2_CLK = IOMUX_PAD(0x02BC, 0x004C, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B = IOMUX_PAD(0x02BC, 0x004C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA06__KPP_ROW0 = IOMUX_PAD(0x02BC, 0x004C, 3, 0x0614, 0, 0), + MX7D_PAD_EPDC_DATA06__EIM_AD6 = IOMUX_PAD(0x02BC, 0x004C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA06__GPIO2_IO6 = IOMUX_PAD(0x02BC, 0x004C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA06__LCD_DATA6 = IOMUX_PAD(0x02BC, 0x004C, 6, 0x0650, 0, 0), + MX7D_PAD_EPDC_DATA06__JTAG_DE_B = IOMUX_PAD(0x02BC, 0x004C, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA07__EPDC_DATA7 = IOMUX_PAD(0x02C0, 0x0050, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA07__SIM2_PORT2_RST_B = IOMUX_PAD(0x02C0, 0x0050, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA07__QSPI_A_SS1_B = IOMUX_PAD(0x02C0, 0x0050, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA07__KPP_COL0 = IOMUX_PAD(0x02C0, 0x0050, 3, 0x05F4, 0, 0), + MX7D_PAD_EPDC_DATA07__EIM_AD7 = IOMUX_PAD(0x02C0, 0x0050, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA07__GPIO2_IO7 = IOMUX_PAD(0x02C0, 0x0050, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA07__LCD_DATA7 = IOMUX_PAD(0x02C0, 0x0050, 6, 0x0654, 0, 0), + MX7D_PAD_EPDC_DATA07__JTAG_DONE = IOMUX_PAD(0x02C0, 0x0050, 7, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA08__EPDC_DATA8 = IOMUX_PAD(0x02C4, 0x0054, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA08__SIM1_PORT1_TRXD = IOMUX_PAD(0x02C4, 0x0054, 1, 0x06E4, 0, 0), + MX7D_PAD_EPDC_DATA08__QSPI_B_DATA0 = IOMUX_PAD(0x02C4, 0x0054, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA08__UART6_DCE_RX = IOMUX_PAD(0x02C4, 0x0054, 3, 0x071C, 0, 0), + MX7D_PAD_EPDC_DATA08__UART6_DTE_TX = IOMUX_PAD(0x02C4, 0x0054, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA08__EIM_OE = IOMUX_PAD(0x02C4, 0x0054, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA08__GPIO2_IO8 = IOMUX_PAD(0x02C4, 0x0054, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA08__LCD_DATA8 = IOMUX_PAD(0x02C4, 0x0054, 6, 0x0658, 0, 0), + MX7D_PAD_EPDC_DATA08__LCD_BUSY = IOMUX_PAD(0x02C4, 0x0054, 7, 0x0634, 0, 0), + MX7D_PAD_EPDC_DATA08__EPDC_SDCLK = IOMUX_PAD(0x02C4, 0x0054, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA09__EPDC_DATA9 = IOMUX_PAD(0x02C8, 0x0058, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__SIM1_PORT1_CLK = IOMUX_PAD(0x02C8, 0x0058, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__QSPI_B_DATA1 = IOMUX_PAD(0x02C8, 0x0058, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__UART6_DCE_TX = IOMUX_PAD(0x02C8, 0x0058, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__UART6_DTE_RX = IOMUX_PAD(0x02C8, 0x0058, 3, 0x071C, 1, 0), + MX7D_PAD_EPDC_DATA09__EIM_RW = IOMUX_PAD(0x02C8, 0x0058, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__GPIO2_IO9 = IOMUX_PAD(0x02C8, 0x0058, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA09__LCD_DATA9 = IOMUX_PAD(0x02C8, 0x0058, 6, 0x065C, 0, 0), + MX7D_PAD_EPDC_DATA09__LCD_DATA0 = IOMUX_PAD(0x02C8, 0x0058, 7, 0x0638, 1, 0), + MX7D_PAD_EPDC_DATA09__EPDC_SDLE = IOMUX_PAD(0x02C8, 0x0058, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA10__EPDC_DATA10 = IOMUX_PAD(0x02CC, 0x005C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__SIM1_PORT1_RST_B = IOMUX_PAD(0x02CC, 0x005C, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__QSPI_B_DATA2 = IOMUX_PAD(0x02CC, 0x005C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__UART6_DCE_RTS = IOMUX_PAD(0x02CC, 0x005C, 3, 0x0718, 0, 0), + MX7D_PAD_EPDC_DATA10__UART6_DTE_CTS = IOMUX_PAD(0x02CC, 0x005C, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__EIM_CS0_B = IOMUX_PAD(0x02CC, 0x005C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__GPIO2_IO10 = IOMUX_PAD(0x02CC, 0x005C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA10__LCD_DATA10 = IOMUX_PAD(0x02CC, 0x005C, 6, 0x0660, 0, 0), + MX7D_PAD_EPDC_DATA10__LCD_DATA9 = IOMUX_PAD(0x02CC, 0x005C, 7, 0x065C, 1, 0), + MX7D_PAD_EPDC_DATA10__EPDC_SDOE = IOMUX_PAD(0x02CC, 0x005C, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA11__EPDC_DATA11 = IOMUX_PAD(0x02D0, 0x0060, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__SIM1_PORT1_SVEN = IOMUX_PAD(0x02D0, 0x0060, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__QSPI_B_DATA3 = IOMUX_PAD(0x02D0, 0x0060, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__UART6_DCE_CTS = IOMUX_PAD(0x02D0, 0x0060, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__UART6_DTE_RTS = IOMUX_PAD(0x02D0, 0x0060, 3, 0x0718, 1, 0), + MX7D_PAD_EPDC_DATA11__EIM_BCLK = IOMUX_PAD(0x02D0, 0x0060, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__GPIO2_IO11 = IOMUX_PAD(0x02D0, 0x0060, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA11__LCD_DATA11 = IOMUX_PAD(0x02D0, 0x0060, 6, 0x0664, 0, 0), + MX7D_PAD_EPDC_DATA11__LCD_DATA1 = IOMUX_PAD(0x02D0, 0x0060, 7, 0x063C, 1, 0), + MX7D_PAD_EPDC_DATA11__EPDC_SDCE0 = IOMUX_PAD(0x02D0, 0x0060, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA12__EPDC_DATA12 = IOMUX_PAD(0x02D4, 0x0064, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA12__SIM1_PORT1_PD = IOMUX_PAD(0x02D4, 0x0064, 1, 0x06E0, 0, 0), + MX7D_PAD_EPDC_DATA12__QSPI_B_DQS = IOMUX_PAD(0x02D4, 0x0064, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA12__UART7_DCE_RX = IOMUX_PAD(0x02D4, 0x0064, 3, 0x0724, 0, 0), + MX7D_PAD_EPDC_DATA12__UART7_DTE_TX = IOMUX_PAD(0x02D4, 0x0064, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA12__EIM_LBA_B = IOMUX_PAD(0x02D4, 0x0064, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA12__GPIO2_IO12 = IOMUX_PAD(0x02D4, 0x0064, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA12__LCD_DATA12 = IOMUX_PAD(0x02D4, 0x0064, 6, 0x0668, 0, 0), + MX7D_PAD_EPDC_DATA12__LCD_DATA21 = IOMUX_PAD(0x02D4, 0x0064, 7, 0x068C, 0, 0), + MX7D_PAD_EPDC_DATA12__EPDC_GDCLK = IOMUX_PAD(0x02D4, 0x0064, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA13__EPDC_DATA13 = IOMUX_PAD(0x02D8, 0x0068, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__SIM2_PORT1_TRXD = IOMUX_PAD(0x02D8, 0x0068, 1, 0x06EC, 0, 0), + MX7D_PAD_EPDC_DATA13__QSPI_B_SCLK = IOMUX_PAD(0x02D8, 0x0068, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__UART7_DCE_TX = IOMUX_PAD(0x02D8, 0x0068, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__UART7_DTE_RX = IOMUX_PAD(0x02D8, 0x0068, 3, 0x0724, 1, 0), + MX7D_PAD_EPDC_DATA13__EIM_WAIT = IOMUX_PAD(0x02D8, 0x0068, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__GPIO2_IO13 = IOMUX_PAD(0x02D8, 0x0068, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__LCD_DATA13 = IOMUX_PAD(0x02D8, 0x0068, 6, 0x066C, 0, 0), + MX7D_PAD_EPDC_DATA13__LCD_CS = IOMUX_PAD(0x02D8, 0x0068, 7, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA13__EPDC_GDOE = IOMUX_PAD(0x02D8, 0x0068, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA14__EPDC_DATA14 = IOMUX_PAD(0x02DC, 0x006C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__SIM2_PORT1_CLK = IOMUX_PAD(0x02DC, 0x006C, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__QSPI_B_SS0_B = IOMUX_PAD(0x02DC, 0x006C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__UART7_DCE_RTS = IOMUX_PAD(0x02DC, 0x006C, 3, 0x0720, 0, 0), + MX7D_PAD_EPDC_DATA14__UART7_DTE_CTS = IOMUX_PAD(0x02DC, 0x006C, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__EIM_EB_B0 = IOMUX_PAD(0x02DC, 0x006C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__GPIO2_IO14 = IOMUX_PAD(0x02DC, 0x006C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA14__LCD_DATA14 = IOMUX_PAD(0x02DC, 0x006C, 6, 0x0670, 0, 0), + MX7D_PAD_EPDC_DATA14__LCD_DATA22 = IOMUX_PAD(0x02DC, 0x006C, 7, 0x0690, 0, 0), + MX7D_PAD_EPDC_DATA14__EPDC_GDSP = IOMUX_PAD(0x02DC, 0x006C, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_DATA15__EPDC_DATA15 = IOMUX_PAD(0x02E0, 0x0070, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__SIM2_PORT1_RST_B = IOMUX_PAD(0x02E0, 0x0070, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__QSPI_B_SS1_B = IOMUX_PAD(0x02E0, 0x0070, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__UART7_DCE_CTS = IOMUX_PAD(0x02E0, 0x0070, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__UART7_DTE_RTS = IOMUX_PAD(0x02E0, 0x0070, 3, 0x0720, 1, 0), + MX7D_PAD_EPDC_DATA15__EIM_CS1_B = IOMUX_PAD(0x02E0, 0x0070, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__GPIO2_IO15 = IOMUX_PAD(0x02E0, 0x0070, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__LCD_DATA15 = IOMUX_PAD(0x02E0, 0x0070, 6, 0x0674, 0, 0), + MX7D_PAD_EPDC_DATA15__LCD_WR_RWN = IOMUX_PAD(0x02E0, 0x0070, 7, 0x0000, 0, 0), + MX7D_PAD_EPDC_DATA15__EPDC_PWR_COM = IOMUX_PAD(0x02E0, 0x0070, 8, 0x0000, 0, 0), + + MX7D_PAD_EPDC_SDCLK__EPDC_SDCLK = IOMUX_PAD(0x02E4, 0x0074, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__SIM2_PORT2_SVEN = IOMUX_PAD(0x02E4, 0x0074, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 = IOMUX_PAD(0x02E4, 0x0074, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__KPP_ROW4 = IOMUX_PAD(0x02E4, 0x0074, 3, 0x0624, 0, 0), + MX7D_PAD_EPDC_SDCLK__EIM_AD10 = IOMUX_PAD(0x02E4, 0x0074, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 = IOMUX_PAD(0x02E4, 0x0074, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__LCD_CLK = IOMUX_PAD(0x02E4, 0x0074, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCLK__LCD_DATA20 = IOMUX_PAD(0x02E4, 0x0074, 7, 0x0688, 0, 0), + + MX7D_PAD_EPDC_SDLE__EPDC_SDLE = IOMUX_PAD(0x02E8, 0x0078, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDLE__SIM2_PORT2_PD = IOMUX_PAD(0x02E8, 0x0078, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 = IOMUX_PAD(0x02E8, 0x0078, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDLE__KPP_COL4 = IOMUX_PAD(0x02E8, 0x0078, 3, 0x0604, 0, 0), + MX7D_PAD_EPDC_SDLE__EIM_AD11 = IOMUX_PAD(0x02E8, 0x0078, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDLE__GPIO2_IO17 = IOMUX_PAD(0x02E8, 0x0078, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDLE__LCD_DATA16 = IOMUX_PAD(0x02E8, 0x0078, 6, 0x0678, 0, 0), + MX7D_PAD_EPDC_SDLE__LCD_DATA8 = IOMUX_PAD(0x02E8, 0x0078, 7, 0x0658, 1, 0), + + MX7D_PAD_EPDC_SDOE__EPDC_SDOE = IOMUX_PAD(0x02EC, 0x007C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDOE__FLEXTIMER1_CH0 = IOMUX_PAD(0x02EC, 0x007C, 1, 0x0584, 0, 0), + MX7D_PAD_EPDC_SDOE__ENET2_RGMII_RD2 = IOMUX_PAD(0x02EC, 0x007C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDOE__KPP_COL5 = IOMUX_PAD(0x02EC, 0x007C, 3, 0x0608, 1, 0), + MX7D_PAD_EPDC_SDOE__EIM_AD12 = IOMUX_PAD(0x02EC, 0x007C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDOE__GPIO2_IO18 = IOMUX_PAD(0x02EC, 0x007C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDOE__LCD_DATA17 = IOMUX_PAD(0x02EC, 0x007C, 6, 0x067C, 0, 0), + MX7D_PAD_EPDC_SDOE__LCD_DATA23 = IOMUX_PAD(0x02EC, 0x007C, 7, 0x0694, 0, 0), + + MX7D_PAD_EPDC_SDSHR__EPDC_SDSHR = IOMUX_PAD(0x02F0, 0x0080, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDSHR__FLEXTIMER1_CH1 = IOMUX_PAD(0x02F0, 0x0080, 1, 0x0588, 0, 0), + MX7D_PAD_EPDC_SDSHR__ENET2_RGMII_RD3 = IOMUX_PAD(0x02F0, 0x0080, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDSHR__KPP_ROW5 = IOMUX_PAD(0x02F0, 0x0080, 3, 0x0628, 1, 0), + MX7D_PAD_EPDC_SDSHR__EIM_AD13 = IOMUX_PAD(0x02F0, 0x0080, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDSHR__GPIO2_IO19 = IOMUX_PAD(0x02F0, 0x0080, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDSHR__LCD_DATA18 = IOMUX_PAD(0x02F0, 0x0080, 6, 0x0680, 0, 0), + MX7D_PAD_EPDC_SDSHR__LCD_DATA10 = IOMUX_PAD(0x02F0, 0x0080, 7, 0x0660, 1, 0), + + MX7D_PAD_EPDC_SDCE0__EPDC_SDCE0 = IOMUX_PAD(0x02F4, 0x0084, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE0__FLEXTIMER1_CH2 = IOMUX_PAD(0x02F4, 0x0084, 1, 0x058C, 0, 0), + MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL = IOMUX_PAD(0x02F4, 0x0084, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE0__EIM_AD14 = IOMUX_PAD(0x02F4, 0x0084, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 = IOMUX_PAD(0x02F4, 0x0084, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE0__LCD_DATA19 = IOMUX_PAD(0x02F4, 0x0084, 6, 0x0684, 0, 0), + MX7D_PAD_EPDC_SDCE0__LCD_DATA5 = IOMUX_PAD(0x02F4, 0x0084, 7, 0x064C, 1, 0), + + MX7D_PAD_EPDC_SDCE1__EPDC_SDCE1 = IOMUX_PAD(0x02F8, 0x0088, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE1__FLEXTIMER1_CH3 = IOMUX_PAD(0x02F8, 0x0088, 1, 0x0590, 0, 0), + MX7D_PAD_EPDC_SDCE1__ENET2_RGMII_RXC = IOMUX_PAD(0x02F8, 0x0088, 2, 0x0578, 0, 0), + MX7D_PAD_EPDC_SDCE1__ENET2_RX_ER = IOMUX_PAD(0x02F8, 0x0088, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE1__EIM_AD15 = IOMUX_PAD(0x02F8, 0x0088, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 = IOMUX_PAD(0x02F8, 0x0088, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE1__LCD_DATA20 = IOMUX_PAD(0x02F8, 0x0088, 6, 0x0688, 1, 0), + MX7D_PAD_EPDC_SDCE1__LCD_DATA4 = IOMUX_PAD(0x02F8, 0x0088, 7, 0x0648, 1, 0), + + MX7D_PAD_EPDC_SDCE2__EPDC_SDCE2 = IOMUX_PAD(0x02FC, 0x008C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE2__SIM2_PORT1_SVEN = IOMUX_PAD(0x02FC, 0x008C, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 = IOMUX_PAD(0x02FC, 0x008C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE2__KPP_COL6 = IOMUX_PAD(0x02FC, 0x008C, 3, 0x060C, 1, 0), + MX7D_PAD_EPDC_SDCE2__EIM_ADDR16 = IOMUX_PAD(0x02FC, 0x008C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 = IOMUX_PAD(0x02FC, 0x008C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE2__LCD_DATA21 = IOMUX_PAD(0x02FC, 0x008C, 6, 0x068C, 1, 0), + MX7D_PAD_EPDC_SDCE2__LCD_DATA3 = IOMUX_PAD(0x02FC, 0x008C, 7, 0x0644, 1, 0), + + MX7D_PAD_EPDC_SDCE3__EPDC_SDCE3 = IOMUX_PAD(0x0300, 0x0090, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE3__SIM2_PORT1_PD = IOMUX_PAD(0x0300, 0x0090, 1, 0x06E8, 0, 0), + MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 = IOMUX_PAD(0x0300, 0x0090, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE3__KPP_ROW6 = IOMUX_PAD(0x0300, 0x0090, 3, 0x062C, 1, 0), + MX7D_PAD_EPDC_SDCE3__EIM_ADDR17 = IOMUX_PAD(0x0300, 0x0090, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 = IOMUX_PAD(0x0300, 0x0090, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_SDCE3__LCD_DATA22 = IOMUX_PAD(0x0300, 0x0090, 6, 0x0690, 1, 0), + MX7D_PAD_EPDC_SDCE3__LCD_DATA2 = IOMUX_PAD(0x0300, 0x0090, 7, 0x0640, 1, 0), + + MX7D_PAD_EPDC_GDCLK__EPDC_GDCLK = IOMUX_PAD(0x0304, 0x0094, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDCLK__FLEXTIMER2_CH0 = IOMUX_PAD(0x0304, 0x0094, 1, 0x05AC, 0, 0), + MX7D_PAD_EPDC_GDCLK__ENET2_RGMII_TD2 = IOMUX_PAD(0x0304, 0x0094, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDCLK__KPP_COL7 = IOMUX_PAD(0x0304, 0x0094, 3, 0x0610, 0, 0), + MX7D_PAD_EPDC_GDCLK__EIM_ADDR18 = IOMUX_PAD(0x0304, 0x0094, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDCLK__GPIO2_IO24 = IOMUX_PAD(0x0304, 0x0094, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDCLK__LCD_DATA23 = IOMUX_PAD(0x0304, 0x0094, 6, 0x0694, 1, 0), + MX7D_PAD_EPDC_GDCLK__LCD_DATA16 = IOMUX_PAD(0x0304, 0x0094, 7, 0x0678, 1, 0), + + MX7D_PAD_EPDC_GDOE__EPDC_GDOE = IOMUX_PAD(0x0308, 0x0098, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDOE__FLEXTIMER2_CH1 = IOMUX_PAD(0x0308, 0x0098, 1, 0x05B0, 0, 0), + MX7D_PAD_EPDC_GDOE__ENET2_RGMII_TD3 = IOMUX_PAD(0x0308, 0x0098, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDOE__KPP_ROW7 = IOMUX_PAD(0x0308, 0x0098, 3, 0x0630, 0, 0), + MX7D_PAD_EPDC_GDOE__EIM_ADDR19 = IOMUX_PAD(0x0308, 0x0098, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDOE__GPIO2_IO25 = IOMUX_PAD(0x0308, 0x0098, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDOE__LCD_WR_RWN = IOMUX_PAD(0x0308, 0x0098, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDOE__LCD_DATA18 = IOMUX_PAD(0x0308, 0x0098, 7, 0x0680, 1, 0), + + MX7D_PAD_EPDC_GDRL__EPDC_GDRL = IOMUX_PAD(0x030C, 0x009C, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDRL__FLEXTIMER2_CH2 = IOMUX_PAD(0x030C, 0x009C, 1, 0x05B4, 0, 0), + MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL = IOMUX_PAD(0x030C, 0x009C, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDRL__EIM_ADDR20 = IOMUX_PAD(0x030C, 0x009C, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDRL__GPIO2_IO26 = IOMUX_PAD(0x030C, 0x009C, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDRL__LCD_RD_E = IOMUX_PAD(0x030C, 0x009C, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDRL__LCD_DATA19 = IOMUX_PAD(0x030C, 0x009C, 7, 0x0684, 1, 0), + + MX7D_PAD_EPDC_GDSP__EPDC_GDSP = IOMUX_PAD(0x0310, 0x00A0, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDSP__FLEXTIMER2_CH3 = IOMUX_PAD(0x0310, 0x00A0, 1, 0x05B8, 0, 0), + MX7D_PAD_EPDC_GDSP__ENET2_RGMII_TXC = IOMUX_PAD(0x0310, 0x00A0, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDSP__ENET2_TX_ER = IOMUX_PAD(0x0310, 0x00A0, 3, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDSP__EIM_ADDR21 = IOMUX_PAD(0x0310, 0x00A0, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDSP__GPIO2_IO27 = IOMUX_PAD(0x0310, 0x00A0, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_GDSP__LCD_BUSY = IOMUX_PAD(0x0310, 0x00A0, 6, 0x0634, 1, 0), + MX7D_PAD_EPDC_GDSP__LCD_DATA17 = IOMUX_PAD(0x0310, 0x00A0, 7, 0x067C, 1, 0), + + MX7D_PAD_EPDC_BDR0__EPDC_BDR0 = IOMUX_PAD(0x0314, 0x00A4, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR0__ENET2_TX_CLK = IOMUX_PAD(0x0314, 0x00A4, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR0__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x0314, 0x00A4, 3, 0x0570, 1, 0), + MX7D_PAD_EPDC_BDR0__EIM_ADDR22 = IOMUX_PAD(0x0314, 0x00A4, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR0__GPIO2_IO28 = IOMUX_PAD(0x0314, 0x00A4, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR0__LCD_CS = IOMUX_PAD(0x0314, 0x00A4, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR0__LCD_DATA7 = IOMUX_PAD(0x0314, 0x00A4, 7, 0x0654, 1, 0), + + MX7D_PAD_EPDC_BDR1__EPDC_BDR1 = IOMUX_PAD(0x0318, 0x00A8, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR1__EPDC_SDCLKN = IOMUX_PAD(0x0318, 0x00A8, 1, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR1__ENET2_RX_CLK = IOMUX_PAD(0x0318, 0x00A8, 2, 0x0578, 1, 0), + MX7D_PAD_EPDC_BDR1__EIM_AD8 = IOMUX_PAD(0x0318, 0x00A8, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR1__GPIO2_IO29 = IOMUX_PAD(0x0318, 0x00A8, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR1__LCD_ENABLE = IOMUX_PAD(0x0318, 0x00A8, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_BDR1__LCD_DATA6 = IOMUX_PAD(0x0318, 0x00A8, 7, 0x0650, 1, 0), + + MX7D_PAD_EPDC_PWR_COM__EPDC_PWR_COM = IOMUX_PAD(0x031C, 0x00AC, 0, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_COM__FLEXTIMER2_PHA = IOMUX_PAD(0x031C, 0x00AC, 1, 0x05CC, 0, 0), + MX7D_PAD_EPDC_PWR_COM__ENET2_CRS = IOMUX_PAD(0x031C, 0x00AC, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_COM__EIM_AD9 = IOMUX_PAD(0x031C, 0x00AC, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 = IOMUX_PAD(0x031C, 0x00AC, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_COM__LCD_HSYNC = IOMUX_PAD(0x031C, 0x00AC, 6, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_COM__LCD_DATA11 = IOMUX_PAD(0x031C, 0x00AC, 7, 0x0664, 1, 0), + + MX7D_PAD_EPDC_PWR_STAT__EPDC_PWR_STAT = IOMUX_PAD(0x0320, 0x00B0, 0, 0x0580, 0, 0), + MX7D_PAD_EPDC_PWR_STAT__FLEXTIMER2_PHB = IOMUX_PAD(0x0320, 0x00B0, 1, 0x05D0, 0, 0), + MX7D_PAD_EPDC_PWR_STAT__ENET2_COL = IOMUX_PAD(0x0320, 0x00B0, 2, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_STAT__EIM_EB_B1 = IOMUX_PAD(0x0320, 0x00B0, 4, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31 = IOMUX_PAD(0x0320, 0x00B0, 5, 0x0000, 0, 0), + MX7D_PAD_EPDC_PWR_STAT__LCD_VSYNC = IOMUX_PAD(0x0320, 0x00B0, 6, 0x0698, 1, 0), + MX7D_PAD_EPDC_PWR_STAT__LCD_DATA12 = IOMUX_PAD(0x0320, 0x00B0, 7, 0x0668, 1, 0), + + MX7D_PAD_LCD_CLK__LCD_CLK = IOMUX_PAD(0x0324, 0x00B4, 0, 0x0000, 0, 0), + MX7D_PAD_LCD_CLK__ECSPI4_MISO = IOMUX_PAD(0x0324, 0x00B4, 1, 0x0558, 0, 0), + MX7D_PAD_LCD_CLK__ENET1_1588_EVENT2_IN = IOMUX_PAD(0x0324, 0x00B4, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_CLK__CSI_DATA16 = IOMUX_PAD(0x0324, 0x00B4, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_CLK__UART2_DCE_RX = IOMUX_PAD(0x0324, 0x00B4, 4, 0x06FC, 0, 0), + MX7D_PAD_LCD_CLK__UART2_DTE_TX = IOMUX_PAD(0x0324, 0x00B4, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_CLK__GPIO3_IO0 = IOMUX_PAD(0x0324, 0x00B4, 5, 0x0000, 0, 0), + + MX7D_PAD_LCD_ENABLE__LCD_ENABLE = IOMUX_PAD(0x0328, 0x00B8, 0, 0x0000, 0, 0), + MX7D_PAD_LCD_ENABLE__ECSPI4_MOSI = IOMUX_PAD(0x0328, 0x00B8, 1, 0x055C, 0, 0), + MX7D_PAD_LCD_ENABLE__ENET1_1588_EVENT3_IN = IOMUX_PAD(0x0328, 0x00B8, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_ENABLE__CSI_DATA17 = IOMUX_PAD(0x0328, 0x00B8, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_ENABLE__UART2_DCE_TX = IOMUX_PAD(0x0328, 0x00B8, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_ENABLE__UART2_DTE_RX = IOMUX_PAD(0x0328, 0x00B8, 4, 0x06FC, 1, 0), + MX7D_PAD_LCD_ENABLE__GPIO3_IO1 = IOMUX_PAD(0x0328, 0x00B8, 5, 0x0000, 0, 0), + + MX7D_PAD_LCD_HSYNC__LCD_HSYNC = IOMUX_PAD(0x032C, 0x00BC, 0, 0x0000, 0, 0), + MX7D_PAD_LCD_HSYNC__ECSPI4_SCLK = IOMUX_PAD(0x032C, 0x00BC, 1, 0x0554, 0, 0), + MX7D_PAD_LCD_HSYNC__ENET2_1588_EVENT2_IN = IOMUX_PAD(0x032C, 0x00BC, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_HSYNC__CSI_DATA18 = IOMUX_PAD(0x032C, 0x00BC, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_HSYNC__UART2_DCE_RTS = IOMUX_PAD(0x032C, 0x00BC, 4, 0x06F8, 0, 0), + MX7D_PAD_LCD_HSYNC__UART2_DTE_CTS = IOMUX_PAD(0x032C, 0x00BC, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_HSYNC__GPIO3_IO2 = IOMUX_PAD(0x032C, 0x00BC, 5, 0x0000, 0, 0), + + MX7D_PAD_LCD_VSYNC__LCD_VSYNC = IOMUX_PAD(0x0330, 0x00C0, 0, 0x0698, 2, 0), + MX7D_PAD_LCD_VSYNC__ECSPI4_SS0 = IOMUX_PAD(0x0330, 0x00C0, 1, 0x0560, 0, 0), + MX7D_PAD_LCD_VSYNC__ENET2_1588_EVENT3_IN = IOMUX_PAD(0x0330, 0x00C0, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_VSYNC__CSI_DATA19 = IOMUX_PAD(0x0330, 0x00C0, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_VSYNC__UART2_DCE_CTS = IOMUX_PAD(0x0330, 0x00C0, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_VSYNC__UART2_DTE_RTS = IOMUX_PAD(0x0330, 0x00C0, 4, 0x06F8, 1, 0), + MX7D_PAD_LCD_VSYNC__GPIO3_IO3 = IOMUX_PAD(0x0330, 0x00C0, 5, 0x0000, 0, 0), + + MX7D_PAD_LCD_RESET__LCD_RESET = IOMUX_PAD(0x0334, 0x00C4, 0, 0x0000, 0, 0), + MX7D_PAD_LCD_RESET__GPT1_COMPARE1 = IOMUX_PAD(0x0334, 0x00C4, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_RESET__ARM_PLATFORM_EVENTI = IOMUX_PAD(0x0334, 0x00C4, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_RESET__CSI_FIELD = IOMUX_PAD(0x0334, 0x00C4, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_RESET__EIM_DTACK_B = IOMUX_PAD(0x0334, 0x00C4, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_RESET__GPIO3_IO4 = IOMUX_PAD(0x0334, 0x00C4, 5, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA00__LCD_DATA0 = IOMUX_PAD(0x0338, 0x00C8, 0, 0x0638, 2, 0), + MX7D_PAD_LCD_DATA00__GPT1_COMPARE2 = IOMUX_PAD(0x0338, 0x00C8, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA00__CSI_DATA20 = IOMUX_PAD(0x0338, 0x00C8, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA00__EIM_DATA0 = IOMUX_PAD(0x0338, 0x00C8, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA00__GPIO3_IO5 = IOMUX_PAD(0x0338, 0x00C8, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA00__SRC_BOOT_CFG0 = IOMUX_PAD(0x0338, 0x00C8, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA01__LCD_DATA1 = IOMUX_PAD(0x033C, 0x00CC, 0, 0x063C, 2, 0), + MX7D_PAD_LCD_DATA01__GPT1_COMPARE3 = IOMUX_PAD(0x033C, 0x00CC, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA01__CSI_DATA21 = IOMUX_PAD(0x033C, 0x00CC, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA01__EIM_DATA1 = IOMUX_PAD(0x033C, 0x00CC, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA01__GPIO3_IO6 = IOMUX_PAD(0x033C, 0x00CC, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA01__SRC_BOOT_CFG1 = IOMUX_PAD(0x033C, 0x00CC, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA02__LCD_DATA2 = IOMUX_PAD(0x0340, 0x00D0, 0, 0x0640, 2, 0), + MX7D_PAD_LCD_DATA02__GPT1_CLK = IOMUX_PAD(0x0340, 0x00D0, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA02__CSI_DATA22 = IOMUX_PAD(0x0340, 0x00D0, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA02__EIM_DATA2 = IOMUX_PAD(0x0340, 0x00D0, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA02__GPIO3_IO7 = IOMUX_PAD(0x0340, 0x00D0, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA02__SRC_BOOT_CFG2 = IOMUX_PAD(0x0340, 0x00D0, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA03__LCD_DATA3 = IOMUX_PAD(0x0344, 0x00D4, 0, 0x0644, 2, 0), + MX7D_PAD_LCD_DATA03__GPT1_CAPTURE1 = IOMUX_PAD(0x0344, 0x00D4, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA03__CSI_DATA23 = IOMUX_PAD(0x0344, 0x00D4, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA03__EIM_DATA3 = IOMUX_PAD(0x0344, 0x00D4, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA03__GPIO3_IO8 = IOMUX_PAD(0x0344, 0x00D4, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA03__SRC_BOOT_CFG3 = IOMUX_PAD(0x0344, 0x00D4, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA04__LCD_DATA4 = IOMUX_PAD(0x0348, 0x00D8, 0, 0x0648, 2, 0), + MX7D_PAD_LCD_DATA04__GPT1_CAPTURE2 = IOMUX_PAD(0x0348, 0x00D8, 1, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA04__CSI_VSYNC = IOMUX_PAD(0x0348, 0x00D8, 3, 0x0520, 0, 0), + MX7D_PAD_LCD_DATA04__EIM_DATA4 = IOMUX_PAD(0x0348, 0x00D8, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA04__GPIO3_IO9 = IOMUX_PAD(0x0348, 0x00D8, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA04__SRC_BOOT_CFG4 = IOMUX_PAD(0x0348, 0x00D8, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA05__LCD_DATA5 = IOMUX_PAD(0x034C, 0x00DC, 0, 0x064C, 2, 0), + MX7D_PAD_LCD_DATA05__CSI_HSYNC = IOMUX_PAD(0x034C, 0x00DC, 3, 0x0518, 0, 0), + MX7D_PAD_LCD_DATA05__EIM_DATA5 = IOMUX_PAD(0x034C, 0x00DC, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA05__GPIO3_IO10 = IOMUX_PAD(0x034C, 0x00DC, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA05__SRC_BOOT_CFG5 = IOMUX_PAD(0x034C, 0x00DC, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA06__LCD_DATA6 = IOMUX_PAD(0x0350, 0x00E0, 0, 0x0650, 2, 0), + MX7D_PAD_LCD_DATA06__CSI_PIXCLK = IOMUX_PAD(0x0350, 0x00E0, 3, 0x051C, 0, 0), + MX7D_PAD_LCD_DATA06__EIM_DATA6 = IOMUX_PAD(0x0350, 0x00E0, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA06__GPIO3_IO11 = IOMUX_PAD(0x0350, 0x00E0, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA06__SRC_BOOT_CFG6 = IOMUX_PAD(0x0350, 0x00E0, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA07__LCD_DATA7 = IOMUX_PAD(0x0354, 0x00E4, 0, 0x0654, 2, 0), + MX7D_PAD_LCD_DATA07__CSI_MCLK = IOMUX_PAD(0x0354, 0x00E4, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA07__EIM_DATA7 = IOMUX_PAD(0x0354, 0x00E4, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA07__GPIO3_IO12 = IOMUX_PAD(0x0354, 0x00E4, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA07__SRC_BOOT_CFG7 = IOMUX_PAD(0x0354, 0x00E4, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA08__LCD_DATA8 = IOMUX_PAD(0x0358, 0x00E8, 0, 0x0658, 2, 0), + MX7D_PAD_LCD_DATA08__CSI_DATA9 = IOMUX_PAD(0x0358, 0x00E8, 3, 0x0514, 0, 0), + MX7D_PAD_LCD_DATA08__EIM_DATA8 = IOMUX_PAD(0x0358, 0x00E8, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA08__GPIO3_IO13 = IOMUX_PAD(0x0358, 0x00E8, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA08__SRC_BOOT_CFG8 = IOMUX_PAD(0x0358, 0x00E8, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA09__LCD_DATA9 = IOMUX_PAD(0x035C, 0x00EC, 0, 0x065C, 2, 0), + MX7D_PAD_LCD_DATA09__CSI_DATA8 = IOMUX_PAD(0x035C, 0x00EC, 3, 0x0510, 0, 0), + MX7D_PAD_LCD_DATA09__EIM_DATA9 = IOMUX_PAD(0x035C, 0x00EC, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA09__GPIO3_IO14 = IOMUX_PAD(0x035C, 0x00EC, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA09__SRC_BOOT_CFG9 = IOMUX_PAD(0x035C, 0x00EC, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA10__LCD_DATA10 = IOMUX_PAD(0x0360, 0x00F0, 0, 0x0660, 2, 0), + MX7D_PAD_LCD_DATA10__CSI_DATA7 = IOMUX_PAD(0x0360, 0x00F0, 3, 0x050C, 0, 0), + MX7D_PAD_LCD_DATA10__EIM_DATA10 = IOMUX_PAD(0x0360, 0x00F0, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA10__GPIO3_IO15 = IOMUX_PAD(0x0360, 0x00F0, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0360, 0x00F0, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA11__LCD_DATA11 = IOMUX_PAD(0x0364, 0x00F4, 0, 0x0664, 2, 0), + MX7D_PAD_LCD_DATA11__CSI_DATA6 = IOMUX_PAD(0x0364, 0x00F4, 3, 0x0508, 0, 0), + MX7D_PAD_LCD_DATA11__EIM_DATA11 = IOMUX_PAD(0x0364, 0x00F4, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA11__GPIO3_IO16 = IOMUX_PAD(0x0364, 0x00F4, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0364, 0x00F4, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA12__LCD_DATA12 = IOMUX_PAD(0x0368, 0x00F8, 0, 0x0668, 2, 0), + MX7D_PAD_LCD_DATA12__CSI_DATA5 = IOMUX_PAD(0x0368, 0x00F8, 3, 0x0504, 0, 0), + MX7D_PAD_LCD_DATA12__EIM_DATA12 = IOMUX_PAD(0x0368, 0x00F8, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA12__GPIO3_IO17 = IOMUX_PAD(0x0368, 0x00F8, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0368, 0x00F8, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA13__LCD_DATA13 = IOMUX_PAD(0x036C, 0x00FC, 0, 0x066C, 1, 0), + MX7D_PAD_LCD_DATA13__CSI_DATA4 = IOMUX_PAD(0x036C, 0x00FC, 3, 0x0500, 0, 0), + MX7D_PAD_LCD_DATA13__EIM_DATA13 = IOMUX_PAD(0x036C, 0x00FC, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA13__GPIO3_IO18 = IOMUX_PAD(0x036C, 0x00FC, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x036C, 0x00FC, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA14__LCD_DATA14 = IOMUX_PAD(0x0370, 0x0100, 0, 0x0670, 1, 0), + MX7D_PAD_LCD_DATA14__CSI_DATA3 = IOMUX_PAD(0x0370, 0x0100, 3, 0x04FC, 0, 0), + MX7D_PAD_LCD_DATA14__EIM_DATA14 = IOMUX_PAD(0x0370, 0x0100, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA14__GPIO3_IO19 = IOMUX_PAD(0x0370, 0x0100, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0370, 0x0100, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA15__LCD_DATA15 = IOMUX_PAD(0x0374, 0x0104, 0, 0x0674, 1, 0), + MX7D_PAD_LCD_DATA15__CSI_DATA2 = IOMUX_PAD(0x0374, 0x0104, 3, 0x04F8, 0, 0), + MX7D_PAD_LCD_DATA15__EIM_DATA15 = IOMUX_PAD(0x0374, 0x0104, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA15__GPIO3_IO20 = IOMUX_PAD(0x0374, 0x0104, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0374, 0x0104, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA16__LCD_DATA16 = IOMUX_PAD(0x0378, 0x0108, 0, 0x0678, 2, 0), + MX7D_PAD_LCD_DATA16__FLEXTIMER1_CH4 = IOMUX_PAD(0x0378, 0x0108, 1, 0x0594, 0, 0), + MX7D_PAD_LCD_DATA16__CSI_DATA1 = IOMUX_PAD(0x0378, 0x0108, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA16__EIM_CRE = IOMUX_PAD(0x0378, 0x0108, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA16__GPIO3_IO21 = IOMUX_PAD(0x0378, 0x0108, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0378, 0x0108, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA17__LCD_DATA17 = IOMUX_PAD(0x037C, 0x010C, 0, 0x067C, 2, 0), + MX7D_PAD_LCD_DATA17__FLEXTIMER1_CH5 = IOMUX_PAD(0x037C, 0x010C, 1, 0x0598, 0, 0), + MX7D_PAD_LCD_DATA17__CSI_DATA0 = IOMUX_PAD(0x037C, 0x010C, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA17__EIM_ACLK_FREERUN = IOMUX_PAD(0x037C, 0x010C, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA17__GPIO3_IO22 = IOMUX_PAD(0x037C, 0x010C, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA17__SRC_BOOT_CFG17 = IOMUX_PAD(0x037C, 0x010C, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA18__LCD_DATA18 = IOMUX_PAD(0x0380, 0x0110, 0, 0x0680, 2, 0), + MX7D_PAD_LCD_DATA18__FLEXTIMER1_CH6 = IOMUX_PAD(0x0380, 0x0110, 1, 0x059C, 0, 0), + MX7D_PAD_LCD_DATA18__ARM_PLATFORM_EVENTO = IOMUX_PAD(0x0380, 0x0110, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA18__CSI_DATA15 = IOMUX_PAD(0x0380, 0x0110, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA18__EIM_CS2_B = IOMUX_PAD(0x0380, 0x0110, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA18__GPIO3_IO23 = IOMUX_PAD(0x0380, 0x0110, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0380, 0x0110, 6, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA19__EIM_CS3_B = IOMUX_PAD(0x0384, 0x0114, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA19__GPIO3_IO24 = IOMUX_PAD(0x0384, 0x0114, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA19__SRC_BOOT_CFG19 = IOMUX_PAD(0x0384, 0x0114, 6, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA19__LCD_DATA19 = IOMUX_PAD(0x0384, 0x0114, 0, 0x0684, 2, 0), + MX7D_PAD_LCD_DATA19__FLEXTIMER1_CH7 = IOMUX_PAD(0x0384, 0x0114, 1, 0x05A0, 0, 0), + MX7D_PAD_LCD_DATA19__CSI_DATA14 = IOMUX_PAD(0x0384, 0x0114, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA20__EIM_ADDR23 = IOMUX_PAD(0x0388, 0x0118, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA20__GPIO3_IO25 = IOMUX_PAD(0x0388, 0x0118, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA20__I2C3_SCL = IOMUX_PAD(0x0388, 0x0118, IOMUX_CONFIG_SION | 6, 0x05E4, 1, 0), + + MX7D_PAD_LCD_DATA20__LCD_DATA20 = IOMUX_PAD(0x0388, 0x0118, 0, 0x0688, 2, 0), + MX7D_PAD_LCD_DATA20__FLEXTIMER2_CH4 = IOMUX_PAD(0x0388, 0x0118, 1, 0x05BC, 0, 0), + MX7D_PAD_LCD_DATA20__ENET1_1588_EVENT2_OUT = IOMUX_PAD(0x0388, 0x0118, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA20__CSI_DATA13 = IOMUX_PAD(0x0388, 0x0118, 3, 0x0000, 0, 0), + + MX7D_PAD_LCD_DATA21__LCD_DATA21 = IOMUX_PAD(0x038C, 0x011C, 0, 0x068C, 2, 0), + MX7D_PAD_LCD_DATA21__FLEXTIMER2_CH5 = IOMUX_PAD(0x038C, 0x011C, 1, 0x05C0, 0, 0), + MX7D_PAD_LCD_DATA21__ENET1_1588_EVENT3_OUT = IOMUX_PAD(0x038C, 0x011C, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA21__CSI_DATA12 = IOMUX_PAD(0x038C, 0x011C, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA21__EIM_ADDR24 = IOMUX_PAD(0x038C, 0x011C, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA21__GPIO3_IO26 = IOMUX_PAD(0x038C, 0x011C, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA21__I2C3_SDA = IOMUX_PAD(0x038C, 0x011C, IOMUX_CONFIG_SION | 6, 0x05E8, 1, 0), + + MX7D_PAD_LCD_DATA22__LCD_DATA22 = IOMUX_PAD(0x0390, 0x0120, 0, 0x0690, 2, 0), + MX7D_PAD_LCD_DATA22__FLEXTIMER2_CH6 = IOMUX_PAD(0x0390, 0x0120, 1, 0x05C4, 0, 0), + MX7D_PAD_LCD_DATA22__ENET2_1588_EVENT2_OUT = IOMUX_PAD(0x0390, 0x0120, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA22__CSI_DATA11 = IOMUX_PAD(0x0390, 0x0120, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA22__EIM_ADDR25 = IOMUX_PAD(0x0390, 0x0120, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA22__GPIO3_IO27 = IOMUX_PAD(0x0390, 0x0120, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA22__I2C4_SCL = IOMUX_PAD(0x0390, 0x0120, IOMUX_CONFIG_SION | 6, 0x05EC, 1, 0), + + MX7D_PAD_LCD_DATA23__LCD_DATA23 = IOMUX_PAD(0x0394, 0x0124, 0, 0x0694, 2, 0), + MX7D_PAD_LCD_DATA23__FLEXTIMER2_CH7 = IOMUX_PAD(0x0394, 0x0124, 1, 0x05C8, 0, 0), + MX7D_PAD_LCD_DATA23__ENET2_1588_EVENT3_OUT = IOMUX_PAD(0x0394, 0x0124, 2, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA23__CSI_DATA10 = IOMUX_PAD(0x0394, 0x0124, 3, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA23__EIM_ADDR26 = IOMUX_PAD(0x0394, 0x0124, 4, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA23__GPIO3_IO28 = IOMUX_PAD(0x0394, 0x0124, 5, 0x0000, 0, 0), + MX7D_PAD_LCD_DATA23__I2C4_SDA = IOMUX_PAD(0x0394, 0x0124, IOMUX_CONFIG_SION | 6, 0x05F0, 1, 0), + + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0), + + MX7D_PAD_UART1_RX_DATA__UART1_DTE_TX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__I2C1_SCL = IOMUX_PAD(0x0398, 0x0128, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__CCM_PMIC_READY = IOMUX_PAD(0x0398, 0x0128, 2, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__ECSPI1_SS1 = IOMUX_PAD(0x0398, 0x0128, 3, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__ENET2_1588_EVENT0_IN = IOMUX_PAD(0x0398, 0x0128, 4, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__GPIO4_IO0 = IOMUX_PAD(0x0398, 0x0128, 5, 0x0000, 0, 0), + MX7D_PAD_UART1_RX_DATA__ENET1_MDIO = IOMUX_PAD(0x0398, 0x0128, 6, 0x0000, 0, 0), + + MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX = IOMUX_PAD(0x039C, 0x012C, 0, 0x0000, 0, 0), + + MX7D_PAD_UART1_TX_DATA__UART1_DTE_RX = IOMUX_PAD(0x039C, 0x012C, 0, 0x06F4, 1, 0), + MX7D_PAD_UART1_TX_DATA__I2C1_SDA = IOMUX_PAD(0x039C, 0x012C, IOMUX_CONFIG_SION | 1, 0x05D8, 0, 0), + MX7D_PAD_UART1_TX_DATA__SAI3_MCLK = IOMUX_PAD(0x039C, 0x012C, 2, 0x0000, 0, 0), + MX7D_PAD_UART1_TX_DATA__ECSPI1_SS2 = IOMUX_PAD(0x039C, 0x012C, 3, 0x0000, 0, 0), + MX7D_PAD_UART1_TX_DATA__ENET2_1588_EVENT0_OUT = IOMUX_PAD(0x039C, 0x012C, 4, 0x0000, 0, 0), + MX7D_PAD_UART1_TX_DATA__GPIO4_IO1 = IOMUX_PAD(0x039C, 0x012C, 5, 0x0000, 0, 0), + MX7D_PAD_UART1_TX_DATA__ENET1_MDC = IOMUX_PAD(0x039C, 0x012C, 6, 0x0000, 0, 0), + + MX7D_PAD_UART2_RX_DATA__UART2_DCE_RX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0), + + MX7D_PAD_UART2_RX_DATA__UART2_DTE_TX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__I2C2_SCL = IOMUX_PAD(0x03A0, 0x0130, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__SAI3_RX_BCLK = IOMUX_PAD(0x03A0, 0x0130, 2, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__ECSPI1_SS3 = IOMUX_PAD(0x03A0, 0x0130, 3, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__ENET2_1588_EVENT1_IN = IOMUX_PAD(0x03A0, 0x0130, 4, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__GPIO4_IO2 = IOMUX_PAD(0x03A0, 0x0130, 5, 0x0000, 0, 0), + MX7D_PAD_UART2_RX_DATA__ENET2_MDIO = IOMUX_PAD(0x03A0, 0x0130, 6, 0x0000, 0, 0), + + MX7D_PAD_UART2_TX_DATA__UART2_DCE_TX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0), + + MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0), + MX7D_PAD_UART2_TX_DATA__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0134, IOMUX_CONFIG_SION | 1, 0x05E0, 0, 0), + MX7D_PAD_UART2_TX_DATA__SAI3_RX_DATA0 = IOMUX_PAD(0x03A4, 0x0134, 2, 0x06C8, 0, 0), + MX7D_PAD_UART2_TX_DATA__ECSPI1_RDY = IOMUX_PAD(0x03A4, 0x0134, 3, 0x0000, 0, 0), + MX7D_PAD_UART2_TX_DATA__ENET2_1588_EVENT1_OUT = IOMUX_PAD(0x03A4, 0x0134, 4, 0x0000, 0, 0), + MX7D_PAD_UART2_TX_DATA__GPIO4_IO3 = IOMUX_PAD(0x03A4, 0x0134, 5, 0x0000, 0, 0), + MX7D_PAD_UART2_TX_DATA__ENET2_MDC = IOMUX_PAD(0x03A4, 0x0134, 6, 0x0000, 0, 0), + + MX7D_PAD_UART3_RX_DATA__UART3_DCE_RX = IOMUX_PAD(0x03A8, 0x0138, 0, 0x0704, 2, 0), + + MX7D_PAD_UART3_RX_DATA__UART3_DTE_TX = IOMUX_PAD(0x03A8, 0x0138, 0, 0x0000, 0, 0), + MX7D_PAD_UART3_RX_DATA__USB_OTG1_OC = IOMUX_PAD(0x03A8, 0x0138, 1, 0x072C, 0, 0), + MX7D_PAD_UART3_RX_DATA__SAI3_RX_SYNC = IOMUX_PAD(0x03A8, 0x0138, 2, 0x06CC, 0, 0), + MX7D_PAD_UART3_RX_DATA__ECSPI1_MISO = IOMUX_PAD(0x03A8, 0x0138, 3, 0x0528, 0, 0), + MX7D_PAD_UART3_RX_DATA__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x03A8, 0x0138, 4, 0x0000, 0, 0), + MX7D_PAD_UART3_RX_DATA__GPIO4_IO4 = IOMUX_PAD(0x03A8, 0x0138, 5, 0x0000, 0, 0), + MX7D_PAD_UART3_RX_DATA__SD1_LCTL = IOMUX_PAD(0x03A8, 0x0138, 6, 0x0000, 0, 0), + + MX7D_PAD_UART3_TX_DATA__UART3_DCE_TX = IOMUX_PAD(0x03AC, 0x013C, 0, 0x0000, 0, 0), + + MX7D_PAD_UART3_TX_DATA__UART3_DTE_RX = IOMUX_PAD(0x03AC, 0x013C, 0, 0x0704, 3, 0), + MX7D_PAD_UART3_TX_DATA__USB_OTG1_PWR = IOMUX_PAD(0x03AC, 0x013C, 1, 0x0000, 0, 0), + MX7D_PAD_UART3_TX_DATA__SAI3_TX_BCLK = IOMUX_PAD(0x03AC, 0x013C, 2, 0x06D0, 0, 0), + MX7D_PAD_UART3_TX_DATA__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x013C, 3, 0x052C, 0, 0), + MX7D_PAD_UART3_TX_DATA__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x03AC, 0x013C, 4, 0x0000, 0, 0), + MX7D_PAD_UART3_TX_DATA__GPIO4_IO5 = IOMUX_PAD(0x03AC, 0x013C, 5, 0x0000, 0, 0), + MX7D_PAD_UART3_TX_DATA__SD2_LCTL = IOMUX_PAD(0x03AC, 0x013C, 6, 0x0000, 0, 0), + + MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0), + + MX7D_PAD_UART3_RTS_B__UART3_DTE_CTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__USB_OTG2_OC = IOMUX_PAD(0x03B0, 0x0140, 1, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__SAI3_TX_DATA0 = IOMUX_PAD(0x03B0, 0x0140, 2, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__ECSPI1_SCLK = IOMUX_PAD(0x03B0, 0x0140, 3, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x03B0, 0x0140, 4, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__GPIO4_IO6 = IOMUX_PAD(0x03B0, 0x0140, 5, 0x0000, 0, 0), + MX7D_PAD_UART3_RTS_B__SD3_LCTL = IOMUX_PAD(0x03B0, 0x0140, 6, 0x0000, 0, 0), + + MX7D_PAD_UART3_CTS_B__UART3_DCE_CTS = IOMUX_PAD(0x03B4, 0x0144, 0, 0x0000, 0, 0), + + MX7D_PAD_UART3_CTS_B__UART3_DTE_RTS = IOMUX_PAD(0x03B4, 0x0144, 0, 0x0700, 3, 0), + MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR = IOMUX_PAD(0x03B4, 0x0144, 1, 0x0000, 0, 0), + MX7D_PAD_UART3_CTS_B__SAI3_TX_SYNC = IOMUX_PAD(0x03B4, 0x0144, 2, 0x06D4, 0, 0), + MX7D_PAD_UART3_CTS_B__ECSPI1_SS0 = IOMUX_PAD(0x03B4, 0x0144, 3, 0x0530, 0, 0), + MX7D_PAD_UART3_CTS_B__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x03B4, 0x0144, 4, 0x0000, 0, 0), + MX7D_PAD_UART3_CTS_B__GPIO4_IO7 = IOMUX_PAD(0x03B4, 0x0144, 5, 0x0000, 0, 0), + MX7D_PAD_UART3_CTS_B__SD1_VSELECT = IOMUX_PAD(0x03B4, 0x0144, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C1_SCL__I2C1_SCL = IOMUX_PAD(0x03B8, 0x0148, IOMUX_CONFIG_SION | 0, 0x05D4, 1, 0), + MX7D_PAD_I2C1_SCL__UART4_DCE_CTS = IOMUX_PAD(0x03B8, 0x0148, 1, 0x0000, 0, 0), + MX7D_PAD_I2C1_SCL__UART4_DTE_RTS = IOMUX_PAD(0x03B8, 0x0148, 1, 0x0708, 0, 0), + MX7D_PAD_I2C1_SCL__FLEXCAN1_RX = IOMUX_PAD(0x03B8, 0x0148, 2, 0x04DC, 1, 0), + MX7D_PAD_I2C1_SCL__ECSPI3_MISO = IOMUX_PAD(0x03B8, 0x0148, 3, 0x0548, 0, 0), + MX7D_PAD_I2C1_SCL__GPIO4_IO8 = IOMUX_PAD(0x03B8, 0x0148, 5, 0x0000, 0, 0), + MX7D_PAD_I2C1_SCL__SD2_VSELECT = IOMUX_PAD(0x03B8, 0x0148, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C1_SDA__I2C1_SDA = IOMUX_PAD(0x03BC, 0x014C, IOMUX_CONFIG_SION | 0, 0x05D8, 1, 0), + MX7D_PAD_I2C1_SDA__UART4_DCE_RTS = IOMUX_PAD(0x03BC, 0x014C, 1, 0x0708, 1, 0), + MX7D_PAD_I2C1_SDA__UART4_DTE_CTS = IOMUX_PAD(0x03BC, 0x014C, 1, 0x0000, 0, 0), + MX7D_PAD_I2C1_SDA__FLEXCAN1_TX = IOMUX_PAD(0x03BC, 0x014C, 2, 0x0000, 0, 0), + MX7D_PAD_I2C1_SDA__ECSPI3_MOSI = IOMUX_PAD(0x03BC, 0x014C, 3, 0x054C, 0, 0), + MX7D_PAD_I2C1_SDA__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x03BC, 0x014C, 4, 0x0564, 1, 0), + MX7D_PAD_I2C1_SDA__GPIO4_IO9 = IOMUX_PAD(0x03BC, 0x014C, 5, 0x0000, 0, 0), + MX7D_PAD_I2C1_SDA__SD3_VSELECT = IOMUX_PAD(0x03BC, 0x014C, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C2_SCL__I2C2_SCL = IOMUX_PAD(0x03C0, 0x0150, IOMUX_CONFIG_SION | 0, 0x05DC, 1, 0), + MX7D_PAD_I2C2_SCL__UART4_DCE_RX = IOMUX_PAD(0x03C0, 0x0150, 1, 0x070C, 0, 0), + MX7D_PAD_I2C2_SCL__UART4_DTE_TX = IOMUX_PAD(0x03C0, 0x0150, 1, 0x0000, 0, 0), + MX7D_PAD_I2C2_SCL__WDOG3_WDOG_B = IOMUX_PAD(0x03C0, 0x0150, 2, 0x0000, 0, 0), + MX7D_PAD_I2C2_SCL__ECSPI3_SCLK = IOMUX_PAD(0x03C0, 0x0150, 3, 0x0544, 0, 0), + MX7D_PAD_I2C2_SCL__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x03C0, 0x0150, 4, 0x0570, 2, 0), + MX7D_PAD_I2C2_SCL__GPIO4_IO10 = IOMUX_PAD(0x03C0, 0x0150, 5, 0x0000, 0, 0), + MX7D_PAD_I2C2_SCL__SD3_CD_B = IOMUX_PAD(0x03C0, 0x0150, 6, 0x0738, 1, 0), + + MX7D_PAD_I2C2_SDA__I2C2_SDA = IOMUX_PAD(0x03C4, 0x0154, IOMUX_CONFIG_SION | 0, 0x05E0, 1, 0), + MX7D_PAD_I2C2_SDA__UART4_DCE_TX = IOMUX_PAD(0x03C4, 0x0154, 1, 0x0000, 0, 0), + MX7D_PAD_I2C2_SDA__UART4_DTE_RX = IOMUX_PAD(0x03C4, 0x0154, 1, 0x070C, 1, 0), + MX7D_PAD_I2C2_SDA__WDOG3_WDOG_RST_B_DEB = IOMUX_PAD(0x03C4, 0x0154, 2, 0x0000, 0, 0), + MX7D_PAD_I2C2_SDA__ECSPI3_SS0 = IOMUX_PAD(0x03C4, 0x0154, 3, 0x0550, 0, 0), + MX7D_PAD_I2C2_SDA__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x03C4, 0x0154, 4, 0x0000, 0, 0), + MX7D_PAD_I2C2_SDA__GPIO4_IO11 = IOMUX_PAD(0x03C4, 0x0154, 5, 0x0000, 0, 0), + MX7D_PAD_I2C2_SDA__SD3_WP = IOMUX_PAD(0x03C4, 0x0154, 6, 0x073C, 1, 0), + + MX7D_PAD_I2C3_SCL__I2C3_SCL = IOMUX_PAD(0x03C8, 0x0158, IOMUX_CONFIG_SION | 0, 0x05E4, 2, 0), + MX7D_PAD_I2C3_SCL__UART5_DCE_CTS = IOMUX_PAD(0x03C8, 0x0158, 1, 0x0000, 0, 0), + MX7D_PAD_I2C3_SCL__UART5_DTE_RTS = IOMUX_PAD(0x03C8, 0x0158, 1, 0x0710, 0, 0), + MX7D_PAD_I2C3_SCL__FLEXCAN2_RX = IOMUX_PAD(0x03C8, 0x0158, 2, 0x04E0, 1, 0), + MX7D_PAD_I2C3_SCL__CSI_VSYNC = IOMUX_PAD(0x03C8, 0x0158, 3, 0x0520, 1, 0), + MX7D_PAD_I2C3_SCL__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03C8, 0x0158, 4, 0x06D8, 1, 0), + MX7D_PAD_I2C3_SCL__GPIO4_IO12 = IOMUX_PAD(0x03C8, 0x0158, 5, 0x0000, 0, 0), + MX7D_PAD_I2C3_SCL__EPDC_BDR0 = IOMUX_PAD(0x03C8, 0x0158, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C3_SDA__I2C3_SDA = IOMUX_PAD(0x03CC, 0x015C, IOMUX_CONFIG_SION | 0, 0x05E8, 2, 0), + MX7D_PAD_I2C3_SDA__UART5_DCE_RTS = IOMUX_PAD(0x03CC, 0x015C, 1, 0x0710, 1, 0), + MX7D_PAD_I2C3_SDA__UART5_DTE_CTS = IOMUX_PAD(0x03CC, 0x015C, 1, 0x0000, 0, 0), + MX7D_PAD_I2C3_SDA__FLEXCAN2_TX = IOMUX_PAD(0x03CC, 0x015C, 2, 0x0000, 0, 0), + MX7D_PAD_I2C3_SDA__CSI_HSYNC = IOMUX_PAD(0x03CC, 0x015C, 3, 0x0518, 1, 0), + MX7D_PAD_I2C3_SDA__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03CC, 0x015C, 4, 0x06DC, 1, 0), + MX7D_PAD_I2C3_SDA__GPIO4_IO13 = IOMUX_PAD(0x03CC, 0x015C, 5, 0x0000, 0, 0), + MX7D_PAD_I2C3_SDA__EPDC_BDR1 = IOMUX_PAD(0x03CC, 0x015C, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C4_SCL__I2C4_SCL = IOMUX_PAD(0x03D0, 0x0160, IOMUX_CONFIG_SION | 0, 0x05EC, 2, 0), + MX7D_PAD_I2C4_SCL__UART5_DCE_RX = IOMUX_PAD(0x03D0, 0x0160, 1, 0x0714, 0, 0), + MX7D_PAD_I2C4_SCL__UART5_DTE_TX = IOMUX_PAD(0x03D0, 0x0160, 1, 0x0000, 0, 0), + MX7D_PAD_I2C4_SCL__WDOG4_WDOG_B = IOMUX_PAD(0x03D0, 0x0160, 2, 0x0000, 0, 0), + MX7D_PAD_I2C4_SCL__CSI_PIXCLK = IOMUX_PAD(0x03D0, 0x0160, 3, 0x051C, 1, 0), + MX7D_PAD_I2C4_SCL__USB_OTG1_ID = IOMUX_PAD(0x03D0, 0x0160, 4, 0x0734, 1, 0), + MX7D_PAD_I2C4_SCL__GPIO4_IO14 = IOMUX_PAD(0x03D0, 0x0160, 5, 0x0000, 0, 0), + MX7D_PAD_I2C4_SCL__EPDC_VCOM0 = IOMUX_PAD(0x03D0, 0x0160, 6, 0x0000, 0, 0), + + MX7D_PAD_I2C4_SDA__I2C4_SDA = IOMUX_PAD(0x03D4, 0x0164, IOMUX_CONFIG_SION | 0, 0x05F0, 2, 0), + MX7D_PAD_I2C4_SDA__UART5_DCE_TX = IOMUX_PAD(0x03D4, 0x0164, 1, 0x0000, 0, 0), + MX7D_PAD_I2C4_SDA__UART5_DTE_RX = IOMUX_PAD(0x03D4, 0x0164, 1, 0x0714, 1, 0), + MX7D_PAD_I2C4_SDA__WDOG4_WDOG_RST_B_DEB = IOMUX_PAD(0x03D4, 0x0164, 2, 0x0000, 0, 0), + MX7D_PAD_I2C4_SDA__CSI_MCLK = IOMUX_PAD(0x03D4, 0x0164, 3, 0x0000, 0, 0), + MX7D_PAD_I2C4_SDA__USB_OTG2_ID = IOMUX_PAD(0x03D4, 0x0164, 4, 0x0730, 1, 0), + MX7D_PAD_I2C4_SDA__GPIO4_IO15 = IOMUX_PAD(0x03D4, 0x0164, 5, 0x0000, 0, 0), + MX7D_PAD_I2C4_SDA__EPDC_VCOM1 = IOMUX_PAD(0x03D4, 0x0164, 6, 0x0000, 0, 0), + + MX7D_PAD_ECSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x03D8, 0x0168, 0, 0x0524, 1, 0), + MX7D_PAD_ECSPI1_SCLK__UART6_DCE_RX = IOMUX_PAD(0x03D8, 0x0168, 1, 0x071C, 2, 0), + MX7D_PAD_ECSPI1_SCLK__UART6_DTE_TX = IOMUX_PAD(0x03D8, 0x0168, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SCLK__SD2_DATA4 = IOMUX_PAD(0x03D8, 0x0168, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SCLK__CSI_DATA2 = IOMUX_PAD(0x03D8, 0x0168, 3, 0x04F8, 1, 0), + MX7D_PAD_ECSPI1_SCLK__GPIO4_IO16 = IOMUX_PAD(0x03D8, 0x0168, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SCLK__EPDC_PWR_COM = IOMUX_PAD(0x03D8, 0x0168, 6, 0x0000, 0, 0), + + MX7D_PAD_ECSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x03DC, 0x016C, 0, 0x052C, 1, 0), + MX7D_PAD_ECSPI1_MOSI__UART6_DCE_TX = IOMUX_PAD(0x03DC, 0x016C, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MOSI__UART6_DTE_RX = IOMUX_PAD(0x03DC, 0x016C, 1, 0x071C, 3, 0), + MX7D_PAD_ECSPI1_MOSI__SD2_DATA5 = IOMUX_PAD(0x03DC, 0x016C, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MOSI__CSI_DATA3 = IOMUX_PAD(0x03DC, 0x016C, 3, 0x04FC, 1, 0), + MX7D_PAD_ECSPI1_MOSI__GPIO4_IO17 = IOMUX_PAD(0x03DC, 0x016C, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MOSI__EPDC_PWR_STAT = IOMUX_PAD(0x03DC, 0x016C, 6, 0x0580, 1, 0), + + MX7D_PAD_ECSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x03E0, 0x0170, 0, 0x0528, 1, 0), + MX7D_PAD_ECSPI1_MISO__UART6_DCE_RTS = IOMUX_PAD(0x03E0, 0x0170, 1, 0x0718, 2, 0), + MX7D_PAD_ECSPI1_MISO__UART6_DTE_CTS = IOMUX_PAD(0x03E0, 0x0170, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MISO__SD2_DATA6 = IOMUX_PAD(0x03E0, 0x0170, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MISO__CSI_DATA4 = IOMUX_PAD(0x03E0, 0x0170, 3, 0x0500, 1, 0), + MX7D_PAD_ECSPI1_MISO__GPIO4_IO18 = IOMUX_PAD(0x03E0, 0x0170, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_MISO__EPDC_PWR_IRQ = IOMUX_PAD(0x03E0, 0x0170, 6, 0x057C, 0, 0), + + MX7D_PAD_ECSPI1_SS0__ECSPI1_SS0 = IOMUX_PAD(0x03E4, 0x0174, 0, 0x0530, 1, 0), + MX7D_PAD_ECSPI1_SS0__UART6_DCE_CTS = IOMUX_PAD(0x03E4, 0x0174, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SS0__UART6_DTE_RTS = IOMUX_PAD(0x03E4, 0x0174, 1, 0x0718, 3, 0), + MX7D_PAD_ECSPI1_SS0__SD2_DATA7 = IOMUX_PAD(0x03E4, 0x0174, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SS0__CSI_DATA5 = IOMUX_PAD(0x03E4, 0x0174, 3, 0x0504, 1, 0), + MX7D_PAD_ECSPI1_SS0__GPIO4_IO19 = IOMUX_PAD(0x03E4, 0x0174, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI1_SS0__EPDC_PWR_CTRL3 = IOMUX_PAD(0x03E4, 0x0174, 6, 0x0000, 0, 0), + + MX7D_PAD_ECSPI2_SCLK__ECSPI2_SCLK = IOMUX_PAD(0x03E8, 0x0178, 0, 0x0534, 0, 0), + MX7D_PAD_ECSPI2_SCLK__UART7_DCE_RX = IOMUX_PAD(0x03E8, 0x0178, 1, 0x0724, 2, 0), + MX7D_PAD_ECSPI2_SCLK__UART7_DTE_TX = IOMUX_PAD(0x03E8, 0x0178, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SCLK__SD1_DATA4 = IOMUX_PAD(0x03E8, 0x0178, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SCLK__CSI_DATA6 = IOMUX_PAD(0x03E8, 0x0178, 3, 0x0508, 1, 0), + MX7D_PAD_ECSPI2_SCLK__LCD_DATA13 = IOMUX_PAD(0x03E8, 0x0178, 4, 0x066C, 2, 0), + MX7D_PAD_ECSPI2_SCLK__GPIO4_IO20 = IOMUX_PAD(0x03E8, 0x0178, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SCLK__EPDC_PWR_CTRL0 = IOMUX_PAD(0x03E8, 0x0178, 6, 0x0000, 0, 0), + + MX7D_PAD_ECSPI2_MOSI__ECSPI2_MOSI = IOMUX_PAD(0x03EC, 0x017C, 0, 0x053C, 0, 0), + MX7D_PAD_ECSPI2_MOSI__UART7_DCE_TX = IOMUX_PAD(0x03EC, 0x017C, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MOSI__UART7_DTE_RX = IOMUX_PAD(0x03EC, 0x017C, 1, 0x0724, 3, 0), + MX7D_PAD_ECSPI2_MOSI__SD1_DATA5 = IOMUX_PAD(0x03EC, 0x017C, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MOSI__CSI_DATA7 = IOMUX_PAD(0x03EC, 0x017C, 3, 0x050C, 1, 0), + MX7D_PAD_ECSPI2_MOSI__LCD_DATA14 = IOMUX_PAD(0x03EC, 0x017C, 4, 0x0670, 2, 0), + MX7D_PAD_ECSPI2_MOSI__GPIO4_IO21 = IOMUX_PAD(0x03EC, 0x017C, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MOSI__EPDC_PWR_CTRL1 = IOMUX_PAD(0x03EC, 0x017C, 6, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MISO__GPIO4_IO22 = IOMUX_PAD(0x03F0, 0x0180, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MISO__EPDC_PWR_CTRL2 = IOMUX_PAD(0x03F0, 0x0180, 6, 0x0000, 0, 0), + + MX7D_PAD_ECSPI2_MISO__ECSPI2_MISO = IOMUX_PAD(0x03F0, 0x0180, 0, 0x0538, 0, 0), + MX7D_PAD_ECSPI2_MISO__UART7_DCE_RTS = IOMUX_PAD(0x03F0, 0x0180, 1, 0x0720, 2, 0), + MX7D_PAD_ECSPI2_MISO__UART7_DTE_CTS = IOMUX_PAD(0x03F0, 0x0180, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MISO__SD1_DATA6 = IOMUX_PAD(0x03F0, 0x0180, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_MISO__CSI_DATA8 = IOMUX_PAD(0x03F0, 0x0180, 3, 0x0510, 1, 0), + MX7D_PAD_ECSPI2_MISO__LCD_DATA15 = IOMUX_PAD(0x03F0, 0x0180, 4, 0x0674, 2, 0), + + MX7D_PAD_ECSPI2_SS0__ECSPI2_SS0 = IOMUX_PAD(0x03F4, 0x0184, 0, 0x0540, 0, 0), + MX7D_PAD_ECSPI2_SS0__UART7_DCE_CTS = IOMUX_PAD(0x03F4, 0x0184, 1, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SS0__UART7_DTE_RTS = IOMUX_PAD(0x03F4, 0x0184, 1, 0x0720, 3, 0), + MX7D_PAD_ECSPI2_SS0__SD1_DATA7 = IOMUX_PAD(0x03F4, 0x0184, 2, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SS0__CSI_DATA9 = IOMUX_PAD(0x03F4, 0x0184, 3, 0x0514, 1, 0), + MX7D_PAD_ECSPI2_SS0__LCD_RESET = IOMUX_PAD(0x03F4, 0x0184, 4, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SS0__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x0184, 5, 0x0000, 0, 0), + MX7D_PAD_ECSPI2_SS0__EPDC_PWR_WAKE = IOMUX_PAD(0x03F4, 0x0184, 6, 0x0000, 0, 0), + + MX7D_PAD_SD1_CD_B__SD1_CD_B = IOMUX_PAD(0x03F8, 0x0188, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_CD_B__UART6_DCE_RX = IOMUX_PAD(0x03F8, 0x0188, 2, 0x071C, 4, 0), + MX7D_PAD_SD1_CD_B__UART6_DTE_TX = IOMUX_PAD(0x03F8, 0x0188, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_CD_B__ECSPI4_MISO = IOMUX_PAD(0x03F8, 0x0188, 3, 0x0558, 1, 0), + MX7D_PAD_SD1_CD_B__FLEXTIMER1_CH0 = IOMUX_PAD(0x03F8, 0x0188, 4, 0x0584, 1, 0), + MX7D_PAD_SD1_CD_B__GPIO5_IO0 = IOMUX_PAD(0x03F8, 0x0188, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_CD_B__CCM_CLKO1 = IOMUX_PAD(0x03F8, 0x0188, 6, 0x0000, 0, 0), + + MX7D_PAD_SD1_WP__SD1_WP = IOMUX_PAD(0x03FC, 0x018C, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_WP__UART6_DCE_TX = IOMUX_PAD(0x03FC, 0x018C, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_WP__UART6_DTE_RX = IOMUX_PAD(0x03FC, 0x018C, 2, 0x071C, 5, 0), + MX7D_PAD_SD1_WP__ECSPI4_MOSI = IOMUX_PAD(0x03FC, 0x018C, 3, 0x055C, 1, 0), + MX7D_PAD_SD1_WP__FLEXTIMER1_CH1 = IOMUX_PAD(0x03FC, 0x018C, 4, 0x0588, 1, 0), + MX7D_PAD_SD1_WP__GPIO5_IO1 = IOMUX_PAD(0x03FC, 0x018C, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_WP__CCM_CLKO2 = IOMUX_PAD(0x03FC, 0x018C, 6, 0x0000, 0, 0), + + MX7D_PAD_SD1_RESET_B__SD1_RESET_B = IOMUX_PAD(0x0400, 0x0190, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_RESET_B__SAI3_MCLK = IOMUX_PAD(0x0400, 0x0190, 1, 0x0000, 0, 0), + MX7D_PAD_SD1_RESET_B__UART6_DCE_RTS = IOMUX_PAD(0x0400, 0x0190, 2, 0x0718, 4, 0), + MX7D_PAD_SD1_RESET_B__UART6_DTE_CTS = IOMUX_PAD(0x0400, 0x0190, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_RESET_B__ECSPI4_SCLK = IOMUX_PAD(0x0400, 0x0190, 3, 0x0554, 1, 0), + MX7D_PAD_SD1_RESET_B__FLEXTIMER1_CH2 = IOMUX_PAD(0x0400, 0x0190, 4, 0x058C, 1, 0), + MX7D_PAD_SD1_RESET_B__GPIO5_IO2 = IOMUX_PAD(0x0400, 0x0190, 5, 0x0000, 0, 0), + + MX7D_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x0404, 0x0194, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_CLK__SAI3_RX_SYNC = IOMUX_PAD(0x0404, 0x0194, 1, 0x06CC, 1, 0), + MX7D_PAD_SD1_CLK__UART6_DCE_CTS = IOMUX_PAD(0x0404, 0x0194, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_CLK__UART6_DTE_RTS = IOMUX_PAD(0x0404, 0x0194, 2, 0x0718, 5, 0), + MX7D_PAD_SD1_CLK__ECSPI4_SS0 = IOMUX_PAD(0x0404, 0x0194, 3, 0x0560, 1, 0), + MX7D_PAD_SD1_CLK__FLEXTIMER1_CH3 = IOMUX_PAD(0x0404, 0x0194, 4, 0x0590, 1, 0), + MX7D_PAD_SD1_CLK__GPIO5_IO3 = IOMUX_PAD(0x0404, 0x0194, 5, 0x0000, 0, 0), + + MX7D_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x0408, 0x0198, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_CMD__SAI3_RX_BCLK = IOMUX_PAD(0x0408, 0x0198, 1, 0x06C4, 1, 0), + MX7D_PAD_SD1_CMD__ECSPI4_SS1 = IOMUX_PAD(0x0408, 0x0198, 3, 0x0000, 0, 0), + MX7D_PAD_SD1_CMD__FLEXTIMER2_CH0 = IOMUX_PAD(0x0408, 0x0198, 4, 0x05AC, 1, 0), + MX7D_PAD_SD1_CMD__GPIO5_IO4 = IOMUX_PAD(0x0408, 0x0198, 5, 0x0000, 0, 0), + + MX7D_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x040C, 0x019C, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA0__SAI3_RX_DATA0 = IOMUX_PAD(0x040C, 0x019C, 1, 0x06C8, 1, 0), + MX7D_PAD_SD1_DATA0__UART7_DCE_RX = IOMUX_PAD(0x040C, 0x019C, 2, 0x0724, 4, 0), + MX7D_PAD_SD1_DATA0__UART7_DTE_TX = IOMUX_PAD(0x040C, 0x019C, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA0__ECSPI4_SS2 = IOMUX_PAD(0x040C, 0x019C, 3, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA0__FLEXTIMER2_CH1 = IOMUX_PAD(0x040C, 0x019C, 4, 0x05B0, 1, 0), + MX7D_PAD_SD1_DATA0__GPIO5_IO5 = IOMUX_PAD(0x040C, 0x019C, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA0__CCM_EXT_CLK1 = IOMUX_PAD(0x040C, 0x019C, 6, 0x04E4, 1, 0), + + MX7D_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x0410, 0x01A0, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA1__SAI3_TX_BCLK = IOMUX_PAD(0x0410, 0x01A0, 1, 0x06D0, 1, 0), + MX7D_PAD_SD1_DATA1__UART7_DCE_TX = IOMUX_PAD(0x0410, 0x01A0, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA1__UART7_DTE_RX = IOMUX_PAD(0x0410, 0x01A0, 2, 0x0724, 5, 0), + MX7D_PAD_SD1_DATA1__ECSPI4_SS3 = IOMUX_PAD(0x0410, 0x01A0, 3, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA1__FLEXTIMER2_CH2 = IOMUX_PAD(0x0410, 0x01A0, 4, 0x05B4, 1, 0), + MX7D_PAD_SD1_DATA1__GPIO5_IO6 = IOMUX_PAD(0x0410, 0x01A0, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA1__CCM_EXT_CLK2 = IOMUX_PAD(0x0410, 0x01A0, 6, 0x04E8, 1, 0), + + MX7D_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x0414, 0x01A4, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA2__SAI3_TX_SYNC = IOMUX_PAD(0x0414, 0x01A4, 1, 0x06D4, 1, 0), + MX7D_PAD_SD1_DATA2__UART7_DCE_CTS = IOMUX_PAD(0x0414, 0x01A4, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA2__UART7_DTE_RTS = IOMUX_PAD(0x0414, 0x01A4, 2, 0x0720, 4, 0), + MX7D_PAD_SD1_DATA2__ECSPI4_RDY = IOMUX_PAD(0x0414, 0x01A4, 3, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA2__FLEXTIMER2_CH3 = IOMUX_PAD(0x0414, 0x01A4, 4, 0x05B8, 1, 0), + MX7D_PAD_SD1_DATA2__GPIO5_IO7 = IOMUX_PAD(0x0414, 0x01A4, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA2__CCM_EXT_CLK3 = IOMUX_PAD(0x0414, 0x01A4, 6, 0x04EC, 1, 0), + + MX7D_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x0418, 0x01A8, 0, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA3__SAI3_TX_DATA0 = IOMUX_PAD(0x0418, 0x01A8, 1, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA3__UART7_DCE_RTS = IOMUX_PAD(0x0418, 0x01A8, 2, 0x0720, 5, 0), + MX7D_PAD_SD1_DATA3__UART7_DTE_CTS = IOMUX_PAD(0x0418, 0x01A8, 2, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA3__ECSPI3_SS1 = IOMUX_PAD(0x0418, 0x01A8, 3, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA3__FLEXTIMER1_PHA = IOMUX_PAD(0x0418, 0x01A8, 4, 0x05A4, 1, 0), + MX7D_PAD_SD1_DATA3__GPIO5_IO8 = IOMUX_PAD(0x0418, 0x01A8, 5, 0x0000, 0, 0), + MX7D_PAD_SD1_DATA3__CCM_EXT_CLK4 = IOMUX_PAD(0x0418, 0x01A8, 6, 0x04F0, 1, 0), + + MX7D_PAD_SD2_CD_B__SD2_CD_B = IOMUX_PAD(0x041C, 0x01AC, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_CD_B__ENET1_MDIO = IOMUX_PAD(0x041C, 0x01AC, 1, 0x0568, 2, 0), + MX7D_PAD_SD2_CD_B__ENET2_MDIO = IOMUX_PAD(0x041C, 0x01AC, 2, 0x0574, 2, 0), + MX7D_PAD_SD2_CD_B__ECSPI3_SS2 = IOMUX_PAD(0x041C, 0x01AC, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_CD_B__FLEXTIMER1_PHB = IOMUX_PAD(0x041C, 0x01AC, 4, 0x05A8, 1, 0), + MX7D_PAD_SD2_CD_B__GPIO5_IO9 = IOMUX_PAD(0x041C, 0x01AC, 5, 0x0000, 0, 0), + MX7D_PAD_SD2_CD_B__SDMA_EXT_EVENT0 = IOMUX_PAD(0x041C, 0x01AC, 6, 0x06D8, 2, 0), + + MX7D_PAD_SD2_WP__SD2_WP = IOMUX_PAD(0x0420, 0x01B0, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_WP__ENET1_MDC = IOMUX_PAD(0x0420, 0x01B0, 1, 0x0000, 0, 0), + MX7D_PAD_SD2_WP__ENET2_MDC = IOMUX_PAD(0x0420, 0x01B0, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_WP__ECSPI3_SS3 = IOMUX_PAD(0x0420, 0x01B0, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_WP__USB_OTG1_ID = IOMUX_PAD(0x0420, 0x01B0, 4, 0x0734, 2, 0), + MX7D_PAD_SD2_WP__GPIO5_IO10 = IOMUX_PAD(0x0420, 0x01B0, 5, 0x0000, 0, 0), + MX7D_PAD_SD2_WP__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0420, 0x01B0, 6, 0x06DC, 2, 0), + + MX7D_PAD_SD2_RESET_B__SD2_RESET_B = IOMUX_PAD(0x0424, 0x01B4, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_RESET_B__SAI2_MCLK = IOMUX_PAD(0x0424, 0x01B4, 1, 0x0000, 0, 0), + MX7D_PAD_SD2_RESET_B__SD2_RESET = IOMUX_PAD(0x0424, 0x01B4, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_RESET_B__ECSPI3_RDY = IOMUX_PAD(0x0424, 0x01B4, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_RESET_B__USB_OTG2_ID = IOMUX_PAD(0x0424, 0x01B4, 4, 0x0730, 2, 0), + MX7D_PAD_SD2_RESET_B__GPIO5_IO11 = IOMUX_PAD(0x0424, 0x01B4, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x0428, 0x01B8, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_CLK__SAI2_RX_SYNC = IOMUX_PAD(0x0428, 0x01B8, 1, 0x06B8, 0, 0), + MX7D_PAD_SD2_CLK__MQS_RIGHT = IOMUX_PAD(0x0428, 0x01B8, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_CLK__GPT4_CLK = IOMUX_PAD(0x0428, 0x01B8, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_CLK__GPIO5_IO12 = IOMUX_PAD(0x0428, 0x01B8, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x042C, 0x01BC, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_CMD__SAI2_RX_BCLK = IOMUX_PAD(0x042C, 0x01BC, 1, 0x06B0, 0, 0), + MX7D_PAD_SD2_CMD__MQS_LEFT = IOMUX_PAD(0x042C, 0x01BC, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_CMD__GPT4_CAPTURE1 = IOMUX_PAD(0x042C, 0x01BC, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_CMD__SIM2_PORT1_TRXD = IOMUX_PAD(0x042C, 0x01BC, 4, 0x06EC, 1, 0), + MX7D_PAD_SD2_CMD__GPIO5_IO13 = IOMUX_PAD(0x042C, 0x01BC, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_DATA0__SD2_DATA0 = IOMUX_PAD(0x0430, 0x01C0, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA0__SAI2_RX_DATA0 = IOMUX_PAD(0x0430, 0x01C0, 1, 0x06B4, 0, 0), + MX7D_PAD_SD2_DATA0__UART4_DCE_RX = IOMUX_PAD(0x0430, 0x01C0, 2, 0x070C, 2, 0), + MX7D_PAD_SD2_DATA0__UART4_DTE_TX = IOMUX_PAD(0x0430, 0x01C0, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA0__GPT4_CAPTURE2 = IOMUX_PAD(0x0430, 0x01C0, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA0__SIM2_PORT1_CLK = IOMUX_PAD(0x0430, 0x01C0, 4, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA0__GPIO5_IO14 = IOMUX_PAD(0x0430, 0x01C0, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_DATA1__SD2_DATA1 = IOMUX_PAD(0x0434, 0x01C4, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA1__SAI2_TX_BCLK = IOMUX_PAD(0x0434, 0x01C4, 1, 0x06BC, 0, 0), + MX7D_PAD_SD2_DATA1__UART4_DCE_TX = IOMUX_PAD(0x0434, 0x01C4, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA1__UART4_DTE_RX = IOMUX_PAD(0x0434, 0x01C4, 2, 0x070C, 3, 0), + MX7D_PAD_SD2_DATA1__GPT4_COMPARE1 = IOMUX_PAD(0x0434, 0x01C4, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA1__SIM2_PORT1_RST_B = IOMUX_PAD(0x0434, 0x01C4, 4, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA1__GPIO5_IO15 = IOMUX_PAD(0x0434, 0x01C4, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_DATA2__SD2_DATA2 = IOMUX_PAD(0x0438, 0x01C8, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA2__SAI2_TX_SYNC = IOMUX_PAD(0x0438, 0x01C8, 1, 0x06C0, 0, 0), + MX7D_PAD_SD2_DATA2__UART4_DCE_CTS = IOMUX_PAD(0x0438, 0x01C8, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA2__UART4_DTE_RTS = IOMUX_PAD(0x0438, 0x01C8, 2, 0x0708, 2, 0), + MX7D_PAD_SD2_DATA2__GPT4_COMPARE2 = IOMUX_PAD(0x0438, 0x01C8, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA2__SIM2_PORT1_SVEN = IOMUX_PAD(0x0438, 0x01C8, 4, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA2__GPIO5_IO16 = IOMUX_PAD(0x0438, 0x01C8, 5, 0x0000, 0, 0), + + MX7D_PAD_SD2_DATA3__SD2_DATA3 = IOMUX_PAD(0x043C, 0x01CC, 0, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA3__SAI2_TX_DATA0 = IOMUX_PAD(0x043C, 0x01CC, 1, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA3__UART4_DCE_RTS = IOMUX_PAD(0x043C, 0x01CC, 2, 0x0708, 3, 0), + MX7D_PAD_SD2_DATA3__UART4_DTE_CTS = IOMUX_PAD(0x043C, 0x01CC, 2, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA3__GPT4_COMPARE3 = IOMUX_PAD(0x043C, 0x01CC, 3, 0x0000, 0, 0), + MX7D_PAD_SD2_DATA3__SIM2_PORT1_PD = IOMUX_PAD(0x043C, 0x01CC, 4, 0x06E8, 1, 0), + MX7D_PAD_SD2_DATA3__GPIO5_IO17 = IOMUX_PAD(0x043C, 0x01CC, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x0440, 0x01D0, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_CLK__NAND_CLE = IOMUX_PAD(0x0440, 0x01D0, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_CLK__ECSPI4_MISO = IOMUX_PAD(0x0440, 0x01D0, 2, 0x0558, 2, 0), + MX7D_PAD_SD3_CLK__SAI3_RX_SYNC = IOMUX_PAD(0x0440, 0x01D0, 3, 0x06CC, 2, 0), + MX7D_PAD_SD3_CLK__GPT3_CLK = IOMUX_PAD(0x0440, 0x01D0, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_CLK__GPIO6_IO0 = IOMUX_PAD(0x0440, 0x01D0, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x0444, 0x01D4, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_CMD__NAND_ALE = IOMUX_PAD(0x0444, 0x01D4, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_CMD__ECSPI4_MOSI = IOMUX_PAD(0x0444, 0x01D4, 2, 0x055C, 2, 0), + MX7D_PAD_SD3_CMD__SAI3_RX_BCLK = IOMUX_PAD(0x0444, 0x01D4, 3, 0x06C4, 2, 0), + MX7D_PAD_SD3_CMD__GPT3_CAPTURE1 = IOMUX_PAD(0x0444, 0x01D4, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_CMD__GPIO6_IO1 = IOMUX_PAD(0x0444, 0x01D4, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA0__SD3_DATA0 = IOMUX_PAD(0x0448, 0x01D8, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA0__NAND_DATA00 = IOMUX_PAD(0x0448, 0x01D8, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA0__ECSPI4_SS0 = IOMUX_PAD(0x0448, 0x01D8, 2, 0x0560, 2, 0), + MX7D_PAD_SD3_DATA0__SAI3_RX_DATA0 = IOMUX_PAD(0x0448, 0x01D8, 3, 0x06C8, 2, 0), + MX7D_PAD_SD3_DATA0__GPT3_CAPTURE2 = IOMUX_PAD(0x0448, 0x01D8, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA0__GPIO6_IO2 = IOMUX_PAD(0x0448, 0x01D8, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA1__SD3_DATA1 = IOMUX_PAD(0x044C, 0x01DC, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA1__NAND_DATA01 = IOMUX_PAD(0x044C, 0x01DC, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA1__ECSPI4_SCLK = IOMUX_PAD(0x044C, 0x01DC, 2, 0x0554, 2, 0), + MX7D_PAD_SD3_DATA1__SAI3_TX_BCLK = IOMUX_PAD(0x044C, 0x01DC, 3, 0x06D0, 2, 0), + MX7D_PAD_SD3_DATA1__GPT3_COMPARE1 = IOMUX_PAD(0x044C, 0x01DC, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA1__GPIO6_IO3 = IOMUX_PAD(0x044C, 0x01DC, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA2__SD3_DATA2 = IOMUX_PAD(0x0450, 0x01E0, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA2__NAND_DATA02 = IOMUX_PAD(0x0450, 0x01E0, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA2__I2C3_SDA = IOMUX_PAD(0x0450, 0x01E0, IOMUX_CONFIG_SION | 2, 0x05E8, 3, 0), + MX7D_PAD_SD3_DATA2__SAI3_TX_SYNC = IOMUX_PAD(0x0450, 0x01E0, 3, 0x06D4, 2, 0), + MX7D_PAD_SD3_DATA2__GPT3_COMPARE2 = IOMUX_PAD(0x0450, 0x01E0, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA2__GPIO6_IO4 = IOMUX_PAD(0x0450, 0x01E0, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA3__SD3_DATA3 = IOMUX_PAD(0x0454, 0x01E4, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA3__NAND_DATA03 = IOMUX_PAD(0x0454, 0x01E4, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA3__I2C3_SCL = IOMUX_PAD(0x0454, 0x01E4, IOMUX_CONFIG_SION | 2, 0x05E4, 3, 0), + MX7D_PAD_SD3_DATA3__SAI3_TX_DATA0 = IOMUX_PAD(0x0454, 0x01E4, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA3__GPT3_COMPARE3 = IOMUX_PAD(0x0454, 0x01E4, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA3__GPIO6_IO5 = IOMUX_PAD(0x0454, 0x01E4, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA4__SD3_DATA4 = IOMUX_PAD(0x0458, 0x01E8, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA4__NAND_DATA04 = IOMUX_PAD(0x0458, 0x01E8, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA4__UART3_DCE_RX = IOMUX_PAD(0x0458, 0x01E8, 3, 0x0704, 4, 0), + MX7D_PAD_SD3_DATA4__UART3_DTE_TX = IOMUX_PAD(0x0458, 0x01E8, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA4__FLEXCAN2_RX = IOMUX_PAD(0x0458, 0x01E8, 4, 0x04E0, 2, 0), + MX7D_PAD_SD3_DATA4__GPIO6_IO6 = IOMUX_PAD(0x0458, 0x01E8, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA5__SD3_DATA5 = IOMUX_PAD(0x045C, 0x01EC, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA5__NAND_DATA05 = IOMUX_PAD(0x045C, 0x01EC, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA5__UART3_DCE_TX = IOMUX_PAD(0x045C, 0x01EC, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA5__UART3_DTE_RX = IOMUX_PAD(0x045C, 0x01EC, 3, 0x0704, 5, 0), + MX7D_PAD_SD3_DATA5__FLEXCAN1_TX = IOMUX_PAD(0x045C, 0x01EC, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA5__GPIO6_IO7 = IOMUX_PAD(0x045C, 0x01EC, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA6__SD3_DATA6 = IOMUX_PAD(0x0460, 0x01F0, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA6__NAND_DATA06 = IOMUX_PAD(0x0460, 0x01F0, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA6__SD3_WP = IOMUX_PAD(0x0460, 0x01F0, 2, 0x073C, 2, 0), + MX7D_PAD_SD3_DATA6__UART3_DCE_RTS = IOMUX_PAD(0x0460, 0x01F0, 3, 0x0700, 4, 0), + MX7D_PAD_SD3_DATA6__UART3_DTE_CTS = IOMUX_PAD(0x0460, 0x01F0, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA6__FLEXCAN2_TX = IOMUX_PAD(0x0460, 0x01F0, 4, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA6__GPIO6_IO8 = IOMUX_PAD(0x0460, 0x01F0, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_DATA7__SD3_DATA7 = IOMUX_PAD(0x0464, 0x01F4, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA7__NAND_DATA07 = IOMUX_PAD(0x0464, 0x01F4, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA7__SD3_CD_B = IOMUX_PAD(0x0464, 0x01F4, 2, 0x0738, 2, 0), + MX7D_PAD_SD3_DATA7__UART3_DCE_CTS = IOMUX_PAD(0x0464, 0x01F4, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_DATA7__UART3_DTE_RTS = IOMUX_PAD(0x0464, 0x01F4, 3, 0x0700, 5, 0), + MX7D_PAD_SD3_DATA7__FLEXCAN1_RX = IOMUX_PAD(0x0464, 0x01F4, 4, 0x04DC, 2, 0), + MX7D_PAD_SD3_DATA7__GPIO6_IO9 = IOMUX_PAD(0x0464, 0x01F4, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_STROBE__SD3_STROBE = IOMUX_PAD(0x0468, 0x01F8, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_STROBE__NAND_RE_B = IOMUX_PAD(0x0468, 0x01F8, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_STROBE__GPIO6_IO10 = IOMUX_PAD(0x0468, 0x01F8, 5, 0x0000, 0, 0), + + MX7D_PAD_SD3_RESET_B__SD3_RESET_B = IOMUX_PAD(0x046C, 0x01FC, 0, 0x0000, 0, 0), + MX7D_PAD_SD3_RESET_B__NAND_WE_B = IOMUX_PAD(0x046C, 0x01FC, 1, 0x0000, 0, 0), + MX7D_PAD_SD3_RESET_B__SD3_RESET = IOMUX_PAD(0x046C, 0x01FC, 2, 0x0000, 0, 0), + MX7D_PAD_SD3_RESET_B__SAI3_MCLK = IOMUX_PAD(0x046C, 0x01FC, 3, 0x0000, 0, 0), + MX7D_PAD_SD3_RESET_B__GPIO6_IO11 = IOMUX_PAD(0x046C, 0x01FC, 5, 0x0000, 0, 0), + + MX7D_PAD_SAI1_RX_DATA__SAI1_RX_DATA0 = IOMUX_PAD(0x0470, 0x0200, 0, 0x06A0, 0, 0), + MX7D_PAD_SAI1_RX_DATA__NAND_CE1_B = IOMUX_PAD(0x0470, 0x0200, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_DATA__UART5_DCE_RX = IOMUX_PAD(0x0470, 0x0200, 2, 0x0714, 2, 0), + MX7D_PAD_SAI1_RX_DATA__UART5_DTE_TX = IOMUX_PAD(0x0470, 0x0200, 2, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_DATA__FLEXCAN1_RX = IOMUX_PAD(0x0470, 0x0200, 3, 0x04DC, 3, 0), + MX7D_PAD_SAI1_RX_DATA__SIM1_PORT1_TRXD = IOMUX_PAD(0x0470, 0x0200, 4, 0x06E4, 1, 0), + MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12 = IOMUX_PAD(0x0470, 0x0200, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_DATA__SRC_ANY_PU_RESET = IOMUX_PAD(0x0470, 0x0200, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_TX_BCLK__SAI1_TX_BCLK = IOMUX_PAD(0x0474, 0x0204, 0, 0x06A8, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B = IOMUX_PAD(0x0474, 0x0204, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__UART5_DCE_TX = IOMUX_PAD(0x0474, 0x0204, 2, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__UART5_DTE_RX = IOMUX_PAD(0x0474, 0x0204, 2, 0x0714, 3, 0), + MX7D_PAD_SAI1_TX_BCLK__FLEXCAN1_TX = IOMUX_PAD(0x0474, 0x0204, 3, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__SIM1_PORT1_CLK = IOMUX_PAD(0x0474, 0x0204, 4, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__GPIO6_IO13 = IOMUX_PAD(0x0474, 0x0204, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_BCLK__SRC_EARLY_RESET = IOMUX_PAD(0x0474, 0x0204, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_TX_SYNC__SAI1_TX_SYNC = IOMUX_PAD(0x0478, 0x0208, 0, 0x06AC, 0, 0), + MX7D_PAD_SAI1_TX_SYNC__NAND_DQS = IOMUX_PAD(0x0478, 0x0208, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_SYNC__UART5_DCE_CTS = IOMUX_PAD(0x0478, 0x0208, 2, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_SYNC__UART5_DTE_RTS = IOMUX_PAD(0x0478, 0x0208, 2, 0x0710, 2, 0), + MX7D_PAD_SAI1_TX_SYNC__FLEXCAN2_RX = IOMUX_PAD(0x0478, 0x0208, 3, 0x04E0, 3, 0), + MX7D_PAD_SAI1_TX_SYNC__SIM1_PORT1_RST_B = IOMUX_PAD(0x0478, 0x0208, 4, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_SYNC__GPIO6_IO14 = IOMUX_PAD(0x0478, 0x0208, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_SYNC__SRC_INT_BOOT = IOMUX_PAD(0x0478, 0x0208, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_TX_DATA__SAI1_TX_DATA0 = IOMUX_PAD(0x047C, 0x020C, 0, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__NAND_READY_B = IOMUX_PAD(0x047C, 0x020C, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__UART5_DCE_RTS = IOMUX_PAD(0x047C, 0x020C, 2, 0x0710, 3, 0), + MX7D_PAD_SAI1_TX_DATA__UART5_DTE_CTS = IOMUX_PAD(0x047C, 0x020C, 2, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__FLEXCAN2_TX = IOMUX_PAD(0x047C, 0x020C, 3, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__SIM1_PORT1_SVEN = IOMUX_PAD(0x047C, 0x020C, 4, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__GPIO6_IO15 = IOMUX_PAD(0x047C, 0x020C, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_TX_DATA__SRC_SYSTEM_RESET = IOMUX_PAD(0x047C, 0x020C, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_RX_SYNC__SAI1_RX_SYNC = IOMUX_PAD(0x0480, 0x0210, 0, 0x06A4, 0, 0), + MX7D_PAD_SAI1_RX_SYNC__NAND_CE2_B = IOMUX_PAD(0x0480, 0x0210, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_SYNC__SAI2_RX_SYNC = IOMUX_PAD(0x0480, 0x0210, 2, 0x06B8, 1, 0), + MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL = IOMUX_PAD(0x0480, 0x0210, IOMUX_CONFIG_SION | 3, 0x05EC, 3, 0), + MX7D_PAD_SAI1_RX_SYNC__SIM1_PORT1_PD = IOMUX_PAD(0x0480, 0x0210, 4, 0x06E0, 1, 0), + MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16 = IOMUX_PAD(0x0480, 0x0210, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_SYNC__MQS_RIGHT = IOMUX_PAD(0x0480, 0x0210, 6, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_SYNC__SRC_CA7_RESET_B0 = IOMUX_PAD(0x0480, 0x0210, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_RX_BCLK__SAI1_RX_BCLK = IOMUX_PAD(0x0484, 0x0214, 0, 0x069C, 0, 0), + MX7D_PAD_SAI1_RX_BCLK__NAND_CE3_B = IOMUX_PAD(0x0484, 0x0214, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_BCLK__SAI2_RX_BCLK = IOMUX_PAD(0x0484, 0x0214, 2, 0x06B0, 1, 0), + MX7D_PAD_SAI1_RX_BCLK__I2C4_SDA = IOMUX_PAD(0x0484, 0x0214, IOMUX_CONFIG_SION | 3, 0x05F0, 3, 0), + MX7D_PAD_SAI1_RX_BCLK__FLEXTIMER2_PHA = IOMUX_PAD(0x0484, 0x0214, 4, 0x05CC, 1, 0), + MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 = IOMUX_PAD(0x0484, 0x0214, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_BCLK__MQS_LEFT = IOMUX_PAD(0x0484, 0x0214, 6, 0x0000, 0, 0), + MX7D_PAD_SAI1_RX_BCLK__SRC_CA7_RESET_B1 = IOMUX_PAD(0x0484, 0x0214, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI1_MCLK__SAI1_MCLK = IOMUX_PAD(0x0488, 0x0218, 0, 0x0000, 0, 0), + MX7D_PAD_SAI1_MCLK__NAND_WP_B = IOMUX_PAD(0x0488, 0x0218, 1, 0x0000, 0, 0), + MX7D_PAD_SAI1_MCLK__SAI2_MCLK = IOMUX_PAD(0x0488, 0x0218, 2, 0x0000, 0, 0), + MX7D_PAD_SAI1_MCLK__CCM_PMIC_READY = IOMUX_PAD(0x0488, 0x0218, 3, 0x04F4, 3, 0), + MX7D_PAD_SAI1_MCLK__FLEXTIMER2_PHB = IOMUX_PAD(0x0488, 0x0218, 4, 0x05D0, 1, 0), + MX7D_PAD_SAI1_MCLK__GPIO6_IO18 = IOMUX_PAD(0x0488, 0x0218, 5, 0x0000, 0, 0), + MX7D_PAD_SAI1_MCLK__SRC_TESTER_ACK = IOMUX_PAD(0x0488, 0x0218, 7, 0x0000, 0, 0), + + MX7D_PAD_SAI2_TX_SYNC__SAI2_TX_SYNC = IOMUX_PAD(0x048C, 0x021C, 0, 0x06C0, 1, 0), + MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x021C, 1, 0x0548, 1, 0), + MX7D_PAD_SAI2_TX_SYNC__UART4_DCE_RX = IOMUX_PAD(0x048C, 0x021C, 2, 0x070C, 4, 0), + MX7D_PAD_SAI2_TX_SYNC__UART4_DTE_TX = IOMUX_PAD(0x048C, 0x021C, 2, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_SYNC__UART1_DCE_CTS = IOMUX_PAD(0x048C, 0x021C, 3, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_SYNC__UART1_DTE_RTS = IOMUX_PAD(0x048C, 0x021C, 3, 0x06F0, 0, 0), + MX7D_PAD_SAI2_TX_SYNC__FLEXTIMER2_CH4 = IOMUX_PAD(0x048C, 0x021C, 4, 0x05BC, 1, 0), + MX7D_PAD_SAI2_TX_SYNC__GPIO6_IO19 = IOMUX_PAD(0x048C, 0x021C, 5, 0x0000, 0, 0), + + MX7D_PAD_SAI2_TX_BCLK__SAI2_TX_BCLK = IOMUX_PAD(0x0490, 0x0220, 0, 0x06BC, 1, 0), + MX7D_PAD_SAI2_TX_BCLK__ECSPI3_MOSI = IOMUX_PAD(0x0490, 0x0220, 1, 0x054C, 1, 0), + MX7D_PAD_SAI2_TX_BCLK__UART4_DCE_TX = IOMUX_PAD(0x0490, 0x0220, 2, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_BCLK__UART4_DTE_RX = IOMUX_PAD(0x0490, 0x0220, 2, 0x070C, 5, 0), + MX7D_PAD_SAI2_TX_BCLK__UART1_DCE_RTS = IOMUX_PAD(0x0490, 0x0220, 3, 0x06F0, 1, 0), + MX7D_PAD_SAI2_TX_BCLK__UART1_DTE_CTS = IOMUX_PAD(0x0490, 0x0220, 3, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_BCLK__FLEXTIMER2_CH5 = IOMUX_PAD(0x0490, 0x0220, 4, 0x05C0, 1, 0), + MX7D_PAD_SAI2_TX_BCLK__GPIO6_IO20 = IOMUX_PAD(0x0490, 0x0220, 5, 0x0000, 0, 0), + + MX7D_PAD_SAI2_RX_DATA__SAI2_RX_DATA0 = IOMUX_PAD(0x0494, 0x0224, 0, 0x06B4, 1, 0), + MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK = IOMUX_PAD(0x0494, 0x0224, 1, 0x0544, 1, 0), + MX7D_PAD_SAI2_RX_DATA__UART4_DCE_CTS = IOMUX_PAD(0x0494, 0x0224, 2, 0x0000, 0, 0), + MX7D_PAD_SAI2_RX_DATA__UART4_DTE_RTS = IOMUX_PAD(0x0494, 0x0224, 2, 0x0708, 4, 0), + MX7D_PAD_SAI2_RX_DATA__UART2_DCE_CTS = IOMUX_PAD(0x0494, 0x0224, 3, 0x0000, 0, 0), + MX7D_PAD_SAI2_RX_DATA__UART2_DTE_RTS = IOMUX_PAD(0x0494, 0x0224, 3, 0x06F8, 2, 0), + MX7D_PAD_SAI2_RX_DATA__FLEXTIMER2_CH6 = IOMUX_PAD(0x0494, 0x0224, 4, 0x05C4, 1, 0), + MX7D_PAD_SAI2_RX_DATA__GPIO6_IO21 = IOMUX_PAD(0x0494, 0x0224, 5, 0x0000, 0, 0), + MX7D_PAD_SAI2_RX_DATA__KPP_COL7 = IOMUX_PAD(0x0494, 0x0224, 6, 0x0610, 1, 0), + + MX7D_PAD_SAI2_TX_DATA__SAI2_TX_DATA0 = IOMUX_PAD(0x0498, 0x0228, 0, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_DATA__ECSPI3_SS0 = IOMUX_PAD(0x0498, 0x0228, 1, 0x0550, 1, 0), + MX7D_PAD_SAI2_TX_DATA__UART4_DCE_RTS = IOMUX_PAD(0x0498, 0x0228, 2, 0x0708, 5, 0), + MX7D_PAD_SAI2_TX_DATA__UART4_DTE_CTS = IOMUX_PAD(0x0498, 0x0228, 2, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_DATA__UART2_DCE_RTS = IOMUX_PAD(0x0498, 0x0228, 3, 0x06F8, 3, 0), + MX7D_PAD_SAI2_TX_DATA__UART2_DTE_CTS = IOMUX_PAD(0x0498, 0x0228, 3, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_DATA__FLEXTIMER2_CH7 = IOMUX_PAD(0x0498, 0x0228, 4, 0x05C8, 1, 0), + MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 = IOMUX_PAD(0x0498, 0x0228, 5, 0x0000, 0, 0), + MX7D_PAD_SAI2_TX_DATA__KPP_ROW7 = IOMUX_PAD(0x0498, 0x0228, 6, 0x0630, 1, 0), + + MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 = IOMUX_PAD(0x049C, 0x022C, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD0__PWM1_OUT = IOMUX_PAD(0x049C, 0x022C, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD0__I2C3_SCL = IOMUX_PAD(0x049C, 0x022C, IOMUX_CONFIG_SION | 2, 0x05E4, 4, 0), + MX7D_PAD_ENET1_RGMII_RD0__UART1_DCE_CTS = IOMUX_PAD(0x049C, 0x022C, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD0__UART1_DTE_RTS = IOMUX_PAD(0x049C, 0x022C, 3, 0x06F0, 2, 0), + MX7D_PAD_ENET1_RGMII_RD0__EPDC_VCOM0 = IOMUX_PAD(0x049C, 0x022C, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD0__GPIO7_IO0 = IOMUX_PAD(0x049C, 0x022C, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD0__KPP_ROW3 = IOMUX_PAD(0x049C, 0x022C, 6, 0x0620, 1, 0), + + MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 = IOMUX_PAD(0x04A0, 0x0230, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD1__PWM2_OUT = IOMUX_PAD(0x04A0, 0x0230, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD1__I2C3_SDA = IOMUX_PAD(0x04A0, 0x0230, IOMUX_CONFIG_SION | 2, 0x05E8, 4, 0), + MX7D_PAD_ENET1_RGMII_RD1__UART1_DCE_RTS = IOMUX_PAD(0x04A0, 0x0230, 3, 0x06F0, 3, 0), + MX7D_PAD_ENET1_RGMII_RD1__UART1_DTE_CTS = IOMUX_PAD(0x04A0, 0x0230, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD1__EPDC_VCOM1 = IOMUX_PAD(0x04A0, 0x0230, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD1__GPIO7_IO1 = IOMUX_PAD(0x04A0, 0x0230, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD1__KPP_COL3 = IOMUX_PAD(0x04A0, 0x0230, 6, 0x0600, 1, 0), + + MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 = IOMUX_PAD(0x04A4, 0x0234, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD2__FLEXCAN1_RX = IOMUX_PAD(0x04A4, 0x0234, 1, 0x04DC, 4, 0), + MX7D_PAD_ENET1_RGMII_RD2__ECSPI2_SCLK = IOMUX_PAD(0x04A4, 0x0234, 2, 0x0534, 1, 0), + MX7D_PAD_ENET1_RGMII_RD2__UART1_DCE_RX = IOMUX_PAD(0x04A4, 0x0234, 3, 0x06F4, 2, 0), + MX7D_PAD_ENET1_RGMII_RD2__UART1_DTE_TX = IOMUX_PAD(0x04A4, 0x0234, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD2__EPDC_SDCE4 = IOMUX_PAD(0x04A4, 0x0234, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD2__GPIO7_IO2 = IOMUX_PAD(0x04A4, 0x0234, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD2__KPP_ROW2 = IOMUX_PAD(0x04A4, 0x0234, 6, 0x061C, 1, 0), + + MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 = IOMUX_PAD(0x04A8, 0x0238, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD3__FLEXCAN1_TX = IOMUX_PAD(0x04A8, 0x0238, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD3__ECSPI2_MOSI = IOMUX_PAD(0x04A8, 0x0238, 2, 0x053C, 1, 0), + MX7D_PAD_ENET1_RGMII_RD3__UART1_DCE_TX = IOMUX_PAD(0x04A8, 0x0238, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD3__UART1_DTE_RX = IOMUX_PAD(0x04A8, 0x0238, 3, 0x06F4, 3, 0), + MX7D_PAD_ENET1_RGMII_RD3__EPDC_SDCE5 = IOMUX_PAD(0x04A8, 0x0238, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD3__GPIO7_IO3 = IOMUX_PAD(0x04A8, 0x0238, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RD3__KPP_COL2 = IOMUX_PAD(0x04A8, 0x0238, 6, 0x05FC, 1, 0), + + MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL = IOMUX_PAD(0x04AC, 0x023C, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RX_CTL__ECSPI2_SS1 = IOMUX_PAD(0x04AC, 0x023C, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RX_CTL__EPDC_SDCE6 = IOMUX_PAD(0x04AC, 0x023C, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RX_CTL__GPIO7_IO4 = IOMUX_PAD(0x04AC, 0x023C, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RX_CTL__KPP_ROW1 = IOMUX_PAD(0x04AC, 0x023C, 6, 0x0618, 1, 0), + + MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC = IOMUX_PAD(0x04B0, 0x0240, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RXC__ENET1_RX_ER = IOMUX_PAD(0x04B0, 0x0240, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RXC__ECSPI2_SS2 = IOMUX_PAD(0x04B0, 0x0240, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RXC__EPDC_SDCE7 = IOMUX_PAD(0x04B0, 0x0240, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RXC__GPIO7_IO5 = IOMUX_PAD(0x04B0, 0x0240, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_RXC__KPP_COL1 = IOMUX_PAD(0x04B0, 0x0240, 6, 0x0000, 0, 0), + + MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 = IOMUX_PAD(0x04B4, 0x0244, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD0__PWM3_OUT = IOMUX_PAD(0x04B4, 0x0244, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD0__ECSPI2_SS3 = IOMUX_PAD(0x04B4, 0x0244, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD0__EPDC_SDCE8 = IOMUX_PAD(0x04B4, 0x0244, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD0__GPIO7_IO6 = IOMUX_PAD(0x04B4, 0x0244, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD0__KPP_ROW0 = IOMUX_PAD(0x04B4, 0x0244, 6, 0x0614, 1, 0), + + MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 = IOMUX_PAD(0x04B8, 0x0248, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD1__PWM4_OUT = IOMUX_PAD(0x04B8, 0x0248, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD1__ECSPI2_RDY = IOMUX_PAD(0x04B8, 0x0248, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD1__EPDC_SDCE9 = IOMUX_PAD(0x04B8, 0x0248, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD1__GPIO7_IO7 = IOMUX_PAD(0x04B8, 0x0248, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD1__KPP_COL0 = IOMUX_PAD(0x04B8, 0x0248, 6, 0x05F4, 1, 0), + + MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 = IOMUX_PAD(0x04BC, 0x024C, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD2__FLEXCAN2_RX = IOMUX_PAD(0x04BC, 0x024C, 1, 0x04E0, 4, 0), + MX7D_PAD_ENET1_RGMII_TD2__ECSPI2_MISO = IOMUX_PAD(0x04BC, 0x024C, 2, 0x0538, 1, 0), + MX7D_PAD_ENET1_RGMII_TD2__I2C4_SCL = IOMUX_PAD(0x04BC, 0x024C, IOMUX_CONFIG_SION | 3, 0x05EC, 4, 0), + MX7D_PAD_ENET1_RGMII_TD2__EPDC_SDOED = IOMUX_PAD(0x04BC, 0x024C, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD2__GPIO7_IO8 = IOMUX_PAD(0x04BC, 0x024C, 5, 0x0000, 0, 0), + + MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 = IOMUX_PAD(0x04C0, 0x0250, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD3__FLEXCAN2_TX = IOMUX_PAD(0x04C0, 0x0250, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD3__ECSPI2_SS0 = IOMUX_PAD(0x04C0, 0x0250, 2, 0x0540, 1, 0), + MX7D_PAD_ENET1_RGMII_TD3__I2C4_SDA = IOMUX_PAD(0x04C0, 0x0250, IOMUX_CONFIG_SION | 3, 0x05F0, 4, 0), + MX7D_PAD_ENET1_RGMII_TD3__EPDC_SDOEZ = IOMUX_PAD(0x04C0, 0x0250, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD3__GPIO7_IO9 = IOMUX_PAD(0x04C0, 0x0250, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TD3__CAAM_RNG_OSC_OBS = IOMUX_PAD(0x04C0, 0x0250, 7, 0x0000, 0, 0), + + MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL = IOMUX_PAD(0x04C4, 0x0254, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TX_CTL__SAI1_RX_SYNC = IOMUX_PAD(0x04C4, 0x0254, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TX_CTL__GPT2_COMPARE1 = IOMUX_PAD(0x04C4, 0x0254, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TX_CTL__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04C4, 0x0254, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TX_CTL__GPIO7_IO10 = IOMUX_PAD(0x04C4, 0x0254, 5, 0x0000, 0, 0), + + MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC = IOMUX_PAD(0x04C8, 0x0258, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TXC__ENET1_TX_ER = IOMUX_PAD(0x04C8, 0x0258, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TXC__SAI1_RX_BCLK = IOMUX_PAD(0x04C8, 0x0258, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TXC__GPT2_COMPARE2 = IOMUX_PAD(0x04C8, 0x0258, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TXC__EPDC_PWR_CTRL3 = IOMUX_PAD(0x04C8, 0x0258, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RGMII_TXC__GPIO7_IO11 = IOMUX_PAD(0x04C8, 0x0258, 5, 0x0000, 0, 0), + + MX7D_PAD_ENET1_TX_CLK__ENET1_TX_CLK = IOMUX_PAD(0x04CC, 0x025C, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_TX_CLK__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x04CC, 0x025C, 1, 0x0564, 2, 0), + MX7D_PAD_ENET1_TX_CLK__SAI1_RX_DATA0 = IOMUX_PAD(0x04CC, 0x025C, 2, 0x06A0, 1, 0), + MX7D_PAD_ENET1_TX_CLK__GPT2_COMPARE3 = IOMUX_PAD(0x04CC, 0x025C, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_TX_CLK__EPDC_PWR_IRQ = IOMUX_PAD(0x04CC, 0x025C, 4, 0x057C, 1, 0), + MX7D_PAD_ENET1_TX_CLK__GPIO7_IO12 = IOMUX_PAD(0x04CC, 0x025C, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_TX_CLK__CCM_EXT_CLK1 = IOMUX_PAD(0x04CC, 0x025C, 6, 0x04E4, 2, 0), + MX7D_PAD_ENET1_TX_CLK__CSU_ALARM_AUT0 = IOMUX_PAD(0x04CC, 0x025C, 7, 0x0000, 0, 0), + + MX7D_PAD_ENET1_RX_CLK__ENET1_RX_CLK = IOMUX_PAD(0x04D0, 0x0260, 0, 0x056C, 0, 0), + MX7D_PAD_ENET1_RX_CLK__WDOG2_WDOG_B = IOMUX_PAD(0x04D0, 0x0260, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_RX_CLK__SAI1_TX_BCLK = IOMUX_PAD(0x04D0, 0x0260, 2, 0x06A8, 1, 0), + MX7D_PAD_ENET1_RX_CLK__GPT2_CLK = IOMUX_PAD(0x04D0, 0x0260, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_RX_CLK__EPDC_PWR_WAKE = IOMUX_PAD(0x04D0, 0x0260, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_RX_CLK__GPIO7_IO13 = IOMUX_PAD(0x04D0, 0x0260, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_RX_CLK__CCM_EXT_CLK2 = IOMUX_PAD(0x04D0, 0x0260, 6, 0x04E8, 2, 0), + MX7D_PAD_ENET1_RX_CLK__CSU_ALARM_AUT1 = IOMUX_PAD(0x04D0, 0x0260, 7, 0x0000, 0, 0), + + MX7D_PAD_ENET1_CRS__ENET1_CRS = IOMUX_PAD(0x04D4, 0x0264, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_CRS__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x04D4, 0x0264, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_CRS__SAI1_TX_SYNC = IOMUX_PAD(0x04D4, 0x0264, 2, 0x06AC, 1, 0), + MX7D_PAD_ENET1_CRS__GPT2_CAPTURE1 = IOMUX_PAD(0x04D4, 0x0264, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_CRS__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04D4, 0x0264, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_CRS__GPIO7_IO14 = IOMUX_PAD(0x04D4, 0x0264, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_CRS__CCM_EXT_CLK3 = IOMUX_PAD(0x04D4, 0x0264, 6, 0x04EC, 2, 0), + MX7D_PAD_ENET1_CRS__CSU_ALARM_AUT2 = IOMUX_PAD(0x04D4, 0x0264, 7, 0x0000, 0, 0), + + MX7D_PAD_ENET1_COL__ENET1_COL = IOMUX_PAD(0x04D8, 0x0268, 0, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__WDOG1_WDOG_ANY = IOMUX_PAD(0x04D8, 0x0268, 1, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__SAI1_TX_DATA0 = IOMUX_PAD(0x04D8, 0x0268, 2, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__GPT2_CAPTURE2 = IOMUX_PAD(0x04D8, 0x0268, 3, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04D8, 0x0268, 4, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__GPIO7_IO15 = IOMUX_PAD(0x04D8, 0x0268, 5, 0x0000, 0, 0), + MX7D_PAD_ENET1_COL__CCM_EXT_CLK4 = IOMUX_PAD(0x04D8, 0x0268, 6, 0x04F0, 2, 0), + MX7D_PAD_ENET1_COL__CSU_INT_DEB = IOMUX_PAD(0x04D8, 0x0268, 7, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_IMX7D_PINS_H__ */ diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 2581019..5dd64f5 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -85,6 +85,36 @@ typedef u64 iomux_v3_cfg_t;
#define NO_PAD_CTRL (1 << 17)
+#ifdef CONFIG_MX7 + +#define IOMUX_LPSR_SEL_INPUT_OFS 0x70000 +#define IOMUX_CONFIG_LPSR 0x8 +#define MUX_MODE_LPSR ((iomux_v3_cfg_t)IOMUX_CONFIG_LPSR << \ + MUX_MODE_SHIFT) + +#define PAD_CTL_DSE_1P8V_140OHM (0x0<<0) +#define PAD_CTL_DSE_1P8V_35OHM (0x1<<0) +#define PAD_CTL_DSE_1P8V_70OHM (0x2<<0) +#define PAD_CTL_DSE_1P8V_23OHM (0x3<<0) + +#define PAD_CTL_DSE_3P3V_196OHM (0x0<<0) +#define PAD_CTL_DSE_3P3V_49OHM (0x1<<0) +#define PAD_CTL_DSE_3P3V_98OHM (0x2<<0) +#define PAD_CTL_DSE_3P3V_32OHM (0x3<<0) + +#define PAD_CTL_SRE_FAST (0 << 2) +#define PAD_CTL_SRE_SLOW (0x1 << 2) + +#define PAD_CTL_HYS (0x1 << 3) +#define PAD_CTL_PUE (0x1 << 4) + +#define PAD_CTL_PUS_PD100KOHM ((0x0 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU5KOHM ((0x1 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU47KOHM ((0x2 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU100KOHM ((0x3 << 5) | PAD_CTL_PUE) + +#else + #ifdef CONFIG_MX6
#define PAD_CTL_HYS (1 << 16) @@ -167,6 +197,8 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_SRE_SLOW (0 << 0) #define PAD_CTL_SRE_FAST (1 << 0)
+#endif + #define IOMUX_CONFIG_SION 0x10
#define GPIO_PIN_MASK 0x1f
Hi Adrian,
On 23/07/2015 00:24, Adrian Alonso wrote:
- Add imx7d support for iomux controller
- imx7d has two iomux controllers iomuxc (0x3033000) and iomuxc-lpsr (0x302C0000) each conroller provides control and mux mode pad registers but shares iomuxc input select register with iomuxc-lpsr IOMUX_CONFIG_LPSR flag is used to properly set daisy chain settings for iomuxc-lpsr pads.
- Since mx7d introduces LPSR IOMUX pins, add new base to IOMUX v3 driver for these LPSR pins.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Signed-off-by: Ye.Li B37916@freescale.com
Changes for V2:
- Update commit log information
Changes for V3: Resend
arch/arm/imx-common/iomux-v3.c | 20 +- arch/arm/include/asm/arch-mx7/mx7-pins.h | 19 + arch/arm/include/asm/arch-mx7/mx7d_pins.h | 1308 ++++++++++++++++++++++++++++ arch/arm/include/asm/imx-common/iomux-v3.h | 32 + 4 files changed, 1378 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx7/mx7-pins.h create mode 100644 arch/arm/include/asm/arch-mx7/mx7d_pins.h
diff --git a/arch/arm/imx-common/iomux-v3.c b/arch/arm/imx-common/iomux-v3.c index 7fb23dd..07e75a6 100644 --- a/arch/arm/imx-common/iomux-v3.c +++ b/arch/arm/imx-common/iomux-v3.c @@ -4,7 +4,7 @@
- Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH,
<armlinux@phytec.de>
- Copyright (C) 2004-2011 Freescale Semiconductor, Inc.
- Copyright (C) 2004-2015 Freescale Semiconductor, Inc.
We have already discussed about this point. After this file was merged into u-boot, a lot of commits changed it. That means that changes are not due only by Freescale employees, and I had already raise the issue that modifying the copyright can raise legal issues. I will not merge changes in copyright if I will not be absolutely certain that it does not create any conflicts.
*/ @@ -41,6 +41,18 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) } #endif
+#ifdef CONFIG_IOMUX_LPSR
Help me to understand. You say imx7 has two iomux. Ok, that means they can be set at the same time. Or not ? Then why should be decided at compile time and not at runtime ?
- u32 lpsr = (pad & MUX_MODE_LPSR) >> MUX_MODE_SHIFT;
- if (lpsr == IOMUX_CONFIG_LPSR) {
base = (void *)IOMUXC_LPSR_BASE_ADDR;
mux_mode &= ~IOMUX_CONFIG_LPSR;
/* set daisy chain sel_input */
if (sel_input_ofs)
sel_input_ofs += IOMUX_LPSR_SEL_INPUT_OFS;
- if (mux_ctrl_ofs) __raw_writel(mux_mode, base + mux_ctrl_ofs);
@@ -55,6 +67,12 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) if (!(pad_ctrl & NO_PAD_CTRL) && pad_ctrl_ofs) __raw_writel(pad_ctrl, base + pad_ctrl_ofs); #endif
base = (void *)IOMUXC_BASE_ADDR;
/* configures a list of pads within declared with IOMUX_PADS macro */ diff --git a/arch/arm/include/asm/arch-mx7/mx7-pins.h b/arch/arm/include/asm/arch-mx7/mx7-pins.h new file mode 100644 index 0000000..164c2be --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7-pins.h @@ -0,0 +1,19 @@ +/*
- Copyright (C) 2015 Freescale Semiconductor, Inc.
+#ifndef __ASM_ARCH_MX7_PINS_H__ +#define __ASM_ARCH_MX7_PINS_H__
+#include <asm/imx-common/iomux-v3.h>
+#if defined(CONFIG_MX7D) +#include "mx7d_pins.h" +#elif defined(CONFIG_MX7S) +#include "mx7s_pins.h" +#else +#error "Please select cpu" +#endif /* CONFIG_MX7D */
+#endif /*__ASM_ARCH_MX7_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx7/mx7d_pins.h b/arch/arm/include/asm/arch-mx7/mx7d_pins.h new file mode 100644 index 0000000..d8b4097 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7d_pins.h @@ -0,0 +1,1308 @@ +/*
+#ifndef __ASM_ARCH_IMX7D_PINS_H__ +#define __ASM_ARCH_IMX7D_PINS_H__
+enum {
- MX7D_PAD_GPIO1_IO00__GPIO1_IO0 = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO00__PWM4_OUT = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B = IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__GPIO1_IO1 = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__PWM1_OUT = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__SAI1_MCLK = IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__GPIO1_IO2 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__PWM2_OUT = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 2, 0x0564, 3, 0),
- MX7D_PAD_GPIO1_IO02__SAI2_MCLK = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__CCM_CLKO1 = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__USB_OTG1_ID = IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 7, 0x0734, 3, 0),
- MX7D_PAD_GPIO1_IO03__GPIO1_IO3 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__PWM3_OUT = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 2, 0x0570, 3, 0),
- MX7D_PAD_GPIO1_IO03__SAI3_MCLK = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__CCM_CLKO2 = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__USB_OTG2_ID = IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 7, 0x0730, 3, 0),
- MX7D_PAD_GPIO1_IO04__GPIO1_IO4 = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO04__USB_OTG1_OC = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 1, 0x072C, 1, 0),
- MX7D_PAD_GPIO1_IO04__FLEXTIMER_CH4 = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 2, 0x0594, 1, 0),
- MX7D_PAD_GPIO1_IO04__UART5_CTS_B = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 3, 0x0710, 4, 0),
- MX7D_PAD_GPIO1_IO04__I2C1_SCL = IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D4, 2, 0),
- MX7D_PAD_GPIO1_IO05__GPIO1_IO5 = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO05__FLEXTIMER1_CH5 = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 2, 0x0598, 1, 0),
- MX7D_PAD_GPIO1_IO05__UART5_RTS_B = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 3, 0x0710, 5, 0),
- MX7D_PAD_GPIO1_IO05__I2C1_SDA = IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D8, 2, 0),
- MX7D_PAD_GPIO1_IO06__GPIO1_IO6 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO06__USB_OTG2_OC = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 1, 0x0728, 1, 0),
- MX7D_PAD_GPIO1_IO06__FLEXTIMER1_CH6 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 2, 0x059C, 1, 0),
- MX7D_PAD_GPIO1_IO06__UART5_RX_DATA = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 3, 0x0714, 4, 0),
- MX7D_PAD_GPIO1_IO06__I2C2_SCL = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05DC, 2, 0),
- MX7D_PAD_GPIO1_IO06__CCM_WAIT = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO06__KPP_ROW4 = IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 6, 0x0624, 1, 0),
- MX7D_PAD_GPIO1_IO07__GPIO1_IO7 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__USB_OTG2_PWR = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__FLEXTIMER1_CH7 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 2, 0x05A0, 1, 0),
- MX7D_PAD_GPIO1_IO07__UART5_TX_DATA = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 3, 0x0714, 5, 0),
- MX7D_PAD_GPIO1_IO07__I2C2_SDA = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05E0, 2, 0),
- MX7D_PAD_GPIO1_IO07__CCM_STOP = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__KPP_COL4 = IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 6, 0x0604, 1, 0),
+enum {
- MX7D_PAD_GPIO1_IO08__GPIO1_IO8 = IOMUX_PAD(0x026C, 0x0014, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__SD1_VSELECT = IOMUX_PAD(0x026C, 0x0014, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__WDOG1_WDOG_B = IOMUX_PAD(0x026C, 0x0014, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__UART3_DCE_RX = IOMUX_PAD(0x026C, 0x0014, 3, 0x0704, 0, 0),
- MX7D_PAD_GPIO1_IO08__UART3_DTE_TX = IOMUX_PAD(0x026C, 0x0014, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__I2C3_SCL = IOMUX_PAD(0x026C, 0x0014, IOMUX_CONFIG_SION | 4, 0x05E4, 0, 0),
- MX7D_PAD_GPIO1_IO08__KPP_COL5 = IOMUX_PAD(0x026C, 0x0014, 6, 0x0608, 0, 0),
- MX7D_PAD_GPIO1_IO08__PWM1_OUT = IOMUX_PAD(0x026C, 0x0014, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__GPIO1_IO9 = IOMUX_PAD(0x0270, 0x0018, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__SD1_LCTL = IOMUX_PAD(0x0270, 0x0018, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x0270, 0x0018, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__UART3_DCE_TX = IOMUX_PAD(0x0270, 0x0018, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__UART3_DTE_RX = IOMUX_PAD(0x0270, 0x0018, 3, 0x0704, 1, 0),
- MX7D_PAD_GPIO1_IO09__I2C3_SDA = IOMUX_PAD(0x0270, 0x0018, IOMUX_CONFIG_SION | 4, 0x05E8, 0, 0),
- MX7D_PAD_GPIO1_IO09__CCM_PMIC_READY = IOMUX_PAD(0x0270, 0x0018, 5, 0x04F4, 0, 0),
- MX7D_PAD_GPIO1_IO09__KPP_ROW5 = IOMUX_PAD(0x0270, 0x0018, 6, 0x0628, 0, 0),
- MX7D_PAD_GPIO1_IO09__PWM2_OUT = IOMUX_PAD(0x0270, 0x0018, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__GPIO1_IO10 = IOMUX_PAD(0x0274, 0x001C, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__SD2_LCTL = IOMUX_PAD(0x0274, 0x001C, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__ENET1_MDIO = IOMUX_PAD(0x0274, 0x001C, 2, 0x0568, 0, 0),
- MX7D_PAD_GPIO1_IO10__UART3_DCE_RTS = IOMUX_PAD(0x0274, 0x001C, 3, 0x0700, 0, 0),
- MX7D_PAD_GPIO1_IO10__UART3_DTE_CTS = IOMUX_PAD(0x0274, 0x001C, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__I2C4_SCL = IOMUX_PAD(0x0274, 0x001C, IOMUX_CONFIG_SION | 4, 0x05EC, 0, 0),
- MX7D_PAD_GPIO1_IO10__FLEXTIMER1_PHA = IOMUX_PAD(0x0274, 0x001C, 5, 0x05A4, 0, 0),
- MX7D_PAD_GPIO1_IO10__KPP_COL6 = IOMUX_PAD(0x0274, 0x001C, 6, 0x060C, 0, 0),
- MX7D_PAD_GPIO1_IO10__PWM3_OUT = IOMUX_PAD(0x0274, 0x001C, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__GPIO1_IO11 = IOMUX_PAD(0x0278, 0x0020, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__SD3_LCTL = IOMUX_PAD(0x0278, 0x0020, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__ENET1_MDC = IOMUX_PAD(0x0278, 0x0020, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__UART3_DCE_CTS = IOMUX_PAD(0x0278, 0x0020, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__UART3_DTE_RTS = IOMUX_PAD(0x0278, 0x0020, 3, 0x0700, 1, 0),
- MX7D_PAD_GPIO1_IO11__I2C4_SDA = IOMUX_PAD(0x0278, 0x0020, IOMUX_CONFIG_SION | 4, 0x05F0, 0, 0),
- MX7D_PAD_GPIO1_IO11__FLEXTIMER1_PHB = IOMUX_PAD(0x0278, 0x0020, 5, 0x05A8, 0, 0),
- MX7D_PAD_GPIO1_IO11__KPP_ROW6 = IOMUX_PAD(0x0278, 0x0020, 6, 0x062C, 0, 0),
- MX7D_PAD_GPIO1_IO11__PWM4_OUT = IOMUX_PAD(0x0278, 0x0020, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__GPIO1_IO12 = IOMUX_PAD(0x027C, 0x0024, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__SD2_VSELECT = IOMUX_PAD(0x027C, 0x0024, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x027C, 0x0024, 2, 0x0564, 0, 0),
- MX7D_PAD_GPIO1_IO12__FLEXCAN1_RX = IOMUX_PAD(0x027C, 0x0024, 3, 0x04DC, 0, 0),
- MX7D_PAD_GPIO1_IO12__CM4_NMI = IOMUX_PAD(0x027C, 0x0024, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__CCM_EXT_CLK1 = IOMUX_PAD(0x027C, 0x0024, 5, 0x04E4, 0, 0),
- MX7D_PAD_GPIO1_IO12__SNVS_VIO_5 = IOMUX_PAD(0x027C, 0x0024, 6, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__USB_OTG1_ID = IOMUX_PAD(0x027C, 0x0024, 7, 0x0734, 0, 0),
- MX7D_PAD_GPIO1_IO13__GPIO1_IO13 = IOMUX_PAD(0x0280, 0x0028, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__SD3_VSELECT = IOMUX_PAD(0x0280, 0x0028, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x0280, 0x0028, 2, 0x0570, 0, 0),
- MX7D_PAD_GPIO1_IO13__FLEXCAN1_TX = IOMUX_PAD(0x0280, 0x0028, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__CCM_PMIC_READY = IOMUX_PAD(0x0280, 0x0028, 4, 0x04F4, 1, 0),
- MX7D_PAD_GPIO1_IO13__CCM_EXT_CLK2 = IOMUX_PAD(0x0280, 0x0028, 5, 0x04E8, 0, 0),
- MX7D_PAD_GPIO1_IO13__SNVS_VIO_5_CTL = IOMUX_PAD(0x0280, 0x0028, 6, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__USB_OTG2_ID = IOMUX_PAD(0x0280, 0x0028, 7, 0x0730, 0, 0),
- MX7D_PAD_GPIO1_IO14__GPIO1_IO14 = IOMUX_PAD(0x0284, 0x002C, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO14__SD3_CD_B = IOMUX_PAD(0x0284, 0x002C, 1, 0x0738, 0, 0),
- MX7D_PAD_GPIO1_IO14__ENET2_MDIO = IOMUX_PAD(0x0284, 0x002C, 2, 0x0574, 0, 0),
- MX7D_PAD_GPIO1_IO14__FLEXCAN2_RX = IOMUX_PAD(0x0284, 0x002C, 3, 0x04E0, 0, 0),
- MX7D_PAD_GPIO1_IO14__WDOG3_WDOG_B = IOMUX_PAD(0x0284, 0x002C, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO14__CCM_EXT_CLK3 = IOMUX_PAD(0x0284, 0x002C, 5, 0x04EC, 0, 0),
- MX7D_PAD_GPIO1_IO14__SDMA_EXT_EVENT0 = IOMUX_PAD(0x0284, 0x002C, 6, 0x06D8, 0, 0),
- MX7D_PAD_GPIO1_IO15__GPIO1_IO15 = IOMUX_PAD(0x0288, 0x0030, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__SD3_WP = IOMUX_PAD(0x0288, 0x0030, 1, 0x073C, 0, 0),
- MX7D_PAD_GPIO1_IO15__ENET2_MDC = IOMUX_PAD(0x0288, 0x0030, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__FLEXCAN2_TX = IOMUX_PAD(0x0288, 0x0030, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__WDOG4_WDOG_B = IOMUX_PAD(0x0288, 0x0030, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__CCM_EXT_CLK4 = IOMUX_PAD(0x0288, 0x0030, 5, 0x04F0, 0, 0),
- MX7D_PAD_GPIO1_IO15__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0288, 0x0030, 6, 0x06DC, 0, 0),
- MX7D_PAD_EPDC_DATA00__EPDC_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__SIM1_PORT2_TRXD = IOMUX_PAD(0x02A4, 0x0034, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__KPP_ROW3 = IOMUX_PAD(0x02A4, 0x0034, 3, 0x0620, 0, 0),
- MX7D_PAD_EPDC_DATA00__EIM_AD0 = IOMUX_PAD(0x02A4, 0x0034, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__GPIO2_IO0 = IOMUX_PAD(0x02A4, 0x0034, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__LCD_DATA0 = IOMUX_PAD(0x02A4, 0x0034, 6, 0x0638, 0, 0),
- MX7D_PAD_EPDC_DATA00__LCD_CLK = IOMUX_PAD(0x02A4, 0x0034, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__EPDC_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__SIM1_PORT2_CLK = IOMUX_PAD(0x02A8, 0x0038, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__KPP_COL3 = IOMUX_PAD(0x02A8, 0x0038, 3, 0x0600, 0, 0),
- MX7D_PAD_EPDC_DATA01__EIM_AD1 = IOMUX_PAD(0x02A8, 0x0038, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__GPIO2_IO1 = IOMUX_PAD(0x02A8, 0x0038, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__LCD_DATA1 = IOMUX_PAD(0x02A8, 0x0038, 6, 0x063C, 0, 0),
- MX7D_PAD_EPDC_DATA01__LCD_ENABLE = IOMUX_PAD(0x02A8, 0x0038, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__EPDC_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__SIM1_PORT2_RST_B = IOMUX_PAD(0x02AC, 0x003C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__KPP_ROW2 = IOMUX_PAD(0x02AC, 0x003C, 3, 0x061C, 0, 0),
- MX7D_PAD_EPDC_DATA02__EIM_AD2 = IOMUX_PAD(0x02AC, 0x003C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__GPIO2_IO2 = IOMUX_PAD(0x02AC, 0x003C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__LCD_DATA2 = IOMUX_PAD(0x02AC, 0x003C, 6, 0x0640, 0, 0),
- MX7D_PAD_EPDC_DATA02__LCD_VSYNC = IOMUX_PAD(0x02AC, 0x003C, 7, 0x0698, 0, 0),
- MX7D_PAD_EPDC_DATA03__EPDC_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__SIM1_PORT2_SVEN = IOMUX_PAD(0x02B0, 0x0040, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__KPP_COL2 = IOMUX_PAD(0x02B0, 0x0040, 3, 0x05FC, 0, 0),
- MX7D_PAD_EPDC_DATA03__EIM_AD3 = IOMUX_PAD(0x02B0, 0x0040, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__GPIO2_IO3 = IOMUX_PAD(0x02B0, 0x0040, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__LCD_DATA3 = IOMUX_PAD(0x02B0, 0x0040, 6, 0x0644, 0, 0),
- MX7D_PAD_EPDC_DATA03__LCD_HSYNC = IOMUX_PAD(0x02B0, 0x0040, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__EPDC_DATA4 = IOMUX_PAD(0x02B4, 0x0044, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__SIM1_PORT2_PD = IOMUX_PAD(0x02B4, 0x0044, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__QSPI_A_DQS = IOMUX_PAD(0x02B4, 0x0044, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__KPP_ROW1 = IOMUX_PAD(0x02B4, 0x0044, 3, 0x0618, 0, 0),
- MX7D_PAD_EPDC_DATA04__EIM_AD4 = IOMUX_PAD(0x02B4, 0x0044, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__GPIO2_IO4 = IOMUX_PAD(0x02B4, 0x0044, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__LCD_DATA4 = IOMUX_PAD(0x02B4, 0x0044, 6, 0x0648, 0, 0),
- MX7D_PAD_EPDC_DATA04__JTAG_FAIL = IOMUX_PAD(0x02B4, 0x0044, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__EPDC_DATA5 = IOMUX_PAD(0x02B8, 0x0048, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__SIM2_PORT2_TRXD = IOMUX_PAD(0x02B8, 0x0048, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK = IOMUX_PAD(0x02B8, 0x0048, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__KPP_COL1 = IOMUX_PAD(0x02B8, 0x0048, 3, 0x05F8, 0, 0),
- MX7D_PAD_EPDC_DATA05__EIM_AD5 = IOMUX_PAD(0x02B8, 0x0048, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__GPIO2_IO5 = IOMUX_PAD(0x02B8, 0x0048, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__LCD_DATA5 = IOMUX_PAD(0x02B8, 0x0048, 6, 0x064C, 0, 0),
- MX7D_PAD_EPDC_DATA05__JTAG_ACTIVE = IOMUX_PAD(0x02B8, 0x0048, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__EPDC_DATA6 = IOMUX_PAD(0x02BC, 0x004C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__SIM2_PORT2_CLK = IOMUX_PAD(0x02BC, 0x004C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B = IOMUX_PAD(0x02BC, 0x004C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__KPP_ROW0 = IOMUX_PAD(0x02BC, 0x004C, 3, 0x0614, 0, 0),
- MX7D_PAD_EPDC_DATA06__EIM_AD6 = IOMUX_PAD(0x02BC, 0x004C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__GPIO2_IO6 = IOMUX_PAD(0x02BC, 0x004C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__LCD_DATA6 = IOMUX_PAD(0x02BC, 0x004C, 6, 0x0650, 0, 0),
- MX7D_PAD_EPDC_DATA06__JTAG_DE_B = IOMUX_PAD(0x02BC, 0x004C, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__EPDC_DATA7 = IOMUX_PAD(0x02C0, 0x0050, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__SIM2_PORT2_RST_B = IOMUX_PAD(0x02C0, 0x0050, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__QSPI_A_SS1_B = IOMUX_PAD(0x02C0, 0x0050, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__KPP_COL0 = IOMUX_PAD(0x02C0, 0x0050, 3, 0x05F4, 0, 0),
- MX7D_PAD_EPDC_DATA07__EIM_AD7 = IOMUX_PAD(0x02C0, 0x0050, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__GPIO2_IO7 = IOMUX_PAD(0x02C0, 0x0050, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__LCD_DATA7 = IOMUX_PAD(0x02C0, 0x0050, 6, 0x0654, 0, 0),
- MX7D_PAD_EPDC_DATA07__JTAG_DONE = IOMUX_PAD(0x02C0, 0x0050, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__EPDC_DATA8 = IOMUX_PAD(0x02C4, 0x0054, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__SIM1_PORT1_TRXD = IOMUX_PAD(0x02C4, 0x0054, 1, 0x06E4, 0, 0),
- MX7D_PAD_EPDC_DATA08__QSPI_B_DATA0 = IOMUX_PAD(0x02C4, 0x0054, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__UART6_DCE_RX = IOMUX_PAD(0x02C4, 0x0054, 3, 0x071C, 0, 0),
- MX7D_PAD_EPDC_DATA08__UART6_DTE_TX = IOMUX_PAD(0x02C4, 0x0054, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__EIM_OE = IOMUX_PAD(0x02C4, 0x0054, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__GPIO2_IO8 = IOMUX_PAD(0x02C4, 0x0054, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__LCD_DATA8 = IOMUX_PAD(0x02C4, 0x0054, 6, 0x0658, 0, 0),
- MX7D_PAD_EPDC_DATA08__LCD_BUSY = IOMUX_PAD(0x02C4, 0x0054, 7, 0x0634, 0, 0),
- MX7D_PAD_EPDC_DATA08__EPDC_SDCLK = IOMUX_PAD(0x02C4, 0x0054, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__EPDC_DATA9 = IOMUX_PAD(0x02C8, 0x0058, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__SIM1_PORT1_CLK = IOMUX_PAD(0x02C8, 0x0058, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__QSPI_B_DATA1 = IOMUX_PAD(0x02C8, 0x0058, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__UART6_DCE_TX = IOMUX_PAD(0x02C8, 0x0058, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__UART6_DTE_RX = IOMUX_PAD(0x02C8, 0x0058, 3, 0x071C, 1, 0),
- MX7D_PAD_EPDC_DATA09__EIM_RW = IOMUX_PAD(0x02C8, 0x0058, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__GPIO2_IO9 = IOMUX_PAD(0x02C8, 0x0058, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__LCD_DATA9 = IOMUX_PAD(0x02C8, 0x0058, 6, 0x065C, 0, 0),
- MX7D_PAD_EPDC_DATA09__LCD_DATA0 = IOMUX_PAD(0x02C8, 0x0058, 7, 0x0638, 1, 0),
- MX7D_PAD_EPDC_DATA09__EPDC_SDLE = IOMUX_PAD(0x02C8, 0x0058, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__EPDC_DATA10 = IOMUX_PAD(0x02CC, 0x005C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__SIM1_PORT1_RST_B = IOMUX_PAD(0x02CC, 0x005C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__QSPI_B_DATA2 = IOMUX_PAD(0x02CC, 0x005C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__UART6_DCE_RTS = IOMUX_PAD(0x02CC, 0x005C, 3, 0x0718, 0, 0),
- MX7D_PAD_EPDC_DATA10__UART6_DTE_CTS = IOMUX_PAD(0x02CC, 0x005C, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__EIM_CS0_B = IOMUX_PAD(0x02CC, 0x005C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__GPIO2_IO10 = IOMUX_PAD(0x02CC, 0x005C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__LCD_DATA10 = IOMUX_PAD(0x02CC, 0x005C, 6, 0x0660, 0, 0),
- MX7D_PAD_EPDC_DATA10__LCD_DATA9 = IOMUX_PAD(0x02CC, 0x005C, 7, 0x065C, 1, 0),
- MX7D_PAD_EPDC_DATA10__EPDC_SDOE = IOMUX_PAD(0x02CC, 0x005C, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__EPDC_DATA11 = IOMUX_PAD(0x02D0, 0x0060, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__SIM1_PORT1_SVEN = IOMUX_PAD(0x02D0, 0x0060, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__QSPI_B_DATA3 = IOMUX_PAD(0x02D0, 0x0060, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__UART6_DCE_CTS = IOMUX_PAD(0x02D0, 0x0060, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__UART6_DTE_RTS = IOMUX_PAD(0x02D0, 0x0060, 3, 0x0718, 1, 0),
- MX7D_PAD_EPDC_DATA11__EIM_BCLK = IOMUX_PAD(0x02D0, 0x0060, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__GPIO2_IO11 = IOMUX_PAD(0x02D0, 0x0060, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__LCD_DATA11 = IOMUX_PAD(0x02D0, 0x0060, 6, 0x0664, 0, 0),
- MX7D_PAD_EPDC_DATA11__LCD_DATA1 = IOMUX_PAD(0x02D0, 0x0060, 7, 0x063C, 1, 0),
- MX7D_PAD_EPDC_DATA11__EPDC_SDCE0 = IOMUX_PAD(0x02D0, 0x0060, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__EPDC_DATA12 = IOMUX_PAD(0x02D4, 0x0064, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__SIM1_PORT1_PD = IOMUX_PAD(0x02D4, 0x0064, 1, 0x06E0, 0, 0),
- MX7D_PAD_EPDC_DATA12__QSPI_B_DQS = IOMUX_PAD(0x02D4, 0x0064, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__UART7_DCE_RX = IOMUX_PAD(0x02D4, 0x0064, 3, 0x0724, 0, 0),
- MX7D_PAD_EPDC_DATA12__UART7_DTE_TX = IOMUX_PAD(0x02D4, 0x0064, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__EIM_LBA_B = IOMUX_PAD(0x02D4, 0x0064, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__GPIO2_IO12 = IOMUX_PAD(0x02D4, 0x0064, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__LCD_DATA12 = IOMUX_PAD(0x02D4, 0x0064, 6, 0x0668, 0, 0),
- MX7D_PAD_EPDC_DATA12__LCD_DATA21 = IOMUX_PAD(0x02D4, 0x0064, 7, 0x068C, 0, 0),
- MX7D_PAD_EPDC_DATA12__EPDC_GDCLK = IOMUX_PAD(0x02D4, 0x0064, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__EPDC_DATA13 = IOMUX_PAD(0x02D8, 0x0068, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__SIM2_PORT1_TRXD = IOMUX_PAD(0x02D8, 0x0068, 1, 0x06EC, 0, 0),
- MX7D_PAD_EPDC_DATA13__QSPI_B_SCLK = IOMUX_PAD(0x02D8, 0x0068, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__UART7_DCE_TX = IOMUX_PAD(0x02D8, 0x0068, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__UART7_DTE_RX = IOMUX_PAD(0x02D8, 0x0068, 3, 0x0724, 1, 0),
- MX7D_PAD_EPDC_DATA13__EIM_WAIT = IOMUX_PAD(0x02D8, 0x0068, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__GPIO2_IO13 = IOMUX_PAD(0x02D8, 0x0068, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__LCD_DATA13 = IOMUX_PAD(0x02D8, 0x0068, 6, 0x066C, 0, 0),
- MX7D_PAD_EPDC_DATA13__LCD_CS = IOMUX_PAD(0x02D8, 0x0068, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__EPDC_GDOE = IOMUX_PAD(0x02D8, 0x0068, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__EPDC_DATA14 = IOMUX_PAD(0x02DC, 0x006C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__SIM2_PORT1_CLK = IOMUX_PAD(0x02DC, 0x006C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__QSPI_B_SS0_B = IOMUX_PAD(0x02DC, 0x006C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__UART7_DCE_RTS = IOMUX_PAD(0x02DC, 0x006C, 3, 0x0720, 0, 0),
- MX7D_PAD_EPDC_DATA14__UART7_DTE_CTS = IOMUX_PAD(0x02DC, 0x006C, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__EIM_EB_B0 = IOMUX_PAD(0x02DC, 0x006C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__GPIO2_IO14 = IOMUX_PAD(0x02DC, 0x006C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__LCD_DATA14 = IOMUX_PAD(0x02DC, 0x006C, 6, 0x0670, 0, 0),
- MX7D_PAD_EPDC_DATA14__LCD_DATA22 = IOMUX_PAD(0x02DC, 0x006C, 7, 0x0690, 0, 0),
- MX7D_PAD_EPDC_DATA14__EPDC_GDSP = IOMUX_PAD(0x02DC, 0x006C, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__EPDC_DATA15 = IOMUX_PAD(0x02E0, 0x0070, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__SIM2_PORT1_RST_B = IOMUX_PAD(0x02E0, 0x0070, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__QSPI_B_SS1_B = IOMUX_PAD(0x02E0, 0x0070, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__UART7_DCE_CTS = IOMUX_PAD(0x02E0, 0x0070, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__UART7_DTE_RTS = IOMUX_PAD(0x02E0, 0x0070, 3, 0x0720, 1, 0),
- MX7D_PAD_EPDC_DATA15__EIM_CS1_B = IOMUX_PAD(0x02E0, 0x0070, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__GPIO2_IO15 = IOMUX_PAD(0x02E0, 0x0070, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__LCD_DATA15 = IOMUX_PAD(0x02E0, 0x0070, 6, 0x0674, 0, 0),
- MX7D_PAD_EPDC_DATA15__LCD_WR_RWN = IOMUX_PAD(0x02E0, 0x0070, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__EPDC_PWR_COM = IOMUX_PAD(0x02E0, 0x0070, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__EPDC_SDCLK = IOMUX_PAD(0x02E4, 0x0074, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__SIM2_PORT2_SVEN = IOMUX_PAD(0x02E4, 0x0074, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 = IOMUX_PAD(0x02E4, 0x0074, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__KPP_ROW4 = IOMUX_PAD(0x02E4, 0x0074, 3, 0x0624, 0, 0),
- MX7D_PAD_EPDC_SDCLK__EIM_AD10 = IOMUX_PAD(0x02E4, 0x0074, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 = IOMUX_PAD(0x02E4, 0x0074, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__LCD_CLK = IOMUX_PAD(0x02E4, 0x0074, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__LCD_DATA20 = IOMUX_PAD(0x02E4, 0x0074, 7, 0x0688, 0, 0),
- MX7D_PAD_EPDC_SDLE__EPDC_SDLE = IOMUX_PAD(0x02E8, 0x0078, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__SIM2_PORT2_PD = IOMUX_PAD(0x02E8, 0x0078, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 = IOMUX_PAD(0x02E8, 0x0078, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__KPP_COL4 = IOMUX_PAD(0x02E8, 0x0078, 3, 0x0604, 0, 0),
- MX7D_PAD_EPDC_SDLE__EIM_AD11 = IOMUX_PAD(0x02E8, 0x0078, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__GPIO2_IO17 = IOMUX_PAD(0x02E8, 0x0078, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__LCD_DATA16 = IOMUX_PAD(0x02E8, 0x0078, 6, 0x0678, 0, 0),
- MX7D_PAD_EPDC_SDLE__LCD_DATA8 = IOMUX_PAD(0x02E8, 0x0078, 7, 0x0658, 1, 0),
- MX7D_PAD_EPDC_SDOE__EPDC_SDOE = IOMUX_PAD(0x02EC, 0x007C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__FLEXTIMER1_CH0 = IOMUX_PAD(0x02EC, 0x007C, 1, 0x0584, 0, 0),
- MX7D_PAD_EPDC_SDOE__ENET2_RGMII_RD2 = IOMUX_PAD(0x02EC, 0x007C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__KPP_COL5 = IOMUX_PAD(0x02EC, 0x007C, 3, 0x0608, 1, 0),
- MX7D_PAD_EPDC_SDOE__EIM_AD12 = IOMUX_PAD(0x02EC, 0x007C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__GPIO2_IO18 = IOMUX_PAD(0x02EC, 0x007C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__LCD_DATA17 = IOMUX_PAD(0x02EC, 0x007C, 6, 0x067C, 0, 0),
- MX7D_PAD_EPDC_SDOE__LCD_DATA23 = IOMUX_PAD(0x02EC, 0x007C, 7, 0x0694, 0, 0),
- MX7D_PAD_EPDC_SDSHR__EPDC_SDSHR = IOMUX_PAD(0x02F0, 0x0080, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__FLEXTIMER1_CH1 = IOMUX_PAD(0x02F0, 0x0080, 1, 0x0588, 0, 0),
- MX7D_PAD_EPDC_SDSHR__ENET2_RGMII_RD3 = IOMUX_PAD(0x02F0, 0x0080, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__KPP_ROW5 = IOMUX_PAD(0x02F0, 0x0080, 3, 0x0628, 1, 0),
- MX7D_PAD_EPDC_SDSHR__EIM_AD13 = IOMUX_PAD(0x02F0, 0x0080, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__GPIO2_IO19 = IOMUX_PAD(0x02F0, 0x0080, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__LCD_DATA18 = IOMUX_PAD(0x02F0, 0x0080, 6, 0x0680, 0, 0),
- MX7D_PAD_EPDC_SDSHR__LCD_DATA10 = IOMUX_PAD(0x02F0, 0x0080, 7, 0x0660, 1, 0),
- MX7D_PAD_EPDC_SDCE0__EPDC_SDCE0 = IOMUX_PAD(0x02F4, 0x0084, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__FLEXTIMER1_CH2 = IOMUX_PAD(0x02F4, 0x0084, 1, 0x058C, 0, 0),
- MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL = IOMUX_PAD(0x02F4, 0x0084, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__EIM_AD14 = IOMUX_PAD(0x02F4, 0x0084, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 = IOMUX_PAD(0x02F4, 0x0084, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__LCD_DATA19 = IOMUX_PAD(0x02F4, 0x0084, 6, 0x0684, 0, 0),
- MX7D_PAD_EPDC_SDCE0__LCD_DATA5 = IOMUX_PAD(0x02F4, 0x0084, 7, 0x064C, 1, 0),
- MX7D_PAD_EPDC_SDCE1__EPDC_SDCE1 = IOMUX_PAD(0x02F8, 0x0088, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__FLEXTIMER1_CH3 = IOMUX_PAD(0x02F8, 0x0088, 1, 0x0590, 0, 0),
- MX7D_PAD_EPDC_SDCE1__ENET2_RGMII_RXC = IOMUX_PAD(0x02F8, 0x0088, 2, 0x0578, 0, 0),
- MX7D_PAD_EPDC_SDCE1__ENET2_RX_ER = IOMUX_PAD(0x02F8, 0x0088, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__EIM_AD15 = IOMUX_PAD(0x02F8, 0x0088, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 = IOMUX_PAD(0x02F8, 0x0088, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__LCD_DATA20 = IOMUX_PAD(0x02F8, 0x0088, 6, 0x0688, 1, 0),
- MX7D_PAD_EPDC_SDCE1__LCD_DATA4 = IOMUX_PAD(0x02F8, 0x0088, 7, 0x0648, 1, 0),
- MX7D_PAD_EPDC_SDCE2__EPDC_SDCE2 = IOMUX_PAD(0x02FC, 0x008C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__SIM2_PORT1_SVEN = IOMUX_PAD(0x02FC, 0x008C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 = IOMUX_PAD(0x02FC, 0x008C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__KPP_COL6 = IOMUX_PAD(0x02FC, 0x008C, 3, 0x060C, 1, 0),
- MX7D_PAD_EPDC_SDCE2__EIM_ADDR16 = IOMUX_PAD(0x02FC, 0x008C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 = IOMUX_PAD(0x02FC, 0x008C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__LCD_DATA21 = IOMUX_PAD(0x02FC, 0x008C, 6, 0x068C, 1, 0),
- MX7D_PAD_EPDC_SDCE2__LCD_DATA3 = IOMUX_PAD(0x02FC, 0x008C, 7, 0x0644, 1, 0),
- MX7D_PAD_EPDC_SDCE3__EPDC_SDCE3 = IOMUX_PAD(0x0300, 0x0090, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__SIM2_PORT1_PD = IOMUX_PAD(0x0300, 0x0090, 1, 0x06E8, 0, 0),
- MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 = IOMUX_PAD(0x0300, 0x0090, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__KPP_ROW6 = IOMUX_PAD(0x0300, 0x0090, 3, 0x062C, 1, 0),
- MX7D_PAD_EPDC_SDCE3__EIM_ADDR17 = IOMUX_PAD(0x0300, 0x0090, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 = IOMUX_PAD(0x0300, 0x0090, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__LCD_DATA22 = IOMUX_PAD(0x0300, 0x0090, 6, 0x0690, 1, 0),
- MX7D_PAD_EPDC_SDCE3__LCD_DATA2 = IOMUX_PAD(0x0300, 0x0090, 7, 0x0640, 1, 0),
- MX7D_PAD_EPDC_GDCLK__EPDC_GDCLK = IOMUX_PAD(0x0304, 0x0094, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__FLEXTIMER2_CH0 = IOMUX_PAD(0x0304, 0x0094, 1, 0x05AC, 0, 0),
- MX7D_PAD_EPDC_GDCLK__ENET2_RGMII_TD2 = IOMUX_PAD(0x0304, 0x0094, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__KPP_COL7 = IOMUX_PAD(0x0304, 0x0094, 3, 0x0610, 0, 0),
- MX7D_PAD_EPDC_GDCLK__EIM_ADDR18 = IOMUX_PAD(0x0304, 0x0094, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__GPIO2_IO24 = IOMUX_PAD(0x0304, 0x0094, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__LCD_DATA23 = IOMUX_PAD(0x0304, 0x0094, 6, 0x0694, 1, 0),
- MX7D_PAD_EPDC_GDCLK__LCD_DATA16 = IOMUX_PAD(0x0304, 0x0094, 7, 0x0678, 1, 0),
- MX7D_PAD_EPDC_GDOE__EPDC_GDOE = IOMUX_PAD(0x0308, 0x0098, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__FLEXTIMER2_CH1 = IOMUX_PAD(0x0308, 0x0098, 1, 0x05B0, 0, 0),
- MX7D_PAD_EPDC_GDOE__ENET2_RGMII_TD3 = IOMUX_PAD(0x0308, 0x0098, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__KPP_ROW7 = IOMUX_PAD(0x0308, 0x0098, 3, 0x0630, 0, 0),
- MX7D_PAD_EPDC_GDOE__EIM_ADDR19 = IOMUX_PAD(0x0308, 0x0098, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__GPIO2_IO25 = IOMUX_PAD(0x0308, 0x0098, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__LCD_WR_RWN = IOMUX_PAD(0x0308, 0x0098, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__LCD_DATA18 = IOMUX_PAD(0x0308, 0x0098, 7, 0x0680, 1, 0),
- MX7D_PAD_EPDC_GDRL__EPDC_GDRL = IOMUX_PAD(0x030C, 0x009C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__FLEXTIMER2_CH2 = IOMUX_PAD(0x030C, 0x009C, 1, 0x05B4, 0, 0),
- MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL = IOMUX_PAD(0x030C, 0x009C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__EIM_ADDR20 = IOMUX_PAD(0x030C, 0x009C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__GPIO2_IO26 = IOMUX_PAD(0x030C, 0x009C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__LCD_RD_E = IOMUX_PAD(0x030C, 0x009C, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__LCD_DATA19 = IOMUX_PAD(0x030C, 0x009C, 7, 0x0684, 1, 0),
- MX7D_PAD_EPDC_GDSP__EPDC_GDSP = IOMUX_PAD(0x0310, 0x00A0, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__FLEXTIMER2_CH3 = IOMUX_PAD(0x0310, 0x00A0, 1, 0x05B8, 0, 0),
- MX7D_PAD_EPDC_GDSP__ENET2_RGMII_TXC = IOMUX_PAD(0x0310, 0x00A0, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__ENET2_TX_ER = IOMUX_PAD(0x0310, 0x00A0, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__EIM_ADDR21 = IOMUX_PAD(0x0310, 0x00A0, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__GPIO2_IO27 = IOMUX_PAD(0x0310, 0x00A0, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__LCD_BUSY = IOMUX_PAD(0x0310, 0x00A0, 6, 0x0634, 1, 0),
- MX7D_PAD_EPDC_GDSP__LCD_DATA17 = IOMUX_PAD(0x0310, 0x00A0, 7, 0x067C, 1, 0),
- MX7D_PAD_EPDC_BDR0__EPDC_BDR0 = IOMUX_PAD(0x0314, 0x00A4, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__ENET2_TX_CLK = IOMUX_PAD(0x0314, 0x00A4, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x0314, 0x00A4, 3, 0x0570, 1, 0),
- MX7D_PAD_EPDC_BDR0__EIM_ADDR22 = IOMUX_PAD(0x0314, 0x00A4, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__GPIO2_IO28 = IOMUX_PAD(0x0314, 0x00A4, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__LCD_CS = IOMUX_PAD(0x0314, 0x00A4, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__LCD_DATA7 = IOMUX_PAD(0x0314, 0x00A4, 7, 0x0654, 1, 0),
- MX7D_PAD_EPDC_BDR1__EPDC_BDR1 = IOMUX_PAD(0x0318, 0x00A8, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__EPDC_SDCLKN = IOMUX_PAD(0x0318, 0x00A8, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__ENET2_RX_CLK = IOMUX_PAD(0x0318, 0x00A8, 2, 0x0578, 1, 0),
- MX7D_PAD_EPDC_BDR1__EIM_AD8 = IOMUX_PAD(0x0318, 0x00A8, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__GPIO2_IO29 = IOMUX_PAD(0x0318, 0x00A8, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__LCD_ENABLE = IOMUX_PAD(0x0318, 0x00A8, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__LCD_DATA6 = IOMUX_PAD(0x0318, 0x00A8, 7, 0x0650, 1, 0),
- MX7D_PAD_EPDC_PWR_COM__EPDC_PWR_COM = IOMUX_PAD(0x031C, 0x00AC, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__FLEXTIMER2_PHA = IOMUX_PAD(0x031C, 0x00AC, 1, 0x05CC, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__ENET2_CRS = IOMUX_PAD(0x031C, 0x00AC, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__EIM_AD9 = IOMUX_PAD(0x031C, 0x00AC, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 = IOMUX_PAD(0x031C, 0x00AC, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__LCD_HSYNC = IOMUX_PAD(0x031C, 0x00AC, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__LCD_DATA11 = IOMUX_PAD(0x031C, 0x00AC, 7, 0x0664, 1, 0),
- MX7D_PAD_EPDC_PWR_STAT__EPDC_PWR_STAT = IOMUX_PAD(0x0320, 0x00B0, 0, 0x0580, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__FLEXTIMER2_PHB = IOMUX_PAD(0x0320, 0x00B0, 1, 0x05D0, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__ENET2_COL = IOMUX_PAD(0x0320, 0x00B0, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__EIM_EB_B1 = IOMUX_PAD(0x0320, 0x00B0, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31 = IOMUX_PAD(0x0320, 0x00B0, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__LCD_VSYNC = IOMUX_PAD(0x0320, 0x00B0, 6, 0x0698, 1, 0),
- MX7D_PAD_EPDC_PWR_STAT__LCD_DATA12 = IOMUX_PAD(0x0320, 0x00B0, 7, 0x0668, 1, 0),
- MX7D_PAD_LCD_CLK__LCD_CLK = IOMUX_PAD(0x0324, 0x00B4, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__ECSPI4_MISO = IOMUX_PAD(0x0324, 0x00B4, 1, 0x0558, 0, 0),
- MX7D_PAD_LCD_CLK__ENET1_1588_EVENT2_IN = IOMUX_PAD(0x0324, 0x00B4, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__CSI_DATA16 = IOMUX_PAD(0x0324, 0x00B4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__UART2_DCE_RX = IOMUX_PAD(0x0324, 0x00B4, 4, 0x06FC, 0, 0),
- MX7D_PAD_LCD_CLK__UART2_DTE_TX = IOMUX_PAD(0x0324, 0x00B4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__GPIO3_IO0 = IOMUX_PAD(0x0324, 0x00B4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__LCD_ENABLE = IOMUX_PAD(0x0328, 0x00B8, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__ECSPI4_MOSI = IOMUX_PAD(0x0328, 0x00B8, 1, 0x055C, 0, 0),
- MX7D_PAD_LCD_ENABLE__ENET1_1588_EVENT3_IN = IOMUX_PAD(0x0328, 0x00B8, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__CSI_DATA17 = IOMUX_PAD(0x0328, 0x00B8, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__UART2_DCE_TX = IOMUX_PAD(0x0328, 0x00B8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__UART2_DTE_RX = IOMUX_PAD(0x0328, 0x00B8, 4, 0x06FC, 1, 0),
- MX7D_PAD_LCD_ENABLE__GPIO3_IO1 = IOMUX_PAD(0x0328, 0x00B8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__LCD_HSYNC = IOMUX_PAD(0x032C, 0x00BC, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__ECSPI4_SCLK = IOMUX_PAD(0x032C, 0x00BC, 1, 0x0554, 0, 0),
- MX7D_PAD_LCD_HSYNC__ENET2_1588_EVENT2_IN = IOMUX_PAD(0x032C, 0x00BC, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__CSI_DATA18 = IOMUX_PAD(0x032C, 0x00BC, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__UART2_DCE_RTS = IOMUX_PAD(0x032C, 0x00BC, 4, 0x06F8, 0, 0),
- MX7D_PAD_LCD_HSYNC__UART2_DTE_CTS = IOMUX_PAD(0x032C, 0x00BC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__GPIO3_IO2 = IOMUX_PAD(0x032C, 0x00BC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__LCD_VSYNC = IOMUX_PAD(0x0330, 0x00C0, 0, 0x0698, 2, 0),
- MX7D_PAD_LCD_VSYNC__ECSPI4_SS0 = IOMUX_PAD(0x0330, 0x00C0, 1, 0x0560, 0, 0),
- MX7D_PAD_LCD_VSYNC__ENET2_1588_EVENT3_IN = IOMUX_PAD(0x0330, 0x00C0, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__CSI_DATA19 = IOMUX_PAD(0x0330, 0x00C0, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__UART2_DCE_CTS = IOMUX_PAD(0x0330, 0x00C0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__UART2_DTE_RTS = IOMUX_PAD(0x0330, 0x00C0, 4, 0x06F8, 1, 0),
- MX7D_PAD_LCD_VSYNC__GPIO3_IO3 = IOMUX_PAD(0x0330, 0x00C0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__LCD_RESET = IOMUX_PAD(0x0334, 0x00C4, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__GPT1_COMPARE1 = IOMUX_PAD(0x0334, 0x00C4, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__ARM_PLATFORM_EVENTI = IOMUX_PAD(0x0334, 0x00C4, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__CSI_FIELD = IOMUX_PAD(0x0334, 0x00C4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__EIM_DTACK_B = IOMUX_PAD(0x0334, 0x00C4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__GPIO3_IO4 = IOMUX_PAD(0x0334, 0x00C4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__LCD_DATA0 = IOMUX_PAD(0x0338, 0x00C8, 0, 0x0638, 2, 0),
- MX7D_PAD_LCD_DATA00__GPT1_COMPARE2 = IOMUX_PAD(0x0338, 0x00C8, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__CSI_DATA20 = IOMUX_PAD(0x0338, 0x00C8, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__EIM_DATA0 = IOMUX_PAD(0x0338, 0x00C8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__GPIO3_IO5 = IOMUX_PAD(0x0338, 0x00C8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__SRC_BOOT_CFG0 = IOMUX_PAD(0x0338, 0x00C8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__LCD_DATA1 = IOMUX_PAD(0x033C, 0x00CC, 0, 0x063C, 2, 0),
- MX7D_PAD_LCD_DATA01__GPT1_COMPARE3 = IOMUX_PAD(0x033C, 0x00CC, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__CSI_DATA21 = IOMUX_PAD(0x033C, 0x00CC, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__EIM_DATA1 = IOMUX_PAD(0x033C, 0x00CC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__GPIO3_IO6 = IOMUX_PAD(0x033C, 0x00CC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__SRC_BOOT_CFG1 = IOMUX_PAD(0x033C, 0x00CC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__LCD_DATA2 = IOMUX_PAD(0x0340, 0x00D0, 0, 0x0640, 2, 0),
- MX7D_PAD_LCD_DATA02__GPT1_CLK = IOMUX_PAD(0x0340, 0x00D0, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__CSI_DATA22 = IOMUX_PAD(0x0340, 0x00D0, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__EIM_DATA2 = IOMUX_PAD(0x0340, 0x00D0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__GPIO3_IO7 = IOMUX_PAD(0x0340, 0x00D0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__SRC_BOOT_CFG2 = IOMUX_PAD(0x0340, 0x00D0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__LCD_DATA3 = IOMUX_PAD(0x0344, 0x00D4, 0, 0x0644, 2, 0),
- MX7D_PAD_LCD_DATA03__GPT1_CAPTURE1 = IOMUX_PAD(0x0344, 0x00D4, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__CSI_DATA23 = IOMUX_PAD(0x0344, 0x00D4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__EIM_DATA3 = IOMUX_PAD(0x0344, 0x00D4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__GPIO3_IO8 = IOMUX_PAD(0x0344, 0x00D4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__SRC_BOOT_CFG3 = IOMUX_PAD(0x0344, 0x00D4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__LCD_DATA4 = IOMUX_PAD(0x0348, 0x00D8, 0, 0x0648, 2, 0),
- MX7D_PAD_LCD_DATA04__GPT1_CAPTURE2 = IOMUX_PAD(0x0348, 0x00D8, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__CSI_VSYNC = IOMUX_PAD(0x0348, 0x00D8, 3, 0x0520, 0, 0),
- MX7D_PAD_LCD_DATA04__EIM_DATA4 = IOMUX_PAD(0x0348, 0x00D8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__GPIO3_IO9 = IOMUX_PAD(0x0348, 0x00D8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__SRC_BOOT_CFG4 = IOMUX_PAD(0x0348, 0x00D8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__LCD_DATA5 = IOMUX_PAD(0x034C, 0x00DC, 0, 0x064C, 2, 0),
- MX7D_PAD_LCD_DATA05__CSI_HSYNC = IOMUX_PAD(0x034C, 0x00DC, 3, 0x0518, 0, 0),
- MX7D_PAD_LCD_DATA05__EIM_DATA5 = IOMUX_PAD(0x034C, 0x00DC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__GPIO3_IO10 = IOMUX_PAD(0x034C, 0x00DC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__SRC_BOOT_CFG5 = IOMUX_PAD(0x034C, 0x00DC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__LCD_DATA6 = IOMUX_PAD(0x0350, 0x00E0, 0, 0x0650, 2, 0),
- MX7D_PAD_LCD_DATA06__CSI_PIXCLK = IOMUX_PAD(0x0350, 0x00E0, 3, 0x051C, 0, 0),
- MX7D_PAD_LCD_DATA06__EIM_DATA6 = IOMUX_PAD(0x0350, 0x00E0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__GPIO3_IO11 = IOMUX_PAD(0x0350, 0x00E0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__SRC_BOOT_CFG6 = IOMUX_PAD(0x0350, 0x00E0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__LCD_DATA7 = IOMUX_PAD(0x0354, 0x00E4, 0, 0x0654, 2, 0),
- MX7D_PAD_LCD_DATA07__CSI_MCLK = IOMUX_PAD(0x0354, 0x00E4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__EIM_DATA7 = IOMUX_PAD(0x0354, 0x00E4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__GPIO3_IO12 = IOMUX_PAD(0x0354, 0x00E4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__SRC_BOOT_CFG7 = IOMUX_PAD(0x0354, 0x00E4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__LCD_DATA8 = IOMUX_PAD(0x0358, 0x00E8, 0, 0x0658, 2, 0),
- MX7D_PAD_LCD_DATA08__CSI_DATA9 = IOMUX_PAD(0x0358, 0x00E8, 3, 0x0514, 0, 0),
- MX7D_PAD_LCD_DATA08__EIM_DATA8 = IOMUX_PAD(0x0358, 0x00E8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__GPIO3_IO13 = IOMUX_PAD(0x0358, 0x00E8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__SRC_BOOT_CFG8 = IOMUX_PAD(0x0358, 0x00E8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__LCD_DATA9 = IOMUX_PAD(0x035C, 0x00EC, 0, 0x065C, 2, 0),
- MX7D_PAD_LCD_DATA09__CSI_DATA8 = IOMUX_PAD(0x035C, 0x00EC, 3, 0x0510, 0, 0),
- MX7D_PAD_LCD_DATA09__EIM_DATA9 = IOMUX_PAD(0x035C, 0x00EC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__GPIO3_IO14 = IOMUX_PAD(0x035C, 0x00EC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__SRC_BOOT_CFG9 = IOMUX_PAD(0x035C, 0x00EC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__LCD_DATA10 = IOMUX_PAD(0x0360, 0x00F0, 0, 0x0660, 2, 0),
- MX7D_PAD_LCD_DATA10__CSI_DATA7 = IOMUX_PAD(0x0360, 0x00F0, 3, 0x050C, 0, 0),
- MX7D_PAD_LCD_DATA10__EIM_DATA10 = IOMUX_PAD(0x0360, 0x00F0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__GPIO3_IO15 = IOMUX_PAD(0x0360, 0x00F0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0360, 0x00F0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__LCD_DATA11 = IOMUX_PAD(0x0364, 0x00F4, 0, 0x0664, 2, 0),
- MX7D_PAD_LCD_DATA11__CSI_DATA6 = IOMUX_PAD(0x0364, 0x00F4, 3, 0x0508, 0, 0),
- MX7D_PAD_LCD_DATA11__EIM_DATA11 = IOMUX_PAD(0x0364, 0x00F4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__GPIO3_IO16 = IOMUX_PAD(0x0364, 0x00F4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0364, 0x00F4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__LCD_DATA12 = IOMUX_PAD(0x0368, 0x00F8, 0, 0x0668, 2, 0),
- MX7D_PAD_LCD_DATA12__CSI_DATA5 = IOMUX_PAD(0x0368, 0x00F8, 3, 0x0504, 0, 0),
- MX7D_PAD_LCD_DATA12__EIM_DATA12 = IOMUX_PAD(0x0368, 0x00F8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__GPIO3_IO17 = IOMUX_PAD(0x0368, 0x00F8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0368, 0x00F8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__LCD_DATA13 = IOMUX_PAD(0x036C, 0x00FC, 0, 0x066C, 1, 0),
- MX7D_PAD_LCD_DATA13__CSI_DATA4 = IOMUX_PAD(0x036C, 0x00FC, 3, 0x0500, 0, 0),
- MX7D_PAD_LCD_DATA13__EIM_DATA13 = IOMUX_PAD(0x036C, 0x00FC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__GPIO3_IO18 = IOMUX_PAD(0x036C, 0x00FC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x036C, 0x00FC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__LCD_DATA14 = IOMUX_PAD(0x0370, 0x0100, 0, 0x0670, 1, 0),
- MX7D_PAD_LCD_DATA14__CSI_DATA3 = IOMUX_PAD(0x0370, 0x0100, 3, 0x04FC, 0, 0),
- MX7D_PAD_LCD_DATA14__EIM_DATA14 = IOMUX_PAD(0x0370, 0x0100, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__GPIO3_IO19 = IOMUX_PAD(0x0370, 0x0100, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0370, 0x0100, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__LCD_DATA15 = IOMUX_PAD(0x0374, 0x0104, 0, 0x0674, 1, 0),
- MX7D_PAD_LCD_DATA15__CSI_DATA2 = IOMUX_PAD(0x0374, 0x0104, 3, 0x04F8, 0, 0),
- MX7D_PAD_LCD_DATA15__EIM_DATA15 = IOMUX_PAD(0x0374, 0x0104, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__GPIO3_IO20 = IOMUX_PAD(0x0374, 0x0104, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0374, 0x0104, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__LCD_DATA16 = IOMUX_PAD(0x0378, 0x0108, 0, 0x0678, 2, 0),
- MX7D_PAD_LCD_DATA16__FLEXTIMER1_CH4 = IOMUX_PAD(0x0378, 0x0108, 1, 0x0594, 0, 0),
- MX7D_PAD_LCD_DATA16__CSI_DATA1 = IOMUX_PAD(0x0378, 0x0108, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__EIM_CRE = IOMUX_PAD(0x0378, 0x0108, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__GPIO3_IO21 = IOMUX_PAD(0x0378, 0x0108, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0378, 0x0108, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__LCD_DATA17 = IOMUX_PAD(0x037C, 0x010C, 0, 0x067C, 2, 0),
- MX7D_PAD_LCD_DATA17__FLEXTIMER1_CH5 = IOMUX_PAD(0x037C, 0x010C, 1, 0x0598, 0, 0),
- MX7D_PAD_LCD_DATA17__CSI_DATA0 = IOMUX_PAD(0x037C, 0x010C, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__EIM_ACLK_FREERUN = IOMUX_PAD(0x037C, 0x010C, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__GPIO3_IO22 = IOMUX_PAD(0x037C, 0x010C, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__SRC_BOOT_CFG17 = IOMUX_PAD(0x037C, 0x010C, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__LCD_DATA18 = IOMUX_PAD(0x0380, 0x0110, 0, 0x0680, 2, 0),
- MX7D_PAD_LCD_DATA18__FLEXTIMER1_CH6 = IOMUX_PAD(0x0380, 0x0110, 1, 0x059C, 0, 0),
- MX7D_PAD_LCD_DATA18__ARM_PLATFORM_EVENTO = IOMUX_PAD(0x0380, 0x0110, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__CSI_DATA15 = IOMUX_PAD(0x0380, 0x0110, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__EIM_CS2_B = IOMUX_PAD(0x0380, 0x0110, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__GPIO3_IO23 = IOMUX_PAD(0x0380, 0x0110, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0380, 0x0110, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__EIM_CS3_B = IOMUX_PAD(0x0384, 0x0114, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__GPIO3_IO24 = IOMUX_PAD(0x0384, 0x0114, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__SRC_BOOT_CFG19 = IOMUX_PAD(0x0384, 0x0114, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__LCD_DATA19 = IOMUX_PAD(0x0384, 0x0114, 0, 0x0684, 2, 0),
- MX7D_PAD_LCD_DATA19__FLEXTIMER1_CH7 = IOMUX_PAD(0x0384, 0x0114, 1, 0x05A0, 0, 0),
- MX7D_PAD_LCD_DATA19__CSI_DATA14 = IOMUX_PAD(0x0384, 0x0114, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__EIM_ADDR23 = IOMUX_PAD(0x0388, 0x0118, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__GPIO3_IO25 = IOMUX_PAD(0x0388, 0x0118, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__I2C3_SCL = IOMUX_PAD(0x0388, 0x0118, IOMUX_CONFIG_SION | 6, 0x05E4, 1, 0),
- MX7D_PAD_LCD_DATA20__LCD_DATA20 = IOMUX_PAD(0x0388, 0x0118, 0, 0x0688, 2, 0),
- MX7D_PAD_LCD_DATA20__FLEXTIMER2_CH4 = IOMUX_PAD(0x0388, 0x0118, 1, 0x05BC, 0, 0),
- MX7D_PAD_LCD_DATA20__ENET1_1588_EVENT2_OUT = IOMUX_PAD(0x0388, 0x0118, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__CSI_DATA13 = IOMUX_PAD(0x0388, 0x0118, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__LCD_DATA21 = IOMUX_PAD(0x038C, 0x011C, 0, 0x068C, 2, 0),
- MX7D_PAD_LCD_DATA21__FLEXTIMER2_CH5 = IOMUX_PAD(0x038C, 0x011C, 1, 0x05C0, 0, 0),
- MX7D_PAD_LCD_DATA21__ENET1_1588_EVENT3_OUT = IOMUX_PAD(0x038C, 0x011C, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__CSI_DATA12 = IOMUX_PAD(0x038C, 0x011C, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__EIM_ADDR24 = IOMUX_PAD(0x038C, 0x011C, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__GPIO3_IO26 = IOMUX_PAD(0x038C, 0x011C, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__I2C3_SDA = IOMUX_PAD(0x038C, 0x011C, IOMUX_CONFIG_SION | 6, 0x05E8, 1, 0),
- MX7D_PAD_LCD_DATA22__LCD_DATA22 = IOMUX_PAD(0x0390, 0x0120, 0, 0x0690, 2, 0),
- MX7D_PAD_LCD_DATA22__FLEXTIMER2_CH6 = IOMUX_PAD(0x0390, 0x0120, 1, 0x05C4, 0, 0),
- MX7D_PAD_LCD_DATA22__ENET2_1588_EVENT2_OUT = IOMUX_PAD(0x0390, 0x0120, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__CSI_DATA11 = IOMUX_PAD(0x0390, 0x0120, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__EIM_ADDR25 = IOMUX_PAD(0x0390, 0x0120, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__GPIO3_IO27 = IOMUX_PAD(0x0390, 0x0120, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__I2C4_SCL = IOMUX_PAD(0x0390, 0x0120, IOMUX_CONFIG_SION | 6, 0x05EC, 1, 0),
- MX7D_PAD_LCD_DATA23__LCD_DATA23 = IOMUX_PAD(0x0394, 0x0124, 0, 0x0694, 2, 0),
- MX7D_PAD_LCD_DATA23__FLEXTIMER2_CH7 = IOMUX_PAD(0x0394, 0x0124, 1, 0x05C8, 0, 0),
- MX7D_PAD_LCD_DATA23__ENET2_1588_EVENT3_OUT = IOMUX_PAD(0x0394, 0x0124, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__CSI_DATA10 = IOMUX_PAD(0x0394, 0x0124, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__EIM_ADDR26 = IOMUX_PAD(0x0394, 0x0124, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__GPIO3_IO28 = IOMUX_PAD(0x0394, 0x0124, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__I2C4_SDA = IOMUX_PAD(0x0394, 0x0124, IOMUX_CONFIG_SION | 6, 0x05F0, 1, 0),
- MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__UART1_DTE_TX = IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__I2C1_SCL = IOMUX_PAD(0x0398, 0x0128, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__CCM_PMIC_READY = IOMUX_PAD(0x0398, 0x0128, 2, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ECSPI1_SS1 = IOMUX_PAD(0x0398, 0x0128, 3, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ENET2_1588_EVENT0_IN = IOMUX_PAD(0x0398, 0x0128, 4, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__GPIO4_IO0 = IOMUX_PAD(0x0398, 0x0128, 5, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ENET1_MDIO = IOMUX_PAD(0x0398, 0x0128, 6, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX = IOMUX_PAD(0x039C, 0x012C, 0, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__UART1_DTE_RX = IOMUX_PAD(0x039C, 0x012C, 0, 0x06F4, 1, 0),
- MX7D_PAD_UART1_TX_DATA__I2C1_SDA = IOMUX_PAD(0x039C, 0x012C, IOMUX_CONFIG_SION | 1, 0x05D8, 0, 0),
- MX7D_PAD_UART1_TX_DATA__SAI3_MCLK = IOMUX_PAD(0x039C, 0x012C, 2, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ECSPI1_SS2 = IOMUX_PAD(0x039C, 0x012C, 3, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ENET2_1588_EVENT0_OUT = IOMUX_PAD(0x039C, 0x012C, 4, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__GPIO4_IO1 = IOMUX_PAD(0x039C, 0x012C, 5, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ENET1_MDC = IOMUX_PAD(0x039C, 0x012C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__UART2_DCE_RX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__UART2_DTE_TX = IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__I2C2_SCL = IOMUX_PAD(0x03A0, 0x0130, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__SAI3_RX_BCLK = IOMUX_PAD(0x03A0, 0x0130, 2, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ECSPI1_SS3 = IOMUX_PAD(0x03A0, 0x0130, 3, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ENET2_1588_EVENT1_IN = IOMUX_PAD(0x03A0, 0x0130, 4, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__GPIO4_IO2 = IOMUX_PAD(0x03A0, 0x0130, 5, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ENET2_MDIO = IOMUX_PAD(0x03A0, 0x0130, 6, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__UART2_DCE_TX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0134, IOMUX_CONFIG_SION | 1, 0x05E0, 0, 0),
- MX7D_PAD_UART2_TX_DATA__SAI3_RX_DATA0 = IOMUX_PAD(0x03A4, 0x0134, 2, 0x06C8, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ECSPI1_RDY = IOMUX_PAD(0x03A4, 0x0134, 3, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ENET2_1588_EVENT1_OUT = IOMUX_PAD(0x03A4, 0x0134, 4, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__GPIO4_IO3 = IOMUX_PAD(0x03A4, 0x0134, 5, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ENET2_MDC = IOMUX_PAD(0x03A4, 0x0134, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__UART3_DCE_RX = IOMUX_PAD(0x03A8, 0x0138, 0, 0x0704, 2, 0),
- MX7D_PAD_UART3_RX_DATA__UART3_DTE_TX = IOMUX_PAD(0x03A8, 0x0138, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__USB_OTG1_OC = IOMUX_PAD(0x03A8, 0x0138, 1, 0x072C, 0, 0),
- MX7D_PAD_UART3_RX_DATA__SAI3_RX_SYNC = IOMUX_PAD(0x03A8, 0x0138, 2, 0x06CC, 0, 0),
- MX7D_PAD_UART3_RX_DATA__ECSPI1_MISO = IOMUX_PAD(0x03A8, 0x0138, 3, 0x0528, 0, 0),
- MX7D_PAD_UART3_RX_DATA__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x03A8, 0x0138, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__GPIO4_IO4 = IOMUX_PAD(0x03A8, 0x0138, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__SD1_LCTL = IOMUX_PAD(0x03A8, 0x0138, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__UART3_DCE_TX = IOMUX_PAD(0x03AC, 0x013C, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__UART3_DTE_RX = IOMUX_PAD(0x03AC, 0x013C, 0, 0x0704, 3, 0),
- MX7D_PAD_UART3_TX_DATA__USB_OTG1_PWR = IOMUX_PAD(0x03AC, 0x013C, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__SAI3_TX_BCLK = IOMUX_PAD(0x03AC, 0x013C, 2, 0x06D0, 0, 0),
- MX7D_PAD_UART3_TX_DATA__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x013C, 3, 0x052C, 0, 0),
- MX7D_PAD_UART3_TX_DATA__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x03AC, 0x013C, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__GPIO4_IO5 = IOMUX_PAD(0x03AC, 0x013C, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__SD2_LCTL = IOMUX_PAD(0x03AC, 0x013C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__UART3_DTE_CTS = IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__USB_OTG2_OC = IOMUX_PAD(0x03B0, 0x0140, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__SAI3_TX_DATA0 = IOMUX_PAD(0x03B0, 0x0140, 2, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__ECSPI1_SCLK = IOMUX_PAD(0x03B0, 0x0140, 3, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x03B0, 0x0140, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__GPIO4_IO6 = IOMUX_PAD(0x03B0, 0x0140, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__SD3_LCTL = IOMUX_PAD(0x03B0, 0x0140, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__UART3_DCE_CTS = IOMUX_PAD(0x03B4, 0x0144, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__UART3_DTE_RTS = IOMUX_PAD(0x03B4, 0x0144, 0, 0x0700, 3, 0),
- MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR = IOMUX_PAD(0x03B4, 0x0144, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__SAI3_TX_SYNC = IOMUX_PAD(0x03B4, 0x0144, 2, 0x06D4, 0, 0),
- MX7D_PAD_UART3_CTS_B__ECSPI1_SS0 = IOMUX_PAD(0x03B4, 0x0144, 3, 0x0530, 0, 0),
- MX7D_PAD_UART3_CTS_B__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x03B4, 0x0144, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__GPIO4_IO7 = IOMUX_PAD(0x03B4, 0x0144, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__SD1_VSELECT = IOMUX_PAD(0x03B4, 0x0144, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__I2C1_SCL = IOMUX_PAD(0x03B8, 0x0148, IOMUX_CONFIG_SION | 0, 0x05D4, 1, 0),
- MX7D_PAD_I2C1_SCL__UART4_DCE_CTS = IOMUX_PAD(0x03B8, 0x0148, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__UART4_DTE_RTS = IOMUX_PAD(0x03B8, 0x0148, 1, 0x0708, 0, 0),
- MX7D_PAD_I2C1_SCL__FLEXCAN1_RX = IOMUX_PAD(0x03B8, 0x0148, 2, 0x04DC, 1, 0),
- MX7D_PAD_I2C1_SCL__ECSPI3_MISO = IOMUX_PAD(0x03B8, 0x0148, 3, 0x0548, 0, 0),
- MX7D_PAD_I2C1_SCL__GPIO4_IO8 = IOMUX_PAD(0x03B8, 0x0148, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__SD2_VSELECT = IOMUX_PAD(0x03B8, 0x0148, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__I2C1_SDA = IOMUX_PAD(0x03BC, 0x014C, IOMUX_CONFIG_SION | 0, 0x05D8, 1, 0),
- MX7D_PAD_I2C1_SDA__UART4_DCE_RTS = IOMUX_PAD(0x03BC, 0x014C, 1, 0x0708, 1, 0),
- MX7D_PAD_I2C1_SDA__UART4_DTE_CTS = IOMUX_PAD(0x03BC, 0x014C, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__FLEXCAN1_TX = IOMUX_PAD(0x03BC, 0x014C, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__ECSPI3_MOSI = IOMUX_PAD(0x03BC, 0x014C, 3, 0x054C, 0, 0),
- MX7D_PAD_I2C1_SDA__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x03BC, 0x014C, 4, 0x0564, 1, 0),
- MX7D_PAD_I2C1_SDA__GPIO4_IO9 = IOMUX_PAD(0x03BC, 0x014C, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__SD3_VSELECT = IOMUX_PAD(0x03BC, 0x014C, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__I2C2_SCL = IOMUX_PAD(0x03C0, 0x0150, IOMUX_CONFIG_SION | 0, 0x05DC, 1, 0),
- MX7D_PAD_I2C2_SCL__UART4_DCE_RX = IOMUX_PAD(0x03C0, 0x0150, 1, 0x070C, 0, 0),
- MX7D_PAD_I2C2_SCL__UART4_DTE_TX = IOMUX_PAD(0x03C0, 0x0150, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__WDOG3_WDOG_B = IOMUX_PAD(0x03C0, 0x0150, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__ECSPI3_SCLK = IOMUX_PAD(0x03C0, 0x0150, 3, 0x0544, 0, 0),
- MX7D_PAD_I2C2_SCL__CCM_ENET_REF_CLK2 = IOMUX_PAD(0x03C0, 0x0150, 4, 0x0570, 2, 0),
- MX7D_PAD_I2C2_SCL__GPIO4_IO10 = IOMUX_PAD(0x03C0, 0x0150, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__SD3_CD_B = IOMUX_PAD(0x03C0, 0x0150, 6, 0x0738, 1, 0),
- MX7D_PAD_I2C2_SDA__I2C2_SDA = IOMUX_PAD(0x03C4, 0x0154, IOMUX_CONFIG_SION | 0, 0x05E0, 1, 0),
- MX7D_PAD_I2C2_SDA__UART4_DCE_TX = IOMUX_PAD(0x03C4, 0x0154, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__UART4_DTE_RX = IOMUX_PAD(0x03C4, 0x0154, 1, 0x070C, 1, 0),
- MX7D_PAD_I2C2_SDA__WDOG3_WDOG_RST_B_DEB = IOMUX_PAD(0x03C4, 0x0154, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__ECSPI3_SS0 = IOMUX_PAD(0x03C4, 0x0154, 3, 0x0550, 0, 0),
- MX7D_PAD_I2C2_SDA__CCM_ENET_REF_CLK3 = IOMUX_PAD(0x03C4, 0x0154, 4, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__GPIO4_IO11 = IOMUX_PAD(0x03C4, 0x0154, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__SD3_WP = IOMUX_PAD(0x03C4, 0x0154, 6, 0x073C, 1, 0),
- MX7D_PAD_I2C3_SCL__I2C3_SCL = IOMUX_PAD(0x03C8, 0x0158, IOMUX_CONFIG_SION | 0, 0x05E4, 2, 0),
- MX7D_PAD_I2C3_SCL__UART5_DCE_CTS = IOMUX_PAD(0x03C8, 0x0158, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SCL__UART5_DTE_RTS = IOMUX_PAD(0x03C8, 0x0158, 1, 0x0710, 0, 0),
- MX7D_PAD_I2C3_SCL__FLEXCAN2_RX = IOMUX_PAD(0x03C8, 0x0158, 2, 0x04E0, 1, 0),
- MX7D_PAD_I2C3_SCL__CSI_VSYNC = IOMUX_PAD(0x03C8, 0x0158, 3, 0x0520, 1, 0),
- MX7D_PAD_I2C3_SCL__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03C8, 0x0158, 4, 0x06D8, 1, 0),
- MX7D_PAD_I2C3_SCL__GPIO4_IO12 = IOMUX_PAD(0x03C8, 0x0158, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SCL__EPDC_BDR0 = IOMUX_PAD(0x03C8, 0x0158, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__I2C3_SDA = IOMUX_PAD(0x03CC, 0x015C, IOMUX_CONFIG_SION | 0, 0x05E8, 2, 0),
- MX7D_PAD_I2C3_SDA__UART5_DCE_RTS = IOMUX_PAD(0x03CC, 0x015C, 1, 0x0710, 1, 0),
- MX7D_PAD_I2C3_SDA__UART5_DTE_CTS = IOMUX_PAD(0x03CC, 0x015C, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__FLEXCAN2_TX = IOMUX_PAD(0x03CC, 0x015C, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__CSI_HSYNC = IOMUX_PAD(0x03CC, 0x015C, 3, 0x0518, 1, 0),
- MX7D_PAD_I2C3_SDA__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03CC, 0x015C, 4, 0x06DC, 1, 0),
- MX7D_PAD_I2C3_SDA__GPIO4_IO13 = IOMUX_PAD(0x03CC, 0x015C, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__EPDC_BDR1 = IOMUX_PAD(0x03CC, 0x015C, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__I2C4_SCL = IOMUX_PAD(0x03D0, 0x0160, IOMUX_CONFIG_SION | 0, 0x05EC, 2, 0),
- MX7D_PAD_I2C4_SCL__UART5_DCE_RX = IOMUX_PAD(0x03D0, 0x0160, 1, 0x0714, 0, 0),
- MX7D_PAD_I2C4_SCL__UART5_DTE_TX = IOMUX_PAD(0x03D0, 0x0160, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__WDOG4_WDOG_B = IOMUX_PAD(0x03D0, 0x0160, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__CSI_PIXCLK = IOMUX_PAD(0x03D0, 0x0160, 3, 0x051C, 1, 0),
- MX7D_PAD_I2C4_SCL__USB_OTG1_ID = IOMUX_PAD(0x03D0, 0x0160, 4, 0x0734, 1, 0),
- MX7D_PAD_I2C4_SCL__GPIO4_IO14 = IOMUX_PAD(0x03D0, 0x0160, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__EPDC_VCOM0 = IOMUX_PAD(0x03D0, 0x0160, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__I2C4_SDA = IOMUX_PAD(0x03D4, 0x0164, IOMUX_CONFIG_SION | 0, 0x05F0, 2, 0),
- MX7D_PAD_I2C4_SDA__UART5_DCE_TX = IOMUX_PAD(0x03D4, 0x0164, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__UART5_DTE_RX = IOMUX_PAD(0x03D4, 0x0164, 1, 0x0714, 1, 0),
- MX7D_PAD_I2C4_SDA__WDOG4_WDOG_RST_B_DEB = IOMUX_PAD(0x03D4, 0x0164, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__CSI_MCLK = IOMUX_PAD(0x03D4, 0x0164, 3, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__USB_OTG2_ID = IOMUX_PAD(0x03D4, 0x0164, 4, 0x0730, 1, 0),
- MX7D_PAD_I2C4_SDA__GPIO4_IO15 = IOMUX_PAD(0x03D4, 0x0164, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__EPDC_VCOM1 = IOMUX_PAD(0x03D4, 0x0164, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x03D8, 0x0168, 0, 0x0524, 1, 0),
- MX7D_PAD_ECSPI1_SCLK__UART6_DCE_RX = IOMUX_PAD(0x03D8, 0x0168, 1, 0x071C, 2, 0),
- MX7D_PAD_ECSPI1_SCLK__UART6_DTE_TX = IOMUX_PAD(0x03D8, 0x0168, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__SD2_DATA4 = IOMUX_PAD(0x03D8, 0x0168, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__CSI_DATA2 = IOMUX_PAD(0x03D8, 0x0168, 3, 0x04F8, 1, 0),
- MX7D_PAD_ECSPI1_SCLK__GPIO4_IO16 = IOMUX_PAD(0x03D8, 0x0168, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__EPDC_PWR_COM = IOMUX_PAD(0x03D8, 0x0168, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x03DC, 0x016C, 0, 0x052C, 1, 0),
- MX7D_PAD_ECSPI1_MOSI__UART6_DCE_TX = IOMUX_PAD(0x03DC, 0x016C, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__UART6_DTE_RX = IOMUX_PAD(0x03DC, 0x016C, 1, 0x071C, 3, 0),
- MX7D_PAD_ECSPI1_MOSI__SD2_DATA5 = IOMUX_PAD(0x03DC, 0x016C, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__CSI_DATA3 = IOMUX_PAD(0x03DC, 0x016C, 3, 0x04FC, 1, 0),
- MX7D_PAD_ECSPI1_MOSI__GPIO4_IO17 = IOMUX_PAD(0x03DC, 0x016C, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__EPDC_PWR_STAT = IOMUX_PAD(0x03DC, 0x016C, 6, 0x0580, 1, 0),
- MX7D_PAD_ECSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x03E0, 0x0170, 0, 0x0528, 1, 0),
- MX7D_PAD_ECSPI1_MISO__UART6_DCE_RTS = IOMUX_PAD(0x03E0, 0x0170, 1, 0x0718, 2, 0),
- MX7D_PAD_ECSPI1_MISO__UART6_DTE_CTS = IOMUX_PAD(0x03E0, 0x0170, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__SD2_DATA6 = IOMUX_PAD(0x03E0, 0x0170, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__CSI_DATA4 = IOMUX_PAD(0x03E0, 0x0170, 3, 0x0500, 1, 0),
- MX7D_PAD_ECSPI1_MISO__GPIO4_IO18 = IOMUX_PAD(0x03E0, 0x0170, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__EPDC_PWR_IRQ = IOMUX_PAD(0x03E0, 0x0170, 6, 0x057C, 0, 0),
- MX7D_PAD_ECSPI1_SS0__ECSPI1_SS0 = IOMUX_PAD(0x03E4, 0x0174, 0, 0x0530, 1, 0),
- MX7D_PAD_ECSPI1_SS0__UART6_DCE_CTS = IOMUX_PAD(0x03E4, 0x0174, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__UART6_DTE_RTS = IOMUX_PAD(0x03E4, 0x0174, 1, 0x0718, 3, 0),
- MX7D_PAD_ECSPI1_SS0__SD2_DATA7 = IOMUX_PAD(0x03E4, 0x0174, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__CSI_DATA5 = IOMUX_PAD(0x03E4, 0x0174, 3, 0x0504, 1, 0),
- MX7D_PAD_ECSPI1_SS0__GPIO4_IO19 = IOMUX_PAD(0x03E4, 0x0174, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__EPDC_PWR_CTRL3 = IOMUX_PAD(0x03E4, 0x0174, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__ECSPI2_SCLK = IOMUX_PAD(0x03E8, 0x0178, 0, 0x0534, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__UART7_DCE_RX = IOMUX_PAD(0x03E8, 0x0178, 1, 0x0724, 2, 0),
- MX7D_PAD_ECSPI2_SCLK__UART7_DTE_TX = IOMUX_PAD(0x03E8, 0x0178, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__SD1_DATA4 = IOMUX_PAD(0x03E8, 0x0178, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__CSI_DATA6 = IOMUX_PAD(0x03E8, 0x0178, 3, 0x0508, 1, 0),
- MX7D_PAD_ECSPI2_SCLK__LCD_DATA13 = IOMUX_PAD(0x03E8, 0x0178, 4, 0x066C, 2, 0),
- MX7D_PAD_ECSPI2_SCLK__GPIO4_IO20 = IOMUX_PAD(0x03E8, 0x0178, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__EPDC_PWR_CTRL0 = IOMUX_PAD(0x03E8, 0x0178, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__ECSPI2_MOSI = IOMUX_PAD(0x03EC, 0x017C, 0, 0x053C, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__UART7_DCE_TX = IOMUX_PAD(0x03EC, 0x017C, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__UART7_DTE_RX = IOMUX_PAD(0x03EC, 0x017C, 1, 0x0724, 3, 0),
- MX7D_PAD_ECSPI2_MOSI__SD1_DATA5 = IOMUX_PAD(0x03EC, 0x017C, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__CSI_DATA7 = IOMUX_PAD(0x03EC, 0x017C, 3, 0x050C, 1, 0),
- MX7D_PAD_ECSPI2_MOSI__LCD_DATA14 = IOMUX_PAD(0x03EC, 0x017C, 4, 0x0670, 2, 0),
- MX7D_PAD_ECSPI2_MOSI__GPIO4_IO21 = IOMUX_PAD(0x03EC, 0x017C, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__EPDC_PWR_CTRL1 = IOMUX_PAD(0x03EC, 0x017C, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__GPIO4_IO22 = IOMUX_PAD(0x03F0, 0x0180, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__EPDC_PWR_CTRL2 = IOMUX_PAD(0x03F0, 0x0180, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__ECSPI2_MISO = IOMUX_PAD(0x03F0, 0x0180, 0, 0x0538, 0, 0),
- MX7D_PAD_ECSPI2_MISO__UART7_DCE_RTS = IOMUX_PAD(0x03F0, 0x0180, 1, 0x0720, 2, 0),
- MX7D_PAD_ECSPI2_MISO__UART7_DTE_CTS = IOMUX_PAD(0x03F0, 0x0180, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__SD1_DATA6 = IOMUX_PAD(0x03F0, 0x0180, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__CSI_DATA8 = IOMUX_PAD(0x03F0, 0x0180, 3, 0x0510, 1, 0),
- MX7D_PAD_ECSPI2_MISO__LCD_DATA15 = IOMUX_PAD(0x03F0, 0x0180, 4, 0x0674, 2, 0),
- MX7D_PAD_ECSPI2_SS0__ECSPI2_SS0 = IOMUX_PAD(0x03F4, 0x0184, 0, 0x0540, 0, 0),
- MX7D_PAD_ECSPI2_SS0__UART7_DCE_CTS = IOMUX_PAD(0x03F4, 0x0184, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__UART7_DTE_RTS = IOMUX_PAD(0x03F4, 0x0184, 1, 0x0720, 3, 0),
- MX7D_PAD_ECSPI2_SS0__SD1_DATA7 = IOMUX_PAD(0x03F4, 0x0184, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__CSI_DATA9 = IOMUX_PAD(0x03F4, 0x0184, 3, 0x0514, 1, 0),
- MX7D_PAD_ECSPI2_SS0__LCD_RESET = IOMUX_PAD(0x03F4, 0x0184, 4, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x0184, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__EPDC_PWR_WAKE = IOMUX_PAD(0x03F4, 0x0184, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__SD1_CD_B = IOMUX_PAD(0x03F8, 0x0188, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__UART6_DCE_RX = IOMUX_PAD(0x03F8, 0x0188, 2, 0x071C, 4, 0),
- MX7D_PAD_SD1_CD_B__UART6_DTE_TX = IOMUX_PAD(0x03F8, 0x0188, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__ECSPI4_MISO = IOMUX_PAD(0x03F8, 0x0188, 3, 0x0558, 1, 0),
- MX7D_PAD_SD1_CD_B__FLEXTIMER1_CH0 = IOMUX_PAD(0x03F8, 0x0188, 4, 0x0584, 1, 0),
- MX7D_PAD_SD1_CD_B__GPIO5_IO0 = IOMUX_PAD(0x03F8, 0x0188, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__CCM_CLKO1 = IOMUX_PAD(0x03F8, 0x0188, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__SD1_WP = IOMUX_PAD(0x03FC, 0x018C, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__UART6_DCE_TX = IOMUX_PAD(0x03FC, 0x018C, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__UART6_DTE_RX = IOMUX_PAD(0x03FC, 0x018C, 2, 0x071C, 5, 0),
- MX7D_PAD_SD1_WP__ECSPI4_MOSI = IOMUX_PAD(0x03FC, 0x018C, 3, 0x055C, 1, 0),
- MX7D_PAD_SD1_WP__FLEXTIMER1_CH1 = IOMUX_PAD(0x03FC, 0x018C, 4, 0x0588, 1, 0),
- MX7D_PAD_SD1_WP__GPIO5_IO1 = IOMUX_PAD(0x03FC, 0x018C, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__CCM_CLKO2 = IOMUX_PAD(0x03FC, 0x018C, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__SD1_RESET_B = IOMUX_PAD(0x0400, 0x0190, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__SAI3_MCLK = IOMUX_PAD(0x0400, 0x0190, 1, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__UART6_DCE_RTS = IOMUX_PAD(0x0400, 0x0190, 2, 0x0718, 4, 0),
- MX7D_PAD_SD1_RESET_B__UART6_DTE_CTS = IOMUX_PAD(0x0400, 0x0190, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__ECSPI4_SCLK = IOMUX_PAD(0x0400, 0x0190, 3, 0x0554, 1, 0),
- MX7D_PAD_SD1_RESET_B__FLEXTIMER1_CH2 = IOMUX_PAD(0x0400, 0x0190, 4, 0x058C, 1, 0),
- MX7D_PAD_SD1_RESET_B__GPIO5_IO2 = IOMUX_PAD(0x0400, 0x0190, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x0404, 0x0194, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__SAI3_RX_SYNC = IOMUX_PAD(0x0404, 0x0194, 1, 0x06CC, 1, 0),
- MX7D_PAD_SD1_CLK__UART6_DCE_CTS = IOMUX_PAD(0x0404, 0x0194, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__UART6_DTE_RTS = IOMUX_PAD(0x0404, 0x0194, 2, 0x0718, 5, 0),
- MX7D_PAD_SD1_CLK__ECSPI4_SS0 = IOMUX_PAD(0x0404, 0x0194, 3, 0x0560, 1, 0),
- MX7D_PAD_SD1_CLK__FLEXTIMER1_CH3 = IOMUX_PAD(0x0404, 0x0194, 4, 0x0590, 1, 0),
- MX7D_PAD_SD1_CLK__GPIO5_IO3 = IOMUX_PAD(0x0404, 0x0194, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x0408, 0x0198, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__SAI3_RX_BCLK = IOMUX_PAD(0x0408, 0x0198, 1, 0x06C4, 1, 0),
- MX7D_PAD_SD1_CMD__ECSPI4_SS1 = IOMUX_PAD(0x0408, 0x0198, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__FLEXTIMER2_CH0 = IOMUX_PAD(0x0408, 0x0198, 4, 0x05AC, 1, 0),
- MX7D_PAD_SD1_CMD__GPIO5_IO4 = IOMUX_PAD(0x0408, 0x0198, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x040C, 0x019C, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__SAI3_RX_DATA0 = IOMUX_PAD(0x040C, 0x019C, 1, 0x06C8, 1, 0),
- MX7D_PAD_SD1_DATA0__UART7_DCE_RX = IOMUX_PAD(0x040C, 0x019C, 2, 0x0724, 4, 0),
- MX7D_PAD_SD1_DATA0__UART7_DTE_TX = IOMUX_PAD(0x040C, 0x019C, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__ECSPI4_SS2 = IOMUX_PAD(0x040C, 0x019C, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__FLEXTIMER2_CH1 = IOMUX_PAD(0x040C, 0x019C, 4, 0x05B0, 1, 0),
- MX7D_PAD_SD1_DATA0__GPIO5_IO5 = IOMUX_PAD(0x040C, 0x019C, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__CCM_EXT_CLK1 = IOMUX_PAD(0x040C, 0x019C, 6, 0x04E4, 1, 0),
- MX7D_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x0410, 0x01A0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__SAI3_TX_BCLK = IOMUX_PAD(0x0410, 0x01A0, 1, 0x06D0, 1, 0),
- MX7D_PAD_SD1_DATA1__UART7_DCE_TX = IOMUX_PAD(0x0410, 0x01A0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__UART7_DTE_RX = IOMUX_PAD(0x0410, 0x01A0, 2, 0x0724, 5, 0),
- MX7D_PAD_SD1_DATA1__ECSPI4_SS3 = IOMUX_PAD(0x0410, 0x01A0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__FLEXTIMER2_CH2 = IOMUX_PAD(0x0410, 0x01A0, 4, 0x05B4, 1, 0),
- MX7D_PAD_SD1_DATA1__GPIO5_IO6 = IOMUX_PAD(0x0410, 0x01A0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__CCM_EXT_CLK2 = IOMUX_PAD(0x0410, 0x01A0, 6, 0x04E8, 1, 0),
- MX7D_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x0414, 0x01A4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__SAI3_TX_SYNC = IOMUX_PAD(0x0414, 0x01A4, 1, 0x06D4, 1, 0),
- MX7D_PAD_SD1_DATA2__UART7_DCE_CTS = IOMUX_PAD(0x0414, 0x01A4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__UART7_DTE_RTS = IOMUX_PAD(0x0414, 0x01A4, 2, 0x0720, 4, 0),
- MX7D_PAD_SD1_DATA2__ECSPI4_RDY = IOMUX_PAD(0x0414, 0x01A4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__FLEXTIMER2_CH3 = IOMUX_PAD(0x0414, 0x01A4, 4, 0x05B8, 1, 0),
- MX7D_PAD_SD1_DATA2__GPIO5_IO7 = IOMUX_PAD(0x0414, 0x01A4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__CCM_EXT_CLK3 = IOMUX_PAD(0x0414, 0x01A4, 6, 0x04EC, 1, 0),
- MX7D_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x0418, 0x01A8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__SAI3_TX_DATA0 = IOMUX_PAD(0x0418, 0x01A8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__UART7_DCE_RTS = IOMUX_PAD(0x0418, 0x01A8, 2, 0x0720, 5, 0),
- MX7D_PAD_SD1_DATA3__UART7_DTE_CTS = IOMUX_PAD(0x0418, 0x01A8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__ECSPI3_SS1 = IOMUX_PAD(0x0418, 0x01A8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__FLEXTIMER1_PHA = IOMUX_PAD(0x0418, 0x01A8, 4, 0x05A4, 1, 0),
- MX7D_PAD_SD1_DATA3__GPIO5_IO8 = IOMUX_PAD(0x0418, 0x01A8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__CCM_EXT_CLK4 = IOMUX_PAD(0x0418, 0x01A8, 6, 0x04F0, 1, 0),
- MX7D_PAD_SD2_CD_B__SD2_CD_B = IOMUX_PAD(0x041C, 0x01AC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__ENET1_MDIO = IOMUX_PAD(0x041C, 0x01AC, 1, 0x0568, 2, 0),
- MX7D_PAD_SD2_CD_B__ENET2_MDIO = IOMUX_PAD(0x041C, 0x01AC, 2, 0x0574, 2, 0),
- MX7D_PAD_SD2_CD_B__ECSPI3_SS2 = IOMUX_PAD(0x041C, 0x01AC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__FLEXTIMER1_PHB = IOMUX_PAD(0x041C, 0x01AC, 4, 0x05A8, 1, 0),
- MX7D_PAD_SD2_CD_B__GPIO5_IO9 = IOMUX_PAD(0x041C, 0x01AC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__SDMA_EXT_EVENT0 = IOMUX_PAD(0x041C, 0x01AC, 6, 0x06D8, 2, 0),
- MX7D_PAD_SD2_WP__SD2_WP = IOMUX_PAD(0x0420, 0x01B0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ENET1_MDC = IOMUX_PAD(0x0420, 0x01B0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ENET2_MDC = IOMUX_PAD(0x0420, 0x01B0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ECSPI3_SS3 = IOMUX_PAD(0x0420, 0x01B0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__USB_OTG1_ID = IOMUX_PAD(0x0420, 0x01B0, 4, 0x0734, 2, 0),
- MX7D_PAD_SD2_WP__GPIO5_IO10 = IOMUX_PAD(0x0420, 0x01B0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0420, 0x01B0, 6, 0x06DC, 2, 0),
- MX7D_PAD_SD2_RESET_B__SD2_RESET_B = IOMUX_PAD(0x0424, 0x01B4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__SAI2_MCLK = IOMUX_PAD(0x0424, 0x01B4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__SD2_RESET = IOMUX_PAD(0x0424, 0x01B4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__ECSPI3_RDY = IOMUX_PAD(0x0424, 0x01B4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__USB_OTG2_ID = IOMUX_PAD(0x0424, 0x01B4, 4, 0x0730, 2, 0),
- MX7D_PAD_SD2_RESET_B__GPIO5_IO11 = IOMUX_PAD(0x0424, 0x01B4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x0428, 0x01B8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__SAI2_RX_SYNC = IOMUX_PAD(0x0428, 0x01B8, 1, 0x06B8, 0, 0),
- MX7D_PAD_SD2_CLK__MQS_RIGHT = IOMUX_PAD(0x0428, 0x01B8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__GPT4_CLK = IOMUX_PAD(0x0428, 0x01B8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__GPIO5_IO12 = IOMUX_PAD(0x0428, 0x01B8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x042C, 0x01BC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SAI2_RX_BCLK = IOMUX_PAD(0x042C, 0x01BC, 1, 0x06B0, 0, 0),
- MX7D_PAD_SD2_CMD__MQS_LEFT = IOMUX_PAD(0x042C, 0x01BC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__GPT4_CAPTURE1 = IOMUX_PAD(0x042C, 0x01BC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SIM2_PORT1_TRXD = IOMUX_PAD(0x042C, 0x01BC, 4, 0x06EC, 1, 0),
- MX7D_PAD_SD2_CMD__GPIO5_IO13 = IOMUX_PAD(0x042C, 0x01BC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SD2_DATA0 = IOMUX_PAD(0x0430, 0x01C0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SAI2_RX_DATA0 = IOMUX_PAD(0x0430, 0x01C0, 1, 0x06B4, 0, 0),
- MX7D_PAD_SD2_DATA0__UART4_DCE_RX = IOMUX_PAD(0x0430, 0x01C0, 2, 0x070C, 2, 0),
- MX7D_PAD_SD2_DATA0__UART4_DTE_TX = IOMUX_PAD(0x0430, 0x01C0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__GPT4_CAPTURE2 = IOMUX_PAD(0x0430, 0x01C0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SIM2_PORT1_CLK = IOMUX_PAD(0x0430, 0x01C0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__GPIO5_IO14 = IOMUX_PAD(0x0430, 0x01C0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SD2_DATA1 = IOMUX_PAD(0x0434, 0x01C4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SAI2_TX_BCLK = IOMUX_PAD(0x0434, 0x01C4, 1, 0x06BC, 0, 0),
- MX7D_PAD_SD2_DATA1__UART4_DCE_TX = IOMUX_PAD(0x0434, 0x01C4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__UART4_DTE_RX = IOMUX_PAD(0x0434, 0x01C4, 2, 0x070C, 3, 0),
- MX7D_PAD_SD2_DATA1__GPT4_COMPARE1 = IOMUX_PAD(0x0434, 0x01C4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SIM2_PORT1_RST_B = IOMUX_PAD(0x0434, 0x01C4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__GPIO5_IO15 = IOMUX_PAD(0x0434, 0x01C4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SD2_DATA2 = IOMUX_PAD(0x0438, 0x01C8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SAI2_TX_SYNC = IOMUX_PAD(0x0438, 0x01C8, 1, 0x06C0, 0, 0),
- MX7D_PAD_SD2_DATA2__UART4_DCE_CTS = IOMUX_PAD(0x0438, 0x01C8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__UART4_DTE_RTS = IOMUX_PAD(0x0438, 0x01C8, 2, 0x0708, 2, 0),
- MX7D_PAD_SD2_DATA2__GPT4_COMPARE2 = IOMUX_PAD(0x0438, 0x01C8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SIM2_PORT1_SVEN = IOMUX_PAD(0x0438, 0x01C8, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__GPIO5_IO16 = IOMUX_PAD(0x0438, 0x01C8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SD2_DATA3 = IOMUX_PAD(0x043C, 0x01CC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SAI2_TX_DATA0 = IOMUX_PAD(0x043C, 0x01CC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__UART4_DCE_RTS = IOMUX_PAD(0x043C, 0x01CC, 2, 0x0708, 3, 0),
- MX7D_PAD_SD2_DATA3__UART4_DTE_CTS = IOMUX_PAD(0x043C, 0x01CC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__GPT4_COMPARE3 = IOMUX_PAD(0x043C, 0x01CC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SIM2_PORT1_PD = IOMUX_PAD(0x043C, 0x01CC, 4, 0x06E8, 1, 0),
- MX7D_PAD_SD2_DATA3__GPIO5_IO17 = IOMUX_PAD(0x043C, 0x01CC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x0440, 0x01D0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__NAND_CLE = IOMUX_PAD(0x0440, 0x01D0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__ECSPI4_MISO = IOMUX_PAD(0x0440, 0x01D0, 2, 0x0558, 2, 0),
- MX7D_PAD_SD3_CLK__SAI3_RX_SYNC = IOMUX_PAD(0x0440, 0x01D0, 3, 0x06CC, 2, 0),
- MX7D_PAD_SD3_CLK__GPT3_CLK = IOMUX_PAD(0x0440, 0x01D0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__GPIO6_IO0 = IOMUX_PAD(0x0440, 0x01D0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x0444, 0x01D4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__NAND_ALE = IOMUX_PAD(0x0444, 0x01D4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__ECSPI4_MOSI = IOMUX_PAD(0x0444, 0x01D4, 2, 0x055C, 2, 0),
- MX7D_PAD_SD3_CMD__SAI3_RX_BCLK = IOMUX_PAD(0x0444, 0x01D4, 3, 0x06C4, 2, 0),
- MX7D_PAD_SD3_CMD__GPT3_CAPTURE1 = IOMUX_PAD(0x0444, 0x01D4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__GPIO6_IO1 = IOMUX_PAD(0x0444, 0x01D4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__SD3_DATA0 = IOMUX_PAD(0x0448, 0x01D8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__NAND_DATA00 = IOMUX_PAD(0x0448, 0x01D8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__ECSPI4_SS0 = IOMUX_PAD(0x0448, 0x01D8, 2, 0x0560, 2, 0),
- MX7D_PAD_SD3_DATA0__SAI3_RX_DATA0 = IOMUX_PAD(0x0448, 0x01D8, 3, 0x06C8, 2, 0),
- MX7D_PAD_SD3_DATA0__GPT3_CAPTURE2 = IOMUX_PAD(0x0448, 0x01D8, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__GPIO6_IO2 = IOMUX_PAD(0x0448, 0x01D8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__SD3_DATA1 = IOMUX_PAD(0x044C, 0x01DC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__NAND_DATA01 = IOMUX_PAD(0x044C, 0x01DC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__ECSPI4_SCLK = IOMUX_PAD(0x044C, 0x01DC, 2, 0x0554, 2, 0),
- MX7D_PAD_SD3_DATA1__SAI3_TX_BCLK = IOMUX_PAD(0x044C, 0x01DC, 3, 0x06D0, 2, 0),
- MX7D_PAD_SD3_DATA1__GPT3_COMPARE1 = IOMUX_PAD(0x044C, 0x01DC, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__GPIO6_IO3 = IOMUX_PAD(0x044C, 0x01DC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__SD3_DATA2 = IOMUX_PAD(0x0450, 0x01E0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__NAND_DATA02 = IOMUX_PAD(0x0450, 0x01E0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__I2C3_SDA = IOMUX_PAD(0x0450, 0x01E0, IOMUX_CONFIG_SION | 2, 0x05E8, 3, 0),
- MX7D_PAD_SD3_DATA2__SAI3_TX_SYNC = IOMUX_PAD(0x0450, 0x01E0, 3, 0x06D4, 2, 0),
- MX7D_PAD_SD3_DATA2__GPT3_COMPARE2 = IOMUX_PAD(0x0450, 0x01E0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__GPIO6_IO4 = IOMUX_PAD(0x0450, 0x01E0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__SD3_DATA3 = IOMUX_PAD(0x0454, 0x01E4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__NAND_DATA03 = IOMUX_PAD(0x0454, 0x01E4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__I2C3_SCL = IOMUX_PAD(0x0454, 0x01E4, IOMUX_CONFIG_SION | 2, 0x05E4, 3, 0),
- MX7D_PAD_SD3_DATA3__SAI3_TX_DATA0 = IOMUX_PAD(0x0454, 0x01E4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__GPT3_COMPARE3 = IOMUX_PAD(0x0454, 0x01E4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__GPIO6_IO5 = IOMUX_PAD(0x0454, 0x01E4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__SD3_DATA4 = IOMUX_PAD(0x0458, 0x01E8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__NAND_DATA04 = IOMUX_PAD(0x0458, 0x01E8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__UART3_DCE_RX = IOMUX_PAD(0x0458, 0x01E8, 3, 0x0704, 4, 0),
- MX7D_PAD_SD3_DATA4__UART3_DTE_TX = IOMUX_PAD(0x0458, 0x01E8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__FLEXCAN2_RX = IOMUX_PAD(0x0458, 0x01E8, 4, 0x04E0, 2, 0),
- MX7D_PAD_SD3_DATA4__GPIO6_IO6 = IOMUX_PAD(0x0458, 0x01E8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__SD3_DATA5 = IOMUX_PAD(0x045C, 0x01EC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__NAND_DATA05 = IOMUX_PAD(0x045C, 0x01EC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__UART3_DCE_TX = IOMUX_PAD(0x045C, 0x01EC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__UART3_DTE_RX = IOMUX_PAD(0x045C, 0x01EC, 3, 0x0704, 5, 0),
- MX7D_PAD_SD3_DATA5__FLEXCAN1_TX = IOMUX_PAD(0x045C, 0x01EC, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__GPIO6_IO7 = IOMUX_PAD(0x045C, 0x01EC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__SD3_DATA6 = IOMUX_PAD(0x0460, 0x01F0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__NAND_DATA06 = IOMUX_PAD(0x0460, 0x01F0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__SD3_WP = IOMUX_PAD(0x0460, 0x01F0, 2, 0x073C, 2, 0),
- MX7D_PAD_SD3_DATA6__UART3_DCE_RTS = IOMUX_PAD(0x0460, 0x01F0, 3, 0x0700, 4, 0),
- MX7D_PAD_SD3_DATA6__UART3_DTE_CTS = IOMUX_PAD(0x0460, 0x01F0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__FLEXCAN2_TX = IOMUX_PAD(0x0460, 0x01F0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__GPIO6_IO8 = IOMUX_PAD(0x0460, 0x01F0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__SD3_DATA7 = IOMUX_PAD(0x0464, 0x01F4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__NAND_DATA07 = IOMUX_PAD(0x0464, 0x01F4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__SD3_CD_B = IOMUX_PAD(0x0464, 0x01F4, 2, 0x0738, 2, 0),
- MX7D_PAD_SD3_DATA7__UART3_DCE_CTS = IOMUX_PAD(0x0464, 0x01F4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__UART3_DTE_RTS = IOMUX_PAD(0x0464, 0x01F4, 3, 0x0700, 5, 0),
- MX7D_PAD_SD3_DATA7__FLEXCAN1_RX = IOMUX_PAD(0x0464, 0x01F4, 4, 0x04DC, 2, 0),
- MX7D_PAD_SD3_DATA7__GPIO6_IO9 = IOMUX_PAD(0x0464, 0x01F4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__SD3_STROBE = IOMUX_PAD(0x0468, 0x01F8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__NAND_RE_B = IOMUX_PAD(0x0468, 0x01F8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__GPIO6_IO10 = IOMUX_PAD(0x0468, 0x01F8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SD3_RESET_B = IOMUX_PAD(0x046C, 0x01FC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__NAND_WE_B = IOMUX_PAD(0x046C, 0x01FC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SD3_RESET = IOMUX_PAD(0x046C, 0x01FC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SAI3_MCLK = IOMUX_PAD(0x046C, 0x01FC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__GPIO6_IO11 = IOMUX_PAD(0x046C, 0x01FC, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__SAI1_RX_DATA0 = IOMUX_PAD(0x0470, 0x0200, 0, 0x06A0, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__NAND_CE1_B = IOMUX_PAD(0x0470, 0x0200, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__UART5_DCE_RX = IOMUX_PAD(0x0470, 0x0200, 2, 0x0714, 2, 0),
- MX7D_PAD_SAI1_RX_DATA__UART5_DTE_TX = IOMUX_PAD(0x0470, 0x0200, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__FLEXCAN1_RX = IOMUX_PAD(0x0470, 0x0200, 3, 0x04DC, 3, 0),
- MX7D_PAD_SAI1_RX_DATA__SIM1_PORT1_TRXD = IOMUX_PAD(0x0470, 0x0200, 4, 0x06E4, 1, 0),
- MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12 = IOMUX_PAD(0x0470, 0x0200, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__SRC_ANY_PU_RESET = IOMUX_PAD(0x0470, 0x0200, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SAI1_TX_BCLK = IOMUX_PAD(0x0474, 0x0204, 0, 0x06A8, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B = IOMUX_PAD(0x0474, 0x0204, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__UART5_DCE_TX = IOMUX_PAD(0x0474, 0x0204, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__UART5_DTE_RX = IOMUX_PAD(0x0474, 0x0204, 2, 0x0714, 3, 0),
- MX7D_PAD_SAI1_TX_BCLK__FLEXCAN1_TX = IOMUX_PAD(0x0474, 0x0204, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SIM1_PORT1_CLK = IOMUX_PAD(0x0474, 0x0204, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__GPIO6_IO13 = IOMUX_PAD(0x0474, 0x0204, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SRC_EARLY_RESET = IOMUX_PAD(0x0474, 0x0204, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__SAI1_TX_SYNC = IOMUX_PAD(0x0478, 0x0208, 0, 0x06AC, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__NAND_DQS = IOMUX_PAD(0x0478, 0x0208, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__UART5_DCE_CTS = IOMUX_PAD(0x0478, 0x0208, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__UART5_DTE_RTS = IOMUX_PAD(0x0478, 0x0208, 2, 0x0710, 2, 0),
- MX7D_PAD_SAI1_TX_SYNC__FLEXCAN2_RX = IOMUX_PAD(0x0478, 0x0208, 3, 0x04E0, 3, 0),
- MX7D_PAD_SAI1_TX_SYNC__SIM1_PORT1_RST_B = IOMUX_PAD(0x0478, 0x0208, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__GPIO6_IO14 = IOMUX_PAD(0x0478, 0x0208, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__SRC_INT_BOOT = IOMUX_PAD(0x0478, 0x0208, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SAI1_TX_DATA0 = IOMUX_PAD(0x047C, 0x020C, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__NAND_READY_B = IOMUX_PAD(0x047C, 0x020C, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__UART5_DCE_RTS = IOMUX_PAD(0x047C, 0x020C, 2, 0x0710, 3, 0),
- MX7D_PAD_SAI1_TX_DATA__UART5_DTE_CTS = IOMUX_PAD(0x047C, 0x020C, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__FLEXCAN2_TX = IOMUX_PAD(0x047C, 0x020C, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SIM1_PORT1_SVEN = IOMUX_PAD(0x047C, 0x020C, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__GPIO6_IO15 = IOMUX_PAD(0x047C, 0x020C, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SRC_SYSTEM_RESET = IOMUX_PAD(0x047C, 0x020C, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SAI1_RX_SYNC = IOMUX_PAD(0x0480, 0x0210, 0, 0x06A4, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__NAND_CE2_B = IOMUX_PAD(0x0480, 0x0210, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SAI2_RX_SYNC = IOMUX_PAD(0x0480, 0x0210, 2, 0x06B8, 1, 0),
- MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL = IOMUX_PAD(0x0480, 0x0210, IOMUX_CONFIG_SION | 3, 0x05EC, 3, 0),
- MX7D_PAD_SAI1_RX_SYNC__SIM1_PORT1_PD = IOMUX_PAD(0x0480, 0x0210, 4, 0x06E0, 1, 0),
- MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16 = IOMUX_PAD(0x0480, 0x0210, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__MQS_RIGHT = IOMUX_PAD(0x0480, 0x0210, 6, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SRC_CA7_RESET_B0 = IOMUX_PAD(0x0480, 0x0210, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SAI1_RX_BCLK = IOMUX_PAD(0x0484, 0x0214, 0, 0x069C, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__NAND_CE3_B = IOMUX_PAD(0x0484, 0x0214, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SAI2_RX_BCLK = IOMUX_PAD(0x0484, 0x0214, 2, 0x06B0, 1, 0),
- MX7D_PAD_SAI1_RX_BCLK__I2C4_SDA = IOMUX_PAD(0x0484, 0x0214, IOMUX_CONFIG_SION | 3, 0x05F0, 3, 0),
- MX7D_PAD_SAI1_RX_BCLK__FLEXTIMER2_PHA = IOMUX_PAD(0x0484, 0x0214, 4, 0x05CC, 1, 0),
- MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 = IOMUX_PAD(0x0484, 0x0214, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__MQS_LEFT = IOMUX_PAD(0x0484, 0x0214, 6, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SRC_CA7_RESET_B1 = IOMUX_PAD(0x0484, 0x0214, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SAI1_MCLK = IOMUX_PAD(0x0488, 0x0218, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__NAND_WP_B = IOMUX_PAD(0x0488, 0x0218, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SAI2_MCLK = IOMUX_PAD(0x0488, 0x0218, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__CCM_PMIC_READY = IOMUX_PAD(0x0488, 0x0218, 3, 0x04F4, 3, 0),
- MX7D_PAD_SAI1_MCLK__FLEXTIMER2_PHB = IOMUX_PAD(0x0488, 0x0218, 4, 0x05D0, 1, 0),
- MX7D_PAD_SAI1_MCLK__GPIO6_IO18 = IOMUX_PAD(0x0488, 0x0218, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SRC_TESTER_ACK = IOMUX_PAD(0x0488, 0x0218, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__SAI2_TX_SYNC = IOMUX_PAD(0x048C, 0x021C, 0, 0x06C0, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x021C, 1, 0x0548, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART4_DCE_RX = IOMUX_PAD(0x048C, 0x021C, 2, 0x070C, 4, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART4_DTE_TX = IOMUX_PAD(0x048C, 0x021C, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART1_DCE_CTS = IOMUX_PAD(0x048C, 0x021C, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART1_DTE_RTS = IOMUX_PAD(0x048C, 0x021C, 3, 0x06F0, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__FLEXTIMER2_CH4 = IOMUX_PAD(0x048C, 0x021C, 4, 0x05BC, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__GPIO6_IO19 = IOMUX_PAD(0x048C, 0x021C, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__SAI2_TX_BCLK = IOMUX_PAD(0x0490, 0x0220, 0, 0x06BC, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__ECSPI3_MOSI = IOMUX_PAD(0x0490, 0x0220, 1, 0x054C, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART4_DCE_TX = IOMUX_PAD(0x0490, 0x0220, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART4_DTE_RX = IOMUX_PAD(0x0490, 0x0220, 2, 0x070C, 5, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART1_DCE_RTS = IOMUX_PAD(0x0490, 0x0220, 3, 0x06F0, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART1_DTE_CTS = IOMUX_PAD(0x0490, 0x0220, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__FLEXTIMER2_CH5 = IOMUX_PAD(0x0490, 0x0220, 4, 0x05C0, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__GPIO6_IO20 = IOMUX_PAD(0x0490, 0x0220, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__SAI2_RX_DATA0 = IOMUX_PAD(0x0494, 0x0224, 0, 0x06B4, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK = IOMUX_PAD(0x0494, 0x0224, 1, 0x0544, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__UART4_DCE_CTS = IOMUX_PAD(0x0494, 0x0224, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__UART4_DTE_RTS = IOMUX_PAD(0x0494, 0x0224, 2, 0x0708, 4, 0),
- MX7D_PAD_SAI2_RX_DATA__UART2_DCE_CTS = IOMUX_PAD(0x0494, 0x0224, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__UART2_DTE_RTS = IOMUX_PAD(0x0494, 0x0224, 3, 0x06F8, 2, 0),
- MX7D_PAD_SAI2_RX_DATA__FLEXTIMER2_CH6 = IOMUX_PAD(0x0494, 0x0224, 4, 0x05C4, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__GPIO6_IO21 = IOMUX_PAD(0x0494, 0x0224, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__KPP_COL7 = IOMUX_PAD(0x0494, 0x0224, 6, 0x0610, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__SAI2_TX_DATA0 = IOMUX_PAD(0x0498, 0x0228, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__ECSPI3_SS0 = IOMUX_PAD(0x0498, 0x0228, 1, 0x0550, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__UART4_DCE_RTS = IOMUX_PAD(0x0498, 0x0228, 2, 0x0708, 5, 0),
- MX7D_PAD_SAI2_TX_DATA__UART4_DTE_CTS = IOMUX_PAD(0x0498, 0x0228, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__UART2_DCE_RTS = IOMUX_PAD(0x0498, 0x0228, 3, 0x06F8, 3, 0),
- MX7D_PAD_SAI2_TX_DATA__UART2_DTE_CTS = IOMUX_PAD(0x0498, 0x0228, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__FLEXTIMER2_CH7 = IOMUX_PAD(0x0498, 0x0228, 4, 0x05C8, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 = IOMUX_PAD(0x0498, 0x0228, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__KPP_ROW7 = IOMUX_PAD(0x0498, 0x0228, 6, 0x0630, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 = IOMUX_PAD(0x049C, 0x022C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__PWM1_OUT = IOMUX_PAD(0x049C, 0x022C, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__I2C3_SCL = IOMUX_PAD(0x049C, 0x022C, IOMUX_CONFIG_SION | 2, 0x05E4, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD0__UART1_DCE_CTS = IOMUX_PAD(0x049C, 0x022C, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__UART1_DTE_RTS = IOMUX_PAD(0x049C, 0x022C, 3, 0x06F0, 2, 0),
- MX7D_PAD_ENET1_RGMII_RD0__EPDC_VCOM0 = IOMUX_PAD(0x049C, 0x022C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__GPIO7_IO0 = IOMUX_PAD(0x049C, 0x022C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__KPP_ROW3 = IOMUX_PAD(0x049C, 0x022C, 6, 0x0620, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 = IOMUX_PAD(0x04A0, 0x0230, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__PWM2_OUT = IOMUX_PAD(0x04A0, 0x0230, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__I2C3_SDA = IOMUX_PAD(0x04A0, 0x0230, IOMUX_CONFIG_SION | 2, 0x05E8, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD1__UART1_DCE_RTS = IOMUX_PAD(0x04A0, 0x0230, 3, 0x06F0, 3, 0),
- MX7D_PAD_ENET1_RGMII_RD1__UART1_DTE_CTS = IOMUX_PAD(0x04A0, 0x0230, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__EPDC_VCOM1 = IOMUX_PAD(0x04A0, 0x0230, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__GPIO7_IO1 = IOMUX_PAD(0x04A0, 0x0230, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__KPP_COL3 = IOMUX_PAD(0x04A0, 0x0230, 6, 0x0600, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 = IOMUX_PAD(0x04A4, 0x0234, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__FLEXCAN1_RX = IOMUX_PAD(0x04A4, 0x0234, 1, 0x04DC, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD2__ECSPI2_SCLK = IOMUX_PAD(0x04A4, 0x0234, 2, 0x0534, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD2__UART1_DCE_RX = IOMUX_PAD(0x04A4, 0x0234, 3, 0x06F4, 2, 0),
- MX7D_PAD_ENET1_RGMII_RD2__UART1_DTE_TX = IOMUX_PAD(0x04A4, 0x0234, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__EPDC_SDCE4 = IOMUX_PAD(0x04A4, 0x0234, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__GPIO7_IO2 = IOMUX_PAD(0x04A4, 0x0234, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__KPP_ROW2 = IOMUX_PAD(0x04A4, 0x0234, 6, 0x061C, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 = IOMUX_PAD(0x04A8, 0x0238, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__FLEXCAN1_TX = IOMUX_PAD(0x04A8, 0x0238, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__ECSPI2_MOSI = IOMUX_PAD(0x04A8, 0x0238, 2, 0x053C, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD3__UART1_DCE_TX = IOMUX_PAD(0x04A8, 0x0238, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__UART1_DTE_RX = IOMUX_PAD(0x04A8, 0x0238, 3, 0x06F4, 3, 0),
- MX7D_PAD_ENET1_RGMII_RD3__EPDC_SDCE5 = IOMUX_PAD(0x04A8, 0x0238, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__GPIO7_IO3 = IOMUX_PAD(0x04A8, 0x0238, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__KPP_COL2 = IOMUX_PAD(0x04A8, 0x0238, 6, 0x05FC, 1, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL = IOMUX_PAD(0x04AC, 0x023C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__ECSPI2_SS1 = IOMUX_PAD(0x04AC, 0x023C, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__EPDC_SDCE6 = IOMUX_PAD(0x04AC, 0x023C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__GPIO7_IO4 = IOMUX_PAD(0x04AC, 0x023C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__KPP_ROW1 = IOMUX_PAD(0x04AC, 0x023C, 6, 0x0618, 1, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC = IOMUX_PAD(0x04B0, 0x0240, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ENET1_RX_ER = IOMUX_PAD(0x04B0, 0x0240, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ECSPI2_SS2 = IOMUX_PAD(0x04B0, 0x0240, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__EPDC_SDCE7 = IOMUX_PAD(0x04B0, 0x0240, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__GPIO7_IO5 = IOMUX_PAD(0x04B0, 0x0240, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__KPP_COL1 = IOMUX_PAD(0x04B0, 0x0240, 6, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 = IOMUX_PAD(0x04B4, 0x0244, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__PWM3_OUT = IOMUX_PAD(0x04B4, 0x0244, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__ECSPI2_SS3 = IOMUX_PAD(0x04B4, 0x0244, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__EPDC_SDCE8 = IOMUX_PAD(0x04B4, 0x0244, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__GPIO7_IO6 = IOMUX_PAD(0x04B4, 0x0244, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__KPP_ROW0 = IOMUX_PAD(0x04B4, 0x0244, 6, 0x0614, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 = IOMUX_PAD(0x04B8, 0x0248, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__PWM4_OUT = IOMUX_PAD(0x04B8, 0x0248, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__ECSPI2_RDY = IOMUX_PAD(0x04B8, 0x0248, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__EPDC_SDCE9 = IOMUX_PAD(0x04B8, 0x0248, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__GPIO7_IO7 = IOMUX_PAD(0x04B8, 0x0248, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__KPP_COL0 = IOMUX_PAD(0x04B8, 0x0248, 6, 0x05F4, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 = IOMUX_PAD(0x04BC, 0x024C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD2__FLEXCAN2_RX = IOMUX_PAD(0x04BC, 0x024C, 1, 0x04E0, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD2__ECSPI2_MISO = IOMUX_PAD(0x04BC, 0x024C, 2, 0x0538, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD2__I2C4_SCL = IOMUX_PAD(0x04BC, 0x024C, IOMUX_CONFIG_SION | 3, 0x05EC, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD2__EPDC_SDOED = IOMUX_PAD(0x04BC, 0x024C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD2__GPIO7_IO8 = IOMUX_PAD(0x04BC, 0x024C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 = IOMUX_PAD(0x04C0, 0x0250, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__FLEXCAN2_TX = IOMUX_PAD(0x04C0, 0x0250, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__ECSPI2_SS0 = IOMUX_PAD(0x04C0, 0x0250, 2, 0x0540, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD3__I2C4_SDA = IOMUX_PAD(0x04C0, 0x0250, IOMUX_CONFIG_SION | 3, 0x05F0, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD3__EPDC_SDOEZ = IOMUX_PAD(0x04C0, 0x0250, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__GPIO7_IO9 = IOMUX_PAD(0x04C0, 0x0250, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__CAAM_RNG_OSC_OBS = IOMUX_PAD(0x04C0, 0x0250, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL = IOMUX_PAD(0x04C4, 0x0254, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__SAI1_RX_SYNC = IOMUX_PAD(0x04C4, 0x0254, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__GPT2_COMPARE1 = IOMUX_PAD(0x04C4, 0x0254, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04C4, 0x0254, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__GPIO7_IO10 = IOMUX_PAD(0x04C4, 0x0254, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC = IOMUX_PAD(0x04C8, 0x0258, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__ENET1_TX_ER = IOMUX_PAD(0x04C8, 0x0258, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__SAI1_RX_BCLK = IOMUX_PAD(0x04C8, 0x0258, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__GPT2_COMPARE2 = IOMUX_PAD(0x04C8, 0x0258, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__EPDC_PWR_CTRL3 = IOMUX_PAD(0x04C8, 0x0258, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__GPIO7_IO11 = IOMUX_PAD(0x04C8, 0x0258, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__ENET1_TX_CLK = IOMUX_PAD(0x04CC, 0x025C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__CCM_ENET_REF_CLK1 = IOMUX_PAD(0x04CC, 0x025C, 1, 0x0564, 2, 0),
- MX7D_PAD_ENET1_TX_CLK__SAI1_RX_DATA0 = IOMUX_PAD(0x04CC, 0x025C, 2, 0x06A0, 1, 0),
- MX7D_PAD_ENET1_TX_CLK__GPT2_COMPARE3 = IOMUX_PAD(0x04CC, 0x025C, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__EPDC_PWR_IRQ = IOMUX_PAD(0x04CC, 0x025C, 4, 0x057C, 1, 0),
- MX7D_PAD_ENET1_TX_CLK__GPIO7_IO12 = IOMUX_PAD(0x04CC, 0x025C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__CCM_EXT_CLK1 = IOMUX_PAD(0x04CC, 0x025C, 6, 0x04E4, 2, 0),
- MX7D_PAD_ENET1_TX_CLK__CSU_ALARM_AUT0 = IOMUX_PAD(0x04CC, 0x025C, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__ENET1_RX_CLK = IOMUX_PAD(0x04D0, 0x0260, 0, 0x056C, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__WDOG2_WDOG_B = IOMUX_PAD(0x04D0, 0x0260, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__SAI1_TX_BCLK = IOMUX_PAD(0x04D0, 0x0260, 2, 0x06A8, 1, 0),
- MX7D_PAD_ENET1_RX_CLK__GPT2_CLK = IOMUX_PAD(0x04D0, 0x0260, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__EPDC_PWR_WAKE = IOMUX_PAD(0x04D0, 0x0260, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__GPIO7_IO13 = IOMUX_PAD(0x04D0, 0x0260, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__CCM_EXT_CLK2 = IOMUX_PAD(0x04D0, 0x0260, 6, 0x04E8, 2, 0),
- MX7D_PAD_ENET1_RX_CLK__CSU_ALARM_AUT1 = IOMUX_PAD(0x04D0, 0x0260, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__ENET1_CRS = IOMUX_PAD(0x04D4, 0x0264, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x04D4, 0x0264, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__SAI1_TX_SYNC = IOMUX_PAD(0x04D4, 0x0264, 2, 0x06AC, 1, 0),
- MX7D_PAD_ENET1_CRS__GPT2_CAPTURE1 = IOMUX_PAD(0x04D4, 0x0264, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04D4, 0x0264, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__GPIO7_IO14 = IOMUX_PAD(0x04D4, 0x0264, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__CCM_EXT_CLK3 = IOMUX_PAD(0x04D4, 0x0264, 6, 0x04EC, 2, 0),
- MX7D_PAD_ENET1_CRS__CSU_ALARM_AUT2 = IOMUX_PAD(0x04D4, 0x0264, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__ENET1_COL = IOMUX_PAD(0x04D8, 0x0268, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__WDOG1_WDOG_ANY = IOMUX_PAD(0x04D8, 0x0268, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__SAI1_TX_DATA0 = IOMUX_PAD(0x04D8, 0x0268, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__GPT2_CAPTURE2 = IOMUX_PAD(0x04D8, 0x0268, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04D8, 0x0268, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__GPIO7_IO15 = IOMUX_PAD(0x04D8, 0x0268, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__CCM_EXT_CLK4 = IOMUX_PAD(0x04D8, 0x0268, 6, 0x04F0, 2, 0),
- MX7D_PAD_ENET1_COL__CSU_INT_DEB = IOMUX_PAD(0x04D8, 0x0268, 7, 0x0000, 0, 0),
+}; +#endif /* __ASM_ARCH_IMX7D_PINS_H__ */ diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 2581019..5dd64f5 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -85,6 +85,36 @@ typedef u64 iomux_v3_cfg_t;
#define NO_PAD_CTRL (1 << 17)
+#ifdef CONFIG_MX7
+#define IOMUX_LPSR_SEL_INPUT_OFS 0x70000 +#define IOMUX_CONFIG_LPSR 0x8 +#define MUX_MODE_LPSR ((iomux_v3_cfg_t)IOMUX_CONFIG_LPSR << \
MUX_MODE_SHIFT)
+#define PAD_CTL_DSE_1P8V_140OHM (0x0<<0) +#define PAD_CTL_DSE_1P8V_35OHM (0x1<<0) +#define PAD_CTL_DSE_1P8V_70OHM (0x2<<0) +#define PAD_CTL_DSE_1P8V_23OHM (0x3<<0)
+#define PAD_CTL_DSE_3P3V_196OHM (0x0<<0) +#define PAD_CTL_DSE_3P3V_49OHM (0x1<<0) +#define PAD_CTL_DSE_3P3V_98OHM (0x2<<0) +#define PAD_CTL_DSE_3P3V_32OHM (0x3<<0)
+#define PAD_CTL_SRE_FAST (0 << 2) +#define PAD_CTL_SRE_SLOW (0x1 << 2)
+#define PAD_CTL_HYS (0x1 << 3) +#define PAD_CTL_PUE (0x1 << 4)
+#define PAD_CTL_PUS_PD100KOHM ((0x0 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU5KOHM ((0x1 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU47KOHM ((0x2 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU100KOHM ((0x3 << 5) | PAD_CTL_PUE)
+#else
#ifdef CONFIG_MX6
#define PAD_CTL_HYS (1 << 16) @@ -167,6 +197,8 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_SRE_SLOW (0 << 0) #define PAD_CTL_SRE_FAST (1 << 0)
#define IOMUX_CONFIG_SION 0x10
#define GPIO_PIN_MASK 0x1f
Best regards, Stefano Babic
Hi Stefano,
-----Original Message----- From: Stefano Babic [mailto:sbabic@denx.de] Sent: Sunday, July 26, 2015 9:15 AM To: Alonso Lazcano Adrian-B38018; u-boot@lists.denx.de; sbabic@denx.de Cc: otavio@ossystems.com.br; Estevam Fabio-R49496; Li Frank-B20596; Garg Nitin-B37173 Subject: Re: [PATCH 04/15][v3] imx: iomux-v3: add imx7d support for iomuxc
Hi Adrian,
On 23/07/2015 00:24, Adrian Alonso wrote:
- Add imx7d support for iomux controller
- imx7d has two iomux controllers iomuxc (0x3033000) and iomuxc-lpsr (0x302C0000) each conroller provides control and mux mode pad registers but shares iomuxc input select register with iomuxc-lpsr IOMUX_CONFIG_LPSR flag is used to properly set daisy chain settings for iomuxc-lpsr pads.
- Since mx7d introduces LPSR IOMUX pins, add new base to IOMUX v3 driver for these LPSR pins.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Signed-off-by: Ye.Li B37916@freescale.com
Changes for V2:
- Update commit log information
Changes for V3: Resend
arch/arm/imx-common/iomux-v3.c | 20 +- arch/arm/include/asm/arch-mx7/mx7-pins.h | 19 + arch/arm/include/asm/arch-mx7/mx7d_pins.h | 1308
arch/arm/include/asm/imx-common/iomux-v3.h | 32 + 4 files changed, 1378 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx7/mx7-pins.h create mode 100644 arch/arm/include/asm/arch-mx7/mx7d_pins.h
diff --git a/arch/arm/imx-common/iomux-v3.c b/arch/arm/imx-
common/iomux-v3.c
index 7fb23dd..07e75a6 100644 --- a/arch/arm/imx-common/iomux-v3.c +++ b/arch/arm/imx-common/iomux-v3.c @@ -4,7 +4,7 @@
- Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH,
<armlinux@phytec.de>
- Copyright (C) 2004-2011 Freescale Semiconductor, Inc.
- Copyright (C) 2004-2015 Freescale Semiconductor, Inc.
We have already discussed about this point. After this file was merged into u-boot, a lot of commits changed it. That means that changes are not due only by Freescale employees, and I had already raise the issue that modifying the copyright can raise legal issues. I will not merge changes in copyright if I will not be absolutely certain that it does not create any conflicts.
[Adrian] Ok I will fix this.
*/ @@ -41,6 +41,18 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) } #endif
+#ifdef CONFIG_IOMUX_LPSR
Help me to understand. You say imx7 has two iomux. Ok, that means they can be set at the same time. Or not ? Then why should be decided at compile time and not at runtime ?
[Adrian] Yes iMX7D has two iomuxc controllers: iomuxc (0x30330000) and iomuxc-lpsr (0x302c0000) each controller Has their own SW_PAD_CONTROL and SWD_PAD_MUX to configure pads; The compile time macro is used to enable the iomuxc-lpsr on SoC that support it, for iMX7 is defined in "include/configs/mx7_common.h".
Iomuxc-lpsr shares the "select input" from iomuxc that's why when a pad from iomux-lpsr needs to set "select input" the offset IOMUX_LPSR_SEL_INPUT_OFS is added so it can access "select input" registers from iomuxc (0x30330000).
- u32 lpsr = (pad & MUX_MODE_LPSR) >> MUX_MODE_SHIFT;
- if (lpsr == IOMUX_CONFIG_LPSR) {
base = (void *)IOMUXC_LPSR_BASE_ADDR;
mux_mode &= ~IOMUX_CONFIG_LPSR;
/* set daisy chain sel_input */
if (sel_input_ofs)
sel_input_ofs += IOMUX_LPSR_SEL_INPUT_OFS;
- if (mux_ctrl_ofs) __raw_writel(mux_mode, base + mux_ctrl_ofs);
@@ -55,6 +67,12 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) if (!(pad_ctrl & NO_PAD_CTRL) && pad_ctrl_ofs) __raw_writel(pad_ctrl, base + pad_ctrl_ofs); #endif
base = (void *)IOMUXC_BASE_ADDR;
/* configures a list of pads within declared with IOMUX_PADS macro */ diff --git a/arch/arm/include/asm/arch-mx7/mx7-pins.h
b/arch/arm/include/asm/arch-mx7/mx7-pins.h
new file mode 100644 index 0000000..164c2be --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7-pins.h @@ -0,0 +1,19 @@ +/*
- Copyright (C) 2015 Freescale Semiconductor, Inc.
+#ifndef __ASM_ARCH_MX7_PINS_H__ +#define __ASM_ARCH_MX7_PINS_H__
+#include <asm/imx-common/iomux-v3.h>
+#if defined(CONFIG_MX7D) +#include "mx7d_pins.h" +#elif defined(CONFIG_MX7S) +#include "mx7s_pins.h" +#else +#error "Please select cpu" +#endif /* CONFIG_MX7D */
+#endif /*__ASM_ARCH_MX7_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx7/mx7d_pins.h
b/arch/arm/include/asm/arch-mx7/mx7d_pins.h
new file mode 100644 index 0000000..d8b4097 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/mx7d_pins.h @@ -0,0 +1,1308 @@ +/*
+#ifndef __ASM_ARCH_IMX7D_PINS_H__ +#define __ASM_ARCH_IMX7D_PINS_H__
+enum {
- MX7D_PAD_GPIO1_IO00__GPIO1_IO0 =
IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO00__PWM4_OUT
= IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B =
IOMUX_PAD(0x0030, 0x0000, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__GPIO1_IO1 =
IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__PWM1_OUT =
IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__CCM_ENET_REF_CLK3 =
IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO01__SAI1_MCLK
= IOMUX_PAD(0x0034, 0x0004, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__GPIO1_IO2 =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__PWM2_OUT =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__CCM_ENET_REF_CLK1 =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 2, 0x0564, 3, 0),
- MX7D_PAD_GPIO1_IO02__SAI2_MCLK =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__CCM_CLKO1 =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO02__USB_OTG1_ID =
IOMUX_PAD(0x0038, 0x0008, IOMUX_CONFIG_LPSR | 7, 0x0734, 3, 0),
- MX7D_PAD_GPIO1_IO03__GPIO1_IO3 =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__PWM3_OUT =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__CCM_ENET_REF_CLK2 =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 2, 0x0570, 3, 0),
- MX7D_PAD_GPIO1_IO03__SAI3_MCLK =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__CCM_CLKO2 =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO03__USB_OTG2_ID =
IOMUX_PAD(0x003c, 0x000C, IOMUX_CONFIG_LPSR | 7, 0x0730, 3, 0),
- MX7D_PAD_GPIO1_IO04__GPIO1_IO4 =
IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO04__USB_OTG1_OC =
IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 1, 0x072C, 1, 0),
- MX7D_PAD_GPIO1_IO04__FLEXTIMER_CH4 =
IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 2, 0x0594, 1, 0),
- MX7D_PAD_GPIO1_IO04__UART5_CTS_B =
IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | 3, 0x0710, 4, 0),
- MX7D_PAD_GPIO1_IO04__I2C1_SCL =
IOMUX_PAD(0x0040, 0x0010, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D4, 2, 0),
- MX7D_PAD_GPIO1_IO05__GPIO1_IO5 =
IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR =
IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO05__FLEXTIMER1_CH5 =
IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 2, 0x0598, 1, 0),
- MX7D_PAD_GPIO1_IO05__UART5_RTS_B =
IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | 3, 0x0710, 5, 0),
- MX7D_PAD_GPIO1_IO05__I2C1_SDA =
IOMUX_PAD(0x0044, 0x0014, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05D8, 2, 0),
- MX7D_PAD_GPIO1_IO06__GPIO1_IO6 =
IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO06__USB_OTG2_OC =
IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 1, 0x0728, 1, 0),
- MX7D_PAD_GPIO1_IO06__FLEXTIMER1_CH6 =
IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 2, 0x059C, 1, 0),
- MX7D_PAD_GPIO1_IO06__UART5_RX_DATA =
IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 3, 0x0714, 4, 0),
- MX7D_PAD_GPIO1_IO06__I2C2_SCL =
IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05DC, 2, 0),
- MX7D_PAD_GPIO1_IO06__CCM_WAIT
= IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO06__KPP_ROW4
= IOMUX_PAD(0x0048, 0x0018, IOMUX_CONFIG_LPSR | 6, 0x0624, 1, 0),
- MX7D_PAD_GPIO1_IO07__GPIO1_IO7 =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__USB_OTG2_PWR =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__FLEXTIMER1_CH7 =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 2, 0x05A0, 1, 0),
- MX7D_PAD_GPIO1_IO07__UART5_TX_DATA =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 3, 0x0714, 5, 0),
- MX7D_PAD_GPIO1_IO07__I2C2_SDA =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | IOMUX_CONFIG_SION | 4, 0x05E0, 2, 0),
- MX7D_PAD_GPIO1_IO07__CCM_STOP
= IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 5, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO07__KPP_COL4 =
IOMUX_PAD(0x004c, 0x001c, IOMUX_CONFIG_LPSR | 6, 0x0604, 1, 0),
+enum {
- MX7D_PAD_GPIO1_IO08__GPIO1_IO8 =
IOMUX_PAD(0x026C, 0x0014, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__SD1_VSELECT =
IOMUX_PAD(0x026C, 0x0014, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__WDOG1_WDOG_B =
IOMUX_PAD(0x026C, 0x0014, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__UART3_DCE_RX =
IOMUX_PAD(0x026C, 0x0014, 3, 0x0704, 0, 0),
- MX7D_PAD_GPIO1_IO08__UART3_DTE_TX =
IOMUX_PAD(0x026C, 0x0014, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO08__I2C3_SCL =
IOMUX_PAD(0x026C, 0x0014, IOMUX_CONFIG_SION | 4, 0x05E4, 0, 0),
- MX7D_PAD_GPIO1_IO08__KPP_COL5 =
IOMUX_PAD(0x026C, 0x0014, 6, 0x0608, 0, 0),
- MX7D_PAD_GPIO1_IO08__PWM1_OUT =
IOMUX_PAD(0x026C, 0x0014, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__GPIO1_IO9 =
IOMUX_PAD(0x0270, 0x0018, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__SD1_LCTL =
IOMUX_PAD(0x0270, 0x0018, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__CCM_ENET_REF_CLK3 =
IOMUX_PAD(0x0270, 0x0018, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__UART3_DCE_TX =
IOMUX_PAD(0x0270, 0x0018, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO09__UART3_DTE_RX =
IOMUX_PAD(0x0270, 0x0018, 3, 0x0704, 1, 0),
- MX7D_PAD_GPIO1_IO09__I2C3_SDA =
IOMUX_PAD(0x0270, 0x0018, IOMUX_CONFIG_SION | 4, 0x05E8, 0, 0),
- MX7D_PAD_GPIO1_IO09__CCM_PMIC_READY =
IOMUX_PAD(0x0270, 0x0018, 5, 0x04F4, 0, 0),
- MX7D_PAD_GPIO1_IO09__KPP_ROW5 =
IOMUX_PAD(0x0270, 0x0018, 6, 0x0628, 0, 0),
- MX7D_PAD_GPIO1_IO09__PWM2_OUT =
IOMUX_PAD(0x0270, 0x0018, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__GPIO1_IO10 =
IOMUX_PAD(0x0274, 0x001C, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__SD2_LCTL =
IOMUX_PAD(0x0274, 0x001C, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__ENET1_MDIO =
IOMUX_PAD(0x0274, 0x001C, 2, 0x0568, 0, 0),
- MX7D_PAD_GPIO1_IO10__UART3_DCE_RTS =
IOMUX_PAD(0x0274, 0x001C, 3, 0x0700, 0, 0),
- MX7D_PAD_GPIO1_IO10__UART3_DTE_CTS =
IOMUX_PAD(0x0274, 0x001C, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO10__I2C4_SCL =
IOMUX_PAD(0x0274, 0x001C, IOMUX_CONFIG_SION | 4, 0x05EC, 0, 0),
- MX7D_PAD_GPIO1_IO10__FLEXTIMER1_PHA =
IOMUX_PAD(0x0274, 0x001C, 5, 0x05A4, 0, 0),
- MX7D_PAD_GPIO1_IO10__KPP_COL6 =
IOMUX_PAD(0x0274, 0x001C, 6, 0x060C, 0, 0),
- MX7D_PAD_GPIO1_IO10__PWM3_OUT =
IOMUX_PAD(0x0274, 0x001C, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__GPIO1_IO11 =
IOMUX_PAD(0x0278, 0x0020, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__SD3_LCTL =
IOMUX_PAD(0x0278, 0x0020, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__ENET1_MDC =
IOMUX_PAD(0x0278, 0x0020, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__UART3_DCE_CTS =
IOMUX_PAD(0x0278, 0x0020, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO11__UART3_DTE_RTS =
IOMUX_PAD(0x0278, 0x0020, 3, 0x0700, 1, 0),
- MX7D_PAD_GPIO1_IO11__I2C4_SDA =
IOMUX_PAD(0x0278, 0x0020, IOMUX_CONFIG_SION | 4, 0x05F0, 0, 0),
- MX7D_PAD_GPIO1_IO11__FLEXTIMER1_PHB =
IOMUX_PAD(0x0278, 0x0020, 5, 0x05A8, 0, 0),
- MX7D_PAD_GPIO1_IO11__KPP_ROW6 =
IOMUX_PAD(0x0278, 0x0020, 6, 0x062C, 0, 0),
- MX7D_PAD_GPIO1_IO11__PWM4_OUT =
IOMUX_PAD(0x0278, 0x0020, 7, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__GPIO1_IO12 =
IOMUX_PAD(0x027C, 0x0024, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__SD2_VSELECT =
IOMUX_PAD(0x027C, 0x0024, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__CCM_ENET_REF_CLK1 =
IOMUX_PAD(0x027C, 0x0024, 2, 0x0564, 0, 0),
- MX7D_PAD_GPIO1_IO12__FLEXCAN1_RX =
IOMUX_PAD(0x027C, 0x0024, 3, 0x04DC, 0, 0),
- MX7D_PAD_GPIO1_IO12__CM4_NMI =
IOMUX_PAD(0x027C, 0x0024, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__CCM_EXT_CLK1 =
IOMUX_PAD(0x027C, 0x0024, 5, 0x04E4, 0, 0),
- MX7D_PAD_GPIO1_IO12__SNVS_VIO_5 =
IOMUX_PAD(0x027C, 0x0024, 6, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO12__USB_OTG1_ID =
IOMUX_PAD(0x027C, 0x0024, 7, 0x0734, 0, 0),
- MX7D_PAD_GPIO1_IO13__GPIO1_IO13 =
IOMUX_PAD(0x0280, 0x0028, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__SD3_VSELECT =
IOMUX_PAD(0x0280, 0x0028, 1, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__CCM_ENET_REF_CLK2 =
IOMUX_PAD(0x0280, 0x0028, 2, 0x0570, 0, 0),
- MX7D_PAD_GPIO1_IO13__FLEXCAN1_TX =
IOMUX_PAD(0x0280, 0x0028, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__CCM_PMIC_READY =
IOMUX_PAD(0x0280, 0x0028, 4, 0x04F4, 1, 0),
- MX7D_PAD_GPIO1_IO13__CCM_EXT_CLK2 =
IOMUX_PAD(0x0280, 0x0028, 5, 0x04E8, 0, 0),
- MX7D_PAD_GPIO1_IO13__SNVS_VIO_5_CTL =
IOMUX_PAD(0x0280, 0x0028, 6, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO13__USB_OTG2_ID =
IOMUX_PAD(0x0280, 0x0028, 7, 0x0730, 0, 0),
- MX7D_PAD_GPIO1_IO14__GPIO1_IO14 =
IOMUX_PAD(0x0284, 0x002C, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO14__SD3_CD_B =
IOMUX_PAD(0x0284, 0x002C, 1, 0x0738, 0, 0),
- MX7D_PAD_GPIO1_IO14__ENET2_MDIO =
IOMUX_PAD(0x0284, 0x002C, 2, 0x0574, 0, 0),
- MX7D_PAD_GPIO1_IO14__FLEXCAN2_RX =
IOMUX_PAD(0x0284, 0x002C, 3, 0x04E0, 0, 0),
- MX7D_PAD_GPIO1_IO14__WDOG3_WDOG_B =
IOMUX_PAD(0x0284, 0x002C, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO14__CCM_EXT_CLK3 =
IOMUX_PAD(0x0284, 0x002C, 5, 0x04EC, 0, 0),
- MX7D_PAD_GPIO1_IO14__SDMA_EXT_EVENT0 =
IOMUX_PAD(0x0284, 0x002C, 6, 0x06D8, 0, 0),
- MX7D_PAD_GPIO1_IO15__GPIO1_IO15 =
IOMUX_PAD(0x0288, 0x0030, 0, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__SD3_WP =
IOMUX_PAD(0x0288, 0x0030, 1, 0x073C, 0, 0),
- MX7D_PAD_GPIO1_IO15__ENET2_MDC =
IOMUX_PAD(0x0288, 0x0030, 2, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__FLEXCAN2_TX =
IOMUX_PAD(0x0288, 0x0030, 3, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__WDOG4_WDOG_B =
IOMUX_PAD(0x0288, 0x0030, 4, 0x0000, 0, 0),
- MX7D_PAD_GPIO1_IO15__CCM_EXT_CLK4 =
IOMUX_PAD(0x0288, 0x0030, 5, 0x04F0, 0, 0),
- MX7D_PAD_GPIO1_IO15__SDMA_EXT_EVENT1 =
IOMUX_PAD(0x0288, 0x0030, 6, 0x06DC, 0, 0),
- MX7D_PAD_EPDC_DATA00__EPDC_DATA0 =
IOMUX_PAD(0x02A4, 0x0034, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__SIM1_PORT2_TRXD =
IOMUX_PAD(0x02A4, 0x0034, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 =
IOMUX_PAD(0x02A4, 0x0034, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__KPP_ROW3 =
IOMUX_PAD(0x02A4, 0x0034, 3, 0x0620, 0, 0),
- MX7D_PAD_EPDC_DATA00__EIM_AD0 =
IOMUX_PAD(0x02A4, 0x0034, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__GPIO2_IO0 =
IOMUX_PAD(0x02A4, 0x0034, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA00__LCD_DATA0 =
IOMUX_PAD(0x02A4, 0x0034, 6, 0x0638, 0, 0),
- MX7D_PAD_EPDC_DATA00__LCD_CLK =
IOMUX_PAD(0x02A4, 0x0034, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__EPDC_DATA1 =
IOMUX_PAD(0x02A8, 0x0038, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__SIM1_PORT2_CLK =
IOMUX_PAD(0x02A8, 0x0038, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 =
IOMUX_PAD(0x02A8, 0x0038, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__KPP_COL3 =
IOMUX_PAD(0x02A8, 0x0038, 3, 0x0600, 0, 0),
- MX7D_PAD_EPDC_DATA01__EIM_AD1 =
IOMUX_PAD(0x02A8, 0x0038, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__GPIO2_IO1 =
IOMUX_PAD(0x02A8, 0x0038, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA01__LCD_DATA1 =
IOMUX_PAD(0x02A8, 0x0038, 6, 0x063C, 0, 0),
- MX7D_PAD_EPDC_DATA01__LCD_ENABLE =
IOMUX_PAD(0x02A8, 0x0038, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__EPDC_DATA2 =
IOMUX_PAD(0x02AC, 0x003C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__SIM1_PORT2_RST_B =
IOMUX_PAD(0x02AC, 0x003C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 =
IOMUX_PAD(0x02AC, 0x003C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__KPP_ROW2 =
IOMUX_PAD(0x02AC, 0x003C, 3, 0x061C, 0, 0),
- MX7D_PAD_EPDC_DATA02__EIM_AD2 =
IOMUX_PAD(0x02AC, 0x003C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__GPIO2_IO2 =
IOMUX_PAD(0x02AC, 0x003C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA02__LCD_DATA2 =
IOMUX_PAD(0x02AC, 0x003C, 6, 0x0640, 0, 0),
- MX7D_PAD_EPDC_DATA02__LCD_VSYNC =
IOMUX_PAD(0x02AC, 0x003C, 7, 0x0698, 0, 0),
- MX7D_PAD_EPDC_DATA03__EPDC_DATA3 =
IOMUX_PAD(0x02B0, 0x0040, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__SIM1_PORT2_SVEN =
IOMUX_PAD(0x02B0, 0x0040, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 =
IOMUX_PAD(0x02B0, 0x0040, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__KPP_COL2 =
IOMUX_PAD(0x02B0, 0x0040, 3, 0x05FC, 0, 0),
- MX7D_PAD_EPDC_DATA03__EIM_AD3 =
IOMUX_PAD(0x02B0, 0x0040, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__GPIO2_IO3 =
IOMUX_PAD(0x02B0, 0x0040, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA03__LCD_DATA3 =
IOMUX_PAD(0x02B0, 0x0040, 6, 0x0644, 0, 0),
- MX7D_PAD_EPDC_DATA03__LCD_HSYNC =
IOMUX_PAD(0x02B0, 0x0040, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__EPDC_DATA4 =
IOMUX_PAD(0x02B4, 0x0044, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__SIM1_PORT2_PD =
IOMUX_PAD(0x02B4, 0x0044, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__QSPI_A_DQS =
IOMUX_PAD(0x02B4, 0x0044, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__KPP_ROW1 =
IOMUX_PAD(0x02B4, 0x0044, 3, 0x0618, 0, 0),
- MX7D_PAD_EPDC_DATA04__EIM_AD4 =
IOMUX_PAD(0x02B4, 0x0044, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__GPIO2_IO4 =
IOMUX_PAD(0x02B4, 0x0044, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA04__LCD_DATA4 =
IOMUX_PAD(0x02B4, 0x0044, 6, 0x0648, 0, 0),
- MX7D_PAD_EPDC_DATA04__JTAG_FAIL =
IOMUX_PAD(0x02B4, 0x0044, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__EPDC_DATA5 =
IOMUX_PAD(0x02B8, 0x0048, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__SIM2_PORT2_TRXD =
IOMUX_PAD(0x02B8, 0x0048, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK =
IOMUX_PAD(0x02B8, 0x0048, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__KPP_COL1 =
IOMUX_PAD(0x02B8, 0x0048, 3, 0x05F8, 0, 0),
- MX7D_PAD_EPDC_DATA05__EIM_AD5 =
IOMUX_PAD(0x02B8, 0x0048, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__GPIO2_IO5 =
IOMUX_PAD(0x02B8, 0x0048, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA05__LCD_DATA5 =
IOMUX_PAD(0x02B8, 0x0048, 6, 0x064C, 0, 0),
- MX7D_PAD_EPDC_DATA05__JTAG_ACTIVE =
IOMUX_PAD(0x02B8, 0x0048, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__EPDC_DATA6 =
IOMUX_PAD(0x02BC, 0x004C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__SIM2_PORT2_CLK =
IOMUX_PAD(0x02BC, 0x004C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B =
IOMUX_PAD(0x02BC, 0x004C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__KPP_ROW0 =
IOMUX_PAD(0x02BC, 0x004C, 3, 0x0614, 0, 0),
- MX7D_PAD_EPDC_DATA06__EIM_AD6 =
IOMUX_PAD(0x02BC, 0x004C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__GPIO2_IO6 =
IOMUX_PAD(0x02BC, 0x004C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA06__LCD_DATA6 =
IOMUX_PAD(0x02BC, 0x004C, 6, 0x0650, 0, 0),
- MX7D_PAD_EPDC_DATA06__JTAG_DE_B =
IOMUX_PAD(0x02BC, 0x004C, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__EPDC_DATA7 =
IOMUX_PAD(0x02C0, 0x0050, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__SIM2_PORT2_RST_B =
IOMUX_PAD(0x02C0, 0x0050, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__QSPI_A_SS1_B =
IOMUX_PAD(0x02C0, 0x0050, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__KPP_COL0 =
IOMUX_PAD(0x02C0, 0x0050, 3, 0x05F4, 0, 0),
- MX7D_PAD_EPDC_DATA07__EIM_AD7 =
IOMUX_PAD(0x02C0, 0x0050, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__GPIO2_IO7 =
IOMUX_PAD(0x02C0, 0x0050, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA07__LCD_DATA7 =
IOMUX_PAD(0x02C0, 0x0050, 6, 0x0654, 0, 0),
- MX7D_PAD_EPDC_DATA07__JTAG_DONE =
IOMUX_PAD(0x02C0, 0x0050, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__EPDC_DATA8 =
IOMUX_PAD(0x02C4, 0x0054, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__SIM1_PORT1_TRXD =
IOMUX_PAD(0x02C4, 0x0054, 1, 0x06E4, 0, 0),
- MX7D_PAD_EPDC_DATA08__QSPI_B_DATA0 =
IOMUX_PAD(0x02C4, 0x0054, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__UART6_DCE_RX =
IOMUX_PAD(0x02C4, 0x0054, 3, 0x071C, 0, 0),
- MX7D_PAD_EPDC_DATA08__UART6_DTE_TX =
IOMUX_PAD(0x02C4, 0x0054, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__EIM_OE =
IOMUX_PAD(0x02C4, 0x0054, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__GPIO2_IO8 =
IOMUX_PAD(0x02C4, 0x0054, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA08__LCD_DATA8 =
IOMUX_PAD(0x02C4, 0x0054, 6, 0x0658, 0, 0),
- MX7D_PAD_EPDC_DATA08__LCD_BUSY =
IOMUX_PAD(0x02C4, 0x0054, 7, 0x0634, 0, 0),
- MX7D_PAD_EPDC_DATA08__EPDC_SDCLK =
IOMUX_PAD(0x02C4, 0x0054, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__EPDC_DATA9 =
IOMUX_PAD(0x02C8, 0x0058, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__SIM1_PORT1_CLK =
IOMUX_PAD(0x02C8, 0x0058, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__QSPI_B_DATA1 =
IOMUX_PAD(0x02C8, 0x0058, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__UART6_DCE_TX =
IOMUX_PAD(0x02C8, 0x0058, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__UART6_DTE_RX =
IOMUX_PAD(0x02C8, 0x0058, 3, 0x071C, 1, 0),
- MX7D_PAD_EPDC_DATA09__EIM_RW =
IOMUX_PAD(0x02C8, 0x0058, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__GPIO2_IO9 =
IOMUX_PAD(0x02C8, 0x0058, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA09__LCD_DATA9 =
IOMUX_PAD(0x02C8, 0x0058, 6, 0x065C, 0, 0),
- MX7D_PAD_EPDC_DATA09__LCD_DATA0 =
IOMUX_PAD(0x02C8, 0x0058, 7, 0x0638, 1, 0),
- MX7D_PAD_EPDC_DATA09__EPDC_SDLE =
IOMUX_PAD(0x02C8, 0x0058, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__EPDC_DATA10 =
IOMUX_PAD(0x02CC, 0x005C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__SIM1_PORT1_RST_B =
IOMUX_PAD(0x02CC, 0x005C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__QSPI_B_DATA2 =
IOMUX_PAD(0x02CC, 0x005C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__UART6_DCE_RTS =
IOMUX_PAD(0x02CC, 0x005C, 3, 0x0718, 0, 0),
- MX7D_PAD_EPDC_DATA10__UART6_DTE_CTS =
IOMUX_PAD(0x02CC, 0x005C, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__EIM_CS0_B =
IOMUX_PAD(0x02CC, 0x005C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__GPIO2_IO10 =
IOMUX_PAD(0x02CC, 0x005C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA10__LCD_DATA10 =
IOMUX_PAD(0x02CC, 0x005C, 6, 0x0660, 0, 0),
- MX7D_PAD_EPDC_DATA10__LCD_DATA9 =
IOMUX_PAD(0x02CC, 0x005C, 7, 0x065C, 1, 0),
- MX7D_PAD_EPDC_DATA10__EPDC_SDOE =
IOMUX_PAD(0x02CC, 0x005C, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__EPDC_DATA11 =
IOMUX_PAD(0x02D0, 0x0060, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__SIM1_PORT1_SVEN =
IOMUX_PAD(0x02D0, 0x0060, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__QSPI_B_DATA3 =
IOMUX_PAD(0x02D0, 0x0060, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__UART6_DCE_CTS =
IOMUX_PAD(0x02D0, 0x0060, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__UART6_DTE_RTS =
IOMUX_PAD(0x02D0, 0x0060, 3, 0x0718, 1, 0),
- MX7D_PAD_EPDC_DATA11__EIM_BCLK =
IOMUX_PAD(0x02D0, 0x0060, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__GPIO2_IO11 =
IOMUX_PAD(0x02D0, 0x0060, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA11__LCD_DATA11 =
IOMUX_PAD(0x02D0, 0x0060, 6, 0x0664, 0, 0),
- MX7D_PAD_EPDC_DATA11__LCD_DATA1 =
IOMUX_PAD(0x02D0, 0x0060, 7, 0x063C, 1, 0),
- MX7D_PAD_EPDC_DATA11__EPDC_SDCE0 =
IOMUX_PAD(0x02D0, 0x0060, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__EPDC_DATA12 =
IOMUX_PAD(0x02D4, 0x0064, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__SIM1_PORT1_PD =
IOMUX_PAD(0x02D4, 0x0064, 1, 0x06E0, 0, 0),
- MX7D_PAD_EPDC_DATA12__QSPI_B_DQS =
IOMUX_PAD(0x02D4, 0x0064, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__UART7_DCE_RX =
IOMUX_PAD(0x02D4, 0x0064, 3, 0x0724, 0, 0),
- MX7D_PAD_EPDC_DATA12__UART7_DTE_TX =
IOMUX_PAD(0x02D4, 0x0064, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__EIM_LBA_B =
IOMUX_PAD(0x02D4, 0x0064, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__GPIO2_IO12 =
IOMUX_PAD(0x02D4, 0x0064, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA12__LCD_DATA12 =
IOMUX_PAD(0x02D4, 0x0064, 6, 0x0668, 0, 0),
- MX7D_PAD_EPDC_DATA12__LCD_DATA21 =
IOMUX_PAD(0x02D4, 0x0064, 7, 0x068C, 0, 0),
- MX7D_PAD_EPDC_DATA12__EPDC_GDCLK =
IOMUX_PAD(0x02D4, 0x0064, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__EPDC_DATA13 =
IOMUX_PAD(0x02D8, 0x0068, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__SIM2_PORT1_TRXD =
IOMUX_PAD(0x02D8, 0x0068, 1, 0x06EC, 0, 0),
- MX7D_PAD_EPDC_DATA13__QSPI_B_SCLK =
IOMUX_PAD(0x02D8, 0x0068, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__UART7_DCE_TX =
IOMUX_PAD(0x02D8, 0x0068, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__UART7_DTE_RX =
IOMUX_PAD(0x02D8, 0x0068, 3, 0x0724, 1, 0),
- MX7D_PAD_EPDC_DATA13__EIM_WAIT =
IOMUX_PAD(0x02D8, 0x0068, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__GPIO2_IO13 =
IOMUX_PAD(0x02D8, 0x0068, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__LCD_DATA13 =
IOMUX_PAD(0x02D8, 0x0068, 6, 0x066C, 0, 0),
- MX7D_PAD_EPDC_DATA13__LCD_CS =
IOMUX_PAD(0x02D8, 0x0068, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA13__EPDC_GDOE =
IOMUX_PAD(0x02D8, 0x0068, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__EPDC_DATA14 =
IOMUX_PAD(0x02DC, 0x006C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__SIM2_PORT1_CLK =
IOMUX_PAD(0x02DC, 0x006C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__QSPI_B_SS0_B =
IOMUX_PAD(0x02DC, 0x006C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__UART7_DCE_RTS =
IOMUX_PAD(0x02DC, 0x006C, 3, 0x0720, 0, 0),
- MX7D_PAD_EPDC_DATA14__UART7_DTE_CTS =
IOMUX_PAD(0x02DC, 0x006C, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__EIM_EB_B0 =
IOMUX_PAD(0x02DC, 0x006C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__GPIO2_IO14 =
IOMUX_PAD(0x02DC, 0x006C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA14__LCD_DATA14 =
IOMUX_PAD(0x02DC, 0x006C, 6, 0x0670, 0, 0),
- MX7D_PAD_EPDC_DATA14__LCD_DATA22 =
IOMUX_PAD(0x02DC, 0x006C, 7, 0x0690, 0, 0),
- MX7D_PAD_EPDC_DATA14__EPDC_GDSP =
IOMUX_PAD(0x02DC, 0x006C, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__EPDC_DATA15 =
IOMUX_PAD(0x02E0, 0x0070, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__SIM2_PORT1_RST_B =
IOMUX_PAD(0x02E0, 0x0070, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__QSPI_B_SS1_B =
IOMUX_PAD(0x02E0, 0x0070, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__UART7_DCE_CTS =
IOMUX_PAD(0x02E0, 0x0070, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__UART7_DTE_RTS =
IOMUX_PAD(0x02E0, 0x0070, 3, 0x0720, 1, 0),
- MX7D_PAD_EPDC_DATA15__EIM_CS1_B =
IOMUX_PAD(0x02E0, 0x0070, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__GPIO2_IO15 =
IOMUX_PAD(0x02E0, 0x0070, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__LCD_DATA15 =
IOMUX_PAD(0x02E0, 0x0070, 6, 0x0674, 0, 0),
- MX7D_PAD_EPDC_DATA15__LCD_WR_RWN =
IOMUX_PAD(0x02E0, 0x0070, 7, 0x0000, 0, 0),
- MX7D_PAD_EPDC_DATA15__EPDC_PWR_COM =
IOMUX_PAD(0x02E0, 0x0070, 8, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__EPDC_SDCLK =
IOMUX_PAD(0x02E4, 0x0074, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__SIM2_PORT2_SVEN =
IOMUX_PAD(0x02E4, 0x0074, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 =
IOMUX_PAD(0x02E4, 0x0074, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__KPP_ROW4 =
IOMUX_PAD(0x02E4, 0x0074, 3, 0x0624, 0, 0),
- MX7D_PAD_EPDC_SDCLK__EIM_AD10 =
IOMUX_PAD(0x02E4, 0x0074, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 =
IOMUX_PAD(0x02E4, 0x0074, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__LCD_CLK =
IOMUX_PAD(0x02E4, 0x0074, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCLK__LCD_DATA20 =
IOMUX_PAD(0x02E4, 0x0074, 7, 0x0688, 0, 0),
- MX7D_PAD_EPDC_SDLE__EPDC_SDLE =
IOMUX_PAD(0x02E8, 0x0078, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__SIM2_PORT2_PD =
IOMUX_PAD(0x02E8, 0x0078, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 =
IOMUX_PAD(0x02E8, 0x0078, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__KPP_COL4 =
IOMUX_PAD(0x02E8, 0x0078, 3, 0x0604, 0, 0),
- MX7D_PAD_EPDC_SDLE__EIM_AD11 =
IOMUX_PAD(0x02E8, 0x0078, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__GPIO2_IO17 =
IOMUX_PAD(0x02E8, 0x0078, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDLE__LCD_DATA16 =
IOMUX_PAD(0x02E8, 0x0078, 6, 0x0678, 0, 0),
- MX7D_PAD_EPDC_SDLE__LCD_DATA8 =
IOMUX_PAD(0x02E8, 0x0078, 7, 0x0658, 1, 0),
- MX7D_PAD_EPDC_SDOE__EPDC_SDOE =
IOMUX_PAD(0x02EC, 0x007C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__FLEXTIMER1_CH0 =
IOMUX_PAD(0x02EC, 0x007C, 1, 0x0584, 0, 0),
- MX7D_PAD_EPDC_SDOE__ENET2_RGMII_RD2 =
IOMUX_PAD(0x02EC, 0x007C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__KPP_COL5 =
IOMUX_PAD(0x02EC, 0x007C, 3, 0x0608, 1, 0),
- MX7D_PAD_EPDC_SDOE__EIM_AD12 =
IOMUX_PAD(0x02EC, 0x007C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__GPIO2_IO18 =
IOMUX_PAD(0x02EC, 0x007C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDOE__LCD_DATA17 =
IOMUX_PAD(0x02EC, 0x007C, 6, 0x067C, 0, 0),
- MX7D_PAD_EPDC_SDOE__LCD_DATA23 =
IOMUX_PAD(0x02EC, 0x007C, 7, 0x0694, 0, 0),
- MX7D_PAD_EPDC_SDSHR__EPDC_SDSHR =
IOMUX_PAD(0x02F0, 0x0080, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__FLEXTIMER1_CH1 =
IOMUX_PAD(0x02F0, 0x0080, 1, 0x0588, 0, 0),
- MX7D_PAD_EPDC_SDSHR__ENET2_RGMII_RD3 =
IOMUX_PAD(0x02F0, 0x0080, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__KPP_ROW5 =
IOMUX_PAD(0x02F0, 0x0080, 3, 0x0628, 1, 0),
- MX7D_PAD_EPDC_SDSHR__EIM_AD13 =
IOMUX_PAD(0x02F0, 0x0080, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__GPIO2_IO19 =
IOMUX_PAD(0x02F0, 0x0080, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDSHR__LCD_DATA18 =
IOMUX_PAD(0x02F0, 0x0080, 6, 0x0680, 0, 0),
- MX7D_PAD_EPDC_SDSHR__LCD_DATA10 =
IOMUX_PAD(0x02F0, 0x0080, 7, 0x0660, 1, 0),
- MX7D_PAD_EPDC_SDCE0__EPDC_SDCE0 =
IOMUX_PAD(0x02F4, 0x0084, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__FLEXTIMER1_CH2 =
IOMUX_PAD(0x02F4, 0x0084, 1, 0x058C, 0, 0),
- MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL =
IOMUX_PAD(0x02F4, 0x0084, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__EIM_AD14 =
IOMUX_PAD(0x02F4, 0x0084, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 =
IOMUX_PAD(0x02F4, 0x0084, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE0__LCD_DATA19 =
IOMUX_PAD(0x02F4, 0x0084, 6, 0x0684, 0, 0),
- MX7D_PAD_EPDC_SDCE0__LCD_DATA5 =
IOMUX_PAD(0x02F4, 0x0084, 7, 0x064C, 1, 0),
- MX7D_PAD_EPDC_SDCE1__EPDC_SDCE1 =
IOMUX_PAD(0x02F8, 0x0088, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__FLEXTIMER1_CH3 =
IOMUX_PAD(0x02F8, 0x0088, 1, 0x0590, 0, 0),
- MX7D_PAD_EPDC_SDCE1__ENET2_RGMII_RXC =
IOMUX_PAD(0x02F8, 0x0088, 2, 0x0578, 0, 0),
- MX7D_PAD_EPDC_SDCE1__ENET2_RX_ER =
IOMUX_PAD(0x02F8, 0x0088, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__EIM_AD15 =
IOMUX_PAD(0x02F8, 0x0088, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 =
IOMUX_PAD(0x02F8, 0x0088, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE1__LCD_DATA20 =
IOMUX_PAD(0x02F8, 0x0088, 6, 0x0688, 1, 0),
- MX7D_PAD_EPDC_SDCE1__LCD_DATA4 =
IOMUX_PAD(0x02F8, 0x0088, 7, 0x0648, 1, 0),
- MX7D_PAD_EPDC_SDCE2__EPDC_SDCE2 =
IOMUX_PAD(0x02FC, 0x008C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__SIM2_PORT1_SVEN =
IOMUX_PAD(0x02FC, 0x008C, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 =
IOMUX_PAD(0x02FC, 0x008C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__KPP_COL6 =
IOMUX_PAD(0x02FC, 0x008C, 3, 0x060C, 1, 0),
- MX7D_PAD_EPDC_SDCE2__EIM_ADDR16 =
IOMUX_PAD(0x02FC, 0x008C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 =
IOMUX_PAD(0x02FC, 0x008C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE2__LCD_DATA21 =
IOMUX_PAD(0x02FC, 0x008C, 6, 0x068C, 1, 0),
- MX7D_PAD_EPDC_SDCE2__LCD_DATA3 =
IOMUX_PAD(0x02FC, 0x008C, 7, 0x0644, 1, 0),
- MX7D_PAD_EPDC_SDCE3__EPDC_SDCE3 =
IOMUX_PAD(0x0300, 0x0090, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__SIM2_PORT1_PD =
IOMUX_PAD(0x0300, 0x0090, 1, 0x06E8, 0, 0),
- MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 =
IOMUX_PAD(0x0300, 0x0090, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__KPP_ROW6 =
IOMUX_PAD(0x0300, 0x0090, 3, 0x062C, 1, 0),
- MX7D_PAD_EPDC_SDCE3__EIM_ADDR17 =
IOMUX_PAD(0x0300, 0x0090, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 =
IOMUX_PAD(0x0300, 0x0090, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_SDCE3__LCD_DATA22 =
IOMUX_PAD(0x0300, 0x0090, 6, 0x0690, 1, 0),
- MX7D_PAD_EPDC_SDCE3__LCD_DATA2 =
IOMUX_PAD(0x0300, 0x0090, 7, 0x0640, 1, 0),
- MX7D_PAD_EPDC_GDCLK__EPDC_GDCLK =
IOMUX_PAD(0x0304, 0x0094, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__FLEXTIMER2_CH0 =
IOMUX_PAD(0x0304, 0x0094, 1, 0x05AC, 0, 0),
- MX7D_PAD_EPDC_GDCLK__ENET2_RGMII_TD2 =
IOMUX_PAD(0x0304, 0x0094, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__KPP_COL7 =
IOMUX_PAD(0x0304, 0x0094, 3, 0x0610, 0, 0),
- MX7D_PAD_EPDC_GDCLK__EIM_ADDR18 =
IOMUX_PAD(0x0304, 0x0094, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__GPIO2_IO24 =
IOMUX_PAD(0x0304, 0x0094, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDCLK__LCD_DATA23 =
IOMUX_PAD(0x0304, 0x0094, 6, 0x0694, 1, 0),
- MX7D_PAD_EPDC_GDCLK__LCD_DATA16 =
IOMUX_PAD(0x0304, 0x0094, 7, 0x0678, 1, 0),
- MX7D_PAD_EPDC_GDOE__EPDC_GDOE =
IOMUX_PAD(0x0308, 0x0098, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__FLEXTIMER2_CH1 =
IOMUX_PAD(0x0308, 0x0098, 1, 0x05B0, 0, 0),
- MX7D_PAD_EPDC_GDOE__ENET2_RGMII_TD3 =
IOMUX_PAD(0x0308, 0x0098, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__KPP_ROW7 =
IOMUX_PAD(0x0308, 0x0098, 3, 0x0630, 0, 0),
- MX7D_PAD_EPDC_GDOE__EIM_ADDR19 =
IOMUX_PAD(0x0308, 0x0098, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__GPIO2_IO25 =
IOMUX_PAD(0x0308, 0x0098, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__LCD_WR_RWN =
IOMUX_PAD(0x0308, 0x0098, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDOE__LCD_DATA18 =
IOMUX_PAD(0x0308, 0x0098, 7, 0x0680, 1, 0),
- MX7D_PAD_EPDC_GDRL__EPDC_GDRL =
IOMUX_PAD(0x030C, 0x009C, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__FLEXTIMER2_CH2 =
IOMUX_PAD(0x030C, 0x009C, 1, 0x05B4, 0, 0),
- MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL =
IOMUX_PAD(0x030C, 0x009C, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__EIM_ADDR20 =
IOMUX_PAD(0x030C, 0x009C, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__GPIO2_IO26 =
IOMUX_PAD(0x030C, 0x009C, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__LCD_RD_E =
IOMUX_PAD(0x030C, 0x009C, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDRL__LCD_DATA19 =
IOMUX_PAD(0x030C, 0x009C, 7, 0x0684, 1, 0),
- MX7D_PAD_EPDC_GDSP__EPDC_GDSP =
IOMUX_PAD(0x0310, 0x00A0, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__FLEXTIMER2_CH3 =
IOMUX_PAD(0x0310, 0x00A0, 1, 0x05B8, 0, 0),
- MX7D_PAD_EPDC_GDSP__ENET2_RGMII_TXC =
IOMUX_PAD(0x0310, 0x00A0, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__ENET2_TX_ER =
IOMUX_PAD(0x0310, 0x00A0, 3, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__EIM_ADDR21 =
IOMUX_PAD(0x0310, 0x00A0, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__GPIO2_IO27 =
IOMUX_PAD(0x0310, 0x00A0, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_GDSP__LCD_BUSY =
IOMUX_PAD(0x0310, 0x00A0, 6, 0x0634, 1, 0),
- MX7D_PAD_EPDC_GDSP__LCD_DATA17 =
IOMUX_PAD(0x0310, 0x00A0, 7, 0x067C, 1, 0),
- MX7D_PAD_EPDC_BDR0__EPDC_BDR0 =
IOMUX_PAD(0x0314, 0x00A4, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__ENET2_TX_CLK =
IOMUX_PAD(0x0314, 0x00A4, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__CCM_ENET_REF_CLK2 =
IOMUX_PAD(0x0314, 0x00A4, 3, 0x0570, 1, 0),
- MX7D_PAD_EPDC_BDR0__EIM_ADDR22 =
IOMUX_PAD(0x0314, 0x00A4, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__GPIO2_IO28 =
IOMUX_PAD(0x0314, 0x00A4, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__LCD_CS =
IOMUX_PAD(0x0314, 0x00A4, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR0__LCD_DATA7 =
IOMUX_PAD(0x0314, 0x00A4, 7, 0x0654, 1, 0),
- MX7D_PAD_EPDC_BDR1__EPDC_BDR1 =
IOMUX_PAD(0x0318, 0x00A8, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__EPDC_SDCLKN =
IOMUX_PAD(0x0318, 0x00A8, 1, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__ENET2_RX_CLK =
IOMUX_PAD(0x0318, 0x00A8, 2, 0x0578, 1, 0),
- MX7D_PAD_EPDC_BDR1__EIM_AD8 =
IOMUX_PAD(0x0318, 0x00A8, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__GPIO2_IO29 =
IOMUX_PAD(0x0318, 0x00A8, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__LCD_ENABLE =
IOMUX_PAD(0x0318, 0x00A8, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_BDR1__LCD_DATA6 =
IOMUX_PAD(0x0318, 0x00A8, 7, 0x0650, 1, 0),
- MX7D_PAD_EPDC_PWR_COM__EPDC_PWR_COM =
IOMUX_PAD(0x031C, 0x00AC, 0, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__FLEXTIMER2_PHA =
IOMUX_PAD(0x031C, 0x00AC, 1, 0x05CC, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__ENET2_CRS =
IOMUX_PAD(0x031C, 0x00AC, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__EIM_AD9 =
IOMUX_PAD(0x031C, 0x00AC, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 =
IOMUX_PAD(0x031C, 0x00AC, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__LCD_HSYNC =
IOMUX_PAD(0x031C, 0x00AC, 6, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_COM__LCD_DATA11 =
IOMUX_PAD(0x031C, 0x00AC, 7, 0x0664, 1, 0),
- MX7D_PAD_EPDC_PWR_STAT__EPDC_PWR_STAT =
IOMUX_PAD(0x0320, 0x00B0, 0, 0x0580, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__FLEXTIMER2_PHB =
IOMUX_PAD(0x0320, 0x00B0, 1, 0x05D0, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__ENET2_COL =
IOMUX_PAD(0x0320, 0x00B0, 2, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__EIM_EB_B1 =
IOMUX_PAD(0x0320, 0x00B0, 4, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31 =
IOMUX_PAD(0x0320, 0x00B0, 5, 0x0000, 0, 0),
- MX7D_PAD_EPDC_PWR_STAT__LCD_VSYNC =
IOMUX_PAD(0x0320, 0x00B0, 6, 0x0698, 1, 0),
- MX7D_PAD_EPDC_PWR_STAT__LCD_DATA12 =
IOMUX_PAD(0x0320, 0x00B0, 7, 0x0668, 1, 0),
- MX7D_PAD_LCD_CLK__LCD_CLK =
IOMUX_PAD(0x0324, 0x00B4, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__ECSPI4_MISO =
IOMUX_PAD(0x0324, 0x00B4, 1, 0x0558, 0, 0),
- MX7D_PAD_LCD_CLK__ENET1_1588_EVENT2_IN =
IOMUX_PAD(0x0324, 0x00B4, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__CSI_DATA16 =
IOMUX_PAD(0x0324, 0x00B4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__UART2_DCE_RX =
IOMUX_PAD(0x0324, 0x00B4, 4, 0x06FC, 0, 0),
- MX7D_PAD_LCD_CLK__UART2_DTE_TX =
IOMUX_PAD(0x0324, 0x00B4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_CLK__GPIO3_IO0 =
IOMUX_PAD(0x0324, 0x00B4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__LCD_ENABLE =
IOMUX_PAD(0x0328, 0x00B8, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__ECSPI4_MOSI =
IOMUX_PAD(0x0328, 0x00B8, 1, 0x055C, 0, 0),
- MX7D_PAD_LCD_ENABLE__ENET1_1588_EVENT3_IN =
IOMUX_PAD(0x0328, 0x00B8, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__CSI_DATA17 =
IOMUX_PAD(0x0328, 0x00B8, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__UART2_DCE_TX =
IOMUX_PAD(0x0328, 0x00B8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_ENABLE__UART2_DTE_RX =
IOMUX_PAD(0x0328, 0x00B8, 4, 0x06FC, 1, 0),
- MX7D_PAD_LCD_ENABLE__GPIO3_IO1 =
IOMUX_PAD(0x0328, 0x00B8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__LCD_HSYNC =
IOMUX_PAD(0x032C, 0x00BC, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__ECSPI4_SCLK =
IOMUX_PAD(0x032C, 0x00BC, 1, 0x0554, 0, 0),
- MX7D_PAD_LCD_HSYNC__ENET2_1588_EVENT2_IN =
IOMUX_PAD(0x032C, 0x00BC, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__CSI_DATA18 =
IOMUX_PAD(0x032C, 0x00BC, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__UART2_DCE_RTS =
IOMUX_PAD(0x032C, 0x00BC, 4, 0x06F8, 0, 0),
- MX7D_PAD_LCD_HSYNC__UART2_DTE_CTS =
IOMUX_PAD(0x032C, 0x00BC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_HSYNC__GPIO3_IO2 =
IOMUX_PAD(0x032C, 0x00BC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__LCD_VSYNC =
IOMUX_PAD(0x0330, 0x00C0, 0, 0x0698, 2, 0),
- MX7D_PAD_LCD_VSYNC__ECSPI4_SS0 =
IOMUX_PAD(0x0330, 0x00C0, 1, 0x0560, 0, 0),
- MX7D_PAD_LCD_VSYNC__ENET2_1588_EVENT3_IN =
IOMUX_PAD(0x0330, 0x00C0, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__CSI_DATA19 =
IOMUX_PAD(0x0330, 0x00C0, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__UART2_DCE_CTS =
IOMUX_PAD(0x0330, 0x00C0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_VSYNC__UART2_DTE_RTS =
IOMUX_PAD(0x0330, 0x00C0, 4, 0x06F8, 1, 0),
- MX7D_PAD_LCD_VSYNC__GPIO3_IO3 =
IOMUX_PAD(0x0330, 0x00C0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__LCD_RESET =
IOMUX_PAD(0x0334, 0x00C4, 0, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__GPT1_COMPARE1 =
IOMUX_PAD(0x0334, 0x00C4, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__ARM_PLATFORM_EVENTI =
IOMUX_PAD(0x0334, 0x00C4, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__CSI_FIELD =
IOMUX_PAD(0x0334, 0x00C4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__EIM_DTACK_B =
IOMUX_PAD(0x0334, 0x00C4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_RESET__GPIO3_IO4 =
IOMUX_PAD(0x0334, 0x00C4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__LCD_DATA0 =
IOMUX_PAD(0x0338, 0x00C8, 0, 0x0638, 2, 0),
- MX7D_PAD_LCD_DATA00__GPT1_COMPARE2 =
IOMUX_PAD(0x0338, 0x00C8, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__CSI_DATA20 =
IOMUX_PAD(0x0338, 0x00C8, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__EIM_DATA0 =
IOMUX_PAD(0x0338, 0x00C8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__GPIO3_IO5 =
IOMUX_PAD(0x0338, 0x00C8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA00__SRC_BOOT_CFG0 =
IOMUX_PAD(0x0338, 0x00C8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__LCD_DATA1 =
IOMUX_PAD(0x033C, 0x00CC, 0, 0x063C, 2, 0),
- MX7D_PAD_LCD_DATA01__GPT1_COMPARE3 =
IOMUX_PAD(0x033C, 0x00CC, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__CSI_DATA21 =
IOMUX_PAD(0x033C, 0x00CC, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__EIM_DATA1 =
IOMUX_PAD(0x033C, 0x00CC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__GPIO3_IO6 =
IOMUX_PAD(0x033C, 0x00CC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA01__SRC_BOOT_CFG1 =
IOMUX_PAD(0x033C, 0x00CC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__LCD_DATA2 =
IOMUX_PAD(0x0340, 0x00D0, 0, 0x0640, 2, 0),
- MX7D_PAD_LCD_DATA02__GPT1_CLK =
IOMUX_PAD(0x0340, 0x00D0, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__CSI_DATA22 =
IOMUX_PAD(0x0340, 0x00D0, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__EIM_DATA2 =
IOMUX_PAD(0x0340, 0x00D0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__GPIO3_IO7 =
IOMUX_PAD(0x0340, 0x00D0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA02__SRC_BOOT_CFG2 =
IOMUX_PAD(0x0340, 0x00D0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__LCD_DATA3 =
IOMUX_PAD(0x0344, 0x00D4, 0, 0x0644, 2, 0),
- MX7D_PAD_LCD_DATA03__GPT1_CAPTURE1 =
IOMUX_PAD(0x0344, 0x00D4, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__CSI_DATA23 =
IOMUX_PAD(0x0344, 0x00D4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__EIM_DATA3 =
IOMUX_PAD(0x0344, 0x00D4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__GPIO3_IO8 =
IOMUX_PAD(0x0344, 0x00D4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA03__SRC_BOOT_CFG3 =
IOMUX_PAD(0x0344, 0x00D4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__LCD_DATA4 =
IOMUX_PAD(0x0348, 0x00D8, 0, 0x0648, 2, 0),
- MX7D_PAD_LCD_DATA04__GPT1_CAPTURE2 =
IOMUX_PAD(0x0348, 0x00D8, 1, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__CSI_VSYNC =
IOMUX_PAD(0x0348, 0x00D8, 3, 0x0520, 0, 0),
- MX7D_PAD_LCD_DATA04__EIM_DATA4 =
IOMUX_PAD(0x0348, 0x00D8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__GPIO3_IO9 =
IOMUX_PAD(0x0348, 0x00D8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA04__SRC_BOOT_CFG4 =
IOMUX_PAD(0x0348, 0x00D8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__LCD_DATA5 =
IOMUX_PAD(0x034C, 0x00DC, 0, 0x064C, 2, 0),
- MX7D_PAD_LCD_DATA05__CSI_HSYNC =
IOMUX_PAD(0x034C, 0x00DC, 3, 0x0518, 0, 0),
- MX7D_PAD_LCD_DATA05__EIM_DATA5 =
IOMUX_PAD(0x034C, 0x00DC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__GPIO3_IO10 =
IOMUX_PAD(0x034C, 0x00DC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA05__SRC_BOOT_CFG5 =
IOMUX_PAD(0x034C, 0x00DC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__LCD_DATA6 =
IOMUX_PAD(0x0350, 0x00E0, 0, 0x0650, 2, 0),
- MX7D_PAD_LCD_DATA06__CSI_PIXCLK =
IOMUX_PAD(0x0350, 0x00E0, 3, 0x051C, 0, 0),
- MX7D_PAD_LCD_DATA06__EIM_DATA6 =
IOMUX_PAD(0x0350, 0x00E0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__GPIO3_IO11 =
IOMUX_PAD(0x0350, 0x00E0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA06__SRC_BOOT_CFG6 =
IOMUX_PAD(0x0350, 0x00E0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__LCD_DATA7 =
IOMUX_PAD(0x0354, 0x00E4, 0, 0x0654, 2, 0),
- MX7D_PAD_LCD_DATA07__CSI_MCLK =
IOMUX_PAD(0x0354, 0x00E4, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__EIM_DATA7 =
IOMUX_PAD(0x0354, 0x00E4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__GPIO3_IO12 =
IOMUX_PAD(0x0354, 0x00E4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA07__SRC_BOOT_CFG7 =
IOMUX_PAD(0x0354, 0x00E4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__LCD_DATA8 =
IOMUX_PAD(0x0358, 0x00E8, 0, 0x0658, 2, 0),
- MX7D_PAD_LCD_DATA08__CSI_DATA9 =
IOMUX_PAD(0x0358, 0x00E8, 3, 0x0514, 0, 0),
- MX7D_PAD_LCD_DATA08__EIM_DATA8 =
IOMUX_PAD(0x0358, 0x00E8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__GPIO3_IO13 =
IOMUX_PAD(0x0358, 0x00E8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA08__SRC_BOOT_CFG8 =
IOMUX_PAD(0x0358, 0x00E8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__LCD_DATA9 =
IOMUX_PAD(0x035C, 0x00EC, 0, 0x065C, 2, 0),
- MX7D_PAD_LCD_DATA09__CSI_DATA8 =
IOMUX_PAD(0x035C, 0x00EC, 3, 0x0510, 0, 0),
- MX7D_PAD_LCD_DATA09__EIM_DATA9 =
IOMUX_PAD(0x035C, 0x00EC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__GPIO3_IO14 =
IOMUX_PAD(0x035C, 0x00EC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA09__SRC_BOOT_CFG9 =
IOMUX_PAD(0x035C, 0x00EC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__LCD_DATA10 =
IOMUX_PAD(0x0360, 0x00F0, 0, 0x0660, 2, 0),
- MX7D_PAD_LCD_DATA10__CSI_DATA7 =
IOMUX_PAD(0x0360, 0x00F0, 3, 0x050C, 0, 0),
- MX7D_PAD_LCD_DATA10__EIM_DATA10 =
IOMUX_PAD(0x0360, 0x00F0, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__GPIO3_IO15 =
IOMUX_PAD(0x0360, 0x00F0, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA10__SRC_BOOT_CFG10 =
IOMUX_PAD(0x0360, 0x00F0, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__LCD_DATA11 =
IOMUX_PAD(0x0364, 0x00F4, 0, 0x0664, 2, 0),
- MX7D_PAD_LCD_DATA11__CSI_DATA6 =
IOMUX_PAD(0x0364, 0x00F4, 3, 0x0508, 0, 0),
- MX7D_PAD_LCD_DATA11__EIM_DATA11 =
IOMUX_PAD(0x0364, 0x00F4, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__GPIO3_IO16 =
IOMUX_PAD(0x0364, 0x00F4, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA11__SRC_BOOT_CFG11 =
IOMUX_PAD(0x0364, 0x00F4, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__LCD_DATA12 =
IOMUX_PAD(0x0368, 0x00F8, 0, 0x0668, 2, 0),
- MX7D_PAD_LCD_DATA12__CSI_DATA5 =
IOMUX_PAD(0x0368, 0x00F8, 3, 0x0504, 0, 0),
- MX7D_PAD_LCD_DATA12__EIM_DATA12 =
IOMUX_PAD(0x0368, 0x00F8, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__GPIO3_IO17 =
IOMUX_PAD(0x0368, 0x00F8, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA12__SRC_BOOT_CFG12 =
IOMUX_PAD(0x0368, 0x00F8, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__LCD_DATA13 =
IOMUX_PAD(0x036C, 0x00FC, 0, 0x066C, 1, 0),
- MX7D_PAD_LCD_DATA13__CSI_DATA4 =
IOMUX_PAD(0x036C, 0x00FC, 3, 0x0500, 0, 0),
- MX7D_PAD_LCD_DATA13__EIM_DATA13 =
IOMUX_PAD(0x036C, 0x00FC, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__GPIO3_IO18 =
IOMUX_PAD(0x036C, 0x00FC, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA13__SRC_BOOT_CFG13 =
IOMUX_PAD(0x036C, 0x00FC, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__LCD_DATA14 =
IOMUX_PAD(0x0370, 0x0100, 0, 0x0670, 1, 0),
- MX7D_PAD_LCD_DATA14__CSI_DATA3 =
IOMUX_PAD(0x0370, 0x0100, 3, 0x04FC, 0, 0),
- MX7D_PAD_LCD_DATA14__EIM_DATA14 =
IOMUX_PAD(0x0370, 0x0100, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__GPIO3_IO19 =
IOMUX_PAD(0x0370, 0x0100, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA14__SRC_BOOT_CFG14 =
IOMUX_PAD(0x0370, 0x0100, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__LCD_DATA15 =
IOMUX_PAD(0x0374, 0x0104, 0, 0x0674, 1, 0),
- MX7D_PAD_LCD_DATA15__CSI_DATA2 =
IOMUX_PAD(0x0374, 0x0104, 3, 0x04F8, 0, 0),
- MX7D_PAD_LCD_DATA15__EIM_DATA15 =
IOMUX_PAD(0x0374, 0x0104, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__GPIO3_IO20 =
IOMUX_PAD(0x0374, 0x0104, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA15__SRC_BOOT_CFG15 =
IOMUX_PAD(0x0374, 0x0104, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__LCD_DATA16 =
IOMUX_PAD(0x0378, 0x0108, 0, 0x0678, 2, 0),
- MX7D_PAD_LCD_DATA16__FLEXTIMER1_CH4 =
IOMUX_PAD(0x0378, 0x0108, 1, 0x0594, 0, 0),
- MX7D_PAD_LCD_DATA16__CSI_DATA1 =
IOMUX_PAD(0x0378, 0x0108, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__EIM_CRE =
IOMUX_PAD(0x0378, 0x0108, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__GPIO3_IO21 =
IOMUX_PAD(0x0378, 0x0108, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA16__SRC_BOOT_CFG16 =
IOMUX_PAD(0x0378, 0x0108, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__LCD_DATA17 =
IOMUX_PAD(0x037C, 0x010C, 0, 0x067C, 2, 0),
- MX7D_PAD_LCD_DATA17__FLEXTIMER1_CH5 =
IOMUX_PAD(0x037C, 0x010C, 1, 0x0598, 0, 0),
- MX7D_PAD_LCD_DATA17__CSI_DATA0 =
IOMUX_PAD(0x037C, 0x010C, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__EIM_ACLK_FREERUN =
IOMUX_PAD(0x037C, 0x010C, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__GPIO3_IO22 =
IOMUX_PAD(0x037C, 0x010C, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA17__SRC_BOOT_CFG17 =
IOMUX_PAD(0x037C, 0x010C, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__LCD_DATA18 =
IOMUX_PAD(0x0380, 0x0110, 0, 0x0680, 2, 0),
- MX7D_PAD_LCD_DATA18__FLEXTIMER1_CH6 =
IOMUX_PAD(0x0380, 0x0110, 1, 0x059C, 0, 0),
- MX7D_PAD_LCD_DATA18__ARM_PLATFORM_EVENTO =
IOMUX_PAD(0x0380, 0x0110, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__CSI_DATA15 =
IOMUX_PAD(0x0380, 0x0110, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__EIM_CS2_B =
IOMUX_PAD(0x0380, 0x0110, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__GPIO3_IO23 =
IOMUX_PAD(0x0380, 0x0110, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA18__SRC_BOOT_CFG18 =
IOMUX_PAD(0x0380, 0x0110, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__EIM_CS3_B =
IOMUX_PAD(0x0384, 0x0114, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__GPIO3_IO24 =
IOMUX_PAD(0x0384, 0x0114, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__SRC_BOOT_CFG19 =
IOMUX_PAD(0x0384, 0x0114, 6, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA19__LCD_DATA19 =
IOMUX_PAD(0x0384, 0x0114, 0, 0x0684, 2, 0),
- MX7D_PAD_LCD_DATA19__FLEXTIMER1_CH7 =
IOMUX_PAD(0x0384, 0x0114, 1, 0x05A0, 0, 0),
- MX7D_PAD_LCD_DATA19__CSI_DATA14 =
IOMUX_PAD(0x0384, 0x0114, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__EIM_ADDR23 =
IOMUX_PAD(0x0388, 0x0118, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__GPIO3_IO25 =
IOMUX_PAD(0x0388, 0x0118, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__I2C3_SCL =
IOMUX_PAD(0x0388, 0x0118, IOMUX_CONFIG_SION | 6, 0x05E4, 1, 0),
- MX7D_PAD_LCD_DATA20__LCD_DATA20 =
IOMUX_PAD(0x0388, 0x0118, 0, 0x0688, 2, 0),
- MX7D_PAD_LCD_DATA20__FLEXTIMER2_CH4 =
IOMUX_PAD(0x0388, 0x0118, 1, 0x05BC, 0, 0),
- MX7D_PAD_LCD_DATA20__ENET1_1588_EVENT2_OUT =
IOMUX_PAD(0x0388, 0x0118, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA20__CSI_DATA13 =
IOMUX_PAD(0x0388, 0x0118, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__LCD_DATA21 =
IOMUX_PAD(0x038C, 0x011C, 0, 0x068C, 2, 0),
- MX7D_PAD_LCD_DATA21__FLEXTIMER2_CH5 =
IOMUX_PAD(0x038C, 0x011C, 1, 0x05C0, 0, 0),
- MX7D_PAD_LCD_DATA21__ENET1_1588_EVENT3_OUT =
IOMUX_PAD(0x038C, 0x011C, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__CSI_DATA12 =
IOMUX_PAD(0x038C, 0x011C, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__EIM_ADDR24 =
IOMUX_PAD(0x038C, 0x011C, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__GPIO3_IO26 =
IOMUX_PAD(0x038C, 0x011C, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA21__I2C3_SDA =
IOMUX_PAD(0x038C, 0x011C, IOMUX_CONFIG_SION | 6, 0x05E8, 1, 0),
- MX7D_PAD_LCD_DATA22__LCD_DATA22 =
IOMUX_PAD(0x0390, 0x0120, 0, 0x0690, 2, 0),
- MX7D_PAD_LCD_DATA22__FLEXTIMER2_CH6 =
IOMUX_PAD(0x0390, 0x0120, 1, 0x05C4, 0, 0),
- MX7D_PAD_LCD_DATA22__ENET2_1588_EVENT2_OUT =
IOMUX_PAD(0x0390, 0x0120, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__CSI_DATA11 =
IOMUX_PAD(0x0390, 0x0120, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__EIM_ADDR25 =
IOMUX_PAD(0x0390, 0x0120, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__GPIO3_IO27 =
IOMUX_PAD(0x0390, 0x0120, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA22__I2C4_SCL =
IOMUX_PAD(0x0390, 0x0120, IOMUX_CONFIG_SION | 6, 0x05EC, 1, 0),
- MX7D_PAD_LCD_DATA23__LCD_DATA23 =
IOMUX_PAD(0x0394, 0x0124, 0, 0x0694, 2, 0),
- MX7D_PAD_LCD_DATA23__FLEXTIMER2_CH7 =
IOMUX_PAD(0x0394, 0x0124, 1, 0x05C8, 0, 0),
- MX7D_PAD_LCD_DATA23__ENET2_1588_EVENT3_OUT =
IOMUX_PAD(0x0394, 0x0124, 2, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__CSI_DATA10 =
IOMUX_PAD(0x0394, 0x0124, 3, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__EIM_ADDR26 =
IOMUX_PAD(0x0394, 0x0124, 4, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__GPIO3_IO28 =
IOMUX_PAD(0x0394, 0x0124, 5, 0x0000, 0, 0),
- MX7D_PAD_LCD_DATA23__I2C4_SDA =
IOMUX_PAD(0x0394, 0x0124, IOMUX_CONFIG_SION | 6, 0x05F0, 1, 0),
- MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX =
IOMUX_PAD(0x0398, 0x0128, 0, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__UART1_DTE_TX =
- MX7D_PAD_UART1_RX_DATA__I2C1_SCL =
IOMUX_PAD(0x0398, 0x0128, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__CCM_PMIC_READY =
IOMUX_PAD(0x0398, 0x0128, 2, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ECSPI1_SS1 =
IOMUX_PAD(0x0398, 0x0128, 3, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ENET2_1588_EVENT0_IN =
IOMUX_PAD(0x0398, 0x0128, 4, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__GPIO4_IO0 =
IOMUX_PAD(0x0398, 0x0128, 5, 0x0000, 0, 0),
- MX7D_PAD_UART1_RX_DATA__ENET1_MDIO =
IOMUX_PAD(0x0398, 0x0128, 6, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX =
IOMUX_PAD(0x039C, 0x012C, 0, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__UART1_DTE_RX =
IOMUX_PAD(0x039C, 0x012C, 0, 0x06F4, 1, 0),
- MX7D_PAD_UART1_TX_DATA__I2C1_SDA =
IOMUX_PAD(0x039C, 0x012C, IOMUX_CONFIG_SION | 1, 0x05D8, 0, 0),
- MX7D_PAD_UART1_TX_DATA__SAI3_MCLK =
IOMUX_PAD(0x039C, 0x012C, 2, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ECSPI1_SS2 =
IOMUX_PAD(0x039C, 0x012C, 3, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ENET2_1588_EVENT0_OUT =
IOMUX_PAD(0x039C, 0x012C, 4, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__GPIO4_IO1 =
IOMUX_PAD(0x039C, 0x012C, 5, 0x0000, 0, 0),
- MX7D_PAD_UART1_TX_DATA__ENET1_MDC =
IOMUX_PAD(0x039C, 0x012C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__UART2_DCE_RX =
IOMUX_PAD(0x03A0, 0x0130, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__UART2_DTE_TX =
- MX7D_PAD_UART2_RX_DATA__I2C2_SCL =
IOMUX_PAD(0x03A0, 0x0130, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__SAI3_RX_BCLK =
IOMUX_PAD(0x03A0, 0x0130, 2, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ECSPI1_SS3 =
IOMUX_PAD(0x03A0, 0x0130, 3, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ENET2_1588_EVENT1_IN =
IOMUX_PAD(0x03A0, 0x0130, 4, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__GPIO4_IO2 =
IOMUX_PAD(0x03A0, 0x0130, 5, 0x0000, 0, 0),
- MX7D_PAD_UART2_RX_DATA__ENET2_MDIO =
IOMUX_PAD(0x03A0, 0x0130, 6, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__UART2_DCE_TX =
IOMUX_PAD(0x03A4, 0x0134, 0, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX =
- MX7D_PAD_UART2_TX_DATA__I2C2_SDA =
IOMUX_PAD(0x03A4, 0x0134, IOMUX_CONFIG_SION | 1, 0x05E0, 0, 0),
- MX7D_PAD_UART2_TX_DATA__SAI3_RX_DATA0 =
IOMUX_PAD(0x03A4, 0x0134, 2, 0x06C8, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ECSPI1_RDY =
IOMUX_PAD(0x03A4, 0x0134, 3, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ENET2_1588_EVENT1_OUT =
IOMUX_PAD(0x03A4, 0x0134, 4, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__GPIO4_IO3 =
IOMUX_PAD(0x03A4, 0x0134, 5, 0x0000, 0, 0),
- MX7D_PAD_UART2_TX_DATA__ENET2_MDC =
IOMUX_PAD(0x03A4, 0x0134, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__UART3_DCE_RX =
IOMUX_PAD(0x03A8, 0x0138, 0, 0x0704, 2, 0),
- MX7D_PAD_UART3_RX_DATA__UART3_DTE_TX =
IOMUX_PAD(0x03A8, 0x0138, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__USB_OTG1_OC =
IOMUX_PAD(0x03A8, 0x0138, 1, 0x072C, 0, 0),
- MX7D_PAD_UART3_RX_DATA__SAI3_RX_SYNC =
IOMUX_PAD(0x03A8, 0x0138, 2, 0x06CC, 0, 0),
- MX7D_PAD_UART3_RX_DATA__ECSPI1_MISO =
IOMUX_PAD(0x03A8, 0x0138, 3, 0x0528, 0, 0),
- MX7D_PAD_UART3_RX_DATA__ENET1_1588_EVENT0_IN =
IOMUX_PAD(0x03A8, 0x0138, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__GPIO4_IO4 =
IOMUX_PAD(0x03A8, 0x0138, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_RX_DATA__SD1_LCTL =
IOMUX_PAD(0x03A8, 0x0138, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__UART3_DCE_TX =
IOMUX_PAD(0x03AC, 0x013C, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__UART3_DTE_RX =
IOMUX_PAD(0x03AC, 0x013C, 0, 0x0704, 3, 0),
- MX7D_PAD_UART3_TX_DATA__USB_OTG1_PWR =
IOMUX_PAD(0x03AC, 0x013C, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__SAI3_TX_BCLK =
IOMUX_PAD(0x03AC, 0x013C, 2, 0x06D0, 0, 0),
- MX7D_PAD_UART3_TX_DATA__ECSPI1_MOSI =
IOMUX_PAD(0x03AC, 0x013C, 3, 0x052C, 0, 0),
- MX7D_PAD_UART3_TX_DATA__ENET1_1588_EVENT0_OUT =
IOMUX_PAD(0x03AC, 0x013C, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__GPIO4_IO5 =
IOMUX_PAD(0x03AC, 0x013C, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_TX_DATA__SD2_LCTL =
IOMUX_PAD(0x03AC, 0x013C, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS =
IOMUX_PAD(0x03B0, 0x0140, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__UART3_DTE_CTS =
- MX7D_PAD_UART3_RTS_B__USB_OTG2_OC =
IOMUX_PAD(0x03B0, 0x0140, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__SAI3_TX_DATA0 =
IOMUX_PAD(0x03B0, 0x0140, 2, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__ECSPI1_SCLK =
IOMUX_PAD(0x03B0, 0x0140, 3, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__ENET1_1588_EVENT1_IN =
IOMUX_PAD(0x03B0, 0x0140, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__GPIO4_IO6 =
IOMUX_PAD(0x03B0, 0x0140, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_RTS_B__SD3_LCTL =
IOMUX_PAD(0x03B0, 0x0140, 6, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__UART3_DCE_CTS =
IOMUX_PAD(0x03B4, 0x0144, 0, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__UART3_DTE_RTS =
IOMUX_PAD(0x03B4, 0x0144, 0, 0x0700, 3, 0),
- MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR =
IOMUX_PAD(0x03B4, 0x0144, 1, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__SAI3_TX_SYNC =
IOMUX_PAD(0x03B4, 0x0144, 2, 0x06D4, 0, 0),
- MX7D_PAD_UART3_CTS_B__ECSPI1_SS0 =
IOMUX_PAD(0x03B4, 0x0144, 3, 0x0530, 0, 0),
- MX7D_PAD_UART3_CTS_B__ENET1_1588_EVENT1_OUT =
IOMUX_PAD(0x03B4, 0x0144, 4, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__GPIO4_IO7 =
IOMUX_PAD(0x03B4, 0x0144, 5, 0x0000, 0, 0),
- MX7D_PAD_UART3_CTS_B__SD1_VSELECT =
IOMUX_PAD(0x03B4, 0x0144, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__I2C1_SCL =
IOMUX_PAD(0x03B8, 0x0148, IOMUX_CONFIG_SION | 0, 0x05D4, 1, 0),
- MX7D_PAD_I2C1_SCL__UART4_DCE_CTS =
IOMUX_PAD(0x03B8, 0x0148, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__UART4_DTE_RTS =
IOMUX_PAD(0x03B8, 0x0148, 1, 0x0708, 0, 0),
- MX7D_PAD_I2C1_SCL__FLEXCAN1_RX =
IOMUX_PAD(0x03B8, 0x0148, 2, 0x04DC, 1, 0),
- MX7D_PAD_I2C1_SCL__ECSPI3_MISO =
IOMUX_PAD(0x03B8, 0x0148, 3, 0x0548, 0, 0),
- MX7D_PAD_I2C1_SCL__GPIO4_IO8 =
IOMUX_PAD(0x03B8, 0x0148, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SCL__SD2_VSELECT =
IOMUX_PAD(0x03B8, 0x0148, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__I2C1_SDA =
IOMUX_PAD(0x03BC, 0x014C, IOMUX_CONFIG_SION | 0, 0x05D8, 1, 0),
- MX7D_PAD_I2C1_SDA__UART4_DCE_RTS =
IOMUX_PAD(0x03BC, 0x014C, 1, 0x0708, 1, 0),
- MX7D_PAD_I2C1_SDA__UART4_DTE_CTS =
IOMUX_PAD(0x03BC, 0x014C, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__FLEXCAN1_TX =
IOMUX_PAD(0x03BC, 0x014C, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__ECSPI3_MOSI =
IOMUX_PAD(0x03BC, 0x014C, 3, 0x054C, 0, 0),
- MX7D_PAD_I2C1_SDA__CCM_ENET_REF_CLK1 =
IOMUX_PAD(0x03BC, 0x014C, 4, 0x0564, 1, 0),
- MX7D_PAD_I2C1_SDA__GPIO4_IO9 =
IOMUX_PAD(0x03BC, 0x014C, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C1_SDA__SD3_VSELECT =
IOMUX_PAD(0x03BC, 0x014C, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__I2C2_SCL =
IOMUX_PAD(0x03C0, 0x0150, IOMUX_CONFIG_SION | 0, 0x05DC, 1, 0),
- MX7D_PAD_I2C2_SCL__UART4_DCE_RX =
IOMUX_PAD(0x03C0, 0x0150, 1, 0x070C, 0, 0),
- MX7D_PAD_I2C2_SCL__UART4_DTE_TX =
IOMUX_PAD(0x03C0, 0x0150, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__WDOG3_WDOG_B =
IOMUX_PAD(0x03C0, 0x0150, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__ECSPI3_SCLK =
IOMUX_PAD(0x03C0, 0x0150, 3, 0x0544, 0, 0),
- MX7D_PAD_I2C2_SCL__CCM_ENET_REF_CLK2 =
IOMUX_PAD(0x03C0, 0x0150, 4, 0x0570, 2, 0),
- MX7D_PAD_I2C2_SCL__GPIO4_IO10 =
IOMUX_PAD(0x03C0, 0x0150, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SCL__SD3_CD_B =
IOMUX_PAD(0x03C0, 0x0150, 6, 0x0738, 1, 0),
- MX7D_PAD_I2C2_SDA__I2C2_SDA =
IOMUX_PAD(0x03C4, 0x0154, IOMUX_CONFIG_SION | 0, 0x05E0, 1, 0),
- MX7D_PAD_I2C2_SDA__UART4_DCE_TX =
IOMUX_PAD(0x03C4, 0x0154, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__UART4_DTE_RX =
IOMUX_PAD(0x03C4, 0x0154, 1, 0x070C, 1, 0),
- MX7D_PAD_I2C2_SDA__WDOG3_WDOG_RST_B_DEB =
IOMUX_PAD(0x03C4, 0x0154, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__ECSPI3_SS0 =
IOMUX_PAD(0x03C4, 0x0154, 3, 0x0550, 0, 0),
- MX7D_PAD_I2C2_SDA__CCM_ENET_REF_CLK3 =
IOMUX_PAD(0x03C4, 0x0154, 4, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__GPIO4_IO11 =
IOMUX_PAD(0x03C4, 0x0154, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C2_SDA__SD3_WP =
IOMUX_PAD(0x03C4, 0x0154, 6, 0x073C, 1, 0),
- MX7D_PAD_I2C3_SCL__I2C3_SCL =
IOMUX_PAD(0x03C8, 0x0158, IOMUX_CONFIG_SION | 0, 0x05E4, 2, 0),
- MX7D_PAD_I2C3_SCL__UART5_DCE_CTS =
IOMUX_PAD(0x03C8, 0x0158, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SCL__UART5_DTE_RTS =
IOMUX_PAD(0x03C8, 0x0158, 1, 0x0710, 0, 0),
- MX7D_PAD_I2C3_SCL__FLEXCAN2_RX =
IOMUX_PAD(0x03C8, 0x0158, 2, 0x04E0, 1, 0),
- MX7D_PAD_I2C3_SCL__CSI_VSYNC =
IOMUX_PAD(0x03C8, 0x0158, 3, 0x0520, 1, 0),
- MX7D_PAD_I2C3_SCL__SDMA_EXT_EVENT0 =
IOMUX_PAD(0x03C8, 0x0158, 4, 0x06D8, 1, 0),
- MX7D_PAD_I2C3_SCL__GPIO4_IO12 =
IOMUX_PAD(0x03C8, 0x0158, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SCL__EPDC_BDR0 =
IOMUX_PAD(0x03C8, 0x0158, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__I2C3_SDA =
IOMUX_PAD(0x03CC, 0x015C, IOMUX_CONFIG_SION | 0, 0x05E8, 2, 0),
- MX7D_PAD_I2C3_SDA__UART5_DCE_RTS =
IOMUX_PAD(0x03CC, 0x015C, 1, 0x0710, 1, 0),
- MX7D_PAD_I2C3_SDA__UART5_DTE_CTS =
IOMUX_PAD(0x03CC, 0x015C, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__FLEXCAN2_TX =
IOMUX_PAD(0x03CC, 0x015C, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__CSI_HSYNC =
IOMUX_PAD(0x03CC, 0x015C, 3, 0x0518, 1, 0),
- MX7D_PAD_I2C3_SDA__SDMA_EXT_EVENT1 =
IOMUX_PAD(0x03CC, 0x015C, 4, 0x06DC, 1, 0),
- MX7D_PAD_I2C3_SDA__GPIO4_IO13 =
IOMUX_PAD(0x03CC, 0x015C, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C3_SDA__EPDC_BDR1 =
IOMUX_PAD(0x03CC, 0x015C, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__I2C4_SCL =
IOMUX_PAD(0x03D0, 0x0160, IOMUX_CONFIG_SION | 0, 0x05EC, 2, 0),
- MX7D_PAD_I2C4_SCL__UART5_DCE_RX =
IOMUX_PAD(0x03D0, 0x0160, 1, 0x0714, 0, 0),
- MX7D_PAD_I2C4_SCL__UART5_DTE_TX =
IOMUX_PAD(0x03D0, 0x0160, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__WDOG4_WDOG_B =
IOMUX_PAD(0x03D0, 0x0160, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__CSI_PIXCLK =
IOMUX_PAD(0x03D0, 0x0160, 3, 0x051C, 1, 0),
- MX7D_PAD_I2C4_SCL__USB_OTG1_ID =
IOMUX_PAD(0x03D0, 0x0160, 4, 0x0734, 1, 0),
- MX7D_PAD_I2C4_SCL__GPIO4_IO14 =
IOMUX_PAD(0x03D0, 0x0160, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SCL__EPDC_VCOM0 =
IOMUX_PAD(0x03D0, 0x0160, 6, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__I2C4_SDA =
IOMUX_PAD(0x03D4, 0x0164, IOMUX_CONFIG_SION | 0, 0x05F0, 2, 0),
- MX7D_PAD_I2C4_SDA__UART5_DCE_TX =
IOMUX_PAD(0x03D4, 0x0164, 1, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__UART5_DTE_RX =
IOMUX_PAD(0x03D4, 0x0164, 1, 0x0714, 1, 0),
- MX7D_PAD_I2C4_SDA__WDOG4_WDOG_RST_B_DEB =
IOMUX_PAD(0x03D4, 0x0164, 2, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__CSI_MCLK =
IOMUX_PAD(0x03D4, 0x0164, 3, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__USB_OTG2_ID =
IOMUX_PAD(0x03D4, 0x0164, 4, 0x0730, 1, 0),
- MX7D_PAD_I2C4_SDA__GPIO4_IO15 =
IOMUX_PAD(0x03D4, 0x0164, 5, 0x0000, 0, 0),
- MX7D_PAD_I2C4_SDA__EPDC_VCOM1 =
IOMUX_PAD(0x03D4, 0x0164, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__ECSPI1_SCLK =
IOMUX_PAD(0x03D8, 0x0168, 0, 0x0524, 1, 0),
- MX7D_PAD_ECSPI1_SCLK__UART6_DCE_RX =
IOMUX_PAD(0x03D8, 0x0168, 1, 0x071C, 2, 0),
- MX7D_PAD_ECSPI1_SCLK__UART6_DTE_TX =
IOMUX_PAD(0x03D8, 0x0168, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__SD2_DATA4 =
IOMUX_PAD(0x03D8, 0x0168, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__CSI_DATA2 =
IOMUX_PAD(0x03D8, 0x0168, 3, 0x04F8, 1, 0),
- MX7D_PAD_ECSPI1_SCLK__GPIO4_IO16 =
IOMUX_PAD(0x03D8, 0x0168, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SCLK__EPDC_PWR_COM =
IOMUX_PAD(0x03D8, 0x0168, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__ECSPI1_MOSI =
IOMUX_PAD(0x03DC, 0x016C, 0, 0x052C, 1, 0),
- MX7D_PAD_ECSPI1_MOSI__UART6_DCE_TX =
IOMUX_PAD(0x03DC, 0x016C, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__UART6_DTE_RX =
IOMUX_PAD(0x03DC, 0x016C, 1, 0x071C, 3, 0),
- MX7D_PAD_ECSPI1_MOSI__SD2_DATA5 =
IOMUX_PAD(0x03DC, 0x016C, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__CSI_DATA3 =
IOMUX_PAD(0x03DC, 0x016C, 3, 0x04FC, 1, 0),
- MX7D_PAD_ECSPI1_MOSI__GPIO4_IO17 =
IOMUX_PAD(0x03DC, 0x016C, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MOSI__EPDC_PWR_STAT =
IOMUX_PAD(0x03DC, 0x016C, 6, 0x0580, 1, 0),
- MX7D_PAD_ECSPI1_MISO__ECSPI1_MISO =
IOMUX_PAD(0x03E0, 0x0170, 0, 0x0528, 1, 0),
- MX7D_PAD_ECSPI1_MISO__UART6_DCE_RTS =
IOMUX_PAD(0x03E0, 0x0170, 1, 0x0718, 2, 0),
- MX7D_PAD_ECSPI1_MISO__UART6_DTE_CTS =
IOMUX_PAD(0x03E0, 0x0170, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__SD2_DATA6 =
IOMUX_PAD(0x03E0, 0x0170, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__CSI_DATA4 =
IOMUX_PAD(0x03E0, 0x0170, 3, 0x0500, 1, 0),
- MX7D_PAD_ECSPI1_MISO__GPIO4_IO18 =
IOMUX_PAD(0x03E0, 0x0170, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_MISO__EPDC_PWR_IRQ =
IOMUX_PAD(0x03E0, 0x0170, 6, 0x057C, 0, 0),
- MX7D_PAD_ECSPI1_SS0__ECSPI1_SS0 =
IOMUX_PAD(0x03E4, 0x0174, 0, 0x0530, 1, 0),
- MX7D_PAD_ECSPI1_SS0__UART6_DCE_CTS =
IOMUX_PAD(0x03E4, 0x0174, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__UART6_DTE_RTS =
IOMUX_PAD(0x03E4, 0x0174, 1, 0x0718, 3, 0),
- MX7D_PAD_ECSPI1_SS0__SD2_DATA7 =
IOMUX_PAD(0x03E4, 0x0174, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__CSI_DATA5 =
IOMUX_PAD(0x03E4, 0x0174, 3, 0x0504, 1, 0),
- MX7D_PAD_ECSPI1_SS0__GPIO4_IO19 =
IOMUX_PAD(0x03E4, 0x0174, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI1_SS0__EPDC_PWR_CTRL3 =
IOMUX_PAD(0x03E4, 0x0174, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__ECSPI2_SCLK =
IOMUX_PAD(0x03E8, 0x0178, 0, 0x0534, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__UART7_DCE_RX =
IOMUX_PAD(0x03E8, 0x0178, 1, 0x0724, 2, 0),
- MX7D_PAD_ECSPI2_SCLK__UART7_DTE_TX =
IOMUX_PAD(0x03E8, 0x0178, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__SD1_DATA4 =
IOMUX_PAD(0x03E8, 0x0178, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__CSI_DATA6 =
IOMUX_PAD(0x03E8, 0x0178, 3, 0x0508, 1, 0),
- MX7D_PAD_ECSPI2_SCLK__LCD_DATA13 =
IOMUX_PAD(0x03E8, 0x0178, 4, 0x066C, 2, 0),
- MX7D_PAD_ECSPI2_SCLK__GPIO4_IO20 =
IOMUX_PAD(0x03E8, 0x0178, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SCLK__EPDC_PWR_CTRL0 =
IOMUX_PAD(0x03E8, 0x0178, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__ECSPI2_MOSI =
IOMUX_PAD(0x03EC, 0x017C, 0, 0x053C, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__UART7_DCE_TX =
IOMUX_PAD(0x03EC, 0x017C, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__UART7_DTE_RX =
IOMUX_PAD(0x03EC, 0x017C, 1, 0x0724, 3, 0),
- MX7D_PAD_ECSPI2_MOSI__SD1_DATA5 =
IOMUX_PAD(0x03EC, 0x017C, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__CSI_DATA7 =
IOMUX_PAD(0x03EC, 0x017C, 3, 0x050C, 1, 0),
- MX7D_PAD_ECSPI2_MOSI__LCD_DATA14 =
IOMUX_PAD(0x03EC, 0x017C, 4, 0x0670, 2, 0),
- MX7D_PAD_ECSPI2_MOSI__GPIO4_IO21 =
IOMUX_PAD(0x03EC, 0x017C, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MOSI__EPDC_PWR_CTRL1 =
IOMUX_PAD(0x03EC, 0x017C, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__GPIO4_IO22 =
IOMUX_PAD(0x03F0, 0x0180, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__EPDC_PWR_CTRL2 =
IOMUX_PAD(0x03F0, 0x0180, 6, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__ECSPI2_MISO =
IOMUX_PAD(0x03F0, 0x0180, 0, 0x0538, 0, 0),
- MX7D_PAD_ECSPI2_MISO__UART7_DCE_RTS =
IOMUX_PAD(0x03F0, 0x0180, 1, 0x0720, 2, 0),
- MX7D_PAD_ECSPI2_MISO__UART7_DTE_CTS =
IOMUX_PAD(0x03F0, 0x0180, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__SD1_DATA6 =
IOMUX_PAD(0x03F0, 0x0180, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_MISO__CSI_DATA8 =
IOMUX_PAD(0x03F0, 0x0180, 3, 0x0510, 1, 0),
- MX7D_PAD_ECSPI2_MISO__LCD_DATA15 =
IOMUX_PAD(0x03F0, 0x0180, 4, 0x0674, 2, 0),
- MX7D_PAD_ECSPI2_SS0__ECSPI2_SS0 =
IOMUX_PAD(0x03F4, 0x0184, 0, 0x0540, 0, 0),
- MX7D_PAD_ECSPI2_SS0__UART7_DCE_CTS =
IOMUX_PAD(0x03F4, 0x0184, 1, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__UART7_DTE_RTS =
IOMUX_PAD(0x03F4, 0x0184, 1, 0x0720, 3, 0),
- MX7D_PAD_ECSPI2_SS0__SD1_DATA7 =
IOMUX_PAD(0x03F4, 0x0184, 2, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__CSI_DATA9 =
IOMUX_PAD(0x03F4, 0x0184, 3, 0x0514, 1, 0),
- MX7D_PAD_ECSPI2_SS0__LCD_RESET =
IOMUX_PAD(0x03F4, 0x0184, 4, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__GPIO4_IO23 =
IOMUX_PAD(0x03F4, 0x0184, 5, 0x0000, 0, 0),
- MX7D_PAD_ECSPI2_SS0__EPDC_PWR_WAKE =
IOMUX_PAD(0x03F4, 0x0184, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__SD1_CD_B =
IOMUX_PAD(0x03F8, 0x0188, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__UART6_DCE_RX =
IOMUX_PAD(0x03F8, 0x0188, 2, 0x071C, 4, 0),
- MX7D_PAD_SD1_CD_B__UART6_DTE_TX =
IOMUX_PAD(0x03F8, 0x0188, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__ECSPI4_MISO =
IOMUX_PAD(0x03F8, 0x0188, 3, 0x0558, 1, 0),
- MX7D_PAD_SD1_CD_B__FLEXTIMER1_CH0 =
IOMUX_PAD(0x03F8, 0x0188, 4, 0x0584, 1, 0),
- MX7D_PAD_SD1_CD_B__GPIO5_IO0 =
IOMUX_PAD(0x03F8, 0x0188, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CD_B__CCM_CLKO1 =
IOMUX_PAD(0x03F8, 0x0188, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__SD1_WP =
IOMUX_PAD(0x03FC, 0x018C, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__UART6_DCE_TX =
IOMUX_PAD(0x03FC, 0x018C, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__UART6_DTE_RX =
IOMUX_PAD(0x03FC, 0x018C, 2, 0x071C, 5, 0),
- MX7D_PAD_SD1_WP__ECSPI4_MOSI =
IOMUX_PAD(0x03FC, 0x018C, 3, 0x055C, 1, 0),
- MX7D_PAD_SD1_WP__FLEXTIMER1_CH1 =
IOMUX_PAD(0x03FC, 0x018C, 4, 0x0588, 1, 0),
- MX7D_PAD_SD1_WP__GPIO5_IO1 =
IOMUX_PAD(0x03FC, 0x018C, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_WP__CCM_CLKO2 =
IOMUX_PAD(0x03FC, 0x018C, 6, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__SD1_RESET_B =
IOMUX_PAD(0x0400, 0x0190, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__SAI3_MCLK =
IOMUX_PAD(0x0400, 0x0190, 1, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__UART6_DCE_RTS =
IOMUX_PAD(0x0400, 0x0190, 2, 0x0718, 4, 0),
- MX7D_PAD_SD1_RESET_B__UART6_DTE_CTS =
IOMUX_PAD(0x0400, 0x0190, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_RESET_B__ECSPI4_SCLK =
IOMUX_PAD(0x0400, 0x0190, 3, 0x0554, 1, 0),
- MX7D_PAD_SD1_RESET_B__FLEXTIMER1_CH2 =
IOMUX_PAD(0x0400, 0x0190, 4, 0x058C, 1, 0),
- MX7D_PAD_SD1_RESET_B__GPIO5_IO2 =
IOMUX_PAD(0x0400, 0x0190, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__SD1_CLK =
IOMUX_PAD(0x0404, 0x0194, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__SAI3_RX_SYNC =
IOMUX_PAD(0x0404, 0x0194, 1, 0x06CC, 1, 0),
- MX7D_PAD_SD1_CLK__UART6_DCE_CTS =
IOMUX_PAD(0x0404, 0x0194, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_CLK__UART6_DTE_RTS =
IOMUX_PAD(0x0404, 0x0194, 2, 0x0718, 5, 0),
- MX7D_PAD_SD1_CLK__ECSPI4_SS0 =
IOMUX_PAD(0x0404, 0x0194, 3, 0x0560, 1, 0),
- MX7D_PAD_SD1_CLK__FLEXTIMER1_CH3 =
IOMUX_PAD(0x0404, 0x0194, 4, 0x0590, 1, 0),
- MX7D_PAD_SD1_CLK__GPIO5_IO3 =
IOMUX_PAD(0x0404, 0x0194, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__SD1_CMD =
IOMUX_PAD(0x0408, 0x0198, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__SAI3_RX_BCLK =
IOMUX_PAD(0x0408, 0x0198, 1, 0x06C4, 1, 0),
- MX7D_PAD_SD1_CMD__ECSPI4_SS1 =
IOMUX_PAD(0x0408, 0x0198, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_CMD__FLEXTIMER2_CH0 =
IOMUX_PAD(0x0408, 0x0198, 4, 0x05AC, 1, 0),
- MX7D_PAD_SD1_CMD__GPIO5_IO4 =
IOMUX_PAD(0x0408, 0x0198, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__SD1_DATA0 =
IOMUX_PAD(0x040C, 0x019C, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__SAI3_RX_DATA0 =
IOMUX_PAD(0x040C, 0x019C, 1, 0x06C8, 1, 0),
- MX7D_PAD_SD1_DATA0__UART7_DCE_RX =
IOMUX_PAD(0x040C, 0x019C, 2, 0x0724, 4, 0),
- MX7D_PAD_SD1_DATA0__UART7_DTE_TX =
IOMUX_PAD(0x040C, 0x019C, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__ECSPI4_SS2 =
IOMUX_PAD(0x040C, 0x019C, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__FLEXTIMER2_CH1 =
IOMUX_PAD(0x040C, 0x019C, 4, 0x05B0, 1, 0),
- MX7D_PAD_SD1_DATA0__GPIO5_IO5 =
IOMUX_PAD(0x040C, 0x019C, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA0__CCM_EXT_CLK1 =
IOMUX_PAD(0x040C, 0x019C, 6, 0x04E4, 1, 0),
- MX7D_PAD_SD1_DATA1__SD1_DATA1 =
IOMUX_PAD(0x0410, 0x01A0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__SAI3_TX_BCLK =
IOMUX_PAD(0x0410, 0x01A0, 1, 0x06D0, 1, 0),
- MX7D_PAD_SD1_DATA1__UART7_DCE_TX =
IOMUX_PAD(0x0410, 0x01A0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__UART7_DTE_RX =
IOMUX_PAD(0x0410, 0x01A0, 2, 0x0724, 5, 0),
- MX7D_PAD_SD1_DATA1__ECSPI4_SS3 =
IOMUX_PAD(0x0410, 0x01A0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__FLEXTIMER2_CH2 =
IOMUX_PAD(0x0410, 0x01A0, 4, 0x05B4, 1, 0),
- MX7D_PAD_SD1_DATA1__GPIO5_IO6 =
IOMUX_PAD(0x0410, 0x01A0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA1__CCM_EXT_CLK2 =
IOMUX_PAD(0x0410, 0x01A0, 6, 0x04E8, 1, 0),
- MX7D_PAD_SD1_DATA2__SD1_DATA2 =
IOMUX_PAD(0x0414, 0x01A4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__SAI3_TX_SYNC =
IOMUX_PAD(0x0414, 0x01A4, 1, 0x06D4, 1, 0),
- MX7D_PAD_SD1_DATA2__UART7_DCE_CTS =
IOMUX_PAD(0x0414, 0x01A4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__UART7_DTE_RTS =
IOMUX_PAD(0x0414, 0x01A4, 2, 0x0720, 4, 0),
- MX7D_PAD_SD1_DATA2__ECSPI4_RDY =
IOMUX_PAD(0x0414, 0x01A4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__FLEXTIMER2_CH3 =
IOMUX_PAD(0x0414, 0x01A4, 4, 0x05B8, 1, 0),
- MX7D_PAD_SD1_DATA2__GPIO5_IO7 =
IOMUX_PAD(0x0414, 0x01A4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA2__CCM_EXT_CLK3 =
IOMUX_PAD(0x0414, 0x01A4, 6, 0x04EC, 1, 0),
- MX7D_PAD_SD1_DATA3__SD1_DATA3 =
IOMUX_PAD(0x0418, 0x01A8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__SAI3_TX_DATA0 =
IOMUX_PAD(0x0418, 0x01A8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__UART7_DCE_RTS =
IOMUX_PAD(0x0418, 0x01A8, 2, 0x0720, 5, 0),
- MX7D_PAD_SD1_DATA3__UART7_DTE_CTS =
IOMUX_PAD(0x0418, 0x01A8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__ECSPI3_SS1 =
IOMUX_PAD(0x0418, 0x01A8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__FLEXTIMER1_PHA =
IOMUX_PAD(0x0418, 0x01A8, 4, 0x05A4, 1, 0),
- MX7D_PAD_SD1_DATA3__GPIO5_IO8 =
IOMUX_PAD(0x0418, 0x01A8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD1_DATA3__CCM_EXT_CLK4 =
IOMUX_PAD(0x0418, 0x01A8, 6, 0x04F0, 1, 0),
- MX7D_PAD_SD2_CD_B__SD2_CD_B =
IOMUX_PAD(0x041C, 0x01AC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__ENET1_MDIO =
IOMUX_PAD(0x041C, 0x01AC, 1, 0x0568, 2, 0),
- MX7D_PAD_SD2_CD_B__ENET2_MDIO =
IOMUX_PAD(0x041C, 0x01AC, 2, 0x0574, 2, 0),
- MX7D_PAD_SD2_CD_B__ECSPI3_SS2 =
IOMUX_PAD(0x041C, 0x01AC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__FLEXTIMER1_PHB =
IOMUX_PAD(0x041C, 0x01AC, 4, 0x05A8, 1, 0),
- MX7D_PAD_SD2_CD_B__GPIO5_IO9 =
IOMUX_PAD(0x041C, 0x01AC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CD_B__SDMA_EXT_EVENT0 =
IOMUX_PAD(0x041C, 0x01AC, 6, 0x06D8, 2, 0),
- MX7D_PAD_SD2_WP__SD2_WP =
IOMUX_PAD(0x0420, 0x01B0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ENET1_MDC =
IOMUX_PAD(0x0420, 0x01B0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ENET2_MDC =
IOMUX_PAD(0x0420, 0x01B0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__ECSPI3_SS3 =
IOMUX_PAD(0x0420, 0x01B0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__USB_OTG1_ID =
IOMUX_PAD(0x0420, 0x01B0, 4, 0x0734, 2, 0),
- MX7D_PAD_SD2_WP__GPIO5_IO10 =
IOMUX_PAD(0x0420, 0x01B0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_WP__SDMA_EXT_EVENT1 =
IOMUX_PAD(0x0420, 0x01B0, 6, 0x06DC, 2, 0),
- MX7D_PAD_SD2_RESET_B__SD2_RESET_B =
IOMUX_PAD(0x0424, 0x01B4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__SAI2_MCLK =
IOMUX_PAD(0x0424, 0x01B4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__SD2_RESET =
IOMUX_PAD(0x0424, 0x01B4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__ECSPI3_RDY =
IOMUX_PAD(0x0424, 0x01B4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_RESET_B__USB_OTG2_ID =
IOMUX_PAD(0x0424, 0x01B4, 4, 0x0730, 2, 0),
- MX7D_PAD_SD2_RESET_B__GPIO5_IO11 =
IOMUX_PAD(0x0424, 0x01B4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__SD2_CLK =
IOMUX_PAD(0x0428, 0x01B8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__SAI2_RX_SYNC =
IOMUX_PAD(0x0428, 0x01B8, 1, 0x06B8, 0, 0),
- MX7D_PAD_SD2_CLK__MQS_RIGHT =
IOMUX_PAD(0x0428, 0x01B8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__GPT4_CLK =
IOMUX_PAD(0x0428, 0x01B8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CLK__GPIO5_IO12 =
IOMUX_PAD(0x0428, 0x01B8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SD2_CMD =
IOMUX_PAD(0x042C, 0x01BC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SAI2_RX_BCLK =
IOMUX_PAD(0x042C, 0x01BC, 1, 0x06B0, 0, 0),
- MX7D_PAD_SD2_CMD__MQS_LEFT =
IOMUX_PAD(0x042C, 0x01BC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__GPT4_CAPTURE1 =
IOMUX_PAD(0x042C, 0x01BC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_CMD__SIM2_PORT1_TRXD =
IOMUX_PAD(0x042C, 0x01BC, 4, 0x06EC, 1, 0),
- MX7D_PAD_SD2_CMD__GPIO5_IO13 =
IOMUX_PAD(0x042C, 0x01BC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SD2_DATA0 =
IOMUX_PAD(0x0430, 0x01C0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SAI2_RX_DATA0 =
IOMUX_PAD(0x0430, 0x01C0, 1, 0x06B4, 0, 0),
- MX7D_PAD_SD2_DATA0__UART4_DCE_RX =
IOMUX_PAD(0x0430, 0x01C0, 2, 0x070C, 2, 0),
- MX7D_PAD_SD2_DATA0__UART4_DTE_TX =
IOMUX_PAD(0x0430, 0x01C0, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__GPT4_CAPTURE2 =
IOMUX_PAD(0x0430, 0x01C0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__SIM2_PORT1_CLK =
IOMUX_PAD(0x0430, 0x01C0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA0__GPIO5_IO14 =
IOMUX_PAD(0x0430, 0x01C0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SD2_DATA1 =
IOMUX_PAD(0x0434, 0x01C4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SAI2_TX_BCLK =
IOMUX_PAD(0x0434, 0x01C4, 1, 0x06BC, 0, 0),
- MX7D_PAD_SD2_DATA1__UART4_DCE_TX =
IOMUX_PAD(0x0434, 0x01C4, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__UART4_DTE_RX =
IOMUX_PAD(0x0434, 0x01C4, 2, 0x070C, 3, 0),
- MX7D_PAD_SD2_DATA1__GPT4_COMPARE1 =
IOMUX_PAD(0x0434, 0x01C4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__SIM2_PORT1_RST_B =
IOMUX_PAD(0x0434, 0x01C4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA1__GPIO5_IO15 =
IOMUX_PAD(0x0434, 0x01C4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SD2_DATA2 =
IOMUX_PAD(0x0438, 0x01C8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SAI2_TX_SYNC =
IOMUX_PAD(0x0438, 0x01C8, 1, 0x06C0, 0, 0),
- MX7D_PAD_SD2_DATA2__UART4_DCE_CTS =
IOMUX_PAD(0x0438, 0x01C8, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__UART4_DTE_RTS =
IOMUX_PAD(0x0438, 0x01C8, 2, 0x0708, 2, 0),
- MX7D_PAD_SD2_DATA2__GPT4_COMPARE2 =
IOMUX_PAD(0x0438, 0x01C8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__SIM2_PORT1_SVEN =
IOMUX_PAD(0x0438, 0x01C8, 4, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA2__GPIO5_IO16 =
IOMUX_PAD(0x0438, 0x01C8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SD2_DATA3 =
IOMUX_PAD(0x043C, 0x01CC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SAI2_TX_DATA0 =
IOMUX_PAD(0x043C, 0x01CC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__UART4_DCE_RTS =
IOMUX_PAD(0x043C, 0x01CC, 2, 0x0708, 3, 0),
- MX7D_PAD_SD2_DATA3__UART4_DTE_CTS =
IOMUX_PAD(0x043C, 0x01CC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__GPT4_COMPARE3 =
IOMUX_PAD(0x043C, 0x01CC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD2_DATA3__SIM2_PORT1_PD =
IOMUX_PAD(0x043C, 0x01CC, 4, 0x06E8, 1, 0),
- MX7D_PAD_SD2_DATA3__GPIO5_IO17 =
IOMUX_PAD(0x043C, 0x01CC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__SD3_CLK =
IOMUX_PAD(0x0440, 0x01D0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__NAND_CLE =
IOMUX_PAD(0x0440, 0x01D0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__ECSPI4_MISO =
IOMUX_PAD(0x0440, 0x01D0, 2, 0x0558, 2, 0),
- MX7D_PAD_SD3_CLK__SAI3_RX_SYNC =
IOMUX_PAD(0x0440, 0x01D0, 3, 0x06CC, 2, 0),
- MX7D_PAD_SD3_CLK__GPT3_CLK =
IOMUX_PAD(0x0440, 0x01D0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_CLK__GPIO6_IO0 =
IOMUX_PAD(0x0440, 0x01D0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__SD3_CMD =
IOMUX_PAD(0x0444, 0x01D4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__NAND_ALE =
IOMUX_PAD(0x0444, 0x01D4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__ECSPI4_MOSI =
IOMUX_PAD(0x0444, 0x01D4, 2, 0x055C, 2, 0),
- MX7D_PAD_SD3_CMD__SAI3_RX_BCLK =
IOMUX_PAD(0x0444, 0x01D4, 3, 0x06C4, 2, 0),
- MX7D_PAD_SD3_CMD__GPT3_CAPTURE1 =
IOMUX_PAD(0x0444, 0x01D4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_CMD__GPIO6_IO1 =
IOMUX_PAD(0x0444, 0x01D4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__SD3_DATA0 =
IOMUX_PAD(0x0448, 0x01D8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__NAND_DATA00 =
IOMUX_PAD(0x0448, 0x01D8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__ECSPI4_SS0 =
IOMUX_PAD(0x0448, 0x01D8, 2, 0x0560, 2, 0),
- MX7D_PAD_SD3_DATA0__SAI3_RX_DATA0 =
IOMUX_PAD(0x0448, 0x01D8, 3, 0x06C8, 2, 0),
- MX7D_PAD_SD3_DATA0__GPT3_CAPTURE2 =
IOMUX_PAD(0x0448, 0x01D8, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA0__GPIO6_IO2 =
IOMUX_PAD(0x0448, 0x01D8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__SD3_DATA1 =
IOMUX_PAD(0x044C, 0x01DC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__NAND_DATA01 =
IOMUX_PAD(0x044C, 0x01DC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__ECSPI4_SCLK =
IOMUX_PAD(0x044C, 0x01DC, 2, 0x0554, 2, 0),
- MX7D_PAD_SD3_DATA1__SAI3_TX_BCLK =
IOMUX_PAD(0x044C, 0x01DC, 3, 0x06D0, 2, 0),
- MX7D_PAD_SD3_DATA1__GPT3_COMPARE1 =
IOMUX_PAD(0x044C, 0x01DC, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA1__GPIO6_IO3 =
IOMUX_PAD(0x044C, 0x01DC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__SD3_DATA2 =
IOMUX_PAD(0x0450, 0x01E0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__NAND_DATA02 =
IOMUX_PAD(0x0450, 0x01E0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__I2C3_SDA =
IOMUX_PAD(0x0450, 0x01E0, IOMUX_CONFIG_SION | 2, 0x05E8, 3, 0),
- MX7D_PAD_SD3_DATA2__SAI3_TX_SYNC =
IOMUX_PAD(0x0450, 0x01E0, 3, 0x06D4, 2, 0),
- MX7D_PAD_SD3_DATA2__GPT3_COMPARE2 =
IOMUX_PAD(0x0450, 0x01E0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA2__GPIO6_IO4 =
IOMUX_PAD(0x0450, 0x01E0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__SD3_DATA3 =
IOMUX_PAD(0x0454, 0x01E4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__NAND_DATA03 =
IOMUX_PAD(0x0454, 0x01E4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__I2C3_SCL =
IOMUX_PAD(0x0454, 0x01E4, IOMUX_CONFIG_SION | 2, 0x05E4, 3, 0),
- MX7D_PAD_SD3_DATA3__SAI3_TX_DATA0 =
IOMUX_PAD(0x0454, 0x01E4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__GPT3_COMPARE3 =
IOMUX_PAD(0x0454, 0x01E4, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA3__GPIO6_IO5 =
IOMUX_PAD(0x0454, 0x01E4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__SD3_DATA4 =
IOMUX_PAD(0x0458, 0x01E8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__NAND_DATA04 =
IOMUX_PAD(0x0458, 0x01E8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__UART3_DCE_RX =
IOMUX_PAD(0x0458, 0x01E8, 3, 0x0704, 4, 0),
- MX7D_PAD_SD3_DATA4__UART3_DTE_TX =
IOMUX_PAD(0x0458, 0x01E8, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA4__FLEXCAN2_RX =
IOMUX_PAD(0x0458, 0x01E8, 4, 0x04E0, 2, 0),
- MX7D_PAD_SD3_DATA4__GPIO6_IO6 =
IOMUX_PAD(0x0458, 0x01E8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__SD3_DATA5 =
IOMUX_PAD(0x045C, 0x01EC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__NAND_DATA05 =
IOMUX_PAD(0x045C, 0x01EC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__UART3_DCE_TX =
IOMUX_PAD(0x045C, 0x01EC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__UART3_DTE_RX =
IOMUX_PAD(0x045C, 0x01EC, 3, 0x0704, 5, 0),
- MX7D_PAD_SD3_DATA5__FLEXCAN1_TX =
IOMUX_PAD(0x045C, 0x01EC, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA5__GPIO6_IO7 =
IOMUX_PAD(0x045C, 0x01EC, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__SD3_DATA6 =
IOMUX_PAD(0x0460, 0x01F0, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__NAND_DATA06 =
IOMUX_PAD(0x0460, 0x01F0, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__SD3_WP =
IOMUX_PAD(0x0460, 0x01F0, 2, 0x073C, 2, 0),
- MX7D_PAD_SD3_DATA6__UART3_DCE_RTS =
IOMUX_PAD(0x0460, 0x01F0, 3, 0x0700, 4, 0),
- MX7D_PAD_SD3_DATA6__UART3_DTE_CTS =
IOMUX_PAD(0x0460, 0x01F0, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__FLEXCAN2_TX =
IOMUX_PAD(0x0460, 0x01F0, 4, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA6__GPIO6_IO8 =
IOMUX_PAD(0x0460, 0x01F0, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__SD3_DATA7 =
IOMUX_PAD(0x0464, 0x01F4, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__NAND_DATA07 =
IOMUX_PAD(0x0464, 0x01F4, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__SD3_CD_B =
IOMUX_PAD(0x0464, 0x01F4, 2, 0x0738, 2, 0),
- MX7D_PAD_SD3_DATA7__UART3_DCE_CTS =
IOMUX_PAD(0x0464, 0x01F4, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_DATA7__UART3_DTE_RTS =
IOMUX_PAD(0x0464, 0x01F4, 3, 0x0700, 5, 0),
- MX7D_PAD_SD3_DATA7__FLEXCAN1_RX =
IOMUX_PAD(0x0464, 0x01F4, 4, 0x04DC, 2, 0),
- MX7D_PAD_SD3_DATA7__GPIO6_IO9 =
IOMUX_PAD(0x0464, 0x01F4, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__SD3_STROBE =
IOMUX_PAD(0x0468, 0x01F8, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__NAND_RE_B =
IOMUX_PAD(0x0468, 0x01F8, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_STROBE__GPIO6_IO10 =
IOMUX_PAD(0x0468, 0x01F8, 5, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SD3_RESET_B =
IOMUX_PAD(0x046C, 0x01FC, 0, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__NAND_WE_B =
IOMUX_PAD(0x046C, 0x01FC, 1, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SD3_RESET =
IOMUX_PAD(0x046C, 0x01FC, 2, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__SAI3_MCLK =
IOMUX_PAD(0x046C, 0x01FC, 3, 0x0000, 0, 0),
- MX7D_PAD_SD3_RESET_B__GPIO6_IO11 =
IOMUX_PAD(0x046C, 0x01FC, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__SAI1_RX_DATA0 =
IOMUX_PAD(0x0470, 0x0200, 0, 0x06A0, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__NAND_CE1_B =
IOMUX_PAD(0x0470, 0x0200, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__UART5_DCE_RX =
IOMUX_PAD(0x0470, 0x0200, 2, 0x0714, 2, 0),
- MX7D_PAD_SAI1_RX_DATA__UART5_DTE_TX =
IOMUX_PAD(0x0470, 0x0200, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__FLEXCAN1_RX =
IOMUX_PAD(0x0470, 0x0200, 3, 0x04DC, 3, 0),
- MX7D_PAD_SAI1_RX_DATA__SIM1_PORT1_TRXD =
IOMUX_PAD(0x0470, 0x0200, 4, 0x06E4, 1, 0),
- MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12 =
IOMUX_PAD(0x0470, 0x0200, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_DATA__SRC_ANY_PU_RESET =
IOMUX_PAD(0x0470, 0x0200, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SAI1_TX_BCLK =
IOMUX_PAD(0x0474, 0x0204, 0, 0x06A8, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B =
IOMUX_PAD(0x0474, 0x0204, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__UART5_DCE_TX =
IOMUX_PAD(0x0474, 0x0204, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__UART5_DTE_RX =
IOMUX_PAD(0x0474, 0x0204, 2, 0x0714, 3, 0),
- MX7D_PAD_SAI1_TX_BCLK__FLEXCAN1_TX =
IOMUX_PAD(0x0474, 0x0204, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SIM1_PORT1_CLK =
IOMUX_PAD(0x0474, 0x0204, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__GPIO6_IO13 =
IOMUX_PAD(0x0474, 0x0204, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_BCLK__SRC_EARLY_RESET =
IOMUX_PAD(0x0474, 0x0204, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__SAI1_TX_SYNC =
IOMUX_PAD(0x0478, 0x0208, 0, 0x06AC, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__NAND_DQS =
IOMUX_PAD(0x0478, 0x0208, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__UART5_DCE_CTS =
IOMUX_PAD(0x0478, 0x0208, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__UART5_DTE_RTS =
IOMUX_PAD(0x0478, 0x0208, 2, 0x0710, 2, 0),
- MX7D_PAD_SAI1_TX_SYNC__FLEXCAN2_RX =
IOMUX_PAD(0x0478, 0x0208, 3, 0x04E0, 3, 0),
- MX7D_PAD_SAI1_TX_SYNC__SIM1_PORT1_RST_B =
IOMUX_PAD(0x0478, 0x0208, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__GPIO6_IO14 =
IOMUX_PAD(0x0478, 0x0208, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_SYNC__SRC_INT_BOOT =
IOMUX_PAD(0x0478, 0x0208, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SAI1_TX_DATA0 =
IOMUX_PAD(0x047C, 0x020C, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__NAND_READY_B =
IOMUX_PAD(0x047C, 0x020C, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__UART5_DCE_RTS =
IOMUX_PAD(0x047C, 0x020C, 2, 0x0710, 3, 0),
- MX7D_PAD_SAI1_TX_DATA__UART5_DTE_CTS =
IOMUX_PAD(0x047C, 0x020C, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__FLEXCAN2_TX =
IOMUX_PAD(0x047C, 0x020C, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SIM1_PORT1_SVEN =
IOMUX_PAD(0x047C, 0x020C, 4, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__GPIO6_IO15 =
IOMUX_PAD(0x047C, 0x020C, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_TX_DATA__SRC_SYSTEM_RESET =
IOMUX_PAD(0x047C, 0x020C, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SAI1_RX_SYNC =
IOMUX_PAD(0x0480, 0x0210, 0, 0x06A4, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__NAND_CE2_B =
IOMUX_PAD(0x0480, 0x0210, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SAI2_RX_SYNC =
IOMUX_PAD(0x0480, 0x0210, 2, 0x06B8, 1, 0),
- MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL =
IOMUX_PAD(0x0480, 0x0210, IOMUX_CONFIG_SION | 3, 0x05EC, 3, 0),
- MX7D_PAD_SAI1_RX_SYNC__SIM1_PORT1_PD =
IOMUX_PAD(0x0480, 0x0210, 4, 0x06E0, 1, 0),
- MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16 =
IOMUX_PAD(0x0480, 0x0210, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__MQS_RIGHT =
IOMUX_PAD(0x0480, 0x0210, 6, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_SYNC__SRC_CA7_RESET_B0 =
IOMUX_PAD(0x0480, 0x0210, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SAI1_RX_BCLK =
IOMUX_PAD(0x0484, 0x0214, 0, 0x069C, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__NAND_CE3_B =
IOMUX_PAD(0x0484, 0x0214, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SAI2_RX_BCLK =
IOMUX_PAD(0x0484, 0x0214, 2, 0x06B0, 1, 0),
- MX7D_PAD_SAI1_RX_BCLK__I2C4_SDA =
IOMUX_PAD(0x0484, 0x0214, IOMUX_CONFIG_SION | 3, 0x05F0, 3, 0),
- MX7D_PAD_SAI1_RX_BCLK__FLEXTIMER2_PHA =
IOMUX_PAD(0x0484, 0x0214, 4, 0x05CC, 1, 0),
- MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 =
IOMUX_PAD(0x0484, 0x0214, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__MQS_LEFT =
IOMUX_PAD(0x0484, 0x0214, 6, 0x0000, 0, 0),
- MX7D_PAD_SAI1_RX_BCLK__SRC_CA7_RESET_B1 =
IOMUX_PAD(0x0484, 0x0214, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SAI1_MCLK =
IOMUX_PAD(0x0488, 0x0218, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__NAND_WP_B =
IOMUX_PAD(0x0488, 0x0218, 1, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SAI2_MCLK =
IOMUX_PAD(0x0488, 0x0218, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__CCM_PMIC_READY =
IOMUX_PAD(0x0488, 0x0218, 3, 0x04F4, 3, 0),
- MX7D_PAD_SAI1_MCLK__FLEXTIMER2_PHB =
IOMUX_PAD(0x0488, 0x0218, 4, 0x05D0, 1, 0),
- MX7D_PAD_SAI1_MCLK__GPIO6_IO18 =
IOMUX_PAD(0x0488, 0x0218, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI1_MCLK__SRC_TESTER_ACK =
IOMUX_PAD(0x0488, 0x0218, 7, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__SAI2_TX_SYNC =
IOMUX_PAD(0x048C, 0x021C, 0, 0x06C0, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO =
IOMUX_PAD(0x048C, 0x021C, 1, 0x0548, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART4_DCE_RX =
IOMUX_PAD(0x048C, 0x021C, 2, 0x070C, 4, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART4_DTE_TX =
IOMUX_PAD(0x048C, 0x021C, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART1_DCE_CTS =
IOMUX_PAD(0x048C, 0x021C, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__UART1_DTE_RTS =
IOMUX_PAD(0x048C, 0x021C, 3, 0x06F0, 0, 0),
- MX7D_PAD_SAI2_TX_SYNC__FLEXTIMER2_CH4 =
IOMUX_PAD(0x048C, 0x021C, 4, 0x05BC, 1, 0),
- MX7D_PAD_SAI2_TX_SYNC__GPIO6_IO19 =
IOMUX_PAD(0x048C, 0x021C, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__SAI2_TX_BCLK =
IOMUX_PAD(0x0490, 0x0220, 0, 0x06BC, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__ECSPI3_MOSI =
IOMUX_PAD(0x0490, 0x0220, 1, 0x054C, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART4_DCE_TX =
IOMUX_PAD(0x0490, 0x0220, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART4_DTE_RX =
IOMUX_PAD(0x0490, 0x0220, 2, 0x070C, 5, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART1_DCE_RTS =
IOMUX_PAD(0x0490, 0x0220, 3, 0x06F0, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__UART1_DTE_CTS =
IOMUX_PAD(0x0490, 0x0220, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_BCLK__FLEXTIMER2_CH5 =
IOMUX_PAD(0x0490, 0x0220, 4, 0x05C0, 1, 0),
- MX7D_PAD_SAI2_TX_BCLK__GPIO6_IO20 =
IOMUX_PAD(0x0490, 0x0220, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__SAI2_RX_DATA0 =
IOMUX_PAD(0x0494, 0x0224, 0, 0x06B4, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK =
IOMUX_PAD(0x0494, 0x0224, 1, 0x0544, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__UART4_DCE_CTS =
IOMUX_PAD(0x0494, 0x0224, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__UART4_DTE_RTS =
IOMUX_PAD(0x0494, 0x0224, 2, 0x0708, 4, 0),
- MX7D_PAD_SAI2_RX_DATA__UART2_DCE_CTS =
IOMUX_PAD(0x0494, 0x0224, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__UART2_DTE_RTS =
IOMUX_PAD(0x0494, 0x0224, 3, 0x06F8, 2, 0),
- MX7D_PAD_SAI2_RX_DATA__FLEXTIMER2_CH6 =
IOMUX_PAD(0x0494, 0x0224, 4, 0x05C4, 1, 0),
- MX7D_PAD_SAI2_RX_DATA__GPIO6_IO21 =
IOMUX_PAD(0x0494, 0x0224, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_RX_DATA__KPP_COL7 =
IOMUX_PAD(0x0494, 0x0224, 6, 0x0610, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__SAI2_TX_DATA0 =
IOMUX_PAD(0x0498, 0x0228, 0, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__ECSPI3_SS0 =
IOMUX_PAD(0x0498, 0x0228, 1, 0x0550, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__UART4_DCE_RTS =
IOMUX_PAD(0x0498, 0x0228, 2, 0x0708, 5, 0),
- MX7D_PAD_SAI2_TX_DATA__UART4_DTE_CTS =
IOMUX_PAD(0x0498, 0x0228, 2, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__UART2_DCE_RTS =
IOMUX_PAD(0x0498, 0x0228, 3, 0x06F8, 3, 0),
- MX7D_PAD_SAI2_TX_DATA__UART2_DTE_CTS =
IOMUX_PAD(0x0498, 0x0228, 3, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__FLEXTIMER2_CH7 =
IOMUX_PAD(0x0498, 0x0228, 4, 0x05C8, 1, 0),
- MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 =
IOMUX_PAD(0x0498, 0x0228, 5, 0x0000, 0, 0),
- MX7D_PAD_SAI2_TX_DATA__KPP_ROW7 =
IOMUX_PAD(0x0498, 0x0228, 6, 0x0630, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 =
IOMUX_PAD(0x049C, 0x022C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__PWM1_OUT =
IOMUX_PAD(0x049C, 0x022C, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__I2C3_SCL =
IOMUX_PAD(0x049C, 0x022C, IOMUX_CONFIG_SION | 2, 0x05E4, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD0__UART1_DCE_CTS =
IOMUX_PAD(0x049C, 0x022C, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__UART1_DTE_RTS =
IOMUX_PAD(0x049C, 0x022C, 3, 0x06F0, 2, 0),
- MX7D_PAD_ENET1_RGMII_RD0__EPDC_VCOM0 =
IOMUX_PAD(0x049C, 0x022C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__GPIO7_IO0 =
IOMUX_PAD(0x049C, 0x022C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD0__KPP_ROW3 =
IOMUX_PAD(0x049C, 0x022C, 6, 0x0620, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 =
IOMUX_PAD(0x04A0, 0x0230, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__PWM2_OUT =
IOMUX_PAD(0x04A0, 0x0230, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__I2C3_SDA =
IOMUX_PAD(0x04A0, 0x0230, IOMUX_CONFIG_SION | 2, 0x05E8, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD1__UART1_DCE_RTS =
IOMUX_PAD(0x04A0, 0x0230, 3, 0x06F0, 3, 0),
- MX7D_PAD_ENET1_RGMII_RD1__UART1_DTE_CTS =
IOMUX_PAD(0x04A0, 0x0230, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__EPDC_VCOM1 =
IOMUX_PAD(0x04A0, 0x0230, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__GPIO7_IO1 =
IOMUX_PAD(0x04A0, 0x0230, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD1__KPP_COL3 =
IOMUX_PAD(0x04A0, 0x0230, 6, 0x0600, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 =
IOMUX_PAD(0x04A4, 0x0234, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__FLEXCAN1_RX =
IOMUX_PAD(0x04A4, 0x0234, 1, 0x04DC, 4, 0),
- MX7D_PAD_ENET1_RGMII_RD2__ECSPI2_SCLK =
IOMUX_PAD(0x04A4, 0x0234, 2, 0x0534, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD2__UART1_DCE_RX =
IOMUX_PAD(0x04A4, 0x0234, 3, 0x06F4, 2, 0),
- MX7D_PAD_ENET1_RGMII_RD2__UART1_DTE_TX =
IOMUX_PAD(0x04A4, 0x0234, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__EPDC_SDCE4 =
IOMUX_PAD(0x04A4, 0x0234, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__GPIO7_IO2 =
IOMUX_PAD(0x04A4, 0x0234, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD2__KPP_ROW2 =
IOMUX_PAD(0x04A4, 0x0234, 6, 0x061C, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 =
IOMUX_PAD(0x04A8, 0x0238, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__FLEXCAN1_TX =
IOMUX_PAD(0x04A8, 0x0238, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__ECSPI2_MOSI =
IOMUX_PAD(0x04A8, 0x0238, 2, 0x053C, 1, 0),
- MX7D_PAD_ENET1_RGMII_RD3__UART1_DCE_TX =
IOMUX_PAD(0x04A8, 0x0238, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__UART1_DTE_RX =
IOMUX_PAD(0x04A8, 0x0238, 3, 0x06F4, 3, 0),
- MX7D_PAD_ENET1_RGMII_RD3__EPDC_SDCE5 =
IOMUX_PAD(0x04A8, 0x0238, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__GPIO7_IO3 =
IOMUX_PAD(0x04A8, 0x0238, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RD3__KPP_COL2 =
IOMUX_PAD(0x04A8, 0x0238, 6, 0x05FC, 1, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL =
IOMUX_PAD(0x04AC, 0x023C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__ECSPI2_SS1 =
IOMUX_PAD(0x04AC, 0x023C, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__EPDC_SDCE6 =
IOMUX_PAD(0x04AC, 0x023C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__GPIO7_IO4 =
IOMUX_PAD(0x04AC, 0x023C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RX_CTL__KPP_ROW1 =
IOMUX_PAD(0x04AC, 0x023C, 6, 0x0618, 1, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC =
IOMUX_PAD(0x04B0, 0x0240, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ENET1_RX_ER =
IOMUX_PAD(0x04B0, 0x0240, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__ECSPI2_SS2 =
IOMUX_PAD(0x04B0, 0x0240, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__EPDC_SDCE7 =
IOMUX_PAD(0x04B0, 0x0240, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__GPIO7_IO5 =
IOMUX_PAD(0x04B0, 0x0240, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_RXC__KPP_COL1 =
IOMUX_PAD(0x04B0, 0x0240, 6, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 =
IOMUX_PAD(0x04B4, 0x0244, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__PWM3_OUT =
IOMUX_PAD(0x04B4, 0x0244, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__ECSPI2_SS3 =
IOMUX_PAD(0x04B4, 0x0244, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__EPDC_SDCE8 =
IOMUX_PAD(0x04B4, 0x0244, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__GPIO7_IO6 =
IOMUX_PAD(0x04B4, 0x0244, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD0__KPP_ROW0 =
IOMUX_PAD(0x04B4, 0x0244, 6, 0x0614, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 =
IOMUX_PAD(0x04B8, 0x0248, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__PWM4_OUT =
IOMUX_PAD(0x04B8, 0x0248, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__ECSPI2_RDY =
IOMUX_PAD(0x04B8, 0x0248, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__EPDC_SDCE9 =
IOMUX_PAD(0x04B8, 0x0248, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__GPIO7_IO7 =
IOMUX_PAD(0x04B8, 0x0248, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD1__KPP_COL0 =
IOMUX_PAD(0x04B8, 0x0248, 6, 0x05F4, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 =
IOMUX_PAD(0x04BC, 0x024C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD2__FLEXCAN2_RX =
IOMUX_PAD(0x04BC, 0x024C, 1, 0x04E0, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD2__ECSPI2_MISO =
IOMUX_PAD(0x04BC, 0x024C, 2, 0x0538, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD2__I2C4_SCL =
IOMUX_PAD(0x04BC, 0x024C, IOMUX_CONFIG_SION | 3, 0x05EC, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD2__EPDC_SDOED =
IOMUX_PAD(0x04BC, 0x024C, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD2__GPIO7_IO8 =
IOMUX_PAD(0x04BC, 0x024C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 =
IOMUX_PAD(0x04C0, 0x0250, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__FLEXCAN2_TX =
IOMUX_PAD(0x04C0, 0x0250, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__ECSPI2_SS0 =
IOMUX_PAD(0x04C0, 0x0250, 2, 0x0540, 1, 0),
- MX7D_PAD_ENET1_RGMII_TD3__I2C4_SDA =
IOMUX_PAD(0x04C0, 0x0250, IOMUX_CONFIG_SION | 3, 0x05F0, 4, 0),
- MX7D_PAD_ENET1_RGMII_TD3__EPDC_SDOEZ =
IOMUX_PAD(0x04C0, 0x0250, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__GPIO7_IO9 =
IOMUX_PAD(0x04C0, 0x0250, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TD3__CAAM_RNG_OSC_OBS =
IOMUX_PAD(0x04C0, 0x0250, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL =
IOMUX_PAD(0x04C4, 0x0254, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__SAI1_RX_SYNC =
IOMUX_PAD(0x04C4, 0x0254, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__GPT2_COMPARE1 =
IOMUX_PAD(0x04C4, 0x0254, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__EPDC_PWR_CTRL2 =
IOMUX_PAD(0x04C4, 0x0254, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TX_CTL__GPIO7_IO10 =
IOMUX_PAD(0x04C4, 0x0254, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC =
IOMUX_PAD(0x04C8, 0x0258, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__ENET1_TX_ER =
IOMUX_PAD(0x04C8, 0x0258, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__SAI1_RX_BCLK =
IOMUX_PAD(0x04C8, 0x0258, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__GPT2_COMPARE2 =
IOMUX_PAD(0x04C8, 0x0258, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__EPDC_PWR_CTRL3 =
IOMUX_PAD(0x04C8, 0x0258, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RGMII_TXC__GPIO7_IO11 =
IOMUX_PAD(0x04C8, 0x0258, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__ENET1_TX_CLK =
IOMUX_PAD(0x04CC, 0x025C, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__CCM_ENET_REF_CLK1 =
IOMUX_PAD(0x04CC, 0x025C, 1, 0x0564, 2, 0),
- MX7D_PAD_ENET1_TX_CLK__SAI1_RX_DATA0 =
IOMUX_PAD(0x04CC, 0x025C, 2, 0x06A0, 1, 0),
- MX7D_PAD_ENET1_TX_CLK__GPT2_COMPARE3 =
IOMUX_PAD(0x04CC, 0x025C, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__EPDC_PWR_IRQ =
IOMUX_PAD(0x04CC, 0x025C, 4, 0x057C, 1, 0),
- MX7D_PAD_ENET1_TX_CLK__GPIO7_IO12 =
IOMUX_PAD(0x04CC, 0x025C, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_TX_CLK__CCM_EXT_CLK1 =
IOMUX_PAD(0x04CC, 0x025C, 6, 0x04E4, 2, 0),
- MX7D_PAD_ENET1_TX_CLK__CSU_ALARM_AUT0 =
IOMUX_PAD(0x04CC, 0x025C, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__ENET1_RX_CLK =
IOMUX_PAD(0x04D0, 0x0260, 0, 0x056C, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__WDOG2_WDOG_B =
IOMUX_PAD(0x04D0, 0x0260, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__SAI1_TX_BCLK =
IOMUX_PAD(0x04D0, 0x0260, 2, 0x06A8, 1, 0),
- MX7D_PAD_ENET1_RX_CLK__GPT2_CLK =
IOMUX_PAD(0x04D0, 0x0260, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__EPDC_PWR_WAKE =
IOMUX_PAD(0x04D0, 0x0260, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__GPIO7_IO13 =
IOMUX_PAD(0x04D0, 0x0260, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_RX_CLK__CCM_EXT_CLK2 =
IOMUX_PAD(0x04D0, 0x0260, 6, 0x04E8, 2, 0),
- MX7D_PAD_ENET1_RX_CLK__CSU_ALARM_AUT1 =
IOMUX_PAD(0x04D0, 0x0260, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__ENET1_CRS =
IOMUX_PAD(0x04D4, 0x0264, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__WDOG2_WDOG_RST_B_DEB =
IOMUX_PAD(0x04D4, 0x0264, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__SAI1_TX_SYNC =
IOMUX_PAD(0x04D4, 0x0264, 2, 0x06AC, 1, 0),
- MX7D_PAD_ENET1_CRS__GPT2_CAPTURE1 =
IOMUX_PAD(0x04D4, 0x0264, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__EPDC_PWR_CTRL0 =
IOMUX_PAD(0x04D4, 0x0264, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__GPIO7_IO14 =
IOMUX_PAD(0x04D4, 0x0264, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_CRS__CCM_EXT_CLK3 =
IOMUX_PAD(0x04D4, 0x0264, 6, 0x04EC, 2, 0),
- MX7D_PAD_ENET1_CRS__CSU_ALARM_AUT2 =
IOMUX_PAD(0x04D4, 0x0264, 7, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__ENET1_COL =
IOMUX_PAD(0x04D8, 0x0268, 0, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__WDOG1_WDOG_ANY =
IOMUX_PAD(0x04D8, 0x0268, 1, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__SAI1_TX_DATA0 =
IOMUX_PAD(0x04D8, 0x0268, 2, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__GPT2_CAPTURE2 =
IOMUX_PAD(0x04D8, 0x0268, 3, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__EPDC_PWR_CTRL1 =
IOMUX_PAD(0x04D8, 0x0268, 4, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__GPIO7_IO15 =
IOMUX_PAD(0x04D8, 0x0268, 5, 0x0000, 0, 0),
- MX7D_PAD_ENET1_COL__CCM_EXT_CLK4 =
IOMUX_PAD(0x04D8, 0x0268, 6, 0x04F0, 2, 0),
- MX7D_PAD_ENET1_COL__CSU_INT_DEB =
IOMUX_PAD(0x04D8, 0x0268, 7, 0x0000, 0, 0),
+}; +#endif /* __ASM_ARCH_IMX7D_PINS_H__ */ diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h
b/arch/arm/include/asm/imx-common/iomux-v3.h
index 2581019..5dd64f5 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -85,6 +85,36 @@ typedef u64 iomux_v3_cfg_t;
#define NO_PAD_CTRL (1 << 17)
+#ifdef CONFIG_MX7
+#define IOMUX_LPSR_SEL_INPUT_OFS 0x70000 +#define IOMUX_CONFIG_LPSR 0x8 +#define MUX_MODE_LPSR ((iomux_v3_cfg_t)IOMUX_CONFIG_LPSR
MUX_MODE_SHIFT)
+#define PAD_CTL_DSE_1P8V_140OHM (0x0<<0) +#define PAD_CTL_DSE_1P8V_35OHM (0x1<<0) +#define PAD_CTL_DSE_1P8V_70OHM (0x2<<0) +#define PAD_CTL_DSE_1P8V_23OHM (0x3<<0)
+#define PAD_CTL_DSE_3P3V_196OHM (0x0<<0) +#define PAD_CTL_DSE_3P3V_49OHM (0x1<<0) +#define PAD_CTL_DSE_3P3V_98OHM (0x2<<0) +#define PAD_CTL_DSE_3P3V_32OHM (0x3<<0)
+#define PAD_CTL_SRE_FAST (0 << 2) +#define PAD_CTL_SRE_SLOW (0x1 << 2)
+#define PAD_CTL_HYS (0x1 << 3) +#define PAD_CTL_PUE (0x1 << 4)
+#define PAD_CTL_PUS_PD100KOHM ((0x0 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU5KOHM ((0x1 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU47KOHM ((0x2 << 5) | PAD_CTL_PUE) +#define PAD_CTL_PUS_PU100KOHM ((0x3 << 5) | PAD_CTL_PUE)
+#else
#ifdef CONFIG_MX6
#define PAD_CTL_HYS (1 << 16) @@ -167,6 +197,8 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_SRE_SLOW (0 << 0) #define PAD_CTL_SRE_FAST (1 << 0)
#define IOMUX_CONFIG_SION 0x10
#define GPIO_PIN_MASK 0x1f
Best regards, Stefano Babic
========= DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ============================================================ =========
* Add mxc_gpio support for imx7d SoC * Use CONFIG_MX7 to extend mxc gpio driver support for imx7d
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Resend Changes for V3: Resend
arch/arm/include/asm/arch-mx7/gpio.h | 12 ++++++++++++ drivers/gpio/mxc_gpio.c | 8 +++++--- 2 files changed, 17 insertions(+), 3 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx7/gpio.h
diff --git a/arch/arm/include/asm/arch-mx7/gpio.h b/arch/arm/include/asm/arch-mx7/gpio.h new file mode 100644 index 0000000..b7890c2 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/gpio.h @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_MX7_GPIO_H +#define __ASM_ARCH_MX7_GPIO_H + +#include <asm/imx-common/gpio.h> + +#endif /* __ASM_ARCH_MX7_GPIO_H */ diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index 2012f99..332ed40 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -40,14 +40,16 @@ static unsigned long gpio_ports[] = { [1] = GPIO2_BASE_ADDR, [2] = GPIO3_BASE_ADDR, #if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX51) || \ - defined(CONFIG_MX53) || defined(CONFIG_MX6) + defined(CONFIG_MX53) || defined(CONFIG_MX6) || \ + defined(CONFIG_MX7) [3] = GPIO4_BASE_ADDR, #endif -#if defined(CONFIG_MX27) || defined(CONFIG_MX53) || defined(CONFIG_MX6) +#if defined(CONFIG_MX27) || defined(CONFIG_MX53) || defined(CONFIG_MX6) || \ + defined(CONFIG_MX7) [4] = GPIO5_BASE_ADDR, [5] = GPIO6_BASE_ADDR, #endif -#if defined(CONFIG_MX53) || defined(CONFIG_MX6) +#if defined(CONFIG_MX53) || defined(CONFIG_MX6) || defined(CONFIG_MX7) [6] = GPIO7_BASE_ADDR, #endif };
* Ocotp of i.MX7D has different operation rule. This patch is to add support for i.MX7D ocotp.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Resend Changes for V3: Resend
drivers/misc/mxc_ocotp.c | 74 +++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 73 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/mxc_ocotp.c b/drivers/misc/mxc_ocotp.c index d92044e..7f0e9e4 100644 --- a/drivers/misc/mxc_ocotp.c +++ b/drivers/misc/mxc_ocotp.c @@ -25,8 +25,21 @@ #define BM_CTRL_ERROR 0x00000200 #define BM_CTRL_BUSY 0x00000100 #define BO_CTRL_ADDR 0 +#ifdef CONFIG_MX7 +#define BM_CTRL_ADDR 0x0000000f +#define BM_CTRL_RELOAD 0x00000400 +#else #define BM_CTRL_ADDR 0x0000007f - +#endif + +#ifdef CONFIG_MX7 +#define BO_TIMING_FSOURCE 12 +#define BM_TIMING_FSOURCE 0x0007f000 +#define BV_TIMING_FSOURCE_NS 1001 +#define BO_TIMING_PROG 0 +#define BM_TIMING_PROG 0x00000fff +#define BV_TIMING_PROG_US 10 +#else #define BO_TIMING_STROBE_READ 16 #define BM_TIMING_STROBE_READ 0x003f0000 #define BV_TIMING_STROBE_READ_NS 37 @@ -36,6 +49,7 @@ #define BO_TIMING_STROBE_PROG 0 #define BM_TIMING_STROBE_PROG 0x00000fff #define BV_TIMING_STROBE_PROG_US 10 +#endif
#define BM_READ_CTRL_READ_FUSE 0x00000001
@@ -109,6 +123,25 @@ int fuse_read(u32 bank, u32 word, u32 *val) return finish_access(regs, __func__); }
+#ifdef CONFIG_MX7 +static void set_timing(struct ocotp_regs *regs) +{ + u32 ipg_clk; + u32 fsource, prog; + u32 timing; + + ipg_clk = mxc_get_clock(MXC_IPG_CLK); + + fsource = DIV_ROUND_UP((ipg_clk / 1000) * BV_TIMING_FSOURCE_NS, + + 1000000) + 1; + prog = DIV_ROUND_CLOSEST(ipg_clk * BV_TIMING_PROG_US, 1000000) + 1; + + timing = BF(fsource, TIMING_FSOURCE) | BF(prog, TIMING_PROG); + + clrsetbits_le32(®s->timing, BM_TIMING_FSOURCE | BM_TIMING_PROG, + timing); +} +#else static void set_timing(struct ocotp_regs *regs) { u32 ipg_clk; @@ -130,12 +163,17 @@ static void set_timing(struct ocotp_regs *regs) clrsetbits_le32(®s->timing, BM_TIMING_STROBE_READ | BM_TIMING_RELAX | BM_TIMING_STROBE_PROG, timing); } +#endif
static void setup_direct_access(struct ocotp_regs *regs, u32 bank, u32 word, int write) { u32 wr_unlock = write ? BV_CTRL_WR_UNLOCK_KEY : 0; +#ifdef CONFIG_MX7 + u32 addr = bank; +#else u32 addr = bank << 3 | word; +#endif
set_timing(regs); clrsetbits_le32(®s->ctrl, BM_CTRL_WR_UNLOCK | BM_CTRL_ADDR, @@ -155,7 +193,11 @@ int fuse_sense(u32 bank, u32 word, u32 *val) setup_direct_access(regs, bank, word, false); writel(BM_READ_CTRL_READ_FUSE, ®s->read_ctrl); wait_busy(regs, 1); +#ifdef CONFIG_MX7 + *val = readl((®s->read_fuse_data0) + (word << 2)); +#else *val = readl(®s->read_fuse_data); +#endif
return finish_access(regs, __func__); } @@ -176,8 +218,38 @@ int fuse_prog(u32 bank, u32 word, u32 val) return ret;
setup_direct_access(regs, bank, word, true); +#ifdef CONFIG_MX7 + switch (word) { + case 0: + writel(0, ®s->data1); + writel(0, ®s->data2); + writel(0, ®s->data3); + writel(val, ®s->data0); + break; + case 1: + writel(val, ®s->data1); + writel(0, ®s->data2); + writel(0, ®s->data3); + writel(0, ®s->data0); + break; + case 2: + writel(0, ®s->data1); + writel(val, ®s->data2); + writel(0, ®s->data3); + writel(0, ®s->data0); + break; + case 3: + writel(0, ®s->data1); + writel(0, ®s->data2); + writel(val, ®s->data3); + writel(0, ®s->data0); + break; + } + wait_busy(regs, BV_TIMING_PROG_US); +#else writel(val, ®s->data); wait_busy(regs, BV_TIMING_STROBE_PROG_US); +#endif udelay(WRITE_POSTAMBLE_US);
* Add thermal driver support for imx7 SoC read_cpu_temperature is SoC dependent * Redefine config macro to support imx7 and imx6 SoC
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- Changes for V2: - Rework patch so it can be applyed on top of patch imx6: standardise OCOTP and fuse config to mx6_common Changes for V3: Resend
arch/arm/imx-common/cpu.c | 10 ++-- drivers/thermal/Makefile | 2 +- drivers/thermal/imx_thermal.c | 100 +++++++++++++++++++++++++++++++++++--- include/configs/embestmx6boards.h | 2 +- include/configs/gw_ventana.h | 2 +- include/configs/mx6cuboxi.h | 2 +- include/configs/mx6sabre_common.h | 2 +- include/configs/mx6slevk.h | 2 +- include/configs/mx6sxsabresd.h | 2 +- include/configs/tbs2910.h | 2 +- 10 files changed, 108 insertions(+), 18 deletions(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 5e56cfe..2e803f3 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -148,14 +148,16 @@ int print_cpuinfo(void) u32 cpurev; __maybe_unused u32 max_freq;
-#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) +#if defined(CONFIG_IMX_THERMAL) struct udevice *thermal_dev; - int cpu_tmp, minc, maxc, ret; + int cpu_tmp, ret; #endif
cpurev = get_cpu_rev();
#if defined(CONFIG_MX6) + int minc, maxc; + printf("CPU: Freescale i.MX%s rev%d.%d", get_imx_type((cpurev & 0xFF000) >> 12), (cpurev & 0x000F0) >> 4, @@ -175,7 +177,7 @@ int print_cpuinfo(void) mxc_get_clock(MXC_ARM_CLK) / 1000000); #endif
-#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) +#if defined(CONFIG_MX6) && defined(CONFIG_IMX_THERMAL) puts("CPU: "); switch (get_cpu_temp_grade(&minc, &maxc)) { case TEMP_AUTOMOTIVE: @@ -192,6 +194,8 @@ int print_cpuinfo(void) break; } printf("(%dC to %dC)", minc, maxc); +#endif +#if defined(CONFIG_IMX_THERMAL) ret = uclass_get_device(UCLASS_THERMAL, 0, &thermal_dev); if (!ret) { ret = thermal_get_temp(thermal_dev, &cpu_tmp); diff --git a/drivers/thermal/Makefile b/drivers/thermal/Makefile index 6d4cacd..d768f5e 100644 --- a/drivers/thermal/Makefile +++ b/drivers/thermal/Makefile @@ -6,4 +6,4 @@ #
obj-$(CONFIG_DM_THERMAL) += thermal-uclass.o -obj-$(CONFIG_IMX6_THERMAL) += imx_thermal.o +obj-$(CONFIG_IMX_THERMAL) += imx_thermal.o diff --git a/drivers/thermal/imx_thermal.c b/drivers/thermal/imx_thermal.c index 0d893c9..046c094 100644 --- a/drivers/thermal/imx_thermal.c +++ b/drivers/thermal/imx_thermal.c @@ -19,6 +19,14 @@ #include <thermal.h> #include <imx_thermal.h>
+struct thermal_data { + unsigned int fuse; + int critical; + int minc; + int maxc; +}; + +#if defined(CONFIG_MX6) /* board will busyloop until this many degrees C below CPU max temperature */ #define TEMPERATURE_HOT_DELTA 5 /* CPU maxT - 5C */ #define FACTOR0 10000000 @@ -34,13 +42,6 @@ #define MISC0_REFTOP_SELBIASOFF (1 << 3) #define TEMPSENSE1_MEASURE_FREQ 0xffff
-struct thermal_data { - unsigned int fuse; - int critical; - int minc; - int maxc; -}; - static int read_cpu_temperature(struct udevice *dev) { int temperature; @@ -124,6 +125,79 @@ static int read_cpu_temperature(struct udevice *dev) return temperature; }
+#elif defined(CONFIG_MX7) +#define TEMPERATURE_MIN -40 +#define TEMPERATURE_HOT 85 +#define TEMPERATURE_MAX 125 +#define MEASURE_FREQ 327 + +static int read_cpu_temperature(struct udevice *dev) +{ + unsigned int reg, tmp, start; + unsigned int raw_25c, te1; + int temperature; + unsigned int *priv = dev_get_priv(dev); + u32 fuse = *priv; + struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; + /* + * fuse data layout: + * [31:21] sensor value @ 25C + * [20:18] hot temperature value + * [17:9] sensor value of room + * [8:0] sensor value of hot + */ + + raw_25c = fuse >> 21; + if (raw_25c == 0) + raw_25c = 25; + + te1 = (fuse >> 9) & 0x1ff; + + /* + * now we only use single measure, every time we read + * the temperature, we will power on/down anadig thermal + * module + */ + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK, &ccm_anatop->tempsense1_clr); + writel(PMU_REF_REFTOP_SELFBIASOFF_MASK, &ccm_anatop->ref_set); + + /* write measure freq */ + reg = readl(&ccm_anatop->tempsense1); + reg &= ~TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK; + reg |= TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ(MEASURE_FREQ); + writel(reg, &ccm_anatop->tempsense1); + + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK, &ccm_anatop->tempsense1_clr); + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK, &ccm_anatop->tempsense1_clr); + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK, &ccm_anatop->tempsense1_set); + + start = get_timer(0); + /* Wait max 100ms */ + do { + /* + * Since we can not rely on finish bit, use 1ms delay to get + * temperature. From RM, 17us is enough to get data, but + * to gurantee to get the data, delay 100ms here. + */ + reg = readl(&ccm_anatop->tempsense1); + tmp = (reg & TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK) + >> TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT; + } while (get_timer(0) < (start + 100)); + + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK, &ccm_anatop->tempsense1_clr); + + /* power down anatop thermal sensor */ + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK, &ccm_anatop->tempsense1_set); + writel(PMU_REF_REFTOP_SELFBIASOFF_MASK, &ccm_anatop->ref_clr); + + /* Single point */ + temperature = tmp - (te1 - raw_25c); + + return temperature; +} +#endif + int imx_thermal_get_temp(struct udevice *dev, int *temp) { struct thermal_data *priv = dev_get_priv(dev); @@ -161,15 +235,27 @@ static int imx_thermal_probe(struct udevice *dev) /* Read Temperature calibration data fuse */ fuse_read(pdata->fuse_bank, pdata->fuse_word, &fuse);
+#if defined(CONFIG_MX6) /* Check for valid fuse */ if (fuse == 0 || fuse == ~0) { printf("CPU: Thermal invalid data, fuse: 0x%x\n", fuse); return -EPERM; } +#elif defined(CONFIG_MX7) + /* No Calibration data in FUSE? */ + if ((fuse & 0x3ffff) == 0) { + printf("CPU: Thermal invalid data, fuse: 0x%x\n", fuse); + return -EPERM; + } +#else +#error "Not support thermal driver" +#endif
+#if defined(CONFIG_MX6) /* set critical cooling temp */ get_cpu_temp_grade(&priv->minc, &priv->maxc); priv->critical = priv->maxc - TEMPERATURE_HOT_DELTA; +#endif priv->fuse = fuse;
enable_thermal_clk(); diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 12744a6..58cee96 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -19,7 +19,7 @@
#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
-#define CONFIG_IMX6_THERMAL +#define CONFIG_IMX_THERMAL
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index df1ff43..240b109 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -57,7 +57,7 @@ #define CONFIG_CMD_GPIO
/* Thermal */ -#define CONFIG_IMX6_THERMAL +#define CONFIG_IMX_THERMAL
/* Serial */ #define CONFIG_MXC_UART diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 634a09f..6e89dd1 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -14,7 +14,7 @@ #define CONFIG_SPL_MMC_SUPPORT #include "imx6_spl.h"
#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) #define CONFIG_BOARD_EARLY_INIT_F diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index e42dfc9..4f1be15 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -11,7 +11,7 @@
#include "mx6_common.h"
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 3cecd94..58e59d8 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -190,6 +190,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC2*/ #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 848bdcd..381eaa2 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -176,7 +176,7 @@ #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif
#define CONFIG_CMD_TIME
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 5bc1209..7c61cb9 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -21,7 +21,7 @@ #define CONFIG_SYS_PROMPT "Matrix U-Boot> " #define CONFIG_SYS_HZ 1000
/* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1
* The system counter driver for imx7d abd mx6ul, move this timer driver to imx-common and rename it as syscounter.c
For mx6ul and mx7, configurations are used for choose the GPT timer or system counter timer (default).
GPT timer: CONFIG_GPT_TIMER System counter timer: CONFIG_SYSCOUNTER_TIMER
For mx6dqp GPT timer is the default setting.
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Resend Changes for V3: Resend
arch/arm/imx-common/syscounter.c | 126 +++++++++++++++++++++++++++ arch/arm/include/asm/imx-common/syscounter.h | 29 ++++++ include/configs/mx6_common.h | 1 + 3 files changed, 156 insertions(+) create mode 100644 arch/arm/imx-common/syscounter.c create mode 100644 arch/arm/include/asm/imx-common/syscounter.h
diff --git a/arch/arm/imx-common/syscounter.c b/arch/arm/imx-common/syscounter.c new file mode 100644 index 0000000..f5e5cdc --- /dev/null +++ b/arch/arm/imx-common/syscounter.c @@ -0,0 +1,126 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * The file use ls102xa/timer.c as a reference. + */ + +#include <common.h> +#include <asm/io.h> +#include <div64.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/syscounter.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * This function is intended for SHORT delays only. + * It will overflow at around 10 seconds @ 400MHz, + * or 20 seconds @ 200MHz. + */ +unsigned long usec2ticks(unsigned long usec) +{ + ulong ticks; + + if (usec < 1000) + ticks = ((usec * (get_tbclk()/1000)) + 500) / 1000; + else + ticks = ((usec / 10) * (get_tbclk() / 100000)); + + return ticks; +} + +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + tick *= CONFIG_SYS_HZ; + do_div(tick, freq); + + return tick; +} + +static inline unsigned long long us_to_tick(unsigned long long usec) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + usec = usec * freq + 999999; + do_div(usec, 1000000); + + return usec; +} + +int timer_init(void) +{ + struct sctr_regs *sctr = (struct sctr_regs *)SCTR_BASE_ADDR; + unsigned long val, freq; + + freq = CONFIG_SC_TIMER_CLK; + asm("mcr p15, 0, %0, c14, c0, 0" : : "r" (freq)); + + writel(freq, &sctr->cntfid0); + + /* Enable system counter */ + val = readl(&sctr->cntcr); + val &= ~(SC_CNTCR_FREQ0 | SC_CNTCR_FREQ1); + val |= SC_CNTCR_FREQ0 | SC_CNTCR_ENABLE | SC_CNTCR_HDBG; + writel(val, &sctr->cntcr); + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + + return 0; +} + +unsigned long long get_ticks(void) +{ + unsigned long long now; + + asm("mrrc p15, 0, %Q0, %R0, c14" : "=r" (now)); + + gd->arch.tbl = (unsigned long)(now & 0xffffffff); + gd->arch.tbu = (unsigned long)(now >> 32); + + return now; +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = us_to_tick(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + return freq; +} diff --git a/arch/arm/include/asm/imx-common/syscounter.h b/arch/arm/include/asm/imx-common/syscounter.h new file mode 100644 index 0000000..ddb412e --- /dev/null +++ b/arch/arm/include/asm/imx-common/syscounter.h @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_SYSTEM_COUNTER_H +#define _ASM_ARCH_SYSTEM_COUNTER_H + +/* System Counter */ +struct sctr_regs { + u32 cntcr; + u32 cntsr; + u32 cntcv1; + u32 cntcv2; + u32 resv1[4]; + u32 cntfid0; + u32 cntfid1; + u32 cntfid2; + u32 resv2[1001]; + u32 counterid[1]; +}; + +#define SC_CNTCR_ENABLE (1 << 0) +#define SC_CNTCR_HDBG (1 << 1) +#define SC_CNTCR_FREQ0 (1 << 8) +#define SC_CNTCR_FREQ1 (1 << 9) + +#endif diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 54ab890..ed9f8fe 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -30,6 +30,7 @@
#define CONFIG_MP #define CONFIG_MXC_GPT_HCLK +#define CONFIG_GPT_TIMER
#define CONFIG_SYS_NO_FLASH
* Add system arch level header files - imx-regs.h: iMX7D SoC system architecture registers - crm_regs.h: Clock control module registers - sys_proto.h: helper callback function for SoC setup
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Split patch to easier review process - Add system arch register definitions Changes for V3: Resend
arch/arm/include/asm/arch-mx7/crm_regs.h | 2813 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx7/imx-regs.h | 1303 +++++++++++++ arch/arm/include/asm/arch-mx7/sys_proto.h | 42 + 3 files changed, 4158 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx7/crm_regs.h create mode 100644 arch/arm/include/asm/arch-mx7/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mx7/sys_proto.h
diff --git a/arch/arm/include/asm/arch-mx7/crm_regs.h b/arch/arm/include/asm/arch-mx7/crm_regs.h new file mode 100644 index 0000000..8a68a39 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/crm_regs.h @@ -0,0 +1,2813 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_ARM_MACH_MX7_CCM_REGS_H__ +#define __ARCH_ARM_MACH_MX7_CCM_REGS_H__ + +#include <asm/arch/imx-regs.h> +#include <asm/io.h> + +#define CCM_GPR0_OFFSET 0x0 +#define CCM_OBSERVE0_OFFSET 0x0400 +#define CCM_SCTRL0_OFFSET 0x0800 +#define CCM_CCGR0_OFFSET 0x4000 +#define CCM_ROOT0_TARGET_OFFSET 0x8000 + +#ifndef __ASSEMBLY__ + +struct mxc_ccm_ccgr { + uint32_t ccgr; + uint32_t ccgr_set; + uint32_t ccgr_clr; + uint32_t ccgr_tog; +}; + +struct mxc_ccm_root_slice { + uint32_t target_root; + uint32_t target_root_set; + uint32_t target_root_clr; + uint32_t target_root_tog; + uint32_t reserved_0[4]; + uint32_t post; + uint32_t post_root_set; + uint32_t post_root_clr; + uint32_t post_root_tog; + uint32_t pre; + uint32_t pre_root_set; + uint32_t pre_root_clr; + uint32_t pre_root_tog; + uint32_t reserved_1[12]; + uint32_t access_ctrl; + uint32_t access_ctrl_root_set; + uint32_t access_ctrl_root_clr; + uint32_t access_ctrl_root_tog; +}; + +/** CCM - Peripheral register structure */ +struct mxc_ccm_reg { + uint32_t gpr0; + uint32_t gpr0_set; + uint32_t gpr0_clr; + uint32_t gpr0_tog; + uint32_t reserved_0[4092]; + struct mxc_ccm_ccgr ccgr_array[191]; /* offset 0x4000 */ + uint32_t reserved_1[3332]; + struct mxc_ccm_root_slice root[121]; /* offset 0x8000 */ + +}; + +struct mxc_ccm_anatop_reg { + uint32_t ctrl_24m; /* offset 0x0000 */ + uint32_t ctrl_24m_set; + uint32_t ctrl_24m_clr; + uint32_t ctrl_24m_tog; + uint32_t rcosc_config0; /* offset 0x0010 */ + uint32_t rcosc_config0_set; + uint32_t rcosc_config0_clr; + uint32_t rcosc_config0_tog; + uint32_t rcosc_config1; /* offset 0x0020 */ + uint32_t rcosc_config1_set; + uint32_t rcosc_config1_clr; + uint32_t rcosc_config1_tog; + uint32_t rcosc_config2; /* offset 0x0030 */ + uint32_t rcosc_config2_set; + uint32_t rcosc_config2_clr; + uint32_t rcosc_config2_tog; + uint8_t reserved_0[16]; + uint32_t osc_32k; /* offset 0x0050 */ + uint32_t osc_32k_set; + uint32_t osc_32k_clr; + uint32_t osc_32k_tog; + uint32_t pll_arm; /* offset 0x0060 */ + uint32_t pll_arm_set; + uint32_t pll_arm_clr; + uint32_t pll_arm_tog; + uint32_t pll_ddr; /* offset 0x0070 */ + uint32_t pll_ddr_set; + uint32_t pll_ddr_clr; + uint32_t pll_ddr_tog; + uint32_t pll_ddr_ss; /* offset 0x0080 */ + uint8_t reserved_1[12]; + uint32_t pll_ddr_num; /* offset 0x0090 */ + uint8_t reserved_2[12]; + uint32_t pll_ddr_denom; /* offset 0x00a0 */ + uint8_t reserved_3[12]; + uint32_t pll_480; /* offset 0x00b0 */ + uint32_t pll_480_set; + uint32_t pll_480_clr; + uint32_t pll_480_tog; + uint32_t pfd_480a; /* offset 0x00c0 */ + uint32_t pfd_480a_set; + uint32_t pfd_480a_clr; + uint32_t pfd_480a_tog; + uint32_t pfd_480b; /* offset 0x00d0 */ + uint32_t pfd_480b_set; + uint32_t pfd_480b_clr; + uint32_t pfd_480b_tog; + uint32_t pll_enet; /* offset 0x00e0 */ + uint32_t pll_enet_set; + uint32_t pll_enet_clr; + uint32_t pll_enet_tog; + uint32_t pll_audio; /* offset 0x00f0 */ + uint32_t pll_audio_set; + uint32_t pll_audio_clr; + uint32_t pll_audio_tog; + uint32_t pll_audio_ss; /* offset 0x0100 */ + uint8_t reserved_4[12]; + uint32_t pll_audio_num; /* offset 0x0110 */ + uint8_t reserved_5[12]; + uint32_t pll_audio_denom; /* offset 0x0120 */ + uint8_t reserved_6[12]; + uint32_t pll_video; /* offset 0x0130 */ + uint32_t pll_video_set; + uint32_t pll_video_clr; + uint32_t pll_video_tog; + uint32_t pll_video_ss; /* offset 0x0140 */ + uint8_t reserved_7[12]; + uint32_t pll_video_num; /* offset 0x0150 */ + uint8_t reserved_8[12]; + uint32_t pll_video_denom; /* offset 0x0160 */ + uint8_t reserved_9[12]; + uint32_t clk_misc0; /* offset 0x0170 */ + uint32_t clk_misc0_set; + uint32_t clk_misc0_clr; + uint32_t clk_misc0_tog; + uint32_t clk_rsvd; /* offset 0x0180 */ + uint8_t reserved_10[124]; + uint32_t reg_1p0a; /* offset 0x0200 */ + uint32_t reg_1p0a_set; + uint32_t reg_1p0a_clr; + uint32_t reg_1p0a_tog; + uint32_t reg_1p0d; /* offsest 0x0210 */ + uint32_t reg_1p0d_set; + uint32_t reg_1p0d_clr; + uint32_t reg_1p0d_tog; + uint32_t reg_hsic_1p2; /* offset 0x0220 */ + uint32_t reg_hsic_1p2_set; + uint32_t reg_hsic_1p2_clr; + uint32_t reg_hsic_1p2_tog; + uint32_t reg_lpsr_1p0; /* offset 0x0230 */ + uint32_t reg_lpsr_1p0_set; + uint32_t reg_lpsr_1p0_clr; + uint32_t reg_lpsr_1p0_tog; + uint32_t reg_3p0; /* offset 0x0240 */ + uint32_t reg_3p0_set; + uint32_t reg_3p0_clr; + uint32_t reg_3p0_tog; + uint32_t reg_snvs; /* offset 0x0250 */ + uint32_t reg_snvs_set; + uint32_t reg_snvs_clr; + uint32_t reg_snvs_tog; + uint32_t analog_debug_misc0; /* offset 0x0260 */ + uint32_t analog_debug_misc0_set; + uint32_t analog_debug_misc0_clr; + uint32_t analog_debug_misc0_tog; + uint32_t ref; /* offset 0x0270 */ + uint32_t ref_set; + uint32_t ref_clr; + uint32_t ref_tog; + uint8_t reserved_11[128]; + uint32_t tempsense0; /* offset 0x0300 */ + uint32_t tempsense0_set; + uint32_t tempsense0_clr; + uint32_t tempsense0_tog; + uint32_t tempsense1; /* offset 0x0310 */ + uint32_t tempsense1_set; + uint32_t tempsense1_clr; + uint32_t tempsense1_tog; + uint32_t tempsense_trim; /* offset 0x0320 */ + uint32_t tempsense_trim_set; + uint32_t tempsense_trim_clr; + uint32_t tempsense_trim_tog; + uint32_t lowpwr_ctrl; /* offset 0x0330 */ + uint32_t lowpwr_ctrl_set; + uint32_t lowpwr_ctrl_clr; + uint32_t lowpwr_ctrl_tog; + uint32_t snvs_tamper_offset_ctrl; /* offset 0x0340 */ + uint32_t snvs_tamper_offset_ctrl_set; + uint32_t snvs_tamper_offset_ctrl_clr; + uint32_t snvs_tamper_offset_ctrl_tog; + uint32_t snvs_tamper_pull_ctrl; /* offset 0x0350 */ + uint32_t snvs_tamper_pull_ctrl_set; + uint32_t snvs_tamper_pull_ctrl_clr; + uint32_t snvs_tamper_pull_ctrl_tog; + uint32_t snvs_test; /* offset 0x0360 */ + uint32_t snvs_test_set; + uint32_t snvs_test_clr; + uint32_t snvs_test_tog; + uint32_t snvs_tamper_trim_ctrl; /* offset 0x0370 */ + uint32_t snvs_tamper_trim_ctrl_set; + uint32_t snvs_tamper_trim_ctrl_ctrl; + uint32_t snvs_tamper_trim_ctrl_tog; + uint32_t snvs_misc_ctrl; /* offset 0x0380 */ + uint32_t snvs_misc_ctrl_set; + uint32_t snvs_misc_ctrl_clr; + uint32_t snvs_misc_ctrl_tog; + uint8_t reserved_12[112]; + uint32_t misc; /* offset 0x0400 */ + uint8_t reserved_13[252]; + uint32_t adc0; /* offset 0x0500 */ + uint8_t reserved_14[12]; + uint32_t adc1; /* offset 0x0510 */ + uint8_t reserved_15[748]; + uint32_t digprog; /* offset 0x0800 */ +}; +#endif + +#define ANADIG_CLK_MISC0_PFD_480_AUTOGATE_EN_MASK (0x01 << 17) + +#define ANADIG_PLL_LOCK 0x80000000 + +#define ANADIG_PLL_ARM_PWDN_MASK (0x01 << 12) +#define ANADIG_PLL_480_PWDN_MASK (0x01 << 12) +#define ANADIG_PLL_DDR_PWDN_MASK (0x01 << 20) +#define ANADIG_PLL_ENET_PWDN_MASK (0x01 << 5) +#define ANADIG_PLL_VIDEO_PWDN_MASK (0x01 << 12) + + +#define ANATOP_PFD480B_PFD4_FRAC_MASK 0x0000003f +#define ANATOP_PFD480B_PFD4_FRAC_320M_VAL 0x0000001B +#define ANATOP_PFD480B_PFD4_FRAC_392M_VAL 0x00000016 +#define ANATOP_PFD480B_PFD4_FRAC_432M_VAL 0x00000014 + +/* PLL_ARM Bit Fields */ +#define CCM_ANALOG_PLL_ARM_DIV_SELECT_MASK 0x7F +#define CCM_ANALOG_PLL_ARM_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_ARM_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_ARM_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_ARM_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_ARM_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_ARM_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_ARM_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_ARM_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_ARM_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_ARM_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_ARM_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_ARM_POWERDOWN_MASK 0x1000 +#define CCM_ANALOG_PLL_ARM_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_ARM_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_ARM_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_ARM_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_ARM_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_ARM_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_ARM_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_ARM_LVDS_SEL_MASK 0x20000 +#define CCM_ANALOG_PLL_ARM_LVDS_SEL_SHIFT 17 +#define CCM_ANALOG_PLL_ARM_LVDS_24MHZ_SEL_MASK 0x40000 +#define CCM_ANALOG_PLL_ARM_LVDS_24MHZ_SEL_SHIFT 18 +#define CCM_ANALOG_PLL_ARM_PLL_SEL_MASK 0x80000 +#define CCM_ANALOG_PLL_ARM_PLL_SEL_SHIFT 19 +#define CCM_ANALOG_PLL_ARM_PLL_ARM_OVERRIDE_MASK 0x100000 +#define CCM_ANALOG_PLL_ARM_PLL_ARM_OVERRIDE_SHIFT 20 +#define CCM_ANALOG_PLL_ARM_RSVD0_MASK 0x7FE00000 +#define CCM_ANALOG_PLL_ARM_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_ARM_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_ARM_LOCK_SHIFT 31 + +/* PLL_DDR Bit Fields */ +#define CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK 0x7F +#define CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_DDR_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_DDR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_DDR_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_DDR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_DDR_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_DDR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_DDR_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_DDR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_DDR_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_DDR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_MASK 0x1000 +#define CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_SHIFT 12 +#define CCM_ANALOG_PLL_DDR_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_DDR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_DDR_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_DDR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_DDR_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_DDR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_DDR_DITHER_ENABLE_MASK 0x20000 +#define CCM_ANALOG_PLL_DDR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_DDR_PFD_OFFSET_EN_MASK 0x40000 +#define CCM_ANALOG_PLL_DDR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_DDR_PLL_DDR_OVERRIDE_MASK 0x80000 +#define CCM_ANALOG_PLL_DDR_PLL_DDR_OVERRIDE_SHIFT 19 +#define CCM_ANALOG_PLL_DDR_POWERDOWN_MASK 0x100000 +#define CCM_ANALOG_PLL_DDR_POWERDOWN_SHIFT 20 +#define CCM_ANALOG_PLL_DDR_TEST_DIV_SELECT_MASK 0x600000 +#define CCM_ANALOG_PLL_DDR_TEST_DIV_SELECT_SHIFT 21 +#define CCM_ANALOG_PLL_DDR_RSVD1_MASK 0x7F800000 +#define CCM_ANALOG_PLL_DDR_RSVD1_SHIFT 23 +#define CCM_ANALOG_PLL_DDR_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_DDR_LOCK_SHIFT 31 + +/* PLL_480 Bit Fields */ +#define CCM_ANALOG_PLL_480_DIV_SELECT_MASK 0x1 +#define CCM_ANALOG_PLL_480_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_480_RSVD0_MASK 0xE +#define CCM_ANALOG_PLL_480_RSVD0_SHIFT 1 +#define CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_MASK 0x10 +#define CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_SHIFT 4 +#define CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_MASK 0x20 +#define CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_SHIFT 5 +#define CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_MASK 0x40 +#define CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_SHIFT 6 +#define CCM_ANALOG_PLL_480_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_480_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_480_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_480_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_480_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_480_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_480_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_480_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_480_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_480_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_480_POWERDOWN_MASK 0x1000 +#define CCM_ANALOG_PLL_480_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_480_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_480_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_480_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_480_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_480_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_480_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_480_PLL_480_OVERRIDE_MASK 0x20000 +#define CCM_ANALOG_PLL_480_PLL_480_OVERRIDE_SHIFT 17 +#define CCM_ANALOG_PLL_480_PFD0_OVERRIDE_MASK 0x40000 +#define CCM_ANALOG_PLL_480_PFD0_OVERRIDE_SHIFT 18 +#define CCM_ANALOG_PLL_480_PFD1_OVERRIDE_MASK 0x80000 +#define CCM_ANALOG_PLL_480_PFD1_OVERRIDE_SHIFT 19 +#define CCM_ANALOG_PLL_480_PFD2_OVERRIDE_MASK 0x100000 +#define CCM_ANALOG_PLL_480_PFD2_OVERRIDE_SHIFT 20 +#define CCM_ANALOG_PLL_480_PFD3_OVERRIDE_MASK 0x200000 +#define CCM_ANALOG_PLL_480_PFD3_OVERRIDE_SHIFT 21 +#define CCM_ANALOG_PLL_480_PFD4_OVERRIDE_MASK 0x400000 +#define CCM_ANALOG_PLL_480_PFD4_OVERRIDE_SHIFT 22 +#define CCM_ANALOG_PLL_480_PFD5_OVERRIDE_MASK 0x800000 +#define CCM_ANALOG_PLL_480_PFD5_OVERRIDE_SHIFT 23 +#define CCM_ANALOG_PLL_480_PFD6_OVERRIDE_MASK 0x1000000 +#define CCM_ANALOG_PLL_480_PFD6_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_480_PFD7_OVERRIDE_MASK 0x2000000 +#define CCM_ANALOG_PLL_480_PFD7_OVERRIDE_SHIFT 25 +#define CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_MASK 0x4000000 +#define CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_SHIFT 26 +#define CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_MASK 0x8000000 +#define CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_SHIFT 27 +#define CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_MASK 0x10000000 +#define CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_SHIFT 28 +#define CCM_ANALOG_PLL_480_RSVD1_MASK 0x60000000 +#define CCM_ANALOG_PLL_480_RSVD1_SHIFT 29 +#define CCM_ANALOG_PLL_480_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_480_LOCK_SHIFT 31 + +/* PFD_480A Bit Fields */ +#define CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK 0x3F +#define CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT 0 +#define CCM_ANALOG_PFD_480A_PFD0_STABLE_MASK 0x40 +#define CCM_ANALOG_PFD_480A_PFD0_STABLE_SHIFT 6 +#define CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_MASK 0x80 +#define CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_SHIFT 7 +#define CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK 0x3F00 +#define CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT 8 +#define CCM_ANALOG_PFD_480A_PFD1_STABLE_MASK 0x4000 +#define CCM_ANALOG_PFD_480A_PFD1_STABLE_SHIFT 14 +#define CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_MASK 0x8000 +#define CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_SHIFT 15 +#define CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK 0x3F0000 +#define CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT 16 +#define CCM_ANALOG_PFD_480A_PFD2_STABLE_MASK 0x400000 +#define CCM_ANALOG_PFD_480A_PFD2_STABLE_SHIFT 22 +#define CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_MASK 0x800000 +#define CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_SHIFT 23 +#define CCM_ANALOG_PFD_480A_PFD3_FRAC_MASK 0x3F000000 +#define CCM_ANALOG_PFD_480A_PFD3_FRAC_SHIFT 24 +#define CCM_ANALOG_PFD_480A_PFD3_STABLE_MASK 0x40000000 +#define CCM_ANALOG_PFD_480A_PFD3_STABLE_SHIFT 30 +#define CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_MASK 0x80000000 +#define CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_SHIFT 31 +/* PFD_480B Bit Fields */ +#define CCM_ANALOG_PFD_480B_PFD4_FRAC_MASK 0x3F +#define CCM_ANALOG_PFD_480B_PFD4_FRAC_SHIFT 0 +#define CCM_ANALOG_PFD_480B_PFD4_STABLE_MASK 0x40 +#define CCM_ANALOG_PFD_480B_PFD4_STABLE_SHIFT 6 +#define CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK 0x80 +#define CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_SHIFT 7 +#define CCM_ANALOG_PFD_480B_PFD5_FRAC_MASK 0x3F00 +#define CCM_ANALOG_PFD_480B_PFD5_FRAC_SHIFT 8 +#define CCM_ANALOG_PFD_480B_PFD5_STABLE_MASK 0x4000 +#define CCM_ANALOG_PFD_480B_PFD5_STABLE_SHIFT 14 +#define CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_MASK 0x8000 +#define CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_SHIFT 15 +#define CCM_ANALOG_PFD_480B_PFD6_FRAC_MASK 0x3F0000 +#define CCM_ANALOG_PFD_480B_PFD6_FRAC_SHIFT 16 +#define CCM_ANALOG_PFD_480B_PFD6_STABLE_MASK 0x400000 +#define CCM_ANALOG_PFD_480B_PFD6_STABLE_SHIFT 22 +#define CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_MASK 0x800000 +#define CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_SHIFT 23 +#define CCM_ANALOG_PFD_480B_PFD7_FRAC_MASK 0x3F000000 +#define CCM_ANALOG_PFD_480B_PFD7_FRAC_SHIFT 24 +#define CCM_ANALOG_PFD_480B_PFD7_STABLE_MASK 0x40000000 +#define CCM_ANALOG_PFD_480B_PFD7_STABLE_SHIFT 30 +#define CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_MASK 0x80000000 +#define CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_SHIFT 31 + +/* PLL_ENET Bit Fields */ +#define CCM_ANALOG_PLL_ENET_HALF_LF_MASK 0x1 +#define CCM_ANALOG_PLL_ENET_HALF_LF_SHIFT 0 +#define CCM_ANALOG_PLL_ENET_DOUBLE_LF_MASK 0x2 +#define CCM_ANALOG_PLL_ENET_DOUBLE_LF_SHIFT 1 +#define CCM_ANALOG_PLL_ENET_HALF_CP_MASK 0x4 +#define CCM_ANALOG_PLL_ENET_HALF_CP_SHIFT 2 +#define CCM_ANALOG_PLL_ENET_DOUBLE_CP_MASK 0x8 +#define CCM_ANALOG_PLL_ENET_DOUBLE_CP_SHIFT 3 +#define CCM_ANALOG_PLL_ENET_HOLD_RING_OFF_MASK 0x10 +#define CCM_ANALOG_PLL_ENET_HOLD_RING_OFF_SHIFT 4 +#define CCM_ANALOG_PLL_ENET_POWERDOWN_MASK 0x20 +#define CCM_ANALOG_PLL_ENET_POWERDOWN_SHIFT 5 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK 0x40 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_SHIFT 6 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK 0x80 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_SHIFT 7 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK 0x100 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_SHIFT 8 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK 0x200 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_SHIFT 9 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK 0x400 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_SHIFT 10 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK 0x800 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_SHIFT 11 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK 0x1000 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_SHIFT 12 +#define CCM_ANALOG_PLL_ENET_PLL_ENET_OVERRIDE_MASK 0x2000 +#define CCM_ANALOG_PLL_ENET_PLL_ENET_OVERRIDE_SHIFT 13 +#define CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_ENET_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_ENET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_ENET_DITHER_ENABLE_MASK 0x20000 +#define CCM_ANALOG_PLL_ENET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN_MASK 0x40000 +#define CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_ENET_RSVD1_MASK 0x7FF80000 +#define CCM_ANALOG_PLL_ENET_RSVD1_SHIFT 19 +#define CCM_ANALOG_PLL_ENET_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_ENET_LOCK_SHIFT 31 + +/* PLL_AUDIO Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_LOCK_SHIFT 31 +/* PLL_AUDIO_SET Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_SET_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_SET_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_SET_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_SET_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_SET_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_SET_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_SET_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_SET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_SET_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_SET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_SET_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_SET_LOCK_SHIFT 31 +/* PLL_AUDIO_CLR Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_CLR_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_CLR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_CLR_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_CLR_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_CLR_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_CLR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_CLR_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_CLR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_CLR_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_CLR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_LOCK_SHIFT 31 +/* PLL_AUDIO_TOG Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_TOG_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_TOG_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_TOG_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_TOG_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_TOG_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_TOG_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_TOG_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_TOG_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_TOG_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_TOG_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_LOCK_SHIFT 31 +/* PLL_AUDIO_SS Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_SS_STEP_MASK 0x7FFFu +#define CCM_ANALOG_PLL_AUDIO_SS_STEP_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_SS_STEP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SS_STEP_SHIFT))&CCM_ANALOG_PLL_AUDIO_SS_STEP_MASK) +#define CCM_ANALOG_PLL_AUDIO_SS_ENABLE_MASK 0x8000u +#define CCM_ANALOG_PLL_AUDIO_SS_ENABLE_SHIFT 15 +#define CCM_ANALOG_PLL_AUDIO_SS_STOP_MASK 0xFFFF0000u +#define CCM_ANALOG_PLL_AUDIO_SS_STOP_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_SS_STOP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SS_STOP_SHIFT))&CCM_ANALOG_PLL_AUDIO_SS_STOP_MASK) +/* PLL_AUDIO_NUM Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_NUM_A_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_AUDIO_NUM_A_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_NUM_A(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_NUM_A_SHIFT))&CCM_ANALOG_PLL_AUDIO_NUM_A_MASK) +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_SHIFT))&CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_MASK) +/* PLL_AUDIO_DENOM Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_DENOM_B_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_AUDIO_DENOM_B_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_DENOM_B(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DENOM_B_SHIFT))&CCM_ANALOG_PLL_AUDIO_DENOM_B_MASK) +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_SHIFT))&CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_MASK) +/* PLL_VIDEO Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_LOCK_SHIFT 31 +/* PLL_VIDEO_SET Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_SET_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_SET_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_SET_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_SET_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_SET_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_SET_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_SET_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_SET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_SET_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_SET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_SET_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_SET_LOCK_SHIFT 31 +/* PLL_VIDEO_CLR Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_CLR_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_CLR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_CLR_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_CLR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_CLR_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_CLR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_LOCK_SHIFT 31 +/* PLL_VIDEO_TOG Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_TOG_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_TOG_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_TOG_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_TOG_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_TOG_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_TOG_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_TOG_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_TOG_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_TOG_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_TOG_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_LOCK_SHIFT 31 +/* PLL_VIDEO_SS Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_SS_STEP_MASK 0x7FFFu +#define CCM_ANALOG_PLL_VIDEO_SS_STEP_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_SS_STEP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SS_STEP_SHIFT))&CCM_ANALOG_PLL_VIDEO_SS_STEP_MASK) +#define CCM_ANALOG_PLL_VIDEO_SS_ENABLE_MASK 0x8000u +#define CCM_ANALOG_PLL_VIDEO_SS_ENABLE_SHIFT 15 +#define CCM_ANALOG_PLL_VIDEO_SS_STOP_MASK 0xFFFF0000u +#define CCM_ANALOG_PLL_VIDEO_SS_STOP_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_SS_STOP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SS_STOP_SHIFT))&CCM_ANALOG_PLL_VIDEO_SS_STOP_MASK) +/* PLL_VIDEO_NUM Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_NUM_A_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_VIDEO_NUM_A_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_NUM_A(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_NUM_A_SHIFT))&CCM_ANALOG_PLL_VIDEO_NUM_A_MASK) +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_SHIFT))&CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_MASK) +/* PLL_VIDEO_DENOM Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_DENOM_B_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_VIDEO_DENOM_B_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_DENOM_B(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DENOM_B_SHIFT))&CCM_ANALOG_PLL_VIDEO_DENOM_B_MASK) +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_SHIFT))&CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_MASK) +/* CLK_MISC0 Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_RSVD0_MASK) +/* CLK_MISC0_SET Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_SET_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_SET_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_SET_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_SET_RSVD0_MASK) +/* CLK_MISC0_CLR Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_CLR_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_CLR_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_CLR_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_CLR_RSVD0_MASK) +/* CLK_MISC0_TOG Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_TOG_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_TOG_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_TOG_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_TOG_RSVD0_MASK) + +/* REG_1P0A Bit Fields */ +#define PMU_REG_1P0A_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_BO_OFFSET_SHIFT))&PMU_REG_1P0A_BO_OFFSET_MASK) +#define PMU_REG_1P0A_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_RSVD0_SHIFT))&PMU_REG_1P0A_RSVD0_MASK) +#define PMU_REG_1P0A_BO_MASK 0x10000u +#define PMU_REG_1P0A_BO_SHIFT 16 +#define PMU_REG_1P0A_OK_MASK 0x20000u +#define PMU_REG_1P0A_OK_SHIFT 17 +#define PMU_REG_1P0A_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_REG_TEST_SHIFT))&PMU_REG_1P0A_REG_TEST_MASK) +#define PMU_REG_1P0A_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_RSVD1_SHIFT))&PMU_REG_1P0A_RSVD1_MASK) +/* REG_1P0A_SET Bit Fields */ +#define PMU_REG_1P0A_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_BO_OFFSET_SHIFT))&PMU_REG_1P0A_SET_BO_OFFSET_MASK) +#define PMU_REG_1P0A_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_SET_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_SET_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_SET_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_RSVD0_SHIFT))&PMU_REG_1P0A_SET_RSVD0_MASK) +#define PMU_REG_1P0A_SET_BO_MASK 0x10000u +#define PMU_REG_1P0A_SET_BO_SHIFT 16 +#define PMU_REG_1P0A_SET_OK_MASK 0x20000u +#define PMU_REG_1P0A_SET_OK_SHIFT 17 +#define PMU_REG_1P0A_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_SET_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_REG_TEST_SHIFT))&PMU_REG_1P0A_SET_REG_TEST_MASK) +#define PMU_REG_1P0A_SET_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_SET_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_RSVD1_SHIFT))&PMU_REG_1P0A_SET_RSVD1_MASK) +/* REG_1P0A_CLR Bit Fields */ +#define PMU_REG_1P0A_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_BO_OFFSET_SHIFT))&PMU_REG_1P0A_CLR_BO_OFFSET_MASK) +#define PMU_REG_1P0A_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_CLR_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_RSVD0_SHIFT))&PMU_REG_1P0A_CLR_RSVD0_MASK) +#define PMU_REG_1P0A_CLR_BO_MASK 0x10000u +#define PMU_REG_1P0A_CLR_BO_SHIFT 16 +#define PMU_REG_1P0A_CLR_OK_MASK 0x20000u +#define PMU_REG_1P0A_CLR_OK_SHIFT 17 +#define PMU_REG_1P0A_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_REG_TEST_SHIFT))&PMU_REG_1P0A_CLR_REG_TEST_MASK) +#define PMU_REG_1P0A_CLR_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_CLR_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_RSVD1_SHIFT))&PMU_REG_1P0A_CLR_RSVD1_MASK) +/* REG_1P0A_TOG Bit Fields */ +#define PMU_REG_1P0A_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_BO_OFFSET_SHIFT))&PMU_REG_1P0A_TOG_BO_OFFSET_MASK) +#define PMU_REG_1P0A_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_TOG_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_RSVD0_SHIFT))&PMU_REG_1P0A_TOG_RSVD0_MASK) +#define PMU_REG_1P0A_TOG_BO_MASK 0x10000u +#define PMU_REG_1P0A_TOG_BO_SHIFT 16 +#define PMU_REG_1P0A_TOG_OK_MASK 0x20000u +#define PMU_REG_1P0A_TOG_OK_SHIFT 17 +#define PMU_REG_1P0A_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_REG_TEST_SHIFT))&PMU_REG_1P0A_TOG_REG_TEST_MASK) +#define PMU_REG_1P0A_TOG_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_TOG_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_RSVD1_SHIFT))&PMU_REG_1P0A_TOG_RSVD1_MASK) +/* REG_1P0D Bit Fields */ +#define PMU_REG_1P0D_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_BO_OFFSET_SHIFT))&PMU_REG_1P0D_BO_OFFSET_MASK) +#define PMU_REG_1P0D_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_RSVD0_SHIFT))&PMU_REG_1P0D_RSVD0_MASK) +#define PMU_REG_1P0D_BO_MASK 0x10000u +#define PMU_REG_1P0D_BO_SHIFT 16 +#define PMU_REG_1P0D_OK_MASK 0x20000u +#define PMU_REG_1P0D_OK_SHIFT 17 +#define PMU_REG_1P0D_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_REG_TEST_SHIFT))&PMU_REG_1P0D_REG_TEST_MASK) +#define PMU_REG_1P0D_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_RSVD1_SHIFT))&PMU_REG_1P0D_RSVD1_MASK) +#define PMU_REG_1P0D_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_OVERRIDE_SHIFT 31 +/* REG_1P0D_SET Bit Fields */ +#define PMU_REG_1P0D_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_BO_OFFSET_SHIFT))&PMU_REG_1P0D_SET_BO_OFFSET_MASK) +#define PMU_REG_1P0D_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_SET_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_SET_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_SET_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_RSVD0_SHIFT))&PMU_REG_1P0D_SET_RSVD0_MASK) +#define PMU_REG_1P0D_SET_BO_MASK 0x10000u +#define PMU_REG_1P0D_SET_BO_SHIFT 16 +#define PMU_REG_1P0D_SET_OK_MASK 0x20000u +#define PMU_REG_1P0D_SET_OK_SHIFT 17 +#define PMU_REG_1P0D_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_SET_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_REG_TEST_SHIFT))&PMU_REG_1P0D_SET_REG_TEST_MASK) +#define PMU_REG_1P0D_SET_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_SET_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_RSVD1_SHIFT))&PMU_REG_1P0D_SET_RSVD1_MASK) +#define PMU_REG_1P0D_SET_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_SET_OVERRIDE_SHIFT 31 +/* REG_1P0D_CLR Bit Fields */ +#define PMU_REG_1P0D_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_BO_OFFSET_SHIFT))&PMU_REG_1P0D_CLR_BO_OFFSET_MASK) +#define PMU_REG_1P0D_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_CLR_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_RSVD0_SHIFT))&PMU_REG_1P0D_CLR_RSVD0_MASK) +#define PMU_REG_1P0D_CLR_BO_MASK 0x10000u +#define PMU_REG_1P0D_CLR_BO_SHIFT 16 +#define PMU_REG_1P0D_CLR_OK_MASK 0x20000u +#define PMU_REG_1P0D_CLR_OK_SHIFT 17 +#define PMU_REG_1P0D_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_REG_TEST_SHIFT))&PMU_REG_1P0D_CLR_REG_TEST_MASK) +#define PMU_REG_1P0D_CLR_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_CLR_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_RSVD1_SHIFT))&PMU_REG_1P0D_CLR_RSVD1_MASK) +#define PMU_REG_1P0D_CLR_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_CLR_OVERRIDE_SHIFT 31 +/* REG_1P0D_TOG Bit Fields */ +#define PMU_REG_1P0D_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_BO_OFFSET_SHIFT))&PMU_REG_1P0D_TOG_BO_OFFSET_MASK) +#define PMU_REG_1P0D_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_TOG_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_RSVD0_SHIFT))&PMU_REG_1P0D_TOG_RSVD0_MASK) +#define PMU_REG_1P0D_TOG_BO_MASK 0x10000u +#define PMU_REG_1P0D_TOG_BO_SHIFT 16 +#define PMU_REG_1P0D_TOG_OK_MASK 0x20000u +#define PMU_REG_1P0D_TOG_OK_SHIFT 17 +#define PMU_REG_1P0D_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_REG_TEST_SHIFT))&PMU_REG_1P0D_TOG_REG_TEST_MASK) +#define PMU_REG_1P0D_TOG_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_TOG_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_RSVD1_SHIFT))&PMU_REG_1P0D_TOG_RSVD1_MASK) +#define PMU_REG_1P0D_TOG_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_TOG_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2 Bit Fields */ +#define PMU_REG_HSIC_1P2_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_SET Bit Fields */ +#define PMU_REG_HSIC_1P2_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_SET_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_SET_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_SET_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_SET_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_SET_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_SET_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_SET_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_SET_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_SET_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_SET_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_SET_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_SET_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_SET_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_SET_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_SET_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_CLR Bit Fields */ +#define PMU_REG_HSIC_1P2_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_CLR_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_CLR_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_CLR_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_CLR_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_CLR_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_CLR_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_CLR_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_CLR_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_CLR_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_CLR_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_CLR_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_CLR_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_CLR_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_TOG Bit Fields */ +#define PMU_REG_HSIC_1P2_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_TOG_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_TOG_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_TOG_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_TOG_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_TOG_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_TOG_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_TOG_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_TOG_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_TOG_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_TOG_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_TOG_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_TOG_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_TOG_OVERRIDE_SHIFT 31 +/* REG_LPSR_1P0 Bit Fields */ +#define PMU_REG_LPSR_1P0_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_RSVD1_MASK) +/* REG_LPSR_1P0_SET Bit Fields */ +#define PMU_REG_LPSR_1P0_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_SET_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_SET_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_SET_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_SET_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_SET_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_SET_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_SET_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_SET_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_SET_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_SET_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_SET_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_SET_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_SET_RSVD1_MASK) +/* REG_LPSR_1P0_CLR Bit Fields */ +#define PMU_REG_LPSR_1P0_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_CLR_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_CLR_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_CLR_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_CLR_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_CLR_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_CLR_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_CLR_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_CLR_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_CLR_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_CLR_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_CLR_RSVD1_MASK) +/* REG_LPSR_1P0_TOG Bit Fields */ +#define PMU_REG_LPSR_1P0_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_TOG_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_TOG_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_TOG_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_TOG_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_TOG_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_TOG_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_TOG_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_TOG_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_TOG_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_TOG_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_TOG_RSVD1_MASK) +/* REG_3P0 Bit Fields */ +#define PMU_REG_3P0_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_RSVD0_MASK 0x8u +#define PMU_REG_3P0_RSVD0_SHIFT 3 +#define PMU_REG_3P0_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_BO_OFFSET_SHIFT))&PMU_REG_3P0_BO_OFFSET_MASK) +#define PMU_REG_3P0_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_RSVD1_SHIFT 13 +#define PMU_REG_3P0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_RSVD1_SHIFT))&PMU_REG_3P0_RSVD1_MASK) +#define PMU_REG_3P0_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_REG_TEST_SHIFT))&PMU_REG_3P0_REG_TEST_MASK) +#define PMU_REG_3P0_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_RSVD2_SHIFT 22 +#define PMU_REG_3P0_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_RSVD2_SHIFT))&PMU_REG_3P0_RSVD2_MASK) +/* REG_3P0_SET Bit Fields */ +#define PMU_REG_3P0_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_SET_RSVD0_MASK 0x8u +#define PMU_REG_3P0_SET_RSVD0_SHIFT 3 +#define PMU_REG_3P0_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_BO_OFFSET_SHIFT))&PMU_REG_3P0_SET_BO_OFFSET_MASK) +#define PMU_REG_3P0_SET_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_SET_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_SET_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_SET_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_SET_RSVD1_SHIFT 13 +#define PMU_REG_3P0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_RSVD1_SHIFT))&PMU_REG_3P0_SET_RSVD1_MASK) +#define PMU_REG_3P0_SET_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_SET_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_SET_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_SET_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_SET_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_SET_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_REG_TEST_SHIFT))&PMU_REG_3P0_SET_REG_TEST_MASK) +#define PMU_REG_3P0_SET_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_SET_RSVD2_SHIFT 22 +#define PMU_REG_3P0_SET_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_RSVD2_SHIFT))&PMU_REG_3P0_SET_RSVD2_MASK) +/* REG_3P0_CLR Bit Fields */ +#define PMU_REG_3P0_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_CLR_RSVD0_MASK 0x8u +#define PMU_REG_3P0_CLR_RSVD0_SHIFT 3 +#define PMU_REG_3P0_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_BO_OFFSET_SHIFT))&PMU_REG_3P0_CLR_BO_OFFSET_MASK) +#define PMU_REG_3P0_CLR_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_CLR_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_CLR_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_CLR_RSVD1_SHIFT 13 +#define PMU_REG_3P0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_RSVD1_SHIFT))&PMU_REG_3P0_CLR_RSVD1_MASK) +#define PMU_REG_3P0_CLR_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_CLR_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_CLR_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_CLR_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_CLR_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_CLR_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_REG_TEST_SHIFT))&PMU_REG_3P0_CLR_REG_TEST_MASK) +#define PMU_REG_3P0_CLR_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_CLR_RSVD2_SHIFT 22 +#define PMU_REG_3P0_CLR_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_RSVD2_SHIFT))&PMU_REG_3P0_CLR_RSVD2_MASK) +/* REG_3P0_TOG Bit Fields */ +#define PMU_REG_3P0_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_TOG_RSVD0_MASK 0x8u +#define PMU_REG_3P0_TOG_RSVD0_SHIFT 3 +#define PMU_REG_3P0_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_BO_OFFSET_SHIFT))&PMU_REG_3P0_TOG_BO_OFFSET_MASK) +#define PMU_REG_3P0_TOG_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_TOG_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_TOG_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_TOG_RSVD1_SHIFT 13 +#define PMU_REG_3P0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_RSVD1_SHIFT))&PMU_REG_3P0_TOG_RSVD1_MASK) +#define PMU_REG_3P0_TOG_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_TOG_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_TOG_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_TOG_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_TOG_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_TOG_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_REG_TEST_SHIFT))&PMU_REG_3P0_TOG_REG_TEST_MASK) +#define PMU_REG_3P0_TOG_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_TOG_RSVD2_SHIFT 22 +#define PMU_REG_3P0_TOG_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_RSVD2_SHIFT))&PMU_REG_3P0_TOG_RSVD2_MASK) +/* REF Bit Fields */ +#define PMU_REF_REFTOP_PWD_MASK 0x1u +#define PMU_REF_REFTOP_PWD_SHIFT 0 +#define PMU_REF_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_REFTOP_VBGADJ_SHIFT))&PMU_REF_REFTOP_VBGADJ_MASK) +#define PMU_REF_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_REFTOP_BIAS_TST_SHIFT))&PMU_REF_REFTOP_BIAS_TST_MASK) +#define PMU_REF_LPBG_SEL_MASK 0x400u +#define PMU_REF_LPBG_SEL_SHIFT 10 +#define PMU_REF_LPBG_TEST_MASK 0x800u +#define PMU_REF_LPBG_TEST_SHIFT 11 +#define PMU_REF_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_RSVD1_SHIFT 14 +#define PMU_REF_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_RSVD1_SHIFT))&PMU_REF_RSVD1_MASK) +/* REF_SET Bit Fields */ +#define PMU_REF_SET_REFTOP_PWD_MASK 0x1u +#define PMU_REF_SET_REFTOP_PWD_SHIFT 0 +#define PMU_REF_SET_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_SET_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_SET_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_SET_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_SET_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_SET_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_SET_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_SET_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_SET_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_REFTOP_VBGADJ_SHIFT))&PMU_REF_SET_REFTOP_VBGADJ_MASK) +#define PMU_REF_SET_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_SET_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_SET_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_SET_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_SET_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_REFTOP_BIAS_TST_SHIFT))&PMU_REF_SET_REFTOP_BIAS_TST_MASK) +#define PMU_REF_SET_LPBG_SEL_MASK 0x400u +#define PMU_REF_SET_LPBG_SEL_SHIFT 10 +#define PMU_REF_SET_LPBG_TEST_MASK 0x800u +#define PMU_REF_SET_LPBG_TEST_SHIFT 11 +#define PMU_REF_SET_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_SET_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_SET_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_SET_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_SET_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_SET_RSVD1_SHIFT 14 +#define PMU_REF_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_RSVD1_SHIFT))&PMU_REF_SET_RSVD1_MASK) +/* REF_CLR Bit Fields */ +#define PMU_REF_CLR_REFTOP_PWD_MASK 0x1u +#define PMU_REF_CLR_REFTOP_PWD_SHIFT 0 +#define PMU_REF_CLR_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_CLR_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_CLR_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_CLR_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_CLR_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_CLR_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_CLR_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_CLR_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_CLR_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_REFTOP_VBGADJ_SHIFT))&PMU_REF_CLR_REFTOP_VBGADJ_MASK) +#define PMU_REF_CLR_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_CLR_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_CLR_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_CLR_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_CLR_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_REFTOP_BIAS_TST_SHIFT))&PMU_REF_CLR_REFTOP_BIAS_TST_MASK) +#define PMU_REF_CLR_LPBG_SEL_MASK 0x400u +#define PMU_REF_CLR_LPBG_SEL_SHIFT 10 +#define PMU_REF_CLR_LPBG_TEST_MASK 0x800u +#define PMU_REF_CLR_LPBG_TEST_SHIFT 11 +#define PMU_REF_CLR_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_CLR_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_CLR_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_CLR_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_CLR_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_CLR_RSVD1_SHIFT 14 +#define PMU_REF_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_RSVD1_SHIFT))&PMU_REF_CLR_RSVD1_MASK) +/* REF_TOG Bit Fields */ +#define PMU_REF_TOG_REFTOP_PWD_MASK 0x1u +#define PMU_REF_TOG_REFTOP_PWD_SHIFT 0 +#define PMU_REF_TOG_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_TOG_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_TOG_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_TOG_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_TOG_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_TOG_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_TOG_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_TOG_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_TOG_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_REFTOP_VBGADJ_SHIFT))&PMU_REF_TOG_REFTOP_VBGADJ_MASK) +#define PMU_REF_TOG_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_TOG_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_TOG_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_TOG_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_TOG_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_REFTOP_BIAS_TST_SHIFT))&PMU_REF_TOG_REFTOP_BIAS_TST_MASK) +#define PMU_REF_TOG_LPBG_SEL_MASK 0x400u +#define PMU_REF_TOG_LPBG_SEL_SHIFT 10 +#define PMU_REF_TOG_LPBG_TEST_MASK 0x800u +#define PMU_REF_TOG_LPBG_TEST_SHIFT 11 +#define PMU_REF_TOG_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_TOG_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_TOG_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_TOG_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_TOG_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_TOG_RSVD1_SHIFT 14 +#define PMU_REF_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_RSVD1_SHIFT))&PMU_REF_TOG_RSVD1_MASK) +/* LOWPWR_CTRL Bit Fields */ +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_CONTROL1_MASK) +/* LOWPWR_CTRL_SET Bit Fields */ +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_SET_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_SET_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_SET_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_SET_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_SET_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_SET_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_SET_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_SET_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_SET_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_SET_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_SET_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_SET_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_SET_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_SET_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_SET_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_SET_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_SET_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_SET_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_SET_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_SET_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_SET_CONTROL1_MASK) +/* LOWPWR_CTRL_CLR Bit Fields */ +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_CLR_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_CLR_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_CLR_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_CLR_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_CLR_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_CLR_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_CLR_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_CLR_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_CLR_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_CLR_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_CLR_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_CLR_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_CLR_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_CLR_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_CLR_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_CLR_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_CLR_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_CLR_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_CLR_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_CLR_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_CLR_CONTROL1_MASK) +/* LOWPWR_CTRL_TOG Bit Fields */ +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_TOG_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_TOG_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_TOG_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_TOG_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_TOG_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_TOG_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_TOG_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_TOG_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_TOG_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_TOG_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_TOG_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_TOG_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_TOG_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_TOG_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_TOG_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_TOG_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_TOG_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_TOG_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_TOG_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_TOG_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_TOG_CONTROL1_MASK) + + +/* HW_ANADIG_TEMPSENSE0 Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE1 Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_MASK) + + +#define CCM_GPR(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i)) +#define CCM_OBSERVE(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i)) +#define CCM_SCTRL(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i)) +#define CCM_CCGR(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i)) +#define CCM_ROOT_TARGET(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i)) + +#define CCM_GPR_SET(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 4) +#define CCM_OBSERVE_SET(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 4) +#define CCM_SCTRL_SET(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 4) +#define CCM_CCGR_SET(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 4) +#define CCM_ROOT_TARGET_SET(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 4) + +#define CCM_GPR_CLR(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 8) +#define CCM_OBSERVE_CLR(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 8) +#define CCM_SCTRL_CLR(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 8) +#define CCM_CCGR_CLR(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 8) +#define CCM_ROOT_TARGET_CLR(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 8) + +#define CCM_GPR_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 12) +#define CCM_OBSERVE_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 12) +#define CCM_SCTRL_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 12) +#define CCM_CCGR_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 12) +#define CCM_ROOT_TARGET_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 12) + +#define HW_CCM_GPR_WR(i, v) writel((v), CCM_GPR(i)) +#define HW_CCM_CCM_OBSERVE_WR(i, v) writel((v), CCM_OBSERVE(i)) +#define HW_CCM_SCTRL_WR(i, v) writel((v), CCM_SCTRL(i)) +#define HW_CCM_CCGR_WR(i, v) writel((v), CCM_CCGR(i)) +#define HW_CCM_ROOT_TARGET_WR(i, v) writel((v), CCM_ROOT_TARGET(i)) + +#define HW_CCM_GPR_RD(i) readl(CCM_GPR(i)) +#define HW_CCM_CCM_OBSERVE_RD(i) readl(CCM_OBSERVE(i)) +#define HW_CCM_SCTRL_RD(i) readl(CCM_SCTRL(i)) +#define HW_CCM_CCGR_RD(i) readl(CCM_CCGR(i)) +#define HW_CCM_ROOT_TARGET_RD(i) readl(CCM_ROOT_TARGET(i)) + +#define HW_CCM_GPR_SET(i, v) writel((v), CCM_GPR_SET(i)) +#define HW_CCM_CCM_OBSERVE_SET(i, v) writel((v), CCM_CCM_OBSERVE_SET(i)) +#define HW_CCM_SCTRL_SET(i, v) writel((v), CCM_SCTRL_SET(i)) +#define HW_CCM_CCGR_SET(i, v) writel((v), CCM_CCGR_SET(i)) +#define HW_CCM_ROOT_TARGET_SET(i, v) writel((v), CCM_ROOT_TARGET_SET(i)) + +#define HW_CCM_GPR_CLR(i, v) writel((v), CCM_GPR_CLR(i)) +#define HW_CCM_CCM_OBSERVE_CLR(i, v) writel((v), CCM_CCM_OBSERVE_CLR(i)) +#define HW_CCM_SCTRL_CLR(i, v) writel((v), CCM_SCTRL_CLR(i)) +#define HW_CCM_CCGR_CLR(i, v) writel((v), CCM_CCGR_CLR(i)) +#define HW_CCM_ROOT_TARGET_CLR(i, v) writel((v), CCM_ROOT_TARGET_CLR(i)) + +#define HW_CCM_GPR_TOGGLE(i, v) writel((v), CCM_GPR_TOGGLE(i)) +#define HW_CCM_CCM_OBSERVE_TOGGLE(i, v) writel((v), CCM_CCM_OBSERVE_TOGGLE(i)) +#define HW_CCM_SCTRL_TOGGLE(i, v) writel((v), CCM_SCTRL_TOGGLE(i)) +#define HW_CCM_CCGR_TOGGLE(i, v) writel((v), CCM_CCGR_TOGGLE(i)) +#define HW_CCM_ROOT_TARGET_TOGGLE(i, v) writel((v), CCM_ROOT_TARGET_TOGGLE(i)) + +#define CCM_CLK_ON_MSK 0x03 + +#define CCM_ROOT_TGT_POST_DIV_SHIFT 0 +#define CCM_ROOT_TGT_PRE_DIV_SHIFT 15 +#define CCM_ROOT_TGT_MUX_SHIFT 24 +#define CCM_ROOT_TGT_ENABLE_SHIFT 28 +#define CCM_ROOT_TGT_POST_DIV_MSK 0x3F +#define CCM_ROOT_TGT_PRE_DIV_MSK (0x07 << CCM_ROOT_TGT_PRE_DIV_SHIFT) +#define CCM_ROOT_TGT_MUX_MSK (0x07 << CCM_ROOT_TGT_MUX_SHIFT) +#define CCM_ROOT_TGT_ENABLE_MSK (0x01 << CCM_ROOT_TGT_ENABLE_SHIFT) + +#define CCM_ROOT_TGT_POST_DIV(x) ((((x) - 1) << CCM_ROOT_TGT_POST_DIV_SHIFT) & CCM_ROOT_TGT_POST_DIV_MSK) +#define CCM_ROOT_TGT_PRE_DIV(x) ((((x) - 1) << CCM_ROOT_TGT_PRE_DIV_SHIFT) & CCM_ROOT_TGT_PRE_DIV_MSK) +#define CCM_ROOT_TGT_MUX_TO(x) ((((x) - 1) << CCM_ROOT_TGT_MUX_SHIFT) & CCM_ROOT_TGT_MUX_MSK) + +/* + * Field values definition for clock slice TARGET register + */ + +#define CLK_ROOT_ON 0x10000000 +#define CLK_ROOT_OFF 0x0 +#define CLK_ROOT_ENABLE_MASK 0x10000000 +#define CLK_ROOT_ENABLE_SHIFT 28 + +#define CLK_ROOT_ALT0 0x00000000 +#define CLK_ROOT_ALT1 0x01000000 +#define CLK_ROOT_ALT2 0x02000000 +#define CLK_ROOT_ALT3 0x03000000 +#define CLK_ROOT_ALT4 0x04000000 +#define CLK_ROOT_ALT5 0x05000000 +#define CLK_ROOT_ALT6 0x06000000 +#define CLK_ROOT_ALT7 0x07000000 + + +#define DRAM_CLK_ROOT_POST_DIV_MASK 0x00000007 +#define CLK_ROOT_POST_DIV_MASK 0x0000003f +#define CLK_ROOT_POST_DIV_SHIFT 0 +#define CLK_ROOT_POST_DIV(n) ((n << CLK_ROOT_POST_DIV_SHIFT) & CLK_ROOT_POST_DIV_MASK) + +#define CLK_ROOT_AUTO_DIV_MASK 0x00000700 +#define CLK_ROOT_AUTO_DIV_SHIFT 8 +#define CLK_ROOT_AUTO_DIV(n) ((n << CLK_ROOT_AUTO_DIV_SHIFT) & CLK_ROOT_AUTO_DIV_MASK) + +#define CLK_ROOT_AUTO_EN_MASK 0x00001000 +#define CLK_ROOT_AUTO_EN 0x00001000 + +#define CLK_ROOT_PRE_DIV_MASK 0x00070000 +#define CLK_ROOT_PRE_DIV_SHIFT 16 +#define CLK_ROOT_PRE_DIV(n) ((n << CLK_ROOT_PRE_DIV_SHIFT) & CLK_ROOT_PRE_DIV_MASK) + +#define CLK_ROOT_MUX_MASK 0x07000000 +#define CLK_ROOT_MUX_SHIFT 24 + +#define CLK_ROOT_EN_MASK 0x10000000 + +#define CLK_ROOT_AUTO_ON 0x00001000 +#define CLK_ROOT_AUTO_OFF 0x0 + +/* ARM_A7_CLK_ROOT */ +#define ARM_A7_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_ARM_MAIN_800M_CLK 0x01000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x03000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x05000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x02000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ARM_M4_CLK_ROOT */ +#define ARM_M4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x03000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x02000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ARM_M0_CLK_ROOT */ +#define ARM_M0_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x03000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x02000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* MAIN_AXI_CLK_ROOT */ +#define MAIN_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x04000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* DISP_AXI_CLK_ROOT */ +#define DISP_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x04000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x05000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* ENET_AXI_CLK_ROOT */ +#define ENET_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x04000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x01000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x07000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* NAND_USDHC_BUS_CLK_ROOT */ +#define NAND_USDHC_BUS_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x03000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x01000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x04000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x05000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 + +/* AHB_CLK_ROOT */ +#define AHB_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define AHB_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define AHB_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x03000000 +#define AHB_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define AHB_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define AHB_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define AHB_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define AHB_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 + +/* DRAM_PHYM_CLK_ROOT */ +#define DRAM_PHYM_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x00000000 +#define DRAM_PHYM_CLK_ROOT_FROM_PLL_DRAM_PHYM_ALT_CLK_ROOT 0x01000000 + +/* DRAM_CLK_ROOT */ +#define DRAM_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x00000000 +#define DRAM_CLK_ROOT_FROM_PLL_DRAM_ALT_CLK_ROOT 0x01000000 + +/* DRAM_PHYM_ALT_CLK_ROOT */ +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x01000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x02000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x05000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* DRAM_ALT_CLK_ROOT */ +#define DRAM_ALT_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x01000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x02000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x05000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x07000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x04000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 + +/* USB_HSIC_CLK_ROOT */ +#define USB_HSIC_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x03000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x05000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x02000000 + +/* PCIE_CTRL_CLK_ROOT */ +#define PCIE_CTRL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x02000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x06000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x03000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x07000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x01000000 + +/* PCIE_PHY_CLK_ROOT */ +#define PCIE_PHY_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x07000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x02000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* EPDC_PIXEL_CLK_ROOT */ +#define EPDC_PIXEL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x04000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x05000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x06000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* LCDIF_PIXEL_CLK_ROOT */ +#define LCDIF_PIXEL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x01000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_EXT_CLK_3 0x03000000 + +/* MIPI_DSI_EXTSER_CLK_ROOT */ +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x05000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD0_196M_CLK 0x04000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x02000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x01000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* MIPI_CSI_WARP_CLK_ROOT */ +#define MIPI_CSI_WARP_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x05000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD0_196M_CLK 0x04000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x02000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x01000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* MIPI_DPHY_REF_CLK_ROOT */ +#define MIPI_DPHY_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x03000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_REF_1M_CLK 0x04000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* SAI1_CLK_ROOT */ +#define SAI1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI1_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI1_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* SAI2_CLK_ROOT */ +#define SAI2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI2_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI2_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* SAI3_CLK_ROOT */ +#define SAI3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI3_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI3_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI3_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* SPDIF_CLK_ROOT */ +#define SPDIF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SPDIF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SPDIF_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SPDIF_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SPDIF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SPDIF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SPDIF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SPDIF_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* ENET1_REF_CLK_ROOT */ +#define ENET1_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x04000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x01000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x03000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ENET1_REF_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* ENET1_TIME_CLK_ROOT */ +#define ENET1_TIME_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ENET2_REF_CLK_ROOT */ +#define ENET2_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x04000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x01000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x03000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ENET2_REF_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* ENET2_TIME_CLK_ROOT */ +#define ENET2_TIME_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ENET_PHY_REF_CLK_ROOT */ +#define ENET_PHY_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x07000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x03000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x01000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* EIM_CLK_ROOT */ +#define EIM_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define EIM_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x04000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x05000000 +#define EIM_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define EIM_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* NAND_CLK_ROOT */ +#define NAND_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define NAND_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x03000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define NAND_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* QSPI_CLK_ROOT */ +#define QSPI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define QSPI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x01000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define QSPI_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC1_CLK_ROOT */ +#define USDHC1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC1_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC2_CLK_ROOT */ +#define USDHC2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC2_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC3_CLK_ROOT */ +#define USDHC3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC3_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* CAN1_CLK_ROOT */ +#define CAN1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CAN1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define CAN1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define CAN1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define CAN1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x04000000 +#define CAN1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define CAN1_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define CAN1_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* CAN2_CLK_ROOT */ +#define CAN2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CAN2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define CAN2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define CAN2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define CAN2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x04000000 +#define CAN2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define CAN2_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define CAN2_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* I2C1_CLK_ROOT */ +#define I2C1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C1_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C2_CLK_ROOT */ +#define I2C2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C2_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C3_CLK_ROOT */ +#define I2C3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C3_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C3_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C4_CLK_ROOT */ +#define I2C4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C4_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C4_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C4_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* UART1_CLK_ROOT */ +#define UART1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART1_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART1_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART2_CLK_ROOT */ +#define UART2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART2_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART2_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART3_CLK_ROOT */ +#define UART3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART3_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART3_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART3_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART4_CLK_ROOT */ +#define UART4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART4_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART4_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART4_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART5_CLK_ROOT */ +#define UART5_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART5_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART5_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART5_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART5_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART5_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART5_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART5_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART6_CLK_ROOT */ +#define UART6_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART6_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART6_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART6_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART6_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART6_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART6_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART6_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART7_CLK_ROOT */ +#define UART7_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART7_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART7_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART7_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART7_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART7_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART7_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART7_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ECSPI1_CLK_ROOT */ +#define ECSPI1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI2_CLK_ROOT */ +#define ECSPI2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI3_CLK_ROOT */ +#define ECSPI3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI4_CLK_ROOT */ +#define ECSPI4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* PWM1_CLK_ROOT */ +#define PWM1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM1_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM1_CLK_ROOT_FROM_EXT_CLK_1 0x05000000 + +/* PWM2_CLK_ROOT */ +#define PWM2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM2_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM2_CLK_ROOT_FROM_EXT_CLK_1 0x05000000 + +/* PWM3_CLK_ROOT */ +#define PWM3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM3_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM3_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 + +/* PWM4_CLK_ROOT */ +#define PWM4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM4_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM4_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 + +/* FLEXTIMER1_CLK_ROOT */ +#define FLEXTIMER1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define FLEXTIMER1_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define FLEXTIMER1_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 + +/* FLEXTIMER2_CLK_ROOT */ +#define FLEXTIMER2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define FLEXTIMER2_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define FLEXTIMER2_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 + +/* SIM1_CLK_ROOT */ +#define SIM1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SIM1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define SIM1_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SIM1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define SIM1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* SIM2_CLK_ROOT */ +#define SIM2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SIM2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define SIM2_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SIM2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define SIM2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* GPT1_CLK_ROOT */ +#define GPT1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT1_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT1_CLK_ROOT_FROM_EXT_CLK_1 0x07000000 + +/* GPT2_CLK_ROOT */ +#define GPT2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT2_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT2_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT2_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* GPT3_CLK_ROOT */ +#define GPT3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT3_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT3_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT3_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* GPT4_CLK_ROOT */ +#define GPT4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT4_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT4_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT4_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* TRACE_CLK_ROOT */ +#define TRACE_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define TRACE_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define TRACE_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define TRACE_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define TRACE_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define TRACE_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define TRACE_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define TRACE_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* WDOG_CLK_ROOT */ +#define WDOG_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define WDOG_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_PFD1_166M_CLK 0x07000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define WDOG_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define WDOG_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define WDOG_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 + +/* CSI_MCLK_CLK_ROOT */ +#define CSI_MCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* AUDIO_MCLK_CLK_ROOT */ +#define AUDIO_MCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* WRCLK_CLK_ROOT */ +#define WRCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define WRCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x04000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define WRCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x06000000 +#define WRCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x01000000 +#define WRCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x03000000 + +/* IPP_DO_CLKO1 */ +#define IPP_DO_CLKO1_FROM_OSC_24M_CLK 0x00000000 +#define IPP_DO_CLKO1_FROM_PLL_DRAM_MAIN_533M_CLK 0x06000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_MAIN_240M_CLK 0x02000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_PFD0_196M_CLK 0x03000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define IPP_DO_CLKO1_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define IPP_DO_CLKO1_FROM_REF_1M_CLK 0x07000000 + +/* IPP_DO_CLKO2 */ +#define IPP_DO_CLKO2_FROM_OSC_24M_CLK 0x00000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD1_166M_CLK 0x03000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define IPP_DO_CLKO2_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define IPP_DO_CLKO2_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define IPP_DO_CLKO2_FROM_OSC_32K_CLK 0x07000000 + +#endif diff --git a/arch/arm/include/asm/arch-mx7/imx-regs.h b/arch/arm/include/asm/arch-mx7/imx-regs.h new file mode 100644 index 0000000..9f800ae --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/imx-regs.h @@ -0,0 +1,1303 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. All Rights Reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_MX7_IMX_REGS_H__ +#define __ASM_ARCH_MX7_IMX_REGS_H__ + +#define ARCH_MXC + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define ROM_SW_INFO_ADDR 0x000001E8 +#define ROMCP_ARB_BASE_ADDR 0x00000000 +#define ROMCP_ARB_END_ADDR 0x00017FFF +#define BOOT_ROM_BASE_ADDR ROMCP_ARB_BASE_ADDR +#define CAAM_ARB_BASE_ADDR 0x00100000 +#define CAAM_ARB_END_ADDR 0x00107FFF +#define GIC400_ARB_BASE_ADDR 0x31000000 +#define GIC400_ARB_END_ADDR 0x31007FFF +#define APBH_DMA_ARB_BASE_ADDR 0x33000000 +#define APBH_DMA_ARB_END_ADDR 0x33007FFF +#define M4_BOOTROM_BASE_ADDR 0x00180000 + +#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR +#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) +#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000) + +/* GPV - PL301 configuration ports */ +#define GPV0_BASE_ADDR 0x32000000 +#define GPV1_BASE_ADDR 0x32100000 +#define GPV2_BASE_ADDR 0x32200000 +#define GPV3_BASE_ADDR 0x32300000 +#define GPV4_BASE_ADDR 0x32400000 +#define GPV5_BASE_ADDR 0x32500000 +#define GPV6_BASE_ADDR 0x32600000 +#define GPV7_BASE_ADDR 0x32700000 + +#define OCRAM_ARB_BASE_ADDR 0x00900000 +#define OCRAM_ARB_END_ADDR 0x0091FFFF +#define OCRAM_EPDC_BASE_ADDR 0x00920000 +#define OCRAM_EPDC_END_ADDR 0x0093FFFF +#define OCRAM_PXP_BASE_ADDR 0x00940000 +#define OCRAM_PXP_END_ADDR 0x00947FFF +#define IRAM_BASE_ADDR OCRAM_ARB_BASE_ADDR +#define IRAM_SIZE 0x00020000 + +#define AIPS1_ARB_BASE_ADDR 0x30000000 +#define AIPS1_ARB_END_ADDR 0x303FFFFF +#define AIPS2_ARB_BASE_ADDR 0x30400000 +#define AIPS2_ARB_END_ADDR 0x307FFFFF +#define AIPS3_ARB_BASE_ADDR 0x30800000 +#define AIPS3_ARB_END_ADDR 0x30BFFFFF + +#define WEIM_ARB_BASE_ADDR 0x28000000 +#define WEIM_ARB_END_ADDR 0x2FFFFFFF + +#define QSPI0_ARB_BASE_ADDR 0x60000000 +#define QSPI0_ARB_END_ADDR 0x6FFFFFFF +#define PCIE_ARB_BASE_ADDR 0x40000000 +#define PCIE_ARB_END_ADDR 0x4FFFFFFF +#define PCIE_REG_BASE_ADDR 0x33800000 +#define PCIE_REG_END_ADDR 0x33803FFF + +#define MMDC0_ARB_BASE_ADDR 0x80000000 +#define MMDC0_ARB_END_ADDR 0xBFFFFFFF +#define MMDC1_ARB_BASE_ADDR 0xC0000000 +#define MMDC1_ARB_END_ADDR 0xFFFFFFFF + +/* Cortex-A9 MPCore private memory region */ +#define ARM_PERIPHBASE 0x31000000 +#define SCU_BASE_ADDR ARM_PERIPHBASE +#define GLOBAL_TIMER_BASE_ADDR (ARM_PERIPHBASE + 0x0200) +#define PRIVATE_TIMERS_WD_BASE_ADDR (ARM_PERIPHBASE + 0x0600) + + +/* Defines for Blocks connected via AIPS (SkyBlue) */ +#define AIPS_TZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR +#define AIPS_TZ2_BASE_ADDR AIPS2_ARB_BASE_ADDR +#define AIPS_TZ3_BASE_ADDR AIPS3_ARB_BASE_ADDR + +/* DAP base-address */ +#define ARM_IPS_BASE_ADDR AIPS1_ARB_BASE_ADDR + +/* AIPS_TZ#1- On Platform */ +#define AIPS1_ON_BASE_ADDR (AIPS_TZ1_BASE_ADDR+0x1F0000) +/* AIPS_TZ#1- Off Platform */ +#define AIPS1_OFF_BASE_ADDR (AIPS_TZ1_BASE_ADDR+0x200000) + +#define GPIO1_BASE_ADDR AIPS1_OFF_BASE_ADDR +#define GPIO2_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x10000) +#define GPIO3_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x20000) +#define GPIO4_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x30000) +#define GPIO5_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x40000) +#define GPIO6_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x50000) +#define GPIO7_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x60000) +#define IOMUXC_LPSR_GPR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x70000) +#define WDOG1_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x80000) +#define WDOG2_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x90000) +#define WDOG3_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xA0000) +#define WDOG4_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xB0000) +#define IOMUXC_LPSR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xC0000) +#define GPT_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xD0000) +#define GPT1_BASE_ADDR GPT_IPS_BASE_ADDR +#define GPT2_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xE0000) +#define GPT3_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xF0000) +#define GPT4_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x100000) +#define ROMCP_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x110000) +#define KPP_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x120000) +#define IOMUXC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x130000) +#define IOMUXC_BASE_ADDR IOMUXC_IPS_BASE_ADDR +#define IOMUXC_GPR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x140000) +#define OCOTP_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x150000) +#define ANATOP_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x160000) +#define SNVS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x170000) +#define CCM_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x180000) +#define SRC_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x190000) +#define GPC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1A0000) +#define SEMA41_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1B0000) +#define SEMA42_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1C0000) +#define RDC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1D0000) +#define CSU_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1E0000) + +/* AIPS_TZ#2- On Platform */ +#define AIPS2_ON_BASE_ADDR (AIPS_TZ2_BASE_ADDR+0x1F0000) +/* AIPS_TZ#2- Off Platform */ +#define AIPS2_OFF_BASE_ADDR (AIPS_TZ2_BASE_ADDR+0x200000) +#define ADC1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x10000) +#define ADC2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x20000) +#define ECSPI4_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x30000) +#define FTM1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x40000) +#define FTM2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x50000) +#define PWM1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x60000) +#define PWM2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x70000) +#define PWM3_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x80000) +#define PWM4_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x90000) +#define SYSCNT_RD_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xA0000) +#define SYSCNT_CMP_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xB0000) +#define SYSCNT_CTRL_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xC0000) +#define PCIE_PHY_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xD0000) +#define EPDC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xF0000) +#define EPDC_BASE_ADDR EPDC_IPS_BASE_ADDR +#define EPXP_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x100000) +#define CSI1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x110000) +#define ELCDIF1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x130000) +#define MIPI_CSI2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x150000) +#define MIPI_DSI_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x160000) +#define IP2APB_TZASC1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x180000) +#define DDRPHY_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x190000) +#define DDRC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1A0000) +#define IP2APB_PERFMON1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1C0000) +#define IP2APB_PERFMON2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1D0000) +#define IP2APB_AXIMON_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1E0000) +#define QOSC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1F0000) + +/* AIPS_TZ#3 - Global enable (0) */ +#define ECSPI1_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x20000) +#define ECSPI2_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x30000) +#define ECSPI3_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x40000) +#define UART1_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x60000) +#define UART3_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x80000) +#define UART2_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x90000) +#define SAI1_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xA0000) +#define SAI2_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xB0000) +#define SAI3_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xC0000) +#define SPBA_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xF0000) +#define CAAM_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x100000) + +/* AIPS_TZ#3- On Platform */ +#define AIPS3_ON_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x1F0000) +/* AIPS_TZ#3- Off Platform */ +#define AIPS3_OFF_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x200000) +#define CAN1_IPS_BASE_ADDR AIPS3_OFF_BASE_ADDR +#define CAN2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x10000) +#define I2C1_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x20000) +#define I2C2_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x30000) +#define I2C3_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x40000) +#define I2C4_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x50000) +#define UART4_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x60000) +#define UART5_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x70000) +#define UART6_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x80000) +#define UART7_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x90000) +#define MUCPU_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xA0000) +#define MUDSP_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xB0000) +#define HS_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xC0000) +#define USBOH2_PL301_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xD0000) +#define USBOTG1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x110000) +#define USBOTG2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x120000) +#define USBHSIC_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x130000) +#define USDHC1_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x140000) +#define USDHC2_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x150000) +#define USDHC3_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x160000) +#define EMVSIM1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x190000) +#define EMVSIM2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1A0000) +#define SIM1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x190000) +#define SIM2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1A0000) +#define QSPI1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1B0000) +#define WEIM_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1C0000) +#define SDMA_PORT_IPS_HOST_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1D0000) +#define ENET_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1E0000) +#define ENET2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1F0000) + +#define SDMA_IPS_HOST_BASE_ADDR SDMA_PORT_IPS_HOST_BASE_ADDR +#define SDMA_IPS_HOST_IPS_BASE_ADDR SDMA_PORT_IPS_HOST_BASE_ADDR + +#define SCTR_BASE_ADDR SYSCNT_CTRL_IPS_BASE_ADDR +#define DEBUG_MONITOR_BASE_ADDR IP2APB_AXIMON_IPS_BASE_ADDR + +#define USB_BASE_ADDR USBOTG1_IPS_BASE_ADDR + +#define FEC_QUIRK_ENET_MAC +#define SNVS_LPGPR 0x68 + +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/types.h> + +extern void imx_get_mac_from_fuse(int dev_id, unsigned char *mac); + +/* System Reset Controller (SRC) */ +struct src { + u32 scr; + u32 a7rcr0; + u32 a7rcr1; + u32 m4rcr; + u32 reserved1; + u32 ercr; + u32 reserved2; + u32 hsicphy_rcr; + u32 usbophy1_rcr; + u32 usbophy2_rcr; + u32 mipiphy_rcr; + u32 pciephy_rcr; + u32 reserved3[10]; + u32 sbmr1; + u32 srsr; + u32 reserved4[2]; + u32 sisr; + u32 simr; + u32 sbmr2; + u32 gpr1; + u32 gpr2; + u32 gpr3; + u32 gpr4; + u32 gpr5; + u32 gpr6; + u32 gpr7; + u32 gpr8; + u32 gpr9; + u32 gpr10; + u32 reserved5[985]; + u32 ddrc_rcr; +}; + +/* GPR0 Bit Fields */ +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL0_MASK 0x1u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL0_SHIFT 0 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL1_MASK 0x2u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL1_SHIFT 1 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL2_MASK 0x4u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL2_SHIFT 2 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL3_MASK 0x8u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL3_SHIFT 3 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL4_MASK 0x10u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL4_SHIFT 4 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL5_MASK 0x20u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL5_SHIFT 5 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL6_MASK 0x40u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL6_SHIFT 6 +/* GPR1 Bit Fields */ +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS0_MASK 0x1u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS0_SHIFT 0 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_MASK 0x6u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_SHIFT 1 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS1_MASK 0x8u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS1_SHIFT 3 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_MASK 0x30u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_SHIFT 4 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS2_MASK 0x40u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS2_SHIFT 6 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_MASK 0x180u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_SHIFT 7 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS3_MASK 0x200u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS3_SHIFT 9 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_MASK 0xC00u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_SHIFT 10 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_MASK) +#define IOMUXC_GPR_GPR1_GPR_IRQ_MASK 0x1000u +#define IOMUXC_GPR_GPR1_GPR_IRQ_SHIFT 12 +#define IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK 0x2000u +#define IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_SHIFT 13 +#define IOMUXC_GPR_GPR1_GPR_ENET2_TX_CLK_SEL_MASK 0x4000u +#define IOMUXC_GPR_GPR1_GPR_ENET2_TX_CLK_SEL_SHIFT 14 +#define IOMUXC_GPR_GPR1_GPR_ANATOP_TESTMODE_MASK 0x8000u +#define IOMUXC_GPR_GPR1_GPR_ANATOP_TESTMODE_SHIFT 15 +#define IOMUXC_GPR_GPR1_GPR_PAD_ADD_DS_MASK 0x10000u +#define IOMUXC_GPR_GPR1_GPR_PAD_ADD_DS_SHIFT 16 +#define IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK 0x20000u +#define IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_SHIFT 17 +#define IOMUXC_GPR_GPR1_GPR_ENET2_CLK_DIR_MASK 0x40000u +#define IOMUXC_GPR_GPR1_GPR_ENET2_CLK_DIR_SHIFT 18 +#define IOMUXC_GPR_GPR1_GPR_EXC_ERR_RESP_EN_MASK 0x400000u +#define IOMUXC_GPR_GPR1_GPR_EXC_ERR_RESP_EN_SHIFT 22 +#define IOMUXC_GPR_GPR1_GPR_TZASC1_SECURE_BOOT_LOCK_MASK 0x800000u +#define IOMUXC_GPR_GPR1_GPR_TZASC1_SECURE_BOOT_LOCK_SHIFT 23 +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK_MASK 0x30000000u +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK_SHIFT 28 +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_DBG_ACK_SHIFT))&IOMUXC_GPR_GPR1_GPR_DBG_ACK_MASK) +#define IOMUXC_GPR_GPR1_GPR_ENABLE_OCRAM_EPDC_MASK 0x40000000u +#define IOMUXC_GPR_GPR1_GPR_ENABLE_OCRAM_EPDC_SHIFT 30 +/* GPR2 Bit Fields */ +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LOWPOWER_MASK 0x1u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LOWPOWER_SHIFT 0 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_SD_MASK 0x2u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_SD_SHIFT 1 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_DS_MASK 0x4u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_DS_SHIFT 2 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LS_MASK 0x8u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LS_SHIFT 3 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LOWPOWER_MASK 0x10u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LOWPOWER_SHIFT 4 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_SD_MASK 0x20u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_SD_SHIFT 5 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_DS_MASK 0x40u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_DS_SHIFT 6 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LS_MASK 0x80u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LS_SHIFT 7 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LOWPOWER_MASK 0x100u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LOWPOWER_SHIFT 8 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_SD_MASK 0x200u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_SD_SHIFT 9 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_DS_MASK 0x400u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_DS_SHIFT 10 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LS_MASK 0x800u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LS_SHIFT 11 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LOWPOWER_MASK 0x1000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LOWPOWER_SHIFT 12 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_SD_MASK 0x2000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_SD_SHIFT 13 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_DS_MASK 0x4000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_DS_SHIFT 14 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LS_MASK 0x8000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LS_SHIFT 15 +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_MASK 0xFF0000u +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_SHIFT 16 +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_SHIFT))&IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_MASK) +#define IOMUXC_GPR_GPR2_GPR_MQS_SW_RST_MASK 0x1000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_SW_RST_SHIFT 24 +#define IOMUXC_GPR_GPR2_GPR_MQS_EN_MASK 0x2000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_EN_SHIFT 25 +#define IOMUXC_GPR_GPR2_GPR_MQS_OVERSAMPLE_MASK 0x4000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_OVERSAMPLE_SHIFT 26 +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_BYPASS_MASK 0x8000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_BYPASS_SHIFT 27 +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_MASK 0x10000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_SHIFT 28 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE0_MASK 0x20000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE0_SHIFT 29 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE1_MASK 0x40000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE1_SHIFT 30 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE_BYPASS_MASK 0x80000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE_BYPASS_SHIFT 31 +/* GPR3 Bit Fields */ +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_DATA_WAIT_EN_MASK 0x1u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_DATA_WAIT_EN_SHIFT 0 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_ADDR_PIPELINE_EN_MASK 0x2u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_ADDR_PIPELINE_EN_SHIFT 1 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_DATA_PIPELINE_EN_MASK 0x4u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_DATA_PIPELINE_EN_SHIFT 2 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_ADDR_PIPELINE_EN_MASK 0x8u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_ADDR_PIPELINE_EN_SHIFT 3 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_DATA_WAIT_EN_MASK 0x10u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_DATA_WAIT_EN_SHIFT 4 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_ADDR_PIPELINE_EN_MASK 0x20u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_ADDR_PIPELINE_EN_SHIFT 5 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_DATA_PIPELINE_EN_MASK 0x40u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_DATA_PIPELINE_EN_SHIFT 6 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_ADDR_PIPELINE_EN_MASK 0x80u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_ADDR_PIPELINE_EN_SHIFT 7 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_DATA_WAIT_EN_MASK 0x100u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_DATA_WAIT_EN_SHIFT 8 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_ADDR_PIPELINE_EN_MASK 0x200u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_ADDR_PIPELINE_EN_SHIFT 9 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_DATA_PIPELINE_EN_MASK 0x400u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_DATA_PIPELINE_EN_SHIFT 10 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_ADDR_PIPELINE_EN_MASK 0x800u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_ADDR_PIPELINE_EN_SHIFT 11 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_DATA_WAIT_EN_MASK 0x1000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_DATA_WAIT_EN_SHIFT 12 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_ADDR_PIPELINE_EN_MASK 0x2000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_ADDR_PIPELINE_EN_SHIFT 13 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_DATA_PIPELINE_EN_MASK 0x4000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_DATA_PIPELINE_EN_SHIFT 14 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_ADDR_PIPELINE_EN_MASK 0x8000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_ADDR_PIPELINE_EN_SHIFT 15 +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_data_wait_en_update_pending_MASK 0x10000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_data_wait_en_update_pending_SHIFT 16 +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_addr_pipeline_en_update_pending_MASK 0x20000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_addr_pipeline_en_update_pending_SHIFT 17 +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_data_pipeline_en_update_pending_MASK 0x40000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_data_pipeline_en_update_pending_SHIFT 18 +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_addr_pipeline_en_update_pending_MASK 0x80000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_addr_pipeline_en_update_pending_SHIFT 19 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_data_wait_en_update_pending_MASK 0x100000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_data_wait_en_update_pending_SHIFT 20 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_addr_pipeline_en_update_pending_MASK 0x200000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_addr_pipeline_en_update_pending_SHIFT 21 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_data_pipeline_en_update_pending_MASK 0x400000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_data_pipeline_en_update_pending_SHIFT 22 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_addr_pipeline_en_update_pending_MASK 0x800000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_addr_pipeline_en_update_pending_SHIFT 23 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_data_wait_en_update_pending_MASK 0x1000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_data_wait_en_update_pending_SHIFT 24 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_addr_pipeline_en_update_pending_MASK 0x2000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_addr_pipeline_en_update_pending_SHIFT 25 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_data_pipeline_en_update_pending_MASK 0x4000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_data_pipeline_en_update_pending_SHIFT 26 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_addr_pipeline_en_update_pending_MASK 0x8000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_addr_pipeline_en_update_pending_SHIFT 27 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_data_wait_en_update_pending_MASK 0x10000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_data_wait_en_update_pending_SHIFT 28 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_addr_pipeline_en_update_pending_MASK 0x20000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_addr_pipeline_en_update_pending_SHIFT 29 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_data_pipeline_en_update_pending_MASK 0x40000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_data_pipeline_en_update_pending_SHIFT 30 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_addr_pipeline_en_update_pending_MASK 0x80000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_addr_pipeline_en_update_pending_SHIFT 31 +/* GPR4 Bit Fields */ +#define IOMUXC_GPR_GPR4_GPR_SDMA_IPG_STOP_MASK 0x1u +#define IOMUXC_GPR_GPR4_GPR_SDMA_IPG_STOP_SHIFT 0 +#define IOMUXC_GPR_GPR4_GPR_CAN1_IPG_STOP_MASK 0x2u +#define IOMUXC_GPR_GPR4_GPR_CAN1_IPG_STOP_SHIFT 1 +#define IOMUXC_GPR_GPR4_GPR_CAN2_IPG_STOP_MASK 0x4u +#define IOMUXC_GPR_GPR4_GPR_CAN2_IPG_STOP_SHIFT 2 +#define IOMUXC_GPR_GPR4_GPR_ENET1_IPG_STOP_MASK 0x8u +#define IOMUXC_GPR_GPR4_GPR_ENET1_IPG_STOP_SHIFT 3 +#define IOMUXC_GPR_GPR4_GPR_ENET2_IPG_STOP_MASK 0x10u +#define IOMUXC_GPR_GPR4_GPR_ENET2_IPG_STOP_SHIFT 4 +#define IOMUXC_GPR_GPR4_GPR_SAI1_IPG_STOP_MASK 0x20u +#define IOMUXC_GPR_GPR4_GPR_SAI1_IPG_STOP_SHIFT 5 +#define IOMUXC_GPR_GPR4_GPR_SAI2_IPG_STOP_MASK 0x40u +#define IOMUXC_GPR_GPR4_GPR_SAI2_IPG_STOP_SHIFT 6 +#define IOMUXC_GPR_GPR4_GPR_SAI3_IPG_STOP_MASK 0x80u +#define IOMUXC_GPR_GPR4_GPR_SAI3_IPG_STOP_SHIFT 7 +#define IOMUXC_GPR_GPR4_sdma_ipg_stop_ack_MASK 0x10000u +#define IOMUXC_GPR_GPR4_sdma_ipg_stop_ack_SHIFT 16 +#define IOMUXC_GPR_GPR4_can1_ipg_stop_ack_MASK 0x20000u +#define IOMUXC_GPR_GPR4_can1_ipg_stop_ack_SHIFT 17 +#define IOMUXC_GPR_GPR4_can2_ipg_stop_ack_MASK 0x40000u +#define IOMUXC_GPR_GPR4_can2_ipg_stop_ack_SHIFT 18 +#define IOMUXC_GPR_GPR4_enet1_ipg_stop_ack_MASK 0x80000u +#define IOMUXC_GPR_GPR4_enet1_ipg_stop_ack_SHIFT 19 +#define IOMUXC_GPR_GPR4_enet2_ipg_stop_ack_MASK 0x100000u +#define IOMUXC_GPR_GPR4_enet2_ipg_stop_ack_SHIFT 20 +#define IOMUXC_GPR_GPR4_sai1_ipg_stop_ack_MASK 0x200000u +#define IOMUXC_GPR_GPR4_sai1_ipg_stop_ack_SHIFT 21 +#define IOMUXC_GPR_GPR4_sai2_ipg_stop_ack_MASK 0x400000u +#define IOMUXC_GPR_GPR4_sai2_ipg_stop_ack_SHIFT 22 +#define IOMUXC_GPR_GPR4_sai3_ipg_stop_ack_MASK 0x800000u +#define IOMUXC_GPR_GPR4_sai3_ipg_stop_ack_SHIFT 23 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI_MASK 0x6000000u +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI_SHIFT 25 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR4_cpu_STANDBYWFI_SHIFT))&IOMUXC_GPR_GPR4_cpu_STANDBYWFI_MASK) +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE_MASK 0x18000000u +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE_SHIFT 27 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR4_cpu_STANDBYWFE_SHIFT))&IOMUXC_GPR_GPR4_cpu_STANDBYWFE_MASK) +/* GPR5 Bit Fields */ +#define IOMUXC_GPR_GPR5_GPR_CSI_MUX_CONTROL_MASK 0x10u +#define IOMUXC_GPR_GPR5_GPR_CSI_MUX_CONTROL_SHIFT 4 +#define IOMUXC_GPR_GPR5_GPR_LVDS_MUX_CONTROL_MASK 0x20u +#define IOMUXC_GPR_GPR5_GPR_LVDS_MUX_CONTROL_SHIFT 5 +#define IOMUXC_GPR_GPR5_GPR_WDOG1_MASK_MASK 0x40u +#define IOMUXC_GPR_GPR5_GPR_WDOG1_MASK_SHIFT 6 +#define IOMUXC_GPR_GPR5_GPR_WDOG2_MASK_MASK 0x80u +#define IOMUXC_GPR_GPR5_GPR_WDOG2_MASK_SHIFT 7 +#define IOMUXC_GPR_GPR5_GPR_LCDIF_HANDSHAKE_MASK 0x1000u +#define IOMUXC_GPR_GPR5_GPR_LCDIF_HANDSHAKE_SHIFT 12 +#define IOMUXC_GPR_GPR5_GPR_PCIE_BTNRST_MASK 0x80000u +#define IOMUXC_GPR_GPR5_GPR_PCIE_BTNRST_SHIFT 19 +#define IOMUXC_GPR_GPR5_GPR_WDOG3_MASK_MASK 0x100000u +#define IOMUXC_GPR_GPR5_GPR_WDOG3_MASK_SHIFT 20 +#define IOMUXC_GPR_GPR5_GPR_LCDIF_CSI_VSYNC_SEL_MASK 0x200000u +#define IOMUXC_GPR_GPR5_GPR_LCDIF_CSI_VSYNC_SEL_SHIFT 21 +#define IOMUXC_GPR_GPR5_GPR_WDOG4_MASK_MASK 0x400000u +#define IOMUXC_GPR_GPR5_GPR_WDOG4_MASK_SHIFT 22 +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN1_SEL_MASK 0x1000000u +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN1_SEL_SHIFT 24 +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN2_SEL_MASK 0x2000000u +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN2_SEL_SHIFT 25 +#define IOMUXC_GPR_GPR5_GPR_ENET1_EVENT3IN_SEL_MASK 0x4000000u +#define IOMUXC_GPR_GPR5_GPR_ENET1_EVENT3IN_SEL_SHIFT 26 +#define IOMUXC_GPR_GPR5_GPR_ENET2_EVENT3IN_SEL_MASK 0x8000000u +#define IOMUXC_GPR_GPR5_GPR_ENET2_EVENT3IN_SEL_SHIFT 27 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT1_MASK 0x10000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT1_SHIFT 28 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT2_MASK 0x20000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT2_SHIFT 29 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT3_MASK 0x40000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT3_SHIFT 30 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT4_MASK 0x80000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT4_SHIFT 31 +/* GPR6 Bit Fields */ +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_MASK 0x1u +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_SHIFT 0 +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_MASK 0x2u +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_SHIFT 1 +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_EN_MASK 0x4u +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_EN_SHIFT 2 +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_EN_MASK 0x8u +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_EN_SHIFT 3 +/* GPR7 Bit Fields */ +#define IOMUXC_GPR_GPR7_GPR_chd1_pwd_ldo_usb_1p0_MASK 0x1u +#define IOMUXC_GPR_GPR7_GPR_chd1_pwd_ldo_usb_1p0_SHIFT 0 +#define IOMUXC_GPR_GPR7_GPR_chd1_lowpwr_ldo_usb_1p0_MASK 0x2u +#define IOMUXC_GPR_GPR7_GPR_chd1_lowpwr_ldo_usb_1p0_SHIFT 1 +#define IOMUXC_GPR_GPR7_GPR_chd1_en_ilimit_ldo_usb_1p0_MASK 0x4u +#define IOMUXC_GPR_GPR7_GPR_chd1_en_ilimit_ldo_usb_1p0_SHIFT 2 +#define IOMUXC_GPR_GPR7_GPR_chd1_en_pwrupload_ldo_usb_1p0_MASK 0x8u +#define IOMUXC_GPR_GPR7_GPR_chd1_en_pwrupload_ldo_usb_1p0_SHIFT 3 +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_MASK 0x30u +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_SHIFT 4 +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_SHIFT))&IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_MASK) +#define IOMUXC_GPR_GPR7_GPR_chd2_pwd_ldo_usb_1p0_MASK 0x40u +#define IOMUXC_GPR_GPR7_GPR_chd2_pwd_ldo_usb_1p0_SHIFT 6 +#define IOMUXC_GPR_GPR7_GPR_chd2_lowpwr_ldo_usb_1p0_MASK 0x80u +#define IOMUXC_GPR_GPR7_GPR_chd2_lowpwr_ldo_usb_1p0_SHIFT 7 +#define IOMUXC_GPR_GPR7_GPR_chd2_en_ilimit_ldo_usb_1p0_MASK 0x100u +#define IOMUXC_GPR_GPR7_GPR_chd2_en_ilimit_ldo_usb_1p0_SHIFT 8 +#define IOMUXC_GPR_GPR7_GPR_chd2_en_pwrupload_ldo_usb_1p0_MASK 0x200u +#define IOMUXC_GPR_GPR7_GPR_chd2_en_pwrupload_ldo_usb_1p0_SHIFT 9 +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_MASK 0xC00u +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_SHIFT 10 +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_SHIFT))&IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_MASK) +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_lnkrst_disable_MASK 0x1000u +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_lnkrst_disable_SHIFT 12 +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_perst_disable_MASK 0x2000u +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_perst_disable_SHIFT 13 +/* GPR8 Bit Fields */ +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_MASK 0xF8u +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_SHIFT 3 +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_SHIFT))&IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_MASK) +#define IOMUXC_GPR_GPR8_ddr_phy_dfi_init_start_MASK 0x100u +#define IOMUXC_GPR_GPR8_ddr_phy_dfi_init_start_SHIFT 8 +/* GPR9 Bit Fields */ +#define IOMUXC_GPR_GPR9_GPR_TZASC1_MUX_CONTROL_MASK 0x1u +#define IOMUXC_GPR_GPR9_GPR_TZASC1_MUX_CONTROL_SHIFT 0 +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_MASK 0x3Eu +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_SHIFT 1 +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_SHIFT))&IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_MASK) +/* GPR10 Bit Fields */ +#define IOMUXC_GPR_GPR10_GPR0_BF0_MASK 0x1u +#define IOMUXC_GPR_GPR10_GPR0_BF0_SHIFT 0 +#define IOMUXC_GPR_GPR10_GPR_DBG_EN_MASK 0x2u +#define IOMUXC_GPR_GPR10_GPR_DBG_EN_SHIFT 1 +#define IOMUXC_GPR_GPR10_GPR_SEC_ERR_RESP_EN_MASK 0x4u +#define IOMUXC_GPR_GPR10_GPR_SEC_ERR_RESP_EN_SHIFT 2 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION0_MASK 0x8u +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION0_SHIFT 3 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_MASK 0x3F0u +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_SHIFT 4 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_MASK) +/* GPR11 Bit Fields */ +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION0_MASK 0x1u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION0_SHIFT 0 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_MASK 0x3Eu +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_SHIFT 1 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_MASK) +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION0_MASK 0x40u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION0_SHIFT 6 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_MASK 0x380u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_SHIFT 7 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_MASK) +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION0_MASK 0x400u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION0_SHIFT 10 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_MASK 0x3800u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_SHIFT 11 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_MASK) +/* GPR12 Bit Fields */ +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_REG_RST_CH0_MASK 0x1u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_REG_RST_CH0_SHIFT 0 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_RST_CH0_MASK 0x2u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_RST_CH0_SHIFT 1 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_SSC_EN_MASK 0x8u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_SSC_EN_SHIFT 3 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_CMN_REG_RST_MASK 0x10u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_CMN_REG_RST_SHIFT 4 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_REFCLK_SEL_MASK 0x20u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_REFCLK_SEL_SHIFT 5 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_MASK 0xF000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_SHIFT 12 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_MASK) +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_MASK 0x1E0000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_SHIFT 17 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_MASK) +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_MASK 0xE00000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_SHIFT 21 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_MASK) +/* GPR13 Bit Fields */ +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_USDHC_MASK 0x1u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_USDHC_SHIFT 0 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_USDHC_MASK 0x2u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_USDHC_SHIFT 1 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_MASK 0x4u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_SHIFT 2 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_MASK 0x8u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_SHIFT 3 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_MASK 0x10u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_SHIFT 4 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_MASK 0x20u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_SHIFT 5 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_MASK 0x40u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_SHIFT 6 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_MASK 0x80u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_SHIFT 7 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_EN_MASK 0x100u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_EN_SHIFT 8 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_EN_MASK 0x200u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_EN_SHIFT 9 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_EN_MASK 0x400u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_EN_SHIFT 10 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_EN_MASK 0x800u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_EN_SHIFT 11 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_EN_MASK 0x1000u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_EN_SHIFT 12 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_EN_MASK 0x2000u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_EN_SHIFT 13 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_MASK 0x4000u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_SHIFT 14 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_EN_MASK 0x8000u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_EN_SHIFT 15 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_MASK 0xFF0000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_SHIFT 16 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_SHIFT))&IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_MASK) +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_MASK 0xF000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_SHIFT 24 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_SHIFT))&IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_MASK) +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_CDR_LOCKED_CH0_MASK 0x10000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_CDR_LOCKED_CH0_SHIFT 28 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_RX_PRESENT_CH0_MASK 0x20000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_RX_PRESENT_CH0_SHIFT 29 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_CDR_VCO_MON_CH0_MASK 0x40000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_CDR_VCO_MON_CH0_SHIFT 30 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PCS_REFCLK_DISABLE_MASK 0x80000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PCS_REFCLK_DISABLE_SHIFT 31 +/* GPR14 Bit Fields */ +#define IOMUXC_GPR_GPR14_GPR_SIM1_SIMV2_EMV_SEL_MASK 0x1u +#define IOMUXC_GPR_GPR14_GPR_SIM1_SIMV2_EMV_SEL_SHIFT 0 +#define IOMUXC_GPR_GPR14_GPR_SIM2_SIMV2_EMV_SEL_MASK 0x2u +#define IOMUXC_GPR_GPR14_GPR_SIM2_SIMV2_EMV_SEL_SHIFT 1 +/* GPR15 Bit Fields */ +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_VBLK_FLAG_MASK 0x1u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_VBLK_FLAG_SHIFT 0 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_AUTO_SEL_MASK 0x2u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_AUTO_SEL_SHIFT 1 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_MASK 0x3FFCu +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_SHIFT 2 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_SHIFT))&IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_MASK) +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_MASK 0x3F0000u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_SHIFT 16 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_SHIFT))&IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_MASK) +/* GPR16 Bit Fields */ +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_MASK 0x3u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_SHIFT 0 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_SEL_DATABF_MASK 0x4u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SEL_DATABF_SHIFT 2 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNTB_TDLY_MASK 0x8u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNTB_TDLY_SHIFT 3 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_EN_H_MASK 0x10u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_EN_H_SHIFT 4 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEWINI_MASK 0x20u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEWINI_SHIFT 5 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_MASK 0x3C0u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_SHIFT 6 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_AUTO_DSK_SEL_MASK 0x400u +#define IOMUXC_GPR_GPR16_GPR_LVDS_AUTO_DSK_SEL_SHIFT 10 +#define IOMUXC_GPR_GPR16_GPR_LVDS_LOCK_CNT_MASK 0x800u +#define IOMUXC_GPR_GPR16_GPR_LVDS_LOCK_CNT_SHIFT 11 +#define IOMUXC_GPR_GPR16_GPR_LVDS_OUTCON_MASK 0x1000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_OUTCON_SHIFT 12 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_MASK 0xE000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_SHIFT 13 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_SRC_TRH_MASK 0x10000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SRC_TRH_SHIFT 16 +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_HIGH_S_MASK 0x20000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_HIGH_S_SHIFT 17 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_MASK 0x180000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_SHIFT 19 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_MODE_SEL_MASK 0x200000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_MODE_SEL_SHIFT 21 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FLT_CNT_MASK 0x400000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_FLT_CNT_SHIFT 22 +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_ONLY_CNT_MASK 0x800000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_ONLY_CNT_SHIFT 23 +/* GPR17 Bit Fields */ +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_MASK 0xFFu +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_SHIFT 0 +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_SHIFT))&IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_MASK) +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_MASK 0xFF00u +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_SHIFT 8 +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_SHIFT))&IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_MASK) +/* GPR18 Bit Fields */ +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_MASK 0x7u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_SHIFT 0 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_MASK 0x18u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_SHIFT 3 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_MASK 0x60u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_SHIFT 5 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_MASK 0x3F00u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_SHIFT 8 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_FORCE_ERROR_MASK 0x4000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_FORCE_ERROR_SHIFT 14 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_MASK 0x7F0000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_SHIFT 16 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_MASK 0x3000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_SHIFT 24 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_EN_MASK 0x4000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_EN_SHIFT 26 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_RESETB_MASK 0x8000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_RESETB_SHIFT 27 +#define IOMUXC_GPR_GPR18_GPR_LVDS_DLYS_BST_MASK 0x10000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_DLYS_BST_SHIFT 28 +#define IOMUXC_GPR_GPR18_GPR_LVDS_SKINI_BST_MASK 0x20000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_SKINI_BST_SHIFT 29 +/* GPR19 Bit Fields */ +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_STATUS_MASK 0x1u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_STATUS_SHIFT 0 +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_MASK 0xFF00u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_SHIFT 8 +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_SHIFT))&IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_MASK) +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_SYNC_MASK 0x10000u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_SYNC_SHIFT 16 +#define IOMUXC_GPR_GPR19_GPR_LVDS_MON_FOR_CNNCT_MASK 0x20000u +#define IOMUXC_GPR_GPR19_GPR_LVDS_MON_FOR_CNNCT_SHIFT 17 +/* GPR20 Bit Fields */ +#define IOMUXC_GPR_GPR20_GPR_LVDS_P_MASK 0x3Fu +#define IOMUXC_GPR_GPR20_GPR_LVDS_P_SHIFT 0 +#define IOMUXC_GPR_GPR20_GPR_LVDS_P(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_P_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_P_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_M_MASK 0x3F00u +#define IOMUXC_GPR_GPR20_GPR_LVDS_M_SHIFT 8 +#define IOMUXC_GPR_GPR20_GPR_LVDS_M(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_M_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_M_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_S_MASK 0x30000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_S_SHIFT 16 +#define IOMUXC_GPR_GPR20_GPR_LVDS_S(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_S_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_S_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_VSEL_MASK 0x1000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_VSEL_SHIFT 24 +#define IOMUXC_GPR_GPR20_GPR_LVDS_CK_POL_SEL_MASK 0x2000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_CK_POL_SEL_SHIFT 25 +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_MASK 0x38000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_SHIFT 27 +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_MASK) +/* GPR21 Bit Fields */ +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_MASK 0x7u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_SHIFT 0 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_MASK 0x38u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_SHIFT 3 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_MASK 0x1C0u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_SHIFT 6 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_MASK 0xE00u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_SHIFT 9 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_MASK 0x7000u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_SHIFT 12 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_MASK 0x38000u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_SHIFT 15 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_MASK) +#define IOMUXC_GPR_GPR21_SJC_BYPASS_CJTAGC_MASK 0x40000u +#define IOMUXC_GPR_GPR21_SJC_BYPASS_CJTAGC_SHIFT 18 +#define IOMUXC_GPR_GPR21_DAP_BYPASS_CJTAGC_MASK 0x80000u +#define IOMUXC_GPR_GPR21_DAP_BYPASS_CJTAGC_SHIFT 19 +/* GPR22 Bit Fields */ +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out_MASK 0xFF0000u +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out_SHIFT 16 +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR22_ddrc_mrr_data_out_SHIFT))&IOMUXC_GPR_GPR22_ddrc_mrr_data_out_MASK) +#define IOMUXC_GPR_GPR22_ddrc_mrr_valid_out_MASK 0x1000000u +#define IOMUXC_GPR_GPR22_ddrc_mrr_valid_out_SHIFT 24 +#define IOMUXC_GPR_GPR22_ddr_phy_dfi_init_complete_MASK 0x2000000u +#define IOMUXC_GPR_GPR22_ddr_phy_dfi_init_complete_SHIFT 25 +#define IOMUXC_GPR_GPR22_GPR_chd2_dvdd_usb_stable_MASK 0x4000000u +#define IOMUXC_GPR_GPR22_GPR_chd2_dvdd_usb_stable_SHIFT 26 +#define IOMUXC_GPR_GPR22_aux_chrg_det_2_usb_iso_enable_1_MASK 0x8000000u +#define IOMUXC_GPR_GPR22_aux_chrg_det_2_usb_iso_enable_1_SHIFT 27 +#define IOMUXC_GPR_GPR22_GPR_chd1_dvdd_usb_stable_MASK 0x10000000u +#define IOMUXC_GPR_GPR22_GPR_chd1_dvdd_usb_stable_SHIFT 28 +#define IOMUXC_GPR_GPR22_aux_chrg_det_1_usb_iso_enable_1_MASK 0x20000000u +#define IOMUXC_GPR_GPR22_aux_chrg_det_1_usb_iso_enable_1_SHIFT 29 +#define IOMUXC_GPR_GPR22_GPR_PCIE_PHY_PLL_LOCKED_MASK 0x80000000u +#define IOMUXC_GPR_GPR22_GPR_PCIE_PHY_PLL_LOCKED_SHIFT 31 + +#define IMX7D_GPR5_CSI1_MUX_CTRL_MASK (0x1 << 4) +#define IMX7D_GPR5_CSI1_MUX_CTRL_PARALLEL_CSI (0x0 << 4) +#define IMX7D_GPR5_CSI1_MUX_CTRL_MIPI_CSI (0x1 << 4) + +struct iomuxc { + u32 gpr[23]; + /* mux and pad registers */ +}; + +struct iomuxc_gpr_base_regs { + u32 gpr[23]; /* 0x000 */ +}; + +/* ECSPI registers */ +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 cfg; + u32 intr; + u32 dma; + u32 stat; + u32 period; +}; + +/* + * CSPI register definitions + */ +#define MXC_ECSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_MODE_MASK (0xf << 4) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 32 + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_PHA 0 /* SCLK phase control */ +#define MXC_CSPICON_POL 4 /* SCLK polarity */ +#define MXC_CSPICON_SSPOL 12 /* SS polarity */ +#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ + +#define MXC_SPI_BASE_ADDRESSES \ + ECSPI1_BASE_ADDR, \ + ECSPI2_BASE_ADDR, \ + ECSPI3_BASE_ADDR, \ + ECSPI4_BASE_ADDR + +struct ocotp_regs { + u32 ctrl; + u32 ctrl_set; + u32 ctrl_clr; + u32 ctrl_tog; + u32 timing; + u32 rsvd0[3]; + u32 data0; + u32 rsvd1[3]; + u32 data1; + u32 rsvd2[3]; + u32 data2; + u32 rsvd3[3]; + u32 data3; + u32 rsvd4[3]; + u32 read_ctrl; + u32 rsvd5[3]; + u32 read_fuse_data0; + u32 rsvd6[3]; + u32 read_fuse_data1; + u32 rsvd7[3]; + u32 read_fuse_data2; + u32 rsvd8[3]; + u32 read_fuse_data3; + u32 rsvd9[3]; + u32 sw_sticky; + u32 rsvd10[3]; + u32 scs; + u32 scs_set; + u32 scs_clr; + u32 scs_tog; + u32 crc_addr; + u32 rsvd11[3]; + u32 crc_value; + u32 rsvd12[3]; + u32 version; + u32 rsvd13[0xc3]; + + struct fuse_bank { /* offset 0x400 */ + u32 fuse_regs[0x10]; + } bank[16]; +}; + +struct fuse_bank0_regs { + u32 lock; + u32 rsvd0[3]; + u32 tester0; + u32 rsvd1[3]; + u32 tester1; + u32 rsvd2[3]; + u32 tester2; + u32 rsvd3[3]; +}; + +struct fuse_bank1_regs { + u32 tester3; + u32 rsvd0[3]; + u32 tester4; + u32 rsvd1[3]; + u32 tester5; + u32 rsvd2[3]; + u32 cfg0; + u32 rsvd3[3]; +}; + +struct fuse_bank2_regs { + u32 cfg1; + u32 rsvd0[3]; + u32 cfg2; + u32 rsvd1[3]; + u32 cfg3; + u32 rsvd2[3]; + u32 cfg4; + u32 rsvd3[3]; +}; + +struct fuse_bank3_regs { + u32 mem_trim0; + u32 rsvd0[3]; + u32 mem_trim1; + u32 rsvd1[3]; + u32 ana0; + u32 rsvd2[3]; + u32 ana1; + u32 rsvd3[3]; +}; + +struct fuse_bank8_regs { + u32 sjc_resp_low; + u32 rsvd0[3]; + u32 sjc_resp_high; + u32 rsvd1[3]; + u32 usb_id; + u32 rsvd2[3]; + u32 field_return; + u32 rsvd3[3]; +}; + +struct fuse_bank9_regs { + u32 mac_addr0; + u32 rsvd0[3]; + u32 mac_addr1; + u32 rsvd1[3]; + u32 mac_addr2; + u32 rsvd2[7]; +}; + +struct aipstz_regs { + u32 mprot0; + u32 mprot1; + u32 rsvd[0xe]; + u32 opacr0; + u32 opacr1; + u32 opacr2; + u32 opacr3; + u32 opacr4; +}; + +struct wdog_regs { + u16 wcr; /* Control */ + u16 wsr; /* Service */ + u16 wrsr; /* Reset Status */ + u16 wicr; /* Interrupt Control */ + u16 wmcr; /* Miscellaneous Control */ +}; + +struct dbg_monitor_regs { + u32 ctrl[4]; /* Control */ + u32 master_en[4]; /* Master enable */ + u32 irq[4]; /* IRQ */ + u32 trap_addr_low[4]; /* Trap address low */ + u32 trap_addr_high[4]; /* Trap address high */ + u32 trap_id[4]; /* Trap ID */ + u32 snvs_addr[4]; /* SNVS address */ + u32 snvs_data[4]; /* SNVS data */ + u32 snvs_info[4]; /* SNVS info */ + u32 version[4]; /* Version */ +}; + +struct rdc_regs { + u32 vir; /* Version information */ + u32 reserved1[8]; + u32 stat; /* Status */ + u32 intctrl; /* Interrupt and Control */ + u32 intstat; /* Interrupt Status */ + u32 reserved2[116]; + u32 mda[27]; /* Master Domain Assignment */ + u32 reserved3[101]; + u32 pdap[118]; /* Peripheral Domain Access Permissions */ + u32 reserved4[138]; + struct { + u32 mrsa; /* Memory Region Start Address */ + u32 mrea; /* Memory Region End Address */ + u32 mrc; /* Memory Region Control */ + u32 mrvs; /* Memory Region Violation Status */ + } mem_region[52]; +}; + +struct rdc_sema_regs { + u8 gate[64]; /* Gate */ + u16 rstgt; /* Reset Gate */ +}; + +/* eLCDIF controller registers */ +struct mxs_lcdif_regs { + u32 hw_lcdif_ctrl; /* 0x00 */ + u32 hw_lcdif_ctrl_set; + u32 hw_lcdif_ctrl_clr; + u32 hw_lcdif_ctrl_tog; + u32 hw_lcdif_ctrl1; /* 0x10 */ + u32 hw_lcdif_ctrl1_set; + u32 hw_lcdif_ctrl1_clr; + u32 hw_lcdif_ctrl1_tog; + u32 hw_lcdif_ctrl2; /* 0x20 */ + u32 hw_lcdif_ctrl2_set; + u32 hw_lcdif_ctrl2_clr; + u32 hw_lcdif_ctrl2_tog; + u32 hw_lcdif_transfer_count; /* 0x30 */ + u32 reserved1[3]; + u32 hw_lcdif_cur_buf; /* 0x40 */ + u32 reserved2[3]; + u32 hw_lcdif_next_buf; /* 0x50 */ + u32 reserved3[3]; + u32 hw_lcdif_timing; /* 0x60 */ + u32 reserved4[3]; + u32 hw_lcdif_vdctrl0; /* 0x70 */ + u32 hw_lcdif_vdctrl0_set; + u32 hw_lcdif_vdctrl0_clr; + u32 hw_lcdif_vdctrl0_tog; + u32 hw_lcdif_vdctrl1; /* 0x80 */ + u32 reserved5[3]; + u32 hw_lcdif_vdctrl2; /* 0x90 */ + u32 reserved6[3]; + u32 hw_lcdif_vdctrl3; /* 0xa0 */ + u32 reserved7[3]; + u32 hw_lcdif_vdctrl4; /* 0xb0 */ + u32 reserved8[3]; + u32 hw_lcdif_dvictrl0; /* 0xc0 */ + u32 reserved9[3]; + u32 hw_lcdif_dvictrl1; /* 0xd0 */ + u32 reserved10[3]; + u32 hw_lcdif_dvictrl2; /* 0xe0 */ + u32 reserved11[3]; + u32 hw_lcdif_dvictrl3; /* 0xf0 */ + u32 reserved12[3]; + u32 hw_lcdif_dvictrl4; /* 0x100 */ + u32 reserved13[3]; + u32 hw_lcdif_csc_coeffctrl0; /* 0x110 */ + u32 reserved14[3]; + u32 hw_lcdif_csc_coeffctrl1; /* 0x120 */ + u32 reserved15[3]; + u32 hw_lcdif_csc_coeffctrl2; /* 0x130 */ + u32 reserved16[3]; + u32 hw_lcdif_csc_coeffctrl3; /* 0x140 */ + u32 reserved17[3]; + u32 hw_lcdif_csc_coeffctrl4; /* 0x150 */ + u32 reserved18[3]; + u32 hw_lcdif_csc_offset; /* 0x160 */ + u32 reserved19[3]; + u32 hw_lcdif_csc_limit; /* 0x170 */ + u32 reserved20[3]; + u32 hw_lcdif_data; /* 0x180 */ + u32 reserved21[3]; + u32 hw_lcdif_bm_error_stat; /* 0x190 */ + u32 reserved22[3]; + u32 hw_lcdif_crc_stat; /* 0x1a0 */ + u32 reserved23[3]; + u32 hw_lcdif_lcdif_stat; /* 0x1b0 */ + u32 reserved24[3]; + u32 hw_lcdif_version; /* 0x1c0 */ + u32 reserved25[3]; + u32 hw_lcdif_debug0; /* 0x1d0 */ + u32 reserved26[3]; + u32 hw_lcdif_debug1; /* 0x1e0 */ + u32 reserved27[3]; + u32 hw_lcdif_debug2; /* 0x1f0 */ + u32 reserved28[3]; + u32 hw_lcdif_thres; /* 0x200 */ + u32 reserved29[3]; + u32 hw_lcdif_as_ctrl; /* 0x210 */ + u32 reserved30[3]; + u32 hw_lcdif_as_buf; /* 0x220 */ + u32 reserved31[3]; + u32 hw_lcdif_as_next_buf; /* 0x230 */ + u32 reserved32[3]; + u32 hw_lcdif_as_clrkeylow; /* 0x240 */ + u32 reserved33[3]; + u32 hw_lcdif_as_clrkeyhigh; /* 0x250 */ + u32 reserved34[3]; + u32 hw_lcdif_as_sync_delay; /* 0x260 */ + u32 reserved35[3]; + u32 hw_lcdif_as_debug3; /* 0x270 */ + u32 reserved36[3]; + u32 hw_lcdif_as_debug4; /* 0x280 */ + u32 reserved37[3]; + u32 hw_lcdif_as_debug5; /* 0x290 */ +}; + +#define MXS_LCDIF_BASE ELCDIF1_IPS_BASE_ADDR + +#define LCDIF_CTRL_SFTRST (1 << 31) +#define LCDIF_CTRL_CLKGATE (1 << 30) +#define LCDIF_CTRL_YCBCR422_INPUT (1 << 29) +#define LCDIF_CTRL_READ_WRITEB (1 << 28) +#define LCDIF_CTRL_WAIT_FOR_VSYNC_EDGE (1 << 27) +#define LCDIF_CTRL_DATA_SHIFT_DIR (1 << 26) +#define LCDIF_CTRL_SHIFT_NUM_BITS_MASK (0x1f << 21) +#define LCDIF_CTRL_SHIFT_NUM_BITS_OFFSET 21 +#define LCDIF_CTRL_DVI_MODE (1 << 20) +#define LCDIF_CTRL_BYPASS_COUNT (1 << 19) +#define LCDIF_CTRL_VSYNC_MODE (1 << 18) +#define LCDIF_CTRL_DOTCLK_MODE (1 << 17) +#define LCDIF_CTRL_DATA_SELECT (1 << 16) +#define LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK (0x3 << 14) +#define LCDIF_CTRL_INPUT_DATA_SWIZZLE_OFFSET 14 +#define LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK (0x3 << 12) +#define LCDIF_CTRL_CSC_DATA_SWIZZLE_OFFSET 12 +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK (0x3 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_OFFSET 10 +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_16BIT (0 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_8BIT (1 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_18BIT (2 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_24BIT (3 << 10) +#define LCDIF_CTRL_WORD_LENGTH_MASK (0x3 << 8) +#define LCDIF_CTRL_WORD_LENGTH_OFFSET 8 +#define LCDIF_CTRL_WORD_LENGTH_16BIT (0 << 8) +#define LCDIF_CTRL_WORD_LENGTH_8BIT (1 << 8) +#define LCDIF_CTRL_WORD_LENGTH_18BIT (2 << 8) +#define LCDIF_CTRL_WORD_LENGTH_24BIT (3 << 8) +#define LCDIF_CTRL_RGB_TO_YCBCR422_CSC (1 << 7) +#define LCDIF_CTRL_LCDIF_MASTER (1 << 5) +#define LCDIF_CTRL_DATA_FORMAT_16_BIT (1 << 3) +#define LCDIF_CTRL_DATA_FORMAT_18_BIT (1 << 2) +#define LCDIF_CTRL_DATA_FORMAT_24_BIT (1 << 1) +#define LCDIF_CTRL_RUN (1 << 0) + +#define LCDIF_CTRL1_COMBINE_MPU_WR_STRB (1 << 27) +#define LCDIF_CTRL1_BM_ERROR_IRQ_EN (1 << 26) +#define LCDIF_CTRL1_BM_ERROR_IRQ (1 << 25) +#define LCDIF_CTRL1_RECOVER_ON_UNDERFLOW (1 << 24) +#define LCDIF_CTRL1_INTERLACE_FIELDS (1 << 23) +#define LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD (1 << 22) +#define LCDIF_CTRL1_FIFO_CLEAR (1 << 21) +#define LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS (1 << 20) +#define LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK (0xf << 16) +#define LCDIF_CTRL1_BYTE_PACKING_FORMAT_OFFSET 16 +#define LCDIF_CTRL1_OVERFLOW_IRQ_EN (1 << 15) +#define LCDIF_CTRL1_UNDERFLOW_IRQ_EN (1 << 14) +#define LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN (1 << 13) +#define LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN (1 << 12) +#define LCDIF_CTRL1_OVERFLOW_IRQ (1 << 11) +#define LCDIF_CTRL1_UNDERFLOW_IRQ (1 << 10) +#define LCDIF_CTRL1_CUR_FRAME_DONE_IRQ (1 << 9) +#define LCDIF_CTRL1_VSYNC_EDGE_IRQ (1 << 8) +#define LCDIF_CTRL1_BUSY_ENABLE (1 << 2) +#define LCDIF_CTRL1_MODE86 (1 << 1) +#define LCDIF_CTRL1_RESET (1 << 0) + +#define LCDIF_CTRL2_OUTSTANDING_REQS_MASK (0x7 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_OFFSET 21 +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_1 (0x0 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_2 (0x1 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_4 (0x2 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_8 (0x3 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_16 (0x4 << 21) +#define LCDIF_CTRL2_BURST_LEN_8 (1 << 20) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_MASK (0x7 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_OFFSET 16 +#define LCDIF_CTRL2_ODD_LINE_PATTERN_RGB (0x0 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_RBG (0x1 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_GBR (0x2 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_GRB (0x3 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_BRG (0x4 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_BGR (0x5 << 16) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK (0x7 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_OFFSET 12 +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_RGB (0x0 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_RBG (0x1 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_GBR (0x2 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_GRB (0x3 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_BRG (0x4 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_BGR (0x5 << 12) +#define LCDIF_CTRL2_READ_PACK_DIR (1 << 10) +#define LCDIF_CTRL2_READ_MODE_OUTPUT_IN_RGB_FORMAT (1 << 9) +#define LCDIF_CTRL2_READ_MODE_6_BIT_INPUT (1 << 8) +#define LCDIF_CTRL2_READ_MODE_NUM_PACKED_SUBWORDS_MASK (0x7 << 4) +#define LCDIF_CTRL2_READ_MODE_NUM_PACKED_SUBWORDS_OFFSET 4 +#define LCDIF_CTRL2_INITIAL_DUMMY_READ_MASK (0x7 << 1) +#define LCDIF_CTRL2_INITIAL_DUMMY_READ_OFFSET 1 + +#define LCDIF_TRANSFER_COUNT_V_COUNT_MASK (0xffff << 16) +#define LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET 16 +#define LCDIF_TRANSFER_COUNT_H_COUNT_MASK (0xffff << 0) +#define LCDIF_TRANSFER_COUNT_H_COUNT_OFFSET 0 + +#define LCDIF_CUR_BUF_ADDR_MASK 0xffffffff +#define LCDIF_CUR_BUF_ADDR_OFFSET 0 + +#define LCDIF_NEXT_BUF_ADDR_MASK 0xffffffff +#define LCDIF_NEXT_BUF_ADDR_OFFSET 0 + +#define LCDIF_TIMING_CMD_HOLD_MASK (0xff << 24) +#define LCDIF_TIMING_CMD_HOLD_OFFSET 24 +#define LCDIF_TIMING_CMD_SETUP_MASK (0xff << 16) +#define LCDIF_TIMING_CMD_SETUP_OFFSET 16 +#define LCDIF_TIMING_DATA_HOLD_MASK (0xff << 8) +#define LCDIF_TIMING_DATA_HOLD_OFFSET 8 +#define LCDIF_TIMING_DATA_SETUP_MASK (0xff << 0) +#define LCDIF_TIMING_DATA_SETUP_OFFSET 0 + +#define LCDIF_VDCTRL0_VSYNC_OEB (1 << 29) +#define LCDIF_VDCTRL0_ENABLE_PRESENT (1 << 28) +#define LCDIF_VDCTRL0_VSYNC_POL (1 << 27) +#define LCDIF_VDCTRL0_HSYNC_POL (1 << 26) +#define LCDIF_VDCTRL0_DOTCLK_POL (1 << 25) +#define LCDIF_VDCTRL0_ENABLE_POL (1 << 24) +#define LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT (1 << 21) +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT (1 << 20) +#define LCDIF_VDCTRL0_HALF_LINE (1 << 19) +#define LCDIF_VDCTRL0_HALF_LINE_MODE (1 << 18) +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK 0x3ffff +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_OFFSET 0 + +#define LCDIF_VDCTRL1_VSYNC_PERIOD_MASK 0xffffffff +#define LCDIF_VDCTRL1_VSYNC_PERIOD_OFFSET 0 + +#define LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_MASK (0x3fff << 18) +#define LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_OFFSET 18 +#define LCDIF_VDCTRL2_HSYNC_PERIOD_MASK 0x3ffff +#define LCDIF_VDCTRL2_HSYNC_PERIOD_OFFSET 0 + +#define LCDIF_VDCTRL3_MUX_SYNC_SIGNALS (1 << 29) +#define LCDIF_VDCTRL3_VSYNC_ONLY (1 << 28) +#define LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK (0xfff << 16) +#define LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_OFFSET 16 +#define LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK (0xffff << 0) +#define LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_OFFSET 0 + +#define LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK (0x7 << 29) +#define LCDIF_VDCTRL4_DOTCLK_DLY_SEL_OFFSET 29 +#define LCDIF_VDCTRL4_SYNC_SIGNALS_ON (1 << 18) +#define LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK 0x3ffff +#define LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_OFFSET 0 + + +extern void check_cpu_temperature(void); + +extern void pcie_power_up(void); +extern void pcie_power_off(void); + +/* If ROM fail back to USB recover mode, USBPH0_PWD will be clear to use USB + * If boot from the other mode, USB0_PWD will keep reset value + */ +#define is_boot_from_usb(void) (readl(USBOTG1_IPS_BASE_ADDR + 0x158) || \ + readl(USBOTG2_IPS_BASE_ADDR + 0x158)) +#define disconnect_from_pc(void) writel(0x0, USBOTG1_IPS_BASE_ADDR + 0x140) + +/* Boot device type */ +#define BOOT_TYPE_SD 0x1 +#define BOOT_TYPE_MMC 0x2 +#define BOOT_TYPE_NAND 0x3 +#define BOOT_TYPE_QSPI 0x4 +#define BOOT_TYPE_WEIM 0x5 +#define BOOT_TYPE_SPINOR 0x6 + +struct bootrom_sw_info { + u8 reserved_1; + u8 boot_dev_instance; + u8 boot_dev_type; + u8 reserved_2; + u32 arm_core_freq; + u32 axi_freq; + u32 ddr_freq; + u32 gpt1_freq; + u32 reserved_3[3]; +}; + +#endif /* __ASSEMBLER__*/ +#endif /* __ASM_ARCH_MX7_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mx7/sys_proto.h b/arch/arm/include/asm/arch-mx7/sys_proto.h new file mode 100644 index 0000000..b5533d0 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/sys_proto.h @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +#include <asm/imx-common/regs-common.h> +#include "../arch-imx/cpu.h" + +#define is_soc_rev(rev) ((int)((get_cpu_rev() & 0xFF) - rev)) +u32 get_cpu_rev(void); + +/* returns MXC_CPU_ value */ +#define cpu_type(rev) (((rev) >> 12)&0xff) + +/* use with MXC_CPU_ constants */ +#define is_cpu_type(cpu) (cpu_type(get_cpu_rev()) == cpu) + +const char *get_imx_type(u32 imxtype); +unsigned imx_ddr_size(void); +void set_wdog_reset(struct wdog_regs *wdog); + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ + +int fecmxc_initialize(bd_t *bis); +u32 get_ahb_clk(void); +u32 get_periph_clk(void); + +int mxs_reset_block(struct mxs_register_32 *reg); +int mxs_wait_mask_set(struct mxs_register_32 *reg, + uint32_t mask, + unsigned int timeout); +int mxs_wait_mask_clr(struct mxs_register_32 *reg, + uint32_t mask, + unsigned int timeout); +#endif
* Add Clock control module (CCM) support * iMX7D SoC introduces 3 main clock sysmtem abstraction for clock root frequency generation denominated clock slices. Core clock slice: hihg speed clock for ARM core Bus clock slice: for bus clocks IP clock slice: Peripheral clocks * At system boot ROM enables PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET In u-boot, we have to: - Configure PFD3- PFD7 for freq we needed in u-boot - Set clock root for peripherals (ip channel)
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Split from patch imx: imx7d: initial arch level support Changes for V3: Resend
arch/arm/cpu/armv7/mx7/clock.c | 1130 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/clock_slice.c | 757 ++++++++++++++++++ arch/arm/include/asm/arch-mx7/clock.h | 348 +++++++++ arch/arm/include/asm/arch-mx7/clock_slice.h | 116 +++ 4 files changed, 2351 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/clock.c create mode 100644 arch/arm/cpu/armv7/mx7/clock_slice.c create mode 100644 arch/arm/include/asm/arch-mx7/clock.h create mode 100644 arch/arm/include/asm/arch-mx7/clock_slice.h
diff --git a/arch/arm/cpu/armv7/mx7/clock.c b/arch/arm/cpu/armv7/mx7/clock.c new file mode 100644 index 0000000..fe92de9 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/clock.c @@ -0,0 +1,1130 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; +struct mxc_ccm_reg *ccm_reg = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + +#ifdef CONFIG_FSL_ESDHC +DECLARE_GLOBAL_DATA_PTR; +#endif + +int get_clocks(void) +{ +#ifdef CONFIG_FSL_ESDHC +#if CONFIG_SYS_FSL_ESDHC_ADDR == USDHC2_BASE_ADDR + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); +#elif CONFIG_SYS_FSL_ESDHC_ADDR == USDHC3_BASE_ADDR + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); +#else + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); +#endif +#endif + return 0; +} + +u32 get_ahb_clk(void) +{ + return get_root_clk(AHB_CLK_ROOT); +} + +static u32 get_ipg_clk(void) +{ + /* + * The AHB and IPG are fixed at 2:1 ratio, and synchronized to + * each other. + */ + return get_ahb_clk() / 2; +} + +u32 imx_get_uartclk(void) +{ + return get_root_clk(UART1_CLK_ROOT); +} + +u32 imx_get_fecclk(void) +{ + return get_root_clk(ENET_AXI_CLK_ROOT); +} + +#ifdef CONFIG_MXC_OCOTP +void enable_ocotp_clk(unsigned char enable) +{ + clock_enable(CCGR_OCOTP, enable); +} + +void enable_thermal_clk(void) +{ + enable_ocotp_clk(1); +} +#endif + +void enable_usboh3_clk(unsigned char enable) +{ + u32 target; + + if (enable) { + /* disable the clock gate first */ + clock_enable(CCGR_USB_HSIC, 0); + + /* 120Mhz */ + target = CLK_ROOT_ON | USB_HSIC_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(USB_HSIC_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_USB_CTRL, 1); + clock_enable(CCGR_USB_HSIC, 1); + clock_enable(CCGR_USB_PHY1, 1); + clock_enable(CCGR_USB_PHY2, 1); + } else { + clock_enable(CCGR_USB_CTRL, 0); + clock_enable(CCGR_USB_HSIC, 0); + clock_enable(CCGR_USB_PHY1, 0); + clock_enable(CCGR_USB_PHY2, 0); + } + +} + +static u32 decode_pll(enum pll_clocks pll, u32 infreq) +{ + u32 reg, div_sel; + u32 num, denom; + + /* + * Alought there are four choices for the bypass src, + * we choose OSC_24M which is the default set in ROM. + */ + switch (pll) { + case PLL_CORE: + reg = readl(&ccm_anatop->pll_arm); + + if (reg & CCM_ANALOG_PLL_ARM_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_ARM_BYPASS_MASK) + return MXC_HCLK; + + div_sel = (reg & CCM_ANALOG_PLL_ARM_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_ARM_DIV_SELECT_SHIFT; + + return (infreq * div_sel) / 2; + + case PLL_SYS: + reg = readl(&ccm_anatop->pll_480); + + if (reg & CCM_ANALOG_PLL_480_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_480_BYPASS_MASK) + return MXC_HCLK; + + if (((reg & CCM_ANALOG_PLL_480_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_480_DIV_SELECT_SHIFT) == 0) + return 480000000u; + else + return 528000000u; + + case PLL_ENET: + reg = readl(&ccm_anatop->pll_enet); + + if (reg & CCM_ANALOG_PLL_ENET_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_ENET_BYPASS_MASK) + return MXC_HCLK; + + return 1000000000u; + + case PLL_DDR: + reg = readl(&ccm_anatop->pll_ddr); + + if (reg & CCM_ANALOG_PLL_DDR_POWERDOWN_MASK) + return 0; + + num = ccm_anatop->pll_ddr_num; + denom = ccm_anatop->pll_ddr_denom; + + if (reg & CCM_ANALOG_PLL_DDR_BYPASS_MASK) + return MXC_HCLK; + + div_sel = (reg & CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT; + + return infreq * (div_sel + num / denom); + + case PLL_USB: + return 480000000u; + + default: + printf("Unsupported pll clocks %d\n", pll); + break; + } + + return 0; +} + +static u32 mxc_get_pll_sys_derive(int derive) +{ + u32 freq, div, frac; + u32 reg; + + div = 1; + reg = readl(&ccm_anatop->pll_480); + freq = decode_pll(PLL_SYS, MXC_HCLK); + + switch (derive) { + case PLL_SYS_MAIN_480M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_MASK) + return 0; + else + return freq; + case PLL_SYS_MAIN_240M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_MASK) + return 0; + else + return freq / 2; + case PLL_SYS_MAIN_120M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_MASK) + return 0; + else + return freq / 4; + case PLL_SYS_PFD0_392M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT; + break; + case PLL_SYS_PFD0_196M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD1_332M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT; + break; + case PLL_SYS_PFD1_166M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD2_270M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT; + break; + case PLL_SYS_PFD2_135M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD3_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD3_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD3_FRAC_SHIFT; + break; + case PLL_SYS_PFD4_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD4_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD4_FRAC_SHIFT; + break; + case PLL_SYS_PFD5_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD5_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD5_FRAC_SHIFT; + break; + case PLL_SYS_PFD6_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD6_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD6_FRAC_SHIFT; + break; + case PLL_SYS_PFD7_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD7_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD7_FRAC_SHIFT; + break; + default: + printf("Error derived pll_sys clock %d\n", derive); + return 0; + } + + return ((freq / frac) * 18) / div; +} + +static u32 mxc_get_pll_enet_derive(int derive) +{ + u32 freq, reg; + + freq = decode_pll(PLL_ENET, MXC_HCLK); + reg = readl(&ccm_anatop->pll_enet); + + switch (derive) { + case PLL_ENET_MAIN_500M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK) + return freq / 2; + break; + case PLL_ENET_MAIN_250M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK) + return freq / 4; + break; + case PLL_ENET_MAIN_125M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK) + return freq / 8; + break; + case PLL_ENET_MAIN_100M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK) + return freq / 10; + break; + case PLL_ENET_MAIN_50M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK) + return freq / 20; + break; + case PLL_ENET_MAIN_40M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK) + return freq / 25; + break; + case PLL_ENET_MAIN_25M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK) + return freq / 40; + break; + default: + printf("Error derived pll_enet clock %d\n", derive); + break; + } + + return 0; +} + +static u32 mxc_get_pll_ddr_derive(int derive) +{ + u32 freq, reg; + + freq = decode_pll(PLL_DDR, MXC_HCLK); + reg = readl(&ccm_anatop->pll_ddr); + + switch (derive) { + case PLL_DRAM_MAIN_1066M_CLK: + return freq; + case PLL_DRAM_MAIN_533M_CLK: + if (reg & CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_MASK) + return freq / 2; + break; + default: + printf("Error derived pll_ddr clock %d\n", derive); + break; + } + + return 0; +} + +static u32 mxc_get_pll_derive(enum pll_clocks pll, int derive) +{ + switch (pll) { + case PLL_SYS: + return mxc_get_pll_sys_derive(derive); + case PLL_ENET: + return mxc_get_pll_enet_derive(derive); + case PLL_DDR: + return mxc_get_pll_ddr_derive(derive); + default: + printf("Error pll.\n"); + return 0; + } +} + +static u32 get_root_src_clk(enum clk_root_src root_src) +{ + switch (root_src) { + case OSC_24M_CLK: + return 24000000u; + case PLL_ARM_MAIN_800M_CLK: + return decode_pll(PLL_CORE, MXC_HCLK); + + case PLL_SYS_MAIN_480M_CLK: + case PLL_SYS_MAIN_240M_CLK: + case PLL_SYS_MAIN_120M_CLK: + case PLL_SYS_PFD0_392M_CLK: + case PLL_SYS_PFD0_196M_CLK: + case PLL_SYS_PFD1_332M_CLK: + case PLL_SYS_PFD1_166M_CLK: + case PLL_SYS_PFD2_270M_CLK: + case PLL_SYS_PFD2_135M_CLK: + case PLL_SYS_PFD3_CLK: + case PLL_SYS_PFD4_CLK: + case PLL_SYS_PFD5_CLK: + case PLL_SYS_PFD6_CLK: + case PLL_SYS_PFD7_CLK: + return mxc_get_pll_derive(PLL_SYS, root_src); + + case PLL_ENET_MAIN_500M_CLK: + case PLL_ENET_MAIN_250M_CLK: + case PLL_ENET_MAIN_125M_CLK: + case PLL_ENET_MAIN_100M_CLK: + case PLL_ENET_MAIN_50M_CLK: + case PLL_ENET_MAIN_40M_CLK: + case PLL_ENET_MAIN_25M_CLK: + return mxc_get_pll_derive(PLL_ENET, root_src); + + case PLL_DRAM_MAIN_1066M_CLK: + case PLL_DRAM_MAIN_533M_CLK: + return mxc_get_pll_derive(PLL_DDR, root_src); + + case PLL_AUDIO_MAIN_CLK: + return decode_pll(PLL_AUDIO, MXC_HCLK); + case PLL_VIDEO_MAIN_CLK: + return decode_pll(PLL_VIDEO, MXC_HCLK); + + case PLL_USB_MAIN_480M_CLK: + return decode_pll(PLL_USB, MXC_HCLK); + + case REF_1M_CLK: + return 1000000; + case OSC_32K_CLK: + return MXC_CLK32; + + case EXT_CLK_1: + case EXT_CLK_2: + case EXT_CLK_3: + case EXT_CLK_4: + printf("No EXT CLK supported??\n"); + break; + }; + + return 0; +} + +u32 get_root_clk(enum clk_root_index clock_id) +{ + enum clk_root_src root_src; + u32 post_podf, pre_podf, auto_podf, root_src_clk; + int auto_en; + + if (clock_root_enabled(clock_id) <= 0) + return 0; + + if (clock_get_prediv(clock_id, &pre_podf) < 0) + return 0; + + if (clock_get_postdiv(clock_id, &post_podf) < 0) + return 0; + + if (clock_get_autopostdiv(clock_id, &auto_podf, &auto_en) < 0) + return 0; + + if (auto_en == 0) + auto_podf = 0; + + if (clock_get_src(clock_id, &root_src) < 0) + return 0; + + root_src_clk = get_root_src_clk(root_src); + + /* + * bypass clk is ignored. + */ + + return root_src_clk / (post_podf + 1) / (pre_podf + 1) / + (auto_podf + 1); +} + +static u32 get_ddrc_clk(void) +{ + u32 reg, freq; + enum root_post_div post_div; + + reg = readl(&ccm_reg->root[DRAM_CLK_ROOT].target_root); + if (reg & CLK_ROOT_MUX_MASK) + /* DRAM_ALT_CLK_ROOT */ + freq = get_root_clk(DRAM_ALT_CLK_ROOT); + else + /* PLL_DRAM_MAIN_1066M_CLK */ + freq = mxc_get_pll_derive(PLL_DDR, PLL_DRAM_MAIN_1066M_CLK); + + post_div = reg & DRAM_CLK_ROOT_POST_DIV_MASK; + + return freq / (post_div + 1) / 2; +} + +unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return get_root_clk(ARM_A7_CLK_ROOT); + case MXC_AXI_CLK: + return get_root_clk(MAIN_AXI_CLK_ROOT); + case MXC_AHB_CLK: + return get_root_clk(AHB_CLK_ROOT); + case MXC_IPG_CLK: + return get_ipg_clk(); + case MXC_I2C_CLK: + return get_root_clk(I2C1_CLK_ROOT); + case MXC_UART_CLK: + return get_root_clk(UART1_CLK_ROOT); + case MXC_CSPI_CLK: + return get_root_clk(ECSPI1_CLK_ROOT); + case MXC_DDR_CLK: + return get_ddrc_clk(); + case MXC_ESDHC_CLK: + return get_root_clk(USDHC1_CLK_ROOT); + case MXC_ESDHC2_CLK: + return get_root_clk(USDHC2_CLK_ROOT); + case MXC_ESDHC3_CLK: + return get_root_clk(USDHC3_CLK_ROOT); + default: + printf("Unsupported mxc_clock %d\n", clk); + break; + } + + return 0; +} + +#ifdef CONFIG_SYS_I2C_MXC +/* i2c_num can be 0 - 3 */ +int enable_i2c_clk(unsigned char enable, unsigned i2c_num) +{ + u32 target; + + if (i2c_num >= 4) + return -EINVAL; + + if (enable) { + clock_enable(CCGR_I2C1 + i2c_num, 0); + + /* Set i2c root clock to PLL_SYS_MAIN_120M_CLK */ + + target = CLK_ROOT_ON | I2C1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(I2C1_CLK_ROOT + i2c_num, target); + + clock_enable(CCGR_I2C1 + i2c_num, 1); + } else { + clock_enable(CCGR_I2C1 + i2c_num, 0); + } + + return 0; +} +#endif + +static void init_clk_esdhc(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_USDHC1, 0); + clock_enable(CCGR_USDHC2, 0); + clock_enable(CCGR_USDHC3, 0); + + /* 196: 392/2 */ + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC1_CLK_ROOT, target); + + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC2_CLK_ROOT, target); + + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC3_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_USDHC1, 1); + clock_enable(CCGR_USDHC2, 1); + clock_enable(CCGR_USDHC3, 1); + +} + +static void init_clk_uart(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_UART1, 0); + clock_enable(CCGR_UART2, 0); + clock_enable(CCGR_UART3, 0); + clock_enable(CCGR_UART4, 0); + clock_enable(CCGR_UART5, 0); + clock_enable(CCGR_UART6, 0); + clock_enable(CCGR_UART7, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | UART1_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART1_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART2_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART2_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART3_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART3_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART4_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART4_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART5_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART5_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART6_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART6_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART7_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART7_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_UART1, 1); + clock_enable(CCGR_UART2, 1); + clock_enable(CCGR_UART3, 1); + clock_enable(CCGR_UART4, 1); + clock_enable(CCGR_UART5, 1); + clock_enable(CCGR_UART6, 1); + clock_enable(CCGR_UART7, 1); + +} + +static void init_clk_weim(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_WEIM, 0); + + /* 120Mhz */ + target = CLK_ROOT_ON | EIM_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(EIM_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_WEIM, 1); +} + +static void init_clk_ecspi(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_ECSPI1, 0); + clock_enable(CCGR_ECSPI2, 0); + clock_enable(CCGR_ECSPI3, 0); + clock_enable(CCGR_ECSPI4, 0); + + /* 60Mhz: 240/4 */ + target = CLK_ROOT_ON | ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI1_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI2_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI3_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI4_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_ECSPI1, 1); + clock_enable(CCGR_ECSPI2, 1); + clock_enable(CCGR_ECSPI3, 1); + clock_enable(CCGR_ECSPI4, 1); +} + +static void init_clk_wdog(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_WDOG1, 0); + clock_enable(CCGR_WDOG2, 0); + clock_enable(CCGR_WDOG3, 0); + clock_enable(CCGR_WDOG4, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | WDOG_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(WDOG_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_WDOG1, 1); + clock_enable(CCGR_WDOG2, 1); + clock_enable(CCGR_WDOG3, 1); + clock_enable(CCGR_WDOG4, 1); + +} + +#ifdef CONFIG_MXC_EPDC +static void init_clk_epdc(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_EPDC, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV12); + clock_set_target_val(EPDC_PIXEL_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_EPDC, 1); +} +#endif + +static int enable_pll_enet(void) +{ + u32 reg; + s32 timeout = 100000; + + reg = readl(&ccm_anatop->pll_enet); + /* If pll_enet powered up, no need to set it again */ + if (reg & ANADIG_PLL_ENET_PWDN_MASK) { + reg &= ~ANADIG_PLL_ENET_PWDN_MASK; + writel(reg, &ccm_anatop->pll_enet); + + while (timeout--) { + if (readl(&ccm_anatop->pll_enet) & ANADIG_PLL_LOCK) + break; + } + + if (timeout <= 0) { + /* If timeout, we set pwdn for pll_enet. */ + reg |= ANADIG_PLL_ENET_PWDN_MASK; + return -ETIME; + } + } + + /* Clear bypass */ + writel(CCM_ANALOG_PLL_ENET_BYPASS_MASK, &ccm_anatop->pll_enet_clr); + + writel((CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK), + &ccm_anatop->pll_enet_set); + + return 0; +} +static int enable_pll_video(u32 pll_div, u32 pll_num, u32 pll_denom, + u32 post_div) +{ + u32 reg = 0; + ulong start; + + debug("pll5 div = %d, num = %d, denom = %d\n", + pll_div, pll_num, pll_denom); + + /* Power up PLL5 video and disable its output */ + writel(CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK, + &ccm_anatop->pll_video_clr); + + /* Set div, num and denom */ + switch (post_div) { + case 1: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x1) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + case 2: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + case 3: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x1), + &ccm_anatop->pll_video_set); + break; + case 4: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x3), + &ccm_anatop->pll_video_set); + break; + case 0: + default: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x2) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + } + + writel(CCM_ANALOG_PLL_VIDEO_NUM_A(pll_num), + &ccm_anatop->pll_video_num); + + writel(CCM_ANALOG_PLL_VIDEO_DENOM_B(pll_denom), + &ccm_anatop->pll_video_denom); + + /* Wait PLL5 lock */ + start = get_timer(0); /* Get current timestamp */ + + do { + reg = readl(&ccm_anatop->pll_video); + if (reg & CCM_ANALOG_PLL_VIDEO_LOCK_MASK) { + /* Enable PLL out */ + writel(CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK, + &ccm_anatop->pll_video_set); + return 0; + } + } while (get_timer(0) < (start + 10)); /* Wait 10ms */ + + printf("Lock PLL5 timeout\n"); + + return 1; + +} + +int set_clk_qspi(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_QSPI, 0); + + /* 49M: 392/2/4 */ + target = CLK_ROOT_ON | QSPI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(QSPI_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_QSPI, 1); + + return 0; +} + +int set_clk_nand(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_RAWNAND, 0); + + enable_pll_enet(); + /* 100: 500/5 */ + target = CLK_ROOT_ON | NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV5); + clock_set_target_val(NAND_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_RAWNAND, 1); + + return 0; +} + +void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq) +{ + u32 hck = MXC_HCLK/1000; + u32 min = hck * 27; + u32 max = hck * 54; + u32 temp, best = 0; + u32 i, j, pred = 1, postd = 1; + u32 pll_div, pll_num, pll_denom, post_div = 0; + u32 target; + + debug("mxs_set_lcdclk, freq = %d\n", freq); + + clock_enable(CCGR_LCDIF, 0); + + temp = (freq * 8 * 8); + if (temp < min) { + + for (i = 1; i <= 4; i++) { + if ((temp * (1 << i)) > min) { + post_div = i; + freq = (freq * (1 << i)); + break; + } + } + + if (5 == i) { + printf("Fail to set rate to %dkhz", freq); + return; + } + } + + for (i = 1; i <= 8; i++) { + for (j = 1; j <= 8; j++) { + temp = freq * i * j; + if (temp > max || temp < min) + continue; + + if (best == 0 || temp < best) { + best = temp; + pred = i; + postd = j; + } + } + } + + if (best == 0) { + printf("Fail to set rate to %dkhz", freq); + return; + } + + debug("best %d, pred = %d, postd = %d\n", best, pred, postd); + + pll_div = best / hck; + pll_denom = 1000000; + pll_num = (best - hck * pll_div) * pll_denom / hck; + + if (enable_pll_video(pll_div, pll_num, pll_denom, post_div)) + return; + + target = CLK_ROOT_ON | LCDIF_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK | + CLK_ROOT_PRE_DIV((pred - 1)) | CLK_ROOT_POST_DIV((postd - 1)); + clock_set_target_val(LCDIF_PIXEL_CLK_ROOT, target); + + clock_enable(CCGR_LCDIF, 1); +} + +#ifdef CONFIG_FEC_MXC +int set_clk_enet(enum enet_freq type) +{ + u32 target; + int ret; + u32 enet1_ref, enet2_ref; + + /* disable the clock first */ + clock_enable(CCGR_ENET1, 0); + clock_enable(CCGR_ENET2, 0); + + switch (type) { + case ENET_125MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; + break; + case ENET_50MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; + break; + case ENET_25MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; + break; + default: + return -EINVAL; + } + + ret = enable_pll_enet(); + if (ret != 0) + return ret; + + /* set enet axi clock 196M: 392/2 */ + target = CLK_ROOT_ON | ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(ENET_AXI_CLK_ROOT, target); + + target = CLK_ROOT_ON | enet1_ref | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET1_REF_CLK_ROOT, target); + + target = CLK_ROOT_ON | ENET1_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ENET1_TIME_CLK_ROOT, target); + + target = CLK_ROOT_ON | enet2_ref | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET2_REF_CLK_ROOT, target); + + target = CLK_ROOT_ON | ENET2_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ENET2_TIME_CLK_ROOT, target); + +#ifdef CONFIG_FEC_MXC_25M_REF_CLK + target = CLK_ROOT_ON | ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET_PHY_REF_CLK_ROOT, target); +#endif + /* enable clock */ + clock_enable(CCGR_ENET1, 1); + clock_enable(CCGR_ENET2, 1); + + return 0; +} +#endif + +/* Configure PLL/PFD freq */ +void clock_init(void) +{ + /* Rom has enabled PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET + * In u-boot, we have to: + * 1. Configure PFD3- PFD7 for freq we needed in u-boot + * 2. Set clock root for peripherals (ip channel) used in u-boot but without set rate + * interface. The clocks for these peripherals are enabled after this intialization. + * 3. Other peripherals with set clock rate interface does not be set in this function. + */ + + u32 reg; + + /* + * Configure PFD4 to 392M + * 480M * 18 / 0x16 = 392M + */ + reg = readl(&ccm_anatop->pfd_480b); + + reg &= ~(ANATOP_PFD480B_PFD4_FRAC_MASK | + CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK); + reg |= ANATOP_PFD480B_PFD4_FRAC_392M_VAL; + + writel(reg, &ccm_anatop->pfd_480b); + + init_clk_esdhc(); + init_clk_uart(); + init_clk_weim(); + init_clk_ecspi(); + init_clk_wdog(); +#ifdef CONFIG_MXC_EPDC + init_clk_epdc(); +#endif + + enable_usboh3_clk(1); + + clock_enable(CCGR_SNVS, 1); + +#ifdef CONFIG_NAND_MXS + clock_enable(CCGR_RAWNAND, 1); +#endif +} + +#ifdef CONFIG_SECURE_BOOT +void hab_caam_clock_enable(unsigned char enable) +{ + if (enable) + clock_enable(CCGR_CAAM, 1); + else + clock_enable(CCGR_CAAM, 0); +} +#endif + +#ifdef CONFIG_MXC_EPDC +void epdc_clock_enable(void) +{ + clock_enable(CCGR_EPDC, 1); +} +void epdc_clock_disable(void) +{ + clock_enable(CCGR_EPDC, 0); +} +#endif + +/* + * Dump some core clockes. + */ +int do_mx7_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + u32 freq; + freq = decode_pll(PLL_CORE, MXC_HCLK); + printf("PLL_CORE %8d MHz\n", freq / 1000000); + freq = decode_pll(PLL_SYS, MXC_HCLK); + printf("PLL_SYS %8d MHz\n", freq / 1000000); + freq = decode_pll(PLL_ENET, MXC_HCLK); + printf("PLL_NET %8d MHz\n", freq / 1000000); + + printf("\n"); + + printf("IPG %8d kHz\n", mxc_get_clock(MXC_IPG_CLK) / 1000); + printf("UART %8d kHz\n", mxc_get_clock(MXC_UART_CLK) / 1000); +#ifdef CONFIG_MXC_SPI + printf("CSPI %8d kHz\n", mxc_get_clock(MXC_CSPI_CLK) / 1000); +#endif + printf("AHB %8d kHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000); + printf("AXI %8d kHz\n", mxc_get_clock(MXC_AXI_CLK) / 1000); + printf("DDR %8d kHz\n", mxc_get_clock(MXC_DDR_CLK) / 1000); + printf("USDHC1 %8d kHz\n", mxc_get_clock(MXC_ESDHC_CLK) / 1000); + printf("USDHC2 %8d kHz\n", mxc_get_clock(MXC_ESDHC2_CLK) / 1000); + printf("USDHC3 %8d kHz\n", mxc_get_clock(MXC_ESDHC3_CLK) / 1000); + + return 0; +} + +U_BOOT_CMD( + clocks, CONFIG_SYS_MAXARGS, 1, do_mx7_showclocks, + "display clocks", + "" +); diff --git a/arch/arm/cpu/armv7/mx7/clock_slice.c b/arch/arm/cpu/armv7/mx7/clock_slice.c new file mode 100644 index 0000000..ad5d504 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/clock_slice.c @@ -0,0 +1,757 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + +static struct clk_root_map root_array[] = { + {ARM_A7_CLK_ROOT, CCM_CORE_CHANNEL, + {OSC_24M_CLK, PLL_ARM_MAIN_800M_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_DRAM_MAIN_1066M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_AUDIO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ARM_M4_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_250M_CLK, + PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ARM_M0_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_125M_CLK, + PLL_SYS_PFD2_135M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {MAIN_AXI_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_PFD5_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD7_CLK} + }, + {DISP_AXI_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {ENET_AXI_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK} + }, + {NAND_USDHC_BUS_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_PFD6_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_AUDIO_MAIN_CLK} + }, + {AHB_CLK_ROOT, CCM_AHB_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {DRAM_PHYM_CLK_ROOT, CCM_DRAM_PHYM_CHANNEL, + {PLL_DRAM_MAIN_1066M_CLK, DRAM_PHYM_ALT_CLK_ROOT} + }, + {DRAM_CLK_ROOT, CCM_DRAM_CHANNEL, + {PLL_DRAM_MAIN_1066M_CLK, DRAM_ALT_CLK_ROOT} + }, + {DRAM_PHYM_ALT_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD7_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {DRAM_ALT_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_ENET_MAIN_250M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_AUDIO_MAIN_CLK, PLL_SYS_PFD2_270M_CLK} + }, + {USB_HSIC_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_USB_MAIN_480M_CLK, + PLL_SYS_PFD3_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD5_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {PCIE_CTRL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_250M_CLK, PLL_SYS_MAIN_240M_CLK, + PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_SYS_PFD6_CLK} + }, + {PCIE_PHY_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_ENET_MAIN_500M_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_SYS_PFD0_392M_CLK} + }, + {EPDC_PIXEL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD5_CLK, PLL_SYS_PFD6_CLK, + PLL_SYS_PFD7_CLK, PLL_VIDEO_MAIN_CLK} + }, + {LCDIF_PIXEL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD5_CLK, PLL_DRAM_MAIN_533M_CLK, + EXT_CLK_3, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {MIPI_DSI_EXTSER_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD5_CLK, PLL_SYS_PFD3_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD0_196M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_AUDIO_MAIN_CLK} + }, + {MIPI_CSI_WARP_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD3_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD0_196M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_AUDIO_MAIN_CLK} + }, + {MIPI_DPHY_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD5_CLK, REF_1M_CLK, EXT_CLK_2, + PLL_VIDEO_MAIN_CLK, EXT_CLK_3} + }, + {SAI1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_2} + }, + {SAI2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_2} + }, + {SAI3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_3} + }, + {SPDIF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_3} + }, + {ENET1_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_25M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, EXT_CLK_4} + }, + {ENET1_TIME_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_AUDIO_MAIN_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_VIDEO_MAIN_CLK} + }, + {ENET2_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_25M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, EXT_CLK_4} + }, + {ENET2_TIME_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_AUDIO_MAIN_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_VIDEO_MAIN_CLK} + }, + {ENET_PHY_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_25M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD3_CLK} + }, + {EIM_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_SYS_PFD3_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {NAND_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_SYS_PFD3_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {QSPI_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD4_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD3_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {CAN1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_4} + }, + {CAN2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_3} + }, + {I2C1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {UART1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART5_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART6_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART7_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {PWM1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_1, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_1, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_2, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_2, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {FLEXTIMER1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_3, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {FLEXTIMER2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_3, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {SIM1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_USB_MAIN_480M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_SYS_PFD7_CLK} + }, + {SIM2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_USB_MAIN_480M_CLK, PLL_VIDEO_MAIN_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_SYS_PFD7_CLK} + }, + {GPT1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_1} + }, + {GPT2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_2} + }, + {GPT3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_3} + }, + {GPT4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_4} + }, + {TRACE_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_3} + }, + {WDOG_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + REF_1M_CLK, PLL_SYS_PFD1_166M_CLK} + }, + {CSI_MCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {AUDIO_MCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {WRCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD7_CLK} + }, + {IPP_DO_CLKO1, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_MAIN_240M_CLK, + PLL_SYS_PFD0_196M_CLK, PLL_SYS_PFD3_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_DRAM_MAIN_533M_CLK, REF_1M_CLK} + }, + {IPP_DO_CLKO2, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_SYS_PFD1_166M_CLK, PLL_SYS_PFD4_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, OSC_32K_CLK} + }, +}; + +/* select which entry of root_array */ +static int select(enum clk_root_index clock_id) +{ + int i, size; + struct clk_root_map *p = root_array; + + size = ARRAY_SIZE(root_array); + + for (i = 0; i < size; i++, p++) { + if (clock_id == p->entry) + return i; + } + + return -EINVAL; +} + +static int src_supported(int entry, enum clk_root_src clock_src) +{ + int i, size; + struct clk_root_map *p = &root_array[entry]; + + if ((p->type == CCM_DRAM_PHYM_CHANNEL) || (p->type == CCM_DRAM_CHANNEL)) + size = 2; + else + size = 8; + + for (i = 0; i < size; i++) { + if (p->src_mux[i] == clock_src) + return i; + } + + return -EINVAL; +} + +/* Set src for clock root slice. */ +int clock_set_src(enum clk_root_index clock_id, enum clk_root_src clock_src) +{ + int root_entry, src_entry; + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + src_entry = src_supported(root_entry, clock_src); + if (src_entry < 0) + return -EINVAL; + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_MUX_MASK; + reg |= src_entry << CLK_ROOT_MUX_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +/* Get src of a clock root slice. */ +int clock_get_src(enum clk_root_index clock_id, enum clk_root_src *p_clock_src) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= CLK_ROOT_MUX_MASK; + val >>= CLK_ROOT_MUX_SHIFT; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + *p_clock_src = p->src_mux[val]; + + return 0; +} + +int clock_set_prediv(enum clk_root_index clock_id, enum root_pre_div pre_div) +{ + int root_entry; + struct clk_root_map *p; + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + if (pre_div != CLK_ROOT_PRE_DIV1) { + printf("Error pre div!\n"); + return -EINVAL; + } + } + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_PRE_DIV_MASK; + reg |= pre_div << CLK_ROOT_PRE_DIV_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_prediv(enum clk_root_index clock_id, enum root_pre_div *pre_div) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + *pre_div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= CLK_ROOT_PRE_DIV_MASK; + val >>= CLK_ROOT_PRE_DIV_SHIFT; + + *pre_div = val; + + return 0; +} + +int clock_set_postdiv(enum clk_root_index clock_id, enum root_post_div div) +{ + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + if (clock_id == DRAM_PHYM_CLK_ROOT) { + if (div != CLK_ROOT_POST_DIV1) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + /* Only 3 bit post div. */ + if ((clock_id == DRAM_CLK_ROOT) && (div > CLK_ROOT_POST_DIV7)) { + printf("Error post div!\n"); + return -EINVAL; + } + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_POST_DIV_MASK; + reg |= div << CLK_ROOT_POST_DIV_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_postdiv(enum clk_root_index clock_id, enum root_post_div *div) +{ + u32 val; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + if (clock_id == DRAM_PHYM_CLK_ROOT) { + *div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + if (clock_id == DRAM_CLK_ROOT) + val &= DRAM_CLK_ROOT_POST_DIV_MASK; + else + val &= CLK_ROOT_POST_DIV_MASK; + val >>= CLK_ROOT_POST_DIV_SHIFT; + + *div = val; + + return 0; +} + +int clock_set_autopostdiv(enum clk_root_index clock_id, enum root_auto_div div, + int auto_en) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type != CCM_BUS_CHANNEL) && (p->type != CCM_AHB_CHANNEL)) { + printf("Auto postdiv not supported.!\n"); + return -EINVAL; + } + + /* + * Each time only one filed can be changed, no use target_root_set. + */ + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= ~CLK_ROOT_AUTO_DIV_MASK; + val |= (div << CLK_ROOT_AUTO_DIV_SHIFT); + + if (auto_en) + val |= CLK_ROOT_AUTO_EN; + else + val &= ~CLK_ROOT_AUTO_EN; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_autopostdiv(enum clk_root_index clock_id, enum root_auto_div *div, + int *auto_en) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + /* + * Only bus/ahb channel supports auto div. + * If unsupported, just set auto_en and div with 0. + */ + if ((p->type != CCM_BUS_CHANNEL) && (p->type != CCM_AHB_CHANNEL)) { + *auto_en = 0; + *div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + if ((val & CLK_ROOT_AUTO_EN_MASK) == 0) + *auto_en = 0; + else + *auto_en = 1; + + val &= CLK_ROOT_AUTO_DIV_MASK; + val >>= CLK_ROOT_AUTO_DIV_SHIFT; + + *div = val; + + return 0; +} + +int clock_get_target_val(enum clk_root_index clock_id, u32 *val) +{ + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + *val = __raw_readl(&imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_set_target_val(enum clk_root_index clock_id, u32 val) +{ + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +/* Auto_div and auto_en is ignored, they are rarely used. */ +int clock_root_cfg(enum clk_root_index clock_id, enum root_pre_div pre_div, + enum root_post_div post_div, enum clk_root_src clock_src) +{ + u32 val; + int root_entry, src_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + if (pre_div != CLK_ROOT_PRE_DIV1) { + printf("Error pre div!\n"); + return -EINVAL; + } + } + + /* Only 3 bit post div. */ + if (p->type == CCM_DRAM_CHANNEL) { + if (post_div > CLK_ROOT_POST_DIV7) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + if (p->type == CCM_DRAM_PHYM_CHANNEL) { + if (post_div != CLK_ROOT_POST_DIV1) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + src_entry = src_supported(root_entry, clock_src); + if (src_entry < 0) + return -EINVAL; + + val = CLK_ROOT_ON | pre_div << CLK_ROOT_PRE_DIV_SHIFT | + post_div << CLK_ROOT_POST_DIV_SHIFT | + src_entry << CLK_ROOT_MUX_SHIFT; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_root_enabled(enum clk_root_index clock_id) +{ + u32 val; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + /* + * No enable bit for DRAM controller and PHY. Just return enabled. + */ + if ((clock_id == DRAM_PHYM_CLK_ROOT) || (clock_id == DRAM_CLK_ROOT)) + return 1; + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + + return (val & CLK_ROOT_ENABLE_MASK) ? 1 : 0; +} + +/* CCGR gate operation */ +int clock_enable(enum clk_ccgr_index index, bool enable) +{ + if (index >= CCGR_MAX) + return -EINVAL; + + if (enable) + __raw_writel(CCM_CLK_ON_MSK, + &imx_ccm->ccgr_array[index].ccgr_set); + else + __raw_writel(CCM_CLK_ON_MSK, + &imx_ccm->ccgr_array[index].ccgr_clr); + + return 0; +} diff --git a/arch/arm/include/asm/arch-mx7/clock.h b/arch/arm/include/asm/arch-mx7/clock.h new file mode 100644 index 0000000..688d236 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/clock.h @@ -0,0 +1,348 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_CLOCK_H +#define _ASM_ARCH_CLOCK_H + +#include <common.h> +#include <asm/arch/crm_regs.h> + +#ifdef CONFIG_SYS_MX7_HCLK +#define MXC_HCLK CONFIG_SYS_MX7_HCLK +#else +#define MXC_HCLK 24000000 +#endif + +#ifdef CONFIG_SYS_MX7_CLK32 +#define MXC_CLK32 CONFIG_SYS_MX7_CLK32 +#else +#define MXC_CLK32 32768 +#endif + +/* Mainly for compatible to imx common code. */ +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_AHB_CLK, + MXC_IPG_CLK, + MXC_UART_CLK, + MXC_CSPI_CLK, + MXC_AXI_CLK, + MXC_DDR_CLK, + MXC_ESDHC_CLK, + MXC_ESDHC2_CLK, + MXC_ESDHC3_CLK, + MXC_I2C_CLK, +}; + +/* PLL supported by i.mx7d */ +enum pll_clocks { + PLL_CORE, /* Core PLL */ + PLL_SYS, /* System PLL*/ + PLL_ENET, /* Enet PLL */ + PLL_AUDIO, /* Audio PLL */ + PLL_VIDEO, /* Video PLL*/ + PLL_DDR, /* Dram PLL */ + PLL_USB, /* USB PLL, fixed at 480MHZ */ +}; + +/* clk src for clock root gen */ +enum clk_root_src { + OSC_24M_CLK, + + PLL_ARM_MAIN_800M_CLK, + + PLL_SYS_MAIN_480M_CLK, + PLL_SYS_MAIN_240M_CLK, + PLL_SYS_MAIN_120M_CLK, + PLL_SYS_PFD0_392M_CLK, + PLL_SYS_PFD0_196M_CLK, + PLL_SYS_PFD1_332M_CLK, + PLL_SYS_PFD1_166M_CLK, + PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD2_135M_CLK, + PLL_SYS_PFD3_CLK, + PLL_SYS_PFD4_CLK, + PLL_SYS_PFD5_CLK, + PLL_SYS_PFD6_CLK, + PLL_SYS_PFD7_CLK, + + PLL_ENET_MAIN_500M_CLK, + PLL_ENET_MAIN_250M_CLK, + PLL_ENET_MAIN_125M_CLK, + PLL_ENET_MAIN_100M_CLK, + PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_25M_CLK, + + PLL_DRAM_MAIN_1066M_CLK, + PLL_DRAM_MAIN_533M_CLK, + + PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, + + PLL_USB_MAIN_480M_CLK, /* fixed at 480MHZ */ + + EXT_CLK_1, + EXT_CLK_2, + EXT_CLK_3, + EXT_CLK_4, + + REF_1M_CLK, + OSC_32K_CLK, +}; + +/* + * Clock root index + */ +enum clk_root_index { + ARM_A7_CLK_ROOT = 0, + ARM_M4_CLK_ROOT = 1, + ARM_M0_CLK_ROOT = 2, + MAIN_AXI_CLK_ROOT = 16, + DISP_AXI_CLK_ROOT = 17, + ENET_AXI_CLK_ROOT = 18, + NAND_USDHC_BUS_CLK_ROOT = 19, + AHB_CLK_ROOT = 32, + DRAM_PHYM_CLK_ROOT = 48, + DRAM_CLK_ROOT = 49, + DRAM_PHYM_ALT_CLK_ROOT = 64, + DRAM_ALT_CLK_ROOT = 65, + USB_HSIC_CLK_ROOT = 66, + PCIE_CTRL_CLK_ROOT = 67, + PCIE_PHY_CLK_ROOT = 68, + EPDC_PIXEL_CLK_ROOT = 69, + LCDIF_PIXEL_CLK_ROOT = 70, + MIPI_DSI_EXTSER_CLK_ROOT = 71, + MIPI_CSI_WARP_CLK_ROOT = 72, + MIPI_DPHY_REF_CLK_ROOT = 73, + SAI1_CLK_ROOT = 74, + SAI2_CLK_ROOT = 75, + SAI3_CLK_ROOT = 76, + SPDIF_CLK_ROOT = 77, + ENET1_REF_CLK_ROOT = 78, + ENET1_TIME_CLK_ROOT = 79, + ENET2_REF_CLK_ROOT = 80, + ENET2_TIME_CLK_ROOT = 81, + ENET_PHY_REF_CLK_ROOT = 82, + EIM_CLK_ROOT = 83, + NAND_CLK_ROOT = 84, + QSPI_CLK_ROOT = 85, + USDHC1_CLK_ROOT = 86, + USDHC2_CLK_ROOT = 87, + USDHC3_CLK_ROOT = 88, + CAN1_CLK_ROOT = 89, + CAN2_CLK_ROOT = 90, + I2C1_CLK_ROOT = 91, + I2C2_CLK_ROOT = 92, + I2C3_CLK_ROOT = 93, + I2C4_CLK_ROOT = 94, + UART1_CLK_ROOT = 95, + UART2_CLK_ROOT = 96, + UART3_CLK_ROOT = 97, + UART4_CLK_ROOT = 98, + UART5_CLK_ROOT = 99, + UART6_CLK_ROOT = 100, + UART7_CLK_ROOT = 101, + ECSPI1_CLK_ROOT = 102, + ECSPI2_CLK_ROOT = 103, + ECSPI3_CLK_ROOT = 104, + ECSPI4_CLK_ROOT = 105, + PWM1_CLK_ROOT = 106, + PWM2_CLK_ROOT = 107, + PWM3_CLK_ROOT = 108, + PWM4_CLK_ROOT = 109, + FLEXTIMER1_CLK_ROOT = 110, + FLEXTIMER2_CLK_ROOT = 111, + SIM1_CLK_ROOT = 112, + SIM2_CLK_ROOT = 113, + GPT1_CLK_ROOT = 114, + GPT2_CLK_ROOT = 115, + GPT3_CLK_ROOT = 116, + GPT4_CLK_ROOT = 117, + TRACE_CLK_ROOT = 118, + WDOG_CLK_ROOT = 119, + CSI_MCLK_CLK_ROOT = 120, + AUDIO_MCLK_CLK_ROOT = 121, + WRCLK_CLK_ROOT = 122, + IPP_DO_CLKO1 = 123, + IPP_DO_CLKO2 = 124, + + CLK_ROOT_MAX, +}; + +struct clk_root_setting { + enum clk_root_index root; + u32 setting; +}; + +/* + * CCGR mapping + */ +enum clk_ccgr_index { + CCGR_CPU = 0, + CCGR_M4 = 1, + CCGR_SIM_MAIN = 4, + CCGR_SIM_DISPLAY = 5, + CCGR_SIM_ENET = 6, + CCGR_SIM_M = 7, + CCGR_SIM_S = 8, + CCGR_SIM_WAKEUP = 9, + CCGR_IPMUX1 = 10, + CCGR_IPMUX2 = 11, + CCGR_IPMUX3 = 12, + CCGR_ROM = 16, + CCGR_OCRAM = 17, + CCGR_OCRAM_S = 18, + CCGR_DRAM = 19, + CCGR_RAWNAND = 20, + CCGR_QSPI = 21, + CCGR_WEIM = 22, + CCGR_ADC = 32, + CCGR_ANATOP = 33, + CCGR_SCTR = 34, + CCGR_OCOTP = 35, + CCGR_CAAM = 36, + CCGR_SNVS = 37, + CCGR_RDC = 38, + CCGR_MU = 39, + CCGR_HS = 40, + CCGR_DVFS = 41, + CCGR_QOS = 42, + CCGR_QOS_DISPMIX = 43, + CCGR_QOS_MEGAMIX = 44, + CCGR_CSU = 45, + CCGR_DBGMON = 46, + CCGR_DEBUG = 47, + CCGR_TRACE = 48, + CCGR_SEC_DEBUG = 49, + CCGR_SEMA1 = 64, + CCGR_SEMA2 = 65, + CCGR_PERFMON1 = 68, + CCGR_PERFMON2 = 69, + CCGR_SDMA = 72, + CCGR_CSI = 73, + CCGR_EPDC = 74, + CCGR_LCDIF = 75, + CCGR_PXP = 76, + CCGR_PCIE = 96, + CCGR_MIPI_CSI = 100, + CCGR_MIPI_DSI = 101, + CCGR_MIPI_MEM_PHY = 102, + CCGR_USB_CTRL = 104, + CCGR_USB_HSIC = 105, + CCGR_USB_PHY1 = 106, + CCGR_USB_PHY2 = 107, + CCGR_USDHC1 = 108, + CCGR_USDHC2 = 109, + CCGR_USDHC3 = 110, + CCGR_ENET1 = 112, + CCGR_ENET2 = 113, + CCGR_CAN1 = 116, + CCGR_CAN2 = 117, + CCGR_ECSPI1 = 120, + CCGR_ECSPI2 = 121, + CCGR_ECSPI3 = 122, + CCGR_ECSPI4 = 123, + CCGR_GPT1 = 124, + CCGR_GPT2 = 125, + CCGR_GPT3 = 126, + CCGR_GPT4 = 127, + CCGR_FTM1 = 128, + CCGR_FTM2 = 129, + CCGR_PWM1 = 132, + CCGR_PWM2 = 133, + CCGR_PWM3 = 134, + CCGR_PWM4 = 135, + CCGR_I2C1 = 136, + CCGR_I2C2 = 137, + CCGR_I2C3 = 138, + CCGR_I2C4 = 139, + CCGR_SAI1 = 140, + CCGR_SAI2 = 141, + CCGR_SAI3 = 142, + CCGR_SIM1 = 144, + CCGR_SIM2 = 145, + CCGR_UART1 = 148, + CCGR_UART2 = 149, + CCGR_UART3 = 150, + CCGR_UART4 = 151, + CCGR_UART5 = 152, + CCGR_UART6 = 153, + CCGR_UART7 = 154, + CCGR_WDOG1 = 156, + CCGR_WDOG2 = 157, + CCGR_WDOG3 = 158, + CCGR_WDOG4 = 159, + CCGR_GPIO1 = 160, + CCGR_GPIO2 = 161, + CCGR_GPIO3 = 162, + CCGR_GPIO4 = 163, + CCGR_GPIO5 = 164, + CCGR_GPIO6 = 165, + CCGR_GPIO7 = 166, + CCGR_IOMUX = 168, + CCGR_IOMUX_LPSR = 169, + CCGR_KPP = 170, + + CCGR_SKIP, + CCGR_MAX, +}; + +/* Clock root channel */ +enum clk_root_type { + CCM_CORE_CHANNEL, + CCM_BUS_CHANNEL, + CCM_AHB_CHANNEL, + CCM_DRAM_PHYM_CHANNEL, + CCM_DRAM_CHANNEL, + CCM_IP_CHANNEL, +}; + +#include <asm/arch/clock_slice.h> + +/* + * entry: the clock root index + * type: ccm channel + * src_mux: each entry corresponding to the clock src, detailed info in CCM RM + */ +struct clk_root_map { + enum clk_root_index entry; + enum clk_root_type type; + uint8_t src_mux[8]; +}; + +enum enet_freq { + ENET_25MHz, + ENET_50MHz, + ENET_125MHz, +}; + +u32 get_root_clk(enum clk_root_index clock_id); +u32 mxc_get_clock(enum mxc_clock clk); +u32 imx_get_uartclk(void); +u32 imx_get_fecclk(void); +void clock_init(void); +#ifdef CONFIG_SYS_I2C_MXC +int enable_i2c_clk(unsigned char enable, unsigned i2c_num); +#endif +#ifdef CONFIG_FEC_MXC +int set_clk_enet(enum enet_freq type); +#endif +int set_clk_qspi(void); +int set_clk_nand(void); +#ifdef CONFIG_MXC_OCOTP +void enable_ocotp_clk(unsigned char enable); +#endif +void enable_usboh3_clk(unsigned char enable); +#ifdef CONFIG_SECURE_BOOT +void hab_caam_clock_enable(unsigned char enable); +#endif +void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq); +void enable_thermal_clk(void); +#endif diff --git a/arch/arm/include/asm/arch-mx7/clock_slice.h b/arch/arm/include/asm/arch-mx7/clock_slice.h new file mode 100644 index 0000000..6ede0cd --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/clock_slice.h @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_CLOCK_SLICE_H +#define _ASM_ARCH_CLOCK_SLICE_H + +enum root_pre_div { + CLK_ROOT_PRE_DIV1 = 0, + CLK_ROOT_PRE_DIV2, + CLK_ROOT_PRE_DIV3, + CLK_ROOT_PRE_DIV4, + CLK_ROOT_PRE_DIV5, + CLK_ROOT_PRE_DIV6, + CLK_ROOT_PRE_DIV7, + CLK_ROOT_PRE_DIV8, +}; + +enum root_post_div { + CLK_ROOT_POST_DIV1 = 0, + CLK_ROOT_POST_DIV2, + CLK_ROOT_POST_DIV3, + CLK_ROOT_POST_DIV4, + CLK_ROOT_POST_DIV5, + CLK_ROOT_POST_DIV6, + CLK_ROOT_POST_DIV7, + CLK_ROOT_POST_DIV8, + CLK_ROOT_POST_DIV9, + CLK_ROOT_POST_DIV10, + CLK_ROOT_POST_DIV11, + CLK_ROOT_POST_DIV12, + CLK_ROOT_POST_DIV13, + CLK_ROOT_POST_DIV14, + CLK_ROOT_POST_DIV15, + CLK_ROOT_POST_DIV16, + CLK_ROOT_POST_DIV17, + CLK_ROOT_POST_DIV18, + CLK_ROOT_POST_DIV19, + CLK_ROOT_POST_DIV20, + CLK_ROOT_POST_DIV21, + CLK_ROOT_POST_DIV22, + CLK_ROOT_POST_DIV23, + CLK_ROOT_POST_DIV24, + CLK_ROOT_POST_DIV25, + CLK_ROOT_POST_DIV26, + CLK_ROOT_POST_DIV27, + CLK_ROOT_POST_DIV28, + CLK_ROOT_POST_DIV29, + CLK_ROOT_POST_DIV30, + CLK_ROOT_POST_DIV31, + CLK_ROOT_POST_DIV32, + CLK_ROOT_POST_DIV33, + CLK_ROOT_POST_DIV34, + CLK_ROOT_POST_DIV35, + CLK_ROOT_POST_DIV36, + CLK_ROOT_POST_DIV37, + CLK_ROOT_POST_DIV38, + CLK_ROOT_POST_DIV39, + CLK_ROOT_POST_DIV40, + CLK_ROOT_POST_DIV41, + CLK_ROOT_POST_DIV42, + CLK_ROOT_POST_DIV43, + CLK_ROOT_POST_DIV44, + CLK_ROOT_POST_DIV45, + CLK_ROOT_POST_DIV46, + CLK_ROOT_POST_DIV47, + CLK_ROOT_POST_DIV48, + CLK_ROOT_POST_DIV49, + CLK_ROOT_POST_DIV50, + CLK_ROOT_POST_DIV51, + CLK_ROOT_POST_DIV52, + CLK_ROOT_POST_DIV53, + CLK_ROOT_POST_DIV54, + CLK_ROOT_POST_DIV55, + CLK_ROOT_POST_DIV56, + CLK_ROOT_POST_DIV57, + CLK_ROOT_POST_DIV58, + CLK_ROOT_POST_DIV59, + CLK_ROOT_POST_DIV60, + CLK_ROOT_POST_DIV61, + CLK_ROOT_POST_DIV62, + CLK_ROOT_POST_DIV63, + CLK_ROOT_POST_DIV64, +}; + +enum root_auto_div { + CLK_ROOT_AUTO_DIV1 = 0, + CLK_ROOT_AUTO_DIV2, + CLK_ROOT_AUTO_DIV4, + CLK_ROOT_AUTO_DIV8, + CLK_ROOT_AUTO_DIV16, +}; + +int clock_set_src(enum clk_root_index clock_id, enum clk_root_src clock_src); +int clock_get_src(enum clk_root_index clock_id, enum clk_root_src *p_clock_src); +int clock_set_prediv(enum clk_root_index clock_id, enum root_pre_div pre_div); +int clock_get_prediv(enum clk_root_index clock_id, enum root_pre_div *pre_div); +int clock_set_postdiv(enum clk_root_index clock_id, enum root_post_div div); +int clock_get_postdiv(enum clk_root_index clock_id, enum root_post_div *div); +int clock_set_autopostdiv(enum clk_root_index clock_id, enum root_auto_div div, + int auto_en); +int clock_get_autopostdiv(enum clk_root_index clock_id, enum root_auto_div *div, + int *auto_en); +int clock_get_target_val(enum clk_root_index clock_id, u32 *val); +int clock_set_target_val(enum clk_root_index clock_id, u32 val); +int clock_root_cfg(enum clk_root_index clock_id, enum root_pre_div pre_div, + enum root_post_div post_div, enum clk_root_src clock_src); +int clock_root_enabled(enum clk_root_index clock_id); + +int clock_enable(enum clk_ccgr_index index, bool enable); +#endif
* Add SoC system support, Misc arch dependent functions for system bring up: s_init: system init enable clock base settings enable_caches: configures Cortex-A7 L2 caches get_boot_device: identifies boot device
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Split from patch imx: imx7d: initial arch level support Changes for V3: Resend
arch/arm/cpu/armv7/mx7/soc.c | 360 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/imx-common/boot_mode.h | 21 ++ 3 files changed, 382 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/soc.c
diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c new file mode 100644 index 0000000..4213dad --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -0,0 +1,360 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv7.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/dma.h> +#include <stdbool.h> +#include <asm/arch/crm_regs.h> +#include <dm.h> +#include <imx_thermal.h> +#ifdef CONFIG_VIDEO_MXS +#include <mxsfb.h> +#endif + +struct src *src_reg = (struct src *)SRC_BASE_ADDR; + +#if defined(CONFIG_IMX_THERMAL) +static const struct imx_thermal_plat imx7_thermal_plat = { + .regs = (void *)ANATOP_BASE_ADDR, + .fuse_bank = 3, + .fuse_word = 3, +}; + +U_BOOT_DEVICE(imx7_thermal) = { + .name = "imx_thermal", + .platdata = &imx7_thermal_plat, +}; +#endif + +u32 get_cpu_rev(void) +{ + struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; + u32 reg = readl(&ccm_anatop->digprog); + u32 type = (reg >> 16) & 0xff; + + reg &= 0xff; + return (type << 12) | reg; +} + +#ifdef CONFIG_REVISION_TAG +u32 __weak get_board_rev(void) +{ + u32 cpurev = get_cpu_rev(); + u32 type = ((cpurev >> 12) & 0xff); + + if (type == MXC_CPU_MX7D) + cpurev = (MXC_CPU_MX7D) << 12 | (cpurev & 0xFFF); + + return cpurev; +} +#endif + +static void init_aips(void) +{ + struct aipstz_regs *aips1, *aips2, *aips3; + + aips1 = (struct aipstz_regs *)AIPS1_ON_BASE_ADDR; + aips2 = (struct aipstz_regs *)AIPS2_ON_BASE_ADDR; + aips3 = (struct aipstz_regs *)AIPS3_ON_BASE_ADDR; + + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips1->mprot0); + writel(0x77777777, &aips1->mprot1); + writel(0x77777777, &aips2->mprot0); + writel(0x77777777, &aips2->mprot1); + writel(0x77777777, &aips3->mprot0); + writel(0x77777777, &aips3->mprot1); + + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips1->opacr0); + writel(0x00000000, &aips1->opacr1); + writel(0x00000000, &aips1->opacr2); + writel(0x00000000, &aips1->opacr3); + writel(0x00000000, &aips1->opacr4); + writel(0x00000000, &aips2->opacr0); + writel(0x00000000, &aips2->opacr1); + writel(0x00000000, &aips2->opacr2); + writel(0x00000000, &aips2->opacr3); + writel(0x00000000, &aips2->opacr4); + writel(0x00000000, &aips3->opacr0); + writel(0x00000000, &aips3->opacr1); + writel(0x00000000, &aips3->opacr2); + writel(0x00000000, &aips3->opacr3); + writel(0x00000000, &aips3->opacr4); +} + +static void imx_set_pcie_phy_power_down(void) +{ + /* TODO */ +} + +static void imx_set_wdog_powerdown(bool enable) +{ + struct wdog_regs *wdog1 = (struct wdog_regs *)WDOG1_BASE_ADDR; + struct wdog_regs *wdog2 = (struct wdog_regs *)WDOG2_BASE_ADDR; + struct wdog_regs *wdog3 = (struct wdog_regs *)WDOG3_BASE_ADDR; + struct wdog_regs *wdog4 = (struct wdog_regs *)WDOG4_BASE_ADDR; + + writew(enable, &wdog1->wmcr); + writew(enable, &wdog2->wmcr); + writew(enable, &wdog3->wmcr); + writew(enable, &wdog4->wmcr); +} + +static void set_epdc_qos(void) +{ +#define REGS_QOS_BASE QOSC_IPS_BASE_ADDR +#define REGS_QOS_EPDC (QOSC_IPS_BASE_ADDR + 0x3400) +#define REGS_QOS_PXP0 (QOSC_IPS_BASE_ADDR + 0x2C00) +#define REGS_QOS_PXP1 (QOSC_IPS_BASE_ADDR + 0x3C00) + + writel(0, REGS_QOS_BASE); /* Disable clkgate & soft_reset */ + writel(0, REGS_QOS_BASE + 0x60); /* Enable all masters */ + writel(0, REGS_QOS_EPDC); /* Disable clkgate & soft_reset */ + writel(0, REGS_QOS_PXP0); /* Disable clkgate & soft_reset */ + writel(0, REGS_QOS_PXP1); /* Disable clkgate & soft_reset */ + + writel(0x0f020722, REGS_QOS_EPDC + 0xd0); /* WR, init = 7 with red flag */ + writel(0x0f020722, REGS_QOS_EPDC + 0xe0); /* RD, init = 7 with red flag */ + + writel(1, REGS_QOS_PXP0); /* OT_CTRL_EN =1 */ + writel(1, REGS_QOS_PXP1); /* OT_CTRL_EN =1 */ + + writel(0x0f020222, REGS_QOS_PXP0 + 0x50); /* WR, init = 2 with red flag */ + writel(0x0f020222, REGS_QOS_PXP1 + 0x50); /* WR, init = 2 with red flag */ + writel(0x0f020222, REGS_QOS_PXP0 + 0x60); /* rD, init = 2 with red flag */ + writel(0x0f020222, REGS_QOS_PXP1 + 0x60); /* rD, init = 2 with red flag */ + writel(0x0f020422, REGS_QOS_PXP0 + 0x70); /* tOTAL, init = 4 with red flag */ + writel(0x0f020422, REGS_QOS_PXP1 + 0x70); /* TOTAL, init = 4 with red flag */ + + writel(0xe080, IOMUXC_GPR_BASE_ADDR + 0x0034); /* EPDC AW/AR CACHE ENABLE */ +} + +int arch_cpu_init(void) +{ + init_aips(); + + /* Disable PDE bit of WMCR register */ + imx_set_wdog_powerdown(false); + + imx_set_pcie_phy_power_down(); + +#ifdef CONFIG_APBH_DMA + /* Start APBH DMA */ + mxs_dma_init(); +#endif + + set_epdc_qos(); + + return 0; +} + +#ifdef CONFIG_BOARD_POSTCLK_INIT +int board_postclk_init(void) +{ + /* + * We do not need to set LDO_SOC as i.mx6, since LDO_ARM and LDO_SOC + * does not exist. Check "Figure 7-9. i.MX7Dual Power Diagram" + */ + return 0; +} +#endif + +#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + serialnr->low = fuse->tester0; + serialnr->high = fuse->tester1; +} +#endif + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ +#if defined(CONFIG_SYS_ARM_CACHE_WRITETHROUGH) + enum dcache_option option = DCACHE_WRITETHROUGH; +#else + enum dcache_option option = DCACHE_WRITEBACK; +#endif + + /* Avoid random hang when download by usb */ + invalidate_dcache_all(); + + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); + + /* Enable caching on OCRAM and ROM */ + mmu_set_region_dcache_behaviour(ROMCP_ARB_BASE_ADDR, + ROMCP_ARB_END_ADDR, + option); + mmu_set_region_dcache_behaviour(IRAM_BASE_ADDR, + IRAM_SIZE, + option); +} +#endif + +#if defined(CONFIG_FEC_MXC) +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[9]; + struct fuse_bank9_regs *fuse = + (struct fuse_bank9_regs *)bank->fuse_regs; + + if (0 == dev_id) { + u32 value = readl(&fuse->mac_addr1); + mac[0] = (value >> 8); + mac[1] = value; + + value = readl(&fuse->mac_addr0); + mac[2] = value >> 24; + mac[3] = value >> 16; + mac[4] = value >> 8; + mac[5] = value; + } else { + u32 value = readl(&fuse->mac_addr2); + mac[0] = value >> 24; + mac[1] = value >> 16; + mac[2] = value >> 8; + mac[3] = value; + + value = readl(&fuse->mac_addr1); + mac[4] = value >> 24; + mac[5] = value >> 16; + } +} +#endif + +void boot_mode_apply(uint32_t cfg_val) +{ + uint32_t reg; + writel(cfg_val, &src_reg->gpr9); + reg = readl(&src_reg->gpr10); + if (cfg_val) + reg |= 1 << 28; + else + reg &= ~(1 << 28); + writel(reg, &src_reg->gpr10); +} + +void set_wdog_reset(struct wdog_regs *wdog) +{ + u32 reg = readw(&wdog->wcr); + /* + * Output WDOG_B signal to reset external pmic or POR_B decided by + * the board desgin. Without external reset, the peripherals/DDR/ + * PMIC are not reset, that may cause system working abnormal. + */ + reg = readw(&wdog->wcr); + reg |= 1 << 3; + /* + * WDZST bit is write-once only bit. Align this bit in kernel, + * otherwise kernel code will have no chance to set this bit. + */ + reg |= 1 << 0; + writew(reg, &wdog->wcr); +} + +/* + * cfg_val will be used for + * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0] + * to SBMR1, which will determine the boot device. + */ +const struct boot_mode soc_boot_modes[] = { + {"ecspi1:0", MAKE_CFGVAL(0x00, 0x60, 0x00, 0x00)}, + {"ecspi1:1", MAKE_CFGVAL(0x40, 0x62, 0x00, 0x00)}, + {"ecspi1:2", MAKE_CFGVAL(0x80, 0x64, 0x00, 0x00)}, + {"ecspi1:3", MAKE_CFGVAL(0xc0, 0x66, 0x00, 0x00)}, + + {"weim", MAKE_CFGVAL(0x00, 0x50, 0x00, 0x00)}, + {"qspi1", MAKE_CFGVAL(0x10, 0x40, 0x00, 0x00)}, + /* 4 bit bus width */ + {"usdhc1", MAKE_CFGVAL(0x10, 0x10, 0x00, 0x00)}, + {"usdhc2", MAKE_CFGVAL(0x10, 0x14, 0x00, 0x00)}, + {"usdhc3", MAKE_CFGVAL(0x10, 0x18, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x10, 0x20, 0x00, 0x00)}, + {"mmc2", MAKE_CFGVAL(0x10, 0x24, 0x00, 0x00)}, + {"mmc3", MAKE_CFGVAL(0x10, 0x28, 0x00, 0x00)}, + {NULL, 0}, +}; + +enum boot_device get_boot_device(void) +{ + struct bootrom_sw_info **p = + (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + + enum boot_device boot_dev = SD1_BOOT; + u8 boot_type = (*p)->boot_dev_type; + u8 boot_instance = (*p)->boot_dev_instance; + + switch (boot_type) { + case BOOT_TYPE_SD: + boot_dev = boot_instance + SD1_BOOT; + break; + case BOOT_TYPE_MMC: + boot_dev = boot_instance + MMC1_BOOT; + break; + case BOOT_TYPE_NAND: + boot_dev = NAND_BOOT; + break; + case BOOT_TYPE_QSPI: + boot_dev = QSPI_BOOT; + break; + case BOOT_TYPE_WEIM: + boot_dev = WEIM_NOR_BOOT; + break; + case BOOT_TYPE_SPINOR: + boot_dev = SPI_NOR_BOOT; + break; + default: + break; + } + + return boot_dev; +} + +void s_init(void) +{ +#if !defined CONFIG_SPL_BUILD + /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ + asm volatile( + "mrc p15, 0, r0, c1, c0, 1\n" + "orr r0, r0, #1 << 6\n" + "mcr p15, 0, r0, c1, c0, 1\n"); +#endif + /* clock configuration. */ + clock_init(); + + return; +} + +void reset_misc(void) +{ +#ifdef CONFIG_VIDEO_MXS + lcdif_power_down(); +#endif +} diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 4715f4e..e0b4bc8 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -12,6 +12,7 @@ #define MXC_CPU_MX6Q 0x63 #define MXC_CPU_MX6D 0x64 #define MXC_CPU_MX6SOLO 0x65 /* dummy ID */ +#define MXC_CPU_MX7D 0x72
#define CS0_128 0 #define CS0_64M_CS1_64M 1 diff --git a/arch/arm/include/asm/imx-common/boot_mode.h b/arch/arm/include/asm/imx-common/boot_mode.h index de0205c..62dd01d 100644 --- a/arch/arm/include/asm/imx-common/boot_mode.h +++ b/arch/arm/include/asm/imx-common/boot_mode.h @@ -9,6 +9,27 @@ #define MAKE_CFGVAL(cfg1, cfg2, cfg3, cfg4) \ ((cfg4) << 24) | ((cfg3) << 16) | ((cfg2) << 8) | (cfg1)
+enum boot_device { + WEIM_NOR_BOOT, + ONE_NAND_BOOT, + PATA_BOOT, + SATA_BOOT, + I2C_BOOT, + SPI_NOR_BOOT, + SD1_BOOT, + SD2_BOOT, + SD3_BOOT, + SD4_BOOT, + MMC1_BOOT, + MMC2_BOOT, + MMC3_BOOT, + MMC4_BOOT, + NAND_BOOT, + QSPI_BOOT, + UNKNOWN_BOOT, + BOOT_DEV_NUM = UNKNOWN_BOOT, +}; + struct boot_mode { const char *name; unsigned cfg_val;
* HAB secure boot support - get_hab_status: checks if secure boot is enabled or not - authenticate_image: verifies image properly signed based on CSF entry * Uboot command for hab authenticate - hab_auth_img: authenticate image via HAB - hab_status: display HAB status
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Split from patch imx: imx7d: initial arch level support Changes for V3: Resend
arch/arm/cpu/armv7/mx7/Makefile | 9 ++ arch/arm/cpu/armv7/mx7/hab.c | 277 ++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx7/hab.h | 69 +++++++++ 3 files changed, 355 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/Makefile create mode 100644 arch/arm/cpu/armv7/mx7/hab.c create mode 100644 arch/arm/include/asm/arch-mx7/hab.h
diff --git a/arch/arm/cpu/armv7/mx7/Makefile b/arch/arm/cpu/armv7/mx7/Makefile new file mode 100644 index 0000000..d36501d --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# +# + +obj-y := soc.o clock.o clock_slice.o +obj-$(CONFIG_SECURE_BOOT) += hab.o diff --git a/arch/arm/cpu/armv7/mx7/hab.c b/arch/arm/cpu/armv7/mx7/hab.c new file mode 100644 index 0000000..43b06bd --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/hab.c @@ -0,0 +1,277 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hab.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +/* -------- start of HAB API updates ------------*/ +#define hab_rvt_report_event_p \ +( \ + ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT) \ +) + +#define hab_rvt_report_status_p \ +( \ + ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS) \ +) + +#define hab_rvt_authenticate_image_p \ +( \ + ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE) \ +) + +#define hab_rvt_entry_p \ +( \ + ((hab_rvt_entry_t *)HAB_RVT_ENTRY) \ +) + +#define hab_rvt_exit_p \ +( \ + ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ +) + +#define IVT_SIZE 0x20 +#define ALIGN_SIZE 0x1000 +#define CSF_PAD_SIZE 0x2000 + +/* + * +------------+ 0x0 (DDR_UIMAGE_START) - + * | Header | | + * +------------+ 0x40 | + * | | | + * | | | + * | | | + * | | | + * | Image Data | | + * . | | + * . | > Stuff to be authenticated ----+ + * . | | | + * | | | | + * | | | | + * +------------+ | | + * | | | | + * | Fill Data | | | + * | | | | + * +------------+ Align to ALIGN_SIZE | | + * | IVT | | | + * +------------+ + IVT_SIZE - | + * | | | + * | CSF DATA | <---------------------------------------------------------+ + * | | + * +------------+ + * | | + * | Fill Data | + * | | + * +------------+ + CSF_PAD_SIZE + */ + +bool is_hab_enabled(void) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + uint32_t reg = readl(&fuse->cfg0); + + return (reg & 0x2000000) == 0x2000000; +} + +void display_event(uint8_t *event_data, size_t bytes) +{ + uint32_t i; + + if (!(event_data && bytes > 0)) + return; + + for (i = 0; i < bytes; i++) { + if (i == 0) + printf("\t0x%02x", event_data[i]); + else if ((i % 8) == 0) + printf("\n\t0x%02x", event_data[i]); + else + printf(" 0x%02x", event_data[i]); + } +} + +int get_hab_status(void) +{ + uint32_t index = 0; /* Loop index */ + uint8_t event_data[128]; /* Event data buffer */ + size_t bytes = sizeof(event_data); /* Event size in bytes */ + enum hab_config config = 0; + enum hab_state state = 0; + hab_rvt_report_event_t *hab_rvt_report_event; + hab_rvt_report_status_t *hab_rvt_report_status; + + if (is_hab_enabled()) + puts("\nSecure boot enabled\n"); + else + puts("\nSecure boot disabled\n"); + + hab_rvt_report_event = hab_rvt_report_event_p; + hab_rvt_report_status = hab_rvt_report_status_p; + + /* Check HAB status */ + if (hab_rvt_report_status(&config, &state) != HAB_SUCCESS) { + printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", + config, state); + + /* Display HAB Error events */ + while (hab_rvt_report_event(HAB_FAILURE, index, event_data, + &bytes) == HAB_SUCCESS) { + puts("\n"); + printf("--------- HAB Event %d -----------------\n", + index + 1); + puts("event data:\n"); + display_event(event_data, bytes); + puts("\n"); + bytes = sizeof(event_data); + index++; + } + } + /* Display message if no HAB events are found */ + else { + printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", + config, state); + puts("No HAB Events Found!\n\n"); + } + return 0; +} + +#ifdef DEBUG_AUTHENTICATE_IMAGE +void dump_mem(uint32_t addr, int size) +{ + int i; + + for (i = 0; i < size; i += 4) { + if (i != 0) { + if (i % 16 == 0) + printf("\n"); + else + printf(" "); + } + + printf("0x%08x", *(uint32_t *)addr); + addr += 4; + } + + printf("\n"); + + return; +} +#endif + +uint32_t authenticate_image(uint32_t ddr_start, uint32_t image_size) +{ + uint32_t load_addr = 0; + size_t bytes; + ptrdiff_t ivt_offset = 0; + int result = 0; + ulong start; + hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; + hab_rvt_entry_t *hab_rvt_entry; + hab_rvt_exit_t *hab_rvt_exit; + + hab_rvt_authenticate_image = hab_rvt_authenticate_image_p; + hab_rvt_entry = hab_rvt_entry_p; + hab_rvt_exit = hab_rvt_exit_p; + + if (is_hab_enabled()) { + printf("\nAuthenticate uImage from DDR location 0x%x...\n", + ddr_start); + + hab_caam_clock_enable(1); + + if (hab_rvt_entry() == HAB_SUCCESS) { + /* If not already aligned, Align to ALIGN_SIZE */ + ivt_offset = (image_size + ALIGN_SIZE - 1) & + ~(ALIGN_SIZE - 1); + + start = ddr_start; + bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; + +#ifdef DEBUG_AUTHENTICATE_IMAGE + printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", + ivt_offset, ddr_start + ivt_offset); + printf("Dumping IVT\n"); + dump_mem(ddr_start + ivt_offset, 0x20); + + printf("Dumping CSF Header\n"); + dump_mem(ddr_start + ivt_offset + 0x20, 0x40); + + get_hab_status(); + + printf("\nCalling authenticate_image in ROM\n"); + printf("\tivt_offset = 0x%x\n\tstart = 0x%08x" + "\n\tbytes = 0x%x\n", ivt_offset, start, bytes); +#endif + load_addr = (uint32_t)hab_rvt_authenticate_image( + HAB_CID_UBOOT, + ivt_offset, (void **)&start, + (size_t *)&bytes, NULL); + if (hab_rvt_exit() != HAB_SUCCESS) { + printf("hab exit function fail\n"); + load_addr = 0; + } + } else + printf("hab entry function fail\n"); + + hab_caam_clock_enable(0); + + get_hab_status(); + } + + if ((!is_hab_enabled()) || (load_addr != 0)) + result = 1; + + return result; +} + +int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if ((argc != 1)) { + cmd_usage(cmdtp); + return 1; + } + + get_hab_status(); + + return 0; +} + +static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + ulong addr, ivt_offset; + int rcode = 0; + + if (argc < 3) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[1], NULL, 16); + ivt_offset = simple_strtoul(argv[2], NULL, 16); + + rcode = authenticate_image(addr, ivt_offset); + + return rcode; +} + +U_BOOT_CMD( + hab_status, CONFIG_SYS_MAXARGS, 1, do_hab_status, + "display HAB status", + "" + ); + +U_BOOT_CMD( + hab_auth_img, 3, 1, do_authenticate_image, + "authenticate image via HAB", + "addr ivt_offset\n" + "addr - image hex address\n" + "ivt_offset - hex offset of IVT in the image" + ); diff --git a/arch/arm/include/asm/arch-mx7/hab.h b/arch/arm/include/asm/arch-mx7/hab.h new file mode 100644 index 0000000..fa29c78 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/hab.h @@ -0,0 +1,69 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. All Rights Reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + * +*/ + +#ifndef __SECURE_MX7_H__ +#define __SECURE_MX7_H__ + +#include <linux/types.h> + +/* -------- start of HAB API updates ------------*/ +/* The following are taken from HAB4 SIS */ + +/* Status definitions */ +enum hab_status { + HAB_STS_ANY = 0x00, + HAB_FAILURE = 0x33, + HAB_WARNING = 0x69, + HAB_SUCCESS = 0xf0 +}; + +/* Security Configuration definitions */ +enum hab_config { + HAB_CFG_RETURN = 0x33, /**< Field Return IC */ + HAB_CFG_OPEN = 0xf0, /**< Non-secure IC */ + HAB_CFG_CLOSED = 0xcc /**< Secure IC */ +}; + +/* State definitions */ +enum hab_state { + HAB_STATE_INITIAL = 0x33, /**< Initialising state (transitory) */ + HAB_STATE_CHECK = 0x55, /**< Check state (non-secure) */ + HAB_STATE_NONSECURE = 0x66, /**< Non-secure state */ + HAB_STATE_TRUSTED = 0x99, /**< Trusted state */ + HAB_STATE_SECURE = 0xaa, /**< Secure state */ + HAB_STATE_FAIL_SOFT = 0xcc, /**< Soft fail state */ + HAB_STATE_FAIL_HARD = 0xff, /**< Hard fail state (terminal) */ + HAB_STATE_NONE = 0xf0, /**< No security state machine */ + HAB_STATE_MAX +}; + +/*Function prototype description*/ +typedef enum hab_status hab_rvt_report_event_t(enum hab_status, uint32_t, + uint8_t* , size_t*); +typedef enum hab_status hab_rvt_report_status_t(enum hab_config *, + enum hab_state *); +typedef enum hab_status hab_loader_callback_f_t(void**, size_t*, const void*); +typedef enum hab_status hab_rvt_entry_t(void); +typedef enum hab_status hab_rvt_exit_t(void); +typedef void *hab_rvt_authenticate_image_t(uint8_t, ptrdiff_t, + void **, size_t *, hab_loader_callback_f_t); +typedef void hapi_clock_init_t(void); + +#define HAB_RVT_UNIFIED_BASE 0x00000100 +#define HAB_RVT_ENTRY (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x04)) +#define HAB_RVT_EXIT (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x08)) +#define HAB_RVT_AUTHENTICATE_IMAGE (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x10)) +#define HAB_RVT_REPORT_EVENT (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x20)) +#define HAB_RVT_REPORT_STATUS (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x24)) + +#define HAB_RVT_CLOCK_INIT ((hapi_clock_init_t *)0x0000024D) + +#define HAB_CID_ROM 0 /**< ROM Caller ID */ +#define HAB_CID_UBOOT 1 /**< UBOOT Caller ID*/ +/* ----------- end of HAB API updates ------------*/ + +#endif
* Add timer support for imx7d SoC
arch/arm/imx-common/timer.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/imx-common/timer.c b/arch/arm/imx-common/timer.c index c12556a..bc4a673 100644 --- a/arch/arm/imx-common/timer.c +++ b/arch/arm/imx-common/timer.c @@ -49,6 +49,8 @@ static inline int gpt_has_clk_source_osc(void) return 1;
return 0; +#elif defined(CONFIG_MX7) + return 1; #else return 0; #endif @@ -56,6 +58,9 @@ static inline int gpt_has_clk_source_osc(void)
static inline ulong gpt_get_clk(void) { +#if defined(CONFIG_MX7) + return MXC_HCLK >> 3; +#else #ifdef CONFIG_MXC_GPT_HCLK if (gpt_has_clk_source_osc()) return MXC_HCLK >> 3; @@ -64,6 +69,7 @@ static inline ulong gpt_get_clk(void) #else return MXC_CLK32; #endif +#endif } static inline unsigned long long tick_to_time(unsigned long long tick) { @@ -106,7 +112,8 @@ int timer_init(void) /* For DL/S, SX, set 24Mhz OSC Enable bit and prescaler */ if (is_cpu_type(MXC_CPU_MX6DL) || is_cpu_type(MXC_CPU_MX6SOLO) || - is_cpu_type(MXC_CPU_MX6SX)) { + is_cpu_type(MXC_CPU_MX6SX) || + is_cpu_type(MXC_CPU_MX7D)) { i |= GPTCR_24MEN;
/* Produce 3Mhz clock */
* Add imx-common cpu support for imx7d SoC * Update reset_cause for imx7d * Enable watchdog driver built for imx7d
arch/arm/Makefile | 4 ++-- arch/arm/cpu/armv7/Makefile | 3 ++- arch/arm/imx-common/Makefile | 17 ++++++++++++++--- arch/arm/imx-common/cpu.c | 17 +++++++++++++++++ drivers/watchdog/Makefile | 2 +- 5 files changed, 36 insertions(+), 7 deletions(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 6f30098..6708140 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -78,11 +78,11 @@ libs-y += arch/arm/cpu/ libs-y += arch/arm/lib/
ifeq ($(CONFIG_SPL_BUILD),y) -ifneq (,$(CONFIG_MX23)$(CONFIG_MX35)$(filter $(SOC), mx25 mx27 mx5 mx6 mx31 mx35)) +ifneq (,$(CONFIG_MX23)$(CONFIG_MX35)$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx31 mx35)) libs-y += arch/arm/imx-common/ endif else -ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx31 mx35 mxs vf610)) +ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx31 mx35 mxs vf610)) libs-y += arch/arm/imx-common/ endif endif diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 5a76100..8defb1b 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -12,7 +12,7 @@ obj-y += cache_v7.o obj-y += cpu.o cp15.o obj-y += syslib.o
-ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_ARCH_SOCFPGA),) +ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_MX7)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_ARCH_SOCFPGA),) ifneq ($(CONFIG_SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif @@ -45,6 +45,7 @@ obj-$(CONFIG_ARCH_EXYNOS) += exynos/ obj-$(if $(filter ls102xa,$(SOC)),y) += ls102xa/ obj-$(if $(filter mx5,$(SOC)),y) += mx5/ obj-$(CONFIG_MX6) += mx6/ +obj-$(CONFIG_MX7) += mx7/ obj-$(CONFIG_OMAP34XX) += omap3/ obj-$(CONFIG_OMAP44XX) += omap4/ obj-$(CONFIG_OMAP54XX) += omap5/ diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index b9f1ca4..99bec53 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -7,20 +7,31 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 vf610)) +ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 mx7 vf610)) obj-y = iomux-v3.o endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) -obj-y += timer.o cpu.o speed.o +obj-y += cpu.o speed.o obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o endif -ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) +ifeq ($(SOC),$(filter $(SOC),mx5)) +obj-y += timer.o +endif +ifeq ($(SOC),$(filter $(SOC),mx7)) +obj-y += cpu.o +obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o +obj-$(CONFIG_GPT_TIMER) += timer.o +obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o +endif +ifeq ($(SOC),$(filter $(SOC),mx7 mx6 mxs)) obj-y += misc.o obj-$(CONFIG_SPL_BUILD) += spl.o endif ifeq ($(SOC),$(filter $(SOC),mx6)) obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o +obj-$(CONFIG_GPT_TIMER) += timer.o +obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o endif ifeq ($(SOC),$(filter $(SOC),vf610)) obj-y += ddrmc-vf610.o diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 2e803f3..3cd30e7 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -46,13 +46,26 @@ static char *get_reset_cause(void) case 0x00008: return "IPP USER"; case 0x00010: +#ifdef CONFIG_MX7 + return "WDOG1"; +#else return "WDOG"; +#endif case 0x00020: return "JTAG HIGH-Z"; case 0x00040: return "JTAG SW"; +#ifdef CONFIG_MX7 + case 0x00080: + return "WDOG3"; + case 0x00100: + return "WDOG4"; + case 0x00200: + return "TEMPSENSE"; +#else case 0x10000: return "WARM BOOT"; +#endif default: return "unknown reset"; } @@ -122,6 +135,8 @@ unsigned imx_ddr_size(void) const char *get_imx_type(u32 imxtype) { switch (imxtype) { + case MXC_CPU_MX7D: + return "7D"; /* Dual-core version of the mx7 */ case MXC_CPU_MX6Q: return "6Q"; /* Quad-core version of the mx6 */ case MXC_CPU_MX6D: @@ -236,6 +251,7 @@ int cpu_mmc_init(bd_t *bis) } #endif
+#ifndef CONFIG_MX7 u32 get_ahb_clk(void) { struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -247,6 +263,7 @@ u32 get_ahb_clk(void)
return get_periph_clk() / (ahb_podf + 1); } +#endif
void arch_preboot_os(void) { diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 482a4bd..9e9cb55 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -7,7 +7,7 @@
obj-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o obj-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o -ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 vf610 ls102xa)) +ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 mx7 vf610 ls102xa)) obj-y += imx_watchdog.o endif obj-$(CONFIG_S5P) += s5p_wdt.o
* Add i.MX7D SABRESD target board support with enabled modules: UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX.
Build target: mx7dsabresd_config
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: - Include arch/arm/Kconfig target config option Changes for V3: - Update target board maintainer contact info
arch/arm/Kconfig | 7 + board/freescale/mx7dsabresd/Kconfig | 15 + board/freescale/mx7dsabresd/MAINTAINERS | 6 + board/freescale/mx7dsabresd/Makefile | 6 + board/freescale/mx7dsabresd/imximage.cfg | 103 +++++ board/freescale/mx7dsabresd/mx7dsabresd.c | 642 ++++++++++++++++++++++++++++++ configs/mx7dsabresd_defconfig | 10 + include/configs/mx7_common.h | 22 + include/configs/mx7dsabresd.h | 355 +++++++++++++++++ 9 files changed, 1166 insertions(+) create mode 100644 board/freescale/mx7dsabresd/Kconfig create mode 100644 board/freescale/mx7dsabresd/MAINTAINERS create mode 100644 board/freescale/mx7dsabresd/Makefile create mode 100644 board/freescale/mx7dsabresd/imximage.cfg create mode 100644 board/freescale/mx7dsabresd/mx7dsabresd.c create mode 100644 configs/mx7dsabresd_defconfig create mode 100644 include/configs/mx7_common.h create mode 100644 include/configs/mx7dsabresd.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 506463c..40aabb6 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -578,6 +578,12 @@ config TARGET_MX6SXSABRESD select DM select DM_THERMAL
+config TARGET_MX7DSABRESD + bool "Support mx7dsabresd" + select CPU_V7 + select DM + select DM_THERMAL + config TARGET_GW_VENTANA bool "Support gw_ventana" select CPU_V7 @@ -923,6 +929,7 @@ source "board/freescale/mx6qsabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" source "board/freescale/mx6slevk/Kconfig" source "board/freescale/mx6sxsabresd/Kconfig" +source "board/freescale/mx7dsabresd/Kconfig" source "board/freescale/vf610twr/Kconfig" source "board/gateworks/gw_ventana/Kconfig" source "board/genesi/mx51_efikamx/Kconfig" diff --git a/board/freescale/mx7dsabresd/Kconfig b/board/freescale/mx7dsabresd/Kconfig new file mode 100644 index 0000000..d7c6ae4 --- /dev/null +++ b/board/freescale/mx7dsabresd/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX7DSABRESD + +config SYS_BOARD + default "mx7dsabresd" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "mx7" + +config SYS_CONFIG_NAME + default "mx7dsabresd" + +endif diff --git a/board/freescale/mx7dsabresd/MAINTAINERS b/board/freescale/mx7dsabresd/MAINTAINERS new file mode 100644 index 0000000..3910ee4 --- /dev/null +++ b/board/freescale/mx7dsabresd/MAINTAINERS @@ -0,0 +1,6 @@ +MX7DSABRESD BOARD +M: Adrian Alonso aalonso@freescale.com +S: Maintained +F: board/freescale/mx7dsabresd +F: include/configs/mx7dsabresd.h +F: configs/mx7dsabresd_defconfig diff --git a/board/freescale/mx7dsabresd/Makefile b/board/freescale/mx7dsabresd/Makefile new file mode 100644 index 0000000..14336ab --- /dev/null +++ b/board/freescale/mx7dsabresd/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx7dsabresd.o diff --git a/board/freescale/mx7dsabresd/imximage.cfg b/board/freescale/mx7dsabresd/imximage.cfg new file mode 100644 index 0000000..5088d0e --- /dev/null +++ b/board/freescale/mx7dsabresd/imximage.cfg @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +#ifdef CONFIG_SYS_BOOT_QSPI +BOOT_FROM qspi +#elif defined(CONFIG_SYS_BOOT_EIMNOR) +BOOT_FROM nor +#else +BOOT_FROM sd +#endif + +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +DATA 4 0x30340004 0x4F400005 + +DATA 4 0x30391000 0x00000002 +DATA 4 0x307a0000 0x03040001 +DATA 4 0x307a01a0 0x80400003 +DATA 4 0x307a01a4 0x00100020 +DATA 4 0x307a01a8 0x80100004 +DATA 4 0x307a0064 0x0040005e +DATA 4 0x307a0490 0x00000001 +DATA 4 0x307a00d0 0x00020001 +DATA 4 0x307a00d4 0x00010000 +DATA 4 0x307a00dc 0x09300004 +DATA 4 0x307a00e0 0x04080000 +DATA 4 0x307a00e4 0x00090004 +DATA 4 0x307a00f4 0x0000033f +DATA 4 0x307a0100 0x0908120a +DATA 4 0x307a0104 0x0002020e +DATA 4 0x307a0108 0x03040407 +DATA 4 0x307a010c 0x00002006 +DATA 4 0x307a0110 0x04020204 +DATA 4 0x307a0114 0x03030202 +DATA 4 0x307a0120 0x03030803 +DATA 4 0x307a0180 0x00800020 +DATA 4 0x307a0190 0x02098204 +DATA 4 0x307a0194 0x00030303 +DATA 4 0x307a0200 0x00000016 +DATA 4 0x307a0204 0x00171717 +DATA 4 0x307a0214 0x04040404 +DATA 4 0x307a0218 0x00040404 +DATA 4 0x307a0240 0x06000601 +DATA 4 0x307a0244 0x00001323 +DATA 4 0x30391000 0x00000000 +DATA 4 0x30790000 0x17420f40 +DATA 4 0x30790004 0x10210100 +DATA 4 0x30790010 0x00060807 +DATA 4 0x3079009c 0x00000d6e +DATA 4 0x30790020 0x08080808 +DATA 4 0x30790030 0x08080808 +DATA 4 0x30790050 0x01000010 +DATA 4 0x30790050 0x00000010 + +DATA 4 0x307900c0 0x0e407304 +DATA 4 0x307900c0 0x0e447304 +DATA 4 0x307900c0 0x0e447306 + +CHECK_BITS_SET 4 0x307900c4 0x1 + +DATA 4 0x307900c0 0x0e447304 +DATA 4 0x307900c0 0x0e407304 + +DATA 4 0x30384130 0x00000000 +DATA 4 0x30340020 0x00000178 +DATA 4 0x30384130 0x00000002 +DATA 4 0x30790018 0x0000000f + +CHECK_BITS_SET 4 0x307a0004 0x1 diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c new file mode 100644 index 0000000..1d5928f --- /dev/null +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -0,0 +1,642 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx7-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/io.h> +#include <linux/sizes.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <miiphy.h> +#include <netdev.h> +#include <power/pmic.h> +#include <power/pfuze3000_pmic.h> +#include "../common/pfuze.h" +#include <i2c.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/arch/crm_regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ + PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) +#define ENET_PAD_CTRL_MII (PAD_CTL_DSE_3P3V_32OHM) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) + +#define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM) + +#define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_PU100KOHM | \ + PAD_CTL_DSE_3P3V_49OHM) + +#define QSPI_PAD_CTRL \ + (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +#define SPI_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define BUTTON_PAD_CTRL (PAD_CTL_PUS_PU5KOHM | PAD_CTL_DSE_3P3V_98OHM) + +#define NAND_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU5KOHM) + +#ifdef CONFIG_SYS_I2C_MXC +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +/* I2C1 for PMIC */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX7D_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = MX7D_PAD_I2C1_SCL__GPIO4_IO8 | PC, + .gp = IMX_GPIO_NR(4, 8), + }, + .sda = { + .i2c_mode = MX7D_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = MX7D_PAD_I2C1_SDA__GPIO4_IO9 | PC, + .gp = IMX_GPIO_NR(4, 9), + }, +}; +#endif + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +static iomux_v3_cfg_t const wdog_pads[] = { + MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart1_pads[] = { + MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + MX7D_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + MX7D_PAD_SD1_CD_B__GPIO5_IO0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_RESET_B__GPIO5_IO2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc3_emmc_pads[] = { + MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_STROBE__SD3_STROBE | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + MX7D_PAD_SD3_RESET_B__GPIO6_IO11 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +#define IOX_SDI IMX_GPIO_NR(1, 9) +#define IOX_STCP IMX_GPIO_NR(1, 12) +#define IOX_SHCP IMX_GPIO_NR(1, 13) + +static iomux_v3_cfg_t const iox_pads[] = { + /* IOX_SDI */ + MX7D_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_STCP */ + MX7D_PAD_GPIO1_IO12__GPIO1_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_SHCP */ + MX7D_PAD_GPIO1_IO13__GPIO1_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* + * PCIE_DIS_B --> Q0 + * PCIE_RST_B --> Q1 + * HDMI_RST_B --> Q2 + * PERI_RST_B --> Q3 + * SENSOR_RST_B --> Q4 + * ENET_RST_B --> Q5 + * PERI_3V3_EN --> Q6 + * LCD_PWR_EN --> Q7 + */ +enum qn { + PCIE_DIS_B, + PCIE_RST_B, + HDMI_RST_B, + PERI_RST_B, + SENSOR_RST_B, + ENET_RST_B, + PERI_3V3_EN, + LCD_PWR_EN, +}; + +enum qn_func { + qn_reset, + qn_enable, + qn_disable, +}; + +enum qn_level { + qn_low = 0, + qn_high = 1, +}; + +static enum qn_level seq[3][2] = { + {0, 1}, {1, 1}, {0, 0} +}; + +static enum qn_func qn_output[8] = { + qn_disable, qn_reset, qn_reset, qn_reset, qn_reset, qn_reset, qn_enable, + qn_enable +}; + +void iox74lv_init(void) +{ + int i; + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); +}; + +void iox74lv_set(int index) +{ + int i; + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + + if (i == index) + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + else + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); +}; + +#ifdef CONFIG_SYS_USE_NAND +static iomux_v3_cfg_t const gpmi_pads[] = { + MX7D_PAD_SD3_DATA0__NAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA1__NAND_DATA01 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA2__NAND_DATA02 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA3__NAND_DATA03 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA4__NAND_DATA04 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA5__NAND_DATA05 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA6__NAND_DATA06 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA7__NAND_DATA07 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_CLK__NAND_CLE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_CMD__NAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_STROBE__NAND_RE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_RESET_B__NAND_WE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_MCLK__NAND_WP_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_BCLK__NAND_CE3_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_SYNC__NAND_CE2_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_DATA__NAND_CE1_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_SYNC__NAND_DQS | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_DATA__NAND_READY_B | MUX_PAD_CTRL(NAND_PAD_READY0_CTRL), +}; + +static void setup_gpmi_nand(void) +{ + imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads)); + + /* + * NAND_USDHC_BUS_CLK is set in rom + */ + + set_clk_nand(); + + /* + * APBH clock root is set in init_esdhc, USDHC3_CLK. + * There is no clk gate for APBHDMA. + * No touch here. + */ +} +#endif + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const fec1_pads[] = { + MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_GPIO1_IO10__ENET1_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), + MX7D_PAD_GPIO1_IO11__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); +} +#endif + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#ifdef CONFIG_FSL_QSPI +static iomux_v3_cfg_t const quadspi_pads[] = { + MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL), +}; + +int board_qspi_init(void) +{ + /* Set the iomux */ + imx_iomux_v3_setup_multiple_pads(quadspi_pads, ARRAY_SIZE(quadspi_pads)); + + /* Set the clock */ + set_clk_qspi(); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 0) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(5, 2) +#define USDHC3_PWR_GPIO IMX_GPIO_NR(6, 11) + +static struct fsl_esdhc_cfg usdhc_cfg[3] = { + {USDHC1_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR}, +}; + +static int mmc_get_env_devno(void) +{ + struct bootrom_sw_info **p = + (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + + u8 boot_type = (*p)->boot_dev_type; + u8 dev_no = (*p)->boot_dev_instance; + + /* If not boot from sd/mmc, use default value */ + if ((boot_type != BOOT_TYPE_SD) && (boot_type != BOOT_TYPE_MMC)) + return CONFIG_SYS_MMC_ENV_DEV; + + if (2 == dev_no) + dev_no--; + + return dev_no; +} + +static int mmc_map_to_kernel_blk(int dev_no) +{ + if (1 == dev_no) + dev_no++; + + return dev_no; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = 1; /* Assume uSDHC3 emmc is always present */ + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc2 USDHC3 (eMMC) + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_CD_GPIO, "usdhc1_cd"); + gpio_direction_input(USDHC1_CD_GPIO); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_pwr"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc3_emmc_pads, ARRAY_SIZE(usdhc3_emmc_pads)); + gpio_request(USDHC3_PWR_GPIO, "usdhc3_pwr"); + gpio_direction_output(USDHC3_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC3_PWR_GPIO, 1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +int check_mmc_autodetect(void) +{ + char *autodetect_str = getenv("mmcautodetect"); + + if ((autodetect_str != NULL) && + (strcmp(autodetect_str, "yes") == 0)) { + return 1; + } + + return 0; +} + +void board_late_mmc_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_devno(); + + if (!check_mmc_autodetect()) + return; + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", + mmc_map_to_kernel_blk(dev_no)); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} + +#endif + +#ifdef CONFIG_FEC_MXC +int board_eth_init(bd_t *bis) +{ + int ret; + + setup_iomux_fec(); + + ret = fecmxc_initialize_multi(bis, 0, + CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); + if (ret) + printf("FEC1 MXC: %s:failed\n", __func__); + + return ret; +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *const iomuxc_gpr_regs + = (struct iomuxc_gpr_base_regs *) IOMUXC_GPR_BASE_ADDR; + + /* Use 125M anatop REF_CLK1 for ENET1, clear gpr1[13], gpr1[17]*/ + clrsetbits_le32(&iomuxc_gpr_regs->gpr[1], + (IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK | + IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK), 0); + + return set_clk_enet(ENET_125MHz); +} + + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x21); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x7ea8); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x2f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x71b7); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + imx_iomux_v3_setup_multiple_pads(iox_pads, ARRAY_SIZE(iox_pads)); + + iox74lv_init(); + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#ifdef CONFIG_SYS_USE_NAND + setup_gpmi_nand(); +#endif + +#ifdef CONFIG_FSL_QSPI + board_qspi_init(); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd1", MAKE_CFGVAL(0x10, 0x10, 0x00, 0x00)}, + {"emmc", MAKE_CFGVAL(0x10, 0x2a, 0x00, 0x00)}, + /* TODO: Nand */ + {"qspi", MAKE_CFGVAL(0x00, 0x40, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +#ifdef CONFIG_POWER +#define I2C_PMIC 0 +int power_init_board(void) +{ + struct pmic *p; + int ret; + unsigned int reg, rev_id; + + ret = power_pfuze3000_init(I2C_PMIC); + if (ret) + return ret; + + p = pmic_get("PFUZE3000"); + ret = pmic_probe(p); + if (ret) + return ret; + + pmic_reg_read(p, PFUZE3000_DEVICEID, ®); + pmic_reg_read(p, PFUZE3000_REVID, &rev_id); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); + + /* disable Low Power Mode during standby mode */ + pmic_reg_read(p, PFUZE3000_LDOGCTL, ®); + reg |= 0x1; + pmic_reg_write(p, PFUZE3000_LDOGCTL, reg); + + return 0; +} +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + +#ifdef CONFIG_ENV_IS_IN_MMC + board_late_mmc_init(); +#endif + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset((struct wdog_regs *)WDOG1_BASE_ADDR); + + return 0; +} + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int checkboard(void) +{ + puts("Board: i.MX7D SABRESD\n"); + + return 0; +} + +#ifdef CONFIG_USB_EHCI_MX7 +iomux_v3_cfg_t const usb_otg1_pads[] = { + MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const usb_otg2_pads[] = { + MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_ehci_hcd_init(int port) +{ + switch (port) { + case 0: + imx_iomux_v3_setup_multiple_pads(usb_otg1_pads, + ARRAY_SIZE(usb_otg1_pads)); + break; + case 1: + imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, + ARRAY_SIZE(usb_otg2_pads)); + break; + default: + printf("MXC USB port %d not yet supported\n", port); + return -EINVAL; + } + return 0; +} +#endif diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig new file mode 100644 index 0000000..879847c --- /dev/null +++ b/configs/mx7dsabresd_defconfig @@ -0,0 +1,10 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg,MX7D" +CONFIG_ARM=y +CONFIG_TARGET_MX7DSABRESD=y +CONFIG_SYS_MALLOC_F=y +CONFIG_SYS_MALLOC_F_LEN=0x400 +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h new file mode 100644 index 0000000..25f79f3 --- /dev/null +++ b/include/configs/mx7_common.h @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX7. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#ifndef __MX7_COMMON_H +#define __MX7_COMMON_H + +#define CONFIG_BOARD_POSTCLK_INIT +#define CONFIG_MXC_GPT_HCLK + +#define CONFIG_SYSCOUNTER_TIMER +#define CONFIG_SC_TIMER_CLK 8000000 /* 8Mhz */ + +#define CONFIG_IOMUX_LPSR +#define CONFIG_IMX_FIXED_IVT_OFFSET + +#endif diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h new file mode 100644 index 0000000..b84590a --- /dev/null +++ b/include/configs/mx7dsabresd.h @@ -0,0 +1,355 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX7D SABRESD board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MX7D_SABRESD_CONFIG_H +#define __MX7D_SABRESD_CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx7_common.h" +#include <asm/imx-common/gpio.h> + +#define CONFIG_MX7 +#define CONFIG_ROM_UNIFIED_SECTIONS +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_DBG_MONITOR +/* uncomment for PLUGIN mode support */ +/* #define CONFIG_USE_PLUGIN */ + +/* uncomment for SECURE mode support */ +/* #define CONFIG_SECURE_BOOT */ + +#ifdef CONFIG_SECURE_BOOT +#ifndef CONFIG_CSF_SIZE +#define CONFIG_CSF_SIZE 0x4000 +#endif +#endif + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_CMD_FUSE +#ifdef CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP +#endif + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define PHYS_SDRAM_SIZE SZ_1G + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 + +#define CONFIG_PHYLIB +#define CONFIG_PHY_BROADCOM +#define CONFIG_FEC_DMA_MINALIGN 64 + +/* ENET1 */ +#define IMX_FEC_BASE ENET_IPS_BASE_ADDR + +/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE3000 +#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 + +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_PLAN9 +#undef CONFIG_BOOTM_RTEMS + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV + +/* I2C configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_SPEED 100000 + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x80800000 +#define CONFIG_SYS_TEXT_BASE 0x87800000 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 +#ifdef CONFIG_SYS_BOOT_NAND +#define CONFIG_MFG_NAND_PARTITION "mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs) " +#else +#define CONFIG_MFG_NAND_PARTITION "" +#endif + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "rdinit=/linuxrc " \ + "g_mass_storage.stall=0 g_mass_storage.removable=1 " \ + "g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF "\ + "g_mass_storage.iSerialNumber="" "\ + CONFIG_MFG_NAND_PARTITION \ + "clk_ignore_unused "\ + "\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffff\0" \ + "bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};\0" \ + +#if defined(CONFIG_SYS_BOOT_NAND) +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + "fdt_addr=0x83000000\0" \ + "fdt_high=0xffffffff\0" \ + "console=ttymxc0\0" \ + "bootargs=console=ttymxc0,115200 ubi.mtd=3 " \ + "root=ubi0:rootfs rootfstype=ubifs " \ + "mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs)\0"\ + "bootcmd=nand read ${loadaddr} 0x4000000 0x800000;"\ + "nand read ${fdt_addr} 0x5000000 0x100000;"\ + "bootz ${loadaddr} - ${fdt_addr}\0" + +#else +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx7d-sdb.dtb\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" +#endif + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 256 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x20000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE SZ_8K + +#ifdef CONFIG_SYS_BOOT_QSPI +#define CONFIG_SYS_USE_QSPI +#define CONFIG_ENV_IS_IN_SPI_FLASH +#elif defined CONFIG_SYS_BOOT_NAND +#define CONFIG_SYS_USE_NAND +#define CONFIG_ENV_IS_IN_NAND +#else +#define CONFIG_ENV_IS_IN_MMC +#endif + +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS + +/* NAND stuff */ +#define CONFIG_NAND_MXS +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* DMA stuff, needed for GPMI/MXS NAND support */ +#define CONFIG_APBH_DMA +#define CONFIG_APBH_DMA_BURST +#define CONFIG_APBH_DMA_BURST8 +#endif + +#ifdef CONFIG_SYS_USE_QSPI +#define CONFIG_FSL_QSPI /* enable the QUADSPI driver */ +#define CONFIG_QSPI_BASE QSPI1_IPS_BASE_ADDR +#define CONFIG_QSPI_MEMMAP_BASE QSPI0_ARB_BASE_ADDR + +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_MACRONIX +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 40000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#endif + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#elif defined(CONFIG_ENV_IS_IN_NAND) +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET (8 << 20) +#define CONFIG_ENV_SECT_SIZE (128 << 10) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#endif + +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#else +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#endif +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ +#define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */ + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#define CONFIG_CMD_BMODE + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX7 +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +#define CONFIG_IMX_THERMAL + +#endif /* __CONFIG_H */
Adrian Alonso
Alonso Adrian
Stefano Babic
