[PATCH 0/2] ARM: meson: libretech-ac: add suppor for EFI Capsules Update
The necessary changes were made in U-Boot to easily support EFI Capsules Update and be compliant with Arm SystemReady SR.
Let's add support for the libretech-ac/AML-S805X-CC since it's an easy well-supported target having a dedicated SPI Flash to store U-Boot.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Neil Armstrong (2): board: libretech-ac: move board support into dedicated directory board: libre-computer: aml-s805-cc: Enable capsule updates
board/amlogic/p212/MAINTAINERS | 2 - board/libre-computer/aml-s805x-ac/MAINTAINERS | 8 ++++ board/libre-computer/aml-s805x-ac/Makefile | 6 +++ board/libre-computer/aml-s805x-ac/aml-s805x-ac.c | 61 ++++++++++++++++++++++++ configs/libretech-ac_defconfig | 7 +++ 5 files changed, 82 insertions(+), 2 deletions(-) --- base-commit: df84c019c46e6833cc79385bdb23efba4882c09d change-id: 20240916-u-boot-topic-dynamic-uuid-a871c25236a4
The libretech-ac aka aml-s805x-ac supports mainline U-boot from a dedicated SPI flash, move the board support into a dedicated vendor/board subdirectory in order to support vendor specific customization.
It also aligns with the vendor downstream changes.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- board/amlogic/p212/MAINTAINERS | 2 - board/libre-computer/aml-s805x-ac/MAINTAINERS | 8 ++++ board/libre-computer/aml-s805x-ac/Makefile | 6 +++ board/libre-computer/aml-s805x-ac/aml-s805x-ac.c | 47 ++++++++++++++++++++++++ configs/libretech-ac_defconfig | 2 + 5 files changed, 63 insertions(+), 2 deletions(-)
diff --git a/board/amlogic/p212/MAINTAINERS b/board/amlogic/p212/MAINTAINERS index b2e3205fdf0..e73a4e52c1f 100644 --- a/board/amlogic/p212/MAINTAINERS +++ b/board/amlogic/p212/MAINTAINERS @@ -5,11 +5,9 @@ L: u-boot-amlogic@groups.io F: board/amlogic/p212/ F: include/configs/p212.h F: configs/khadas-vim_defconfig -F: configs/libretech-ac_defconfig F: configs/libretech-cc_defconfig F: configs/libretech-cc_v2_defconfig F: configs/p212_defconfig F: doc/board/amlogic/p212.rst -F: doc/board/amlogic/libretech-ac.rst F: doc/board/amlogic/libretech-cc.rst F: doc/board/amlogic/khadas-vim.rst diff --git a/board/libre-computer/aml-s805x-ac/MAINTAINERS b/board/libre-computer/aml-s805x-ac/MAINTAINERS new file mode 100644 index 00000000000..7cbc08aeb6c --- /dev/null +++ b/board/libre-computer/aml-s805x-ac/MAINTAINERS @@ -0,0 +1,8 @@ +LIBRE-COMPUTER AML-S805X-AC +M: Neil Armstrong neil.armstrong@linaro.org +S: Maintained +L: u-boot-amlogic@groups.io +F: board/amlogic/aml-s805x-ac/ +F: include/configs/libretech-ac.h +F: configs/libretech-ac_defconfig +F: doc/board/amlogic/libretech-ac.rst diff --git a/board/libre-computer/aml-s805x-ac/Makefile b/board/libre-computer/aml-s805x-ac/Makefile new file mode 100644 index 00000000000..b4367ea522b --- /dev/null +++ b/board/libre-computer/aml-s805x-ac/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 BayLibre, SAS +# Author: Neil Armstrong narmstrong@baylibre.com + +obj-y := aml-s805x-ac.o diff --git a/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c b/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c new file mode 100644 index 00000000000..ae9834c0bf8 --- /dev/null +++ b/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include <dm.h> +#include <env.h> +#include <init.h> +#include <net.h> +#include <asm/io.h> +#include <asm/arch/gx.h> +#include <asm/arch/sm.h> +#include <asm/arch/eth.h> +#include <asm/arch/mem.h> + +#define EFUSE_SN_OFFSET 20 +#define EFUSE_SN_SIZE 16 +#define EFUSE_MAC_OFFSET 52 +#define EFUSE_MAC_SIZE 6 + +int misc_init_r(void) +{ + u8 mac_addr[EFUSE_MAC_SIZE + 1]; + char serial[EFUSE_SN_SIZE + 1]; + ssize_t len; + + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { + len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, + mac_addr, EFUSE_MAC_SIZE); + mac_addr[len] = '\0'; + if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) + eth_env_set_enetaddr("ethaddr", mac_addr); + else + meson_generate_serial_ethaddr(); + } + + if (!env_get("serial#")) { + len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, + EFUSE_SN_SIZE); + serial[len] = '\0'; + if (len == EFUSE_SN_SIZE) + env_set("serial#", serial); + } + + return 0; +} diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index 6ad04570022..11d9795e05d 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="libretech-ac" +CONFIG_SYS_VENDOR="libre-computer" +CONFIG_SYS_BOARD="aml-s805x-ac" CONFIG_ARCH_MESON=y CONFIG_TEXT_BASE=0x01000000 CONFIG_NR_DRAM_BANKS=1
Since the aml-s805-cc works well using EFI, and now the capsule updates backend has been merged, let's enable the missing configs and add the required structures to support it.
The GUID is dynamically generated for the board, to get it: => efidebug capsule esrt ======================================== ESRT: fw_resource_count=1 ESRT: fw_resource_count_max=1 ESRT: fw_resource_version=1 [entry 0]============================== ESRT: fw_class=B8079027-9B2C-57D4-86AA-CC782ADA598C ESRT: fw_type=unknown ESRT: fw_version=0 ESRT: lowest_supported_fw_version=0 ESRT: capsule_flags=0 ESRT: last_attempt_version=0 ESRT: last_attempt_status=success ========================================
On the host (with the aml_encrypt_gxl result binary): $ eficapsule --guid B8079027-9B2C-57D4-86AA-CC782ADA598C -i 1 u-boot.bin u-boot.cap
On the board (from USB disk containing u-boot.cap at root): => load usb 0:1 $kernel_addr_r u-boot.cap => efidebug capsule update $kernel_addr_r
The binary will then be flashed on the SPI.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- board/libre-computer/aml-s805x-ac/aml-s805x-ac.c | 14 ++++++++++++++ configs/libretech-ac_defconfig | 5 +++++ 2 files changed, 19 insertions(+)
diff --git a/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c b/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c index ae9834c0bf8..ba14df54967 100644 --- a/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c +++ b/board/libre-computer/aml-s805x-ac/aml-s805x-ac.c @@ -8,6 +8,7 @@ #include <env.h> #include <init.h> #include <net.h> +#include <efi_loader.h> #include <asm/io.h> #include <asm/arch/gx.h> #include <asm/arch/sm.h> @@ -19,6 +20,19 @@ #define EFUSE_MAC_OFFSET 52 #define EFUSE_MAC_SIZE 6
+struct efi_fw_image fw_images[] = { + { + .fw_name = u"AML_S805X_AC_BOOT", + .image_index = 1, + }, +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "sf 0:0=u-boot-bin raw 0 0x10000", + .num_images = ARRAY_SIZE(fw_images), + .images = fw_images, +}; + int misc_init_r(void) { u8 mac_addr[EFUSE_MAC_SIZE + 1]; diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index 11d9795e05d..f146a495654 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_MAXARGS=32 # CONFIG_CMD_IMI is not set CONFIG_CMD_ADC=y CONFIG_CMD_DFU=y +CONFIG_CMD_NVEDIT_EFI=y CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y @@ -42,6 +43,7 @@ CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_EFIDEBUG=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -49,6 +51,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SARADC_MESON=y CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_MMC_MESON_GX=y CONFIG_MTD=y CONFIG_DM_MTD=y @@ -98,3 +101,5 @@ CONFIG_VIDEO_BMP_RLE8=y CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
Thanks Neil!
On Mon, 16 Sept 2024 at 12:41, Neil Armstrong neil.armstrong@linaro.org wrote:
.image_index = 1,
-- 2.34.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
On 16/09/2024 18:29, Tom Rini wrote:
To be clear, "SR" or "IR" ? I assume you meant IR here.
Indeed IR, I'll fix in v2, I need to send a v2 because I need to add set_dfu_alt_info() to keep support for the ram backed dfu I used when booting from USB.
Thanks, Neil
Ilias Apalodimas
Neil Armstrong
