[U-Boot] (no subject)
Fix some bugs: 1. Correctly set intlv_ctl in cs_config. 2. Correctly set sa, ea in cs_bnds when bank interleaving mode is enabled. 3. Set base_address and total memory for each ddr controller in memory controller interleaving mode.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- cpu/mpc8xxx/ddr/ctrl_regs.c | 61 +++++++++++++++++++++++++++++++------- cpu/mpc8xxx/ddr/main.c | 5 +++ include/asm-ppc/fsl_ddr_sdram.h | 12 +++++++ 3 files changed, 66 insertions(+), 12 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index e6c2a5c..6297141 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -95,16 +95,10 @@ static void set_csn_config(int i, fsl_ddr_cfg_regs_t *ddr, col_bits_cs_n = dimm_params[i/2].n_col_addr - 8; }
- /* FIXME: intlv_en, intlv_ctl only on CS0_CONFIG */ - if (i != 0) { - intlv_en = 0; - intlv_ctl = 0; - } - ddr->cs[i].config = (0 | ((cs_n_en & 0x1) << 31) | ((intlv_en & 0x3) << 29) - | ((intlv_en & 0xf) << 24) + | ((intlv_ctl & 0xf) << 24) | ((ap_n_en & 0x1) << 23)
/* XXX: some implementation only have 1 bit starting at left */ @@ -874,8 +868,13 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { phys_size_t sa = 0; phys_size_t ea = 0; - if (popts->ba_intlv_ctl && i > 0) { - /* Don't set up boundaries if bank interleaving */ + + if (popts->ba_intlv_ctl && (i > 0) && + ((popts->ba_intlv_ctl & 0x60) != FSL_DDR_CS2_CS3 )) { + /* Don't set up boundaries for other CS + * other than CS0, if bank interleaving + * is enabled and not CS2+CS3 interleaved. + */ break; }
@@ -894,7 +893,9 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, * on each controller is twice the amount present on * each controller. */ - ea = (2 * common_dimm->total_mem >> dbw_cap_adj) - 1; + unsigned long long rank_density + = dimm_params[0].capacity; + ea = (2 * (rank_density >> dbw_cap_adj)) - 1; } else if (!popts->memctl_interleaving && popts->ba_intlv_ctl) { /* @@ -906,8 +907,44 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, * controller needs to be programmed into its * respective CS0_BNDS. */ - sa = common_dimm->base_address; - ea = sa + (common_dimm->total_mem >> dbw_cap_adj) - 1; + unsigned long long rank_density + = dimm_params[i/2].rank_density; + switch (popts->ba_intlv_ctl & FSL_DDR_CS0_CS1_CS2_CS3) { + case FSL_DDR_CS0_CS1_CS2_CS3: + /* CS0+CS1+CS2+CS3 interleaving, only CS0_CNDS + * needs to be set. + */ + sa = common_dimm->base_address; + ea = sa + (4 * (rank_density >> dbw_cap_adj))-1; + break; + case FSL_DDR_CS0_CS1_AND_CS2_CS3: + /* CS0+CS1 and CS2+CS3 interleaving, CS0_CNDS + * and CS2_CNDS need to be set. + */ + if (!(i&1)) { + sa = dimm_params[i/2].base_address; + ea = sa + (i * (rank_density >> + dbw_cap_adj)) - 1; + } + break; + case FSL_DDR_CS0_CS1: + /* CS0+CS1 interleaving, CS0_CNDS needs + * to be set + */ + sa = common_dimm->base_address; + ea = sa + (2 * (rank_density >> dbw_cap_adj))-1; + break; + case FSL_DDR_CS2_CS3: + /* CS2+CS3 interleaving*/ + if (i == 2) { + sa = dimm_params[i/2].base_address; + ea = sa + (2 * (rank_density >> + dbw_cap_adj)) - 1; + } + break; + default: /* No bank(chip-select) interleaving */ + break; + } } else if (popts->memctl_interleaving && !popts->ba_intlv_ctl) { /* diff --git a/cpu/mpc8xxx/ddr/main.c b/cpu/mpc8xxx/ddr/main.c index c340d56..d26c5c5 100644 --- a/cpu/mpc8xxx/ddr/main.c +++ b/cpu/mpc8xxx/ddr/main.c @@ -179,6 +179,7 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo,
if (*memctl_interleaving) { phys_addr_t addr; + phys_size_t total_mem_per_ctlr = 0;
/* * If interleaving between memory controllers, @@ -197,14 +198,18 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo,
for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { addr = 0; + pinfo->common_timing_params[i].base_address = + (phys_addr_t)addr; for (j = 0; j < CONFIG_DIMM_SLOTS_PER_CTLR; j++) { unsigned long long cap = pinfo->dimm_params[i][j].capacity;
pinfo->dimm_params[i][j].base_address = addr; addr += (phys_addr_t)(cap >> dbw_cap_adj[i]); + total_mem_per_ctlr += cap >> dbw_cap_adj[i]; } } + pinfo->common_timing_params[0].total_mem = total_mem_per_ctlr; } else { /* * Simple linear assignment if memory diff --git a/include/asm-ppc/fsl_ddr_sdram.h b/include/asm-ppc/fsl_ddr_sdram.h index 8adde34..c1ea7cd 100644 --- a/include/asm-ppc/fsl_ddr_sdram.h +++ b/include/asm-ppc/fsl_ddr_sdram.h @@ -36,6 +36,18 @@ typedef ddr2_spd_eeprom_t generic_spd_eeprom_t; typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #endif
+/* define bank(chip select) interleaving mode */ +#define FSL_DDR_CS0_CS1 0x40 +#define FSL_DDR_CS2_CS3 0x20 +#define FSL_DDR_CS0_CS1_AND_CS2_CS3 (FSL_DDR_CS0_CS1 | FSL_DDR_CS2_CS3) +#define FSL_DDR_CS0_CS1_CS2_CS3 (FSL_DDR_CS0_CS1_AND_CS2_CS3 | 0x04) + +/* define memory controller interleaving mode */ +#define FSL_DDR_CACHE_LINE_INTERLEAVING 0x0 +#define FSL_DDR_PAGE_INTERLEAVING 0x1 +#define FSL_DDR_BANK_INTERLEAVING 0x2 +#define FSL_DDR_SUPERBANK_INTERLEAVING 0x3 + /* Record of register values computed */ typedef struct fsl_ddr_cfg_regs_s { struct {
Dear Haiying Wang,
In message 1223051524-22415-1-git-send-email-Haiying.Wang@freescale.com you wrote:
Fix some bugs:
- Correctly set intlv_ctl in cs_config.
- Correctly set sa, ea in cs_bnds when bank interleaving mode is enabled.
- Set base_address and total memory for each ddr controller in memory controller interleaving mode.
Can you please (re-) submit your patches with a valid subject?
Please keep in mind that the subject is used as the tile line of the commit message, so it is essential.
On Sat, 2008-10-04 at 01:35 +0200, Wolfgang Denk wrote:
Dear Haiying Wang,
Fix some bugs:
I am so sorry, please ignore the 6 patches without subject. I recognized it right after I sent them, and re-submitted the correct patches with [PATCH n/6] in the subject.
Haiying
Haiying Wang
