[U-Boot] Please pull u-boot-rockchip
Tom,
Here’s a few minor fixes for RC2. I am still waiting for a final revision on a somewhat involved bug-fix for our RK3399-Q7, which is held up by my colleagues also introducing changes to pinctrl to ensure a PWM regulator can be auto-set.
The all-green Travis report for these changes is at https://travis-ci.org/ptomsich/u-boot-rockchip/builds/468541679
Thanks, Philipp.
The following changes since commit 8fc26fce41592175ae004514e431e68a9dd60671:
Merge tag 'dm-pull-14dec18' of git://git.denx.de/u-boot-dm (2018-12-14 14:18:47 -0500)
git://git.denx.de/u-boot-rockchip.git tags/for-master-20181216
for you to fetch changes up to e11ef3d26eff8d14a11f89b9bdc20471b425d2d7:
ARM: rockchip: Add rv1108-elgin-r1 board support (2018-12-16 01:30:11 +0100)
---------------------------------------------------------------- Improvements and fixes or u-boot-rockchip: - new board: adds rv1108-elgin-r1 board support - rk3288-evb: dts: remove 'vmmc' from emmc node - rk3399-puma: dts: remove obsolete DTS node 'vcc5v0_host'
---------------------------------------------------------------- Christoph Muellner (1): rockchip: rk3399-puma: Remove obsolete DTS node 'vcc5v0_host'.
Kever Yang (1): rockchip: rk3288-evb: dts: remove 'vmmc' from emmc node
Otavio Salvador (1): ARM: rockchip: Add rv1108-elgin-r1 board support
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-evb.dtsi | 2 - arch/arm/dts/rk3399-puma.dtsi | 12 +----- arch/arm/dts/rv1108-elgin-r1.dts | 48 +++++++++++++++++++++ arch/arm/mach-rockchip/rv1108/Kconfig | 6 +++ board/elgin/elgin_rv1108/Kconfig | 15 +++++++ board/elgin/elgin_rv1108/MAINTAINERS | 6 +++ board/elgin/elgin_rv1108/Makefile | 7 ++++ board/elgin/elgin_rv1108/elgin_rv1108.c | 74 +++++++++++++++++++++++++++++++++ configs/elgin-rv1108_defconfig | 58 ++++++++++++++++++++++++++ include/configs/elgin_rv1108.h | 13 ++++++ 11 files changed, 230 insertions(+), 12 deletions(-) create mode 100644 arch/arm/dts/rv1108-elgin-r1.dts create mode 100644 board/elgin/elgin_rv1108/Kconfig create mode 100644 board/elgin/elgin_rv1108/MAINTAINERS create mode 100644 board/elgin/elgin_rv1108/Makefile create mode 100644 board/elgin/elgin_rv1108/elgin_rv1108.c create mode 100644 configs/elgin-rv1108_defconfig create mode 100644 include/configs/elgin_rv1108.h
On Sun, Dec 16, 2018 at 07:03:19PM +0100, Philipp Tomsich wrote:
Tom,
Thanks, Philipp.
Philipp Tomsich
