[U-Boot] [PATCH v3 1/8] ppc: t2080qds: add eSDHC node
This patch is to add eSDHC node for t2080qds
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/t2080.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/powerpc/dts/t2080.dtsi b/arch/powerpc/dts/t2080.dtsi index db65ea5725..f895dda4d7 100644 --- a/arch/powerpc/dts/t2080.dtsi +++ b/arch/powerpc/dts/t2080.dtsi @@ -58,5 +58,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + interrupts = <48 2 0 0>; + clock-frequency = <0>; + sdhci,auto-cmd12; + bus-width = <4>; + voltage-ranges = <1800 1800 3300 3300>; + }; }; };
This patch is to set sdhc clock for ppc
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v3: (struct fsl_esdhc *)(addr) => (struct fsl_esdhc *)addr
drivers/mmc/fsl_esdhc.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 9e34557d16..88a5b0c46d 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -1428,7 +1428,9 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) #endif
#if CONFIG_IS_ENABLED(DM_MMC) +#ifndef CONFIG_PPC #include <asm/arch/clock.h> +#endif __weak void init_clk_usdhc(u32 index) { } @@ -1560,7 +1562,11 @@ static int fsl_esdhc_probe(struct udevice *dev)
priv->sdhc_clk = clk_get_rate(&priv->per_clk); } else { +#ifndef CONFIG_PPC priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); +#else + priv->sdhc_clk = gd->arch.sdhc_clk; +#endif if (priv->sdhc_clk <= 0) { dev_err(dev, "Unable to get clk for %s\n", dev->name); return -EINVAL;
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 2/8] mmc: fsl_esdhc: ppc: set sdhc clock
This patch has been applied to u-boot-mpc85xx, awaiting upstream.
--pk
This patch is to adopt 32 bit address for ppc
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v3: update the commit information
drivers/mmc/fsl_esdhc.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 88a5b0c46d..fc84d4b7ee 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -1455,8 +1455,11 @@ static int fsl_esdhc_probe(struct udevice *dev) addr = dev_read_addr(dev); if (addr == FDT_ADDR_T_NONE) return -EINVAL; - +#ifdef CONFIG_PPC + priv->esdhc_regs = (struct fsl_esdhc *)lower_32_bits(addr); +#else priv->esdhc_regs = (struct fsl_esdhc *)addr; +#endif priv->dev = dev; priv->mode = -1; if (data) {
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 3/8] mmc: fsl_esdhc: ppc: adopt 32 bit address
--pk
This patch is to enable device tree support for T2080QDS
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/T2080QDS_SECURE_BOOT_defconfig | 2 ++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 3 +++ 2 files changed, 5 insertions(+)
diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 9e155ee6ae..2658bf8460 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -50,3 +50,5 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_OF_LIBFDT=y +CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_DEFAULT_DEVICE_TREE="t2080qds" diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 9c9a436d81..8febabd84f 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -39,3 +39,6 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y +CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="t2080qds"
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 4/8] configs: enable device tree support for T2080QDS
--pk
This patch is to enable MMC DM for T2080QDS
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v3: Update the commit information
configs/T2080QDS_NAND_defconfig | 3 +++ configs/T2080QDS_SDCARD_defconfig | 3 +++ configs/T2080QDS_SECURE_BOOT_defconfig | 3 +++ configs/T2080QDS_SPIFLASH_defconfig | 3 +++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 3 +++ configs/T2080QDS_defconfig | 3 +++ 6 files changed, 18 insertions(+)
diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 948a05af89..02d47c9fdd 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -59,3 +59,6 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_DM=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 30e87df3bb..4ce83fe8c4 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -58,3 +58,6 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_DM=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 2658bf8460..e2a7d3fa76 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -52,3 +52,6 @@ CONFIG_RSA_SOFTWARE_EXP=y CONFIG_OF_LIBFDT=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_OF_CONTROL=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 0cccb3a85d..641f3c0c97 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -59,3 +59,6 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_DM=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 8febabd84f..d2a8875aac 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -42,3 +42,6 @@ CONFIG_OF_LIBFDT=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_DM=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 79cf4424b4..d55ce771a9 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -48,3 +48,6 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_BLK=y +CONFIG_DM=y
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 5/8] configs: enable eSDHC device module in T2080QDS
--pk
This patch is to add usb node for t2080qds
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/t2080.dtsi | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/arch/powerpc/dts/t2080.dtsi b/arch/powerpc/dts/t2080.dtsi index f895dda4d7..666601ed49 100644 --- a/arch/powerpc/dts/t2080.dtsi +++ b/arch/powerpc/dts/t2080.dtsi @@ -68,5 +68,24 @@ bus-width = <4>; voltage-ranges = <1800 1800 3300 3300>; }; + + usb0: usb@210000 { + compatible = "fsl-usb2-mph"; + reg = <0x210000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <44 0x2 0 0>; + phy_type = "utmi"; + }; + + usb1: usb@211000 { + compatible = "fsl-usb2-dr"; + reg = <0x211000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <45 0x2 0 0>; + dr_mode = "host"; + phy_type = "utmi"; + }; }; };
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 6/8] ppc: t2080qds: add usb node
--pk
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- drivers/usb/host/ehci-fsl.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 23e7e7125f..b8f8e7a794 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -75,8 +75,12 @@ static int ehci_fsl_init_after_reset(struct ehci_ctrl *ctrl) struct usb_ehci *ehci = NULL; struct ehci_fsl_priv *priv = container_of(ctrl, struct ehci_fsl_priv, ehci); - +#ifdef CONFIG_PPC + ehci = (struct usb_ehci *)lower_32_bits(priv->hcd_base); +#else ehci = (struct usb_ehci *)priv->hcd_base; +#endif + if (ehci_fsl_init(priv, ehci, priv->ehci.hccr, priv->ehci.hcor) < 0) return -ENXIO;
@@ -103,7 +107,11 @@ static int ehci_fsl_probe(struct udevice *dev) debug("Can't get the EHCI register base address\n"); return -ENXIO; } +#ifdef CONFIG_PPC + ehci = (struct usb_ehci *)lower_32_bits(priv->hcd_base); +#else ehci = (struct usb_ehci *)priv->hcd_base; +#endif hccr = (struct ehci_hccr *)(&ehci->caplength); hcor = (struct ehci_hcor *) ((void *)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 7/8] usb: ehci: ppc: adopt 32 bit address
--pk
This patch is to enable usb DM for T2080QDS
configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 02d47c9fdd..c8811fbc83 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -59,6 +59,7 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y CONFIG_DM_MMC=y CONFIG_BLK=y CONFIG_DM=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 4ce83fe8c4..6c5838d611 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -58,6 +58,7 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y CONFIG_DM_MMC=y CONFIG_BLK=y CONFIG_DM=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index e2a7d3fa76..7ebfcc97e6 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -46,6 +46,7 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 641f3c0c97..e9d0d10414 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -59,6 +59,7 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y CONFIG_DM_MMC=y CONFIG_BLK=y CONFIG_DM=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index d2a8875aac..3a50230acf 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -38,6 +38,7 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y CONFIG_OF_LIBFDT=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_OF_CONTROL=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index d55ce771a9..a42f728d0d 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -51,3 +51,4 @@ CONFIG_USB_STORAGE=y CONFIG_DM_MMC=y CONFIG_BLK=y CONFIG_DM=y +CONFIG_DM_USB=y
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 8/8] configs: enable usb device module in T2080QDS
--pk
-----Original Message----- From: Yinbo Zhu Sent: Thursday, April 11, 2019 4:32 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Ran Wang ran.wang_1@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH v3 1/8] ppc: t2080qds: add eSDHC node
--pk
Prabhakar Kushwaha
Yinbo Zhu
