[U-Boot] Porting U-Boot Issue - Linking fails
I'm attempting to port u-boot for NS7520 (arm7tdmi). My idea was to first revive the port of NS9750 (removed in commit4cfc611b4a4ce009cfad46804bec2a1caad8e329) and then rename and configure it for NS7520 which is quite similar. But I've kind of hit a wall, that I don't understand.
=========================================================== git clean -dfx > /dev/null && make ns9750dev_config all .... LDS u-boot.lds LD u-boot arm-linux-gnueabi-ld.bfd: BFD (GNU Binutils for Ubuntu) 2.23.2 assertion fail ../../bfd/elf32-arm.c:7683 arm-linux-gnueabi-ld.bfd: error: required section '.rel.plt' not found in the linker script arm-linux-gnueabi-ld.bfd: final link failed: Invalid operation make[1]: *** [u-boot] Error 1 ===========================================================
At first I thought this issue was thou to the toolchain I used. I expressed these thoughts in #u-boot@freenode, but no matter which toolchain I use, I always get this error, for this port. (Other configurations that are similar builds without any noticeable issues.)
I have tried the following toolchains 1. ELDK-5.5 armv5te 2. arm-linux-gnueabi from gcc-arm-linux-gnueabi package 3. arm-none-eabi from gcc-arm-none-eabi package (ppa:terry.guo/gcc-embedded)
All resulting in the same build error. I have also tried using all three different linkers that comes with the gcc-arm-linux-gnueabi package (ld, ld.bfd and ld.gold), all of this also fails in the same way.
So all in all, it feels highly unlikely that this is a compiler issue. It is rather something with the code (https://github.com/soderstrom-rikard/u-boot/tree/ns9750)
Off course I've tried just adding the section .rel.plt to the linker description script, this had no effect either. I mimicked patch lists.denx.de/pipermail/u-boot/2010-November/081709.html
Can anyone help me? I feel so clueless about this, that it is ridiculous :)
Yours Sincerely Rikard Söderström
-- View this message in context: http://u-boot.10912.n7.nabble.com/Porting-U-Boot-Issue-Linking-fails-tp17624... Sent from the U-Boot mailing list archive at Nabble.com.
soderstrom
