[U-Boot-Users] how to support usbtty
becides set CONFIG_USB_TTY, what other modification need to do for the usbtty support?
thanks for any hints
You will probably have to adapt "drivers/usbtty.c"; so far it's pretty omap1510-specifc. Also, you may have to write your own USB bus interface driver (see drivers/usbdcore_omap1510.c).
Any document on how to use usbtty?
I have a USB-RS232 cable to convert the USB port into a RS232 port. Do I need any driver? What environment variable shall I set?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "No matter where you go, there you are..." - Buckaroo Banzai
SF.Net email is sponsored by: Tame your development challenges with Apache's Geronimo App Server. Download it for free - -and be entered to win a 42" plasma tv or your very own Sony(tm)PSP. Click here to play: http://sourceforge.net/geronimo.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Dear mikezh,
Did you read the README?
You enable it using the commands "setenv stdout usbtty; setenv stdin usbtty"
If you want to attach the cable to a USB port on the target that runs U-Boot, you obviously need the matching usbtty driver for your hardware.
I am using an embedded system with MPC8567 as processor and ISP1561 as USB PCI host controller. There is USB port on this board. A sealevel USB/RS232 cable is connect to the USB port on the board, and it converts USB port into RS232 port. A PC is connected to the RS232 end of the cable.
With "CONFIG_USB_SERIAL_FTDI_SIO" flag enabled, I compiled the Linux kernel. Everything works fine, I am able to launch the hyperterminal on PC and have the console running for Linux.
Now I need make things working for Uboot. I've already have the EHCI host controller running well on the board.
Please correct me if my understanding is incorrect. What I need to do is to port the FTDI_SIO driver from Linux to Uboot, which replace those "udc" calls in usbtty.c. With the ported FTDI_SIO code and existing usbtty.c. It shall work fine after correct setup of the environment variables - "setenv stdin usbtty, setenv stdout usbtty".
Or is there any other solution for me? I don't have to use the USB-RS232 cable. I just need the Uboot console from USB port.
Thanks,
On 8/26/08, Wolfgang Denk wd@denx.de wrote:
Dear mikezh,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de God made the integers; all else is the work of Man. - Kronecker
That really depends on what you mean by "replace".
usbtty at this moment in time is slave only. What you are describing is having u-boot be a USB host, and control a usbserial device attached to the u-boot/host.
usbtty - is basically analogous to the firmware that would run inside of your USB-2-RS232 cable, in that it - uboot- is a USB slave, at the usbtty layer.
Not that I've looked in detail but, whatever way USB sticks are controlled by USB hosts in u-boot would be closer to what you'd need to do to support having a USB-slave tty device attached to your board, then subsequently you'd plug this into the serial layer of u-boot.
Possibly you could add the usbserial and cdc-acm protocols supported in usbtty.. depending .. but, it's important to be aware that usbtty in u-boot is a slave oriented thing.
For the case above - you'd need to implement drivers/usbdcore_isp1561.c - but .. this would have to be a USB host... not a slave.
Since a USB host model already exists in u-boot - I'm not sure making usbdcore_isp1561.c would be a wise or acceptable choice.
For example usbdcore_mpc8xx.c and it's sibling usbdcore_omap1510.c - enumerate a USB host... - they're completely slave oriented... whereas - you need for u-boot to be the host like drivers/usb/isp116x-hcd.c (perhaps a isp1516-hcd.c is required), then you need to plug your FTDI stuff on top of that, then you need to plug that into the u-boot serial layer, somehow...
Sure it might be possible and appropriate to have [usbtty.c=>fdti]=>isp1516-hdc.c but, the low-level USB twiddling you need to do at the host controller level will be quite different for the host - which is what I think you need to do... in comparison to the slave - which is what usbdcore_mpc8xx.c and usbdcore_omap1510.c are.
Greetings, Bryan
One more thing.
If the isp1561 supports "slave" mode - you can implement usbdcore_isp1561.c and add fdti to usbtty... otherwise as previously stated you'll have to munge something on top of some host controller code, and then plug that into the serial layer independently.
-- BOD
Hi Bryan,
The USB/RS232 cable is a USB device, it shall has firmware in it, which works as a USB slave. What I need to do is have some code talk to this device via the Host controller - ISP1561. So, I need some code as usb-storage.c, maybe called usb-serial.c.
I am not sure how "usbtty" being used. Is it used when there is a USB/USB cable connected between the target and PC? Both ends of the cable are USB port, the PC end is a master, the target end is the slave. So usbtty running on the target is acting as the USB device. However it is not my case. The cable I have has one USB end, and one RS232 end. The USB end is connected to the target. I assume there is something in the chip within the cable acts as a USB slave device already.
Thanks,
Mike
One more thing.
-- BOD
On Fri, 29 Aug 2008 11:53:45 -0400 "mike zheng" mail4mz@gmail.com wrote:
Hi Bryan,
Almost certainly.
Yes. Think of usbtty being equivalent to the firmware that runs inside of that USB/RS232 cable you have.
It allows u-boot to be a USB slave and provide a console interface over the USB, to a USB host somewhere.
Understood.
A bit of firmware implementing either some FDTI-specific USB protocol stuff to emulate UART over the USB, or just simply following the USB standard for this => cdc-acm.
And again you're right - you'll need to be implementing a host side USB serial driver for u-boot.
Alternatively if the ISP1561 can do device mode - you could have your PC be master and just implement the usbdcore_isp1561.c for u-boot and then use either the usbserial or cdc-acm USB protocol to talk to the USB host. In this case you could use the code in usbtty to plug into the u-boot console system - and just implement whatever is required to make the isp1561 be a well behaved u-boot USB slave.
Most embedded USB transceivers these days to both host and slave - so it'd probably be worth looking into this option ?
In either case it might be interesting to plug your host-side stuff into usbtty.c in u-boot - though it's unclear to me if there'd be more or less pain for you in the long run !
-- Bryan
Hi Bryan,
Almost certainly.
Understood.
-- Bryan
I will try a standalone host side USB serial driver for u-boot at first.
For the alternatively solution, it is very interesting. Then we don't need the USB/RS232 convertor at all. Just a USB/USB cable connect PC and target with Uboot. I just wonder anyone tried the usbtty.c on a target with MPC85xx processor? What OS on PC has been verified, Windows or Linux? Is there any document on it?
Cheers,
Mike
Not with that processor specifically.
Linux and Windows both support cdc-acm, though you do have to install the CDC-ACM driver on Windows from .cab files.
Linux supports usbserial but, Windows, does not.
participants (5)
Bryan O'Donoghue
mike zheng
mikezh
zhuzhenhua
