[U-Boot] Porting Linux's MTD/NAND changes into U-Boot
Hi Scott,
I've recently contributed a lot of MTD/NAND related patches (and intend to continue doing so). Some of them are transversal changes touching the MTD and NAND framework internals, which implies patching all NAND drivers along with the core changes.
All those changes are required to properly handle modern NANDs (MLC/TLC NANDs), and I need them to add proper NAND support to the sunxi platform (and more particularly to the C.H.I.P from NextThing Co.).
So my question is, how should I port those changes to U-Boot? I see that your doing "synchronization commits", but in my case this mean including a bunch of driver specific changes into this "sync commit".
I think it's also worth mentioning that I plan to heavily rework the Linux NAND framework to improve NAND performances on modern NAND controllers and clarify the NAND chip / NAND controller concepts, and other people are also working on merging the BBT code of the NAND and OneNAND framework. Which unfortunately means that we're not done porting invasive changes to U-Boot :-/.
Any advice is welcome.
Thanks,
Boris
On Mon, Apr 25, 2016 at 04:43:14PM +0200, Boris Brezillon wrote:
Hi Scott,
I suppose my first suggestion would be to sync the kernel back into U-Boot more frequently. With our bi-monthly release cycle it shouldn't be too hard to pick a window to grab the current kernel release and bring it over. I think the more stuff we let build up prior to syncing the harder it will be.
Hi Scott,
Okay, so this means I should be the one back-porting Linux changes into U-Boot? I was planning on porting my current work on the sunxi NAND driver (including all the core dependencies) and submitting it to U-Boot, but honestly, I don't see how I can keep things in sync in the long run. From my experience, porting things to U-Boot is never as easy at it seems, and I don't think I'll have the time to maintain that by myself. Scott, what's your policy regarding Linux -> U-Boot syncs? Can I expect some help from your side?
Hi Scott,
I usually do syncs when someone complains about needing a sync. Every release seems a bit much. I'll try to do one soon.
-Scott
Hi Scott,
Hi Scott,
Great! Let me know if you need some help.
Thanks,
Boris
Hi Scott,
Hi Scott,
Sorry to bother you with that, but can I ask when you plan to do this sync (I guess you'll sync with 4.6)? As I explained, I depend on features introduced in 4.6 to make the sunxi NAND driver usable on sunxi based boards (the concept of data randomizer/scrambler is required on some MLC NANDs, and most Allwinner boards embed this kind of NAND chips).
Don't hesitate to let me know if you need some help.
Thanks,
Boris
On Mon, 2016-05-16 at 14:02 +0200, Boris Brezillon wrote:
Hi Scott,
I'm working on it now. Yes, with 4.6.
-Scott
Hello Tom, Boris,
Am 25.04.2016 um 19:36 schrieb Tom Rini:
Hi Scott,
Yes, the same applies for UBI/UBIFS. I have no real strategy yet for this. I think also, we need when doing such a sync a better testframe- work, which tests on ideally a lot of boards the new versions ...
Without this, it is very difficult not to break existing boards with such a sync ... especially MTD is tricky, I think, because a lot of boards use it ...
I know I am nerving with my tbot [1], but it is may a solution for this.
Also, as the UBI/UIFS case may show, it is not always a trivial job to do such a sync, as concepts in Linux changes ...
bye, Heiko [1] https://github.com/hsdenx/tbot
Am 26.04.2016 um 07:17 schrieb Heiko Schocher:
While we are at it, how do you QA? Did you ever port port UBI or MTD tests to u-boot and let them run? Maybe there are more issues hidden which didn't came up in quick "builds and boots a kernel" tests. ;-) As you offer the full UBI and UBIFS feature sets advanced users may get surprised.
Thanks, //richard
Hello Richard,
Am 26.04.2016 um 09:20 schrieb Richard Weinberger:
I do some very basic ubi/ubifs tests with tbot [1] on the aristainetos2 [2] and dxr2 board [3].
No, patches are welcome.
Yes, possible.
bye, Heiko
[1] https://github.com/hsdenx/tbot [2] U-Boot cyclic tests on the aristainetos2 board (used UBI on sf nor and nand, UBIFS on the nand, U-Boot test only) http://xeidos.ddns.net/buildbot/builders/ari_ubi/builds/50 [3] U-Boot / Linux UBI/UBIFS tests, last log: http://xeidos.ddns.net/buildbot/builders/dxr2/builds/12/steps/shell/logs/tbo...
participants (5)
Boris Brezillon
Heiko Schocher
Richard Weinberger
Scott Wood
