[U-Boot] [PATCH] spl: fat: Support full fitImage handling
Handle the case where the full fitImage support is enabled. In this case, the whole fitImage must be loaded up front as some parts of the fitImage code require memory-mapped access to the entire fitImage.
Signed-off-by: Marek Vasut marex@denx.de Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com Cc: Simon Glass sjg@chromium.org --- common/spl/spl_fat.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 87dd553210..0403016bb4 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -70,7 +70,18 @@ int spl_load_image_fat(struct spl_image_info *spl_image, if (err <= 0) goto end;
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT_FULL) && + image_get_magic(header) == FDT_MAGIC) { + err = file_fat_read(filename, (void *)CONFIG_SYS_LOAD_ADDR, 0); + if (err <= 0) + goto end; + err = spl_parse_image_header(spl_image, + (struct image_header *)CONFIG_SYS_LOAD_ADDR); + if (err == -EAGAIN) + return err; + if (err == 0) + err = 1; + } else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load;
Hi Marex,
if (err <= 0)
goto end;
if (err == -EAGAIN)
return err;
if (err == 0)
err = 1;
The error handling here is too confusing.
spl_load_image_fat() has no comment indicating what the return value means. So is 0 success?
spl_parse_image_header() seems to return 0 on success, which is good, but your code appears to turn that into 1. Why?
Can you please add comments and consider moving towards using 0 to mean success everywhere?
-- 2.16.2
On 06/07/2018 10:27 PM, Simon Glass wrote:
Hi Marex,
if (err <= 0)
goto end;
if (err == -EAGAIN)
return err;
if (err == 0)
err = 1;
Yes, 0 is success, EAGAIN is retry, anything else is an error.
The SPL loader expects I think positive return value to indicate success though.
-- 2.16.2
