[U-Boot-Users] [PATCH] Add setexpr command
Add a simple expr style command that will set an env variable as the result of the command. This allows us to do simple math in shell. The following operations are supported: &, |, ^, +, -, *, /.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
this was the expr patch, but renamed based on comments on the list.
Still open issue about should this be in config_cmd_default.h
- k
common/cmd_setexpr.c | 70 ++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 70 insertions(+), 0 deletions(-) create mode 100644 common/cmd_setexpr.c
diff --git a/common/cmd_setexpr.c b/common/cmd_setexpr.c new file mode 100644 index 0000000..2e49b6d --- /dev/null +++ b/common/cmd_setexpr.c @@ -0,0 +1,70 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This file provides a shell like 'expr' function to return. + */ + +#include <common.h> +#include <config.h> +#include <command.h> + +int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong a, b; + char buf[16]; + + /* Validate arguments */ + if ((argc != 5) || (strlen(argv[3]) != 1)) { + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + a = simple_strtoul(argv[2], NULL, 16); + b = simple_strtoul(argv[4], NULL, 16); + + switch (argv[3][0]) { + case '|': sprintf(buf, "%lx", (a | b)); break; + case '&': sprintf(buf, "%lx", (a & b)); break; + case '+': sprintf(buf, "%lx", (a + b)); break; + case '^': sprintf(buf, "%lx", (a ^ b)); break; + case '-': sprintf(buf, "%lx", (a - b)); break; + case '*': sprintf(buf, "%lx", (a * b)); break; + case '/': sprintf(buf, "%lx", (a / b)); break; + case '%': sprintf(buf, "%lx", (a % b)); break; + default: + printf("invalid op\n"); + return 1; + } + + setenv(argv[1], buf); + + return 0; +} + +U_BOOT_CMD( + setexpr, 5, 0, do_setexpr, + "setexpr - set environment variable as the result of eval expression\n", + "name value1 <op> value2\n" + " - set environment variable 'name' to the result of the evaluated\n" + " express specified by <op>. <op> can be &, |, ^, +, -, *, /, %\n" +);
In message Pine.LNX.4.64.0802131648030.23661@blarg.am.freescale.net you wrote:
<grumble> Well, *my* command was *not* to rename it. </grumble>
At least, please don't make it a default command, then.
On Feb 13, 2008, at 5:07 PM, Wolfgang Denk wrote:
In message <Pine.LNX. 4.64.0802131648030.23661@blarg.am.freescale.net> you wrote:
sorry, saw your post after I sent this :)
</grumble>
If you are good with calling it expr so am I. I'd prefer not confusing 'setenv' with 'setexpr'. If we call it expr add it to the default list?
- k
In message ECA572BB-0720-4BD4-9A91-AEBC1056DCA4@kernel.crashing.org you wrote:
Can't even type any more. I intended to write "comment".
Well, given the fact that only very few boards need it but it adds to the memory footprint I recommend to not add it to the defaults list.
</grumble>
- k
OK, time to educate Jerry since I'm too lazy to check myself. Does our hush shell support back ticks? If we have back tick support, or can add that support, we should call it expr and return a value which then gets placed properly. That would be IDEAL. setenv foo `expr 2 + 3`
gvb
you wrote: Add a simple expr style command that will set an env variable as the result of the command. This allows us to do simple math in shell. The following operations are supported: &, |, ^, +, -, *, /.
</grumble>
- k
no we dont' support back ticks like this.
- k
No, we don't, and it's not trivial to add. [Feel free to prove me worng :-) ]
Agreed. BUt that's the very reason not to call it expr, because it doesn't work this way.
Hi Kumar,
nice idea. Can you at a little prose to the README (perhaps with a little usage example).
Matthias
On Feb 14, 2008, at 3:14 AM, Matthias Fuchs wrote:
Hi Kumar,
I can do this.
- k
Matthias
Or (and better *and*) to the manual, please?
- k
Applied, thanks.
Jerry Van Baren
Kumar Gala
Matthias Fuchs
