[PATCH v2] dm: core: Move "/chosen" and "/firmware" node scan
Use the new function dm_scan_fdt_ofnode_path() to scan all the nodes which aren't devices themselves but may contain some: - "/chosen" - "/clocks" - "/firmware"
The patch removes the strcmp call in recursive function dm_scan_fdt_live() and also corrects a conflict with the 2 applied patches in the commit 1712ca21924b ("dm: core: Scan /firmware node by default") and in the commit 747558d01457 ("dm: fdt: scan for devices under /firmware too"): the subnodes of "/firmware" (optee for example) are bound 2 times.
For example the dm tree command result on STM32MP1 is:
STM32MP> dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver firmware 0 [ ] psci |-- psci sysreset 0 [ ] psci-sysreset | `-- psci-sysreset simple_bus 0 [ + ] generic_simple_bus |-- soc ... tee 0 [ + ] optee |-- optee ... tee 1 [ ] optee `-- optee
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
Changes in v2: - update commit message (Serie-cc => Series-cc)
drivers/core/root.c | 52 +++++++++++++++------------------------------ 1 file changed, 17 insertions(+), 35 deletions(-)
diff --git a/drivers/core/root.c b/drivers/core/root.c index e85643819e..14df16c280 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -203,15 +203,6 @@ static int dm_scan_fdt_live(struct udevice *parent, int ret = 0, err;
for (np = node_parent->child; np; np = np->sibling) { - /* "chosen" node isn't a device itself but may contain some: */ - if (!strcmp(np->name, "chosen")) { - pr_debug("parsing subnodes of "chosen"\n"); - - err = dm_scan_fdt_live(parent, np, pre_reloc_only); - if (err && !ret) - ret = err; - continue; - }
if (!of_device_is_available(np)) { pr_debug(" - ignoring disabled device\n"); @@ -256,21 +247,6 @@ static int dm_scan_fdt_node(struct udevice *parent, const void *blob, offset = fdt_next_subnode(blob, offset)) { const char *node_name = fdt_get_name(blob, offset, NULL);
- /* - * The "chosen" and "firmware" nodes aren't devices - * themselves but may contain some: - */ - if (!strcmp(node_name, "chosen") || - !strcmp(node_name, "firmware")) { - pr_debug("parsing subnodes of "%s"\n", node_name); - - err = dm_scan_fdt_node(parent, blob, offset, - pre_reloc_only); - if (err && !ret) - ret = err; - continue; - } - if (!fdtdec_get_is_enabled(blob, offset)) { pr_debug(" - ignoring disabled device\n"); continue; @@ -315,7 +291,8 @@ int dm_scan_fdt(const void *blob, bool pre_reloc_only) return dm_scan_fdt_node(gd->dm_root, blob, 0, pre_reloc_only); }
-static int dm_scan_fdt_ofnode_path(const char *path, bool pre_reloc_only) +static int dm_scan_fdt_ofnode_path(const void *blob, const char *path, + bool pre_reloc_only) { ofnode node;
@@ -327,13 +304,18 @@ static int dm_scan_fdt_ofnode_path(const char *path, bool pre_reloc_only) if (of_live_active()) return dm_scan_fdt_live(gd->dm_root, node.np, pre_reloc_only); #endif - return dm_scan_fdt_node(gd->dm_root, gd->fdt_blob, node.of_offset, + return dm_scan_fdt_node(gd->dm_root, blob, node.of_offset, pre_reloc_only); }
int dm_extended_scan_fdt(const void *blob, bool pre_reloc_only) { - int ret; + int ret, i; + const char * const nodes[] = { + "/chosen", + "/clocks", + "/firmware" + };
ret = dm_scan_fdt(blob, pre_reloc_only); if (ret) { @@ -341,16 +323,16 @@ int dm_extended_scan_fdt(const void *blob, bool pre_reloc_only) return ret; }
- ret = dm_scan_fdt_ofnode_path("/clocks", pre_reloc_only); - if (ret) { - debug("scan for /clocks failed: %d\n", ret); - return ret; + /* Some nodes aren't devices themselves but may contain some */ + for (i = 0; i < ARRAY_SIZE(nodes); i++) { + ret = dm_scan_fdt_ofnode_path(blob, nodes[i], pre_reloc_only); + if (ret) { + debug("dm_scan_fdt() scan for %s failed: %d\n", + nodes[i], ret); + return ret; + } }
- ret = dm_scan_fdt_ofnode_path("/firmware", pre_reloc_only); - if (ret) - debug("scan for /firmware failed: %d\n", ret); - return ret; } #endif
čt 13. 2. 2020 v 19:48 odesílatel Patrick Delaunay patrick.delaunay@st.com napsal:
- "/chosen"
- "/clocks"
- "/firmware"
Changes in v2:
pr_debug("parsing subnodes of \"chosen\"\n");
if (err && !ret)
ret = err;
continue;
} if (!of_device_is_available(np)) { pr_debug(" - ignoring disabled device\n");
pr_debug("parsing subnodes of \"%s\"\n", node_name);
pre_reloc_only);
if (err && !ret)
ret = err;
continue;
{ ofnode node;
int ret;
int ret, i;
"/chosen",
"/clocks",
"/firmware"
}; ret = dm_scan_fdt(blob, pre_reloc_only); if (ret) {
if (ret) {
return ret;
if (ret) {
nodes[i], ret);
return ret;
if (ret)
return ret;
#endif
2.17.1
It looks good to me. I have reported here. https://lists.denx.de/pipermail/u-boot/2020-January/395427.html
Tested-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Hi Patrick,
On Thu, 13 Feb 2020 at 11:48, Patrick Delaunay patrick.delaunay@st.com wrote:
- "/chosen"
- "/clocks"
- "/firmware"
Changes in v2:
This looks good to me, but please can you address the test failure (make qcheck)?
From: Simon Glass sjg@chromium.org Sent: lundi 17 février 2020 04:56
Hi Patrick,
- "/chosen"
- "/clocks"
- "/firmware"
Changes in v2:
I forget to execute it, sorry.
Work in progress....
Patrick
Michal Simek
Patrick DELAUNAY
Patrick Delaunay
