[U-Boot] [PATCH 1/2] board/bsc9132qds: Add DSP side tlb and laws
BSC9132QDS is a Freescale Reference Design Board for BSC9132 SoC which is a integrated device that contains two powerpc e500v2 cores and two DSP starcores.
To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 and M3 memory -Creating LAW for 1GB DDR which is connected exclusively to DSP-cores
Signed-off-by: Manish Jaggi Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- README | 8 ++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 4 ++++ arch/powerpc/include/asm/fsl_law.h | 6 +++++- board/freescale/bsc9132qds/law.c | 8 ++++++++ board/freescale/bsc9132qds/tlb.c | 5 +++++ include/configs/BSC9132QDS.h | 4 ++++ 6 files changed, 34 insertions(+), 1 deletions(-)
diff --git a/README b/README index e8359f8..99a2c02 100644 --- a/README +++ b/README @@ -422,10 +422,18 @@ The following options need to be configured: This is the value to write into CCSR offset 0x18600 according to the A004510 workaround.
+ CONFIG_SYS_FSL_DSP_DDR_ADDR + This value denotes start offset of DDR memory which is + connected exclusively to the DSP cores. + CONFIG_SYS_FSL_DSP_M2_RAM_ADDR This value denotes start offset of M2 memory which is directly connected to the DSP core.
+ CONFIG_SYS_FSL_DSP_M3_RAM_ADDR + This value denotes start offset of M3 memory which is directly + connected to the DSP core. + CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT This value denotes start offset of DSP CCSR space.
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 1d46b14..16ef7df 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -506,6 +506,10 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_DSP_DDR_ADDR 0x40000000 +#define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 +#define CONFIG_SYS_FSL_DSP_M3_RAM_ADDR 0xc0000000 +#define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index bea1636..fa51e59 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -82,7 +82,7 @@ enum law_trgt_if { #ifndef CONFIG_MPC8641 LAW_TRGT_IF_PCIE_1 = 0x02, #endif -#if defined(CONFIG_BSC9131) +#if defined(CONFIG_BSC9131) || defined(CONFIG_BSC9132) LAW_TRGT_IF_OCN_DSP = 0x03, #else #if !defined(CONFIG_MPC8572) && !defined(CONFIG_P2020) @@ -94,7 +94,11 @@ enum law_trgt_if { LAW_TRGT_IF_DSP_CCSR = 0x09, LAW_TRGT_IF_DDR_INTRLV = 0x0b, LAW_TRGT_IF_RIO = 0x0c, +#if defined(CONFIG_BSC9132) + LAW_TRGT_IF_CLASS_DSP = 0x0d, +#else LAW_TRGT_IF_RIO_2 = 0x0d, +#endif LAW_TRGT_IF_DPAA_SWP_SRAM = 0x0e, LAW_TRGT_IF_DDR = 0x0f, LAW_TRGT_IF_DDR_2 = 0x16, /* 2nd controller */ diff --git a/board/freescale/bsc9132qds/law.c b/board/freescale/bsc9132qds/law.c index b4bce99..99ea56b 100644 --- a/board/freescale/bsc9132qds/law.c +++ b/board/freescale/bsc9132qds/law.c @@ -32,6 +32,14 @@ struct law_entry law_table[] = { #ifdef CONFIG_SYS_FPGA_BASE_PHYS SET_LAW(CONFIG_SYS_FPGA_BASE_PHYS, LAW_SIZE_128K, LAW_TRGT_IF_IFC), #endif + SET_LAW(CONFIG_SYS_FSL_DSP_CCSRBAR_PHYS, LAW_SIZE_1M, + LAW_TRGT_IF_DSP_CCSR), + SET_LAW(CONFIG_SYS_FSL_DSP_M2_RAM_ADDR, LAW_SIZE_32M, + LAW_TRGT_IF_OCN_DSP), + SET_LAW(CONFIG_SYS_FSL_DSP_M3_RAM_ADDR, LAW_SIZE_32K, + LAW_TRGT_IF_CLASS_DSP), + SET_LAW(CONFIG_SYS_FSL_DSP_DDR_ADDR, LAW_SIZE_1G, + LAW_TRGT_IF_CLASS_DSP) };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/bsc9132qds/tlb.c b/board/freescale/bsc9132qds/tlb.c index 0ec9a85..734f3f8 100644 --- a/board/freescale/bsc9132qds/tlb.c +++ b/board/freescale/bsc9132qds/tlb.c @@ -57,6 +57,11 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 1, BOOKE_PAGESZ_1M, 1),
+ /* CCSRBAR (DSP) */ + SET_TLB_ENTRY(1, CONFIG_SYS_FSL_DSP_CCSRBAR, + CONFIG_SYS_FSL_DSP_CCSRBAR_PHYS, MAS3_SW|MAS3_SR, + MAS2_I|MAS2_G, 0, 2, BOOKE_PAGESZ_1M, 1), + #ifndef CONFIG_SPL_BUILD SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 3aa4443..91105eb 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -240,6 +240,10 @@ combinations. this should be removed later
#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR
+/* DSP CCSRBAR */ +#define CONFIG_SYS_FSL_DSP_CCSRBAR CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT +#define CONFIG_SYS_FSL_DSP_CCSRBAR_PHYS CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT + /* * IFC Definitions */
On Tue, Jun 25, 2013 at 10:57 AM, Priyanka Jain Priyanka.Jain@freescale.com wrote:
missing mail id ? and similarly for 2/2
Regards, --Prabhakar Lad
Email-id is no longer valid as person has left the company. Git send-email was throwing error as it could not send message to that mail.
Regards Priyanka
-----Original Message----- From: Prabhakar Lad [mailto:prabhakar.csengg@gmail.com] Sent: Tuesday, June 25, 2013 5:15 PM To: Jain Priyanka-B32167 Cc: u-boot@lists.denx.de; Fleming Andy-AFLEMING Subject: Re: [U-Boot] [PATCH 1/2] board/bsc9132qds: Add DSP side tlb and laws
Hi Jain,
On Thu, 27 Jun 2013 03:59:16 +0000, Jain Priyanka-B32167 B32167@freescale.com wrote:
(please do not top-post)
Without an e-mail address, I suspect we cannot consider that person's Signed-off-by to be valid, if only because it does not identify a single individual any more.
Regards Priyanka
Amicalement,
On Thu, Jun 27, 2013 at 1:21 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Jain,
Yes that's rite! alternatively you can just mention his name in the commit message(with _NO_ signed-of).
Hi Prabhakar,
On Thu, 27 Jun 2013 13:36:16 +0530, Prabhakar Lad prabhakar.csengg@gmail.com wrote:
Hi Jain,
Note however that we *do* need a signed-off-by line.
Amicalement,
On 06/27/2013 05:05:55 AM, Albert ARIBAUD wrote:
Hi Prabhakar,
Hi Jain,
to that mail.
person's
We would still have Priyanka's signed-off-by.
-Scott
You can use --suppress-cc=sob to tell git send-email to not automatically CC people with sign-off lines.
Or, you could use an ordinary e-mail client to send it, as long as it doesn't mangle the patch (mutt works well for this).
-Scott
participants (5)
Albert ARIBAUD
Prabhakar Lad
Priyanka Jain
Scott Wood
