[U-Boot] [PATCH] sh: Add support watchdog for SH4A core
Add support watchdog for SH4A core (SH7763, SH7780 and SH7785). And fix some compile warning.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- cpu/sh4/watchdog.c | 48 ++++++++++++++++++++-------- lib_sh/board.c | 89 +++++++++++++++++++++++++++++++--------------------- 2 files changed, 87 insertions(+), 50 deletions(-)
diff --git a/cpu/sh4/watchdog.c b/cpu/sh4/watchdog.c index 346e217..6fbb069 100644 --- a/cpu/sh4/watchdog.c +++ b/cpu/sh4/watchdog.c @@ -17,32 +17,52 @@
#include <common.h> #include <asm/processor.h> +#include <asm/io.h>
#define WDT_BASE WTCNT
-static unsigned char cnt_read (void){ - return *((volatile unsigned char *)(WDT_BASE + 0x00)); +#define WDT_WD (1 << 6) +#define WDT_RST_P (0) +#define WDT_RST_M (1 << 5) +#define WDT_ENABLE (1 << 7) + +#if defined(CONFIG_WATCHDOG) +static unsigned char csr_read (void) +{ + return inb(WDT_BASE + 0x04); }
-static unsigned char csr_read (void){ - return *((volatile unsigned char *)(WDT_BASE + 0x04)); +static void cnt_write (unsigned char value) +{ + outl((unsigned short)value | 0x5A00, WDT_BASE + 0x00); }
-static void cnt_write (unsigned char value){ - while (csr_read() & (1 << 5)) { - /* delay */ - } - *((volatile unsigned short *)(WDT_BASE + 0x00)) - = ((unsigned short) value) | 0x5A00; +static void csr_write (unsigned char value) +{ + outl((unsigned short)value | 0xA500, WDT_BASE + 0x04); }
-static void csr_write (unsigned char value){ - *((volatile unsigned short *)(WDT_BASE + 0x04)) - = ((unsigned short) value) | 0xA500; +void watchdog_reset(void) +{ + outl(0x55000000, WDT_BASE + 0x08); }
+int watchdog_init (void) +{ + /* Set overflow time*/ + cnt_write(0); + /* Power on reset */ + csr_write(WDT_WD|WDT_RST_P|WDT_ENABLE); + + return 0; +}
-int watchdog_init (void){ return 0; } +int watchdog_disable (void) +{ + csr_write(csr_read() & ~WDT_ENABLE); + return 0; +} +#endif
void reset_cpu (unsigned long ignored) { diff --git a/lib_sh/board.c b/lib_sh/board.c index eb81bd9..c678120 100644 --- a/lib_sh/board.c +++ b/lib_sh/board.c @@ -23,6 +23,7 @@ #include <malloc.h> #include <devices.h> #include <version.h> +#include <watchdog.h> #include <net.h> #include <environment.h>
@@ -30,7 +31,6 @@ extern void malloc_bin_reloc (void); extern int cpu_init(void); extern int board_init(void); extern int dram_init(void); -extern int watchdog_init(void); extern int timer_init(void);
const char version_string[] = U_BOOT_VERSION" (" __DATE__ " - " __TIME__ ")"; @@ -70,37 +70,45 @@ static int sh_flash_init(void) DECLARE_GLOBAL_DATA_PTR;
gd->bd->bi_flashsize = flash_init(); - printf("FLASH: %dMB\n", gd->bd->bi_flashsize / (1024*1024)); + printf("FLASH: %ldMB\n", gd->bd->bi_flashsize / (1024*1024));
return 0; }
#if defined(CONFIG_CMD_NAND) -#include <nand.h> -static int sh_nand_init(void) -{ - printf("NAND: "); - nand_init(); /* go init the NAND */ - return 0; -} +# include <nand.h> +# define INIT_FUNC_NAND_INIT nand_init, +#else +# define INIT_FUNC_NAND_INIT #endif /* CONFIG_CMD_NAND */
+#if defined(CONFIG_WATCHDOG) +extern int watchdog_init(void); +extern int watchdog_disable(void); +# define INIT_FUNC_WATCHDOG_INIT watchdog_init, +# define WATCHDOG_DISABLE watchdog_disable +#else +# define INIT_FUNC_WATCHDOG_INIT +# define WATCHDOG_DISABLE +#endif /* CONFIG_WATCHDOG */ + #if defined(CONFIG_CMD_IDE) -#include <ide.h> -static int sh_marubun_init(void) -{ - puts ("IDE: "); - ide_init(); - return 0; -} -#endif /* (CONFIG_CMD_IDE) */ +# include <ide.h> +# define INIT_FUNC_IDE_INIT ide_init, +#else +# define INIT_FUNC_IDE_INIT +#endif /* CONFIG_CMD_IDE */
#if defined(CONFIG_PCI) +#include <pci.h> static int sh_pci_init(void) { pci_init(); return 0; } +# define INIT_FUNC_PCI_INIT sh_pci_init, +#else +# define INIT_FUNC_PCI_INIT #endif /* CONFIG_PCI */
static int sh_mem_env_init(void) @@ -136,24 +144,20 @@ init_fnc_t *init_sequence[] = { cpu_init, /* basic cpu dependent setup */ board_init, /* basic board dependent setup */ - interrupt_init, /* set up exceptions */ + interrupt_init, /* set up exceptions */ env_init, /* event init */ - serial_init, /* SCIF init */ - watchdog_init, /* watchdog init */ + serial_init, /* SCIF init */ + INIT_FUNC_WATCHDOG_INIT /* watchdog init */ console_init_f, display_options, checkcpu, checkboard, /* Check support board */ dram_init, /* SDRAM init */ timer_init, /* SuperH Timer (TCNT0 only) init */ - sh_flash_init, /* Flash memory(NOR) init*/ + sh_flash_init, /* Flash memory(NOR) init*/ sh_mem_env_init, -#if defined(CONFIG_CMD_NAND) - sh_nand_init, /* Flash memory (NAND) init */ -#endif -#if defined(CONFIG_PCI) - sh_pci_init, /* PCI Init */ -#endif + INIT_FUNC_NAND_INIT/* Flash memory (NAND) init */ + INIT_FUNC_PCI_INIT /* PCI init */ devices_init, console_init_r, interrupt_init, @@ -172,8 +176,6 @@ void sh_generic_init (void)
bd_t *bd; init_fnc_t **init_fnc_ptr; - int i; - char *s;
memset (gd, 0, CFG_GBL_DATA_SIZE);
@@ -194,22 +196,37 @@ void sh_generic_init (void) #endif bd->bi_baudrate = CONFIG_BAUDRATE;
- for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr , i++) { - if ((*init_fnc_ptr) () != 0) { + for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { + WATCHDOG_RESET(); + if ((*init_fnc_ptr) () != 0) hang(); - } }
+#ifdef CONFIG_WATCHDOG + /* disable watchdog if environment is set */ + { + char *s; + if ((s = getenv ("watchdog")) != NULL) + if (strncmp (s, "off", 3) == 0) + WATCHDOG_DISABLE (); + } +#endif /* CONFIG_WATCHDOG*/ + + #if defined(CONFIG_CMD_NET) - puts ("Net: "); - eth_initialize(gd->bd); + { + char *s; + puts ("Net: "); + eth_initialize(gd->bd);
- if ((s = getenv ("bootfile")) != NULL) { - copy_filename (BootFile, s, sizeof (BootFile)); + if ((s = getenv ("bootfile")) != NULL) { + copy_filename (BootFile, s, sizeof (BootFile)); + } } #endif /* CONFIG_CMD_NET */
while (1) { + WATCHDOG_RESET(); main_loop(); } }
- Fix checkpatch warning
cpu/sh4/watchdog.c | 53 +++++++++++++++++------- lib_sh/board.c | 115 ++++++++++++++++++++++++++++++---------------------- 2 files changed, 104 insertions(+), 64 deletions(-)
diff --git a/cpu/sh4/watchdog.c b/cpu/sh4/watchdog.c index 346e217..f692429 100644 --- a/cpu/sh4/watchdog.c +++ b/cpu/sh4/watchdog.c @@ -17,34 +17,55 @@
-static unsigned char cnt_read (void){ - return *((volatile unsigned char *)(WDT_BASE + 0x00)); +#define WDT_WD (1 << 6) +#define WDT_RST_P (0) +#define WDT_RST_M (1 << 5) +#define WDT_ENABLE (1 << 7) + +#if defined(CONFIG_WATCHDOG) +static unsigned char csr_read(void) +{ + return inb(WDT_BASE + 0x04); }
-static unsigned char csr_read (void){ - return *((volatile unsigned char *)(WDT_BASE + 0x04)); +static void cnt_write(unsigned char value) +{ + outl((unsigned short)value | 0x5A00, WDT_BASE + 0x00); }
-static void cnt_write (unsigned char value){ - while (csr_read() & (1 << 5)) { - /* delay */ - } - *((volatile unsigned short *)(WDT_BASE + 0x00)) - = ((unsigned short) value) | 0x5A00; +static void csr_write(unsigned char value) +{ + outl((unsigned short)value | 0xA500, WDT_BASE + 0x04); }
+int watchdog_init(void) +{ + /* Set overflow time*/ + cnt_write(0); + /* Power on reset */ + csr_write(WDT_WD|WDT_RST_P|WDT_ENABLE); + + return 0; +}
-int watchdog_init (void){ return 0; } +int watchdog_disable(void) +{ + csr_write(csr_read() & ~WDT_ENABLE); + return 0; +} +#endif
-void reset_cpu (unsigned long ignored) +void reset_cpu(unsigned long ignored) { - while(1); + while (1) + ; } diff --git a/lib_sh/board.c b/lib_sh/board.c index eb81bd9..6dfab4e 100644 --- a/lib_sh/board.c +++ b/lib_sh/board.c @@ -23,6 +23,7 @@ #include <malloc.h> #include <devices.h> #include <version.h> +#include <watchdog.h> #include <net.h> #include <environment.h>
const char version_string[] = U_BOOT_VERSION" (" __DATE__ " - " __TIME__ ")"; @@ -41,17 +41,17 @@ static unsigned long mem_malloc_start; static unsigned long mem_malloc_end; static unsigned long mem_malloc_brk;
-static void mem_malloc_init (void) +static void mem_malloc_init(void) {
mem_malloc_start = (TEXT_BASE - CFG_GBL_DATA_SIZE - CFG_MALLOC_LEN); mem_malloc_end = (mem_malloc_start + CFG_MALLOC_LEN - 16); mem_malloc_brk = mem_malloc_start; - memset ((void *) mem_malloc_start, 0, + memset((void *) mem_malloc_start, 0, (mem_malloc_end - mem_malloc_start)); }
-void *sbrk (ptrdiff_t increment) +void *sbrk(ptrdiff_t increment) { unsigned long old = mem_malloc_brk; unsigned long new = old + increment; @@ -70,37 +70,45 @@ static int sh_flash_init(void) DECLARE_GLOBAL_DATA_PTR;
return 0; }
static int sh_mem_env_init(void) @@ -123,7 +131,8 @@ static int sh_net_init(void) s = getenv("ethaddr"); for (i = 0; i < 6; ++i) { gd->bd->bi_enetaddr[i] = s ? simple_strtoul(s, &e, 16) : 0; - if (s) s = (*e) ? e + 1 : e; + if (s) + s = (*e) ? e + 1 : e; }
return 0; @@ -136,24 +145,20 @@ init_fnc_t *init_sequence[] = { cpu_init, /* basic cpu dependent setup */ board_init, /* basic board dependent setup */ - interrupt_init, /* set up exceptions */ + interrupt_init, /* set up exceptions */ env_init, /* event init */ - serial_init, /* SCIF init */ - watchdog_init, /* watchdog init */ + serial_init, /* SCIF init */ + INIT_FUNC_WATCHDOG_INIT /* watchdog init */ console_init_f, display_options, checkcpu, checkboard, /* Check support board */ dram_init, /* SDRAM init */ timer_init, /* SuperH Timer (TCNT0 only) init */ - sh_flash_init, /* Flash memory(NOR) init*/ + sh_flash_init, /* Flash memory(NOR) init*/ sh_mem_env_init, -#if defined(CONFIG_CMD_NAND) - sh_nand_init, /* Flash memory (NAND) init */ -#endif -#if defined(CONFIG_PCI) - sh_pci_init, /* PCI Init */ -#endif + INIT_FUNC_NAND_INIT/* Flash memory (NAND) init */ + INIT_FUNC_PCI_INIT /* PCI init */ devices_init, console_init_r, interrupt_init, @@ -166,20 +171,18 @@ init_fnc_t *init_sequence[] = NULL /* Terminate this list */ };
-void sh_generic_init (void) +void sh_generic_init(void) { DECLARE_GLOBAL_DATA_PTR;
- memset (gd, 0, CFG_GBL_DATA_SIZE); + memset(gd, 0, CFG_GBL_DATA_SIZE);
gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */
- gd->bd = (bd_t *) (gd + 1); /* At end of global data */ + gd->bd = (bd_t *)(gd + 1); /* At end of global data */ gd->baudrate = CONFIG_BAUDRATE;
gd->cpu_clk = CONFIG_SYS_CLK_FREQ; @@ -189,35 +192,51 @@ void sh_generic_init (void) bd->bi_memsize = CFG_SDRAM_SIZE; bd->bi_flashstart = CFG_FLASH_BASE; #if defined(CFG_SRAM_BASE) && defined(CFG_SRAM_SIZE) - bd->bi_sramstart= CFG_SRAM_BASE; + bd->bi_sramstart = CFG_SRAM_BASE; bd->bi_sramsize = CFG_SRAM_SIZE; #endif bd->bi_baudrate = CONFIG_BAUDRATE;
-#if defined(CONFIG_CMD_NET) - puts ("Net: "); - eth_initialize(gd->bd); +#ifdef CONFIG_WATCHDOG + /* disable watchdog if environment is set */ + { + char *s = getenv("watchdog"); + if (s != NULL) + if (strncmp(s, "off", 3) == 0) + WATCHDOG_DISABLE(); + } +#endif /* CONFIG_WATCHDOG*/
- if ((s = getenv ("bootfile")) != NULL) { - copy_filename (BootFile, s, sizeof (BootFile)); + +#if defined(CONFIG_CMD_NET) + { + char *s; + puts("Net: "); + eth_initialize(gd->bd); + + s = getenv("bootfile"); + if (s != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); } #endif /* CONFIG_CMD_NET */
-void hang (void) +void hang(void) { - puts ("Board ERROR\n"); - for (;;); + puts("Board ERROR\n"); + for (;;) + ; }
Nobuhiro Iwamatsu
