[PATCH] usb: kbd: dwc2: Increase wait for dwc2 controller reset by 125us
Two following performance patches applied together occasionally harm usb keyboard on RPi3.
'dwc2: use the nonblock argument in submit_int_msg' commit 9dcab2c4d2cb50ab1864c818b82a72393c160236
'console: usb: kbd: Limit poll frequency to improve performance' commit 96991e652f541323a03c5b7e075d54a117091618
This empirically increased by sub-millisecond wait for dwc2 controller reset makes keyboard reliable.
Signed-off-by: Filip Zaludek filip.zaludek@oracle.com --- drivers/usb/host/dwc2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 23060fc369..71b66a52ed 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -764,7 +764,7 @@ static int dwc_otg_submit_rh_msg_out(struct dwc2_priv *priv, DWC2_HPRT0_PRTENCHNG | DWC2_HPRT0_PRTOVRCURRCHNG, DWC2_HPRT0_PRTRST); - mdelay(50); + udelay(50125); clrbits_le32(®s->hprt0, DWC2_HPRT0_PRTRST); break;
mdelay(50);
udelay(50125);
Why not just use 'mdelay(51);' ?
If you can tell me how to reproduce this , I could try and use USB bus analyzer (Beagle 5000) to look at his. I have RPi3 somewhere I think. Then we would know what's up.
But that might take a while, since I am a bit busy these days.
Hi Marek,
Unfortunately mdelay(51) does not work, what is actually strange. Be aware 'usb reset' might require 50 repetitions to reproduce, but usually it is reproduced under 20 cycles.
Prerequisities: * RPi3B or RPi3B+ * unplugged all usb devices except keyboard, (both usb 1.1 and 2.0 tested) * RPi3 connected to console and HDMI monitor, (monitor is not requirement) * u-boot from master compiled without debugging as it works as workaround (reproducible with current JeOS-20230110)
Refined reproducer: * Enter 'U-Boot>' shell using usb keyboard, (always works) * repeat 'usb reset' until usb keyboard responds, (press ENTER, or ARROW UP followed by ENTER [to see responsiveness]) * keyboard can be usually resurrected by subsequent 'usb reset' from console
Thanks, Filip
Hi Marek,
On 5/15/23 20:56, Filip Žaludek wrote:
Hi Marek,
Prerequisities:
- RPi3B or RPi3B+
- unplugged all usb devices except keyboard, (both usb 1.1 and 2.0 tested)
- RPi3 connected to console and HDMI monitor, (monitor is not requirement)
- u-boot from master compiled without debugging as it works as workaround (reproducible with current JeOS-20230110)
Refined reproducer:
- Enter 'U-Boot>' shell using usb keyboard, (always works)
- repeat 'usb reset' until usb keyboard responds, (press ENTER, or ARROW UP followed by ENTER [to see responsiveness])
- keyboard can be usually resurrected by subsequent 'usb reset' from console
Marek Vasut suggested CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y is another way how to deal with it, I can confirm. Thanks!
Not proposing changes to configs/rpi_3_* defaults, hopefully distributors are listening..
Regards, Filip
Filip Zaludek
Filip Žaludek
