[U-Boot] FDT on second address of android image
This is not a patch, but just an idea of what I would like to have. I don't know what is the best option to change the image-fit file. So I have just tried because the boot_get_fdt start to be a very long function and would make sense to split in some way. There are two point where make sense to insert this code in my opinion. As you can see here or complicated this condition
} else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) {
I don't test it so far. Anyway, I have seen that some android image (aka fsl) use this address.
diff --git a/common/image-android.c b/common/image-android.c index ee03b96..9701acd 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -146,6 +146,27 @@ int android_image_get_ramdisk(const struct andr_img_hdr *hdr, return 0; }
+int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len) +{ + if (!hdr->second_size) { + *dts_data = *dts_len = 0; + return -1; + } + + printf("Dts load addr 0x%08x size %u KiB\n", + hdr->second_addr, DIV_ROUND_UP(hdr->second_size, 1024)); + + *dts_data = (unsigned long)hdr; + *dts_data += hdr->page_size; + *dts_data += ALIGN(hdr->kernel_size, hdr->page_size); + *dts_data += ALIGN(hdr->ramdisk_size, hdr->page_size); + + *dts_len = hdr->second_size; + return 0; +} + #if !defined(CONFIG_SPL_BUILD) /** * android_print_contents - prints out the contents of the Android format image diff --git a/common/image-fdt.c b/common/image-fdt.c index 6cac7db..cdcdfd3 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -345,6 +345,30 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, fdt_addr = load; break; #endif +#if defined(CONFIG_ANDROID_BOOT_IMAGE) + case IMAGE_FORMAT_ANDROID: { + ulong fdt_data, fdt_len; + android_image_get_dts(buf, &fdt_data, &fdt_len); + if (fdt_len) { + fdt_blob = (char *)fdt_data; + printf(" Booting using the fdt at 0x%p\n", fdt_blob); + + if (fdt_check_header(fdt_blob) != 0) { + fdt_error("image is not a fdt"); + goto error; + } + + if (fdt_totalsize(fdt_blob) != fdt_len) { + fdt_error("fdt size != image size"); + goto error; + } + } else { + debug("## No Flattened Device Tree\n"); + goto no_fdt; + } + } + break; +#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format diff --git a/include/image.h b/include/image.h index 61b5d3b..f475481 100644 --- a/include/image.h +++ b/include/image.h @@ -1147,6 +1147,8 @@ struct andr_img_hdr; int android_image_check_header(const struct andr_img_hdr *hdr); int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, ulong *os_data, ulong *os_len); +int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len); int android_image_get_ramdisk(const struct andr_img_hdr *hdr, ulong *rd_data, ulong *rd_len); ulong android_image_get_end(const struct andr_img_hdr *hdr); --
We can support dts load from the second address of android image. This let us to boot board (aka freescale)
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- common/image-fdt.c | 26 ++++++++++++++++++++++++++ include/image.h | 2 ++ 2 files changed, 28 insertions(+)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 6cac7db..782c489 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -345,6 +345,31 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, fdt_addr = load; break; #endif +#if defined(CONFIG_ANDROID_BOOT_IMAGE) + case IMAGE_FORMAT_ANDROID: { + ulong fdt_data, fdt_len; + android_image_get_dts(buf, &fdt_data, &fdt_len); + if (fdt_len) { + fdt_blob = (char *)fdt_data; + printf(" Booting using the fdt at 0x%p\n", fdt_blob); + + if (fdt_check_header(fdt_blob) != 0) { + fdt_error("image is not a fdt"); + goto error; + } + + if (fdt_totalsize(fdt_blob) != fdt_len) { + fdt_error("fdt size != image size"); + goto error; + } + goto boot_fdt; + } else { + debug("## No Flattened Device Tree\n"); + goto no_fdt; + } + } + break; +#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format @@ -422,6 +447,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, goto no_fdt; }
+boot_fdt: *of_flat_tree = fdt_blob; *of_size = fdt_totalsize(fdt_blob); debug(" of_flat_tree at 0x%08lx size 0x%08lx\n", diff --git a/include/image.h b/include/image.h index 61b5d3b..f475481 100644 --- a/include/image.h +++ b/include/image.h @@ -1147,6 +1147,8 @@ struct andr_img_hdr; int android_image_check_header(const struct andr_img_hdr *hdr); int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, ulong *os_data, ulong *os_len); +int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len); int android_image_get_ramdisk(const struct andr_img_hdr *hdr, ulong *rd_data, ulong *rd_len); ulong android_image_get_end(const struct andr_img_hdr *hdr);
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- common/image-android.c | 21 +++++++++++++++++++++ common/image-fdt.c | 12 ++++++++++++ include/image.h | 2 ++ 3 files changed, 35 insertions(+)
+int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len) +{ + if (!hdr->second_size) { + *dts_data = *dts_len = 0; + return -1; + } + + printf("Dts load addr 0x%08x size %u KiB\n", + hdr->second_addr, DIV_ROUND_UP(hdr->second_size, 1024)); + + *dts_data = (unsigned long)hdr; + *dts_data += hdr->page_size; + *dts_data += ALIGN(hdr->kernel_size, hdr->page_size); + *dts_data += ALIGN(hdr->ramdisk_size, hdr->page_size); + + *dts_len = hdr->second_size; + return 0; +} + + #if !defined(CONFIG_SPL_BUILD) /** * android_print_contents - prints out the contents of the Android format image diff --git a/common/image-fdt.c b/common/image-fdt.c index 6cac7db..732a1a3 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -345,6 +345,14 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, fdt_addr = load; break; #endif +#if defined(CONFIG_ANDROID_BOOT_IMAGE) + case IMAGE_FORMAT_ANDROID: { + ulong fdt_data, fdt_len; + android_image_get_dts(buf, &fdt_data, &fdt_len); + goto boot_fdt; + } + break; +#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format @@ -400,6 +408,10 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch,
image_multi_getimg(images->legacy_hdr_os, 2, &fdt_data, &fdt_len); + +#if defined(CONFIG_ANDROID_BOOT_IMAGE) +boot_fdt: +#endif if (fdt_len) { fdt_blob = (char *)fdt_data; printf(" Booting using the fdt at 0x%p\n", fdt_blob); diff --git a/include/image.h b/include/image.h index 61b5d3b..f475481 100644 --- a/include/image.h +++ b/include/image.h @@ -1147,6 +1147,8 @@ struct andr_img_hdr; int android_image_check_header(const struct andr_img_hdr *hdr); int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, ulong *os_data, ulong *os_len); +int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len); int android_image_get_ramdisk(const struct andr_img_hdr *hdr, ulong *rd_data, ulong *rd_len); ulong android_image_get_end(const struct andr_img_hdr *hdr);
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changes: v2 -> v3: Move variable fdt_data and fdt_len in main body v1 -> v2: reduce code and cleanup --- common/image-android.c | 21 +++++++++++++++++++++ common/image-fdt.c | 13 +++++++++++-- include/image.h | 2 ++ 3 files changed, 34 insertions(+), 2 deletions(-)
+int android_image_get_dts(const struct andr_img_hdr *hdr, + ulong *dts_data, ulong *dts_len) +{ + if (!hdr->second_size) { + *dts_data = *dts_len = 0; + return -1; + } + + printf("Dts load addr 0x%08x size %u KiB\n", + hdr->second_addr, DIV_ROUND_UP(hdr->second_size, 1024)); + + *dts_data = (unsigned long)hdr; + *dts_data += hdr->page_size; + *dts_data += ALIGN(hdr->kernel_size, hdr->page_size); + *dts_data += ALIGN(hdr->ramdisk_size, hdr->page_size); + + *dts_len = hdr->second_size; + return 0; +} + + #if !defined(CONFIG_SPL_BUILD) /** * android_print_contents - prints out the contents of the Android format image diff --git a/common/image-fdt.c b/common/image-fdt.c index 6cac7db..fb4cceb 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -237,6 +237,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, ulong default_addr; int fdt_noffset; #endif + ulong fdt_data, fdt_len; const char *select = NULL; int ok_no_fdt = 0;
@@ -345,6 +346,12 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, fdt_addr = load; break; #endif +#if defined(CONFIG_ANDROID_BOOT_IMAGE) + case IMAGE_FORMAT_ANDROID: + android_image_get_dts(buf, &fdt_data, &fdt_len); + goto boot_fdt; + break; +#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format @@ -389,8 +396,6 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) { - ulong fdt_data, fdt_len; - /* * Now check if we have a legacy multi-component image, * get second entry data start address and len. @@ -400,6 +405,10 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch,
Hi Michael,
On 13 June 2016 at 13:53, Michael Trimarchi michael@amarulasolutions.com wrote:
But please see below.
return -1;
- android_print_contents - prints out the contents of the Android format image
Won't this give an unused variable warning if CONFIG_ANDROID_BOOT_IMAGE is not defined?
goto boot_fdt;
break;
int android_image_get_ramdisk(const struct andr_img_hdr *hdr, ulong *rd_data, ulong *rd_len); ulong android_image_get_end(const struct andr_img_hdr *hdr); -- 2.8.4
Hi
On Thu, Jun 16, 2016 at 2:39 AM, Simon Glass sjg@chromium.org wrote:
Hi Michael,
return -1;
I had the same feeling but if I remember correctly the other path is always compiled. I will check and in case I will add may_unsed or somenthing similar
Michael
goto boot_fdt;
break;
Michael Trimarchi
