[PATCH] mtd: rawnand: stm32_fmc2: remove unsupported EDO mode
Remove the EDO mode support from as the FMC2 controller does not support the feature.
Signed-off-by: Christophe Kerello christophe.kerello@foss.st.com ---
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index fb3279b405e..69dbb629e93 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -735,6 +735,9 @@ static int stm32_fmc2_nfc_setup_interface(struct mtd_info *mtd, int chipnr, if (IS_ERR(sdrt)) return PTR_ERR(sdrt);
+ if (sdrt->tRC_min < 30000) + return -EOPNOTSUPP; + if (chipnr == NAND_DATA_IFACE_CHECK_ONLY) return 0;
Hi Christophe
- if (sdrt->tRC_min < 30000)
return -EOPNOTSUPP;
- if (chipnr == NAND_DATA_IFACE_CHECK_ONLY) return 0;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
On 4/11/23 08:53, Patrice CHOTARD wrote:
Hi Christophe
return -EOPNOTSUPP;
Thanks Patrice
Applied on u-boot-stm/master, thanks
Patrice
Christophe Kerello
Patrice CHOTARD
