[U-Boot-Users] API for serial functions
is there a document that outlines the exact expected behavior of the serial functions ? specifically, i'm looking to see if the serial_putc() function is supposed to wait until the character it is given has been fully transmitted over the wire, or if it is simply required to queue the character up into the hardware fifo and then return ... -mike
Dear Mike,
There is no such document...
While it's not a strict requirement, I would expect that you wait until the charatcer has been sent. You have toi add some wait anway - either at the start or at the end of the function, and from the debugging point of view it makes more sense to wait for completion before continuing. Performancewise there will be no difference, I think.
On Monday 01 October 2007, Wolfgang Denk wrote:
Dear Mike,
oh well :/
the optimal performance method would be at the start of serial_putc(), spin until a byte has opened up in the hardware fifo, and then queue it up and return ... in the normal path, the leading spin would probably not execute even once as the hardware can go faster than people can type :)
then in the serial_setbrg() function (what does "brg" stand for anyways?), spin until both the fifo and the transmit register are empty so that you dont go changing the baud rate while a character is in the middle of transmission ...
the current Blackfin serial driver posts a character into the fifo and then spins until both the fifo and the transmit register is empty ... if there is no higher level API dictacting the requirement (and my quick tests here seem to back that up), then i'll just scrub the code and gain a little bit of speed and lose a few bytes in code size :)
thanks ! -mike
Hi Mike,
I doubt that you will increase the "performance" notably by removing this check in the serial_putc routine. Please keep in mind that U-Boot is a bootloader, and while executing "printf" the CPU has nothing else to do.
But you will loose some debug functionality when removing this check, since you can't use printf anymore for debugging and really be sure, that the received output in your terminal program matches the CPU state.
So I vote for not removing this transmitter empty check.
Best regards, Stefan
On Monday 01 October 2007, Stefan Roese wrote:
Hi Mike,
i'm not claiming this is going to turn a 100mhz proc into 1000mhz proc or something, but in the tail end of writing to the UART, you would free up the CPU to continue ... and the processor tends to be a lot faster than the speed of a UART, so it could chew through a sizable chunk of code before the UART finishes shifting out a single byte ... and depending on the hardware, you could be talking about 1 byte, 5 bytes, or more
maybe ... you'd have to mess up the processor pretty bad such that it breaks the peripherals ... the UART in a Blackfin acts independently of the core
i'd note that this is pretty inconsistent across different ports ...
so when do you return ? after making sure the byte has moved from the core to the peripheral hardware ? after making sure the byte has started to be shifted out from the peripheral onto the line ? after making sure the byte has been completed shifted onto the line ? the current Blackfin serial driver exhibits the last -- it waits until the whole byte has gone through the whole process, from core through the line -mike
So you might end up saving 1 or 5 or a few more milliseconds.
I agree with Stefan. Please don't change this. The current implemen- tation (wait until trasmit has completed) is what I prefer.
If that's how it was implemented, then leave it that way. It's OK.
np ... as for non-Blackfin ports, it isnt my code so i dont care ;)
there is plenty of code (on the Blackfin side) that was thrown together and left that way because "it just worked" rather than being correct ... so i dont buy the "this is how it was, so just leave it" argument
but if the behavior we want is "drain the byte completely across the line before returning", that's easy enough
thanks :) -mike
Maybe. But in reality, you won;t be able to see a differecne in performance.
But the code will be more complicated and have a higher footprint, which both is a con.
Baud Rate Generator. This origins from the initial implementation on MPC8xx systems...
I like this implementation. It's simple and straightforward, and you can rely on that the user has seen the caratcer on the line before the function returns. That's a good thing for initial debugging (board bring up).
Please don't.
Reduce code size? To me it seems the changes you described above would take more code.
the current code checks the hardware before sending the byte to the uart and then waits for it to drain ... i was looking at having just one check. but i guess you could argue that in theory, no byte should get into the uart that didnt come through serial_putc(), so the initial check is over kill and can be dropped -mike
Mike Frysinger
Stefan Roese
