[U-Boot] [PATCH 1/3] mmc: fsl_esdhc: enable dat[4:7] for eMMC4.5
If adapter card type identification is supported for platform, we would enable dat[4:7] for eMMC4.5 card.
Signed-off-by: Yangbo Lu yangbo.lu@freescale.com Cc: York Sun yorksun@freescale.com --- board/freescale/common/qixis.h | 2 ++ drivers/mmc/fsl_esdhc.c | 3 +++ 2 files changed, 5 insertions(+)
diff --git a/board/freescale/common/qixis.h b/board/freescale/common/qixis.h index 51ce9c3..450cd0d 100644 --- a/board/freescale/common/qixis.h +++ b/board/freescale/common/qixis.h @@ -127,6 +127,8 @@ void qixis_write_i2c(unsigned int reg, u8 value); #define QIXIS_ESDHC_NO_ADAPTER 0x7 /* No Card is Present*/ #define QIXIS_SDCLKIN 0x08 #define QIXIS_SDCLKOUT 0x02 +#define QIXIS_DAT5_6_7 0X02 +#define QIXIS_DAT4 0X01 #endif
#endif diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 0b37002..639ec02 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -747,6 +747,9 @@ void mmc_adapter_card_type_ident(void)
switch (card_id) { case QIXIS_ESDHC_ADAPTER_TYPE_EMMC45: + value = QIXIS_READ(brdcfg[5]); + value |= (QIXIS_DAT4 | QIXIS_DAT5_6_7); + QIXIS_WRITE(brdcfg[5], value); break; case QIXIS_ESDHC_ADAPTER_TYPE_SDMMC_LEGACY: break;
Yangbo,
break; case QIXIS_ESDHC_ADAPTER_TYPE_SDMMC_LEGACY: break;QIXIS_WRITE(brdcfg[5], value);
Does any other board have this identification feature? I see the code only use qixis. How are RDB and customer boards handled?
York
Hi York,
Please see my comments below.
-----Original Message----- From: Sun York-R58495 Sent: Monday, September 14, 2015 11:57 PM To: Lu Yangbo-B47093; u-boot@lists.denx.de Subject: Re: [PATCH 1/3] mmc: fsl_esdhc: enable dat[4:7] for eMMC4.5
Yangbo,
Present*/
York
[Lu Yangbo-B47093] This feature is used for QDS boards that use SDHC Adapter card. Now only T1040QDS and T2080QDS are enabled, because we want to support SD/MMC UHS-I speed mode on these two boards in kernel and these QIXIS configuration are needed for *the Adapter*. For RDB and customer boards, they don't use Adapter card and the default configuration is ok for SD/MMC Default speed mode and High speed mode.
On 09/14/2015 07:22 PM, Lu Yangbo-B47093 wrote:
Hi York,
Yangbo,
Present*/
York
I am actually more concerned how a customer board can take advantage of this.
York
Hi York,
Yangbo,
Present*/
York
York
[Lu Yangbo-B47093] This feature is used to resolve pin multiplexing and Adapter card configuration on QDS board. RDB and custom boards don't support Adapter card, and the FPGA/CPLD is easier(don't have these register and settings), having no need to change. So they couldn't take advantage of this...
Thanks.
-Yangbo Lu
Lu Y.B.
Yangbo Lu
York Sun
