[PATCH v2 0/1] introduce .editorconfig
Current process of sending patches includes running checkpatch.pl script for each patch, and fixing found style problems. Editorconfig may help to prevent some style related problems (like spaces vs tab indentation) on the fly.
Dzmitry Sankouski (1): editorconfig: introduce .editorconfig
.editorconfig | 15 +++++++++++++++ .gitignore | 1 + doc/develop/codingstyle.rst | 4 ++++ 3 files changed, 20 insertions(+) create mode 100644 .editorconfig
Current process of sending patches includes running checkpatch.pl script for each patch, and fixing found style problems. EditorConfig may help to prevent some style related problems (like spaces vs tab indentation) on the fly.
Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: - add section in coding style rst doc - unify Kconfig with other files
diff --git a/.editorconfig b/.editorconfig new file mode 100644 index 0000000000..10fe165f09 --- /dev/null +++ b/.editorconfig @@ -0,0 +1,15 @@ +; This file is for unifying the coding style for different editors and IDEs. +; Plugins are available for notepad++, emacs, vim, gedit, +; textmate, visual studio, and more. +; +; See http://editorconfig.org for details. + +# Top-most EditorConfig file. +root = true + +[{**.c, **.h, **Kconfig}] +indent_style = tab +indent_size=8 +end_of_line = lf +trim_trailing_whitespace = true +insert_final_newline = true diff --git a/.gitignore b/.gitignore index 3a4d056edf..ed8ca226fe 100644 --- a/.gitignore +++ b/.gitignore @@ -7,6 +7,7 @@ # .* !.checkpatch.conf +!.editorconfig *.a *.asn1.[ch] *.bin diff --git a/doc/develop/codingstyle.rst b/doc/develop/codingstyle.rst index 1d5d0192b3..741bc58b83 100644 --- a/doc/develop/codingstyle.rst +++ b/doc/develop/codingstyle.rst @@ -27,6 +27,10 @@ The following rules apply: more information, read :doc:`checkpatch`. Note that this should be done *before* posting on the mailing list!
+* Some code style rules may be applied automatically by your editor using + EditorConfig tool. Feel free to setup your editor to work with u-boot's + .editorconfig. + * Source files originating from different projects (for example the MTD subsystem or the hush shell code from the BusyBox project) may, after careful consideration, be exempted from these rules. For such files, the
Changes for v2:
As Simon noted before, this should be " = 8".
"using the"
- EditorConfig tool. Feel free to setup your editor to work with u-boot's
ср, 1 мар. 2023 г. в 18:58, Tom Rini trini@konsulko.com:
Changes for v2:
oops, I thought he meant consistent spacing in a sense of 8 spaces. I personally like Kconfigs with 4 indent more.
Changes for v2:
Ah. But, in both cases it should be 8, as well.
Hi Dzmitry,
You missed giving your Signed-off-by tag.
Dzmitry Sankouski
Fabio Estevam
