[U-Boot] [PATCH 1/7] driver: net: fsl-mc: Add version check for MC objects
Check and compare version of management complex's object with the version supported by Freescale ldpaa2 ethernet driver.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- drivers/net/fsl-mc/mc.c | 51 ++++++++++++++++++++++++++++++++++++++- drivers/net/ldpaa_eth/ldpaa_eth.c | 28 +++++++++++++++++++++ 2 files changed, 78 insertions(+), 1 deletion(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index bac4610..b773e35 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -655,6 +655,26 @@ int fsl_mc_ldpaa_init(bd_t *bis) return 0; }
+static int dprc_version_check(struct fsl_mc_io *mc_io, uint16_t handle) +{ + struct dprc_attributes attr; + int error; + + memset(&attr, 0, sizeof(struct dprc_attributes)); + error = dprc_get_attributes(mc_io, MC_CMD_NO_FLAGS, handle, &attr); + if (error == 0) { + if ((attr.version.major != DPRC_VER_MAJOR) || + (attr.version.minor != DPRC_VER_MINOR)) { + printf("DPRC version mismatch found %u.%u,", + attr.version.major, + attr.version.minor); + printf("supported version is %u.%u\n", + DPRC_VER_MAJOR, DPRC_VER_MINOR); + } + } + return error; +} + static int dpio_init(void) { struct qbman_swp_desc p_des; @@ -688,11 +708,18 @@ static int dpio_init(void) goto err_get_attr; }
+ if ((attr.version.major != DPIO_VER_MAJOR) || + (attr.version.minor != DPIO_VER_MINOR)) { + printf("DPIO version mismatch found %u.%u,", + attr.version.major, attr.version.minor); + printf("supported version is %u.%u\n", + DPIO_VER_MAJOR, DPIO_VER_MINOR); + } + dflt_dpio->dpio_id = attr.id; #ifdef DEBUG printf("Init: DPIO id=0x%d\n", dflt_dpio->dpio_id); #endif - err = dpio_enable(dflt_mc_io, MC_CMD_NO_FLAGS, dflt_dpio->dpio_handle); if (err < 0) { printf("dpio_enable() failed %d\n", err); @@ -784,6 +811,12 @@ static int dprc_init(void) goto err_root_open; }
+ err = dprc_version_check(root_mc_io, root_dprc_handle); + if (err < 0) { + printf("dprc_version_check() failed: %d\n", err); + goto err_root_open; + } + cfg.options = DPRC_CFG_OPT_TOPOLOGY_CHANGES_ALLOWED | DPRC_CFG_OPT_OBJ_CREATE_ALLOWED | DPRC_CFG_OPT_ALLOC_ALLOWED; @@ -906,6 +939,14 @@ static int dpbp_init(void) goto err_get_attr; }
+ if ((dpbp_attr.version.major != DPBP_VER_MAJOR) || + (dpbp_attr.version.minor != DPBP_VER_MINOR)) { + printf("DPBP version mismatch found %u.%u,", + dpbp_attr.version.major, dpbp_attr.version.minor); + printf("supported version is %u.%u\n", + DPBP_VER_MAJOR, DPBP_VER_MINOR); + } + dflt_dpbp->dpbp_attr.id = dpbp_attr.id; #ifdef DEBUG printf("Init: DPBP id=0x%d\n", dflt_dpbp->dpbp_attr.id); @@ -994,6 +1035,14 @@ static int dpni_init(void) goto err_get_attr; }
+ if ((dpni_attr.version.major != DPNI_VER_MAJOR) || + (dpni_attr.version.minor != DPNI_VER_MINOR)) { + printf("DPNI version mismatch found %u.%u,", + dpni_attr.version.major, dpni_attr.version.minor); + printf("supported version is %u.%u\n", + DPNI_VER_MAJOR, DPNI_VER_MINOR); + } + dflt_dpni->dpni_id = dpni_attr.id; #ifdef DEBUG printf("Init: DPNI id=0x%d\n", dflt_dpni->dpni_id); diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 69530b1..47a3a23 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -599,6 +599,29 @@ static void ldpaa_dpbp_free(void) dpbp_close(dflt_mc_io, MC_CMD_NO_FLAGS, dflt_dpbp->dpbp_handle); }
+static int ldpaa_dpmac_version_check(struct fsl_mc_io *mc_io, + struct ldpaa_eth_priv *priv) +{ + struct dpmac_attr attr; + int error; + + memset(&attr, 0, sizeof(struct dpmac_attr)); + error = dpmac_get_attributes(mc_io, MC_CMD_NO_FLAGS, + priv->dpmac_handle, + &attr); + if (error == 0) { + if ((attr.version.major != DPMAC_VER_MAJOR) || + (attr.version.minor != DPMAC_VER_MINOR)) { + printf("DPMAC version mismatch found %u.%u,", + attr.version.major, attr.version.minor); + printf("supported version is %u.%u\n", + DPMAC_VER_MAJOR, DPMAC_VER_MINOR); + } + } + + return error; +} + static int ldpaa_dpmac_setup(struct ldpaa_eth_priv *priv) { int err = 0; @@ -609,6 +632,11 @@ static int ldpaa_dpmac_setup(struct ldpaa_eth_priv *priv) &priv->dpmac_handle); if (err) printf("dpmac_create() failed\n"); + + err = ldpaa_dpmac_version_check(dflt_mc_io, priv); + if (err < 0) + printf("ldpaa_dpmac_version_check() failed: %d\n", err); + return err; }
The driver is not backward compatible, is it? Looks like every time the firmware upgrades, the driver changes.
York
-----Original Message----- From: york sun [mailto:york.sun@nxp.com] Sent: Monday, January 25, 2016 10:49 PM To: Prabhakar Kushwaha prabhakar@freescale.com; u-boot@lists.denx.de Cc: Yusong Sun yorksun@freescale.com Subject: Re: [PATCH 1/7] driver: net: fsl-mc: Add version check for MC objects
Yes, driver is not backward compatible. Each Firmware new version changes lots of things including APIs. It is still getting stable.
--prabhakar
Slightly reformat commit message. Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Prabhakar Kushwaha
Prabhakar Kushwaha
york sun
