[U-Boot] [PATCH v2] ppc4xx: Changed 460EX/GT OCM TLB and internal SRAM initialization
Expanded OCM TLB to allow access to 64K OCM as well as 256K of internal SRAM.
Adjusted internal SRAM initialization to match updated user manual recommendation.
OCM & ISRAM are now mapped as follows: physical virtual size ISRAM 0x4_0000_0000 0xE300_0000 256k OCM 0x4_0004_0000 0xE304_0000 64k
A single TLB was used for this mapping.
Signed-off-by: Dave Mitchell dmitch71@gmail.com --- board/amcc/canyonlands/init.S | 2 +- cpu/ppc4xx/start.S | 27 ++++++++++++++++++++------- include/configs/canyonlands.h | 2 +- 3 files changed, 22 insertions(+), 9 deletions(-)
diff --git a/board/amcc/canyonlands/init.S b/board/amcc/canyonlands/init.S index 12dead3..b7ea59c 100644 --- a/board/amcc/canyonlands/init.S +++ b/board/amcc/canyonlands/init.S @@ -89,7 +89,7 @@ tlbtab: #endif
/* TLB-entry for OCM */ - tlbentry(CFG_OCM_BASE, SZ_16K, 0x00040000, 4, AC_R|AC_W|AC_X|SA_I) + tlbentry(CFG_OCM_BASE, SZ_1M, 0x00000000, 4, AC_R|AC_W|AC_X|SA_I)
/* TLB-entry for Local Configuration registers => peripherals */ tlbentry(CFG_LOCAL_CONF_REGS, SZ_16M, CFG_LOCAL_CONF_REGS, 4, AC_R|AC_W|AC_X|SA_G|SA_I) diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index a22520e..4d282f1 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -678,9 +678,12 @@ _start: /* not all PPC's have internal SRAM usable as L2-cache */ #if defined(CONFIG_440GX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ - defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_460SX) mtdcr L2_CACHE_CFG,r0 /* Ensure L2 Cache is off */ +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) + lis r1, 0x0000 + ori r1,r1,0x0008 /* Set L2_CACHE_CFG[RDBW]=1 */ + mtdcr L2_CACHE_CFG,r1 #endif
lis r2,0x7fff @@ -705,8 +708,8 @@ _start: lis r1, 0x8003 ori r1,r1, 0x0980 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#elif defined(CONFIG_440SPE) - lis r1,0x0000 /* BAS = 0000_0000 */ +#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || defined(CONFIG_460GT) + lis r1,0x0000 /* BAS = X_0000_0000 */ ori r1,r1,0x0984 /* first 64k */ mtdcr ISRAM0_SB0CR,r1 lis r1,0x0001 @@ -718,10 +721,20 @@ _start: lis r1, 0x0003 ori r1,r1, 0x0984 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) - lis r1,0x4000 /* BAS = 8000_0000 */ - ori r1,r1,0x4580 /* 16k */ - mtdcr ISRAM0_SB0CR,r1 +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) + lis r2,0x7fff + ori r2,r2,0xffff + mfdcr r1,ISRAM1_DPC + and r1,r1,r2 /* Disable parity check */ + mtdcr ISRAM1_DPC,r1 + mfdcr r1,ISRAM1_PMEG + and r1,r1,r2 /* Disable pwr mgmt */ + mtdcr ISRAM1_PMEG,r1 + + lis r1,0x0004 /* BAS = 4_0004_0000 */ + ori r1,r1,0x0984 /* 64k */ + mtdcr ISRAM1_SB0CR,r1 +#endif #elif defined(CONFIG_460SX) lis r1,0x0000 /* BAS = 0000_0000 */ ori r1,r1,0x0B84 /* first 128k */ diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 5ab678a..d57e1b7 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -102,7 +102,7 @@ #define CFG_FLASH_BASE_PHYS (((u64)CFG_FLASH_BASE_PHYS_H << 32) | \ (u64)CFG_FLASH_BASE_PHYS_L)
-#define CFG_OCM_BASE 0xE3000000 /* OCM: 16k */ +#define CFG_OCM_BASE 0xE3000000 /* OCM: 64k */ #define CFG_SRAM_BASE 0xE8000000 /* SRAM: 256k */ #define CFG_LOCAL_CONF_REGS 0xEF000000
I changed CFG_OCM_BASE to CONFIG_SYS_OCM_BASE manually.
Applied to 4xx/master. Thanks.
Best regards, Stefan
Dave Mitchell
Stefan Roese
