[U-Boot] [PATCH] AT91:mmc:fix multiple read/write error
According to datasheet,set block count before multiple read/write.
Signed-off-by: elen.song elen.song@atmel.com --- drivers/mmc/atmel_mci.h | 9 ++++++++- drivers/mmc/gen_atmel_mci.c | 4 ++++ 2 files changed, 12 insertions(+), 1 deletions(-)
diff --git a/drivers/mmc/atmel_mci.h b/drivers/mmc/atmel_mci.h index 90ab6a8..3095d22 100644 --- a/drivers/mmc/atmel_mci.h +++ b/drivers/mmc/atmel_mci.h @@ -36,7 +36,7 @@ typedef struct atmel_mci { u32 sdcr; /* 0x0c */ u32 argr; /* 0x10 */ u32 cmdr; /* 0x14 */ - u32 _18; /* 0x18 */ + u32 blkr; /* 0x18 */ u32 _1c; /* 0x1c */ u32 rspr; /* 0x20 */ u32 rspr1; /* 0x24 */ @@ -67,6 +67,7 @@ typedef struct atmel_mci { #define MMCI_SDCR 0x000c #define MMCI_ARGR 0x0010 #define MMCI_CMDR 0x0014 +#define MMCI_BLKR 0x0018 #define MMCI_RSPR 0x0020 #define MMCI_RSPR1 0x0024 #define MMCI_RSPR2 0x0028 @@ -140,6 +141,12 @@ typedef struct atmel_mci { #define MMCI_TRTYP_OFFSET 19 #define MMCI_TRTYP_SIZE 2
+/* Bitfields in BLKR */ +#define MMCI_BCNT_OFFSET 0 +#define MMCI_BCNT_SIZE 16 +#define MMCI_BLKLEN_OFFSET 16 +#define MMCI_BLKLEN_SIZE 16 + /* Bitfields in RSPRx */ #define MMCI_RSP_OFFSET 0 #define MMCI_RSP_SIZE 32 diff --git a/drivers/mmc/gen_atmel_mci.c b/drivers/mmc/gen_atmel_mci.c index f346b24..d217574 100644 --- a/drivers/mmc/gen_atmel_mci.c +++ b/drivers/mmc/gen_atmel_mci.c @@ -183,6 +183,10 @@ mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) /* Figure out the transfer arguments */ cmdr = mci_encode_cmd(cmd, data, &error_flags);
+ if (data) + writel(MMCI_BF(BCNT, data->blocks) | + MMCI_BF(BLKLEN, mmc->read_bl_len), &mci->blkr); + /* Send the command */ writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr);
Dear Andy, dear Elen,
- u32 blkr; /* 0x18 */ u32 _1c; /* 0x1c */ u32 rspr; /* 0x20 */ u32 rspr1; /* 0x24 */
- if (data)
- /* Send the command */ writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr);
I find it highly irregular that this patch has made it into mainline!
1. We have had a discussion about that I think the approach in this patch is wrong. My concerns have not been addressed yet.
2. This is clearly an ATMEL domain/custodian patch.
3. I was not put on CC by Elen.
4. Andy snapped it away and applied it without sending an "Applied to" message.
Best Regards, Reinhard
- We have had a discussion about that I think the approach in this
I have seen no such discussion. I saw no comments on this patch, so I applied it. In an idea world, I would read all of the u-boot list messages, but in reality I filter heavily, and often only look for messages in the same thread as the patch when deciding whether to apply (it was also a fairly simple-seeming patch).
- This is clearly an ATMEL domain/custodian patch.
It's also clearly an MMC domain/custodian patch, as the changes rest solely within the MMC directory.
- I was not put on CC by Elen.
Elen should have put you on CC, I agree.
- Andy snapped it away and applied it without sending an "Applied to"
message.
I should have sent the message, but it wouldn't have affected things, much. The gap between application and pull request tends to be fairly short. Could you point me to the discussion, so I can see your objections? I'd be happy to revert the patch.
Andy Fleming
elen.song
Reinhard Meyer
