[GIT PULL] Please pull u-boot-imx-next-20240911
Hi Tom,
Please pull from u-boot-imx/next, thanks.
The following changes since commit 78d898eec080b02059c8dc09318b8761044fea85:
Merge patch series "phycore-am62/4: Add more boot sources" (2024-09-10 14:56:12 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-next-20240911
for you to fetch changes up to 5748aa1e372d2db3db6bf3e863f4571bf2ffedb9:
pwm: imx: Don't drop the enable bit once set (2024-09-11 17:02:36 -0300)
u-boot-imx-next-20240911 ------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/22320
- Improve i.MX8M boot time by enabling MMU and D-cache very early. - Don't drop the enable bit once set on the i.MX PWM driver. - Enable DM_RNG so that the kaslr-seed property is set in the dt allowing Linux KASLR. ---------------------------------------------------------------- Marek Vasut (1): ARM: imx: Enable MMU and dcache very early on i.MX8M
Miquel Raynal (1): pwm: imx: Don't drop the enable bit once set
Tim Harvey (1): configs: venice: enable DM_RNG
arch/arm/mach-imx/imx8m/soc.c | 47 +++++++++++++++++++++++++++++++++++++++++ configs/imx8mm_venice_defconfig | 1 - configs/imx8mn_venice_defconfig | 1 - configs/imx8mp_venice_defconfig | 1 - drivers/pwm/pwm-imx.c | 5 +++-- 5 files changed, 50 insertions(+), 5 deletions(-)
On Wed, Sep 11, 2024 at 08:25:21PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
