[U-Boot] [PATCH 03/13 v5] serial: atmel_usart: Use fixed clock value in SPL version with DM_SERIAL
This patch adds an alterative SPL version of atmel_serial_enable_clk(). This enables the usage of this driver without full clock support (in drivers and DT nodes). This saves some space in the SPL image.
Please note that this fixed clock support is only added to the SPL code in the DM_SERIAL part of this file. All boards not using SPL & DM_SERIAL should not be affected.
This patch also introduces CONFIG_SPL_UART_CLOCK for the fixed UART input clock. It defaults to 132096000 for ARCH_AT91 but can be set to a different value if needed.
Signed-off-by: Stefan Roese sr@denx.de Cc: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas@biessmann.org Cc: Eugen Hristev eugen.hristev@microchip.com --- v5: - Restrict SPL_UART_CLOCK on ATMEL_USART && SPL && !SPL_CLK
v4: - Restrict SPL_UART_CLOCK on SPL && !SPL_CLK - Provide default value for non AT91 platforms to not break the build - Fix typo in Kconfig text
v3: - Depend fixed clock atmel_serial_enable_clk() function also on !CONFIG_SPL_CLK so that board with full clocj support in SPL can still use the normal function here - Introcude CONFIG_SPL_UART_CLOCK and use this Kconfig option instead of the hardcoded value
v2: - Reword patch subject and commit text to make it more clear, that this change only affects ports with SPL and DM_SERIAL enabled
drivers/serial/Kconfig | 9 +++++++++ drivers/serial/atmel_usart.c | 12 ++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 887cd687c0..fcbb0a81ed 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -508,6 +508,15 @@ config ATMEL_USART configured in the device tree, and input clock frequency can be got from the clk node.
+config SPL_UART_CLOCK + int "SPL fixed UART input clock" + depends on ATMEL_USART && SPL && !SPL_CLK + default 132096000 if ARCH_AT91 + help + Provide a fixed clock value as input to the UART controller. This + might be needed on platforms which can't enable CONFIG_SPL_CLK + because of SPL image size restrictions. + config BCM283X_MU_SERIAL bool "Support for BCM283x Mini-UART" depends on DM_SERIAL && ARCH_BCM283X diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index aa8cdff840..c450a4e08a 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -218,6 +218,17 @@ static const struct dm_serial_ops atmel_serial_ops = { .setbrg = atmel_serial_setbrg, };
+#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_SPL_CLK) +static int atmel_serial_enable_clk(struct udevice *dev) +{ + struct atmel_serial_priv *priv = dev_get_priv(dev); + + /* Use fixed clock value in SPL */ + priv->usart_clk_rate = CONFIG_SPL_UART_CLOCK; + + return 0; +} +#else static int atmel_serial_enable_clk(struct udevice *dev) { struct atmel_serial_priv *priv = dev_get_priv(dev); @@ -245,6 +256,7 @@ static int atmel_serial_enable_clk(struct udevice *dev)
return 0; } +#endif
static int atmel_serial_probe(struct udevice *dev) {
Stefan Roese
